[geos-commits] r4151 - in branches/3.4: . include/geos/algorithm src/algorithm src/geom/prep tests/unit/algorithm
svn_geos at osgeo.org svn_geos at osgeo.org
Wed Feb 24 03:51:00 PST 2016
Author: strk
Date: 2016-02-24 03:51:00 -0800 (Wed, 24 Feb 2016)
New Revision: 4151
   branches/3.4/NEWS
   branches/3.4/include/geos/algorithm/PointLocator.h
   branches/3.4/src/algorithm/PointLocator.cpp
   branches/3.4/src/geom/prep/PreparedPoint.cpp
   branches/3.4/tests/unit/algorithm/PointLocatorTest.cpp
Fix incorrect return from PreparedPoint::intersects
Includes unit test
Patch by Daniel Baston via
https://github.com/libgeos/libgeos/pull/60
Closes #764 (3.4 branch)
Reverts r4132
Modified: branches/3.4/NEWS
--- branches/3.4/NEWS	2016-02-24 11:50:47 UTC (rev 4150)
+++ branches/3.4/NEWS	2016-02-24 11:51:00 UTC (rev 4151)
@@ -18,6 +18,7 @@
  - Update for Microsoft NMAKE (r4063)
  - Fix compilation issues while building with Visual C++ (#701)
  - Fix support of PHP bindings for version < 5.4.0 (#709)
+ - Fix incorrect return from prepared multipoint intersects (#764)
 Changes in 3.4.2
 2013-08-25
Modified: branches/3.4/include/geos/algorithm/PointLocator.h
--- branches/3.4/include/geos/algorithm/PointLocator.h	2016-02-24 11:50:47 UTC (rev 4150)
+++ branches/3.4/include/geos/algorithm/PointLocator.h	2016-02-24 11:51:00 UTC (rev 4151)
@@ -31,6 +31,7 @@
 		class LinearRing;
 		class LineString;
 		class Polygon;
+		class Point;
@@ -93,6 +94,8 @@
 	void updateLocationInfo(int loc);
+	int locate(const geom::Coordinate& p, const geom::Point *pt);
 	int locate(const geom::Coordinate& p, const geom::LineString *l);
 	int locateInPolygonRing(const geom::Coordinate& p, const geom::LinearRing *ring);
Modified: branches/3.4/src/algorithm/PointLocator.cpp
--- branches/3.4/src/algorithm/PointLocator.cpp	2016-02-24 11:50:47 UTC (rev 4150)
+++ branches/3.4/src/algorithm/PointLocator.cpp	2016-02-24 11:51:00 UTC (rev 4151)
@@ -20,6 +20,7 @@
 #include <geos/algorithm/PointLocator.h>
 #include <geos/algorithm/CGAlgorithms.h>
 #include <geos/geom/Geometry.h>
+#include <geos/geom/Point.h>
 #include <geos/geom/LineString.h>
 #include <geos/geom/LinearRing.h>
 #include <geos/geom/MultiLineString.h>
@@ -61,9 +62,12 @@
 void
 PointLocator::computeLocation(const Coordinate& p, const Geometry *geom)
-	if (const LineString *ls=dynamic_cast<const LineString*>(geom))
+	if (const Point *pt=dynamic_cast<const Point*>(geom))
+		updateLocationInfo(locate(p, pt));
+	else if (const LineString *ls=dynamic_cast<const LineString*>(geom))
 		updateLocationInfo(locate(p, ls));
 	else if (const Polygon *po=dynamic_cast<const Polygon*>(geom))
@@ -111,6 +115,17 @@
 /* private */
 int
+PointLocator::locate(const Coordinate& p, const Point *pt)
+	// no point in doing envelope test, since equality test is just as fast
+	const Coordinate *ptCoord = pt->getCoordinate();
+	if (ptCoord->equals2D(p))
+		return Location::INTERIOR;
+	return Location::EXTERIOR;
+/* private */
+int
 PointLocator::locate(const Coordinate& p, const LineString *l)
 	const CoordinateSequence* pt=l->getCoordinatesRO();
Modified: branches/3.4/src/geom/prep/PreparedPoint.cpp
--- branches/3.4/src/geom/prep/PreparedPoint.cpp	2016-02-24 11:50:47 UTC (rev 4150)
+++ branches/3.4/src/geom/prep/PreparedPoint.cpp	2016-02-24 11:51:00 UTC (rev 4151)
@@ -18,7 +18,6 @@
 #include <geos/geom/prep/PreparedPoint.h>
-#include <geos/geom/Point.h>
 namespace geos {
 namespace geom { // geos.geom
@@ -29,10 +28,6 @@
 	if (! envelopesIntersect( g)) return false;
-	const Point *pt_geom = dynamic_cast<const Point *>(g);
-	if (pt_geom)
-        return getGeometry().equals(g);
 	// This avoids computing topology for the test geometry
 	return isAnyTargetComponentInTest( g);
Modified: branches/3.4/tests/unit/algorithm/PointLocatorTest.cpp
--- branches/3.4/tests/unit/algorithm/PointLocatorTest.cpp	2016-02-24 11:50:47 UTC (rev 4150)
+++ branches/3.4/tests/unit/algorithm/PointLocatorTest.cpp	2016-02-24 11:51:00 UTC (rev 4151)
@@ -96,8 +96,15 @@
 	    runPtLocator(Location::EXTERIOR, Coordinate(11, 11),
 	                     "LINEARRING(10 10, 10 20, 20 10, 10 10)");
+	// 5 - TestPointLocator Point inside MultiPoint
+	template<>
+	template<>
+	void object::test<5>()
+		runPtLocator(Location::INTERIOR, Coordinate(0, 0),
+				"MULTIPOINT ((1 1), (0 0))");
 } // namespace tut
More information about the geos-commits mailing list
