[geos-commits] r4140 - in branches/3.5: . include/geos/geomgraph include/geos/geomgraph/index src/geomgraph src/geomgraph/index src/operation/valid
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Jan 19 16:02:47 PST 2016
Author: pramsey
Date: 2016-01-19 16:02:46 -0800 (Tue, 19 Jan 2016)
New Revision: 4140
   branches/3.5/NEWS
   branches/3.5/include/geos/geomgraph/GeometryGraph.h
   branches/3.5/include/geos/geomgraph/index/SegmentIntersector.h
   branches/3.5/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
   branches/3.5/src/geomgraph/GeometryGraph.cpp
   branches/3.5/src/geomgraph/index/SegmentIntersector.cpp
   branches/3.5/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp
   branches/3.5/src/operation/valid/ConsistentAreaTester.cpp
   branches/3.5/src/operation/valid/IsValidOp.cpp
#757, fix memory exhaustion case in isvalid
Modified: branches/3.5/NEWS
--- branches/3.5/NEWS	2015-12-31 08:25:06 UTC (rev 4139)
+++ branches/3.5/NEWS	2016-01-20 00:02:46 UTC (rev 4140)
@@ -6,6 +6,7 @@
   - Fix memory leaks in single-sided buffers (#747), PlanarGraph and tests
   - Fix GeometryEditor to correctly update factory of empty geometries (#749)
   - Fix snapping of last segment of a closed linestring (#758)
+  - Fix memory exhaustion case in isvalid (#757)
 Changes in 3.5.0
 2015-08-15
Modified: branches/3.5/include/geos/geomgraph/GeometryGraph.h
--- branches/3.5/include/geos/geomgraph/GeometryGraph.h	2015-12-31 08:25:06 UTC (rev 4139)
+++ branches/3.5/include/geos/geomgraph/GeometryGraph.h	2016-01-20 00:02:46 UTC (rev 4140)
@@ -219,12 +219,25 @@
 		return computeSelfNodes(*li, computeRingSelfNodes, env);
+	index::SegmentIntersector* computeSelfNodes(
+			algorithm::LineIntersector *li,
+			bool computeRingSelfNodes,
+			bool isDoneIfProperInt,
+			const geom::Envelope *env=0)
+		return computeSelfNodes(*li, computeRingSelfNodes, isDoneIfProperInt, env);
 	// Quick inline calling the function above, the above should probably
 	// be deprecated.
 			algorithm::LineIntersector& li,
 			bool computeRingSelfNodes, const geom::Envelope *env=0);
+			algorithm::LineIntersector& li,
+			bool computeRingSelfNodes, bool isDoneIfProperInt, const geom::Envelope *env=0);
 	index::SegmentIntersector* computeEdgeIntersections(GeometryGraph *g,
 		algorithm::LineIntersector *li, bool includeProper,
Modified: branches/3.5/include/geos/geomgraph/index/SegmentIntersector.h
--- branches/3.5/include/geos/geomgraph/index/SegmentIntersector.h	2015-12-31 08:25:06 UTC (rev 4139)
+++ branches/3.5/include/geos/geomgraph/index/SegmentIntersector.h	2016-01-20 00:02:46 UTC (rev 4140)
@@ -56,6 +56,10 @@
 	bool hasProperInterior;
+	bool isDone;
+	bool isDoneWhenProperInt;
 	// the proper intersection point found
 	geom::Coordinate properIntersectionPoint;
@@ -99,6 +103,8 @@
 		hasIntersectionVar(false),
 		hasProper(false),
 		hasProperInterior(false),
+		isDone(false),
+		isDoneWhenProperInt(false),
 		li(newLi),
 		includeProper(newIncludeProper),
 		recordIsolated(newRecordIsolated),
@@ -123,6 +129,10 @@
 	void addIntersections(Edge *e0, int segIndex0, Edge *e1, int segIndex1);
+	void setIsDoneIfProperInt(bool isDoneWhenProperInt);
+	bool getIsDone();
 } // namespace geos.geomgraph.index
Modified: branches/3.5/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
--- branches/3.5/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h	2015-12-31 08:25:06 UTC (rev 4139)
+++ branches/3.5/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h	2016-01-20 00:02:46 UTC (rev 4140)
@@ -20,6 +20,7 @@
 #include <vector>
 #include <geos/geomgraph/index/EdgeSetIntersector.h> // for inheritance
+#include <geos/geomgraph/index/SegmentIntersector.h>
 #ifdef _MSC_VER
 #pragma warning(push)
@@ -31,7 +32,7 @@
 	namespace geomgraph {
 		class Edge;
 		namespace index {
-			class SegmentIntersector;
+			// class SegmentIntersector;
 			class SweepLineEvent;
Modified: branches/3.5/src/geomgraph/GeometryGraph.cpp
--- branches/3.5/src/geomgraph/GeometryGraph.cpp	2015-12-31 08:25:06 UTC (rev 4139)
+++ branches/3.5/src/geomgraph/GeometryGraph.cpp	2016-01-20 00:02:46 UTC (rev 4140)
@@ -363,31 +363,35 @@
 GeometryGraph::computeSelfNodes(LineIntersector &li,
   bool computeRingSelfNodes, const Envelope *env)
-	SegmentIntersector *si=new SegmentIntersector(&li,true,false);
-    	auto_ptr<EdgeSetIntersector> esi(createEdgeSetIntersector());
+	return computeSelfNodes(li, computeRingSelfNodes, false, env);
+SegmentIntersector*
+GeometryGraph::computeSelfNodes(LineIntersector &li,
+  bool computeRingSelfNodes, bool isDoneIfProperInt, const Envelope *env)
+	SegmentIntersector *si = new SegmentIntersector(&li, true, false);
+	si->setIsDoneIfProperInt(isDoneIfProperInt);
+	auto_ptr<EdgeSetIntersector> esi(createEdgeSetIntersector());
 	typedef vector<Edge*> EC;
 	EC *se = edges;
 	EC self_edges_copy;
 	if ( env && ! env->covers(parentGeom->getEnvelopeInternal()) ) {
 		collect_intersecting_edges(env, se->begin(), se->end(), self_edges_copy);
     //cerr << "(computeSelfNodes) Self edges reduced from " << se->size() << " to " << self_edges_copy.size() << endl;
 		se = &self_edges_copy;
-	// optimized test for Polygons and Rings
-	if (! computeRingSelfNodes
-	    && ( dynamic_cast<const LinearRing*>(parentGeom)
+	bool isRings = dynamic_cast<const LinearRing*>(parentGeom)
 	    || dynamic_cast<const Polygon*>(parentGeom)
-	    || dynamic_cast<const MultiPolygon*>(parentGeom) ))
-		esi->computeIntersections(se, si, false);
-	else
-		esi->computeIntersections(se, si, true);
+	    || dynamic_cast<const MultiPolygon*>(parentGeom);
+	bool computeAllSegments = computeRingSelfNodes || ! isRings;
+	esi->computeIntersections(se, si, computeAllSegments);
 #if GEOS_DEBUG
 	cerr << "SegmentIntersector # tests = " << si->numTests << endl;
 #endif // GEOS_DEBUG
Modified: branches/3.5/src/geomgraph/index/SegmentIntersector.cpp
--- branches/3.5/src/geomgraph/index/SegmentIntersector.cpp	2015-12-31 08:25:06 UTC (rev 4139)
+++ branches/3.5/src/geomgraph/index/SegmentIntersector.cpp	2016-01-20 00:02:46 UTC (rev 4140)
@@ -73,6 +73,18 @@
 	return hasIntersectionVar;
+void
+SegmentIntersector::setIsDoneIfProperInt(bool idwpi)
+	isDoneWhenProperInt = idwpi;
+bool
+SegmentIntersector::getIsDone()
+	return isDone;
  * A proper intersection is an intersection which is interior to at least two
  * line segments.  Note that a proper intersection is not necessarily
@@ -184,6 +196,10 @@
 				cerr<<"SegmentIntersector::addIntersections(): properIntersectionPoint: "<<properIntersectionPoint.toString()<<endl;
 #endif // DEBUG_INTERSECT
 				hasProper=true;
+				if (isDoneWhenProperInt)
+					isDone = true;
 				if (!isBoundaryPoint(li,bdyNodes))
 					hasProperInterior=true;
Modified: branches/3.5/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp
--- branches/3.5/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp	2015-12-31 08:25:06 UTC (rev 4139)
+++ branches/3.5/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp	2016-01-20 00:02:46 UTC (rev 4140)
@@ -135,6 +135,10 @@
 			processOverlaps(i,ev->getDeleteEventIndex(),ev,si);
+		if (si->getIsDone())
+			break;
Modified: branches/3.5/src/operation/valid/ConsistentAreaTester.cpp
--- branches/3.5/src/operation/valid/ConsistentAreaTester.cpp	2015-12-31 08:25:06 UTC (rev 4139)
+++ branches/3.5/src/operation/valid/ConsistentAreaTester.cpp	2016-01-20 00:02:46 UTC (rev 4140)
@@ -69,7 +69,10 @@
 	 * To fully check validity, it is necessary to
 	 * compute ALL intersections, including self-intersections within a single edge.
-	auto_ptr<SegmentIntersector> intersector(geomGraph->computeSelfNodes(&li, true));
+	auto_ptr<SegmentIntersector> intersector(geomGraph->computeSelfNodes(&li, true, true));
+	* A proper intersection means that the area is not consistent.
 	if (intersector->hasProperIntersection()) {
 		invalidPoint=intersector->getProperIntersectionPoint();
 		return false;
Modified: branches/3.5/src/operation/valid/IsValidOp.cpp
--- branches/3.5/src/operation/valid/IsValidOp.cpp	2015-12-31 08:25:06 UTC (rev 4139)
+++ branches/3.5/src/operation/valid/IsValidOp.cpp	2016-01-20 00:02:46 UTC (rev 4140)
@@ -189,7 +189,7 @@
 	if (validErr!=NULL) return;
 	LineIntersector li;
-	delete graph.computeSelfNodes(&li, true);
+	delete graph.computeSelfNodes(&li, true, true);
 	checkNoSelfIntersectingRings(&graph);
More information about the geos-commits mailing list
