[geos-commits] r4212 - trunk
Mateusz Loskot mateusz at loskot.net
Tue Jun 7 16:21:31 PDT 2016
Author: mloskot
Date: 2016-06-07 16:21:31 -0700 (Tue, 07 Jun 2016)
New Revision: 4212
Added:
   trunk/appveyor.yml
First stab at AppVeyor configuration
Added: trunk/appveyor.yml
--- trunk/appveyor.yml	                        (rev 0)
+++ trunk/appveyor.yml	2016-06-07 23:21:31 UTC (rev 4212)
@@ -0,0 +1,60 @@
+version: 1.0.{build}
+os: Visual Studio 2015
+platform: x64
+configuration: Release
+branches:
+  only:
+    - svn-trunk
+    - svn-3.5
+shallow_clone: true
+clone_depth: 5
+matrix:
+  fast_finish: false # set this flag to immediately finish build once one of the jobs fails.
+environment:
+  matrix:
+    - CFG: Debug
+      PLATFORM: Win32
+    - CFG: Release
+      PLATFORM: Win64
+init:
+  - ps: |
+      Write-Host "Build worker environment variables:" -ForegroundColor Magenta
+      Get-ChildItem Env: | %{"{0}={1}" -f $_.Name,$_.Value}
+before_build:
+  - ps: |
+      if ($env:PLATFORM -Match "Win32") {
+        $G="Visual Studio 14 2015"
+      } elseif ($env:PLATFORM -Match "Win64") {
+        $G="Visual Studio 14 2015 Win64"
+      Write-Host "Running CMake:" -ForegroundColor Magenta
+      cmake.exe -G $G -DCMAKE_BUILD_TYPE=$env:CFG %APPVEYOR_BUILD_FOLDER%
+      Write-Host "Running MSBuild:" -ForegroundColor Magenta
+  - ps:
+build:
+  parallel: true
+  project: GEOS.sln
+  verbosity: minimal
+test_script:
+  - ps: |
+      $cmd = 'ctest -V --output-on-failure -C ' + $Env:CFG
+      iex "& $cmd"
+      if ($LastExitCode -ne 0) { $host.SetShouldExit($LastExitCode) }
+# If you need to debug AppVeyor session (https://www.appveyor.com/docs/how-to/rdp-to-build-worker), then:
+# 1. Uncomment the on_finish section below:
+#on_finish:
+#  - ps: $blockRdp = $true; iex ((new-object net.webclient).DownloadString('https://raw.githubusercontent.com/appveyor/ci/master/scripts/enable-rdp.ps1'))
+# 2. Add this line to the init section below
+#- ps: iex ((new-object net.webclient).DownloadString('https://raw.githubusercontent.com/appveyor/ci/master/scripts/enable-rdp.ps1'))
More information about the geos-commits mailing list
