[geos-commits] r4167 - in trunk/src: algorithm geomgraph operation/buffer
svn_geos at osgeo.org
Sun Mar 6 05:51:05 PST 2016
Author: mloskot
Date: 2016-03-06 05:51:05 -0800 (Sun, 06 Mar 2016)
New Revision: 4167
trunk/src/algorithm/Centroid.cpp
trunk/src/geomgraph/EdgeEndStar.cpp
trunk/src/operation/buffer/BufferBuilder.cpp
Clean up a bunch of MSVC++ 14.0 warning C4456: declaration of 'x' hides previous local declaration
Modified: trunk/src/algorithm/Centroid.cpp
--- trunk/src/algorithm/Centroid.cpp 2016-03-06 13:40:26 UTC (rev 4166)
+++ trunk/src/algorithm/Centroid.cpp 2016-03-06 13:51:05 UTC (rev 4167)
@@ -7,7 +7,7 @@
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
* See the COPYING file for more information.
@@ -70,14 +70,14 @@
if (geom.isEmpty()) return;
- if (const Point* g = dynamic_cast<const Point*>(&geom)) {
- addPoint(*g->getCoordinate());
+ if (const Point* pt = dynamic_cast<const Point*>(&geom)) {
+ addPoint(*pt->getCoordinate());
- else if (const LineString* g = dynamic_cast<const LineString*>(&geom)) {
- addLineSegments(*g->getCoordinatesRO());
+ else if (const LineString* ls = dynamic_cast<const LineString*>(&geom)) {
+ addLineSegments(*ls->getCoordinatesRO());
- else if (const Polygon* g = dynamic_cast<const Polygon*>(&geom)) {
- add(*g);
+ else if (const Polygon* p = dynamic_cast<const Polygon*>(&geom)) {
+ add(*p);
else if (const GeometryCollection* g = dynamic_cast<const GeometryCollection*>(&geom)) {
for (size_t i = 0; i < g->getNumGeometries(); i++) {
Modified: trunk/src/geomgraph/EdgeEndStar.cpp
--- trunk/src/geomgraph/EdgeEndStar.cpp 2016-03-06 13:40:26 UTC (rev 4166)
+++ trunk/src/geomgraph/EdgeEndStar.cpp 2016-03-06 13:51:05 UTC (rev 4167)
@@ -9,7 +9,7 @@
@@ -108,7 +108,7 @@
* In all other cases (e.g. the node is on a line, on a point, or
* not on the geometry at all) the edge
* has the location EXTERIOR for the geometry.
* Note that the edge cannot be on the BOUNDARY of the geometry,
* since then there would have been a parallel edge from the
* Geometry at this node also labelled BOUNDARY
@@ -218,10 +218,8 @@
if (edgeMap.size()==0) return true;
// initialize startLoc to location of last L side (if any)
- EdgeEndStar::reverse_iterator it=rbegin();
- assert(*it);
- const Label& startLabel = (*it)->getLabel();
+ assert(*rbegin());
+ const Label& startLabel = (*rbegin())->getLabel();
int startLoc = startLabel.getLocation(geomIndex, Position::LEFT);
// Found unlabelled area edge
Modified: trunk/src/operation/buffer/BufferBuilder.cpp
--- trunk/src/operation/buffer/BufferBuilder.cpp 2016-03-06 13:40:26 UTC (rev 4166)
+++ trunk/src/operation/buffer/BufferBuilder.cpp 2016-03-06 13:51:05 UTC (rev 4167)
@@ -10,7 +10,7 @@
@@ -32,9 +32,9 @@
#include <geos/operation/buffer/BufferSubgraph.h>
#include <geos/operation/buffer/SubgraphDepthLocater.h>
#include <geos/operation/overlay/OverlayOp.h>
-#include <geos/operation/overlay/snap/SnapOverlayOp.h>
-#include <geos/operation/overlay/PolygonBuilder.h>
-#include <geos/operation/overlay/OverlayNodeFactory.h>
+#include <geos/operation/overlay/snap/SnapOverlayOp.h>
+#include <geos/operation/overlay/PolygonBuilder.h>
+#include <geos/operation/overlay/OverlayNodeFactory.h>
#include <geos/operation/linemerge/LineMerger.h>
#include <geos/algorithm/LineIntersector.h>
#include <geos/noding/IntersectionAdder.h>
@@ -65,7 +65,7 @@
#define GEOS_DEBUG 0
#endif
-#ifndef JTS_DEBUG
+#ifndef JTS_DEBUG
#define JTS_DEBUG 0
#endif
@@ -149,7 +149,7 @@
// First, generate the two-sided buffer using a butt-cap.
BufferParameters modParams = bufParams;
- modParams.setEndCapStyle(BufferParameters::CAP_FLAT);
+ modParams.setEndCapStyle(BufferParameters::CAP_FLAT);
modParams.setSingleSided(false); // ignore parameter for areal-only geometries
std::auto_ptr<Geometry> buf;
@@ -174,10 +174,12 @@
OffsetCurveBuilder curveBuilder( precisionModel, modParams );
std::vector< CoordinateSequence* > lineList;
- std::auto_ptr< CoordinateSequence > coords ( g->getCoordinates() );
- curveBuilder.getSingleSidedLineCurve( coords.get(), distance,
- lineList, leftSide, !leftSide );
- coords.reset();
+ std::auto_ptr< CoordinateSequence > coords(g->getCoordinates());
+ curveBuilder.getSingleSidedLineCurve(coords.get(), distance,
+ lineList, leftSide, !leftSide);
+ coords.reset();
// Create a SegmentString from these coordinates.
SegmentString::NonConstVect curveList;
@@ -261,9 +263,9 @@
// included.
// Let's try and estimate a more accurate bound instead of just assuming
- // 98%. With 98%, the episilon grows as the buffer distance grows,
+ // 98%. With 98%, the episilon grows as the buffer distance grows,
// so that at large distance, artifacts may skip through this filter
- // Let the length of the line play a factor in the distance, which is still
+ // Let the length of the line play a factor in the distance, which is still
// going to be bounded by 98%. Take 10% of the length of the line from the buffer distance
// to try and minimize any artifacts.
const double ptDistAllowance = std::max(distance - l->getLength()*0.1, distance * 0.98);
@@ -275,7 +277,7 @@
// Clean up the front of the list.
// Loop until the line's end is not inside the buffer width from
// the startPoint.
- while ( coords->size() > 1 &&
+ while ( coords->size() > 1 &&
coords->front().distance( startPoint ) < ptDistAllowance )
// Record the end segment length.
@@ -290,7 +292,7 @@
// reference point, then delete the point.
coords->deleteAt( 0 );
coords->front().distance( endPoint ) < ptDistAllowance )
double segLength = coords->front().distance( ( *coords )[1] );
@@ -343,7 +345,7 @@
intersectedLines.reset();
if ( mergedLinesGeom->size() > 1 )
return geomFact->createMultiLineString( mergedLinesGeom );
else if ( mergedLinesGeom->size() == 1 )
@@ -375,7 +377,7 @@
// factory must be the same as the one used by the input
geomFact=g->getFactory();
- { // This scope is here to force release of resources owned by
+ { // This scope is here to force release of resources owned by
// OffsetCurveSetBuilder when we're doing with it
OffsetCurveBuilder curveBuilder(precisionModel, bufParams);
@@ -464,7 +466,7 @@
subgraphList.clear();
throw;
return resultGeom;
@@ -551,11 +553,11 @@
CoordinateSequence* cs = CoordinateSequence::removeRepeatedPoints(segStr->getCoordinates());
delete segStr;
- if ( cs->size() < 2 )
+ if ( cs->size() < 2 )
// don't insert collapsed edges
// we need to take care of the memory here as cs is a new sequence
- delete cs;
+ delete cs;
continue;
@@ -599,7 +601,7 @@
int newDelta = existingDelta + mergeDelta;
existingEdge->setDepthDelta(newDelta);
- // we have memory release responsibility
+ // we have memory release responsibility
delete e;
} else { // no matching existing edge was found
More information about the geos-commits
