[geos-commits] r4277 - branches/3.5
Sandro Santilli
strk at kbt.io
Tue Oct 25 09:33:11 PDT 2016
Author: strk
Date: 2016-10-25 09:33:11 -0700 (Tue, 25 Oct 2016)
New Revision: 4277
branches/3.5/ChangeLog
branches/3.5/NEWS
Release 3.5.1
Modified: branches/3.5/ChangeLog
--- branches/3.5/ChangeLog 2016-10-25 16:03:51 UTC (rev 4276)
+++ branches/3.5/ChangeLog 2016-10-25 16:33:11 UTC (rev 4277)
@@ -1,3 +1,185 @@
+2016-08-03 19:28 Mateusz Loskot <mateusz at loskot.net>
+ * [r4246] ., nmake.opt: Merged revision(s) 4244 from trunk:
+ Add NMAKE version from VS2015 Update 3
+2016-07-15 16:38 Sandro Santilli <strk at keybit.net>
+ * [r4232] .drone.yml: Add a "make check" step to the drone config
+2016-07-14 11:06 Sandro Santilli <strk at keybit.net>
+ * [r4225] NEWS, configure.ac, include/geos/platform.h.in: Look for
+ isnan in std:: namespace
+ Fully qualify isnan call when HAVE_ISNAN is defined
+ Tested with gcc 4.8.4
+ Fixes build with GCC-5.3.0 and higher.
+ Closes #784
+2016-07-12 17:48 Sandro Santilli <strk at keybit.net>
+ * [r4223] README.md: Use https for travis badge
+2016-07-12 17:47 Sandro Santilli <strk at keybit.net>
+ * [r4222] .drone.yml: Add .drone.yml
+2016-06-07 09:27 Mateusz Loskot <mateusz at loskot.net>
+ * [r4210] CMakeLists.txt, tests/xmltester/CMakeLists.txt: Update
+ CMake configuration based on trunk/CMakeLists.txt
+2016-05-12 09:36 Sandro Santilli <strk at keybit.net>
+ * [r4206] README.md: Add debbie and winnie build badges
+2016-04-22 16:19 Sandro Santilli <strk at keybit.net>
+ * [r4192] .gitlab-ci.yml, README.md: Add gitlab-ci config and badge
+2016-03-07 10:23 Sandro Santilli <strk at keybit.net>
+ * [r4171] .travis.yml: Report build activity in #postgis-activity
+ (not #postgis)
+ Also do not use notices
+2016-02-24 11:50 Sandro Santilli <strk at keybit.net>
+ * [r4150] NEWS, include/geos/algorithm/PointLocator.h,
+ src/algorithm/PointLocator.cpp, src/geom/prep/PreparedPoint.cpp,
+ tests/unit/algorithm/PointLocatorTest.cpp: Fix incorrect return
+ from PreparedPoint::intersects
+ Includes unit test
+ Patch by Daniel Baston via
+ https://github.com/libgeos/libgeos/pull/60
+ See #764 (for 3.5 branch)
+ Reverts r4081
+2016-02-05 08:00 Sandro Santilli <strk at keybit.net>
+ * [r4143] NEWS, src/io/StringTokenizer.cpp: Include <limits> in
+ StringTokenizer
+ Patch by Jeff Mckenna
+ Closes #766
+2016-01-20 00:02 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r4140] NEWS, include/geos/geomgraph/GeometryGraph.h,
+ include/geos/geomgraph/index/SegmentIntersector.h,
+ include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h,
+ src/geomgraph/GeometryGraph.cpp,
+ src/geomgraph/index/SegmentIntersector.cpp,
+ src/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
+ src/operation/valid/ConsistentAreaTester.cpp,
+ src/operation/valid/IsValidOp.cpp: #757, fix memory exhaustion
+ case in isvalid
+2015-12-31 08:25 Sandro Santilli <strk at keybit.net>
+ * [r4139] NEWS: Add missing 3.3.9 section
+2015-12-14 17:20 Sandro Santilli <strk at keybit.net>
+ * [r4131] NEWS, src/operation/overlay/snap/LineStringSnapper.cpp,
+ tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp: Fix
+ snapping of last segment in a closed linestring
+ See #758
+ * [r4130]
+ Enable a commented-out test (works)
+2015-11-21 16:01 Sandro Santilli <strk at keybit.net>
+ * [r4120] include/geos/triangulate/quadedge/QuadEdgeSubdivision.h,
+ src/triangulate/quadedge/QuadEdgeSubdivision.cpp: use std::vector
+ instead of std::list to avoid size() bottleneck
+ https://github.com/libgeos/libgeos/pull/55
+2015-11-04 20:41 Mateusz Loskot <mateusz at loskot.net>
+ * [r4116] NEWS: Add #753 fix
+2015-11-04 20:37 Mateusz Loskot <mateusz at loskot.net>
+ * [r4115] ., CMakeLists.txt, include/geos/platform.h.cmake: Merged
+ revision(s) 4112,4114 from trunk:
+ Add #define NOMINMAX for Visual C++
+ CMake should not try to generate geos_svn_revision.h if GEOS is
+ built from packaged sources.
+ Fixes #753
+2015-10-13 11:43 Sandro Santilli <strk at keybit.net>
+ * [r4110] NEWS, src/geom/util/GeometryEditor.cpp: Fix
+ GeometryEditor to correctly update factory of empty geometries
+ Closes #749
+2015-10-05 12:55 Mateusz Loskot <mateusz at loskot.net>
+ * [r4107] NEWS: Revert accidental removal of whitespaces in r4106.
+2015-10-05 09:45 Mateusz Loskot <mateusz at loskot.net>
+ * [r4106] NEWS: Update NEWS item about memory leaks fixes
+2015-10-05 09:44 Mateusz Loskot <mateusz at loskot.net>
+ * [r4105] ., src/geomgraph/PlanarGraph.cpp,
+ tests/unit/triangulate/DelaunayTest.cpp: Merged revision(s)
+ 4099-4100, 4104 from trunk:
+ Fix memory leaks (two) due to misuse of CoordinateArraySequence
+ Make adding edges a bit more exception safe and helps to avoid
+ memory leaks when PlanarGraph::add(de1) throws, leaving de2
+ behind.
+ This also fixes memory leak in case of self-union with NaN
+ coordinates, revealed by GEOSUnaryUnionTest/test<9>.
+ Use std::auto_ptr to simplify r4100 fix of a memory leak
+ potential
+2015-10-04 16:09 Sandro Santilli <strk at keybit.net>
+ * [r4102] NEWS: Add NEWS item about memory leaks fixes
+2015-10-04 16:08 Sandro Santilli <strk at keybit.net>
+ * [r4101] src/operation/buffer/BufferBuilder.cpp: Fix a few
+ potential (one confirmed) leak in single sided buffer
+ See #747
+2015-08-16 22:29 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r4088] NEWS: Add 3.5.1 entry to NEWS
+2015-08-16 22:28 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r4087] CMakeLists.txt, HOWTO_RELEASE, capi/geos_c.h.in,
+ configure.ac, include/geos/version.h.vc: Bump branch versions for
+ 3.5.1
+2015-08-14 18:34 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r4084] CMakeLists.txt, ChangeLog, HOWTO_RELEASE, NEWS,
+ configure.ac: Ready to tag'n'bag 3.5.0
2015-08-14 18:22 Paul Ramsey <pramsey at cleverelephant.ca>
* [r4083] .: Branch for release
Modified: branches/3.5/NEWS
--- branches/3.5/NEWS 2016-10-25 16:03:51 UTC (rev 4276)
+++ branches/3.5/NEWS 2016-10-25 16:33:11 UTC (rev 4277)
@@ -1,5 +1,5 @@
Changes in 3.5.1
-2015-MM-dd
+2015-10-25
- Bug fixes / improvements
- Fix CMake configuration to allow build from released sources package (#753)
More information about the geos-commits
