[geos-commits] r4349 - trunk
Mateusz Loskot
mateusz at loskot.net
Mon Mar 20 16:48:46 PDT 2017
Author: mloskot
Date: 2017-03-20 16:48:46 -0700 (Mon, 20 Mar 2017)
New Revision: 4349
trunk/appveyor.yml
AppVeyor: Replace build step with build_script
Modified: trunk/appveyor.yml
--- trunk/appveyor.yml 2017-03-20 23:31:59 UTC (rev 4348)
+++ trunk/appveyor.yml 2017-03-20 23:48:46 UTC (rev 4349)
@@ -20,8 +20,10 @@
environment:
matrix:
- - platform: x86
- - platform: x64
+ - PLATFORM: x86
+ GENERATOR: "Visual Studio 14 2015"
+ - PLATFORM: x64
+ GENERATOR: "Visual Studio 14 2015 Win64"
init:
- ps: |
@@ -29,28 +31,16 @@
Get-ChildItem Env: | %{"{0}={1}" -f $_.Name,$_.Value}
before_build:
- - ps: |
- if ($env:PLATFORM -Match "x86") {
- $G="Visual Studio 14 2015"
- } elseif ($env:PLATFORM -Match "x64") {
- $G="Visual Studio 14 2015 Win64"
- Write-Host "Running CMake:" -ForegroundColor Magenta
- cmake.exe -G $G -DCMAKE_BUILD_TYPE=$env:CONFIGURATION -DGEOS_ENABLE_TESTS=OFF -DGEOS_BUILD_SHARED=OFF $env:APPVEYOR_BUILD_FOLDER
- Write-Host "Running MSBuild:" -ForegroundColor Magenta
- - ps:
+ - ps: 'Write-Host "Running cmake: $env:GENERATOR" -ForegroundColor Magenta'
+ - cmake.exe -G "%GENERATOR%" -DCMAKE_BUILD_TYPE=%CONFIGURATION% -DGEOS_ENABLE_TESTS=OFF -DGEOS_BUILD_SHARED=OFF %APPVEYOR_BUILD_FOLDER%
-build:
- parallel: true
- project: GEOS.sln
- verbosity: minimal
+build_script:
+ - ps: 'Write-Host "Running cmake --build:" -ForegroundColor Magenta'
+ - cmake --build . --config %CONFIGURATION%
test_script:
- - ps: |
- Write-Host "Running CTest:" -ForegroundColor Magenta
-# $cmd = 'ctest -V --output-on-failure -C ' + $Env:CFG
-# iex "& $cmd"
-# if ($LastExitCode -ne 0) { $host.SetShouldExit($LastExitCode) }
+ - ps: 'Write-Host "Running CTest:" -ForegroundColor Magenta'
+ - ctest -V --output-on-failure -C %CONFIGURATION%
# If you need to debug AppVeyor session (https://www.appveyor.com/docs/how-to/rdp-to-build-worker), then:
# 1. Uncomment the on_finish section below:
More information about the geos-commits
