[geos-commits] r4363 - branches/3.6
Mateusz Loskot mateusz at loskot.net
Tue Mar 21 07:40:11 PDT 2017
Author: mloskot
Date: 2017-03-21 07:40:10 -0700 (Tue, 21 Mar 2017)
New Revision: 4363
   branches/3.6/appveyor.yml
AppVeyor: Restore and fix build configuration
Modified: branches/3.6/appveyor.yml
--- branches/3.6/appveyor.yml	2017-03-21 12:14:20 UTC (rev 4362)
+++ branches/3.6/appveyor.yml	2017-03-21 14:40:10 UTC (rev 4363)
@@ -1,4 +1,4 @@
-version: 1.0.{build}
+version: 1.0.{build}
 os: Visual Studio 2015
@@ -9,6 +9,7 @@
 branches:
   only:
     - svn-trunk
+    - svn-3.6
     - svn-3.5
 shallow_clone: true
@@ -19,39 +20,35 @@
 environment:
   matrix:
-    - CFG: Debug
-      PLATFORM: Win32
-    - CFG: Release
-      PLATFORM: Win64
+    - PLATFORM: x86
+      GENERATOR: "Visual Studio 14 2015"
+    - PLATFORM: x64
+      GENERATOR: "Visual Studio 14 2015 Win64"
+    - PLATFORM: x86
+      GENERATOR: "NMake Makefiles"
+    - PLATFORM: x64
 init:
-  - ps: |
-      Write-Host "Build worker environment variables:" -ForegroundColor Magenta
-      Get-ChildItem Env: | %{"{0}={1}" -f $_.Name,$_.Value}
+  - ps: 'Write-Host "Building GEOS branch: $env:APPVEYOR_REPO_BRANCH" -ForegroundColor Magenta'
+  #- ps: |
+  #  Write-Host "Build worker environment variables:" -ForegroundColor Magenta
+  #      Get-ChildItem Env: | %{"{0}={1}" -f $_.Name,$_.Value}
+  - if "%GENERATOR%"=="NMake Makefiles" if "%PLATFORM%"=="x86" call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" x86
+  - if "%GENERATOR%"=="NMake Makefiles" if "%PLATFORM%"=="x64" "C:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\SetEnv.cmd" /x64
+  - if "%GENERATOR%"=="NMake Makefiles" if "%PLATFORM%"=="x64" call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" x86_amd64
 before_build:
-  - ps: |
-      if ($env:PLATFORM -Match "Win32") {
-        $G="Visual Studio 14 2015"
-      } elseif ($env:PLATFORM -Match "Win64") {
-        $G="Visual Studio 14 2015 Win64"
-      Write-Host "Running CMake:" -ForegroundColor Magenta
-      cmake.exe -G $G -DCMAKE_BUILD_TYPE=$env:CFG $env:APPVEYOR_BUILD_FOLDER
-      Write-Host "Running MSBuild:" -ForegroundColor Magenta
-  - ps:
+  - ps: 'Write-Host "Running cmake: $env:GENERATOR" -ForegroundColor Magenta'
+  - cmake.exe -G "%GENERATOR%" -DCMAKE_BUILD_TYPE=%CONFIGURATION% %APPVEYOR_BUILD_FOLDER%
-build:
-  parallel: true
-  project: GEOS.sln
-  verbosity: minimal
+build_script:
+  - ps: 'Write-Host "Running cmake --build:" -ForegroundColor Magenta'
+  - cmake --build . --config %CONFIGURATION%
 test_script:
-  - ps: |
-      Write-Host "Running CTest:" -ForegroundColor Magenta
-      $cmd = 'ctest -V --output-on-failure -C ' + $Env:CFG
-      iex "& $cmd"
-      if ($LastExitCode -ne 0) { $host.SetShouldExit($LastExitCode) }
+  - ps: 'Write-Host "Running CTest:" -ForegroundColor Magenta'
+  - ctest -V --output-on-failure -C %CONFIGURATION%
 # If you need to debug AppVeyor session (https://www.appveyor.com/docs/how-to/rdp-to-build-worker), then:
 # 1. Uncomment the on_finish section below:
More information about the geos-commits mailing list
