[geos-commits] r4389 - in trunk: . tools
Sandro Santilli
strk at kbt.io
Fri Mar 31 12:44:55 PDT 2017
Author: strk
Date: 2017-03-31 12:44:55 -0700 (Fri, 31 Mar 2017)
New Revision: 4389
Added:
trunk/tools/repo_revision.sh
Removed:
trunk/tools/svn_repo_revision.sh
trunk/CMakeLists.txt
trunk/Makefile.am
trunk/tools/Makefile.am
Rename svn_repo_revision.sh to repo_revision.sh
.. even if it still only extracts the *SVN* revision (also from git log).
See #794
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt 2017-03-31 19:26:16 UTC (rev 4388)
+++ trunk/CMakeLists.txt 2017-03-31 19:44:55 UTC (rev 4389)
@@ -296,7 +296,7 @@
find_program(SH sh)
if(SH)
execute_process(COMMAND ${SH} -c
- "cd ${PROJECT_SOURCE_DIR} && ${PROJECT_SOURCE_DIR}/tools/svn_repo_revision.sh")
+ "cd ${PROJECT_SOURCE_DIR} && ${PROJECT_SOURCE_DIR}/tools/repo_revision.sh")
file(RENAME "${PROJECT_SOURCE_DIR}/geos_revision.h"
"${PROJECT_BINARY_DIR}/geos_revision.h")
Modified: trunk/Makefile.am
--- trunk/Makefile.am 2017-03-31 19:26:16 UTC (rev 4388)
+++ trunk/Makefile.am 2017-03-31 19:44:55 UTC (rev 4389)
@@ -54,7 +54,7 @@
cd $(srcdir) && git svn rebase --authors-file authors.git
geos_revision.h:
- top_srcdir=$(srcdir) sh $(srcdir)/tools/svn_repo_revision.sh
+ top_srcdir=$(srcdir) sh $(srcdir)/tools/repo_revision.sh
VALGRIND = $(LIBTOOL) --mode=execute valgrind --leak-check=full --error-exitcode=1
Modified: trunk/tools/Makefile.am
--- trunk/tools/Makefile.am 2017-03-31 19:26:16 UTC (rev 4388)
+++ trunk/tools/Makefile.am 2017-03-31 19:44:55 UTC (rev 4389)
@@ -2,4 +2,4 @@
# This file is part of project GEOS (http://trac.osgeo.org/geos/)
bin_SCRIPTS = geos-config
-EXTRA_DIST = CMakeLists.txt svn_repo_revision.sh
+EXTRA_DIST = CMakeLists.txt repo_revision.sh
Copied: trunk/tools/repo_revision.sh (from rev 4388, trunk/tools/svn_repo_revision.sh)
--- trunk/tools/repo_revision.sh (rev 0)
+++ trunk/tools/repo_revision.sh 2017-03-31 19:44:55 UTC (rev 4389)
@@ -0,0 +1,86 @@
+#!/bin/sh
+LC_ALL="C" # what for ?
+[ -z "$top_srcdir" ] && top_srcdir="."
+rev_file=$top_srcdir'/geos_revision.h'
+read_rev() {
+ if test -d $top_srcdir"/.svn"; then
+ read_rev_svn
+ elif test -d $top_srcdir"/.git"; then
+ read_rev_git
+ else
+ echo "Can't fetch local revision (neither .svn nor .git found)" >&2
+ echo 0
+ fi
+read_rev_git() {
+ # TODO: test on old systems, I think I saw some `which`
+ # implementations returning "nothing found" or something
+ # like that, making the later if ( ! $svn_exe ) always false
+ git_exe=`which git`;
+ if test -z "$git_exe"; then
+ echo "Can't fetch SVN revision: no git executable found" >&2
+ echo 0;
+ fi
+ rev=`cd ${top_srcdir} && ${git_exe} log --grep=git-svn -1 | grep git-svn | cut -d@ -f2 | cut -d' ' -f1`
+ if test -z "$rev"; then
+ echo "Can't fetch SVN revision from git log" >&2
+ echo 0
+ else
+ echo $rev
+ fi
+read_rev_svn() {
+ svn_exe=`which svn`
+ if test -z "$svn_exe"; then
+ echo "Can't fetch SVN revision: no svn executable found" >&2
+ echo 0;
+ fi
+ svn_info=`"${svn_exe}" info | grep 'Last Changed Rev:' | cut -d: -f2`
+ if test -z "$svn_info"; then
+ echo "Can't fetch SVN revision with `svn info`" >&2
+ echo 0
+ else
+ echo ${svn_info}
+ fi
+write_defn() {
+ rev=$1
+ oldrev=0
+ # Do not override the file if new detected
+ # revision isn't zero nor different from the existing one
+ if test -f $rev_file; then
+ oldrev=`grep GEOS_SVN_REVISION ${rev_file} | awk '{print $2}'`
+ if test "$rev" = 0 -o "$rev" = "$oldrev"; then
+ echo "Not updating existing rev file at $oldrev" >&2
+ return;
+ fi
+ fi
+ echo "#define GEOS_SVN_REVISION $rev" | tee $rev_file
+ echo "Wrote rev '$rev' in file '$rev_file'" >&2
+# Read the svn revision number
+svn_rev=`read_rev`
+# Write it
+write_defn $svn_rev
Deleted: trunk/tools/svn_repo_revision.sh
--- trunk/tools/svn_repo_revision.sh 2017-03-31 19:26:16 UTC (rev 4388)
+++ trunk/tools/svn_repo_revision.sh 2017-03-31 19:44:55 UTC (rev 4389)
@@ -1,86 +0,0 @@
-#!/bin/sh
-LC_ALL="C" # what for ?
-[ -z "$top_srcdir" ] && top_srcdir="."
-rev_file=$top_srcdir'/geos_revision.h'
-read_rev() {
- if test -d $top_srcdir"/.svn"; then
- read_rev_svn
- elif test -d $top_srcdir"/.git"; then
- read_rev_git
- else
- echo "Can't fetch local revision (neither .svn nor .git found)" >&2
- echo 0
- fi
-read_rev_git() {
- # TODO: test on old systems, I think I saw some `which`
- # implementations returning "nothing found" or something
- # like that, making the later if ( ! $svn_exe ) always false
- git_exe=`which git`;
- if test -z "$git_exe"; then
- echo "Can't fetch SVN revision: no git executable found" >&2
- echo 0;
- fi
- rev=`cd ${top_srcdir} && ${git_exe} log --grep=git-svn -1 | grep git-svn | cut -d@ -f2 | cut -d' ' -f1`
- if test -z "$rev"; then
- echo "Can't fetch SVN revision from git log" >&2
- echo 0
- else
- echo $rev
- fi
-read_rev_svn() {
- svn_exe=`which svn`
- if test -z "$svn_exe"; then
- echo "Can't fetch SVN revision: no svn executable found" >&2
- echo 0;
- fi
- svn_info=`"${svn_exe}" info | grep 'Last Changed Rev:' | cut -d: -f2`
- if test -z "$svn_info"; then
- echo "Can't fetch SVN revision with `svn info`" >&2
- echo 0
- else
- echo ${svn_info}
- fi
-write_defn() {
- rev=$1
- oldrev=0
- # Do not override the file if new detected
- # revision isn't zero nor different from the existing one
- if test -f $rev_file; then
- oldrev=`grep GEOS_SVN_REVISION ${rev_file} | awk '{print $2}'`
- if test "$rev" = 0 -o "$rev" = "$oldrev"; then
- echo "Not updating existing rev file at $oldrev" >&2
- return;
- fi
- fi
- echo "#define GEOS_SVN_REVISION $rev" | tee $rev_file
- echo "Wrote rev '$rev' in file '$rev_file'" >&2
-# Read the svn revision number
-svn_rev=`read_rev`
-# Write it
-write_defn $svn_rev
More information about the geos-commits
