[geos-commits] [SCM] geos branch master updated. b7101be6533a1273f715a3309889c23b7ae02e4f
Sat Sep 9 14:07:18 PDT 2017
the project "geos".
       via  b7101be6533a1273f715a3309889c23b7ae02e4f (commit)
      from  6f0c2bac087180369760e9fed244bb797582a3b2 (commit)
revisions in full, below.
commit b7101be6533a1273f715a3309889c23b7ae02e4f
Author: Mateusz Loskot <mateusz at loskot.net>
Date:   Sat Sep 9 22:23:43 2017 +0200
    Apply clang-tidy-4.0 modernize-use-override
    Used command:
      run-clang-tidy.py -header-filter='.*' -checks='-*,modernize-use-modernize' -fix
    Part of GEOS RFC 5: C++11 Compilation Mode
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 00e347f..45426a1 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -274,7 +274,7 @@ class CAPI_ItemVisitor : public geos::index::ItemVisitor {
   public:
     CAPI_ItemVisitor (GEOSQueryCallback cb, void *ud)
         : ItemVisitor(), callback(cb), userdata(ud) {}
-    void visitItem (void *item) { callback(item, userdata); }
+    void visitItem (void *item) override { callback(item, userdata); }
@@ -6199,7 +6199,7 @@ GEOSSTRtree_nearest_generic_r(GEOSContextHandle_t extHandle,
 				GEOSDistanceCallback m_distancefn;
 				void* m_userdata;
-				double distance(const ItemBoundable* item1, const ItemBoundable* item2) {
+				double distance(const ItemBoundable* item1, const ItemBoundable* item2) override {
 						const void* a = item1->getItem();
 						const void* b = item2->getItem();
 						double d;
diff --git a/include/geos/algorithm/MCPointInRing.h b/include/geos/algorithm/MCPointInRing.h
index 9e5160e..872cf44 100644
--- a/include/geos/algorithm/MCPointInRing.h
+++ b/include/geos/algorithm/MCPointInRing.h
@@ -50,8 +50,8 @@ namespace algorithm { // geos::algorithm
 class GEOS_DLL MCPointInRing: public PointInRing {
 public:
 	MCPointInRing(const geom::LinearRing *newRing);
-	~MCPointInRing();
-	bool isInside(const geom::Coordinate& pt);
+	~MCPointInRing() override;
+	bool isInside(const geom::Coordinate& pt) override;
 	void testLineSegment(const geom::Coordinate& p,
 	                        const geom::LineSegment& seg);
@@ -63,7 +63,7 @@ public:
 		MCPointInRing *parent;
 	public:
 		MCSelecter(const geom::Coordinate& newP, MCPointInRing *prt);
-		void select(const geom::LineSegment& ls);
+		void select(const geom::LineSegment& ls) override;
 private:
diff --git a/include/geos/algorithm/NotRepresentableException.h b/include/geos/algorithm/NotRepresentableException.h
index 5ca390c..f8a0fa7 100644
--- a/include/geos/algorithm/NotRepresentableException.h
+++ b/include/geos/algorithm/NotRepresentableException.h
@@ -36,7 +36,7 @@ class GEOS_DLL NotRepresentableException: public util::GEOSException {
 public:
 	NotRepresentableException();
 	NotRepresentableException(std::string msg);
-	~NotRepresentableException() throw() {}
+	~NotRepresentableException() throw() override {}
 } // namespace geos::algorithm
diff --git a/include/geos/algorithm/SIRtreePointInRing.h b/include/geos/algorithm/SIRtreePointInRing.h
index ab56449..cb29a69 100644
--- a/include/geos/algorithm/SIRtreePointInRing.h
+++ b/include/geos/algorithm/SIRtreePointInRing.h
@@ -49,8 +49,8 @@ private:
 			geom::LineSegment *seg);
 public:
 	SIRtreePointInRing(geom::LinearRing *newRing);
-	~SIRtreePointInRing();
+	~SIRtreePointInRing() override;
diff --git a/include/geos/algorithm/SimplePointInRing.h b/include/geos/algorithm/SimplePointInRing.h
index fda9c6b..05cfeda 100644
--- a/include/geos/algorithm/SimplePointInRing.h
+++ b/include/geos/algorithm/SimplePointInRing.h
@@ -34,8 +34,8 @@ namespace algorithm { // geos::algorithm
 class GEOS_DLL SimplePointInRing: public PointInRing {
 public:
 	SimplePointInRing(geom::LinearRing *ring);
-	virtual ~SimplePointInRing();
+	~SimplePointInRing() override;
 private:
 	const geom::CoordinateSequence* pts;
diff --git a/include/geos/algorithm/distance/DiscreteHausdorffDistance.h b/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
index 54cca1f..4e6c320 100644
--- a/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
+++ b/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
@@ -160,7 +160,7 @@ public:
 			geom(geom)
-		void filter_ro(const geom::Coordinate* pt)
+		void filter_ro(const geom::Coordinate* pt) override
 			minPtDist.initialize();
 			DistanceToPoint::computeDistance(geom, *pt,
@@ -198,11 +198,11 @@ public:
 		void filter_ro(const geom::CoordinateSequence& seq,
-		               std::size_t index);
+		               std::size_t index) override;
-		bool isGeometryChanged() const { return false; }
+		bool isGeometryChanged() const override { return false; }
-		bool isDone() const { return false; }
+		bool isDone() const override { return false; }
 		const PointPairDistance& getMaxPointDistance() const {
 			return maxPtDist;
diff --git a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
index 96329a8..d10b290 100644
--- a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
+++ b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
@@ -84,10 +84,10 @@ private:
 		:	counter( counter)
-		~SegmentVisitor()
+		~SegmentVisitor() override
-		void visitItem( void * item);
+		void visitItem( void * item) override;
@@ -107,7 +107,7 @@ public:
 	IndexedPointInAreaLocator( const geom::Geometry & g);
-	~IndexedPointInAreaLocator();
+	~IndexedPointInAreaLocator() override;
 	 * Determines the {@link Location} of a point in an areal {@link Geometry}.
@@ -115,7 +115,7 @@ public:
 	 * @param p the point to test
 	 * @return the location of the point in the geometry
-	int locate( const geom::Coordinate * /*const*/ p);
+	int locate( const geom::Coordinate * /*const*/ p) override;
diff --git a/include/geos/algorithm/locate/SimplePointInAreaLocator.h b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
index 58f1221..c9f0f89 100644
--- a/include/geos/algorithm/locate/SimplePointInAreaLocator.h
+++ b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
@@ -59,7 +59,7 @@ public:
 	:	g( g)
-	int locate( const geom::Coordinate * p)
+	int locate( const geom::Coordinate * p) override
 		return locate( *p, g);
diff --git a/include/geos/geom/CoordinateArraySequence.h b/include/geos/geom/CoordinateArraySequence.h
index edc1b9e..c080b63 100644
--- a/include/geos/geom/CoordinateArraySequence.h
+++ b/include/geos/geom/CoordinateArraySequence.h
@@ -41,22 +41,22 @@ public:
 	CoordinateArraySequence(const CoordinateSequence &cl);
-	CoordinateSequence *clone() const;
+	CoordinateSequence *clone() const override;
 	//const Coordinate& getCoordinate(int pos) const;
-	const Coordinate& getAt(std::size_t pos) const;
+	const Coordinate& getAt(std::size_t pos) const override;
 	/// Copy Coordinate at position i to Coordinate c
-	virtual void getAt(std::size_t i, Coordinate& c) const;
+	void getAt(std::size_t i, Coordinate& c) const override;
 	//int size() const;
-	size_t getSize() const;
+	size_t getSize() const override;
 	// @deprecated
-	const std::vector<Coordinate>* toVector() const;
+	const std::vector<Coordinate>* toVector() const override;
 	// See dox in CoordinateSequence.h
-	void toVector(std::vector<Coordinate>&) const;
+	void toVector(std::vector<Coordinate>&) const override;
 	/// Construct an empty sequence
 	CoordinateArraySequence();
@@ -68,18 +68,18 @@ public:
 	/// Construct sequence allocating space for n coordinates
 	CoordinateArraySequence(std::size_t n, std::size_t dimension = 0);
-	~CoordinateArraySequence();
+	~CoordinateArraySequence() override;
-	bool isEmpty() const { return empty(); }
+	bool isEmpty() const override { return empty(); }
 	bool empty() const { return vect->empty(); }
 	/// Reset this CoordinateArraySequence to the empty state
 	void clear() { vect->clear(); }
-	void add(const Coordinate& c);
+	void add(const Coordinate& c) override;
-	virtual void add(const Coordinate& c, bool allowRepeated);
+	void add(const Coordinate& c, bool allowRepeated) override;
 	/** \brief
 	 * Inserts the specified coordinate at the specified position in
@@ -92,31 +92,31 @@ public:
 	 * NOTE: this is a CoordinateList interface in JTS
-	virtual void add(std::size_t i, const Coordinate& coord, bool allowRepeated);
+	void add(std::size_t i, const Coordinate& coord, bool allowRepeated) override;
-	void setAt(const Coordinate& c, std::size_t pos);
+	void setAt(const Coordinate& c, std::size_t pos) override;
-	void deleteAt(std::size_t pos);
+	void deleteAt(std::size_t pos) override;
-	std::string toString() const;
+	std::string toString() const override;
-	void setPoints(const std::vector<Coordinate> &v);
+	void setPoints(const std::vector<Coordinate> &v) override;
 	double getOrdinate(std::size_t index,
-			size_t ordinateIndex) const;
+			size_t ordinateIndex) const override;
 	void setOrdinate(std::size_t index, std::size_t ordinateIndex,
-			double value);
+			double value) override;
-	void expandEnvelope(Envelope &env) const;
+	void expandEnvelope(Envelope &env) const override;
-    std::size_t getDimension() const;
+    std::size_t getDimension() const override;
-	void apply_rw(const CoordinateFilter *filter);
+	void apply_rw(const CoordinateFilter *filter) override;
-	void apply_ro(CoordinateFilter *filter) const;
+	void apply_ro(CoordinateFilter *filter) const override;
-	virtual CoordinateSequence& removeRepeatedPoints();
+	CoordinateSequence& removeRepeatedPoints() override;
 private:
 	std::vector<Coordinate> *vect;
diff --git a/include/geos/geom/CoordinateArraySequenceFactory.h b/include/geos/geom/CoordinateArraySequenceFactory.h
index 9d779af..3519480 100644
--- a/include/geos/geom/CoordinateArraySequenceFactory.h
+++ b/include/geos/geom/CoordinateArraySequenceFactory.h
@@ -43,14 +43,14 @@ namespace geom { // geos::geom
 class GEOS_DLL CoordinateArraySequenceFactory: public CoordinateSequenceFactory {
 public:
-	CoordinateSequence *create() const;
+	CoordinateSequence *create() const override;
-	CoordinateSequence *create(std::vector<Coordinate> *coords, std::size_t dims=0) const;
+	CoordinateSequence *create(std::vector<Coordinate> *coords, std::size_t dims=0) const override;
    	/** @see CoordinateSequenceFactory::create(std::size_t, int) */
-	CoordinateSequence *create(std::size_t size, std::size_t dimension=0) const;
+	CoordinateSequence *create(std::size_t size, std::size_t dimension=0) const override;
-	CoordinateSequence *create(const CoordinateSequence &coordSeq) const;
+	CoordinateSequence *create(const CoordinateSequence &coordSeq) const override;
 	/** \brief
 	 * Returns the singleton instance of CoordinateArraySequenceFactory
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index d82502a..4deb2e5 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -835,7 +835,7 @@ private:
 	class GEOS_DLL GeometryChangedFilter : public GeometryComponentFilter
 	public:
-		void filter_rw(Geometry* geom);
+		void filter_rw(Geometry* geom) override;
 	static GeometryChangedFilter geometryChangedFilter;
diff --git a/include/geos/geom/GeometryCollection.h b/include/geos/geom/GeometryCollection.h
index b7b5bbf..f5a2989 100644
--- a/include/geos/geom/GeometryCollection.h
+++ b/include/geos/geom/GeometryCollection.h
@@ -72,11 +72,11 @@ public:
 	 * @return a clone of this instance
-	virtual Geometry *clone() const {
+	Geometry *clone() const override {
 		return new GeometryCollection(*this);
-	virtual ~GeometryCollection();
+	~GeometryCollection() override;
 	 * \brief
@@ -91,9 +91,9 @@ public:
 	 * @return the collected coordinates
-	virtual CoordinateSequence* getCoordinates() const;
+	CoordinateSequence* getCoordinates() const override;
-	virtual bool isEmpty() const;
+	bool isEmpty() const override;
 	 * \brief
@@ -102,60 +102,60 @@ public:
 	 * @see Dimension::DimensionType
-	virtual Dimension::DimensionType getDimension() const;
+	Dimension::DimensionType getDimension() const override;
 	/// Returns coordinate dimension.
-	virtual int getCoordinateDimension() const;
+	int getCoordinateDimension() const override;
-	virtual Geometry* getBoundary() const;
+	Geometry* getBoundary() const override;
 	 * \brief
 	 * Returns the maximum boundary dimension of geometries in
 	 * this collection.
-	virtual int getBoundaryDimension() const;
+	int getBoundaryDimension() const override;
-	virtual std::size_t getNumPoints() const;
+	std::size_t getNumPoints() const override;
-	virtual std::string getGeometryType() const;
+	std::string getGeometryType() const override;
-	virtual GeometryTypeId getGeometryTypeId() const;
+	GeometryTypeId getGeometryTypeId() const override;
-	virtual bool equalsExact(const Geometry *other,
-			double tolerance=0) const;
+	bool equalsExact(const Geometry *other,
+			double tolerance=0) const override;
-	virtual void apply_ro(CoordinateFilter *filter) const;
-	virtual void apply_rw(const CoordinateFilter *filter);
-	virtual void apply_ro(GeometryFilter *filter) const;
+	void apply_ro(GeometryFilter *filter) const override;
-	virtual void apply_rw(GeometryFilter *filter);
+	void apply_rw(GeometryFilter *filter) override;
-	virtual void apply_ro(GeometryComponentFilter *filter) const;
+	void apply_ro(GeometryComponentFilter *filter) const override;
-	virtual void apply_rw(GeometryComponentFilter *filter);
+	void apply_rw(GeometryComponentFilter *filter) override;
-	virtual void apply_rw(CoordinateSequenceFilter& filter);
+	void apply_rw(CoordinateSequenceFilter& filter) override;
-	virtual void apply_ro(CoordinateSequenceFilter& filter) const;
+	void apply_ro(CoordinateSequenceFilter& filter) const override;
-	virtual void normalize();
+	void normalize() override;
-	virtual const Coordinate* getCoordinate() const;
+	const Coordinate* getCoordinate() const override;
 	/// Returns the total area of this collection
-	virtual double getArea() const;
+	double getArea() const override;
 	/// Returns the total length of this collection
-	virtual double getLength() const;
+	double getLength() const override;
 	/// Returns the number of geometries in this collection
-	virtual std::size_t getNumGeometries() const;
+	std::size_t getNumGeometries() const override;
 	/// Returns a pointer to the nth Geometry int this collection
-	virtual const Geometry* getGeometryN(std::size_t n) const;
+	const Geometry* getGeometryN(std::size_t n) const override;
 protected:
@@ -190,9 +190,9 @@ protected:
 	std::vector<Geometry *>* geometries;
-	Envelope::Ptr computeEnvelopeInternal() const;
+	Envelope::Ptr computeEnvelopeInternal() const override;
-	int compareToSameClass(const Geometry *gc) const;
+	int compareToSameClass(const Geometry *gc) const override;
diff --git a/include/geos/geom/LineString.h b/include/geos/geom/LineString.h
index 72fa019..7b84299 100644
--- a/include/geos/geom/LineString.h
+++ b/include/geos/geom/LineString.h
@@ -76,7 +76,7 @@ public:
 	/// A vector of const LineString pointers
 	typedef std::vector<const LineString *> ConstVect;
-	virtual ~LineString();
+	~LineString() override;
 	 * \brief
@@ -85,9 +85,9 @@ public:
 	 * @return A clone of this instance
-	virtual Geometry *clone() const;
+	Geometry *clone() const override;
 	/// Returns a read-only pointer to internal CoordinateSequence
 	const CoordinateSequence* getCoordinatesRO() const;
@@ -95,28 +95,28 @@ public:
 	virtual const Coordinate& getCoordinateN(int n) const;
 	/// Returns line dimension (1)
 	 * \brief
 	 * Returns Dimension::False for a closed LineString,
 	 * 0 otherwise (LineString boundary is a MultiPoint)
 	 * \brief
 	 * Returns a MultiPoint.
 	 * Empty for closed LineString, a Point for each vertex otherwise.
 	virtual Point* getPointN(std::size_t n) const;
@@ -136,30 +136,30 @@ public:
 	virtual bool isRing() const;
 	virtual bool isCoordinate(Coordinate& pt) const;
-	virtual bool equalsExact(const Geometry *other, double tolerance=0)
-		const;
+	bool equalsExact(const Geometry *other, double tolerance=0)
+		const override;
-	void apply_rw(CoordinateSequenceFilter& filter);
-	void apply_ro(CoordinateSequenceFilter& filter) const;
 	/** \brief
 	 * Normalizes a LineString.
@@ -168,14 +168,14 @@ public:
 	 * has the first point which is not equal to its reflected point
 	 * less than the reflected point.
 	//was protected
-	virtual int compareToSameClass(const Geometry *ls) const;
+	int compareToSameClass(const Geometry *ls) const override;
 	 * Creates a LineString whose coordinates are in the reverse
@@ -198,7 +198,7 @@ protected:
 	LineString(CoordinateSequence::Ptr pts,
 			const GeometryFactory *newFactory);
 	CoordinateSequence::Ptr points;
diff --git a/include/geos/geom/LinearRing.h b/include/geos/geom/LinearRing.h
index 873dd8a..4b34776 100644
--- a/include/geos/geom/LinearRing.h
+++ b/include/geos/geom/LinearRing.h
 	LinearRing(CoordinateSequence::Ptr points,
-	virtual Geometry *clone() const { return new LinearRing(*this); }
+	Geometry *clone() const override { return new LinearRing(*this); }
-	virtual ~LinearRing();
+	~LinearRing() override;
 	/** \brief
 	 * Returns <code>Dimension.FALSE</code>, since by definition
@@ -95,7 +95,7 @@ public:
 	 * @return Dimension::False
-	int getBoundaryDimension() const;
 	/** \brief
 	 * Returns <code>true</code>, since by definition LinearRings
@@ -105,13 +105,13 @@ public:
 	 * @see Geometry::isSimple
-	bool isSimple() const;
+	bool isSimple() const override;
-	bool isClosed() const;
+	bool isClosed() const override;
-	std::string getGeometryType() const;
 	void setPoints(CoordinateSequence* cl);
diff --git a/include/geos/geom/MultiLineString.h b/include/geos/geom/MultiLineString.h
index c652fb3..da411bf 100644
--- a/include/geos/geom/MultiLineString.h
+++ b/include/geos/geom/MultiLineString.h
@@ -54,30 +54,30 @@ public:
 	friend class GeometryFactory;
-	virtual ~MultiLineString();
+	~MultiLineString() override;
-	Dimension::DimensionType getDimension() const;
 	 * \brief
 	 * Returns Dimension::False if all LineStrings in the collection
 	 * are closed, 0 otherwise.
 	/// Returns a (possibly empty) MultiPoint
-	Geometry* getBoundary() const;
-	bool equalsExact(const Geometry *other, double tolerance=0) const;
+	bool equalsExact(const Geometry *other, double tolerance=0) const override;
-	Geometry *clone() const;
 	 * Creates a MultiLineString in the reverse
diff --git a/include/geos/geom/MultiPoint.h b/include/geos/geom/MultiPoint.h
index eec7419..5dac6e0 100644
--- a/include/geos/geom/MultiPoint.h
+++ b/include/geos/geom/MultiPoint.h
@@ -59,13 +59,13 @@ public:
-	virtual ~MultiPoint();
+	~MultiPoint() override;
 	/// Returns point dimension (0)
 	/// Returns Dimension::False (Point has no boundary)
 	/** \brief
 	 * Gets the boundary of this geometry.
@@ -76,15 +76,15 @@ public:
 	 * @return an empty GeometryCollection
 	 * @see Geometry#getBoundary
-	Geometry *clone() const { return new MultiPoint(*this); }
+	Geometry *clone() const override { return new MultiPoint(*this); }
 protected:
diff --git a/include/geos/geom/MultiPolygon.h b/include/geos/geom/MultiPolygon.h
index 9bf6428..bb4ce98 100644
--- a/include/geos/geom/MultiPolygon.h
+++ b/include/geos/geom/MultiPolygon.h
@@ -63,13 +63,13 @@ public:
-	virtual ~MultiPolygon();
+	~MultiPolygon() override;
 	/// Returns surface dimension (2)
 	/// Returns 1 (MultiPolygon boundary is MultiLineString)
 	/** \brief
 	 * Computes the boundary of this geometry
@@ -77,17 +77,17 @@ public:
 	 * @return a lineal geometry (which may be empty)
 protected:
diff --git a/include/geos/geom/Point.h b/include/geos/geom/Point.h
index 14a5956..16e25b1 100644
--- a/include/geos/geom/Point.h
+++ b/include/geos/geom/Point.h
@@ -74,7 +74,7 @@ public:
 	/// A vector of const Point pointers
 	typedef std::vector<const Point *> ConstVect;
-	virtual ~Point();
+	~Point() override;
 	 * Creates and returns a full copy of this {@link Point} object.
@@ -82,24 +82,24 @@ public:
-	Geometry *clone() const { return new Point(*this); }
+	Geometry *clone() const override { return new Point(*this); }
-	CoordinateSequence* getCoordinates(void) const;
+	CoordinateSequence* getCoordinates(void) const override;
-	size_t getNumPoints() const;
-	bool isEmpty() const;
+	size_t getNumPoints() const override;
@@ -109,25 +109,25 @@ public:
 	 * @see Geometry::getBoundary
 	double getX() const;
 	double getY() const;
-	const Coordinate* getCoordinate() const;
-	void apply_ro(GeometryFilter *filter) const;
-	void apply_rw(GeometryFilter *filter);
-	void apply_rw(GeometryComponentFilter *filter);
-	void apply_ro(GeometryComponentFilter *filter) const;
-	void normalize(void)
+	void normalize(void) override
 		// a Point is always in normalized form
@@ -155,9 +155,9 @@ protected:
 	Point(const Point &p);
-	int compareToSameClass(const Geometry *p) const;
+	int compareToSameClass(const Geometry *p) const override;
 private:
diff --git a/include/geos/geom/Polygon.h b/include/geos/geom/Polygon.h
index 500a384..fd3d412 100644
--- a/include/geos/geom/Polygon.h
+++ b/include/geos/geom/Polygon.h
@@ -73,7 +73,7 @@ public:
 	/// A vector of const Polygon pointers
 	typedef std::vector<const Polygon *> ConstVect;
-	virtual ~Polygon();
+	~Polygon() override;
 	 * Creates and returns a full copy of this {@link Polygon} object.
@@ -81,20 +81,20 @@ public:
-	virtual Geometry *clone() const { return new Polygon(*this); }
+	Geometry *clone() const override { return new Polygon(*this); }
-	CoordinateSequence* getCoordinates() const;
 	/// Returns 1 (Polygon boundary is a MultiLineString)
 	/** \brief
@@ -102,9 +102,9 @@ public:
 	/** \brief
 	 * Tests if a valid polygon is simple.
@@ -112,7 +112,7 @@ public:
 	 * @return <code>true</code>
 	/// Returns the exterior ring (shell)
 	const LineString* getExteriorRing() const;
@@ -123,34 +123,34 @@ public:
 	/// Get nth interior ring (hole)
 	const LineString* getInteriorRingN(std::size_t n) const;
-	Geometry* convexHull() const;
+	Geometry* convexHull() const override;
-	void normalize();
-	int compareToSameClass(const Geometry *p) const; //was protected
+	int compareToSameClass(const Geometry *p) const override; //was protected
-	double getArea() const;
  	/// Returns the perimeter of this <code>Polygon</code>
-	double getLength() const;
-	bool isRectangle() const;
+	bool isRectangle() const override;
 protected:
@@ -182,7 +182,7 @@ protected:
 	std::vector<Geometry *> *holes; //Actually vector<LinearRing *>
 private:
diff --git a/include/geos/geom/prep/AbstractPreparedPolygonContains.h b/include/geos/geom/prep/AbstractPreparedPolygonContains.h
index 9e0a19d..6bd4e90 100644
--- a/include/geos/geom/prep/AbstractPreparedPolygonContains.h
+++ b/include/geos/geom/prep/AbstractPreparedPolygonContains.h
@@ -125,7 +125,7 @@ public:
 		requireSomePointInInterior(requireSomePointInInterior)
-	virtual ~AbstractPreparedPolygonContains()
+	~AbstractPreparedPolygonContains() override
diff --git a/include/geos/geom/prep/BasicPreparedGeometry.h b/include/geos/geom/prep/BasicPreparedGeometry.h
index 87d327b..a084ab6 100644
--- a/include/geos/geom/prep/BasicPreparedGeometry.h
+++ b/include/geos/geom/prep/BasicPreparedGeometry.h
@@ -90,9 +90,9 @@ protected:
 public:
 	BasicPreparedGeometry( const Geometry * geom);
-	~BasicPreparedGeometry( );
+	~BasicPreparedGeometry( ) override;
-	const geom::Geometry & getGeometry() const
+	const geom::Geometry & getGeometry() const override
 		return *baseGeom;
@@ -123,53 +123,53 @@ public:
 	 * Default implementation.
-	bool contains(const geom::Geometry * g) const;
+	bool contains(const geom::Geometry * g) const override;
-	bool containsProperly(const geom::Geometry * g)	const;
+	bool containsProperly(const geom::Geometry * g)	const override;
-	bool coveredBy(const geom::Geometry * g) const;
+	bool coveredBy(const geom::Geometry * g) const override;
-	bool covers(const geom::Geometry * g) const;
+	bool covers(const geom::Geometry * g) const override;
-	bool crosses(const geom::Geometry * g) const;
+	bool crosses(const geom::Geometry * g) const override;
 	 * Standard implementation for all geometries.
 	 * Supports {@link GeometryCollection}s as input.
-	bool disjoint(const geom::Geometry * g)	const;
+	bool disjoint(const geom::Geometry * g)	const override;
-	bool intersects(const geom::Geometry * g) const;
+	bool intersects(const geom::Geometry * g) const override;
-	bool overlaps(const geom::Geometry * g)	const;
+	bool overlaps(const geom::Geometry * g)	const override;
-	bool touches(const geom::Geometry * g) const;
+	bool touches(const geom::Geometry * g) const override;
-	bool within(const geom::Geometry * g) const;
+	bool within(const geom::Geometry * g) const override;
 	std::string toString();
diff --git a/include/geos/geom/prep/PreparedLineString.h b/include/geos/geom/prep/PreparedLineString.h
index 4001966..d804b80 100644
--- a/include/geos/geom/prep/PreparedLineString.h
+++ b/include/geos/geom/prep/PreparedLineString.h
@@ -54,11 +54,11 @@ public:
 		segIntFinder( nullptr)
-	~PreparedLineString();
+	~PreparedLineString() override;
 	noding::FastSegmentSetIntersectionFinder * getIntersectionFinder();
diff --git a/include/geos/geom/prep/PreparedPoint.h b/include/geos/geom/prep/PreparedPoint.h
index 7fc0943..6355f07 100644
--- a/include/geos/geom/prep/PreparedPoint.h
+++ b/include/geos/geom/prep/PreparedPoint.h
@@ -48,7 +48,7 @@ public:
 	 * The optimization here is that computing topology for the test
 	 * geometry is avoided. This can be significant for large geometries.
-	bool intersects(const geom::Geometry* g) const;
+	bool intersects(const geom::Geometry* g) const override;
diff --git a/include/geos/geom/prep/PreparedPolygon.h b/include/geos/geom/prep/PreparedPolygon.h
index d9552b6..0bfde3d 100644
--- a/include/geos/geom/prep/PreparedPolygon.h
+++ b/include/geos/geom/prep/PreparedPolygon.h
@@ -56,15 +56,15 @@ private:
 protected:
 public:
 	PreparedPolygon( const geom::Geometry * geom);
-	~PreparedPolygon( );
+	~PreparedPolygon( ) override;
 	noding::FastSegmentSetIntersectionFinder * getIntersectionFinder() const;
 	algorithm::locate::PointOnGeometryLocator * getPointLocator() const;
-	bool contains( const geom::Geometry* g) const;
-	bool containsProperly( const geom::Geometry* g) const;
-	bool covers( const geom::Geometry* g) const;
-	bool intersects( const geom::Geometry* g) const;
+	bool contains( const geom::Geometry* g) const override;
+	bool containsProperly( const geom::Geometry* g) const override;
+	bool covers( const geom::Geometry* g) const override;
+	bool intersects( const geom::Geometry* g) const override;
diff --git a/include/geos/geom/prep/PreparedPolygonContains.h b/include/geos/geom/prep/PreparedPolygonContains.h
index f8b4765..bf76452 100644
--- a/include/geos/geom/prep/PreparedPolygonContains.h
+++ b/include/geos/geom/prep/PreparedPolygonContains.h
@@ -95,7 +95,7 @@ protected:
 	* @param geom the test geometry
 	* @return true if this prepared polygon contains the test geometry
-	bool fullTopologicalPredicate(const geom::Geometry * geom);
+	bool fullTopologicalPredicate(const geom::Geometry * geom) override;
diff --git a/include/geos/geom/prep/PreparedPolygonCovers.h b/include/geos/geom/prep/PreparedPolygonCovers.h
index 149b005..f633523 100644
--- a/include/geos/geom/prep/PreparedPolygonCovers.h
+++ b/include/geos/geom/prep/PreparedPolygonCovers.h
@@ -63,7 +63,7 @@ protected:
 	 * @return true if this prepared polygon covers the test geometry
-	bool fullTopologicalPredicate( const geom::Geometry * geom);
+	bool fullTopologicalPredicate( const geom::Geometry * geom) override;
 public:
diff --git a/include/geos/geom/util/ComponentCoordinateExtracter.h b/include/geos/geom/util/ComponentCoordinateExtracter.h
index 6e577ca..3f54ab6 100644
--- a/include/geos/geom/util/ComponentCoordinateExtracter.h
+++ b/include/geos/geom/util/ComponentCoordinateExtracter.h
@@ -53,9 +53,9 @@ public:
 	ComponentCoordinateExtracter( std::vector<const Coordinate*> &newComps);
-	void filter_rw( Geometry * geom);
+	void filter_rw( Geometry * geom) override;
-	void filter_ro( const Geometry * geom);
+	void filter_ro( const Geometry * geom) override;
 private:
diff --git a/include/geos/geom/util/CoordinateOperation.h b/include/geos/geom/util/CoordinateOperation.h
index dafc329..8b87cf4 100644
--- a/include/geos/geom/util/CoordinateOperation.h
+++ b/include/geos/geom/util/CoordinateOperation.h
@@ -45,8 +45,8 @@ public:
 	 * Return a newly created geometry, ownership to caller
-	virtual Geometry* edit(const Geometry *geometry,
-			const GeometryFactory *factory);
+	Geometry* edit(const Geometry *geometry,
+			const GeometryFactory *factory) override;
 	 * Edits the array of Coordinate from a Geometry.
@@ -60,7 +60,7 @@ public:
 			const Geometry *geometry)=0;
-	virtual ~CoordinateOperation() {}
+	~CoordinateOperation() override {}
diff --git a/include/geos/geom/util/GeometryExtracter.h b/include/geos/geom/util/GeometryExtracter.h
index db5c2c7..827ec54 100644
--- a/include/geos/geom/util/GeometryExtracter.h
+++ b/include/geos/geom/util/GeometryExtracter.h
@@ -74,7 +74,7 @@ private:
     TargetContainer& comps_;
-    void filter_ro(const Geometry* geom)
+    void filter_ro(const Geometry* geom) override
       if ( const ComponentType* c = dynamic_cast<const ComponentType*>(geom) ) {
         comps_.push_back(c);
diff --git a/include/geos/geom/util/LinearComponentExtracter.h b/include/geos/geom/util/LinearComponentExtracter.h
index d86406a..1f2b4e7 100644
--- a/include/geos/geom/util/LinearComponentExtracter.h
+++ b/include/geos/geom/util/LinearComponentExtracter.h
@@ -57,9 +57,9 @@ public:
 	LinearComponentExtracter(std::vector<const LineString*> &newComps);
-	void filter_rw(Geometry *geom);
+	void filter_rw(Geometry *geom) override;
-	void filter_ro(const Geometry *geom);
+	void filter_ro(const Geometry *geom) override;
diff --git a/include/geos/geom/util/PointExtracter.h b/include/geos/geom/util/PointExtracter.h
index 4e81249..a9449c3 100644
--- a/include/geos/geom/util/PointExtracter.h
+++ b/include/geos/geom/util/PointExtracter.h
@@ -46,9 +46,9 @@ public:
 	PointExtracter(Point::ConstVect& newComps);
 private:
diff --git a/include/geos/geom/util/PolygonExtracter.h b/include/geos/geom/util/PolygonExtracter.h
index bab2a82..fe5b6b2 100644
--- a/include/geos/geom/util/PolygonExtracter.h
+++ b/include/geos/geom/util/PolygonExtracter.h
@@ -48,9 +48,9 @@ public:
 	PolygonExtracter(std::vector<const Polygon*>& newComps);
 private:
diff --git a/include/geos/geomgraph/DirectedEdge.h b/include/geos/geomgraph/DirectedEdge.h
index 6136555..ee992d5 100644
--- a/include/geos/geomgraph/DirectedEdge.h
+++ b/include/geos/geomgraph/DirectedEdge.h
@@ -142,7 +142,7 @@ public:
 	void setEdgeDepths(int position, int newDepth);
-	virtual std::string print() const;
+	std::string print() const override;
 	std::string printEdge();
diff --git a/include/geos/geomgraph/DirectedEdgeStar.h b/include/geos/geomgraph/DirectedEdgeStar.h
index 325bada..6af6bcb 100644
--- a/include/geos/geomgraph/DirectedEdgeStar.h
+++ b/include/geos/geomgraph/DirectedEdgeStar.h
@@ -63,12 +63,12 @@ public:
 		label()
-	~DirectedEdgeStar() {
+	~DirectedEdgeStar() override {
 		delete resultAreaEdgeList;
 	/// Insert a directed edge in the list
-	void insert(EdgeEnd *ee);
+	void insert(EdgeEnd *ee) override;
 	Label &getLabel() { return label; }
@@ -82,7 +82,7 @@ public:
 	 * Compute the labelling for all dirEdges in this star, as well
 	 * as the overall labelling
-	void computeLabelling(std::vector<GeometryGraph*> *geom); // throw(TopologyException *);
+	void computeLabelling(std::vector<GeometryGraph*> *geom) override; // throw(TopologyException *);
 	/** \brief
 	 * For each dirEdge in the star,
@@ -132,7 +132,7 @@ public:
 	void computeDepths(DirectedEdge *de);
 private:
diff --git a/include/geos/geomgraph/Edge.h b/include/geos/geomgraph/Edge.h
index 2f225c3..1583e2a 100644
--- a/include/geos/geomgraph/Edge.h
+++ b/include/geos/geomgraph/Edge.h
 	/// Takes ownership of CoordinateSequence
 	Edge(geom::CoordinateSequence* newPts);
-	virtual ~Edge();
+	~Edge() override;
 	virtual int getNumPoints() const {
 		return static_cast<int>(pts->getSize());
@@ -187,7 +187,7 @@ public:
 		testInvariant();
-	virtual bool isIsolated() const {
+	bool isIsolated() const override {
 		testInvariant();
 		return isIsolatedVar;
@@ -212,7 +212,7 @@ public:
 	/// A component only contributes if it has a labelling for both
 	/// parent geometries
-	virtual void computeIM(geom::IntersectionMatrix& im) {
+	void computeIM(geom::IntersectionMatrix& im) override {
 		updateIM(label, im);
 		testInvariant();
diff --git a/include/geos/geomgraph/GeometryGraph.h b/include/geos/geomgraph/GeometryGraph.h
index 0a9f42e..bb59761 100644
--- a/include/geos/geomgraph/GeometryGraph.h
+++ b/include/geos/geomgraph/GeometryGraph.h
@@ -175,7 +175,7 @@ public:
 	GeometryGraph(int newArgIndex, const geom::Geometry *newParentGeom,
 	              const algorithm::BoundaryNodeRule& boundaryNodeRule);
-	virtual ~GeometryGraph();
+	~GeometryGraph() override;
 	const geom::Geometry* getGeometry();
diff --git a/include/geos/geomgraph/Node.h b/include/geos/geomgraph/Node.h
index 80dc64e..1072fa6 100644
--- a/include/geos/geomgraph/Node.h
+++ b/include/geos/geomgraph/Node.h
@@ -68,13 +68,13 @@ public:
 	Node(const geom::Coordinate& newCoord, EdgeEndStar* newEdges);
-	virtual ~Node();
+	~Node() override;
 	virtual const geom::Coordinate& getCoordinate() const;
 	virtual EdgeEndStar* getEdges();
-	virtual bool isIsolated() const;
+	bool isIsolated() const override;
 	/** \brief
 	 * Add the edge to the list of edges at this node
@@ -140,7 +140,7 @@ protected:
 	/** \brief
 	 * Basic nodes do not compute IMs
-	virtual void computeIM(geom::IntersectionMatrix& /*im*/) {}
+	void computeIM(geom::IntersectionMatrix& /*im*/) override {}
 private:
diff --git a/include/geos/geomgraph/index/MonotoneChain.h b/include/geos/geomgraph/index/MonotoneChain.h
index 0231b3f..f19c463 100644
--- a/include/geos/geomgraph/index/MonotoneChain.h
+++ b/include/geos/geomgraph/index/MonotoneChain.h
@@ -53,7 +53,7 @@ public:
 		chainIndex(newChainIndex)
-	~MonotoneChain() {}
+	~MonotoneChain() override {}
 	void computeIntersections(MonotoneChain *mc,SegmentIntersector *si) {
 		mce->computeIntersectsForChain(chainIndex,*(mc->mce),mc->chainIndex,*si);
diff --git a/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h b/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h
index e0be762..78d41ab 100644
--- a/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h
+++ b/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h
@@ -42,10 +42,10 @@ public:
 	SimpleEdgeSetIntersector();
 	void computeIntersections(std::vector<Edge*> *edges,
-			SegmentIntersector *si, bool testAllSegments);
+			SegmentIntersector *si, bool testAllSegments) override;
 	void computeIntersections(std::vector<Edge*> *edges0,
-			std::vector<Edge*> *edges1, SegmentIntersector *si);
+			std::vector<Edge*> *edges1, SegmentIntersector *si) override;
 private:
diff --git a/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h b/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
index f326d49..d88bdc3 100644
--- a/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
+++ b/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
@@ -57,14 +57,14 @@ public:
 	SimpleMCSweepLineIntersector();
-	virtual ~SimpleMCSweepLineIntersector();
+	~SimpleMCSweepLineIntersector() override;
-			SegmentIntersector *si);
+			SegmentIntersector *si) override;
 protected:
diff --git a/include/geos/geomgraph/index/SimpleSweepLineIntersector.h b/include/geos/geomgraph/index/SimpleSweepLineIntersector.h
index 6b06d3d..cd8c84d 100644
--- a/include/geos/geomgraph/index/SimpleSweepLineIntersector.h
+++ b/include/geos/geomgraph/index/SimpleSweepLineIntersector.h
@@ -54,15 +54,15 @@ public:
 	SimpleSweepLineIntersector();
-	virtual ~SimpleSweepLineIntersector();
+	~SimpleSweepLineIntersector() override;
-			bool testAllSegments);
+			bool testAllSegments) override;
 private:
diff --git a/include/geos/geomgraph/index/SweepLineSegment.h b/include/geos/geomgraph/index/SweepLineSegment.h
index a5f9973..d6c8f35 100644
--- a/include/geos/geomgraph/index/SweepLineSegment.h
+++ b/include/geos/geomgraph/index/SweepLineSegment.h
@@ -40,7 +40,7 @@ namespace index { // geos::geomgraph::index
 class GEOS_DLL SweepLineSegment: public SweepLineEventOBJ {
 public:
 	SweepLineSegment(Edge *newEdge, int newPtIndex);
-	~SweepLineSegment();
+	~SweepLineSegment() override;
 	double getMinX();
 	double getMaxX();
 	void computeIntersections(SweepLineSegment *ss, SegmentIntersector *si);
diff --git a/include/geos/index/bintree/Node.h b/include/geos/index/bintree/Node.h
index 7a63a98..8e92a49 100644
--- a/include/geos/index/bintree/Node.h
+++ b/include/geos/index/bintree/Node.h
@@ -42,7 +42,7 @@ public:
 	Node(Interval *newInterval,int newLevel);
-	~Node();
+	~Node() override;
 	Interval* getInterval();
@@ -66,7 +66,7 @@ private:
 protected:
-	bool isSearchMatch(Interval *itemInterval);
+	bool isSearchMatch(Interval *itemInterval) override;
 } // namespace geos::index::bintree
diff --git a/include/geos/index/bintree/Root.h b/include/geos/index/bintree/Root.h
index dc0c174..ec90980 100644
--- a/include/geos/index/bintree/Root.h
+++ b/include/geos/index/bintree/Root.h
 	Root() {}
-	~Root() {}
+	~Root() override {}
 	/// @param itemInterval
 	///     Ownership left to caller, references kept in this class.
@@ -65,7 +65,7 @@ public:
 protected:
-	bool isSearchMatch(Interval* /*interval*/) { return true; }
+	bool isSearchMatch(Interval* /*interval*/) override { return true; }
diff --git a/include/geos/index/intervalrtree/IntervalRTreeBranchNode.h b/include/geos/index/intervalrtree/IntervalRTreeBranchNode.h
index e55ccfd..97347aa 100644
--- a/include/geos/index/intervalrtree/IntervalRTreeBranchNode.h
+++ b/include/geos/index/intervalrtree/IntervalRTreeBranchNode.h
@@ -52,14 +52,14 @@ public:
 		node2( n2)
-	~IntervalRTreeBranchNode()
+	~IntervalRTreeBranchNode() override
 		delete node1;
 		delete node2;
-	void query(double queryMin, double queryMax, index::ItemVisitor * visitor) const;
+	void query(double queryMin, double queryMax, index::ItemVisitor * visitor) const override;
 } // geos::intervalrtree
diff --git a/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h b/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h
index 5c8ad2c..683404e 100644
--- a/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h
+++ b/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h
@@ -47,11 +47,11 @@ public:
 		item( item)
-	~IntervalRTreeLeafNode()
+	~IntervalRTreeLeafNode() override
-	void query( double queryMin, double queryMax, index::ItemVisitor * visitor) const;
+	void query( double queryMin, double queryMax, index::ItemVisitor * visitor) const override;
diff --git a/include/geos/index/quadtree/Node.h b/include/geos/index/quadtree/Node.h
index 76f4fd4..5b01f50 100644
--- a/include/geos/index/quadtree/Node.h
+++ b/include/geos/index/quadtree/Node.h
@@ -75,7 +75,7 @@ private:
 protected:
-	bool isSearchMatch(const geom::Envelope& searchEnv) const {
+	bool isSearchMatch(const geom::Envelope& searchEnv) const override {
 		return env->intersects(searchEnv);
@@ -101,7 +101,7 @@ public:
-	virtual ~Node() {}
+	~Node() override {}
 	/// Return Envelope associated with this node
 	/// ownership retained by this object
@@ -122,7 +122,7 @@ public:
 	void insertNode(std::unique_ptr<Node> node);
diff --git a/include/geos/index/quadtree/Quadtree.h b/include/geos/index/quadtree/Quadtree.h
index a1fab07..d237023 100644
--- a/include/geos/index/quadtree/Quadtree.h
+++ b/include/geos/index/quadtree/Quadtree.h
@@ -113,7 +113,7 @@ public:
 		minExtent(1.0)
-	~Quadtree();
+	~Quadtree() override;
 	/// Returns the number of levels in the tree.
 	int depth();
@@ -121,7 +121,7 @@ public:
 	/// Returns the number of items in the tree.
 	int size();
-	void insert(const geom::Envelope *itemEnv, void *item);
+	void insert(const geom::Envelope *itemEnv, void *item) override;
 	/** \brief
 	 * Queries the tree and returns items which may lie
@@ -140,7 +140,7 @@ public:
 	 * @param ret a vector where items which may intersect the
 	 * 	      search envelope are pushed
-	void query(const geom::Envelope *searchEnv, std::vector<void*>& ret);
+	void query(const geom::Envelope *searchEnv, std::vector<void*>& ret) override;
 	/** \brief
@@ -159,7 +159,7 @@ public:
 	 * @param searchEnv the envelope of the desired query area.
 	 * @param visitor a visitor object which is passed the visited items
-	void query(const geom::Envelope *searchEnv, ItemVisitor& visitor)
+	void query(const geom::Envelope *searchEnv, ItemVisitor& visitor) override
 		 * the items that are matched are the items in quads which
 	 * @param item the item to remove
 	 * @return <code>true</code> if the item was found (and thus removed)
-	bool remove(const geom::Envelope* itemEnv, void* item);
+	bool remove(const geom::Envelope* itemEnv, void* item) override;
 	/// Return a list of all items in the Quadtree
 	std::vector<void*>* queryAll();
diff --git a/include/geos/index/quadtree/Root.h b/include/geos/index/quadtree/Root.h
index 2ddbcae..98342c9 100644
--- a/include/geos/index/quadtree/Root.h
+++ b/include/geos/index/quadtree/Root.h
 	Root() {}
-	virtual ~Root() {}
 	 * Insert an item into the quadtree this is the root of.
 protected:
-	bool isSearchMatch(const geom::Envelope& /* searchEnv */) const {
+	bool isSearchMatch(const geom::Envelope& /* searchEnv */) const override {
 		return true;
diff --git a/include/geos/index/strtree/AbstractNode.h b/include/geos/index/strtree/AbstractNode.h
index d7f1f7f..4edcf01 100644
--- a/include/geos/index/strtree/AbstractNode.h
+++ b/include/geos/index/strtree/AbstractNode.h
@@ -45,7 +45,7 @@ private:
 	int level;
 public:
 	AbstractNode(int newLevel, int capacity=10);
-	virtual	~AbstractNode();
+		~AbstractNode() override;
 	// TODO: change signature to return by ref,
 	// document ownership of the return
@@ -71,7 +71,7 @@ public:
 	 * @see AbstractSTRtree::IntersectsOp
-	const void* getBounds() const;
+	const void* getBounds() const override;
 	int getLevel();
diff --git a/include/geos/index/strtree/GeometryItemDistance.h b/include/geos/index/strtree/GeometryItemDistance.h
index e9a97e5..887ea29 100644
--- a/include/geos/index/strtree/GeometryItemDistance.h
+++ b/include/geos/index/strtree/GeometryItemDistance.h
@@ -36,7 +36,7 @@ public:
 	 * @return the distance between the geometries
 	 * @throws ClassCastException if either item is not a Geometry
-	double distance(const ItemBoundable* item1, const ItemBoundable* item2);
+	double distance(const ItemBoundable* item1, const ItemBoundable* item2) override;
diff --git a/include/geos/index/strtree/ItemBoundable.h b/include/geos/index/strtree/ItemBoundable.h
index 5cbdf21..1454827 100644
--- a/include/geos/index/strtree/ItemBoundable.h
+++ b/include/geos/index/strtree/ItemBoundable.h
@@ -34,9 +34,9 @@ class GEOS_DLL ItemBoundable: public Boundable
 public:
     ItemBoundable(const void* newBounds, void* newItem);
-	virtual ~ItemBoundable();
+	~ItemBoundable() override;
 	void* getItem() const;
 private:
diff --git a/include/geos/index/strtree/SIRtree.h b/include/geos/index/strtree/SIRtree.h
index dc09da8..54f7895 100644
--- a/include/geos/index/strtree/SIRtree.h
+++ b/include/geos/index/strtree/SIRtree.h
@@ -55,7 +55,7 @@ public:
 	SIRtree(std::size_t nodeCapacity);
-	virtual ~SIRtree();
+	~SIRtree() override;
 	void insert(double x1, double x2, void* item);
@@ -81,7 +81,7 @@ protected:
 	class SIRIntersectsOp:public AbstractSTRtree::IntersectsOp {
 	public:
-		bool intersects(const void* aBounds, const void* bBounds);
+		bool intersects(const void* aBounds, const void* bBounds) override;
 	/** \brief
@@ -89,13 +89,13 @@ protected:
 	 * M is the node capacity.
 	std::unique_ptr<BoundableList> createParentBoundables(
-			BoundableList* childBoundables, int newLevel);
+			BoundableList* childBoundables, int newLevel) override;
-	AbstractNode* createNode(int level);
+	AbstractNode* createNode(int level) override;
-	IntersectsOp* getIntersectsOp() {return intersectsOp;}
+	IntersectsOp* getIntersectsOp() override {return intersectsOp;}
-	std::unique_ptr<BoundableList> sortBoundables(const BoundableList* input);
+	std::unique_ptr<BoundableList> sortBoundables(const BoundableList* input) override;
 private:
diff --git a/include/geos/index/strtree/STRtree.h b/include/geos/index/strtree/STRtree.h
index 6f49bc8..70be833 100644
--- a/include/geos/index/strtree/STRtree.h
+++ b/include/geos/index/strtree/STRtree.h
@@ -69,7 +69,7 @@ using AbstractSTRtree::query;
 private:
 	class GEOS_DLL STRIntersectsOp: public AbstractSTRtree::IntersectsOp {
 		public:
@@ -79,13 +79,13 @@ private:
 	 * group them into runs of size M (the node capacity). For each run, creates
 	 * a new (parent) node.
-	std::unique_ptr<BoundableList> createParentBoundables(BoundableList* childBoundables, int newLevel);
+	std::unique_ptr<BoundableList> createParentBoundables(BoundableList* childBoundables, int newLevel) override;
 	std::unique_ptr<BoundableList> createParentBoundablesFromVerticalSlices(std::vector<BoundableList*>* verticalSlices, int newLevel);
 	STRIntersectsOp intersectsOp;
 	std::unique_ptr<BoundableList> createParentBoundablesFromVerticalSlice(
@@ -103,15 +103,15 @@ private:
 protected:
 		return &intersectsOp;
 public:
-	~STRtree();
+	~STRtree() override;
 	 * Constructs an STRtree with the given maximum number of child nodes that
@@ -119,7 +119,7 @@ public:
 	STRtree(std::size_t nodeCapacity=10);
-	void insert(const geom::Envelope *itemEnv,void* item);
+	void insert(const geom::Envelope *itemEnv,void* item) override;
 	//static double centreX(const geom::Envelope *e);
@@ -131,11 +131,11 @@ public:
 		return STRtree::avg(e->getMinY(), e->getMaxY());
-	void query(const geom::Envelope *searchEnv, std::vector<void*>& matches) {
+	void query(const geom::Envelope *searchEnv, std::vector<void*>& matches) override {
 		AbstractSTRtree::query(searchEnv, matches);
-	void query(const geom::Envelope *searchEnv, ItemVisitor& visitor) {
+	void query(const geom::Envelope *searchEnv, ItemVisitor& visitor) override {
 		return AbstractSTRtree::query(searchEnv, visitor);
@@ -145,7 +145,7 @@ public:
 	std::pair<const void*, const void*> nearestNeighbour(BoundablePair* initBndPair, double maxDistance);
 	std::pair<const void*, const void*> nearestNeighbour(STRtree *tree, ItemDistance *itemDist);
-	bool remove(const geom::Envelope *itemEnv, void* item) {
+	bool remove(const geom::Envelope *itemEnv, void* item) override {
 		return AbstractSTRtree::remove(itemEnv, item);
diff --git a/include/geos/io/ParseException.h b/include/geos/io/ParseException.h
index 23c5925..bcef225 100644
--- a/include/geos/io/ParseException.h
+++ b/include/geos/io/ParseException.h
@@ -44,7 +44,7 @@ public:
 	ParseException(const std::string& msg, double num);
-	~ParseException() throw() {}
+	~ParseException() throw() override {}
 private:
 	static std::string stringify(double num);
diff --git a/include/geos/noding/BasicSegmentString.h b/include/geos/noding/BasicSegmentString.h
index 1b0b7ca..e1e08d8 100644
--- a/include/geos/noding/BasicSegmentString.h
+++ b/include/geos/noding/BasicSegmentString.h
@@ -64,26 +64,26 @@ public:
 		pts(newPts)
-	virtual ~BasicSegmentString()
+	~BasicSegmentString() override
 	/// see dox in SegmentString.h
-	virtual unsigned int size() const
+	unsigned int size() const override
 		return pts->size();
-	virtual const geom::Coordinate& getCoordinate(unsigned int i) const;
+	const geom::Coordinate& getCoordinate(unsigned int i) const override;
-	virtual geom::CoordinateSequence* getCoordinates() const;
+	geom::CoordinateSequence* getCoordinates() const override;
-	virtual bool isClosed() const;
-	virtual std::ostream& print(std::ostream& os) const;
+	std::ostream& print(std::ostream& os) const override;
 	/** \brief
 	 * Gets the octant of the segment starting at vertex index.
diff --git a/include/geos/noding/IntersectionAdder.h b/include/geos/noding/IntersectionAdder.h
index eaacc90..d32b955 100644
--- a/include/geos/noding/IntersectionAdder.h
+++ b/include/geos/noding/IntersectionAdder.h
@@ -158,7 +158,7 @@ public:
 	void processIntersections(
 		SegmentString* e0,  int segIndex0,
-		SegmentString* e1,  int segIndex1);
+		SegmentString* e1,  int segIndex1) override;
 	static bool isAdjacentSegments(int i1, int i2) {
@@ -170,7 +170,7 @@ public:
 	 * @return false always
-	virtual bool isDone() const {
 		return false;
diff --git a/include/geos/noding/IntersectionFinderAdder.h b/include/geos/noding/IntersectionFinderAdder.h
index ccf6bdd..4c9184e 100644
--- a/include/geos/noding/IntersectionFinderAdder.h
+++ b/include/geos/noding/IntersectionFinderAdder.h
@@ -80,7 +80,7 @@ public:
 	std::vector<geom::Coordinate>& getInteriorIntersections() {
 		return interiorIntersections;
@@ -91,7 +91,7 @@ public:
 		return false;
diff --git a/include/geos/noding/IteratedNoder.h b/include/geos/noding/IteratedNoder.h
index d85689b..684d9c9 100644
--- a/include/geos/noding/IteratedNoder.h
+++ b/include/geos/noding/IteratedNoder.h
-	virtual ~IteratedNoder() {}
+	~IteratedNoder() override {}
 	 * Sets the maximum number of noding iterations performed before
@@ -93,7 +93,7 @@ public:
 	void setMaximumIterations(int n) { maxIter = n; }
-	std::vector<SegmentString*>* getNodedSubstrings() const {
+	std::vector<SegmentString*>* getNodedSubstrings() const override {
 		return nodedSegStrings;
 	 * @param segStrings a collection of SegmentStrings to be noded
 	 * @throws TopologyException if the iterated noding fails to converge.
-	void computeNodes(std::vector<SegmentString*>* inputSegmentStrings); // throw(GEOSException);
+	void computeNodes(std::vector<SegmentString*>* inputSegmentStrings) override; // throw(GEOSException);
 } // namespace geos::noding
diff --git a/include/geos/noding/MCIndexNoder.h b/include/geos/noding/MCIndexNoder.h
index f2cd1bf..25ebcfa 100644
--- a/include/geos/noding/MCIndexNoder.h
+++ b/include/geos/noding/MCIndexNoder.h
@@ -84,16 +84,16 @@ public:
 		nOverlaps(0)
-	~MCIndexNoder();
+	~MCIndexNoder() override;
 	/// Return a reference to this instance's std::vector of MonotoneChains
 	std::vector<index::chain::MonotoneChain*>& getMonotoneChains() { return monoChains; }
 	index::SpatialIndex& getIndex();
-	std::vector<SegmentString*>* getNodedSubstrings() const;
+	std::vector<SegmentString*>* getNodedSubstrings() const override;
 	class SegmentOverlapAction : public index::chain::MonotoneChainOverlapAction {
 	public:
@@ -104,7 +104,7 @@ public:
 		void overlap(index::chain::MonotoneChain& mc1, std::size_t start1,
-            index::chain::MonotoneChain& mc2, std::size_t start2);
+            index::chain::MonotoneChain& mc2, std::size_t start2) override;
     private:
         SegmentIntersector& si;
diff --git a/include/geos/noding/MCIndexSegmentSetMutualIntersector.h b/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
index 6ed321c..24318df 100644
--- a/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
+++ b/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
@@ -57,7 +57,7 @@ public:
 	MCIndexSegmentSetMutualIntersector();
-	~MCIndexSegmentSetMutualIntersector();
+	~MCIndexSegmentSetMutualIntersector() override;
 	/* Returns a reference to a vector of MonotoneChain objects owned
 	 * by this class and destroyed on next call to ::process.
@@ -73,10 +73,10 @@ public:
 		return index;
-	void setBaseSegments(SegmentString::ConstVect* segStrings);
+	void setBaseSegments(SegmentString::ConstVect* segStrings) override;
 	// NOTE: re-populates the MonotoneChain vector with newly created chains
-	void process(SegmentString::ConstVect* segStrings);
+	void process(SegmentString::ConstVect* segStrings) override;
 private:
diff --git a/include/geos/noding/NodedSegmentString.h b/include/geos/noding/NodedSegmentString.h
index 108b6d2..426fc5c 100644
--- a/include/geos/noding/NodedSegmentString.h
+++ b/include/geos/noding/NodedSegmentString.h
         , pts(newPts)
-	~NodedSegmentString()
+	~NodedSegmentString() override
 		delete pts;
@@ -143,18 +143,18 @@ public:
 	const SegmentNodeList& getNodeList() const;
 		return static_cast<unsigned int>(pts->size());
 	/** \brief
diff --git a/include/geos/noding/ScaledNoder.h b/include/geos/noding/ScaledNoder.h
index 0b5f26b..f46d1a8 100644
--- a/include/geos/noding/ScaledNoder.h
+++ b/include/geos/noding/ScaledNoder.h
@@ -74,11 +74,11 @@ public:
 		isScaled(nScaleFactor!=1.0)
-	~ScaledNoder();
+	~ScaledNoder() override;
-	void computeNodes(std::vector<SegmentString*>* inputSegStr);
+	void computeNodes(std::vector<SegmentString*>* inputSegStr) override;
 	//void filter(Coordinate& c);
diff --git a/include/geos/noding/SegmentIntersectionDetector.h b/include/geos/noding/SegmentIntersectionDetector.h
index b75d3ec..8aff530 100644
--- a/include/geos/noding/SegmentIntersectionDetector.h
+++ b/include/geos/noding/SegmentIntersectionDetector.h
@@ -69,7 +69,7 @@ public:
 		intSegments( nullptr)
-	~SegmentIntersectionDetector()
+	~SegmentIntersectionDetector() override
 		//delete intPt;
 		delete intSegments;
@@ -138,7 +138,7 @@ public:
 		return intSegments;
 		// If finding all types, we can stop
 		// when both possible types have been found.
@@ -161,7 +161,7 @@ public:
 	 * (e.g. by an disjoint envelope test).
 	void processIntersections(	noding::SegmentString * e0, int segIndex0,
-								noding::SegmentString * e1, int segIndex1 );
+								noding::SegmentString * e1, int segIndex1 ) override;
diff --git a/include/geos/noding/SimpleNoder.h b/include/geos/noding/SimpleNoder.h
index 86489b9..cb700db 100644
--- a/include/geos/noding/SimpleNoder.h
+++ b/include/geos/noding/SimpleNoder.h
@@ -59,9 +59,9 @@ public:
 		SinglePassNoder(nSegInt)
 		return NodedSegmentString::getNodedSubstrings(*nodedSegStrings);
diff --git a/include/geos/noding/SingleInteriorIntersectionFinder.h b/include/geos/noding/SingleInteriorIntersectionFinder.h
index c9f3360..d471fd5 100644
--- a/include/geos/noding/SingleInteriorIntersectionFinder.h
+++ b/include/geos/noding/SingleInteriorIntersectionFinder.h
@@ -100,9 +100,9 @@ public:
 		return !interiorIntersection.isNull();
diff --git a/include/geos/noding/SinglePassNoder.h b/include/geos/noding/SinglePassNoder.h
index e9106ff..c18781f 100644
--- a/include/geos/noding/SinglePassNoder.h
+++ b/include/geos/noding/SinglePassNoder.h
@@ -58,7 +58,7 @@ public:
 	SinglePassNoder(SegmentIntersector* nSegInt=nullptr): segInt(nSegInt) {}
-	virtual ~SinglePassNoder() {}
+	~SinglePassNoder() override {}
 	 * Sets the SegmentIntersector to use with this noder.
@@ -78,7 +78,7 @@ public:
 	 * @param segStrings a collection of {@link SegmentString}s to node
-	virtual void computeNodes(std::vector<SegmentString*>* segStrings)=0;
+	void computeNodes(std::vector<SegmentString*>* segStrings) override =0;
 	 * Returns a {@link Collection} of fully noded {@link SegmentStrings}.
@@ -86,7 +86,7 @@ public:
 	 * @return a Collection of SegmentStrings
-	virtual std::vector<SegmentString*>* getNodedSubstrings() const=0;
+	std::vector<SegmentString*>* getNodedSubstrings() const override =0;
diff --git a/include/geos/noding/snapround/MCIndexSnapRounder.h b/include/geos/noding/snapround/MCIndexSnapRounder.h
index 8fa377f..ca1e6e5 100644
--- a/include/geos/noding/snapround/MCIndexSnapRounder.h
+++ b/include/geos/noding/snapround/MCIndexSnapRounder.h
@@ -84,11 +84,11 @@ public:
     li.setPrecisionModel(&pm);
-	void computeNodes(std::vector<SegmentString*>* segStrings);
+	void computeNodes(std::vector<SegmentString*>* segStrings) override;
 	 * Computes nodes introduced as a result of
diff --git a/include/geos/noding/snapround/SimpleSnapRounder.h b/include/geos/noding/snapround/SimpleSnapRounder.h
index 8d24cfb..095b478 100644
--- a/include/geos/noding/snapround/SimpleSnapRounder.h
+++ b/include/geos/noding/snapround/SimpleSnapRounder.h
@@ -76,9 +76,9 @@ public:
 	SimpleSnapRounder(const geom::PrecisionModel& newPm);
 	void add(const SegmentString* segStr);
diff --git a/include/geos/operation/distance/ConnectedElementLocationFilter.h b/include/geos/operation/distance/ConnectedElementLocationFilter.h
index 84658ac..046465e 100644
--- a/include/geos/operation/distance/ConnectedElementLocationFilter.h
+++ b/include/geos/operation/distance/ConnectedElementLocationFilter.h
@@ -68,8 +68,8 @@ public:
 		locations(newLocations)
-	void filter_ro(const geom::Geometry *geom);
-	void filter_rw(geom::Geometry *geom);
+	void filter_ro(const geom::Geometry *geom) override;
+	void filter_rw(geom::Geometry *geom) override;
diff --git a/include/geos/operation/distance/ConnectedElementPointFilter.h b/include/geos/operation/distance/ConnectedElementPointFilter.h
index d0c2b77..bf2de98 100644
--- a/include/geos/operation/distance/ConnectedElementPointFilter.h
+++ b/include/geos/operation/distance/ConnectedElementPointFilter.h
@@ -62,7 +62,7 @@ public:
 		pts(newPts)
 	//void filter_rw(geom::Geometry * /*geom*/) {};
diff --git a/include/geos/operation/linemerge/LineMergeGraph.h b/include/geos/operation/linemerge/LineMergeGraph.h
index a6a57fc..6c932d1 100644
--- a/include/geos/operation/linemerge/LineMergeGraph.h
+++ b/include/geos/operation/linemerge/LineMergeGraph.h
 	void addEdge(const geom::LineString *lineString);
-	~LineMergeGraph();
+	~LineMergeGraph() override;
 } // namespace geos::operation::linemerge
diff --git a/include/geos/operation/overlay/ElevationMatrix.h b/include/geos/operation/overlay/ElevationMatrix.h
index 0c2c2d6..9e3e52c 100644
--- a/include/geos/operation/overlay/ElevationMatrix.h
+++ b/include/geos/operation/overlay/ElevationMatrix.h
@@ -62,9 +62,9 @@ class GEOS_DLL ElevationMatrixFilter: public geom::CoordinateFilter
 public:
 	ElevationMatrixFilter(ElevationMatrix &em);
-	~ElevationMatrixFilter();
-	void filter_rw(geom::Coordinate *c) const;
-	void filter_ro(const geom::Coordinate *c);
+	~ElevationMatrixFilter() override;
+	void filter_rw(geom::Coordinate *c) const override;
+	void filter_ro(const geom::Coordinate *c) override;
 private:
 	ElevationMatrix &em;
 	double avgElevation;
diff --git a/include/geos/operation/overlay/MaximalEdgeRing.h b/include/geos/operation/overlay/MaximalEdgeRing.h
index 2c340d7..bee9505 100644
--- a/include/geos/operation/overlay/MaximalEdgeRing.h
+++ b/include/geos/operation/overlay/MaximalEdgeRing.h
@@ -71,11 +71,11 @@ public:
 		const geom::GeometryFactory *geometryFactory);
 			// throw(const TopologyException &)
-	virtual ~MaximalEdgeRing();
+	~MaximalEdgeRing() override;
-	geomgraph::DirectedEdge* getNext(geomgraph::DirectedEdge *de);
+	geomgraph::DirectedEdge* getNext(geomgraph::DirectedEdge *de) override;
-	void setEdgeRing(geomgraph::DirectedEdge* de, geomgraph::EdgeRing* er);
+	void setEdgeRing(geomgraph::DirectedEdge* de, geomgraph::EdgeRing* er) override;
 	/// \brief
 	/// This function returns a newly allocated vector of
diff --git a/include/geos/operation/overlay/MinimalEdgeRing.h b/include/geos/operation/overlay/MinimalEdgeRing.h
index 62ad3d9..6571241 100644
--- a/include/geos/operation/overlay/MinimalEdgeRing.h
+++ b/include/geos/operation/overlay/MinimalEdgeRing.h
@@ -61,12 +61,12 @@ public:
 	MinimalEdgeRing(geomgraph::DirectedEdge *start,
-	virtual ~MinimalEdgeRing();
+	~MinimalEdgeRing() override;
 	void setEdgeRing(geomgraph::DirectedEdge *de,
-			geomgraph::EdgeRing *er);
+			geomgraph::EdgeRing *er) override;
diff --git a/include/geos/operation/overlay/OverlayNodeFactory.h b/include/geos/operation/overlay/OverlayNodeFactory.h
index 6d66a4d..bd345b8 100644
--- a/include/geos/operation/overlay/OverlayNodeFactory.h
+++ b/include/geos/operation/overlay/OverlayNodeFactory.h
@@ -46,7 +46,7 @@ namespace overlay { // geos::operation::overlay
 class GEOS_DLL OverlayNodeFactory: public geomgraph::NodeFactory {
 public:
 	OverlayNodeFactory():geomgraph::NodeFactory() {}
-	geomgraph::Node* createNode(const geom::Coordinate &coord) const;
+	geomgraph::Node* createNode(const geom::Coordinate &coord) const override;
 	static const geomgraph::NodeFactory &instance();
diff --git a/include/geos/operation/overlay/OverlayOp.h b/include/geos/operation/overlay/OverlayOp.h
index e504541..ac52b2b 100644
--- a/include/geos/operation/overlay/OverlayOp.h
+++ b/include/geos/operation/overlay/OverlayOp.h
@@ -126,7 +126,7 @@ public:
 	OverlayOp(const geom::Geometry *g0, const geom::Geometry *g1);
-	virtual ~OverlayOp(); // FIXME: virtual ?
+	~OverlayOp() override; // FIXME: virtual ?
 	 * Gets the result of the overlay for a given overlay operation.
diff --git a/include/geos/operation/polygonize/PolygonizeGraph.h b/include/geos/operation/polygonize/PolygonizeGraph.h
index 3fe94c1..21248a1 100644
--- a/include/geos/operation/polygonize/PolygonizeGraph.h
+++ b/include/geos/operation/polygonize/PolygonizeGraph.h
 	 * \brief
 	 * Destroy a polygonization graph.
-	~PolygonizeGraph();
+	~PolygonizeGraph() override;
 	 * \brief
diff --git a/include/geos/operation/polygonize/Polygonizer.h b/include/geos/operation/polygonize/Polygonizer.h
index 203b3bf..6064db1 100644
--- a/include/geos/operation/polygonize/Polygonizer.h
+++ b/include/geos/operation/polygonize/Polygonizer.h
@@ -80,7 +80,7 @@ private:
 		Polygonizer *pol;
 		LineStringAdder(Polygonizer *p);
 		//void filter_rw(geom::Geometry *g);
-		void filter_ro(const geom::Geometry * g);
+		void filter_ro(const geom::Geometry * g) override;
 	// default factory
diff --git a/include/geos/operation/relate/EdgeEndBundle.h b/include/geos/operation/relate/EdgeEndBundle.h
index 4881497..eaba734 100644
--- a/include/geos/operation/relate/EdgeEndBundle.h
+++ b/include/geos/operation/relate/EdgeEndBundle.h
@@ -48,11 +48,11 @@ class GEOS_DLL EdgeEndBundle: public geomgraph::EdgeEnd
 public:
 	EdgeEndBundle(geomgraph::EdgeEnd *e);
-	virtual ~EdgeEndBundle();
+	~EdgeEndBundle() override;
 	std::vector<geomgraph::EdgeEnd*>* getEdgeEnds();
 	void insert(geomgraph::EdgeEnd *e);
-	void computeLabel(const algorithm::BoundaryNodeRule& bnr);
+	void computeLabel(const algorithm::BoundaryNodeRule& bnr) override;
    * \brief
diff --git a/include/geos/operation/relate/EdgeEndBundleStar.h b/include/geos/operation/relate/EdgeEndBundleStar.h
index 75b966b..9118b24 100644
--- a/include/geos/operation/relate/EdgeEndBundleStar.h
+++ b/include/geos/operation/relate/EdgeEndBundleStar.h
@@ -51,8 +51,8 @@ public:
 	/// Creates a new empty EdgeEndBundleStar
 	EdgeEndBundleStar() {}
-	virtual ~EdgeEndBundleStar();
-	void insert(geomgraph::EdgeEnd *e);
+	~EdgeEndBundleStar() override;
+	void insert(geomgraph::EdgeEnd *e) override;
 	 * Update the IM with the contribution for the EdgeStubs around the node.
diff --git a/include/geos/operation/relate/RelateNode.h b/include/geos/operation/relate/RelateNode.h
index d1ae36d..7d9c43f 100644
--- a/include/geos/operation/relate/RelateNode.h
+++ b/include/geos/operation/relate/RelateNode.h
@@ -49,7 +49,7 @@ public:
 	RelateNode(const geom::Coordinate& coord, geomgraph::EdgeEndStar *edges);
-	virtual ~RelateNode();
+	~RelateNode() override;
 	 * Update the IM with the contribution for the EdgeEnds incident on this node.
 protected:
-	void computeIM(geom::IntersectionMatrix& im);
+	void computeIM(geom::IntersectionMatrix& im) override;
diff --git a/include/geos/operation/relate/RelateNodeFactory.h b/include/geos/operation/relate/RelateNodeFactory.h
index 3815a2b..60e38e2 100644
--- a/include/geos/operation/relate/RelateNodeFactory.h
+++ b/include/geos/operation/relate/RelateNodeFactory.h
@@ -43,7 +43,7 @@ namespace relate { // geos::operation::relate
 class GEOS_DLL RelateNodeFactory: public geomgraph::NodeFactory {
 public:
 private:
 	RelateNodeFactory() {}
diff --git a/include/geos/operation/relate/RelateOp.h b/include/geos/operation/relate/RelateOp.h
index 5ba5556..b3b99f6 100644
--- a/include/geos/operation/relate/RelateOp.h
+++ b/include/geos/operation/relate/RelateOp.h
 	         const geom::Geometry *g1,
-	virtual ~RelateOp();
+	~RelateOp() override;
 	/** \brief
 	 * Gets the IntersectionMatrix for the spatial relationship
diff --git a/include/geos/operation/valid/SweeplineNestedRingTester.h b/include/geos/operation/valid/SweeplineNestedRingTester.h
index d79fe13..86e21f6 100644
--- a/include/geos/operation/valid/SweeplineNestedRingTester.h
+++ b/include/geos/operation/valid/SweeplineNestedRingTester.h
@@ -102,7 +102,7 @@ public:
 		bool isNonNested;
 		OverlapAction(SweeplineNestedRingTester *p);
 		void overlap(index::sweepline::SweepLineInterval *s0,
-				index::sweepline::SweepLineInterval *s1);
+				index::sweepline::SweepLineInterval *s1) override;
 	private:
 		SweeplineNestedRingTester *parent;
diff --git a/include/geos/planargraph/Node.h b/include/geos/planargraph/Node.h
index 903b0da..5a96ac9 100644
--- a/include/geos/planargraph/Node.h
+++ b/include/geos/planargraph/Node.h
 		pt(newPt)
 		{ deStar=new DirectedEdgeStar(); }
-	virtual ~Node() {
 		delete deStar;
diff --git a/include/geos/precision/PrecisionReducerCoordinateOperation.h b/include/geos/precision/PrecisionReducerCoordinateOperation.h
index e0b05db..90cb5ee 100644
--- a/include/geos/precision/PrecisionReducerCoordinateOperation.h
+++ b/include/geos/precision/PrecisionReducerCoordinateOperation.h
   /// virtual function
 	geom::CoordinateSequence* edit(const geom::CoordinateSequence *coordinates,
-	                         const geom::Geometry *geom);
+	                         const geom::Geometry *geom) override;
 } // namespace geos.precision
diff --git a/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h b/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h
index f280621..e7c9e65 100644
--- a/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h
+++ b/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h
 	 * The search starts from the last located edge amd proceeds on the general direction of v.
 	 * @return The caller _does not_ take ownership of the returned object.
-	virtual QuadEdge* locate(const Vertex &v);
+	QuadEdge* locate(const Vertex &v) override;
 } //namespace geos.triangulate.quadedge
diff --git a/include/geos/util/AssertionFailedException.h b/include/geos/util/AssertionFailedException.h
index b336615..7142c69 100644
--- a/include/geos/util/AssertionFailedException.h
+++ b/include/geos/util/AssertionFailedException.h
@@ -41,7 +41,7 @@ public:
 		GEOSException("AssertionFailedException", msg)
-	~AssertionFailedException() throw() {}
+	~AssertionFailedException() throw() override {}
 } // namespace geos.util
diff --git a/include/geos/util/GEOSException.h b/include/geos/util/GEOSException.h
index 632b5c1..26fd05d 100644
--- a/include/geos/util/GEOSException.h
+++ b/include/geos/util/GEOSException.h
@@ -57,10 +57,10 @@ public:
 		_msg(name+": "+msg)
-	virtual ~GEOSException() throw()
+	~GEOSException() throw() override
-	const char* what() const throw()
+	const char* what() const throw() override
 		return _msg.c_str();
diff --git a/include/geos/util/IllegalArgumentException.h b/include/geos/util/IllegalArgumentException.h
index 8e3b03c..f58a7d2 100644
--- a/include/geos/util/IllegalArgumentException.h
+++ b/include/geos/util/IllegalArgumentException.h
@@ -43,7 +43,7 @@ public:
 		GEOSException("IllegalArgumentException", msg)
-	~IllegalArgumentException() throw() {}
+	~IllegalArgumentException() throw() override {}
 } // namespace geos::util
diff --git a/include/geos/util/IllegalStateException.h b/include/geos/util/IllegalStateException.h
index 6eae12d..d23281f 100644
--- a/include/geos/util/IllegalStateException.h
+++ b/include/geos/util/IllegalStateException.h
 		GEOSException("IllegalStateException", msg)
-	~IllegalStateException() throw() {}
+	~IllegalStateException() throw() override {}
diff --git a/include/geos/util/TopologyException.h b/include/geos/util/TopologyException.h
index 332e6eb..f87fd54 100644
--- a/include/geos/util/TopologyException.h
+++ b/include/geos/util/TopologyException.h
@@ -50,7 +50,7 @@ public:
 		pt(newPt)
-	~TopologyException() throw() {}
+	~TopologyException() throw() override {}
 	geom::Coordinate& getCoordinate() { return pt; }
 private:
 	geom::Coordinate pt;
diff --git a/include/geos/util/UniqueCoordinateArrayFilter.h b/include/geos/util/UniqueCoordinateArrayFilter.h
index da42e38..4e52bec 100644
--- a/include/geos/util/UniqueCoordinateArrayFilter.h
+++ b/include/geos/util/UniqueCoordinateArrayFilter.h
 	 * delete a derived-class object via a base-class pointer.
 	 * http://www.parashift.com/c++-faq-lite/virtual-functions.html#faq-20.7
-	virtual ~UniqueCoordinateArrayFilter() {}
+	~UniqueCoordinateArrayFilter() override {}
 	 * Performs a filtering operation with or on coord in "read-only" mode.
 	 * @param coord The "read-only" Coordinate to which
 	 * 				the filter is applied.
-	virtual void filter_ro(const geom::Coordinate *coord)
+	void filter_ro(const geom::Coordinate *coord) override
 		if ( uniqPts.insert(coord).second )
diff --git a/include/geos/util/UnsupportedOperationException.h b/include/geos/util/UnsupportedOperationException.h
index 69aa718..95b2715 100644
--- a/include/geos/util/UnsupportedOperationException.h
+++ b/include/geos/util/UnsupportedOperationException.h
@@ -45,7 +45,7 @@ public:
 		GEOSException("UnsupportedOperationException", msg)
-	~UnsupportedOperationException() throw() {}
+	~UnsupportedOperationException() throw() override {}
diff --git a/src/algorithm/BoundaryNodeRule.cpp b/src/algorithm/BoundaryNodeRule.cpp
index 8c4ce69..1603696 100644
--- a/src/algorithm/BoundaryNodeRule.cpp
+++ b/src/algorithm/BoundaryNodeRule.cpp
@@ -44,7 +44,7 @@ namespace {
 class Mod2BoundaryNodeRule : public BoundaryNodeRule
 public:
-	bool isInBoundary(int boundaryCount) const
+	bool isInBoundary(int boundaryCount) const override
 		// the "Mod-2 Rule"
 		return boundaryCount % 2 == 1;
@@ -81,7 +81,7 @@ public:
 class EndPointBoundaryNodeRule : public BoundaryNodeRule
 		return boundaryCount > 0;
@@ -99,7 +99,7 @@ class EndPointBoundaryNodeRule : public BoundaryNodeRule
 class MultiValentEndPointBoundaryNodeRule : public BoundaryNodeRule
 		return boundaryCount > 1;
@@ -116,7 +116,7 @@ class MultiValentEndPointBoundaryNodeRule : public BoundaryNodeRule
 class MonoValentEndPointBoundaryNodeRule : public BoundaryNodeRule
 		return boundaryCount == 1;
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index 4c2b2a0..f60025c 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -68,7 +68,7 @@ public:
       : _gsf(gsf)
   CoordinateSequence* edit( const CoordinateSequence *coordSeq,
-                            const Geometry * )
+                            const Geometry * ) override
     return _gsf->create(*coordSeq);
diff --git a/src/index/strtree/SIRtree.cpp b/src/index/strtree/SIRtree.cpp
index 3c5505b..b5a2cbd 100644
--- a/src/index/strtree/SIRtree.cpp
+++ b/src/index/strtree/SIRtree.cpp
@@ -91,14 +91,14 @@ public:
 		AbstractNode(level, capacity)
-	~SIRAbstractNode()
+	~SIRAbstractNode() override
 		delete (Interval *)bounds;
 protected:
-	void* computeBounds() const
+	void* computeBounds() const override
 		Interval* bounds=nullptr;
 		const BoundableList& b = *getChildBoundables();
diff --git a/src/index/strtree/STRtree.cpp b/src/index/strtree/STRtree.cpp
index 4670811..b9f5e68 100644
--- a/src/index/strtree/STRtree.cpp
+++ b/src/index/strtree/STRtree.cpp
@@ -282,14 +282,14 @@ public:
-	~STRAbstractNode()
+	~STRAbstractNode() override
 		delete (Envelope *)bounds;
 protected:
 		Envelope* bounds=nullptr;
diff --git a/src/noding/GeometryNoder.cpp b/src/noding/GeometryNoder.cpp
index bf02d7b..615fe12 100644
--- a/src/noding/GeometryNoder.cpp
+++ b/src/noding/GeometryNoder.cpp
     : _to(to)
-  void filter_ro(const geom::Geometry * g) {
+  void filter_ro(const geom::Geometry * g) override {
     const geom::LineString *ls = dynamic_cast<const geom::LineString *>(g);
     if ( ls ) {
       geom::CoordinateSequence* coord = ls->getCoordinates();
diff --git a/src/noding/ScaledNoder.cpp b/src/noding/ScaledNoder.cpp
index 517d595..e31a820 100644
--- a/src/noding/ScaledNoder.cpp
+++ b/src/noding/ScaledNoder.cpp
 	//void filter_ro(const geom::Coordinate* c) { assert(0); }
-	void filter_rw(geom::Coordinate* c) const {
+	void filter_rw(geom::Coordinate* c) const override {
 		c->x = util::round( ( c->x - sn.offsetX ) * sn.scaleFactor );
 		c->y = util::round( ( c->y - sn.offsetY ) * sn.scaleFactor );
@@ -109,13 +109,13 @@ public:
 #endif
-	void filter_ro(const geom::Coordinate* c)
+	void filter_ro(const geom::Coordinate* c) override
         ::geos::ignore_unused_variable_warning(c);
         assert(0);
 		c->x = c->x / sn.scaleFactor + sn.offsetX;
 		c->y = c->y / sn.scaleFactor + sn.offsetY;
diff --git a/src/noding/snapround/MCIndexPointSnapper.cpp b/src/noding/snapround/MCIndexPointSnapper.cpp
index 56a6859..281bb70 100644
--- a/src/noding/snapround/MCIndexPointSnapper.cpp
+++ b/src/noding/snapround/MCIndexPointSnapper.cpp
 	bool isNodeAdded() const { return isNodeAddedVar; }
-	void select(chain::MonotoneChain& mc, unsigned int startIndex)
+	void select(chain::MonotoneChain& mc, unsigned int startIndex) override
 		// This is casting away 'constness'!
 		NodedSegmentString& ss = *(static_cast<NodedSegmentString*>(mc.getContext()));
 		isNodeAddedVar = hotPixel.addSnappedNode(ss, startIndex);
-	void select(const LineSegment& ls)
+	void select(const LineSegment& ls) override
 		::geos::ignore_unused_variable_warning(ls);
@@ -93,9 +93,9 @@ public:
 		action(nAction)
-	virtual ~MCIndexPointSnapperVisitor() {}
+	~MCIndexPointSnapperVisitor() override {}
-	void visitItem(void* item) {
+	void visitItem(void* item) override {
 		chain::MonotoneChain& testChain =
 			*(static_cast<chain::MonotoneChain*>(item));
 		testChain.select(pixelEnv, action);
diff --git a/src/operation/distance/FacetSequenceTreeBuilder.cpp b/src/operation/distance/FacetSequenceTreeBuilder.cpp
index e1273af..d7456c2 100644
--- a/src/operation/distance/FacetSequenceTreeBuilder.cpp
+++ b/src/operation/distance/FacetSequenceTreeBuilder.cpp
@@ -49,7 +49,7 @@ std::vector<FacetSequence*> * FacetSequenceTreeBuilder::computeFacetSequences(co
     public :
         FacetSequenceAdder(std::vector<FacetSequence*> * p_sections) :
             m_sections(p_sections) {}
-        void filter_ro(const Geometry* geom) {
+        void filter_ro(const Geometry* geom) override {
             if (const LineString* ls = dynamic_cast<const LineString*>(geom)) {
                 const CoordinateSequence* seq = ls->getCoordinatesRO();
                 addFacetSequences(seq, *m_sections);
diff --git a/src/operation/distance/IndexedFacetDistance.cpp b/src/operation/distance/IndexedFacetDistance.cpp
index a8f4d55..31f00d0 100644
--- a/src/operation/distance/IndexedFacetDistance.cpp
+++ b/src/operation/distance/IndexedFacetDistance.cpp
@@ -27,7 +27,7 @@ namespace geos {
     namespace operation {
         namespace distance {
             struct Deleter : public index::ItemVisitor {
-                void visitItem(void * item) {
+                void visitItem(void * item) override {
                     delete static_cast<FacetSequence*>(item);
             } deleter;
@@ -39,7 +39,7 @@ namespace geos {
             double IndexedFacetDistance::getDistance(const Geometry * g) const {
                 struct : public ItemDistance {
-                    double distance(const ItemBoundable* item1, const ItemBoundable* item2) {
+                    double distance(const ItemBoundable* item1, const ItemBoundable* item2) override {
                         return static_cast<const FacetSequence*>(item1->getItem())->distance(*static_cast<const FacetSequence*>(item2->getItem()));
                 } itemDistance;
diff --git a/src/operation/overlay/OverlayOp.cpp b/src/operation/overlay/OverlayOp.cpp
index e2e9b2f..77f8773 100644
--- a/src/operation/overlay/OverlayOp.cpp
+++ b/src/operation/overlay/OverlayOp.cpp
@@ -962,7 +962,7 @@ struct PointCoveredByAny: public geom::CoordinateFilter
 		: geoms(nGeoms)
-	void filter_ro(const Coordinate* coord)
+	void filter_ro(const Coordinate* coord) override
 		for (size_t i=0, n=geoms.size(); i<n; ++i)
diff --git a/src/operation/overlay/snap/GeometrySnapper.cpp b/src/operation/overlay/snap/GeometrySnapper.cpp
index f7d03f4..53b3ed5 100644
--- a/src/operation/overlay/snap/GeometrySnapper.cpp
+++ b/src/operation/overlay/snap/GeometrySnapper.cpp
 	CoordinateSequence::Ptr transformCoordinates(
 			const CoordinateSequence* coords,
-			const Geometry* parent)
+			const Geometry* parent) override
         ::geos::ignore_unused_variable_warning(parent);
 		return snapLine(coords);
diff --git a/src/operation/predicate/RectangleIntersects.cpp b/src/operation/predicate/RectangleIntersects.cpp
index fd66c5e..0a159f5 100644
--- a/src/operation/predicate/RectangleIntersects.cpp
+++ b/src/operation/predicate/RectangleIntersects.cpp
 	 * @return <code>true</code> if an intersection must occur
 	 * <code>false</code> if no conclusion can be made
-	void visit(const geom::Geometry &element)
+	void visit(const geom::Geometry &element) override
 		const geom::Envelope &elementEnv = *(element.getEnvelopeInternal());
@@ -101,7 +101,7 @@ protected:
-	bool isDone() { return intersectsVar==true; }
+	bool isDone() override { return intersectsVar==true; }
 public:
@@ -137,7 +137,7 @@ private:
 protected:
-	void visit(const geom::Geometry &geom)
+	void visit(const geom::Geometry &geom) override
 		using geos::algorithm::locate::SimplePointInAreaLocator;
@@ -174,7 +174,7 @@ protected:
-	bool isDone() { return containsPointVar; }
+	bool isDone() override { return containsPointVar; }
 public:
@@ -225,7 +225,7 @@ private:
 protected:
 		const geom::Envelope &elementEnv = *(geom.getEnvelopeInternal());
@@ -235,7 +235,7 @@ protected:
 		computeSegmentIntersection(geom);
-	bool isDone() { return intersectsVar; }
+	bool isDone() override { return intersectsVar; }
 public:
diff --git a/src/precision/CommonBitsRemover.cpp b/src/precision/CommonBitsRemover.cpp
index 9e19bd9..d72b6af 100644
--- a/src/precision/CommonBitsRemover.cpp
+++ b/src/precision/CommonBitsRemover.cpp
@@ -49,13 +49,13 @@ public:
 		trans(newTrans)
-	void filter_ro(const geom::Coordinate *coord)  //Not used
+	void filter_ro(const geom::Coordinate *coord) override  //Not used
         ::geos::ignore_unused_variable_warning(coord);
         assert(0);
-	void filter_rw(geom::Coordinate *coord) const
+	void filter_rw(geom::Coordinate *coord) const override
 		coord->x += trans.x;
 		coord->y += trans.y;
@@ -69,14 +69,14 @@ private:
 	CommonBits commonBitsY;
 public:
         // CommonCoordinateFilter is a read-only filter
 		assert(0);
 		commonBitsX.add(coord->x);
 		commonBitsY.add(coord->y);
diff --git a/src/precision/MinimumClearance.cpp b/src/precision/MinimumClearance.cpp
index ed020f8..34e6b6a 100644
--- a/src/precision/MinimumClearance.cpp
+++ b/src/precision/MinimumClearance.cpp
@@ -72,7 +72,7 @@ void MinimumClearance::compute() {
             return &minPts;
-        double distance(const ItemBoundable* b1, const ItemBoundable* b2) {
+        double distance(const ItemBoundable* b1, const ItemBoundable* b2) override {
             FacetSequence* fs1 = static_cast<FacetSequence*>(b1->getItem());
             FacetSequence* fs2 = static_cast<FacetSequence*>(b2->getItem());
@@ -142,7 +142,7 @@ void MinimumClearance::compute() {
     struct ItemDeleter : public index::ItemVisitor {
diff --git a/src/precision/SimpleGeometryPrecisionReducer.cpp b/src/precision/SimpleGeometryPrecisionReducer.cpp
index 29d1297..dc2ce56 100644
--- a/src/precision/SimpleGeometryPrecisionReducer.cpp
+++ b/src/precision/SimpleGeometryPrecisionReducer.cpp
 	/// Ownership of returned CoordinateSequence to caller
 	CoordinateSequence* edit(const CoordinateSequence *coordinates,
-	                         const Geometry *geom);
+	                         const Geometry *geom) override;
 PrecisionReducerCoordinateOperation::PrecisionReducerCoordinateOperation(
diff --git a/src/simplify/DouglasPeuckerSimplifier.cpp b/src/simplify/DouglasPeuckerSimplifier.cpp
index 239b71b..48bd6dd 100644
--- a/src/simplify/DouglasPeuckerSimplifier.cpp
+++ b/src/simplify/DouglasPeuckerSimplifier.cpp
@@ -53,15 +53,15 @@ protected:
-			const Geometry* parent);
+			const Geometry* parent) override;
 	Geometry::Ptr transformPolygon(
 			const Polygon* geom,
 	Geometry::Ptr transformMultiPolygon(
 			const MultiPolygon* geom,
 private:
diff --git a/src/simplify/LineSegmentIndex.cpp b/src/simplify/LineSegmentIndex.cpp
index 9173d49..efffb6f 100644
--- a/src/simplify/LineSegmentIndex.cpp
+++ b/src/simplify/LineSegmentIndex.cpp
 		items(new vector<LineSegment*>())
-	virtual ~LineSegmentVisitor()
+	~LineSegmentVisitor() override
 		// nothing to do, LineSegments are not owned by us
 		return *this;
 		LineSegment* seg = (LineSegment*) item;
 		if ( Envelope::intersects(seg->p0, seg->p1,
diff --git a/src/simplify/TopologyPreservingSimplifier.cpp b/src/simplify/TopologyPreservingSimplifier.cpp
index 689c5e5..4e44706 100644
--- a/src/simplify/TopologyPreservingSimplifier.cpp
+++ b/src/simplify/TopologyPreservingSimplifier.cpp
@@ -69,7 +69,7 @@ protected:
 private:
@@ -203,7 +203,7 @@ public:
 	 * geom a geometry of any type
-	void filter_ro(const Geometry* geom);
+	void filter_ro(const Geometry* geom) override;
diff --git a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
index feefda1..5291798 100644
--- a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
+++ b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
@@ -383,7 +383,7 @@ public:
-    void visit(QuadEdge* triEdges[3])
+    void visit(QuadEdge* triEdges[3]) override
         geom::CoordinateSequence *coordSeq = coordSeqFact.create(4,0);
         for (int i = 0; i < 3; i++) {
@@ -400,7 +400,7 @@ class
 QuadEdgeSubdivision::TriangleCircumcentreVisitor : public TriangleVisitor
 public:
 		Triangle triangle(triEdges[0]->orig().getCoordinate(),
 				triEdges[1]->orig().getCoordinate(), triEdges[2]->orig().getCoordinate());
diff --git a/tests/unit/geom/CoordinateArraySequenceTest.cpp b/tests/unit/geom/CoordinateArraySequenceTest.cpp
index 4d4162c..000504f 100644
--- a/tests/unit/geom/CoordinateArraySequenceTest.cpp
+++ b/tests/unit/geom/CoordinateArraySequenceTest.cpp
@@ -28,7 +28,7 @@ namespace tut
           bool is3d;
           Filter() : is3d(false) {}
-          void filter_rw(geos::geom::Coordinate* c) const {
+          void filter_rw(geos::geom::Coordinate* c) const override {
             if ( is3d ) {
               if ( ISNAN(c->z) ) c->z = 0.0;
diff --git a/tests/unit/geom/GeometryComponentFilterTest.cpp b/tests/unit/geom/GeometryComponentFilterTest.cpp
index 09fbf11..9f6a220 100644
--- a/tests/unit/geom/GeometryComponentFilterTest.cpp
+++ b/tests/unit/geom/GeometryComponentFilterTest.cpp
@@ -59,14 +59,14 @@ void object::test<1>()
             ensure(lineal.empty());
             ensure(nonlineal.empty());
-        void filter_ro(geos::geom::Geometry const* g)
+        void filter_ro(geos::geom::Geometry const* g) override
             if (dynamic_cast<geos::geom::Lineal const*>(g))
                 lineal.push_back(g);
             else
                 nonlineal.push_back(g);
-        void filter_rw(geos::geom::Geometry*) {}
+        void filter_rw(geos::geom::Geometry*) override {}
     GeometryRefArray lineal;
diff --git a/tests/unit/geom/GeometryFilterTest.cpp b/tests/unit/geom/GeometryFilterTest.cpp
index c3b1f92..99afe5e 100644
--- a/tests/unit/geom/GeometryFilterTest.cpp
+++ b/tests/unit/geom/GeometryFilterTest.cpp
             else
diff --git a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
index edeb61d..9be23a6 100644
--- a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
+++ b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
@@ -301,18 +301,18 @@ namespace tut
             double f;
             Multiplier(double f) : f(f) {}
-            void filter_rw(CoordinateSequence& seq, std::size_t i)
+            void filter_rw(CoordinateSequence& seq, std::size_t i) override
                 seq.setOrdinate(i, CoordinateSequence::X, seq[i].x * f);
                 seq.setOrdinate(i, CoordinateSequence::Y, seq[i].y * f);
-            void filter_ro(const CoordinateSequence& seq, std::size_t i)
+            void filter_ro(const CoordinateSequence& seq, std::size_t i) override
                 ::geos::ignore_unused_variable_warning(seq);
                 ::geos::ignore_unused_variable_warning(i);
-            bool isDone() const { return false; }
-            bool isGeometryChanged() const { return true; }
+            bool isDone() const override { return false; }
+            bool isGeometryChanged() const override { return true; }
         Multiplier m(2047);
diff --git a/tests/unit/tut/tut.hpp b/tests/unit/tut/tut.hpp
index ccb4d06..e8aabd8 100644
--- a/tests/unit/tut/tut.hpp
+++ b/tests/unit/tut/tut.hpp
@@ -107,7 +107,7 @@ public:
     bool called_method_was_a_dummy_test_;
-    virtual ~test_object()
+    ~test_object() override
@@ -338,7 +338,7 @@ public:
      * Reset test position before first test.
-    void rewind()
+    void rewind() override
         current_test_ = tests_.begin();
@@ -346,7 +346,7 @@ public:
      * Runs next test.
-    bool run_next(test_result &tr)
+    bool run_next(test_result &tr) override
         if (current_test_ == tests_.end())
@@ -371,7 +371,7 @@ public:
      * Runs one test by position.
-    bool run_test(int n, test_result &tr)
+    bool run_test(int n, test_result &tr) override
         if (tests_.rbegin() == tests_.rend() ||
             tests_.rbegin()->first < n)
diff --git a/tests/unit/tut/tut_console_reporter.hpp b/tests/unit/tut/tut_console_reporter.hpp
index 614e1f2..28ee4ca 100644
--- a/tests/unit/tut/tut_console_reporter.hpp
+++ b/tests/unit/tut/tut_console_reporter.hpp
@@ -108,12 +108,12 @@ public:
         init();
-    void run_started()
+    void run_started() override
         init();
-    void test_completed(const tut::test_result& tr)
+    void test_completed(const tut::test_result& tr) override
         if (tr.group != current_group)
@@ -156,7 +156,7 @@ public:
-    void run_completed()
+    void run_completed() override
         os << std::endl;
@@ -256,7 +256,7 @@ public:
         os << std::endl;
-    virtual bool all_ok() const
+    bool all_ok() const override
         return not_passed.empty();
diff --git a/tests/unit/tut/tut_exception.hpp b/tests/unit/tut/tut_exception.hpp
index 1ebea34..4120428 100644
--- a/tests/unit/tut/tut_exception.hpp
+++ b/tests/unit/tut/tut_exception.hpp
@@ -27,12 +27,12 @@ struct tut_error : public std::exception
         return "tut::tut_error";
         return err_msg.c_str();
-    ~tut_error() throw()
+    ~tut_error() throw() override
@@ -52,12 +52,12 @@ struct no_such_group : public tut_error
-    virtual std::string type() const
+    std::string type() const override
         return "tut::no_such_group";
-    ~no_such_group() throw()
+    ~no_such_group() throw() override
@@ -72,12 +72,12 @@ struct no_such_test : public tut_error
         return "tut::no_such_test";
-    ~no_such_test() throw()
+    ~no_such_test() throw() override
@@ -93,17 +93,17 @@ struct bad_ctor : public tut_error
-    test_result::result_type result() const
+    test_result::result_type result() const override
         return test_result::ex_ctor;
         return "tut::bad_ctor";
-    ~bad_ctor() throw()
+    ~bad_ctor() throw() override
@@ -118,17 +118,17 @@ struct failure : public tut_error
         return test_result::fail;
         return "tut::failure";
-    ~failure() throw()
+    ~failure() throw() override
@@ -143,17 +143,17 @@ struct warning : public tut_error
         return test_result::warn;
         return "tut::warning";
-    ~warning() throw()
+    ~warning() throw() override
@@ -168,17 +168,17 @@ struct seh : public tut_error
-    virtual test_result::result_type result() const
         return test_result::term;
         return "tut::seh";
-    ~seh() throw()
+    ~seh() throw() override
@@ -193,17 +193,17 @@ struct rethrown : public failure
         return test_result::rethrown;
         return "tut::rethrown";
-    ~rethrown() throw()
+    ~rethrown() throw() override
@@ -217,17 +217,17 @@ struct skipped : public tut_error
         return test_result::skipped;
         return "tut::skipped";
-    ~skipped() throw()
+    ~skipped() throw() override
diff --git a/tests/unit/tut/tut_result.hpp b/tests/unit/tut/tut_result.hpp
index 28a5671..078f257 100644
--- a/tests/unit/tut/tut_result.hpp
+++ b/tests/unit/tut/tut_result.hpp
@@ -169,7 +169,7 @@ struct test_result : public test_result_posix
-    virtual ~test_result()
+    ~test_result() override
diff --git a/tests/xmltester/tinyxml/tinyxml.h b/tests/xmltester/tinyxml/tinyxml.h
index 92b4264..31b873a 100644
--- a/tests/xmltester/tinyxml/tinyxml.h
+++ b/tests/xmltester/tinyxml/tinyxml.h
@@ -471,7 +471,7 @@ public:
 		TYPECOUNT
-	virtual ~TiXmlNode();
+	~TiXmlNode() override;
 	/** The meaning of 'value' changes for the specific type of
 		TiXmlNode.
@@ -865,10 +865,10 @@ public:
 	/*	Attribute parsing starts: first letter of the name
 						 returns: the next char after the value end quote
-	virtual const char* Parse( const char* p, TiXmlParsingData* data, TiXmlEncoding encoding );
+	const char* Parse( const char* p, TiXmlParsingData* data, TiXmlEncoding encoding ) override;
 	// Prints this Attribute to a FILE stream.
-	virtual void Print( FILE* cfile, int depth ) const {
+	void Print( FILE* cfile, int depth ) const override {
 		Print( cfile, depth, nullptr );
 	void Print( FILE* cfile, int depth, TIXML_STRING* str ) const;
@@ -956,7 +956,7 @@ public:
 	void operator=( const TiXmlElement& base );
-	virtual ~TiXmlElement();
+	~TiXmlElement() override;
 	/** Given an attribute name, Attribute() returns the value
 		for the attribute of that name, or null if none exists.
@@ -1112,21 +1112,21 @@ public:
 	const char* GetText() const;
 	/// Creates a new Element and returns it - the returned element is a copy.
-	virtual TiXmlNode* Clone() const;
+	TiXmlNode* Clone() const override;
 	// Print the Element to a FILE stream.
-	virtual void Print( FILE* cfile, int depth ) const;
+	void Print( FILE* cfile, int depth ) const override;
 	/*	Attribtue parsing starts: next char past '<'
 						 returns: next char past '>'
-	virtual const TiXmlElement*     ToElement()     const { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
-	virtual TiXmlElement*           ToElement()	          { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
+	const TiXmlElement*     ToElement()     const override { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
+	TiXmlElement*           ToElement() override	          { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
 	/** Walk the XML tree visiting this node and all of its children.
-	virtual bool Accept( TiXmlVisitor* visitor ) const;
+	bool Accept( TiXmlVisitor* visitor ) const override;
 protected:
@@ -1163,24 +1163,24 @@ public:
 	TiXmlComment( const TiXmlComment& );
 	void operator=( const TiXmlComment& base );
-	virtual ~TiXmlComment()	{}
+	~TiXmlComment() override	{}
 	/// Returns a copy of this Comment.
 	// Write this Comment to a FILE stream.
 	/*	Attribtue parsing starts: at the ! of the !--
-	virtual const TiXmlComment*  ToComment() const { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
-	virtual TiXmlComment*  ToComment() { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
+	const TiXmlComment*  ToComment() const override { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
+	TiXmlComment*  ToComment() override { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
 protected:
 	void CopyTo( TiXmlComment* target ) const;
@@ -1214,7 +1214,7 @@ public:
 		SetValue( initValue );
 		cdata = false;
-	virtual ~TiXmlText() {}
+	~TiXmlText() override {}
 	#ifdef TIXML_USE_STL
 	/// Constructor.
@@ -1229,25 +1229,25 @@ public:
 	void operator=( const TiXmlText& base )							 	{ base.CopyTo( this ); }
 	// Write this text object to a FILE stream.
 	/// Queries whether this represents text using a CDATA section.
 	bool CDATA() const				{ return cdata; }
 	/// Turns on or off a CDATA representation of text.
 	void SetCDATA( bool _cdata )	{ cdata = _cdata; }
-	virtual const TiXmlText* ToText() const { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
-	virtual TiXmlText*       ToText()       { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
+	const TiXmlText* ToText() const override { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
+	TiXmlText*       ToText() override       { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
-	virtual bool Accept( TiXmlVisitor* content ) const;
+	bool Accept( TiXmlVisitor* content ) const override;
 protected :
 	///  [internal use] Creates a new Element and returns it.
 	void CopyTo( TiXmlText* target ) const;
 	bool Blank() const;	// returns true if all white space and new lines
@@ -1295,7 +1295,7 @@ public:
 	TiXmlDeclaration( const TiXmlDeclaration& copy );
 	void operator=( const TiXmlDeclaration& copy );
-	virtual ~TiXmlDeclaration()	{}
+	~TiXmlDeclaration() override	{}
 	/// Version. Will return an empty string if none was found.
 	const char *Version() const			{ return version.c_str (); }
@@ -1305,21 +1305,21 @@ public:
 	const char *Standalone() const		{ return standalone.c_str (); }
 	/// Creates a copy of this Declaration and returns it.
 	// Print this declaration to a FILE stream.
 	virtual void Print( FILE* cfile, int depth, TIXML_STRING* str ) const;
-	virtual const TiXmlDeclaration* ToDeclaration() const { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
-	virtual TiXmlDeclaration*       ToDeclaration()       { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
+	const TiXmlDeclaration* ToDeclaration() const override { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
+	TiXmlDeclaration*       ToDeclaration() override       { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
 protected:
 	void CopyTo( TiXmlDeclaration* target ) const;
@@ -1347,24 +1347,24 @@ class TiXmlUnknown : public TiXmlNode
 public:
 	TiXmlUnknown() : TiXmlNode( TiXmlNode::UNKNOWN )	{}
-	virtual ~TiXmlUnknown() {}
+	~TiXmlUnknown() override {}
 	TiXmlUnknown( const TiXmlUnknown& copy ) : TiXmlNode( TiXmlNode::UNKNOWN )		{ copy.CopyTo( this ); }
 	void operator=( const TiXmlUnknown& copy )										{ copy.CopyTo( this ); }
 	/// Creates a copy of this Unknown and returns it.
 	// Print this Unknown to a FILE stream.
-	virtual const TiXmlUnknown*     ToUnknown()     const { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
-	virtual TiXmlUnknown*           ToUnknown()	    { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
+	const TiXmlUnknown*     ToUnknown()     const override { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
+	TiXmlUnknown*           ToUnknown() override	    { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
 protected:
 	void CopyTo( TiXmlUnknown* target ) const;
@@ -1398,7 +1398,7 @@ public:
 	TiXmlDocument( const TiXmlDocument& copy );
 	void operator=( const TiXmlDocument& copy );
-	virtual ~TiXmlDocument() {}
+	~TiXmlDocument() override {}
 	/** Load a file using the current document value.
 		Returns true if successful. Will delete any existing
@@ -1439,7 +1439,7 @@ public:
 		method (either TIXML_ENCODING_LEGACY or TIXML_ENCODING_UTF8 will force TinyXml
 		to use that encoding, regardless of what TinyXml might otherwise try to detect.
-	virtual const char* Parse( const char* p, TiXmlParsingData* data = nullptr, TiXmlEncoding encoding = TIXML_DEFAULT_ENCODING );
+	const char* Parse( const char* p, TiXmlParsingData* data = nullptr, TiXmlEncoding encoding = TIXML_DEFAULT_ENCODING ) override;
 	/** Get the root element -- the only top level element -- of the document.
 		In well formed XML, there should only be one. TinyXml is tolerant of
@@ -1521,20 +1521,20 @@ public:
 	//char* PrintToMemory() const;
 	/// Print this Document to a FILE stream.
-	virtual void Print( FILE* cfile, int depth = 0 ) const;
+	void Print( FILE* cfile, int depth = 0 ) const override;
 	// [internal use]
 	void SetError( int err, const char* errorLocation, TiXmlParsingData* prevData, TiXmlEncoding encoding );
-	virtual const TiXmlDocument*    ToDocument()    const { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
-	virtual TiXmlDocument*          ToDocument()          { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
+	const TiXmlDocument*    ToDocument()    const override { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
+	TiXmlDocument*          ToDocument() override          { return this; } ///< Cast to a more defined type. Will return null not of the requested type.
 protected :
 	// [internal use]
 	virtual void StreamIn( std::istream * in, TIXML_STRING * tag );
 	#endif
@@ -1736,16 +1736,16 @@ public:
 	TiXmlPrinter() : depth( 0 ), simpleTextPrint( false ),
 					 buffer(), indent( "    " ), lineBreak( "\n" ) {}
-	virtual bool VisitEnter( const TiXmlDocument& doc );
-	virtual bool VisitExit( const TiXmlDocument& doc );
+	bool VisitEnter( const TiXmlDocument& doc ) override;
+	bool VisitExit( const TiXmlDocument& doc ) override;
-	virtual bool VisitEnter( const TiXmlElement& element, const TiXmlAttribute* firstAttribute );
-	virtual bool VisitExit( const TiXmlElement& element );
+	bool VisitEnter( const TiXmlElement& element, const TiXmlAttribute* firstAttribute ) override;
+	bool VisitExit( const TiXmlElement& element ) override;
-	virtual bool Visit( const TiXmlDeclaration& declaration );
-	virtual bool Visit( const TiXmlText& text );
-	virtual bool Visit( const TiXmlComment& comment );
-	virtual bool Visit( const TiXmlUnknown& unknown );
+	bool Visit( const TiXmlDeclaration& declaration ) override;
+	bool Visit( const TiXmlText& text ) override;
+	bool Visit( const TiXmlComment& comment ) override;
+	bool Visit( const TiXmlUnknown& unknown ) override;
 	/** Set the indent characters for printing. By default 4 spaces
 		but tab (\t) is also useful, or null/empty string for no indentation.
Summary of changes:
 capi/geos_ts_c.cpp                                 |    4 +-
 include/geos/algorithm/MCPointInRing.h             |    6 +-
 include/geos/algorithm/NotRepresentableException.h |    2 +-
 include/geos/algorithm/SIRtreePointInRing.h        |    4 +-
 include/geos/algorithm/SimplePointInRing.h         |    4 +-
 .../algorithm/distance/DiscreteHausdorffDistance.h |    8 +-
 .../algorithm/locate/IndexedPointInAreaLocator.h   |    8 +-
 .../algorithm/locate/SimplePointInAreaLocator.h    |    2 +-
 include/geos/geom/CoordinateArraySequence.h        |   44 ++++----
 include/geos/geom/CoordinateArraySequenceFactory.h |    8 +-
 include/geos/geom/Geometry.h                       |    2 +-
 include/geos/geom/GeometryCollection.h             |   58 +++++------
 include/geos/geom/LineString.h                     |   52 +++++-----
 include/geos/geom/LinearRing.h                     |   14 +--
 include/geos/geom/MultiLineString.h                |   16 +--
 include/geos/geom/MultiPoint.h                     |   16 +--
 include/geos/geom/MultiPolygon.h                   |   18 ++--
 include/geos/geom/Point.h                          |   54 +++++-----
 include/geos/geom/Polygon.h                        |   58 +++++------
 .../geom/prep/AbstractPreparedPolygonContains.h    |    2 +-
 include/geos/geom/prep/BasicPreparedGeometry.h     |   24 ++---
 include/geos/geom/prep/PreparedLineString.h        |    4 +-
 include/geos/geom/prep/PreparedPoint.h             |    2 +-
 include/geos/geom/prep/PreparedPolygon.h           |   10 +-
 include/geos/geom/prep/PreparedPolygonContains.h   |    2 +-
 include/geos/geom/prep/PreparedPolygonCovers.h     |    2 +-
 .../geos/geom/util/ComponentCoordinateExtracter.h  |    4 +-
 include/geos/geom/util/CoordinateOperation.h       |    6 +-
 include/geos/geom/util/GeometryExtracter.h         |    2 +-
 include/geos/geom/util/LinearComponentExtracter.h  |    4 +-
 include/geos/geom/util/PointExtracter.h            |    4 +-
 include/geos/geom/util/PolygonExtracter.h          |    4 +-
 include/geos/geomgraph/DirectedEdge.h              |    2 +-
 include/geos/geomgraph/DirectedEdgeStar.h          |    8 +-
 include/geos/geomgraph/Edge.h                      |    6 +-
 include/geos/geomgraph/GeometryGraph.h             |    2 +-
 include/geos/geomgraph/Node.h                      |    6 +-
 include/geos/geomgraph/index/MonotoneChain.h       |    2 +-
 .../geomgraph/index/SimpleEdgeSetIntersector.h     |    4 +-
 .../geomgraph/index/SimpleMCSweepLineIntersector.h |    6 +-
 .../geomgraph/index/SimpleSweepLineIntersector.h   |    6 +-
 include/geos/geomgraph/index/SweepLineSegment.h    |    2 +-
 include/geos/index/bintree/Node.h                  |    4 +-
 include/geos/index/bintree/Root.h                  |    4 +-
 .../index/intervalrtree/IntervalRTreeBranchNode.h  |    4 +-
 .../index/intervalrtree/IntervalRTreeLeafNode.h    |    4 +-
 include/geos/index/quadtree/Node.h                 |    6 +-
 include/geos/index/quadtree/Quadtree.h             |   10 +-
 include/geos/index/quadtree/Root.h                 |    4 +-
 include/geos/index/strtree/AbstractNode.h          |    4 +-
 include/geos/index/strtree/GeometryItemDistance.h  |    2 +-
 include/geos/index/strtree/ItemBoundable.h         |    4 +-
 include/geos/index/strtree/SIRtree.h               |   12 +--
 include/geos/index/strtree/STRtree.h               |   20 ++--
 include/geos/io/ParseException.h                   |    2 +-
 include/geos/noding/BasicSegmentString.h           |   12 +--
 include/geos/noding/IntersectionAdder.h            |    4 +-
 include/geos/noding/IntersectionFinderAdder.h      |    4 +-
 include/geos/noding/IteratedNoder.h                |    6 +-
 include/geos/noding/MCIndexNoder.h                 |    8 +-
 .../noding/MCIndexSegmentSetMutualIntersector.h    |    8 +-
 include/geos/noding/NodedSegmentString.h           |   12 +--
 include/geos/noding/ScaledNoder.h                  |    6 +-
 include/geos/noding/SegmentIntersectionDetector.h  |    6 +-
 include/geos/noding/SimpleNoder.h                  |    4 +-
 .../geos/noding/SingleInteriorIntersectionFinder.h |    4 +-
 include/geos/noding/SinglePassNoder.h              |    6 +-
 include/geos/noding/snapround/MCIndexSnapRounder.h |    4 +-
 include/geos/noding/snapround/SimpleSnapRounder.h  |    4 +-
 .../distance/ConnectedElementLocationFilter.h      |    4 +-
 .../distance/ConnectedElementPointFilter.h         |    2 +-
 include/geos/operation/linemerge/LineMergeGraph.h  |    2 +-
 include/geos/operation/overlay/ElevationMatrix.h   |    6 +-
 include/geos/operation/overlay/MaximalEdgeRing.h   |    6 +-
 include/geos/operation/overlay/MinimalEdgeRing.h   |    6 +-
 .../geos/operation/overlay/OverlayNodeFactory.h    |    2 +-
 include/geos/operation/overlay/OverlayOp.h         |    2 +-
 .../geos/operation/polygonize/PolygonizeGraph.h    |    2 +-
 include/geos/operation/polygonize/Polygonizer.h    |    2 +-
 include/geos/operation/relate/EdgeEndBundle.h      |    4 +-
 include/geos/operation/relate/EdgeEndBundleStar.h  |    4 +-
 include/geos/operation/relate/RelateNode.h         |    4 +-
 include/geos/operation/relate/RelateNodeFactory.h  |    2 +-
 include/geos/operation/relate/RelateOp.h           |    2 +-
 .../operation/valid/SweeplineNestedRingTester.h    |    2 +-
 include/geos/planargraph/Node.h                    |    2 +-
 .../PrecisionReducerCoordinateOperation.h          |    2 +-
 .../quadedge/LastFoundQuadEdgeLocator.h            |    2 +-
 include/geos/util/AssertionFailedException.h       |    2 +-
 include/geos/util/GEOSException.h                  |    4 +-
 include/geos/util/IllegalArgumentException.h       |    2 +-
 include/geos/util/IllegalStateException.h          |    2 +-
 include/geos/util/TopologyException.h              |    2 +-
 include/geos/util/UniqueCoordinateArrayFilter.h    |    4 +-
 include/geos/util/UnsupportedOperationException.h  |    2 +-
 src/algorithm/BoundaryNodeRule.cpp                 |    8 +-
 src/geom/GeometryFactory.cpp                       |    2 +-
 src/index/strtree/SIRtree.cpp                      |    4 +-
 src/index/strtree/STRtree.cpp                      |    4 +-
 src/noding/GeometryNoder.cpp                       |    2 +-
 src/noding/ScaledNoder.cpp                         |    6 +-
 src/noding/snapround/MCIndexPointSnapper.cpp       |    8 +-
 .../distance/FacetSequenceTreeBuilder.cpp          |    2 +-
 src/operation/distance/IndexedFacetDistance.cpp    |    4 +-
 src/operation/overlay/OverlayOp.cpp                |    2 +-
 src/operation/overlay/snap/GeometrySnapper.cpp     |    2 +-
 src/operation/predicate/RectangleIntersects.cpp    |   12 +--
 src/precision/CommonBitsRemover.cpp                |    8 +-
 src/precision/MinimumClearance.cpp                 |    4 +-
 src/precision/SimpleGeometryPrecisionReducer.cpp   |    2 +-
 src/simplify/DouglasPeuckerSimplifier.cpp          |    6 +-
 src/simplify/LineSegmentIndex.cpp                  |    4 +-
 src/simplify/TopologyPreservingSimplifier.cpp      |    4 +-
 src/triangulate/quadedge/QuadEdgeSubdivision.cpp   |    4 +-
 tests/unit/geom/CoordinateArraySequenceTest.cpp    |    2 +-
 tests/unit/geom/GeometryComponentFilterTest.cpp    |    4 +-
 tests/unit/geom/GeometryFilterTest.cpp             |    4 +-
 .../unit/simplify/DouglasPeuckerSimplifierTest.cpp |    8 +-
 tests/unit/tut/tut.hpp                             |    8 +-
 tests/unit/tut/tut_console_reporter.hpp            |    8 +-
 tests/unit/tut/tut_exception.hpp                   |   48 ++++-----
 tests/unit/tut/tut_result.hpp                      |    2 +-
 tests/xmltester/tinyxml/tinyxml.h                  |  106 ++++++++++----------
 123 files changed, 507 insertions(+), 507 deletions(-)
hooks/post-receive
geos
More information about the geos-commits mailing list
