[geos-commits] [SCM] GEOS branch master updated. 96041d28f472ad759a50913bd9fbf55be5d18d91
Sat Aug 18 10:07:22 PDT 2018
the project "GEOS".
       via  96041d28f472ad759a50913bd9fbf55be5d18d91 (commit)
       via  ae8a2d31dcfe5c7a60c9e48bdd66886f95aa5772 (commit)
      from  3db733ddd1b6c4c407561023291cd648741ea79d (commit)
revisions in full, below.
commit 96041d28f472ad759a50913bd9fbf55be5d18d91
Merge: 3db733d ae8a2d3
Author: Daniel Baston <dbaston at gmail.com>
Date:   Sat Aug 18 13:06:28 2018 -0400
    Merge branch 'trac-730'
commit ae8a2d31dcfe5c7a60c9e48bdd66886f95aa5772
Date:   Mon Aug 13 19:11:30 2018 -0400
    Avoid segfault when querying empty tree
    Closes #730
    Closes https://github.com/libgeos/geos/pull/116
diff --git a/src/index/strtree/AbstractSTRtree.cpp b/src/index/strtree/AbstractSTRtree.cpp
index 44d73f3..12fa521 100644
--- a/src/index/strtree/AbstractSTRtree.cpp
+++ b/src/index/strtree/AbstractSTRtree.cpp
@@ -125,7 +125,10 @@ AbstractSTRtree::query(const void* searchBounds, vector<void*>& matches)
 	if (!built) build();
-	if (itemBoundables->empty()) assert(root->getBounds()==nullptr);
+	if (itemBoundables->empty()) {
+		assert(root->getBounds()==nullptr);
+		return;
 	if (getIntersectsOp()->intersects(root->getBounds(), searchBounds))
@@ -139,7 +142,10 @@ AbstractSTRtree::query(const void* searchBounds, ItemVisitor& visitor)
+        return;
 	if (getIntersectsOp()->intersects(root->getBounds(),searchBounds))
diff --git a/tests/unit/capi/GEOSSTRtreeTest.cpp b/tests/unit/capi/GEOSSTRtreeTest.cpp
index a3f6293..72989c5 100644
--- a/tests/unit/capi/GEOSSTRtreeTest.cpp
+++ b/tests/unit/capi/GEOSSTRtreeTest.cpp
@@ -230,6 +230,21 @@ namespace tut
 		GEOSSTRtree_destroy(tree);
+	// querying empty tree should not crash (see #730)
+    template<>
+    template<>
+    void object::test<7>() {
+	    GEOSSTRtree* tree = GEOSSTRtree_create(16);
+	    GEOSGeometry* q = GEOSGeomFromWKT("POLYGON ((0 0, 1 0, 1 1, 0 1, 0 0))");
+	    GEOSSTRtree_query(tree, q, [](void* item, void* userdata) {
+	   		assert(item); // make unused parameter warning go away
+			assert(userdata);
+        }, nullptr);
+		GEOSGeom_destroy(q);
+		GEOSSTRtree_destroy(tree);
 } // namespace tut
Summary of changes:
 src/index/strtree/AbstractSTRtree.cpp | 10 ++++++++--
 tests/unit/capi/GEOSSTRtreeTest.cpp   | 15 +++++++++++++++
 2 files changed, 23 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
