[geos-commits] [SCM] GEOS branch master updated. 691ea75810a806bd860eb921ff560827275a06a3
Mon Dec 17 15:58:41 PST 2018
the project "GEOS".
       via  691ea75810a806bd860eb921ff560827275a06a3 (commit)
      from  002bfbeedfb21ad217e90f237f3149dcfd9b7786 (commit)
revisions in full, below.
commit 691ea75810a806bd860eb921ff560827275a06a3
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Dec 17 15:58:27 2018 -0800
    Move CGAlgorithms functions into Orientation class
    JTS 4c4ccd7fe5c758abb48647da60dacf8e4cd7f9df
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index e824b15..383e468 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -43,11 +43,12 @@
 #include <geos/io/WKBReader.h>
 #include <geos/io/WKTWriter.h>
 #include <geos/io/WKBWriter.h>
-#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
-#include <geos/algorithm/distance/DiscreteFrechetDistance.h>
-#include <geos/algorithm/CGAlgorithms.h>
 #include <geos/algorithm/BoundaryNodeRule.h>
+#include <geos/algorithm/CGAlgorithms.h>
 #include <geos/algorithm/MinimumDiameter.h>
+#include <geos/algorithm/Orientation.h>
+#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
+#include <geos/algorithm/distance/DiscreteFrechetDistance.h>
 #include <geos/simplify/DouglasPeuckerSimplifier.h>
 #include <geos/simplify/TopologyPreservingSimplifier.h>
 #include <geos/noding/GeometryNoder.h>
@@ -4265,7 +4266,7 @@ GEOSCoordSeq_isCCW_r(GEOSContextHandle_t extHandle, const CoordinateSequence *cs
     try
-        *val = geos::algorithm::CGAlgorithms::isCCW(cs);
+        *val = geos::algorithm::Orientation::isCCW(cs);
         return 1;
     catch (const std::exception &e)
diff --git a/include/geos/algorithm/Makefile.am b/include/geos/algorithm/Makefile.am
index 2791033..113c1fb 100644
--- a/include/geos/algorithm/Makefile.am
+++ b/include/geos/algorithm/Makefile.am
@@ -27,6 +27,7 @@ geos_HEADERS = \
 	Length.h \
 	MinimumDiameter.h \
 	NotRepresentableException.h \
+	Orientation.h \
 	PointLocator.h \
 	RayCrossingCounter.h \
 	RayCrossingCounterDD.h \
diff --git a/include/geos/algorithm/Orientation.h b/include/geos/algorithm/Orientation.h
new file mode 100644
index 0000000..e0ac45b
--- /dev/null
+++ b/include/geos/algorithm/Orientation.h
@@ -0,0 +1,91 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2018 Paul Ramsey <pramsey at cleverlephant.ca>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: algorithm/Orientation.java @ 2017-09-04
+#ifndef GEOS_ALGORITHM_ORIENTATION_H
+#define GEOS_ALGORITHM_ORIENTATION_H
+#include <geos/export.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateSequence.h>
+namespace geos {
+namespace algorithm { // geos::algorithm
+* Functions to compute the orientation of points, lines and rings.
+* @author Martin Davis
+class GEOS_DLL Orientation {
+public:
+    /* A value that indicates an orientation or turn */
+    enum {
+        CLOCKWISE=-1,
+        COLLINEAR=0,
+        COUNTERCLOCKWISE=1,
+        RIGHT=-1,
+        LEFT=1,
+        STRAIGHT=0
+    * Returns the index of the direction of the point <code>q</code>
+    * relative to a vector specified by <code>p1-p2</code>.
+    * @param p1 the origin point of the vector
+    * @param p2 the final point of the vector
+    * @param q the point to compute the direction to
+    * @return 1 if q is counter-clockwise (left) from p1-p2
+    * @return -1 if q is clockwise (right) from p1-p2
+    * @return 0 if q is collinear with p1-p2
+    static int index(const geom::Coordinate &p1,
+                     const geom::Coordinate &p2, const geom::Coordinate &q);
+    * Computes whether a ring defined by an array of {@link Coordinate}s is
+    * oriented counter-clockwise.
+    * <ul>
+    * <li>The list of points is assumed to have the first and last points equal.
+    * <li>This will handle coordinate lists which contain repeated points.
+    * </ul>
+    * This algorithm is <b>only</b> guaranteed to work with valid rings. If the
+    * ring is invalid (e.g. self-crosses or touches), the computed result may not
+    * be correct.
+    * @param ring
+    *          an array of Coordinates forming a ring
+    * @return true if the ring is oriented counter-clockwise.
+    * @throws IllegalArgumentException
+    *           if there are too few points to determine orientation (< 4)
+    static bool isCCW(const geom::CoordinateSequence* ring);
+} // namespace geos::algorithm
+#endif // GEOS_ALGORITHM_ORIENTATION_H
diff --git a/include/geos/geom/LineSegment.h b/include/geos/geom/LineSegment.h
index 5f5bc58..3c3bf02 100644
--- a/include/geos/geom/LineSegment.h
+++ b/include/geos/geom/LineSegment.h
@@ -130,7 +130,7 @@ public:
 	 * relative to this segment.
 	 * The orientation index is as defined in
-	 * CGAlgorithms::computeOrientation.
+	 * Orientation::index.
 	 * @param seg the LineSegment to compare
@@ -138,7 +138,7 @@ public:
 	 * @return -1 if <code>p</code> is to the right of this segment
 	 * @return 0 if <code>p</code> is collinear with this segment
-	 * @see CGAlgorithms::computeOrientation(Coordinate, Coordinate,
+	 * @see Orientation::index(Coordinate, Coordinate,
 	 *                                       Coordinate)
 	int orientationIndex(const Coordinate& p) const;
diff --git a/include/geos/geom/util/GeometryTransformer.h b/include/geos/geom/util/GeometryTransformer.h
index cff3ea0..c26ac56 100644
--- a/include/geos/geom/util/GeometryTransformer.h
+++ b/include/geos/geom/util/GeometryTransformer.h
@@ -173,7 +173,7 @@ private:
 	 * <code>true</code> if the output from a collection argument should still be a collection
-	bool preserveCollections;
+	// bool preserveCollections;
 	 * <code>true</code> if the type of the input should be preserved
diff --git a/include/geos/planargraph/DirectedEdge.h b/include/geos/planargraph/DirectedEdge.h
index d45dda8..25944ec 100644
--- a/include/geos/planargraph/DirectedEdge.h
+++ b/include/geos/planargraph/DirectedEdge.h
@@ -187,7 +187,7 @@ public:
 	 *   If the quadrants are different, it it
 	 *   trivial to determine which std::vector is "greater".
 	 * - if the vectors lie in the same quadrant, the robust
-	 *   RobustCGAlgorithms::computeOrientation(Coordinate, Coordinate, Coordinate)
+	 *   Orientation::index(Coordinate, Coordinate, Coordinate)
 	 *   function can be used to decide the relative orientation of
 	 *   the vectors.
@@ -208,7 +208,7 @@ public:
 	 *   If the quadrants are different, it it trivial to determine
 	 *   which std::vector is "greater".
 	 *   the vectors.
diff --git a/src/algorithm/Centroid.cpp b/src/algorithm/Centroid.cpp
index c5f31ab..f217420 100644
--- a/src/algorithm/Centroid.cpp
+++ b/src/algorithm/Centroid.cpp
@@ -17,7 +17,7 @@
 #include <geos/algorithm/Centroid.h>
 #include <geos/geom/Geometry.h>
 #include <geos/geom/Point.h>
@@ -110,7 +110,7 @@ Centroid::addShell(const CoordinateSequence& pts)
   size_t len = pts.size();
   if (len > 0)
     setAreaBasePoint(pts[0]);
-  bool isPositiveArea = ! CGAlgorithms::isCCW(&pts);
+  bool isPositiveArea = ! Orientation::isCCW(&pts);
   for (size_t i = 0; i < len - 1; ++i) {
     addTriangle(*areaBasePt, pts[i], pts[i+1], isPositiveArea);
@@ -121,7 +121,7 @@ Centroid::addShell(const CoordinateSequence& pts)
 void
 Centroid::addHole(const CoordinateSequence& pts)
-  bool isPositiveArea = CGAlgorithms::isCCW(&pts);
+  bool isPositiveArea = Orientation::isCCW(&pts);
   for (size_t i = 0, e = pts.size() - 1; i < e; ++i) {
diff --git a/src/algorithm/ConvexHull.cpp b/src/algorithm/ConvexHull.cpp
index 636cce8..8da34c4 100644
--- a/src/algorithm/ConvexHull.cpp
+++ b/src/algorithm/ConvexHull.cpp
@@ -20,6 +20,7 @@
 #include <geos/algorithm/ConvexHull.h>
 #include <geos/geom/GeometryFactory.h>
@@ -62,11 +63,11 @@ private:
 		double dxq=q->x-o->x;
 		double dyq=q->y-o->y;
-		int orient = CGAlgorithms::computeOrientation(*o, *p, *q);
+		int orient = Orientation::index(*o, *p, *q);
-		if (orient == CGAlgorithms::COUNTERCLOCKWISE) return 1;
-		if (orient == CGAlgorithms::CLOCKWISE) return -1;
+		if (orient == Orientation::COUNTERCLOCKWISE) return 1;
+		if (orient == Orientation::CLOCKWISE) return -1;
 		// points are collinear - check distance
 		double op = dxp * dxp + dyp * dyp;
@@ -302,7 +303,7 @@ ConvexHull::grahamScan(const Coordinate::ConstVect &c,
 		const Coordinate *p = ps.back(); ps.pop_back();
 		while (!ps.empty() &&
-			CGAlgorithms::computeOrientation(
+			Orientation::index(
 		    *(ps.back()), *p, *(c[i])) > 0)
@@ -418,7 +419,7 @@ ConvexHull::grahamScan(const Coordinate::ConstVect &c,
 bool
 ConvexHull::isBetween(const Coordinate &c1, const Coordinate &c2, const Coordinate &c3)
-	if (CGAlgorithms::computeOrientation(c1, c2, c3)!=0) {
+	if (Orientation::index(c1, c2, c3)!=0) {
 		return false;
 	if (c1.x!=c3.x) {
diff --git a/src/algorithm/Makefile.am b/src/algorithm/Makefile.am
index d316f85..7c9f7f9 100644
--- a/src/algorithm/Makefile.am
+++ b/src/algorithm/Makefile.am
@@ -25,6 +25,7 @@ libalgorithm_la_SOURCES = \
 	Length.cpp \
 	MinimumDiameter.cpp \
 	NotRepresentableException.cpp \
+	Orientation.cpp \
 	PointLocator.cpp \
 	RayCrossingCounter.cpp \
 	RayCrossingCounterDD.cpp \
diff --git a/src/algorithm/Orientation.cpp b/src/algorithm/Orientation.cpp
index 0000000..dcedac0
--- /dev/null
+++ b/src/algorithm/Orientation.cpp
@@ -0,0 +1,131 @@
+#include <cmath>
+#include <vector>
+#include <geos/algorithm/CGAlgorithmsDD.h>
+#include <geos/geom/Location.h>
+#include <geos/util/IllegalArgumentException.h>
+namespace geos {
+namespace algorithm { // geos.algorithm
+/* public static */
+int
+Orientation::index(const geom::Coordinate &p1,
+    return CGAlgorithmsDD::orientationIndex(p1, p2, q);
+bool
+Orientation::isCCW(const geom::CoordinateSequence *ring)
+    // sanity check
+    if (ring->getSize() < 4)
+        throw util::IllegalArgumentException("Ring has fewer than 3 points, so orientation cannot be determined");
+    // # of points without closing endpoint
+    const std::size_t nPts=ring->getSize()-1;
+    // find highest point
+    const geom::Coordinate *hiPt=&ring->getAt(0);
+    size_t hiIndex = 0;
+    for (std::size_t i = 1; i <= nPts; ++i)
+        const geom::Coordinate *p=&ring->getAt(i);
+        if (p->y > hiPt->y) {
+            hiPt = p;
+            hiIndex = i;
+    // find distinct point before highest point
+    auto iPrev = hiIndex;
+    do {
+        if (iPrev == 0)
+            iPrev = nPts;
+        iPrev = iPrev - 1;
+    } while (ring->getAt(iPrev) == *hiPt && iPrev != hiIndex);
+    // find distinct point after highest point
+    auto iNext = hiIndex;
+    do {
+        iNext = (iNext + 1) % nPts;
+    } while (ring->getAt(iNext)==*hiPt && iNext != hiIndex);
+    const geom::Coordinate *prev=&ring->getAt(iPrev);
+    const geom::Coordinate *next=&ring->getAt(iNext);
+     * This check catches cases where the ring contains an A-B-A
+     * configuration of points.
+     * This can happen if the ring does not contain 3 distinct points
+     * (including the case where the input array has fewer than 4 elements),
+     * or it contains coincident line segments.
+    if ( prev->equals2D(*hiPt) || next->equals2D(*hiPt) ||
+        prev->equals2D(*next) )
+        return false;
+        // MD - don't bother throwing exception,
+        // since this isn't a complete check for ring validity
+        //throw  IllegalArgumentException("degenerate ring (does not contain 3 distinct points)");
+    // New DD high precision implementation
+    int disc = Orientation::index(*prev, *hiPt, *next);
+    // Old double implementation
+    // int disc = CGAlgorithms::computeOrientation(*prev, *hiPt, *next);
+     *  If disc is exactly 0, lines are collinear.
+     * There are two possible cases:
+     *  (1) the lines lie along the x axis in opposite directions
+     *  (2) the lines lie on top of one another
+     *  (1) is handled by checking if next is left of prev ==> CCW
+     *  (2) should never happen, so we're going to ignore it!
+     *  (Might want to assert this)
+    bool isCCW=false;
+    if (disc == 0) {
+        // poly is CCW if prev x is right of next x
+        isCCW = (prev->x > next->x);
+    } else {
+        // if area is positive, points are ordered CCW
+        isCCW = (disc > 0);
+    return isCCW;
+} // namespace geos.algorithm
+} //namespace geos
diff --git a/src/geom/Polygon.cpp b/src/geom/Polygon.cpp
index 7b8fea5..7d5dfbf 100644
--- a/src/geom/Polygon.cpp
+++ b/src/geom/Polygon.cpp
@@ -19,7 +19,7 @@
 #include <geos/algorithm/Area.h>
 #include <geos/geom/Polygon.h>
@@ -346,7 +346,7 @@ Polygon::normalize(LinearRing *ring, bool clockwise)
 	const Coordinate* minCoordinate=CoordinateSequence::minCoordinate(uniqueCoordinates);
 	CoordinateSequence::scroll(uniqueCoordinates, minCoordinate);
 	uniqueCoordinates->add(uniqueCoordinates->getAt(0));
-	if (algorithm::CGAlgorithms::isCCW(uniqueCoordinates)==clockwise) {
+	if (algorithm::Orientation::isCCW(uniqueCoordinates)==clockwise) {
 		CoordinateSequence::reverse(uniqueCoordinates);
 	ring->setPoints(uniqueCoordinates);
diff --git a/src/geomgraph/EdgeEnd.cpp b/src/geomgraph/EdgeEnd.cpp
index 9650b8a..d5ebcdd 100644
--- a/src/geomgraph/EdgeEnd.cpp
+++ b/src/geomgraph/EdgeEnd.cpp
@@ -20,7 +20,7 @@
 #include <geos/geomgraph/EdgeEnd.h>
 #include <geos/geomgraph/Node.h> // for assertions
 #include <geos/geomgraph/Label.h>
 #include <geos/geomgraph/Quadrant.h>
@@ -178,7 +178,7 @@ EdgeEnd::compareDirection(const EdgeEnd* e) const
 	// vectors are in the same quadrant - check relative
 	// orientation of direction vectors
 	// this is > e if it is CCW of e
-	return CGAlgorithms::computeOrientation(e->p0, e->p1, p1);
+	return Orientation::index(e->p0, e->p1, p1);
 /*public*/
diff --git a/src/geomgraph/EdgeRing.cpp b/src/geomgraph/EdgeRing.cpp
index 17127b1..1c602f8 100644
--- a/src/geomgraph/EdgeRing.cpp
+++ b/src/geomgraph/EdgeRing.cpp
@@ -21,6 +21,7 @@
 #include <geos/util/Assert.h>
 #include <geos/util/TopologyException.h>
 #include <geos/geomgraph/EdgeRing.h>
 #include <geos/geomgraph/DirectedEdge.h>
 #include <geos/geomgraph/DirectedEdgeStar.h>
@@ -204,7 +205,7 @@ EdgeRing::computeRing()
 	if (ring!=nullptr) return;   // don't compute more than once
 	ring=geometryFactory->createLinearRing(pts);
-	isHoleVar=CGAlgorithms::isCCW(pts);
+	isHoleVar=Orientation::isCCW(pts);
 	testInvariant();
diff --git a/src/geomgraph/GeometryGraph.cpp b/src/geomgraph/GeometryGraph.cpp
index b838919..e0ab745 100644
--- a/src/geomgraph/GeometryGraph.cpp
+++ b/src/geomgraph/GeometryGraph.cpp
@@ -18,7 +18,7 @@
 #include <geos/util/UnsupportedOperationException.h>
@@ -258,7 +258,7 @@ GeometryGraph::addPolygonRing(const LinearRing *lr, int cwLeft, int cwRight)
 	try
-		if (CGAlgorithms::isCCW(coord)) {
+		if (Orientation::isCCW(coord)) {
 			left=cwRight;
 			right=cwLeft;
diff --git a/src/geomgraph/PlanarGraph.cpp b/src/geomgraph/PlanarGraph.cpp
index 859f1bd..18d9d04 100644
--- a/src/geomgraph/PlanarGraph.cpp
+++ b/src/geomgraph/PlanarGraph.cpp
@@ -31,7 +31,7 @@
 #include <geos/geomgraph/NodeMap.h>
 #include <vector>
 #include <sstream>
@@ -353,7 +353,7 @@ PlanarGraph::matchInSameDirection(const Coordinate& p0, const Coordinate& p1,
 	if (!(p0==ep0))
 		return false;
-	if (CGAlgorithms::computeOrientation(p0,p1,ep1)==CGAlgorithms::COLLINEAR
+	if (Orientation::index(p0,p1,ep1)==Orientation::COLLINEAR
 		&& Quadrant::quadrant(p0,p1)==Quadrant::quadrant(ep0,ep1))
 			return true;
 	return false;
diff --git a/src/operation/buffer/BufferInputLineSimplifier.cpp b/src/operation/buffer/BufferInputLineSimplifier.cpp
index 4dda5b9..4772794 100644
--- a/src/operation/buffer/BufferInputLineSimplifier.cpp
+++ b/src/operation/buffer/BufferInputLineSimplifier.cpp
@@ -20,6 +20,7 @@
 #include <geos/geom/CoordinateSequence.h> // for inlines
 #include <geos/geom/CoordinateArraySequence.h> // for constructing the return
 #include <geos/algorithm/CGAlgorithms.h> // for use
+#include <geos/algorithm/Orientation.h> // for use
 #include <memory>
 #include <cmath>
@@ -27,7 +28,7 @@
 //#include <cassert>
-using namespace geos::algorithm; // CGAlgorithms
+using namespace geos::algorithm; // Orientation
 using namespace geos::geom;
 //using namespace geos::geomgraph; // DirectedEdge, Position
@@ -39,7 +40,7 @@ BufferInputLineSimplifier::BufferInputLineSimplifier(
 		const geom::CoordinateSequence& input)
 	inputLine(input),
-	angleOrientation(CGAlgorithms::COUNTERCLOCKWISE)
+	angleOrientation(Orientation::COUNTERCLOCKWISE)
 /*public static*/
@@ -57,7 +58,7 @@ BufferInputLineSimplifier::simplify(double nDistanceTol)
 	distanceTol = fabs(nDistanceTol);
 	if (nDistanceTol < 0)
-		angleOrientation = CGAlgorithms::CLOCKWISE;
+		angleOrientation = Orientation::CLOCKWISE;
 	// rely on fact that boolean array is filled with false value
 	static const int startValue = INIT;
@@ -160,7 +161,7 @@ BufferInputLineSimplifier::isShallowConcavity(const geom::Coordinate& p0,
                                               const geom::Coordinate& p2,
                                               double p_distanceTol) const
-	int orientation = CGAlgorithms::computeOrientation(p0, p1, p2);
+	int orientation = Orientation::index(p0, p1, p2);
 	bool isAngleToSimplify = (orientation == angleOrientation);
 	if (! isAngleToSimplify)
 		return false;
@@ -204,7 +205,7 @@ BufferInputLineSimplifier::isConcave(const geom::Coordinate& p0,
                                      const geom::Coordinate& p1,
                                      const geom::Coordinate& p2) const
 	bool p_isConcave = (orientation == angleOrientation);
 	return p_isConcave;
diff --git a/src/operation/buffer/OffsetCurveSetBuilder.cpp b/src/operation/buffer/OffsetCurveSetBuilder.cpp
index f384d42..1e365f5 100644
--- a/src/operation/buffer/OffsetCurveSetBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveSetBuilder.cpp
@@ -20,6 +20,7 @@
 #include <geos/platform.h>
 #include <geos/operation/buffer/OffsetCurveSetBuilder.h>
@@ -53,7 +54,7 @@
 using namespace geos::noding; // SegmentString
 using namespace geos::geomgraph; // Label, Position
 namespace geos {
 namespace operation { // geos.operation
@@ -301,10 +302,10 @@ OffsetCurveSetBuilder::addPolygonRing(const CoordinateSequence *coord,
 	int leftLoc=cwLeftLoc;
 	int rightLoc=cwRightLoc;
 #if GEOS_DEBUG
-	std::cerr<<"OffsetCurveSetBuilder::addPolygonRing: CCW: "<<CGAlgorithms::isCCW(coord)<<std::endl;
+	std::cerr<<"OffsetCurveSetBuilder::addPolygonRing: CCW: "<<Orientation::isCCW(coord)<<std::endl;
 #endif
 	if (coord->size() >= LinearRing::MINIMUM_VALID_SIZE
-			&& CGAlgorithms::isCCW(coord))
+			&& Orientation::isCCW(coord))
 		leftLoc=cwRightLoc;
 		rightLoc=cwLeftLoc;
diff --git a/src/operation/buffer/OffsetSegmentGenerator.cpp b/src/operation/buffer/OffsetSegmentGenerator.cpp
index 12afdac..cad67d7 100644
--- a/src/operation/buffer/OffsetSegmentGenerator.cpp
+++ b/src/operation/buffer/OffsetSegmentGenerator.cpp
@@ -20,7 +20,7 @@
 #include <cmath>
 #include <vector>
 #include <geos/algorithm/Angle.h>
 #include <geos/operation/buffer/OffsetSegmentGenerator.h>
 #include <geos/operation/buffer/OffsetSegmentString.h>
@@ -147,12 +147,12 @@ OffsetSegmentGenerator::addNextSegment(const Coordinate &p, bool addStartPoint)
   seg1.setCoordinates(s1, s2);
   computeOffsetSegment(seg1, side, distance, offset1);
-  int orientation=CGAlgorithms::computeOrientation(s0, s1, s2);
+  int orientation=Orientation::index(s0, s1, s2);
   bool outsideTurn =
-    (orientation==CGAlgorithms::CLOCKWISE
+    (orientation==Orientation::CLOCKWISE
      && side==Position::LEFT)
-    (orientation==CGAlgorithms::COUNTERCLOCKWISE
+    (orientation==Orientation::COUNTERCLOCKWISE
      && side==Position::RIGHT);
   if (orientation==0)
@@ -210,7 +210,7 @@ OffsetSegmentGenerator::addLineEndCap(const Coordinate &p0, const Coordinate &p1
       // add offset seg points with a fillet between them
       segList.addPt(offsetL.p1);
       addFillet(p1, angle+PI/2.0, angle-PI/2.0,
-                CGAlgorithms::CLOCKWISE, distance);
+                Orientation::CLOCKWISE, distance);
       segList.addPt(offsetR.p1);
       break;
     case BufferParameters::CAP_FLAT:
@@ -249,7 +249,7 @@ OffsetSegmentGenerator::addFillet(const Coordinate &p, const Coordinate &p0,
   double dy1 = p1.y - p.y;
   double endAngle = atan2(dy1, dx1);
-  if (direction == CGAlgorithms::CLOCKWISE) {
+  if (direction == Orientation::CLOCKWISE) {
     if (startAngle <= endAngle) startAngle += 2.0 * PI;
   else {    // direction==COUNTERCLOCKWISE
@@ -266,7 +266,7 @@ void
 OffsetSegmentGenerator::addFillet(const Coordinate &p, double startAngle,
   double endAngle, int direction, double radius)
-  int directionFactor = direction == CGAlgorithms::CLOCKWISE ? -1 : 1;
+  int directionFactor = direction == Orientation::CLOCKWISE ? -1 : 1;
   double totalAngle = fabs(startAngle - endAngle);
   int nSegs = (int) (totalAngle / filletAngleQuantum + 0.5);
@@ -352,7 +352,7 @@ OffsetSegmentGenerator::addCollinear(bool addStartPoint)
     else
       addFillet(s1, offset0.p1, offset1.p0,
diff --git a/src/operation/buffer/RightmostEdgeFinder.cpp b/src/operation/buffer/RightmostEdgeFinder.cpp
index 89a83a7..b58fdfb 100644
--- a/src/operation/buffer/RightmostEdgeFinder.cpp
+++ b/src/operation/buffer/RightmostEdgeFinder.cpp
@@ -17,7 +17,7 @@
 #include <geos/operation/buffer/RightmostEdgeFinder.h>
@@ -29,7 +29,7 @@
 #include <vector>
 #include <cassert>
@@ -166,7 +166,7 @@ RightmostEdgeFinder::findRightmostEdgeAtVertex()
 	const Coordinate& pPrev=pts->getAt(minIndex-1);
 	const Coordinate& pNext=pts->getAt(minIndex+1);
 			minCoord,
 			pNext,
 			pPrev);
@@ -174,12 +174,12 @@ RightmostEdgeFinder::findRightmostEdgeAtVertex()
 	// both segments are below min point
 	if ( pPrev.y < minCoord.y && pNext.y < minCoord.y
-		&& orientation == CGAlgorithms::COUNTERCLOCKWISE)
+		&& orientation == Orientation::COUNTERCLOCKWISE)
 			usePrev=true;
 	else if ( pPrev.y > minCoord.y && pNext.y > minCoord.y
-		&& orientation == CGAlgorithms::CLOCKWISE)
+		&& orientation == Orientation::CLOCKWISE)
 			usePrev=true;
diff --git a/src/operation/buffer/SubgraphDepthLocater.cpp b/src/operation/buffer/SubgraphDepthLocater.cpp
index 51c23e7..50bdd72 100644
--- a/src/operation/buffer/SubgraphDepthLocater.cpp
+++ b/src/operation/buffer/SubgraphDepthLocater.cpp
@@ -24,7 +24,7 @@
 #include <geos/operation/buffer/BufferSubgraph.h>
 #include <geos/operation/buffer/SubgraphDepthLocater.h>
 #include <geos/geom/Envelope.h>
@@ -315,11 +315,11 @@ SubgraphDepthLocater::findStabbedSegments(
 		// skip if stabbing ray is right of the segment
 #ifndef SKIP_LS
-		if (CGAlgorithms::computeOrientation(seg.p0, seg.p1,
+		if (Orientation::index(seg.p0, seg.p1,
 #else
-		if (CGAlgorithms::computeOrientation(*low, *high,
+		if (Orientation::index(*low, *high,
 #endif
-				stabbingRayLeftPt)==CGAlgorithms::RIGHT)
+				stabbingRayLeftPt)==Orientation::RIGHT)
 #if GEOS_DEBUG
 			cerr<<" stabbing ray right of segment, skipping"<<endl;
diff --git a/src/operation/intersection/RectangleIntersection.cpp b/src/operation/intersection/RectangleIntersection.cpp
index df4e8f4..3178c46 100644
--- a/src/operation/intersection/RectangleIntersection.cpp
+++ b/src/operation/intersection/RectangleIntersection.cpp
@@ -13,6 +13,7 @@
 #include <geos/operation/intersection/RectangleIntersection.h>
 #include <geos/operation/intersection/Rectangle.h>
 #include <geos/operation/intersection/RectangleIntersectionBuilder.h>
@@ -470,6 +471,7 @@ RectangleIntersection::clip_polygon_to_polygons(const geom::Polygon * g,
   // completely outside.
   using geos::algorithm::CGAlgorithms;
+  using geos::algorithm::Orientation;
   if( parts.empty() )
     Coordinate rectCenter(rect.xmin(), rect.ymin());
@@ -485,7 +487,7 @@ RectangleIntersection::clip_polygon_to_polygons(const geom::Polygon * g,
   else
     // TODO: make CCW checking part of clip_linestring_parts ?
-    if ( CGAlgorithms::isCCW(shell->getCoordinatesRO()) ) {
+    if ( Orientation::isCCW(shell->getCoordinatesRO()) ) {
       parts.reverseLines();
@@ -515,7 +517,7 @@ RectangleIntersection::clip_polygon_to_polygons(const geom::Polygon * g,
 		  if(!holeparts.empty())
-        if ( ! CGAlgorithms::isCCW(hole->getCoordinatesRO()) ) {
+        if ( ! Orientation::isCCW(hole->getCoordinatesRO()) ) {
           holeparts.reverseLines();
 			  holeparts.reconnect();
diff --git a/src/operation/polygonize/EdgeRing.cpp b/src/operation/polygonize/EdgeRing.cpp
index 93ebd38..52503f1 100644
--- a/src/operation/polygonize/EdgeRing.cpp
+++ b/src/operation/polygonize/EdgeRing.cpp
@@ -27,6 +27,7 @@
 #include <geos/geom/CoordinateSequenceFactory.h>
 #include <geos/util.h> // TODO: drop this, includes too much
@@ -161,7 +162,7 @@ EdgeRing::add(const DirectedEdge *de){
 bool
 EdgeRing::isHole(){
     getRingInternal();
-    return CGAlgorithms::isCCW(ring->getCoordinatesRO());
+    return Orientation::isCCW(ring->getCoordinatesRO());
 /*public*/
diff --git a/src/planargraph/DirectedEdge.cpp b/src/planargraph/DirectedEdge.cpp
index 37942f8..5987359 100644
--- a/src/planargraph/DirectedEdge.cpp
+++ b/src/planargraph/DirectedEdge.cpp
@@ -15,7 +15,7 @@
 #include <geos/planargraph/DirectedEdge.h>
 #include <geos/planargraph/Node.h>
 #include <cmath>
 #include <sstream>
@@ -159,7 +159,7 @@ DirectedEdge::compareDirection(const DirectedEdge *e) const
 	if (quadrant < e->quadrant) return -1;
 	// vectors are in the same quadrant - check relative orientation of direction vectors
-	return algorithm::CGAlgorithms::computeOrientation(e->p0,e->p1,p1);
+	return algorithm::Orientation::index(e->p0,e->p1,p1);
 /*public*/
diff --git a/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp b/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp
index 2161f8f..d403913 100644
--- a/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp
@@ -4,8 +4,8 @@
 #include <tut/tut.hpp>
 // geos
@@ -35,7 +35,7 @@ namespace tut
     typedef test_group<test_computeorientation_data> group;
     typedef group::object object;
-    group test_computeorientation_group("geos::algorithm::CGAlgorithms::computeOrientation");
+    group test_computeorientation_group("geos::algorithm::Orientation::index");
     // Test Cases
@@ -51,9 +51,9 @@ namespace tut
         CoordinateSequence::Ptr pts(geom->getCoordinates());
-        int const a = CGAlgorithms::computeOrientation(pts->getAt(0), pts->getAt(1), pts->getAt(2));
-        int const b = CGAlgorithms::computeOrientation(pts->getAt(0), pts->getAt(1), pts->getAt(2));
-        int const c = CGAlgorithms::computeOrientation(pts->getAt(0), pts->getAt(1), pts->getAt(2));
+        int const a = Orientation::index(pts->getAt(0), pts->getAt(1), pts->getAt(2));
+        int const b = Orientation::index(pts->getAt(0), pts->getAt(1), pts->getAt(2));
+        int const c = Orientation::index(pts->getAt(0), pts->getAt(1), pts->getAt(2));
         ensure_equals( a, b );
         ensure_equals( a, c );
@@ -73,9 +73,9 @@ namespace tut
         pts.add(c2);
         pts.add(c3);
-        int const a = CGAlgorithms::computeOrientation(pts[0], pts[1], pts[2]);
-        int const b = CGAlgorithms::computeOrientation(pts[0], pts[1], pts[2]);
-        int const c = CGAlgorithms::computeOrientation(pts[0], pts[1], pts[2]);
+        int const a = Orientation::index(pts[0], pts[1], pts[2]);
+        int const b = Orientation::index(pts[0], pts[1], pts[2]);
+        int const c = Orientation::index(pts[0], pts[1], pts[2]);
@@ -93,8 +93,8 @@ namespace tut
         Coordinate p(186.80814046338352, 46.28973405831556);
         // CGAlgorithms::orientationIndex gives both the same!!!
         // First case of doubledouble robustness improvement
-        int orient = CGAlgorithmsDD::orientationIndex(p0, p1, p);
-        int orientInv = CGAlgorithmsDD::orientationIndex(p1, p0, p);
+        int orient = Orientation::index(p0, p1, p);
+        int orientInv = Orientation::index(p1, p0, p);
         ensure( orient != orientInv );
diff --git a/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp b/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
index 8b512d4..df842fc 100644
--- a/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
@@ -1,11 +1,11 @@
-// Test Suite for CGAlgorithms::isCCW() function
+// Test Suite for Orientation::isCCW() function
 // Ported from JTS junit/algorithm/IsCCWTest.java
 // tut
 // geos
@@ -50,7 +50,7 @@ namespace tut
     typedef test_group<test_isccw_data> group;
-    group test_isccw_group("geos::algorithm::CGAlgorithms::isCCW");
+    group test_isccw_group("geos::algorithm::Orientation::isCCW");
     // Test Cases
@@ -65,7 +65,7 @@ namespace tut
 		GeometryPtr geom(reader_.read(wkt));
         cs_ = geom->getCoordinates();
-        bool isCCW = CGAlgorithms::isCCW(cs_);
+        bool isCCW = Orientation::isCCW(cs_);
         ensure_equals( false, isCCW );
@@ -79,7 +79,7 @@ namespace tut
         ensure_equals( true, isCCW );
@@ -93,7 +93,7 @@ namespace tut
@@ -108,8 +108,8 @@ namespace tut
         std::istringstream wkt("0102000000040000000000000000000000841D588465963540F56BFB214F0341408F26B714B2971B40F66BFB214F0341408C26B714B2971B400000000000000000841D588465963540");
         GeometryPtr geom(breader_.readHEX(wkt));
-        ensure_equals( isCCW, false );
+        ensure_equals( isCCW, true );
     // 5 - Test orientation the narrow (almost collapsed) ring
@@ -122,7 +122,7 @@ namespace tut
         std::istringstream wkt("0102000000040000000000000000000000841D588465963540F56BFB214F0341408F26B714B2971B40F66BFB214F0341408E26B714B2971B400000000000000000841D588465963540");
diff --git a/tests/unit/algorithm/RobustLineIntersectorTest.cpp b/tests/unit/algorithm/RobustLineIntersectorTest.cpp
index 40fe1a7..f57ab91 100644
--- a/tests/unit/algorithm/RobustLineIntersectorTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectorTest.cpp
@@ -7,6 +7,7 @@
 #include <geos/io/WKTReader.h>
 #include <geos/algorithm/LineIntersector.h>
 #include <geos/geom/PrecisionModel.h>
 #include <geos/geom/Geometry.h> // required for use in unique_ptr
@@ -24,6 +25,7 @@
 using namespace geos::geom; //
 using geos::algorithm::LineIntersector;
+using geos::algorithm::Orientation;
 namespace tut
@@ -203,7 +205,7 @@ namespace tut
 	template<>
 	void object::test<11>()
-	    ensure_equals(CGAlgorithms::computeOrientation(
+	    ensure_equals(Orientation::index(
 		Coordinate(-123456789, -40),
 		Coordinate(0, 0),
 		Coordinate(381039468754763.0, 123456789)), 1);
@@ -214,7 +216,7 @@ namespace tut
 	template<>
 	void object::test<12>()
 		Coordinate(10, 10),
 		Coordinate(20, 20),
 		Coordinate(0, 0)), 0);
@@ -243,7 +245,7 @@ namespace tut
     ensure(!l->intersects(p.get()));
     ensure(!CGAlgorithms::isOnLine(q, cs));
-    ensure_equals(CGAlgorithms::computeOrientation(p1, p2, q), -1);
+    ensure_equals(Orientation::index(p1, p2, q), -1);
diff --git a/tests/unit/operation/buffer/BufferBuilderTest.cpp b/tests/unit/operation/buffer/BufferBuilderTest.cpp
index bec7228..f18b59a 100644
--- a/tests/unit/operation/buffer/BufferBuilderTest.cpp
+++ b/tests/unit/operation/buffer/BufferBuilderTest.cpp
@@ -12,7 +12,7 @@
 #include <geos/geom/LineString.h>
 #include <geos/algorithm/PointLocator.h>
 // std
@@ -66,7 +66,7 @@ namespace tut
         using geos::operation::buffer::BufferBuilder;
         using geos::operation::buffer::BufferParameters;
-        using geos::algorithm::CGAlgorithms;
         using geos::geom::LineString;
         // Original input from test in ticket #633
@@ -106,8 +106,8 @@ namespace tut
             // For left-side offset curve, the offset will be at the left side of the input line
             // and retain the same direction.
             ensure_equals(
-                CGAlgorithms::isCCW(dynamic_cast<LineString*>(g0.get())->getCoordinatesRO()),
-                CGAlgorithms::isCCW(dynamic_cast<LineString*>(gB.get())->getCoordinatesRO()));
+                Orientation::isCCW(dynamic_cast<LineString*>(g0.get())->getCoordinatesRO()),
+                Orientation::isCCW(dynamic_cast<LineString*>(gB.get())->getCoordinatesRO()));
         // right-side
@@ -121,8 +121,8 @@ namespace tut
             // For right-side offset curve, it'll be at the right side
             // and in the opposite direction.
             ensure_equals(
-                !CGAlgorithms::isCCW(dynamic_cast<LineString*>(gB.get())->getCoordinatesRO()));
+                !Orientation::isCCW(dynamic_cast<LineString*>(gB.get())->getCoordinatesRO()));
diff --git a/tests/xmltester/tinyxml2/tinyxml2.cpp b/tests/xmltester/tinyxml2/tinyxml2.cpp
index 6fa8596..182f406 100755
--- a/tests/xmltester/tinyxml2/tinyxml2.cpp
+++ b/tests/xmltester/tinyxml2/tinyxml2.cpp
@@ -572,7 +572,7 @@ void XMLUtil::ToStr( bool v, char* buffer, int bufferSize )
 void XMLUtil::ToStr( float v, char* buffer, int bufferSize )
-    TIXML_SNPRINTF( buffer, bufferSize, "%.8f", v );
+    TIXML_SNPRINTF( buffer, bufferSize, "%.8g", (double)v );
Summary of changes:
 capi/geos_ts_c.cpp                                 |   9 +-
 include/geos/algorithm/Makefile.am                 |   1 +
 include/geos/algorithm/Orientation.h               |  91 ++++++++++++++
 include/geos/geom/LineSegment.h                    |   4 +-
 include/geos/geom/util/GeometryTransformer.h       |   2 +-
 include/geos/planargraph/DirectedEdge.h            |   4 +-
 src/algorithm/Centroid.cpp                         |   6 +-
 src/algorithm/ConvexHull.cpp                       |  11 +-
 src/algorithm/Makefile.am                          |   1 +
 src/algorithm/Orientation.cpp                      | 131 +++++++++++++++++++++
 src/geom/Polygon.cpp                               |   4 +-
 src/geomgraph/EdgeEnd.cpp                          |   4 +-
 src/geomgraph/EdgeRing.cpp                         |   3 +-
 src/geomgraph/GeometryGraph.cpp                    |   4 +-
 src/geomgraph/PlanarGraph.cpp                      |   4 +-
 src/operation/buffer/BufferInputLineSimplifier.cpp |  11 +-
 src/operation/buffer/OffsetCurveSetBuilder.cpp     |   7 +-
 src/operation/buffer/OffsetSegmentGenerator.cpp    |  16 +--
 src/operation/buffer/RightmostEdgeFinder.cpp       |  10 +-
 src/operation/buffer/SubgraphDepthLocater.cpp      |   8 +-
 .../intersection/RectangleIntersection.cpp         |   6 +-
 src/operation/polygonize/EdgeRing.cpp              |   3 +-
 src/planargraph/DirectedEdge.cpp                   |   4 +-
 .../CGAlgorithms/computeOrientationTest.cpp        |  20 ++--
 tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp    |  18 +--
 tests/unit/algorithm/RobustLineIntersectorTest.cpp |   8 +-
 tests/unit/operation/buffer/BufferBuilderTest.cpp  |  12 +-
 tests/xmltester/tinyxml2/tinyxml2.cpp              |   2 +-
 28 files changed, 319 insertions(+), 85 deletions(-)
 create mode 100644 include/geos/algorithm/Orientation.h
 create mode 100644 src/algorithm/Orientation.cpp
hooks/post-receive
More information about the geos-commits mailing list
