[geos-commits] [SCM] GEOS branch master updated. 5f92026c20de11c4c0f46c5feb9665523c2922cf
Tue Nov 20 15:54:37 PST 2018
the project "GEOS".
       via  5f92026c20de11c4c0f46c5feb9665523c2922cf (commit)
       via  fe5f16c8f00dad2709a6dd0306b5831b686d905c (commit)
      from  81ff4c0359100dcdb8c89109e65f0c265b451ca6 (commit)
revisions in full, below.
commit 5f92026c20de11c4c0f46c5feb9665523c2922cf
Merge: 81ff4c0 fe5f16c
Author: Daniel Baston <dbaston at gmail.com>
Date:   Tue Nov 20 18:54:24 2018 -0500
    Merge branch 'trac-912'
commit fe5f16c8f00dad2709a6dd0306b5831b686d905c
Date:   Mon Nov 19 20:17:42 2018 -0500
    Resolve segfault in BinTree
    Take things a bit farther than needed to strictly fix the bug, by using
    std::unique_ptr to clearly define the ownership of objects returned by
    MonotoneChainBuilder.
diff --git a/include/geos/algorithm/MCPointInRing.h b/include/geos/algorithm/MCPointInRing.h
index 872cf44..61ebd59 100644
--- a/include/geos/algorithm/MCPointInRing.h
+++ b/include/geos/algorithm/MCPointInRing.h
@@ -22,6 +22,7 @@
 #include <geos/geom/Coordinate.h> // for composition
 #include <geos/index/bintree/Interval.h> // for composition
+#include <memory>
 #include <vector>
 // Forward declarations
@@ -38,9 +39,6 @@ namespace geos {
 			class Bintree;
 			class Interval;
-		namespace chain {
-			class MonotoneChain;
@@ -69,8 +67,9 @@ public:
 private:
 	const geom::LinearRing *ring;
 	index::bintree::Interval interval;
-	geom::CoordinateSequence *pts;
-	index::bintree::Bintree *tree;
+	std::unique_ptr<geom::CoordinateSequence> pts;
+	std::unique_ptr<index::bintree::Bintree> tree;
+	std::unique_ptr<std::vector<std::unique_ptr<index::chain::MonotoneChain>>> chains;
 	int crossings;  // number of segment/ray crossings
 	void buildIndex();
 	void testMonotoneChain(geom::Envelope *rayEnv,
diff --git a/include/geos/index/chain/MonotoneChainBuilder.h b/include/geos/index/chain/MonotoneChainBuilder.h
index 6e5ff52..8ac9060 100644
--- a/include/geos/index/chain/MonotoneChainBuilder.h
+++ b/include/geos/index/chain/MonotoneChainBuilder.h
@@ -20,6 +20,7 @@
 #define GEOS_IDX_CHAIN_MONOTONECHAINBUILDER_H
 #include <geos/export.h>
+#include <memory>
 #include <vector>
 #include <cstddef>
@@ -56,7 +57,7 @@ public:
 	 * MonotoneChain objects for the given CoordinateSequence.
 	 * Remember to deep-delete the result.
-	static std::vector<MonotoneChain*>* getChains(
+	static std::unique_ptr<std::vector<std::unique_ptr<MonotoneChain>>> getChains(
 			const geom::CoordinateSequence *pts,
 			void* context);
@@ -67,9 +68,9 @@ public:
 	static void getChains(const geom::CoordinateSequence *pts,
 			void* context,
-			std::vector<MonotoneChain*>& mcList);
+			std::vector<std::unique_ptr<MonotoneChain>> & mcList);
-	static std::vector<MonotoneChain*>* getChains(const geom::CoordinateSequence *pts)
+	static std::unique_ptr<std::vector<std::unique_ptr<MonotoneChain>>> getChains(const geom::CoordinateSequence *pts)
 		return getChains(pts, nullptr);
diff --git a/include/geos/noding/MCIndexSegmentSetMutualIntersector.h b/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
index 0b36d27..05a0c96 100644
--- a/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
+++ b/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
@@ -59,15 +59,6 @@ public:
 	~MCIndexSegmentSetMutualIntersector() override;
-	/* Returns a reference to a vector of MonotoneChain objects owned
-	 * by this class and destroyed on next call to ::process.
-	 * Copy them if you need them alive for longer.
-	std::vector<index::chain::MonotoneChain *>& getMonotoneChains()
-		return monoChains;
 	index::SpatialIndex* getIndex()
 		return index;
@@ -98,7 +89,7 @@ public:
 private:
-	typedef std::vector<index::chain::MonotoneChain *> MonoChains;
+	typedef std::vector<std::unique_ptr<index::chain::MonotoneChain>> MonoChains;
 	MonoChains monoChains;
diff --git a/src/algorithm/MCPointInRing.cpp b/src/algorithm/MCPointInRing.cpp
index 74904d8..f098575 100644
--- a/src/algorithm/MCPointInRing.cpp
+++ b/src/algorithm/MCPointInRing.cpp
@@ -60,44 +60,23 @@ MCPointInRing::MCPointInRing(const LinearRing *newRing)
 	buildIndex();
-MCPointInRing::~MCPointInRing()
-	delete tree;
-	delete pts;
+MCPointInRing::~MCPointInRing() = default;
 void
 MCPointInRing::buildIndex()
-	//using namespace geos::index;
-//	Envelope *env=ring->getEnvelopeInternal();
-	tree=new bintree::Bintree();
-	pts=CoordinateSequence::removeRepeatedPoints(ring->getCoordinatesRO());
+	tree.reset(new bintree::Bintree());
+	pts.reset(CoordinateSequence::removeRepeatedPoints(ring->getCoordinatesRO()));
+	chains = chain::MonotoneChainBuilder::getChains(pts.get());
-	// NOTE: we take ownership of mcList and it's elements
-	vector<chain::MonotoneChain*> *mcList =
-		chain::MonotoneChainBuilder::getChains(pts);
-	for(size_t i=0, n=mcList->size(); i<n; ++i)
+	for(const auto& mc : *chains)
-		chain::MonotoneChain *mc=(*mcList)[i];
 		const Envelope& mcEnv = mc->getEnvelope();
 		interval.min = mcEnv.getMinY();
 		interval.max = mcEnv.getMaxY();
-		// TODO: is 'mc' ownership transferred here ? (see below)
-		//       by documentation SpatialIndex does NOT take
-		//       ownership of the items, so unless we query it
-		//       all later we've a leak problem here..
-		//       Need a focused testcase.
-		tree->insert(&interval, mc);
+		tree->insert(&interval, mc.get());
-	// TODO: mcList elements ownership went to tree or what ?
-	delete mcList;
 bool
diff --git a/src/index/bintree/NodeBase.cpp b/src/index/bintree/NodeBase.cpp
index ee89d93..b801b43 100644
--- a/src/index/bintree/NodeBase.cpp
+++ b/src/index/bintree/NodeBase.cpp
@@ -16,14 +16,11 @@
 #include <geos/index/bintree/NodeBase.h>
 #include <geos/index/bintree/Node.h>
-#include <geos/index/chain/MonotoneChain.h> // FIXME: split
 #include <vector>
 using namespace std;
-using namespace geos::index::chain;
 namespace geos {
 namespace index { // geos.index
 namespace bintree { // geos.index.bintree
@@ -49,9 +46,6 @@ NodeBase::NodeBase()
 NodeBase::~NodeBase() {
-	for(int i=0;i<(int)items->size();i++) {
-		delete (MonotoneChain*)(*items)[i];
 	delete items;
 	delete subnode[0];
 	delete subnode[1];
diff --git a/src/index/chain/MonotoneChainBuilder.cpp b/src/index/chain/MonotoneChainBuilder.cpp
index 81b5c52..2e30a63 100644
--- a/src/index/chain/MonotoneChainBuilder.cpp
+++ b/src/index/chain/MonotoneChainBuilder.cpp
@@ -42,10 +42,11 @@ namespace index { // geos.index
 namespace chain { // geos.index.chain
 /* static public */
-vector<MonotoneChain*>*
+std::unique_ptr<std::vector<std::unique_ptr<MonotoneChain>>>
 MonotoneChainBuilder::getChains(const CoordinateSequence* pts, void* context)
-	vector<MonotoneChain*>* mcList = new vector<MonotoneChain*>();
+   	// TODO clean this up with std::make_unique (C++14)
+	std::unique_ptr<std::vector<std::unique_ptr<MonotoneChain>>> mcList{new vector<std::unique_ptr<MonotoneChain>>()};
 	getChains(pts, context, *mcList);
 	return mcList;
@@ -53,7 +54,7 @@ MonotoneChainBuilder::getChains(const CoordinateSequence* pts, void* context)
 /* static public */
 void
 MonotoneChainBuilder::getChains(const CoordinateSequence* pts, void* context,
-                                vector<MonotoneChain*>& mcList)
+                                vector<std::unique_ptr<MonotoneChain>>& mcList)
 	vector<std::size_t> startIndex;
 	getChainStartIndices(*pts, startIndex);
@@ -63,8 +64,7 @@ MonotoneChainBuilder::getChains(const CoordinateSequence* pts, void* context,
 		std::size_t n = nindexes - 1;
 		for(std::size_t i = 0; i < n; i++)
-			MonotoneChain* mc = new MonotoneChain(*pts, startIndex[i], startIndex[i+1], context);
-			mcList.push_back(mc);
+			mcList.emplace_back(new MonotoneChain(*pts, startIndex[i], startIndex[i+1], context));
diff --git a/src/noding/MCIndexNoder.cpp b/src/noding/MCIndexNoder.cpp
index aefae13..aa79c65 100644
--- a/src/noding/MCIndexNoder.cpp
+++ b/src/noding/MCIndexNoder.cpp
@@ -105,24 +105,21 @@ MCIndexNoder::intersectChains()
 void
 MCIndexNoder::add(SegmentString* segStr)
-	vector<MonotoneChain*> segChains;
+	vector<std::unique_ptr<MonotoneChain>> segChains;
 	// segChains will contain nelwy allocated MonotoneChain objects
 	MonotoneChainBuilder::getChains(segStr->getCoordinates(),
 			segStr, segChains);
-	for(vector<MonotoneChain*>::iterator
-			it=segChains.begin(), iEnd=segChains.end();
-			it!=iEnd; ++it)
+	for(auto& mc : segChains)
-		MonotoneChain* mc = *it;
 		assert(mc);
 		mc->setId(idCounter++);
-		index.insert(&(mc->getEnvelope()), mc);
+		index.insert(&(mc->getEnvelope()), mc.get());
 		// MonotoneChain objects deletion delegated to destructor
-		monoChains.push_back(mc);
+		monoChains.push_back(mc.release());
diff --git a/src/noding/MCIndexSegmentSetMutualIntersector.cpp b/src/noding/MCIndexSegmentSetMutualIntersector.cpp
index e837b5c..f35718a 100644
--- a/src/noding/MCIndexSegmentSetMutualIntersector.cpp
+++ b/src/noding/MCIndexSegmentSetMutualIntersector.cpp
@@ -43,12 +43,11 @@ MCIndexSegmentSetMutualIntersector::addToIndex(SegmentString* segStr)
     MonoChains::size_type n = segChains.size();
     chainStore.reserve(chainStore.size() + n);
-    for (MonoChains::size_type i = 0; i < n; i++)
+    for (auto& mc : segChains)
-        MonotoneChain * mc = segChains[i];
         mc->setId(indexCounter++);
-        index->insert(&(mc->getEnvelope()), mc);
-        chainStore.push_back(mc);
+        index->insert(&(mc->getEnvelope()), mc.get());
+        chainStore.push_back(std::move(mc));
@@ -59,10 +58,8 @@ MCIndexSegmentSetMutualIntersector::intersectChains()
     MCIndexSegmentSetMutualIntersector::SegmentOverlapAction overlapAction( *segInt);
-    for (MonoChains::size_type i = 0, ni = monoChains.size(); i < ni; ++i)
+    for (const auto& queryChain : monoChains)
-        MonotoneChain * queryChain = (MonotoneChain *)monoChains[i];
         std::vector<void*> overlapChains;
         index->query( &(queryChain->getEnvelope()), overlapChains);
@@ -88,11 +85,10 @@ MCIndexSegmentSetMutualIntersector::addToMonoChains(SegmentString* segStr)
     monoChains.reserve(monoChains.size() + n);
-        MonotoneChain* mc = segChains[i];
         mc->setId( processCounter++ );
+        monoChains.push_back(std::move(mc));
@@ -112,14 +108,6 @@ MCIndexSegmentSetMutualIntersector::~MCIndexSegmentSetMutualIntersector()
     delete index;
     MonoChains::iterator i, e;
-    for (i = chainStore.begin(), e = chainStore.end(); i != e; ++i) {
-        delete *i;
-    for (i = monoChains.begin(), e = monoChains.end(); i != e; i++) {
-      delete *i;
 /* public */
@@ -143,11 +131,6 @@ MCIndexSegmentSetMutualIntersector::process(SegmentString::ConstVect * segString
     processCounter = indexCounter + 1;
     nOverlaps = 0;
-    for (MonoChains::iterator i = monoChains.begin(), e = monoChains.end();
-         i != e; i++)
-      delete *i;
     monoChains.clear();
     for (SegmentString::ConstVect::size_type i = 0, n = segStrings->size(); i < n; i++)
Summary of changes:
 include/geos/algorithm/MCPointInRing.h             |  9 +++---
 include/geos/index/chain/MonotoneChainBuilder.h    |  7 +++--
 .../noding/MCIndexSegmentSetMutualIntersector.h    | 11 +-------
 src/algorithm/MCPointInRing.cpp                    | 33 ++++------------------
 src/index/bintree/NodeBase.cpp                     |  6 ----
 src/index/chain/MonotoneChainBuilder.cpp           | 10 +++----
 src/noding/MCIndexNoder.cpp                        | 11 +++-----
 src/noding/MCIndexSegmentSetMutualIntersector.cpp  | 29 ++++---------------
 8 files changed, 30 insertions(+), 86 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
