[geos-commits] [SCM] GEOS branch master updated. 52aba2ca24177acc5ceecbcfb8e47d41d45c034b
git at osgeo.org
git at osgeo.org
Thu Nov 29 14:22:10 PST 2018
the project "GEOS".
via 52aba2ca24177acc5ceecbcfb8e47d41d45c034b (commit)
from 2ff10b8e4536e8fb430d2de9e80f5b2075a4ed8e (commit)
revisions in full, below.
commit 52aba2ca24177acc5ceecbcfb8e47d41d45c034b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Nov 29 14:21:26 2018 -0800
Add the JTS ./validate XML tests.
Reorganize the order of XML tests in build files
to match sort order. Update the xml tester
to handle the operations in the validate
tests.
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index d68189f..2f3e299 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -128,6 +128,15 @@ if(GEOS_ENABLE_TESTS)
${XMLTESTS_DIR}/ticket/bug615.xml
${XMLTESTS_DIR}/ticket/bug716.xml
${XMLTESTS_DIR}/ticket/bug837.xml
+ ${XMLTESTS_DIR}/validate/TestRelateAA-big.xml
+ ${XMLTESTS_DIR}/validate/TestRelateAA.xml
+ ${XMLTESTS_DIR}/validate/TestRelateAC.xml
+ ${XMLTESTS_DIR}/validate/TestRelateLA.xml
+ ${XMLTESTS_DIR}/validate/TestRelateLC.xml
+ ${XMLTESTS_DIR}/validate/TestRelateLL.xml
+ ${XMLTESTS_DIR}/validate/TestRelatePA.xml
+ ${XMLTESTS_DIR}/validate/TestRelatePL.xml
+ ${XMLTESTS_DIR}/validate/TestRelatePP.xml
set(FAILING_XMLTESTS
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index 61017b7..e38f00b 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -13,53 +13,39 @@ CLEANFILES = testrunner
EXTRA_DIST = testrunner.sh CMakeLists.txt
-SAFE_XMLTESTS=$(srcdir)/tests/testLeaksBig.xml \
- $(srcdir)/tests/split.xml \
+SAFE_XMLTESTS= \
+ $(srcdir)/tests/TestBufferExternal.xml \
+ $(srcdir)/tests/TestBufferExternal2.xml \
+ $(srcdir)/tests/TestIsValid.xml \
+ $(srcdir)/tests/badguy3.xml \
+ $(srcdir)/tests/buffer.xml \
+ $(srcdir)/tests/fme.xml \
+ $(srcdir)/tests/heisenbugs.xml \
$(srcdir)/tests/hexwkb.xml \
- $(srcdir)/tests/test.xml \
+ $(srcdir)/tests/hole_from_shell.xml \
+ $(srcdir)/tests/hole_red.xml \
$(srcdir)/tests/linemerge.xml \
- $(srcdir)/tests/TestIsValid.xml \
$(srcdir)/tests/robustness.xml \
- $(srcdir)/tests/buffer.xml \
$(srcdir)/tests/singlesidedbuffer.xml \
- $(srcdir)/tests/ticket/bug176.xml \
- $(srcdir)/tests/ticket/bug188.xml \
- $(srcdir)/tests/ticket/bug244.xml \
- $(srcdir)/tests/ticket/bug275.xml \
- $(srcdir)/tests/ticket/bug350.xml \
- $(srcdir)/tests/ticket/bug356.xml \
- $(srcdir)/tests/ticket/bug358.xml \
- $(srcdir)/tests/ticket/bug360.xml \
- $(srcdir)/tests/ticket/bug366.xml \
- $(srcdir)/tests/ticket/bug392.xml \
- $(srcdir)/tests/ticket/bug398.xml \
- $(srcdir)/tests/ticket/bug434.xml \
- $(srcdir)/tests/ticket/bug459.xml \
- $(srcdir)/tests/ticket/bug527.xml \
- $(srcdir)/tests/ticket/bug569.xml \
- $(srcdir)/tests/ticket/bug582.xml \
- $(srcdir)/tests/ticket/bug586.xml \
- $(srcdir)/tests/ticket/bug599.xml \
- $(srcdir)/tests/ticket/bug605.xml \
- $(srcdir)/tests/ticket/bug615.xml \
- $(srcdir)/tests/ticket/bug716.xml \
- $(srcdir)/tests/ticket/bug837.xml \
+ $(srcdir)/tests/split.xml \
+ $(srcdir)/tests/test.xml \
+ $(srcdir)/tests/testLeaksBig.xml \
$(srcdir)/tests/general/TestBoundary.xml \
$(srcdir)/tests/general/TestBuffer.xml \
$(srcdir)/tests/general/TestBufferMitredJoin.xml \
$(srcdir)/tests/general/TestCentroid.xml \
- $(srcdir)/tests/general/TestConvexHull.xml \
$(srcdir)/tests/general/TestConvexHull-big.xml \
+ $(srcdir)/tests/general/TestConvexHull.xml \
$(srcdir)/tests/general/TestDistance.xml \
- $(srcdir)/tests/general/TestFunctionAAPrec.xml \
$(srcdir)/tests/general/TestFunctionAA.xml \
- $(srcdir)/tests/general/TestFunctionLAPrec.xml \
+ $(srcdir)/tests/general/TestFunctionAAPrec.xml \
$(srcdir)/tests/general/TestFunctionLA.xml \
- $(srcdir)/tests/general/TestFunctionLLPrec.xml \
+ $(srcdir)/tests/general/TestFunctionLAPrec.xml \
$(srcdir)/tests/general/TestFunctionLL.xml \
+ $(srcdir)/tests/general/TestFunctionLLPrec.xml \
$(srcdir)/tests/general/TestFunctionPA.xml \
- $(srcdir)/tests/general/TestFunctionPLPrec.xml \
$(srcdir)/tests/general/TestFunctionPL.xml \
+ $(srcdir)/tests/general/TestFunctionPLPrec.xml \
$(srcdir)/tests/general/TestFunctionPP.xml \
$(srcdir)/tests/general/TestInteriorPoint.xml \
$(srcdir)/tests/general/TestPreparedPointPredicate.xml \
@@ -67,35 +53,59 @@ SAFE_XMLTESTS=$(srcdir)/tests/testLeaksBig.xml \
$(srcdir)/tests/general/TestPreparedPredicatesWithGeometryCollection.xml \
$(srcdir)/tests/general/TestRectanglePredicate.xml \
$(srcdir)/tests/general/TestRelateAA.xml \
- $(srcdir)/tests/general/TestRelateLA.xml \
- $(srcdir)/tests/general/TestRelateLL.xml \
- $(srcdir)/tests/general/TestRelatePL.xml \
$(srcdir)/tests/general/TestRelateAC.xml \
+ $(srcdir)/tests/general/TestRelateLA.xml \
$(srcdir)/tests/general/TestRelateLC.xml \
+ $(srcdir)/tests/general/TestRelateLL.xml \
$(srcdir)/tests/general/TestRelatePA.xml \
+ $(srcdir)/tests/general/TestRelatePL.xml \
$(srcdir)/tests/general/TestRelatePP.xml \
$(srcdir)/tests/general/TestSimple.xml \
$(srcdir)/tests/general/TestUnaryUnion.xml \
$(srcdir)/tests/general/TestUnaryUnionFloating.xml \
$(srcdir)/tests/general/TestValid.xml \
- $(srcdir)/tests/general/TestValid2.xml \
$(srcdir)/tests/general/TestValid2-big.xml \
+ $(srcdir)/tests/general/TestValid2.xml \
$(srcdir)/tests/general/TestWithinDistance.xml \
- $(srcdir)/tests/stmlf/stmlf-cases-20061020.xml \
- $(srcdir)/tests/stmlf/stmlf-cases-20061020-invalid-output.xml \
- $(srcdir)/tests/stmlf/stmlf-cases-20070119.xml \
$(srcdir)/tests/robust/TestRobustOverlayFixed.xml \
$(srcdir)/tests/robust/TestRobustRelate.xml \
- $(srcdir)/tests/fme.xml \
- $(srcdir)/tests/TestBufferExternal.xml \
- $(srcdir)/tests/TestBufferExternal2.xml \
- $(srcdir)/tests/heisenbugs.xml \
- $(srcdir)/tests/badguy3.xml \
- $(srcdir)/tests/hole_from_shell.xml \
- $(srcdir)/tests/hole_red.xml \
$(srcdir)/tests/safe/16595.xml \
$(srcdir)/tests/safe/16596.xml \
- $(srcdir)/tests/safe/TestBufferJagged.xml
+ $(srcdir)/tests/safe/TestBufferJagged.xml \
+ $(srcdir)/tests/stmlf/stmlf-cases-20061020-invalid-output.xml \
+ $(srcdir)/tests/stmlf/stmlf-cases-20061020.xml \
+ $(srcdir)/tests/stmlf/stmlf-cases-20070119.xml \
+ $(srcdir)/tests/ticket/bug176.xml \
+ $(srcdir)/tests/ticket/bug188.xml \
+ $(srcdir)/tests/ticket/bug244.xml \
+ $(srcdir)/tests/ticket/bug275.xml \
+ $(srcdir)/tests/ticket/bug350.xml \
+ $(srcdir)/tests/ticket/bug356.xml \
+ $(srcdir)/tests/ticket/bug358.xml \
+ $(srcdir)/tests/ticket/bug360.xml \
+ $(srcdir)/tests/ticket/bug366.xml \
+ $(srcdir)/tests/ticket/bug392.xml \
+ $(srcdir)/tests/ticket/bug398.xml \
+ $(srcdir)/tests/ticket/bug434.xml \
+ $(srcdir)/tests/ticket/bug459.xml \
+ $(srcdir)/tests/ticket/bug527.xml \
+ $(srcdir)/tests/ticket/bug569.xml \
+ $(srcdir)/tests/ticket/bug582.xml \
+ $(srcdir)/tests/ticket/bug586.xml \
+ $(srcdir)/tests/ticket/bug599.xml \
+ $(srcdir)/tests/ticket/bug605.xml \
+ $(srcdir)/tests/ticket/bug615.xml \
+ $(srcdir)/tests/ticket/bug716.xml \
+ $(srcdir)/tests/ticket/bug837.xml \
+ $(srcdir)/tests/validate/TestRelateAA-big.xml \
+ $(srcdir)/tests/validate/TestRelateAA.xml \
+ $(srcdir)/tests/validate/TestRelateAC.xml \
+ $(srcdir)/tests/validate/TestRelateLA.xml \
+ $(srcdir)/tests/validate/TestRelateLC.xml \
+ $(srcdir)/tests/validate/TestRelateLL.xml \
+ $(srcdir)/tests/validate/TestRelatePA.xml \
+ $(srcdir)/tests/validate/TestRelatePL.xml \
+ $(srcdir)/tests/validate/TestRelatePP.xml
INVALID_OUTPUT_XMLTESTS =
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 626ec62..3ad7e53 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -949,6 +949,21 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
if (actual_result==opRes) success=1;
+ else if (opName=="overlaps")
+ geom::Geometry *g1 = opArg1 == "B" ? gB : gA;
+ geom::Geometry *g2 = opArg2 == "B" ? gB : gA;
+ actual_result="false";
+ if ( usePrepared )
+ if ( prepare(g1)->overlaps(g2) ) actual_result="true";
+ else if (g1->overlaps(g2)) actual_result="true";
+ if (actual_result==opRes) success=1;
else if (opName=="within")
@@ -964,6 +979,51 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
+ else if (opName=="touches")
+ if ( prepare(g1)->touches(g2) ) actual_result="true";
+ else if (g1->touches(g2)) actual_result="true";
+ else if (opName=="crosses")
+ if ( prepare(g1)->crosses(g2) ) actual_result="true";
+ else if (g1->crosses(g2)) actual_result="true";
+ else if (opName=="disjoint")
+ if ( prepare(g1)->disjoint(g2) ) actual_result="true";
+ else if (g1->disjoint(g2)) actual_result="true";
else if (opName=="covers")
@@ -979,6 +1039,18 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
+ // equalsTopo() is synomym for equals() in JTS
+ else if (opName=="equalstopo")
+ if (g1->equals(g2)) actual_result="true";
else if (opName=="coveredby")
diff --git a/tests/xmltester/tests/validate/TestRelateAA-big.xml b/tests/xmltester/tests/validate/TestRelateAA-big.xml
new file mode 100644
index 0000000..2d8e9c6
--- /dev/null
+++ b/tests/xmltester/tests/validate/TestRelateAA-big.xml
@@ -0,0 +1,34 @@
+<run>
+<precisionModel type="FLOATING"/>
+<case>
+<desc>A/A-6-18: a polygon overlapping a very skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (100 100, 100 200, 200 200, 200 100, 100 100))
+ </a>
+ <b>
+ POLYGON(
+ (100 100, 1000000000000000 110, 1000000000000000 100, 100 100))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="212111212">true</op>
+ </test>
+</case>
+<case>
+<desc>A/A-6-24: a polygon overlapping a very skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (120 100, 120 200, 200 200, 200 100, 120 100))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+</run>
diff --git a/tests/xmltester/tests/validate/TestRelateAA.xml b/tests/xmltester/tests/validate/TestRelateAA.xml
index 0000000..bb9c3ea
--- /dev/null
+++ b/tests/xmltester/tests/validate/TestRelateAA.xml
@@ -0,0 +1,2833 @@
+<run>
+<case>
+<desc>A/A-1-1: same polygons [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Bdy.SP-EP}]</desc>
+ <a>
+ POLYGON(
+ (20 20, 20 100, 120 100, 140 20, 20 20))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="2FFF1FFF2">true</op>
+ </test>
+ <test><op name="contains" arg1="A" arg2="B">true</op></test>
+ <test><op name="coveredBy" arg1="A" arg2="B">true</op></test>
+ <test><op name="covers" arg1="A" arg2="B">true</op></test>
+ <test><op name="crosses" arg1="A" arg2="B">false</op></test>
+ <test><op name="disjoint" arg1="A" arg2="B">false</op></test>
+ <test><op name="equalsTopo" arg1="A" arg2="B">true</op></test>
+ <test><op name="intersects" arg1="A" arg2="B">true</op></test>
+ <test><op name="overlaps" arg1="A" arg2="B">false</op></test>
+ <test><op name="touches" arg1="A" arg2="B">false</op></test>
+ <test><op name="within" arg1="A" arg2="B">true</op></test>
+</case>
+<case>
+<desc>A/A-1-2: same polygons with reverse sequence of points [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Bdy.EP-SP}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 20, 140 20, 120 100, 20 100, 20 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-1-3: same polygons with different sequence of points [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Bdy.SP-EP}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (120 100, 140 20, 20 20, 20 100, 120 100))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-1-4: same polygons with different number of points [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Bdy.SP-EP}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 100, 60 100, 120 100, 140 20, 80 20, 20 20, 20 100))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-2: different polygons [dim(2){A.A.Int = B.A.Ext}]</desc>
+ <a>
+ POLYGON(
+ (0 0, 80 0, 80 80, 0 80, 0 0))
+ </a>
+ <b>
+ POLYGON(
+ (100 200, 100 140, 180 140, 180 200, 100 200))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF2FF1212">true</op>
+ </test>
+ <test><op name="contains" arg1="A" arg2="B">false</op></test>
+ <test><op name="coveredBy" arg1="A" arg2="B">false</op></test>
+ <test><op name="covers" arg1="A" arg2="B">false</op></test>
+ <test><op name="disjoint" arg1="A" arg2="B">true</op></test>
+ <test><op name="equalsTopo" arg1="A" arg2="B">false</op></test>
+ <test><op name="intersects" arg1="A" arg2="B">false</op></test>
+ <test><op name="within" arg1="A" arg2="B">false</op></test>
+</case>
+<case>
+<desc>A/A-3-1-1: the closing point of a polygon touching the closing point of another polygon [dim(0){A.A.Bdy.CP = B.A.Bdy.CP}]</desc>
+ <a>
+ POLYGON(
+ (140 120, 160 20, 20 20, 20 120, 140 120))
+ </a>
+ <b>
+ POLYGON(
+ (140 120, 140 200, 240 200, 240 120, 140 120))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF2F01212">true</op>
+ </test>
+ <test><op name="touches" arg1="A" arg2="B">true</op></test>
+</case>
+<case>
+<desc>A/A-3-1-2: the closing point of a polygon touching the boundary (at a non-vertex) of another polygon [dim(0){A.A.Bdy.CP = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (80 180, 140 260, 260 200, 200 60, 80 180))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-1-3: the closing point of a polygon touching the boundary (at a vertex) of another polygon [dim(0){A.A.Bdy.CP = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (240 80, 140 120, 180 240, 280 200, 240 80))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-1-4: the boundary (at a non-vertex) of a polygon touching the closing point of another polygon [dim(0){A.A.Bdy.NV = B.A.Bdy.CP}]</desc>
+ <a>
+ POLYGON(
+ (140 160, 20 20, 270 20, 150 160, 230 40, 60 40, 140 160))
+ </a>
+ <b>
+ POLYGON(
+ (140 40, 180 80, 120 100, 140 40))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-1-5: the boundary (at a non-vertex) of a polygon touching the boundary (at a vertex) of another polygon [dim(0){A.A.Bdy.NV = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (120 100, 180 80, 130 40, 120 100))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-1-6: the boundary (at a vertex) of a polygon touching the boundary (at a non-vertex) of another polygon [dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (20 20, 180 20, 140 140, 20 140, 20 20))
+ </a>
+ <b>
+ POLYGON(
+ (180 100, 80 200, 180 280, 260 200, 180 100))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-1-7: the boundary (at a vertex) of a polygon touching the boundary (at a vertex) of another polygon [dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (140 140, 20 120, 0 220, 120 240, 140 140))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-2-1: two polygons touching at multiple points [dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ (20 120, 20 20, 260 20, 260 120, 200 40, 140 120, 80 40, 20 120))
+ </a>
+ <b>
+ POLYGON(
+ (20 120, 20 240, 260 240, 260 120, 200 200, 140 120, 80 200, 20 120))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-2-2: two polygons touching at multiple points [dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (20 120, 20 20, 260 20, 260 120, 180 40, 140 120, 100 40, 20 120))
+ </a>
+ <b>
+ POLYGON(
+ (20 120, 300 120, 140 240, 20 120))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-2-3: two polygons touching at multiple points [dim(0){A.A.Bdy.CP = B.A.Bdy.NV}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (20 20, 20 300, 280 300, 280 260, 220 260, 60 100, 60 60, 280 60, 280 20,
+ 20 20))
+ </a>
+ <b>
+ POLYGON(
+ (100 140, 160 80, 280 180, 200 240, 220 160, 160 200, 180 120, 100 140))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-2-4: two polygons touching at multiple points [dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ 20 20))
+ </a>
+ <b>
+ POLYGON(
+ (260 200, 180 80, 120 160, 200 160, 180 220, 260 200))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-2-5: two polygons touching at multiple points [dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (20 20, 280 20, 280 140, 220 60, 140 140, 80 60, 20 140, 20 20))
+ </a>
+ <b>
+ POLYGON(
+ (0 140, 300 140, 140 240, 0 140))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-2-6: two polygons touching at multiple points [dim(0){A.A.Bdy.V = B.A.Bdy.V}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 240, 20 140, 320 140, 180 240, 20 240))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-2-7: two polygons touching at multiple points [dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 240, 20 140, 80 180, 140 140, 220 180, 280 140, 280 240, 20 240))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-3-1: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.SP-NV}]</desc>
+ <a>
+ POLYGON(
+ (120 120, 180 60, 20 20, 20 120, 120 120))
+ </a>
+ <b>
+ POLYGON(
+ (120 120, 220 20, 280 20, 240 160, 120 120))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF2F11212">true</op>
+ </test>
+</case>
+<case>
+<desc>A/A-3-3-2: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.SP-V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (140 120, 160 20, 260 120, 220 200, 140 120))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-3-3: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.NV-V}]</desc>
+ <a>
+ POLYGON(
+ (20 140, 120 40, 20 40, 20 140))
+ </a>
+ <b>
+ POLYGON(
+ (190 140, 190 20, 140 20, 20 140, 190 140))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-3-4: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.NV-V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (300 20, 220 20, 120 120, 260 160, 300 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-3-5: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.V-EP}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (140 120, 240 160, 280 60, 160 20, 140 120))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-3-6: two polygons touching along a boundary [dim(1){A.A.Bdy.SP-V = B.A.Bdy.V-V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (280 60, 180 60, 120 120, 260 180, 280 60))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-3-7: two polygons touching along a boundary [dim(1){A.A.Bdy.NV-NV = B.A.Bdy.V-V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (120 200, 120 120, 40 120, 40 200, 120 200))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-3-8: two polygons touching along a boundary [dim(1){A.A.Bdy.NV-EP = B.A.Bdy.V-V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (160 220, 140 120, 60 120, 40 220, 160 220))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-3-9: two polygons touching along a boundary [dim(1){A.A.Bdy.V-EP = B.A.Bdy.V-SP}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (140 120, 20 120, 20 220, 140 220, 140 120))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-3-3-10: two polygons touching along a boundary [dim(1){A.A.Bdy.V-V = B.A.Bdy.NV-NV}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (320 20, 220 20, 80 160, 240 140, 320 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-1: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Int}]</desc>
+ <a>
+ POLYGON(
+ (20 20, 20 180, 220 180, 220 20, 20 20))
+ </a>
+ <b>
+ POLYGON(
+ (60 40, 60 140, 180 140, 180 40, 60 40))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="212FF1FF2">true</op>
+ </test>
+</case>
+<case>
+<desc>A/A-5-2-1: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 20, 80 140, 160 60, 20 20))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="212F01FF2">true</op>
+ </test>
+</case>
+<case>
+<desc>A/A-5-2-2: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (160 60, 20 20, 100 140, 160 60))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-2-3: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.CP}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 100, 140 160, 160 40, 20 100))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-2-4: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (160 40, 20 100, 160 160, 160 40))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-2-5: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.V = B.A.Bdy.CP}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 180, 180 120, 80 40, 20 180))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-2-6: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (180 120, 100 40, 20 180, 180 120))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-3-1: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 20, 140 40, 140 120, 20 160, 80 80, 20 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-3-2: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 20, 140 40, 140 140, 20 180, 80 100, 20 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-3-3: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (40 180, 60 100, 180 100, 200 180, 120 120, 40 180))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-3-4: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.V = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 180, 60 80, 180 80, 220 180, 120 120, 20 180))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-3-5: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.V = B.A.Bdy.V}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (40 60, 20 180, 100 100, 140 180, 160 120, 220 100, 140 40, 40 60))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-3-6: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.V = B.A.Bdy.V}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (60 100, 180 100, 220 180, 120 140, 20 180, 60 100))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-4-1: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-NV = B.A.Bdy.SP-V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 20, 20 140, 120 120, 120 40, 20 20))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="212F11FF2">true</op>
+ </test>
+</case>
+<case>
+<desc>A/A-5-4-2: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-V = B.A.Bdy.SP-V)}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 20, 20 180, 140 140, 140 60, 20 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-4-3: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-NV = B.A.Bdy.V-EP}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 20, 120 40, 120 120, 20 140, 20 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-4-4: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-NV = B.A.Bdy.V-V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (120 40, 20 20, 20 140, 120 120, 120 40))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-4-5: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-V = B.A.Bdy.V-EP}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 20, 140 60, 140 140, 20 180, 20 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-4-6: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-V = B.A.Bdy.V-V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (140 60, 20 20, 20 180, 140 140, 140 60))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-4-7: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.NV-EP = B.A.Bdy.V-EP}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 20, 60 120, 140 120, 180 20, 20 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-4-8: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.NV-NV = B.A.Bdy.V-EP}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 40, 120 40, 120 120, 20 140, 20 40))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-5-5-1: a polygon containing another polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-V = B.A.Bdy.SP-V}, dim(1){A.A.Bdy.(NV, V) = B.A.Bdy.(V, V)}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 20, 20 180, 60 120, 100 180, 140 120, 220 180, 200 120, 140 60, 20 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-1: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}]</desc>
+ <a>
+ POLYGON(
+ (150 150, 330 150, 250 70, 70 70, 150 150))
+ </a>
+ <b>
+ POLYGON(
+ (150 150, 270 150, 140 20, 20 20, 150 150))
+ </b>
+ <test>
+ </test>
+ <test><op name="overlaps" arg1="A" arg2="B">true</op></test>
+</case>
+<case>
+<desc>A/A-6-2: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}]</desc>
+ <a>
+ POLYGON(
+ (150 150, 270 150, 330 150, 250 70, 190 70, 70 70, 150 150))
+ </a>
+ <b>
+ POLYGON(
+ (150 150, 270 150, 190 70, 140 20, 20 20, 70 70, 150 150))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-3: spiky polygons overlapping; boundary <-> boundary intersecting at 0 dimension [dim(2){A.A.Int = B.A.Int}]</desc>
+ <a>
+ POLYGON(
+ (20 20, 60 50, 20 40, 60 70, 20 60, 60 90, 20 90, 70 110, 20 130,
+ 80 130, 20 150, 80 160, 20 170, 80 180, 20 200, 80 200, 30 240, 80 220, 50 260,
+ 100 220, 100 260, 120 220, 130 260, 140 220, 150 280, 150 190, 160 280, 170 190, 180 280,
+ 190 190, 200 280, 210 190, 220 280, 230 190, 240 260, 250 230, 260 260, 260 220, 290 270,
+ 290 220, 330 260, 300 210, 340 240, 290 180, 340 210, 290 170, 350 170, 240 150, 350 150,
+ 240 140, 350 130, 240 120, 350 120, 240 110, 350 110, 240 100, 350 100, 240 90, 350 90,
+ 240 80, 350 80, 300 70, 340 60, 290 60, 340 40, 300 50, 340 20, 270 60, 310 20,
+ 250 60, 270 20, 230 60, 240 20, 210 60, 210 20, 190 70, 190 20, 180 90, 170 20,
+ 160 90, 150 20, 140 90, 130 20, 120 90, 110 20, 100 90, 100 20, 90 60, 80 20,
+ 70 40, 20 20))
+ </a>
+ <b>
+ POLYGON(
+ (190 140, 140 130, 200 160, 130 150, 210 170, 130 170, 210 180, 120 190, 220 200,
+ 120 200, 250 210, 120 210, 250 220, 120 220, 250 230, 120 240, 230 240, 120 250, 240 260,
+ 120 260, 240 270, 120 270, 270 290, 120 290, 230 300, 150 310, 250 310, 180 320, 250 320,
+ 200 360, 260 330, 240 360, 280 320, 290 370, 290 320, 320 360, 310 320, 360 360, 310 310,
+ 380 340, 310 290, 390 330, 310 280, 410 310, 310 270, 420 280, 310 260, 430 250, 300 250,
+ 440 240, 300 240, 450 230, 280 220, 440 220, 280 210, 440 210, 300 200, 430 190, 300 190,
+ 440 180, 330 180, 430 150, 320 180, 420 130, 300 180, 410 120, 280 180, 400 110, 280 170,
+ 390 90, 280 160, 400 70, 270 160, 450 30, 260 160, 420 30, 250 160, 390 30, 240 160,
+ 370 30, 230 160, 360 30, 230 150, 330 50, 240 130, 330 30, 230 130, 310 30, 220 130,
+ 280 30, 230 100, 270 40, 220 110, 250 30, 210 130, 240 30, 210 100, 220 40, 200 90,
+ 200 20, 190 100, 180 30, 20 20, 180 40, 20 30, 180 50, 20 50, 180 60, 30 60,
+ 180 70, 20 70, 170 80, 80 80, 170 90, 20 80, 180 100, 40 100, 200 110, 60 110,
+ 200 120, 120 120, 190 140))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="212101212">true</op>
+ </test>
+</case>
+<case>
+<desc>A/A-6-4: spiky polygons overlapping; boundary <-> boundary intersecting at 1 dimension at a few locations [dim(2){A.A.Int = B.A.Int}]</desc>
+ <a>
+ POLYGON(
+ (70 150, 20 160, 110 160, 20 180, 100 200, 20 200, 190 210, 20 210, 160 220,
+ 20 220, 150 230, 60 240, 180 250, 20 260, 170 260, 60 270, 160 270, 100 310, 170 280,
+ 200 260, 180 230, 210 260, 130 330, 230 250, 210 290, 240 250, 230 210, 260 300, 250 230,
+ 270 300, 270 240, 300 340, 280 250, 320 330, 290 250, 340 350, 290 240, 350 360, 270 190,
+ 350 340, 290 200, 350 330, 300 190, 360 320, 310 190, 360 300, 320 200, 360 280, 330 200,
+ 360 260, 340 200, 370 260, 340 180, 390 290, 340 170, 400 260, 350 170, 400 250, 350 160,
+ 410 240, 350 150, 400 170, 350 140, 310 170, 340 140, 270 180, 330 140, 260 170, 310 140,
+ 240 170, 290 140, 200 190, 270 140, 180 190, 260 140, 170 190, 260 130, 170 180, 250 130,
+ 170 170, 240 120, 170 160, 210 120, 170 150, 210 110, 340 130, 230 110, 420 140, 220 100,
+ 410 130, 220 90, 400 120, 220 80, 390 110, 220 70, 420 110, 240 70, 420 100, 260 70,
+ 420 90, 280 70, 430 80, 230 60, 430 60, 270 50, 450 40, 210 50, 370 40, 260 40,
+ 460 30, 160 40, 210 60, 200 110, 190 60, 190 120, 170 50, 180 130, 150 30, 170 130,
+ 140 20, 160 120, 130 20, 160 150, 120 20, 160 170, 110 20, 160 190, 100 20, 150 190,
+ 90 20, 140 180, 80 20, 120 140, 70 20, 120 150, 60 20, 110 150, 50 20, 100 140,
+ 50 30, 90 130, 40 30, 80 120, 30 30, 80 130, 30 40, 80 140, 20 40, 70 140,
+ 40 90, 60 130, 20 90, 60 140, 20 130, 70 150))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-5: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ (60 160, 220 160, 220 20, 60 20, 60 160))
+ </a>
+ <b>
+ POLYGON(
+ (60 160, 20 200, 260 200, 220 160, 140 80, 60 160))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-6: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (60 160, 20 200, 260 200, 140 80, 60 160))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-7: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.NV}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 200, 140 80, 260 200, 20 200))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-8: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.V}, dim(0){A.A.Bdy.V = B.A.Bdy.V}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 200, 60 160, 140 80, 220 160, 260 200, 20 200))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-9: a polygon overlapping another polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.CP = B.A.Bdy.V}, dim(0){A.A.Bdy.V = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (20 200, 60 160, 140 80, 260 200, 20 200))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-10: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (0 0, 0 200, 200 200, 200 0, 0 0))
+ </a>
+ <b>
+ POLYGON(
+ (100 100, 1000000 110, 10000000 100, 100 100))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-11: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (100 0, 100 200, 200 200, 200 0, 100 0))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-12: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (120 0, 120 200, 200 200, 200 0, 120 0))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-13: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (0 0, 0 200, 110 200, 110 0, 0 0))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-14: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (100 100, 2100 110, 2100 100, 100 100))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-15: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (100 100, 2101 110, 2101 100, 100 100))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-16: two skinny polygons overlapping [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (100 100, 200 200, 200 100, 100 100))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-17: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (100 100, 1000000 110, 1000000 100, 100 100))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-19: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (100 100, 500 110, 500 100, 100 100))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-20: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ (100 100, 501 110, 501 100, 100 100))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-21: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (120 100, 130 200, 200 200, 200 100, 120 100))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-22: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (120 100, 17 200, 200 200, 200 100, 120 100))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-23: a polygon overlapping a skinny polygon [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-NV}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-25: two skinny polygons overlapping [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (101 99, 101 1000000, 102 1000000, 101 99))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-26: two skinny polygons overlapping [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.V-EP = B.A.Bdy.NV-EP}, dim(0){A.A.Bdy.CP = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (100 100, 200 101, 200 100, 100 100))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/A-6-26: two polygons overlapping [dim(2){A.A.Int = B.A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (16 319, 150 39, 25 302, 160 20, 265 20, 127 317, 16 319))
+ </a>
+ <b>
+ POLYGON(
+ (10 307, 22 307, 153 34, 22 34, 10 307))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/Ah-3-1: the closing point of a polygon touching the closing points of another polygon and its hole [dim(0){A.A.Bdy.CP = B.A.oBdy.CP}, dim(0){A.A.Bdy.CP = B.A.iBdy.CP}]</desc>
+ <a>
+ POLYGON(
+ (160 200, 210 70, 120 70, 160 200))
+ </a>
+ <b>
+ POLYGON(
+ (160 200, 310 20, 20 20, 160 200),
+ (160 200, 260 40, 70 40, 160 200))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/Ah-3-2: the boundary of a polygon touching the inner boundary of another polygon at two spots [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.SP = B.A.iBdy.SP}, dim(0){A.A.oBdy.V = B.A.iBdy.V}]</desc>
+ <a>
+ POLYGON(
+ (170 120, 240 100, 260 50, 190 70, 170 120))
+ </a>
+ <b>
+ POLYGON(
+ (150 150, 410 150, 280 20, 20 20, 150 150),
+ (170 120, 330 120, 260 50, 100 50, 170 120))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/Ah-3-3: the boundary of a polygon touching the inner boundary of another polygon at two spots [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.SP = B.A.iBdy.SP}, dim(0){A.A.oBdy.V = B.A.iBdy.V}]</desc>
+ <a>
+ POLYGON(
+ (270 90, 200 50, 150 80, 210 120, 270 90))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/Ah-3-4: the boundary of a polygon touching the inner boundary of another polygon at one spot [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.SP = B.A.iBdy.SP}]</desc>
+ <a>
+ POLYGON(
+ (170 120, 260 100, 240 60, 150 80, 170 120))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/Ah-3-5: the boundary of a polygon touching the inner boundary of another polygon at one spot [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.SP = B.A.iBdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (220 120, 270 80, 200 60, 160 100, 220 120))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/Ah-3-6: the boundary of a polygon touching the inner boundary of another polygon at one spot [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.SP = B.A.iBdy.V}]</desc>
+ <a>
+ POLYGON(
+ (260 50, 180 70, 180 110, 260 90, 260 50))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/Ah-3-7: the boundary of a polygon touching the inner boundary of another polygon at two spots [dim(2){A.A.Int = B.A.Ext.h}, dim(0){A.A.oBdy.V = B.A.iBdy.NV}, dim(0){A.A.oBdy.V = B.A.iBdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (230 110, 290 80, 190 60, 140 90, 230 110))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/Ah-3-8: the boundary of a polygon touching the inner boundary of another polygon [dim(2){A.A.Int = B.A.Ext.h}, dim(1){A.A.oBdy.SP-EP = B.A.iBdy.SP-EP}]</desc>
+ <a>
+ POLYGON(
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF2F1F212">true</op>
+ </test>
+</case>
+<case>
+<desc>A/Ah-3-9: part of the boundary of a polygon touching part of the inner boundary of another polygon [dim(2){A.A.Int = B.A.Ext.h}, dim(1){A.A.oBdy.SP-V = B.A.iBdy.SP-NV}, dim(1){A.A.oBdy.V-EP = B.A.iBdy.NV-EP}]</desc>
+ <a>
+ POLYGON(
+ (170 120, 330 120, 280 70, 120 70, 170 120))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/Ah-3-10: part of the boundary of a polygon touching part of the inner boundary of another polygon [dim(2){A.A.Int = B.A.Ext.h}, dim(1){A.A.oBdy.SP-V = B.A.iBdy.SP-NV}, dim(1){A.A.oBdy.V-EP = B.A.iBdy.NV-EP}]</desc>
+ <a>
+ POLYGON(
+ (170 120, 300 120, 250 70, 120 70, 170 120))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/Ah-3-11: part of the boundary of a polygon touching part of the inner boundary of another polygon [dim(2){A.A.Int = B.A.Ext.h}, dim(1){A.A.oBdy.V-V-V = B.A.iBdy.NV-V-NV}]</desc>
+ <a>
+ POLYGON(
+ (190 100, 310 100, 260 50, 140 50, 190 100))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/Ah-5-1: an entire polygon within another polygon which has a hole [dim(2){A.A.Ext = B.A.Int}, dim(2){A.A.Int = B.A.Int}]</desc>
+ <a>
+ POLYGON(
+ (280 130, 360 130, 270 40, 190 40, 280 130))
+ </a>
+ <b>
+ POLYGON(
+ (170 120, 250 120, 180 50, 100 50, 170 120))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="2FF1FF212">true</op>
+ </test>
+</case>
+<case>
+<desc>A/Ah-5-2: an entire polygon within another polygon which has a hole [dim(2){A.A.Int = B.A.Int}, dim(2){A.A.Ext = B.A.Int}]</desc>
+ <a>
+ POLYGON(
+ (220 80, 180 40, 80 40, 170 130, 270 130, 230 90, 300 90, 250 30, 280 30,
+ 390 140, 150 140, 40 30, 230 30, 280 80, 220 80))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/Ah-5-3: polygon A within polygon B, the boundary of A touching the inner boundary of B [dim(2){A.A.Int = B.A.Int}, dim(2){A.A.Ext = B.A.Int}, dim(1){A.A.Bdy.NV-NV = B.A.iBdy.V-V}]</desc>
+ <a>
+ POLYGON(
+ (260 130, 360 130, 280 40, 170 40, 260 130))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="2FF11F212">true</op>
+ </test>
+</case>
+<case>
+<desc>A/Ah-5-4: polygon A within polygon B, the boundary of A touching the inner boundary of B [dim(2){A.A.Int = B.A.Int}, dim(2){A.A.Ext = B.A.Int}, dim(1){A.A.Bdy.V-V = B.A.iBdy.NV-NV}]</desc>
+ <a>
+ POLYGON(
+ (240 110, 340 110, 290 60, 190 60, 240 110))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/Ah-5-5: polygon A within polygon B, the boundary of A touching the inner boundary of B [dim(2){A.A.Int = B.A.Int}, dim(2){A.A.Ext = B.A.Int}, dim(1){A.A.Bdy.V-V = B.A.iBdy.V-V}]</desc>
+ <a>
+ POLYGON(
+ (250 120, 350 120, 280 50, 180 50, 250 120))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>Ah/Ah-1-1: same polygons (with a hole) [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.oBdy.SP-EP = B.A.oBdy.SP-EP}, dim(1){A.A.iBdy.SP-EP = B.A.iBdy.SP-EP}]</desc>
+ <a>
+ POLYGON(
+ (230 210, 230 20, 20 20, 20 210, 230 210),
+ (120 180, 50 50, 200 50, 120 180))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A2h/A2h-1-1: same polygons (with two holes) [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.oBdy.SP-EP = B.A.oBdy.SP-EP}, dim(1){A.A.iBdy.SP-EP = B.A.iBdy.SP-EP}]</desc>
+ <a>
+ POLYGON(
+ (140 40, 40 40, 40 170, 140 40),
+ (110 190, 210 190, 210 50, 110 190))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/mA-3-1: a polygon touching multipolygon at two points [dim(2){A.A.Int = B.2A.Ext}, dim(0){A.A.oBdy.CP = B.2A2.oBdy.NV}, dim(0){A.A.oBdy.V = B.2A1.oBdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (280 190, 330 150, 200 110, 150 150, 280 190))
+ </a>
+ <b>
+ MULTIPOLYGON(
+ (140 110, 260 110, 170 20, 50 20, 140 110)),
+ (300 270, 420 270, 340 190, 220 190, 300 270)))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/mA-3-2: a polygon touching multipolygon at two points [dim(2){A.A.Int = B.2A.Ext}, dim(0){A.A.oBdy.V = B.2A1.oBdy.CP}, dim(0){A.A.oBdy.V = B.2A2.oBdy.V}]</desc>
+ <a>
+ POLYGON(
+ (80 190, 220 190, 140 110, 0 110, 80 190))
+ </a>
+ <b>
+ MULTIPOLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/mA-3-3: a polygon touching multipolygon at two points [dim(2){A.A.Int = B.2A.Ext}, dim(0){A.A.oBdy.V = B.2A2.oBdy.NV}, dim(0){A.A.oBdy.V = B.2A1.oBdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (330 150, 200 110, 150 150, 280 190, 330 150))
+ </a>
+ <b>
+ MULTIPOLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/mA-3-4: a polygon touching multipolygon at one spoint [dim(2){A.A.Int = B.2A.Ext}, dim(0){A.A.oBdy.V = B.2A2.oBdy.NV}]</desc>
+ <a>
+ POLYGON(
+ (290 190, 340 150, 220 120, 170 170, 290 190))
+ </a>
+ <b>
+ MULTIPOLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/mA-3-5: a polygon touching multipolygon along boundaries [dim(2){A.A.Int = B.2A.Ext}, dim(1){A.A.oBdy.SP-V = B.2A2.oBdy.V-V}, dim(1){A.A.oBdy.V-V = B.2A1.oBdy.V-SP}]</desc>
+ <a>
+ POLYGON(
+ (220 190, 340 190, 260 110, 140 110, 220 190))
+ </a>
+ <b>
+ MULTIPOLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/mA-3-6: a polygon touching multipolygon along boundaries and at a point [dim(2){A.A.Int = B.2A.Ext}, dim(1){A.A.oBdy.V-NV = B.2A1.oBdy.NV-SP}, dim(0){A.A.oBdy.V = B.2A2.oBdy.V}]</desc>
+ <a>
+ POLYGON(
+ (140 190, 220 190, 100 70, 20 70, 140 190))
+ </a>
+ <b>
+ MULTIPOLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>A/mA-6-1: a polygon overlapping multipolygon [dim(2){A.A.Int = B.4A.Int}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}, dim(0){A.A.Bdy.NV = B.A.Bdy.CP}, dim(0){A.A.Bdy.NV = B.A.Bdy.V}, dim(0){A.A.Bdy.NV = B.A.Bdy.CP}]</desc>
+ <a>
+ POLYGON(
+ (140 220, 60 140, 140 60, 220 140, 140 220))
+ </a>
+ <b>
+ MULTIPOLYGON(
+ (100 20, 180 20, 180 100, 100 100, 100 20)),
+ (20 100, 100 100, 100 180, 20 180, 20 100)),
+ (100 180, 180 180, 180 260, 100 260, 100 180)),
+ (180 100, 260 100, 260 180, 180 180, 180 100)))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="21210F212">true</op>
+ </test>
+</case>
+<case>
+<desc>mA/mA-3-1: MultiPolygon touching MultiPolygon [dim(0){A.mA.Bdy.TP = B.mA.Bdy.TP}]</desc>
+ <a>
+ MULTIPOLYGON(
+ (110 110, 70 200, 150 200, 110 110)),
+ (110 110, 150 20, 70 20, 110 110)))
+ </a>
+ <b>
+ MULTIPOLYGON(
+ (110 110, 160 160, 210 110, 160 60, 110 110)),
+ (110 110, 60 60, 10 110, 60 160, 110 110)))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mAh/mAh-3-1: MultiPolygon touching MultiPolygon [dim(0){A.mA.Bdy.TP = B.mA.Bdy.TP}]</desc>
+ <a>
+ MULTIPOLYGON(
+ (110 110, 70 200, 150 200, 110 110),
+ (110 110, 100 180, 120 180, 110 110)),
+ (110 110, 150 20, 70 20, 110 110),
+ (110 110, 120 40, 100 40, 110 110)))
+ </a>
+ <b>
+ MULTIPOLYGON(
+ (110 110, 160 160, 210 110, 160 60, 110 110),
+ (110 110, 160 130, 160 90, 110 110)),
+ (110 110, 60 60, 10 110, 60 160, 110 110),
+ (110 110, 60 90, 60 130, 110 110)))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mAh/mAh-3-2: MultiPolygon touching MultiPolygon [dim(1){A.mA.Bdy.NV-EP = B.mA.Bdy.V-SP}, dim(1){A.mA.Bdy.SP-NV = B.mA.Bdy.EP-V}]</desc>
+ <a>
+ MULTIPOLYGON(
+ (110 110, 70 200, 200 200, 110 110),
+ (110 110, 200 20, 70 20, 110 110),
+ </a>
+ <b>
+ MULTIPOLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mAh/mAh-3-3: MultiPolygon touching MultiPolygon [dim(1){A.mA.Bdy.SP-NV = B.mA.Bdy.EP-V}, dim(1){A.mA.Bdy.NV-EP = B.mA.Bdy.V-SP}, dim(1){A.mA.Bdy.NV-EP = B.mA.Bdy.V-SP}, dim(1){A.mA.Bdy.SP-NV = B.mA.Bdy.EP-V}]</desc>
+ <a>
+ MULTIPOLYGON(
+ (110 110, 20 200, 200 200, 110 110),
+ (110 110, 200 20, 20 20, 110 110),
+ </a>
+ <b>
+ MULTIPOLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mAh/mAh-6-1: MultiPolygon touching MultiPolygon [dim(2){A.mA.Int = B.mA.Int}]</desc>
+ <a>
+ MULTIPOLYGON(
+ </a>
+ <b>
+ MULTIPOLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mAh/mAh-6-2: MultiPolygon touching MultiPolygon [dim(2){A.mA.Int = B.mA.Int}]</desc>
+ <a>
+ MULTIPOLYGON(
+ </a>
+ <b>
+ MULTIPOLYGON(
+ (110 110, 70 200, 210 110, 70 20, 110 110),
+ (110 110, 110 140, 150 110, 110 80, 110 110)),
+ </b>
+ <test>
+ </test>
+</case>
+</run>
diff --git a/tests/xmltester/tests/validate/TestRelateAC.xml b/tests/xmltester/tests/validate/TestRelateAC.xml
index 0000000..526288b
--- /dev/null
+++ b/tests/xmltester/tests/validate/TestRelateAC.xml
@@ -0,0 +1,36 @@
+<run>
+<case>
+<desc>AC A-shells overlapping B-shell at A-vertex</desc>
+ <a>
+ POLYGON(
+ (100 60, 140 100, 100 140, 60 100, 100 60))
+ </a>
+ <b>
+ MULTIPOLYGON(
+ (80 40, 120 40, 120 80, 80 80, 80 40)),
+ (120 80, 160 80, 160 120, 120 120, 120 80)),
+ (80 120, 120 120, 120 160, 80 160, 80 120)),
+ (40 80, 80 80, 80 120, 40 120, 40 80)))
+ </b>
+ <test>
+ </test>
+</case>
+</run>
diff --git a/tests/xmltester/tests/validate/TestRelateLA.xml b/tests/xmltester/tests/validate/TestRelateLA.xml
index 0000000..3be916e
--- /dev/null
+++ b/tests/xmltester/tests/validate/TestRelateLA.xml
@@ -0,0 +1,1932 @@
+<run>
+<case>
+<desc>L/A-3-1: a line touching the closing point of a polygon [dim(0){A.L.Bdy.SP = B.oBdy.CP}]</desc>
+ <a>
+ LINESTRING(150 150, 40 230)
+ </a>
+ <b>
+ POLYGON(
+ (150 150, 410 150, 280 20, 20 20, 150 150))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF1F00212">true</op>
+ </test>
+</case>
+<case>
+<desc>L/A-3-2: the start and end points of a LineString touching the boundary (at non-vertices) of a polygon [dim(0){A.L.Bdy.SP = B.oBdy.NV}, dim(0){A.L.Bdy.EP = B.oBdy.NV}]</desc>
+ <a>
+ LINESTRING(40 40, 50 130, 130 130)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF1F0F212">true</op>
+ </test>
+</case>
+<case>
+<desc>L/A-3-3: the end point of a line touching the closing point of a polygon [dim(0){A.L.Bdy.EP = B.oBdy.CP}]</desc>
+ <a>
+ LINESTRING(40 230, 150 150)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/A-3-4: an entire LineString touching the boundary (at non-vertices) of a polygon [dim(1){A.L.Int.SP-EP = B.oBdy.NV-NV}]</desc>
+ <a>
+ LINESTRING(210 150, 330 150)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F1FF0F212">true</op>
+ </test>
+</case>
+<case>
+<desc>L/A-3-5: the start portion of a LineString touching the boundary (at non-vertices) of a polygon [dim(1){A.L.Int.SP-V = B.oBdy.NV-NV}]</desc>
+ <a>
+ LINESTRING(200 150, 310 150, 360 220)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F11F00212">true</op>
+ </test>
+</case>
+<case>
+<desc>L/A-3-6: the start portion and the end point of a LineString touching the boundary of a polygon [dim(1){A.L.Int.SP-V = B.oBdy.NV-NV}, dim(0){A.L.Bdy.EP = B.A.oBdy.V}]</desc>
+ <a>
+ LINESTRING(180 150, 250 150, 230 250, 370 250, 410 150)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F11F0F212">true</op>
+ </test>
+</case>
+<case>
+<desc>L/A-3-7: the middle portion of a LineString touching the boundary (at non-vertices) of a polygon [dim(1){A.L.Int.V-V = B.oBdy.NV-NV}]</desc>
+ <a>
+ LINESTRING(210 210, 220 150, 320 150, 370 210)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F11FF0212">true</op>
+ </test>
+</case>
+<case>
+<desc>L/A-4-1: a line at non-vertex crossing non-vertex boundary of polygon [dim(0){A.L.Int.NV = B.A.oBdy.NV}, dim(1){A.L.Int.NV-EP = B.A.Int}]</desc>
+ <a>
+ LINESTRING(20 60, 150 60)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1010F0212">true</op>
+ </test>
+ <test><op name="crosses" arg1="A" arg2="B">true</op></test>
+</case>
+<case>
+<desc>L/A-4-2: a line at non-vertex crossing non-vertex boundaries of polygon twice [dim(0){A.L.Int.NV = B.A.oBdy.NV}, dim(1){A.L.Int.NV-NV = B.A.Int}]</desc>
+ <a>
+ LINESTRING(60 90, 310 180)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="101FF0212">true</op>
+ </test>
+</case>
+<case>
+<desc>L/A-4-3: a line at non-vertex crossing vertex boundary of polygon [dim(0){A.L.Int.NV = B.A.oBdy.V}, dim(1){A.L.Int.NV-EP = B.A.Int}]</desc>
+ <a>
+ LINESTRING(90 210, 210 90)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/A-4-4: a line at non-vertex crossing vertex boundaries of polygon twice [dim(0){A.L.Int.NV = B.A.oBdy.V}, dim(1){A.L.Int.NV-NV = B.A.Int}, dim(0){A.L.Int.NV = B.A.oBdy.CP}]</desc>
+ <a>
+ LINESTRING(290 10, 130 170)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/A-4-5: a line at vertex crossing non-vertex boundary of polygon [dim(0){A.L.Int.V = B.A.oBdy.NV}, dim(1){A.L.Int.V-EP = B.A.Int}]</desc>
+ <a>
+ LINESTRING(30 100, 100 100, 180 100)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/A-4-6: a line at vertex crossing non-vertex boundaries of polygon twice [dim(0){A.L.Int.V = B.A.oBdy.NV}, dim(1){A.L.Int.V-V = B.A.Int}]</desc>
+ <a>
+ LINESTRING(20 100, 100 100, 360 100, 410 100)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/A-4-7: a line at vertex crossing vertex boundary of polygon [dim(0){A.L.Int.V = B.A.oBdy.V}, dim(1){A.L.Int.V-EP = B.A.Int}]</desc>
+ <a>
+ LINESTRING(90 210, 150 150, 210 90)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/A-5-1: an entire line within a polygon [dim(1){A.L.Int.SP-EP = B.A.Int}]</desc>
+ <a>
+ LINESTRING(180 90, 280 120)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1FF0FF212">true</op>
+ </test>
+</case>
+<case>
+<desc>L/A-5-2: a line within a polygon but the line's both ends touching the boundary of the polygon [dim(1){A.L.Int.SP-EP = B.A.Int}, dim(0){A.L.Bdy.SP = B.oBdy.NV}, dim(0){A.L.Bdy.EP = B.oBdy.NV}]</desc>
+ <a>
+ LINESTRING(70 70, 80 20)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1FFF0F212">true</op>
+ </test>
+</case>
+<case>
+<desc>L/A-5-3: a line within a polygon but the line's start point touching the boundary of the polygon [dim(1){A.L.Int.SP-EP = B.A.Int}, dim(0){A.L.Bdy.SP = B.oBdy.NV}]</desc>
+ <a>
+ LINESTRING(130 20, 150 60)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1FF00F212">true</op>
+ </test>
+</case>
+<case>
+<desc>L/A-5-4: a line within a polygon but the line's start point and middle portion touching the boundary of the polygon [dim(1){A.L.Int.SP-V = B.A.Int}, dim(1){A.L.Int.V-V = B.oBdy.NV-NV}, dim(1){A.L.Int.V-EP = B.A.Int}, dim(0){A.L.Bdy.SP = B.A.oBdy.NV}]</desc>
+ <a>
+ LINESTRING(70 70, 80 20, 140 20, 150 60)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="11F00F212">true</op>
+ </test>
+</case>
+<case>
+<desc>L/A-5-5: a line within a polygon but the line's middle portion touching the boundary of the polygon [dim(1){A.L.Int.SP-V = B.A.Int}, dim(1){A.L.Int.V-V = B.A.oBdy.NV-NV}, dim(1){A.L.Int.V-EP = B.A.Int}]</desc>
+ <a>
+ LINESTRING(170 50, 170 20, 240 20, 260 60)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="11F0FF212">true</op>
+ </test>
+</case>
+<case>
+<desc>L/Ah-2-1: a line outside a polygon [dim(1){A.L.Int.SP-EP = B.A.Ext}]</desc>
+ <a>
+ LINESTRING(50 100, 140 190, 280 190)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF1FF0212">true</op>
+ </test>
+</case>
+<case>
+<desc>L/Ah-2-2: a line inside a polygon's hole [dim(1){A.L.Int.SP-EP = B.A.Ext.h}]</desc>
+ <a>
+ LINESTRING(140 60, 180 100, 290 100)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/Ah-3-1: the start point of a line touching the inner boundary of a polygon [dim(0){A.L.Bdy.SP = B.A.iBdy.CP}, dim(1){A.L.Int.SP-EP = B.A.Ext.h}]</desc>
+ <a>
+ LINESTRING(170 120, 210 80, 270 80)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/Ah-3-2: both ends of a line touching the inner boundary of a polygon [dim(0){A.L.Bdy.SP = B.A.iBdy.CP}, dim(1){A.L.Int.SP-EP = B.A.Ext.h}, dim(0){A.L.Bdy.SP = B.A.iBdy.CP}]</desc>
+ <a>
+ LINESTRING(170 120, 260 50)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/Ah-3-1: both ends of a line touching the inner boundary of a polygon [dim(0){A.L.Int.NV = B.A.Bdy.TP}]</desc>
+ <a>
+ LINESTRING(190 90, 190 270)
+ </a>
+ <b>
+ POLYGON(
+ (190 190, 360 20, 20 20, 190 190),
+ (190 190, 280 50, 100 50, 190 190))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F01FF0212">true</op>
+ </test>
+</case>
+<case>
+<desc>L/Ah-3-2: a line at a non-vertex crossing the boundary of a polygon where the closing point of the hole touches the shell at a non-vertex [dim(0){A.L.Int.NV = B.A.Bdy.TP}]</desc>
+ <a>
+ LINESTRING(60 160, 150 70)
+ </a>
+ <b>
+ POLYGON(
+ (110 110, 250 100, 140 30, 110 110))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/Ah-3-3: a line at a non-vertex crossing the boundary of a polygon where the hole at a vertex touches the shell at a non-vertex [dim(0){A.L.Int.NV = B.A.Bdy.TP}]</desc>
+ <a>
+ </a>
+ <b>
+ POLYGON(
+ (190 190, 20 20, 360 20, 190 190),
+ (250 100, 110 110, 140 30, 250 100))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/Ah-3-4: a line at a non-vertex crossing the boundary of a polygon where the hole at a vertex touches the shell at a vertex [dim(0){A.L.Int.NV = B.A.Bdy.TP}]</desc>
+ <a>
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/Ah-3-5: a line crossing polygon boundary where the closing point of the hole touches the shell at a vertex [dim(0){A.L.Int.V = B.A.Bdy.TP}]</desc>
+ <a>
+ LINESTRING(190 90, 190 190, 190 270)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/Ah-3-6: a line at a vertex crossing the boundary of a polygon where closing point of the hole touches the shell at a non-vertex [dim(0){A.L.Int.V = B.A.Bdy.TP}]</desc>
+ <a>
+ LINESTRING(60 160, 110 110, 150 70)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/Ah-3-7: a line at a vertex crossing the boundary of a polygon where the hole at a vertex touches the shell at a non-vertex [dim(0){A.L.Int.V = B.A.Bdy.TP}]</desc>
+ <a>
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/Ah-3-8: a line at a non-vertex crossing the boundary of a polygon where the hole at a vertex touches the shell at a vertex [dim(0){A.L.Int.V = B.A.Bdy.TP}]</desc>
+ <a>
+ </a>
+ <b>
+ POLYGON(
+ (190 190, 110 110, 20 20, 360 20, 190 190),
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/A2h-3-1: the start point a line touching the closing points of two connected holes in a polygon [dim(0){A.L.Int.SP = B.A.iBdy.TP}]</desc>
+ <a>
+ LINESTRING(130 110, 180 110, 190 60)
+ </a>
+ <b>
+ POLYGON(
+ (20 200, 240 200, 240 20, 20 20, 20 200),
+ (130 110, 60 180, 60 40, 130 110),
+ (130 110, 200 40, 200 180, 130 110))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/A2h-3-2: the interior (at a non-vertex) of a line touching the closing points of two connected holes in a polygon [dim(0){A.L.Int.NV = B.A.iBdy.TP}]</desc>
+ <a>
+ LINESTRING(80 110, 180 110)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/A2h-3-3: the interior (at a non-vertex) of a line touching the closing point and at a vertex of two connected holes in a polygon [dim(0){A.L.Int.NV = B.A.iBdy1.TP}]</desc>
+ <a>
+ </a>
+ <b>
+ POLYGON(
+ (20 200, 20 20, 240 20, 240 200, 20 200),
+ (60 180, 130 110, 60 40, 60 180),
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/A2h-3-4: the interior (at a non-vertex) of a line touching the closing point and at a non-vertex of two connected holes in a polygon [dim(0){A.L.Int.NV = B.A.iBdy.TP}]</desc>
+ <a>
+ LINESTRING(80 110, 170 110)
+ </a>
+ <b>
+ POLYGON(
+ (130 110, 60 40, 60 180, 130 110),
+ (130 180, 130 40, 200 110, 130 180))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/A2h-3-5: the start point a line touching the closing point and a non-vertex of two connected holes in a polygon [dim(0){A.L.Int.V = B.A.iBdy.TP}]</desc>
+ <a>
+ LINESTRING(80 110, 130 110, 170 110)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/A2h-3-6: the interior (at a vertex) of a line touching the closing points of two connected holes in a polygon [dim(0){A.L.Int.V = B.A.iBdy.TP}]</desc>
+ <a>
+ LINESTRING(80 110, 130 110, 180 110)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/A2h-3-7: the interior (at a vertex) of a line touching the closing point and at a vertex of two connected holes in a polygon [dim(0){A.L.Int.V = B.A.iBdy1.TP}]</desc>
+ <a>
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/A2h-3-8: the interior (at a vertex) of a line touching the closing point and at a non-vertex of two connected holes in a polygon [dim(0){A.L.Int.V = B.A.iBdy.TP}]</desc>
+ <a>
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/mA-4-1: a line intersecting the interior and exterior of MultiPolygon [dim(1){A.L.Int.SP-NV = B.2A1.Int}, dim (1){A.L.Int.NV-EP = B.2A2.Int}]</desc>
+ <a>
+ LINESTRING(160 70, 320 230)
+ </a>
+ <b>
+ MULTIPOLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1010FF212">true</op>
+ </test>
+</case>
+<case>
+<desc>L/mA-4-2: a line intersecting the interior and exterior of MultiPolygon [dim(1){A.L.Int.SP-V = B.2A1.Int}, dim (1){A.L.Int.V-EP = B.2A2.Int}]</desc>
+ <a>
+ LINESTRING(160 70, 200 110, 280 190, 320 230)
+ </a>
+ <b>
+ MULTIPOLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/mA-5-1: a line within two connected polygons [dim(1){A.L.Int = B.2A.Int}, dim(0){A.L.Int.NV = B.2A.Bdy.TP]</desc>
+ <a>
+ LINESTRING(70 50, 70 150)
+ </a>
+ <b>
+ MULTIPOLYGON(
+ (0 0, 0 100, 140 100, 140 0, 0 0)),
+ (20 170, 70 100, 130 170, 20 170)))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="10F0FF212">true</op>
+ </test>
+</case>
+<case>
+<desc>RL/A-3-1: a LinearRing touching a polygon's closing point [dim(0){A.RL.Int.CP = B.A.Bdy.CP}]</desc>
+ <a>
+ LINESTRING(110 110, 20 200, 200 200, 110 110)
+ </a>
+ <b>
+ POLYGON(
+ (20 20, 200 20, 110 110, 20 20))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F01FFF212">true</op>
+ </test>
+</case>
+<case>
+<desc>RL/A-3-2: a LinearRing touching a polygon's boundary at a non-vertex [dim(0){A.RL.Int.CP = B.A.Bdy.NV}]</desc>
+ <a>
+ LINESTRING(150 70, 160 110, 200 60, 150 70)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>RL/A-3-3: a LinearRing touching a polygon's boundary at a non-vertex [dim(0){A.RL.Int.CP = B.A.iBdy.NV}]</desc>
+ <a>
+ LINESTRING(80 60, 120 40, 120 70, 80 60)
+ </a>
+ <b>
+ POLYGON(
+ (110 90, 50 30, 170 30, 110 90))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>RL/A-3-4: a LinearRing on the boundary of a polygon [dim(1){A.RL.Int.SP-EP = B.A.Bdy.SP-EP}]</desc>
+ <a>
+ LINESTRING(20 20, 200 20, 110 110, 20 20)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F1FFFF2F2">true</op>
+ </test>
+</case>
+<case>
+<desc>RL/A-3-5: a LinearRing on the inner boundary of a polygon [dim(1){A.RL.Int.SP-EP = B.A.iBdy.SP-EP}]</desc>
+ <a>
+ LINESTRING(110 90, 170 30, 50 30, 110 90)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F1FFFF212">true</op>
+ </test>
+</case>
+<case>
+<desc>RL/A-3-6: a LinearRing on the inner boundary of a polygon [dim(1){A.RL.Int.SP-V = B.A.oBdy.SP-NV}]</desc>
+ <a>
+ LINESTRING(110 110, 170 50, 170 110, 110 110)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F11FFF212">true</op>
+ </test>
+</case>
+<case>
+<desc>RL/A-3-7: a LinearRing on the inner boundary of a polygon [dim(1){A.RL.Int.SP-V = B.A.iBdy.SP-NV}]</desc>
+ <a>
+ LINESTRING(110 90, 70 50, 130 50, 110 90)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>RL/A-4-1: a LinearRing crossing a polygon [dim(1){A.RL.Int.CP-NV = B.A.Int}, dim(0){A.L.Int.NV = B.A.Bdy.NV}]</desc>
+ <a>
+ LINESTRING(110 60, 20 150, 200 150, 110 60)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="101FFF212">true</op>
+ </test>
+</case>
+<case>
+<desc>RL/A-4-2: a LinearRing crossing a polygon with a hole [dim(1){A.RL.Int.NV-NV = B.A.Int}, dim(0){A.RL.Int.NV = B.A.oBdy.CP}, dim(0){A.RL.Int.NV = B.A.iBdy.CP}, dim(0){A.RL.Int.NV = B.A.oBdy.NV}, dim(0){A.RL.Int.NV = B.A.iBdy.NV}]</desc>
+ <a>
+ LINESTRING(110 130, 110 70, 200 100, 110 130)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>RL/A-5-1: a LinearRing within a polygon [dim(1){A.RL.Int.SP-EP = B.A.Int}]</desc>
+ <a>
+ LINESTRING(110 90, 160 40, 60 40, 110 90)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1FFFFF212">true</op>
+ </test>
+</case>
+<case>
+<desc>RL/A-5-2: a LinearRing within a polygon with a hole [dim(1){A.RL.Int.SP-EP = B.A.Int}]</desc>
+ <a>
+ LINESTRING(110 100, 40 30, 180 30, 110 100)
+ </a>
+ <b>
+ POLYGON(
+ (110 90, 60 40, 160 40, 110 90))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>RL/A-5-3: a LinearRing within a polygon with a hole [dim(1){A.RL.Int.SP-EP = B.A.Int}, dim(0){A.L.Int.CP = B.A.oBdy.CP}]</desc>
+ <a>
+ LINESTRING(110 110, 180 30, 40 30, 110 110)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="10FFFF212">true</op>
+ </test>
+</case>
+<case>
+<desc>RL/A-5-4: a LinearRing within a polygon with a hole [dim(1){A.RL.Int.SP-EP = B.A.Int}, dim(0){A.RL.Int.CP = B.A.iBdy.CP}]</desc>
+ <a>
+ LINESTRING(110 90, 180 30, 40 30, 110 90)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>RL/A-5-5: a LinearRing within a polygon with a hole [dim(1){A.RL.Int.SP-EP = B.A.Int}, dim(1){A.RL.Int.SP-NV = B.A.Bdy.iBdy.SP-V}]</desc>
+ <a>
+ LINESTRING(110 90, 50 30, 180 30, 110 90)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="11FFFF212">true</op>
+ </test>
+</case>
+<case>
+<desc>nsL/A-3-1: a non-simple LineString touching a polygon [dim(0){A.nsL.Bdy.SP = B.A.Bdy.CP}]</desc>
+ <a>
+ LINESTRING(110 110, 200 200, 200 110, 110 200)
+ </a>
+ <b>
+ POLYGON(
+ (110 110, 200 20, 20 20, 110 110))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>nsL/A-3-2: a non-simple LineString touching a polygon [dim(0){A.nsL.Bdy.SPb = B.A.Bdy.CP}]</desc>
+ <a>
+ LINESTRING(110 110, 200 200, 110 110, 20 200, 20 110, 200 110)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>nsL/A-3-3: a non-simple LineString touching a polygon [dim(0){A.nsL.Bdy.SPo = B.A.Bdy.CP}]</desc>
+ <a>
+ LINESTRING(110 110, 20 110, 200 110, 50 110, 110 170)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>nsL/A-3-4: a non-simple LineString touching a polygon [dim(0){A.nsL.Bdy.SPx = B.A.Bdy.CP}]</desc>
+ <a>
+ LINESTRING(110 110, 20 200, 110 200, 110 110, 200 200)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>nsL/A-3-5: a non-simple LineString touching a polygon [dim(1){A.nsL.Int.SPb-Vo = B.A.Bdy.SP-NV}]</desc>
+ <a>
+ LINESTRING(110 110, 170 50, 20 200, 20 110, 200 110)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>nsL/A-4-1: a non-simple LineString crossing a polygon [dim(1){A.nsL.Int.V-V-NV = B.A.Int}, dim(1){A.nsL.SPx-V = B.A.Bdy.SP-NV}]</desc>
+ <a>
+ LINESTRING(110 110, 180 40, 110 40, 110 180)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="111F00212">true</op>
+ </test>
+</case>
+<case>
+<desc>nsL/A-5-1: a non-simple LineString within a polygon [dim(1){A.nsL.Int.SPx-EP = B.A.Int}]</desc>
+ <a>
+ LINESTRING(110 60, 50 30, 170 30, 90 70)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>nsL/A-5-2: a non-simple LineString within a polygon [dim(1){A.nsL.Int.SPx-EP = B.A.Int}, dim(1){A.nsL.Int.SPx-V = B.A.Bdy.SP-NV}]</desc>
+ <a>
+ LINESTRING(110 110, 180 40, 110 40, 110 110, 70 40)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>nsL/Ah: the self-crossing point of a non-simple LineString touching the closing point of the inner boundary of a polygon [dim(0){A.nsL.Int.V = B.A.iBdy.CP}]</desc>
+ <a>
+ LINESTRING(230 70, 170 120, 190 60, 140 60, 170 120, 270 90)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/A-3-1: MultiLineString touching a polygon's closing point [dim(0){A.mL.Bdy.SPb = B.A.Bdy.CP}]</desc>
+ <a>
+ MULTILINESTRING(
+ (20 110, 200 110),
+ (200 200, 110 110, 20 210, 110 110))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/A-3-2: MultiLineString touching a polygon's closing point [dim(0){A.mL.Bdy.SPo = B.A.Bdy.CP}]</desc>
+ <a>
+ MULTILINESTRING(
+ (60 180, 60 110, 160 110, 110 110))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/A-3-3: MultiLineString touching a polygon's closing point [dim(0){A.mL.Bdy.SPx = B.A.Bdy.CP}]</desc>
+ <a>
+ MULTILINESTRING(
+ (200 200, 110 110, 20 200, 110 200, 110 110))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/A-4-1: MultiLineString crossing a polygon [dim(1){A.mL.Int.SP-NVb = B.A.Int}, dim(0){A.mL.Int.NVb = B.A.Bdy.CP}]</desc>
+ <a>
+ MULTILINESTRING(
+ (110 50, 110 170, 110 70, 110 150, 200 150))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/A-4-2: MultiLineString crossing a polygon [dim(1){A.mL.Int.SP-NVo = B.A.Int}, dim(0){A.mL.Int.NVo = B.A.Bdy.CP}]</desc>
+ <a>
+ MULTILINESTRING(
+ (50 110, 170 110, 110 170, 110 50, 110 170, 110 50))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/A-4-3: MultiLineString crossing a polygon [dim(1){A.mL.Int.SP-NVx = B.A.Int}, dim(0){A.mL.Int.NVx = B.A.Bdy.CP}]</desc>
+ <a>
+ MULTILINESTRING(
+ (110 60, 110 160, 200 160))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/A-4-4: MultiLineString crossing a polygon [dim(1){A.mL.Int.Vb-Vb = B.A.Int}, dim(0){A.mL.Int.Vb = B.A.oBdy.CP}, dim(0){A.mL.Int.Vb = B.A.iBdy.CP}]</desc>
+ <a>
+ MULTILINESTRING(
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/A-5-1: MultiLineString within a polygon [dim(1){A.mL.Int.SP-EP = B.A.Int}]</desc>
+ <a>
+ MULTILINESTRING(
+ (110 100, 40 30, 180 30),
+ (170 30, 110 90, 50 30))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/A-5-2: MultiLineString within a polygon [dim(1){A.mL.Int.SP-EP = B.A.Int}]</desc>
+ <a>
+ MULTILINESTRING(
+ (110 110, 60 40, 70 20, 150 20, 170 40),
+ (180 30, 40 30, 110 80))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mA-3-1: MultiLineString within a MultiPolygon [dim(0){A.mL.Bdy.SPb = B.mA.Bdy.TP}]</desc>
+ <a>
+ MULTILINESTRING(
+ (20 110, 200 110, 200 160),
+ (110 110, 200 110, 200 70, 20 150))
+ </a>
+ <b>
+ MULTIPOLYGON(
+ (110 110, 20 20, 200 20, 110 110)),
+ (110 110, 20 200, 200 200, 110 110)))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mA-3-2: MultiLineString within a MultiPolygon [dim(0){A.mL.Bdy.SPo = B.mA.Bdy.TP}]</desc>
+ <a>
+ MULTILINESTRING(
+ (20 160, 70 110, 150 110, 200 160),
+ (110 110, 20 110, 50 80, 70 110, 200 110))
+ </a>
+ <b>
+ MULTIPOLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mA-3-3: MultiLineString within a MultiPolygon [dim(0){A.mL.Bdy.SPx = B.mA.Bdy.TP}]</desc>
+ <a>
+ MULTILINESTRING(
+ (110 110, 20 170, 20 130, 200 90))
+ </a>
+ <b>
+ MULTIPOLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+</run>
diff --git a/tests/xmltester/tests/validate/TestRelateLC.xml b/tests/xmltester/tests/validate/TestRelateLC.xml
new file mode 100644
index 0000000..c002318
--- /dev/null
+++ b/tests/xmltester/tests/validate/TestRelateLC.xml
@@ -0,0 +1,57 @@
+<run>
+<precisionModel type="FLOATING"/>
+<case>
+<desc>LC - topographically equal with no boundary</desc>
+ <a>
+ LINESTRING(0 0, 0 50, 50 50, 50 0, 0 0)
+ </a>
+ <b>
+ MULTILINESTRING(
+ (0 0, 0 50),
+ (0 50, 50 50),
+ (50 50, 50 0),
+ (50 0, 0 0))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1FFFFFFF2">true</op>
+ </test>
+ <test><op name="contains" arg1="A" arg2="B">true</op></test>
+ <test><op name="coveredBy" arg1="A" arg2="B">true</op></test>
+ <test><op name="covers" arg1="A" arg2="B">true</op></test>
+ <test><op name="crosses" arg1="A" arg2="B">false</op></test>
+ <test><op name="disjoint" arg1="A" arg2="B">false</op></test>
+ <test><op name="equalsTopo" arg1="A" arg2="B">true</op></test>
+ <test><op name="intersects" arg1="A" arg2="B">true</op></test>
+ <test><op name="overlaps" arg1="A" arg2="B">false</op></test>
+ <test><op name="touches" arg1="A" arg2="B">false</op></test>
+ <test><op name="within" arg1="A" arg2="B">true</op></test>
+</case>
+<case>
+<desc>LC - equal with boundary intersection</desc>
+ <a>
+ LINESTRING(0 0, 60 0, 60 60, 60 0, 120 0)
+ </a>
+ <b>
+ MULTILINESTRING(
+ (0 0, 60 0),
+ (60 0, 120 0),
+ (60 0, 60 60))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="10FF0FFF2">true</op>
+ </test>
+</case>
+</run>
diff --git a/tests/xmltester/tests/validate/TestRelateLL.xml b/tests/xmltester/tests/validate/TestRelateLL.xml
index 0000000..0308d75
--- /dev/null
+++ b/tests/xmltester/tests/validate/TestRelateLL.xml
@@ -0,0 +1,3388 @@
+<run>
+<case>
+<desc>L/L.1-3-1: touching at the start points of two lines [dim(0){A.L.Bdy.SP = B.L.Bdy.SP}]</desc>
+ <a>
+ LINESTRING(40 40, 120 120)
+ </a>
+ <b>
+ LINESTRING(40 40, 60 120)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF1F00102">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.1-3-2: start point of one line touching end point of another line [dim(0){A.L.Bdy.SP = B.L.Bdy.EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(60 240, 40 40)
+ </b>
+ <test>
+ </test>
+ <test><op name="contains" arg1="A" arg2="B">false</op></test>
+ <test><op name="coveredBy" arg1="A" arg2="B">false</op></test>
+ <test><op name="covers" arg1="A" arg2="B">false</op></test>
+</case>
+<case>
+<desc>L/L.1-3-3: start point of a line touching the interior of another line at a non-vertex [dim(0){A.L.Bdy.SP = B.L.Int.NV}]</desc>
+ <a>
+ LINESTRING(40 40, 180 180)
+ </a>
+ <b>
+ LINESTRING(120 120, 20 200)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F01FF0102">true</op>
+ </test>
+ <test><op name="equalsTopo" arg1="A" arg2="B">false</op></test>
+ <test><op name="within" arg1="A" arg2="B">false</op></test>
+</case>
+<case>
+<desc>L/L.1-3-4: touching at the end points of two lines [dim(0){A.L.Bdy.EP = B.L.Bdy.EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(60 240, 120 120)
+ </b>
+ <test>
+ </test>
+ <test><op name="touches" arg1="A" arg2="B">true</op></test>
+</case>
+<case>
+<desc>L/L.1-3-5: end point of a line touching the interior of another line at a non-vertex [dim(0){A.L.Bdy.EP = B.L.Int.NV}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(20 180, 140 140)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.1-4-1: two lines crossing at non-vertex [dim(0){A.L.Int.NV = B.L.Int.NV}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(40 120, 120 40)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0F1FF0102">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.1-1-1: equal pointwise [dim(1){A.L.Int.SP-EP = B.L.Int.SP-EP}]</desc>
+ <a>
+ LINESTRING(40 40, 100 100)
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1FFF0FFF2">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.1-1-2: equal lines but points in reverse sequence [dim(1){A.L.Int.SP-EP = B.L.Int.EP-SP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(100 100, 40 40)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.1-2-1: dim(1){A.L.Int.SP-EP = B.L.Ext}</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(40 120, 120 160)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF1FF0102">true</op>
+ </test>
+ <test><op name="disjoint" arg1="A" arg2="B">true</op></test>
+ <test><op name="intersects" arg1="A" arg2="B">false</op></test>
+</case>
+<case>
+<desc>L/L.1-5-1: line A containing line B [dim(1){A.L.Int.SP-EP = B.L.Int.SP-EP}]</desc>
+ <a>
+ LINESTRING(20 20, 180 180)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.1-5-2: line B is part of line A [dim(1){A.L.Int.SP-NV) = B.L.Int.SP-EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(20 20, 110 110)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="101F00FF2">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.1-5-3: Line B is part of line A (in the middle portion) [dim(1){A.L.Int.NV-NV = B.L.Int.SP-EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(50 50, 140 140)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="101FF0FF2">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.1-6-1: start portions of two lines overlapping [dim(1){A.L.Int.SP-NV = B.L.Int.SP-NV]</desc>
+ <a>
+ LINESTRING(180 180, 40 40)
+ </a>
+ <b>
+ LINESTRING(120 120, 260 260)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1010F0102">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.1-6-2: end portions of two lines overlapping [dim(1){A.L.Int.NV-EP = B.L.Int.NV-EP]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(260 260, 120 120)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.1-6-3: end portion of line A overlapping the start portion of line B [dim(1){A.L.Int.NV-EP = B.L.Int.SP-NV]</desc>
+ <a>
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-3-1: two LineStrings touching at start points [dim(0){A.L.Bdy.SP = B.L.Bdy.SP}]</desc>
+ <a>
+ LINESTRING(40 40, 100 100, 200 120, 80 240)
+ </a>
+ <b>
+ LINESTRING(40 40, 20 100, 40 160, 20 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-3-2: start point of LineStrings A touching the end point of LineString B [dim(0){A.L.Bdy.SP = B.L.Bdy.EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(20 200, 40 160, 20 100, 40 40)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-3-3: two LineStrings touching at end points [dim(0){A.L.Bdy.EP = B.L.Bdy.EP}]</desc>
+ <a>
+ LINESTRING(80 240, 200 120, 100 100, 40 40)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-3-4: both the start and end points of LineString A touching the interior of LineString B at two vertices [dim(0){A.L.Bdy.SP = B.L.Int.V}, dim(0){A.L.Bdy.EP = B.L.Int.V}]</desc>
+ <a>
+ LINESTRING(60 60, 60 230, 140 230, 250 160)
+ </a>
+ <b>
+ LINESTRING(20 20, 60 60, 250 160, 310 230)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF10FF102">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.2-3-5: both the start and end points of LineString A touching the interior of LineString B at two non-vertices [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Bdy.EP = B.L.Int.NV}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(20 20, 110 110, 200 110, 320 230)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-3-6: the start and end points of two LineStrings touching each other [dim(0){A.L.Bdy.SP = B.L.Bdy.SP}, dim(0){A.L.Bdy.EP = B.L.Bdy.EP}]</desc>
+ <a>
+ LINESTRING(60 110, 60 250, 360 210)
+ </a>
+ <b>
+ LINESTRING(60 110, 110 160, 250 160, 310 160, 360 210)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF1F0F1F2">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.2-3-7: the start and end points of two LineStrings touching each other [dim(0){A.L.Bdy.SP = B.L.Bdy.EP}, dim(0){A.L.Bdy.EP = B.L.Bdy.SP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(360 210, 310 160, 110 160, 60 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-3-8: start point of LineString B touching LineString A at a non-vertex [dim(0){A.L.Int.NV = B.L.Bdy.SP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(160 160, 240 240)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-3-9: end point of LineString B touching LineString A at a non-vertex [dim(0){A.L.Int.NV = B.L.Bdy.EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(240 240, 160 160)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-3-10: both the start and end points of LineString B touching the interior of LineString A at two non-vertices [dim(0){A.L.Int.NV = B.L.Bdy.SP}, dim(0){A.L.Int.NV = B.L.Bdy.EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(60 150, 110 100, 170 100, 110 230)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F01FF01F2">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.2-3-11: the start point of LineString B touching the interior of LineString A at a non-vertex and the end point of LineString A touching the interior of LineString B at a vertex [dim(0){A.L.Int.NV = B.L.Bdy.SP}, dim(0){A.L.Bdy.EP = B.L.Int.V}]</desc>
+ <a>
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F010F0102">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.2-3-12: start point of LineString B touching LineString A at a vertex [dim(0){A.L.Int.V = B.L.Bdy.SP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(200 120, 200 190, 150 240, 200 240)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-3-13: end point of LineString B touching LineString A at a vertex [dim(0){A.L.Int.V = B.L.Bdy.EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(200 240, 150 240, 200 200, 200 120)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-3-14: both the start and end points of LineString B touching the interior of LineString A at two vertices [dim(0){A.L.Int.V = B.L.Bdy.SP}, dim(0){A.L.Int.V = B.L.Bdy.EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(60 230, 80 140, 120 140, 140 230)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-1: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Bdy.SP}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
+ <a>
+ LINESTRING(60 110, 200 110, 250 160, 300 210)
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0F1F00102">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-2: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.SP}, dim(0){A.L.Int.V = B.L.Int.V}, dim(0){A.L.Bdy.EP = B.L.Int.EP}]</desc>
+ <a>
+ LINESTRING(60 110, 200 110, 250 160, 300 210, 360 210)
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0F1F0F1F2">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-3: two LineStrings crossing on one side [dim(0){A.L.Bdy.SP = B.L.Bdy.SP}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
+ <a>
+ LINESTRING(60 110, 220 110, 250 160, 280 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-4: two LineStrings crossing on one side [dim(0){A.L.Bdy.SP = B.L.Int.SP}, dim(0){A.L.Int.V = B.L.Int.NV}, dim(0){A.L.Bdy.EP = B.L.Int.EP}]</desc>
+ <a>
+ LINESTRING(60 110, 150 110, 200 160, 250 110, 360 110, 360 210)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-5: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
+ <a>
+ LINESTRING(130 160, 160 110, 220 110, 250 160, 250 210)
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0F10F0102">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-6: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.NV = B.L.Int.NV}]</desc>
+ <a>
+ LINESTRING(130 160, 160 110, 190 110, 230 210)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-7: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.NV}, dim(0){A.L.Bdy.SP = B.L.Bdy.EP}]</desc>
+ <a>
+ LINESTRING(130 160, 160 110, 200 110, 230 160, 260 210, 360 210)
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0F100F102">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-8: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Bdy.EP}]</desc>
+ <a>
+ LINESTRING(130 160, 160 110, 200 110, 230 160, 260 210, 360 210, 380 210)
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0010F0102">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-9: two LineStrings crossing at three points [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.NV}, dim(0){A.L.Int.NV = B.L.Bdy.EP}]</desc>
+ <a>
+ LINESTRING(130 160, 160 110, 200 110, 230 160, 260 210, 380 210)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-10: two LineStrings crossing at two points [dim(0){A.L.Bdy.SP = B.L.Int.V}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
+ <a>
+ LINESTRING(110 160, 160 110, 200 110, 250 160, 250 210)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-11: two LineStrings crossing on one side [dim(0){A.L.Bdy.SP = B.L.Int.V}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
+ <a>
+ LINESTRING(110 160, 180 110, 250 160, 320 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-12: two LineStrings crossing on one side [dim(0){A.L.Bdy.SP = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.NV}]</desc>
+ <a>
+ LINESTRING(140 160, 180 80, 220 160, 250 80)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-13: two LineStrings crossing at a vertex for one of the LineStrings [dim(0){A.L.Int.V = B.L.Int.NV}]</desc>
+ <a>
+ LINESTRING(40 40, 100 100, 200 120, 130 190)
+ </a>
+ <b>
+ LINESTRING(20 130, 70 130, 160 40)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-14: two LineStrings crossing at non-vertices for both of the LineStrings [dim(0){A.L.Int.NV = B.L.Int.NV}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(40 160, 40 100, 110 40, 170 40)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-15: two LineStrings crossing on one side [dim(0){A.L.Int.V = B.L.Int.NV}, dim(0){A.L.Int.V = B.L.Int.NV}]</desc>
+ <a>
+ LINESTRING(130 110, 180 160, 230 110, 280 160, 330 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-16: two LineStrings crossing at vertices for both LineString [dim(0){A.L.Int.V = B.L.Int.V}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(30 140, 80 140, 100 100, 200 30)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-17: two LineStrings crossing on one side [dim(0){A.L.Int.V = B.L.Int.V}, dim(0){A.L.Int.V = B.L.Int.V}]</desc>
+ <a>
+ LINESTRING(110 110, 110 160, 180 110, 250 160, 250 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-18: multiple crossings [dim(0){A.L.Int.V = B.L.Int.V}, dim(0){A.L.Int.NV = B.L.Int.NV}]</desc>
+ <a>
+ LINESTRING(20 20, 80 80, 160 80, 240 80, 300 140)
+ </a>
+ <b>
+ LINESTRING(20 60, 60 60, 60 140, 80 80, 100 20, 140 140, 180 20, 200 80, 220 20,
+ 240 80, 300 80, 270 110, 200 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-4-19: spiky LineStrings with multiple crossing [dim(0){A.L.Int.V = B.L.Int.V}]</desc>
+ <a>
+ LINESTRING(20 20, 230 20, 20 30, 170 30, 20 40, 230 40, 20 50, 230 60, 60 60,
+ 230 70, 20 70, 180 80, 60 80, 230 90, 20 90, 230 100, 30 100, 210 110, 20 110,
+ 80 120, 20 130, 170 130, 90 120, 230 130, 170 140, 230 140, 80 150, 160 140, 20 140,
+ 70 150, 20 150, 230 160, 80 160, 230 170, 20 160, 180 170, 20 170, 230 180, 20 180,
+ 40 190, 230 190, 20 200, 230 200)
+ </a>
+ <b>
+ LINESTRING(30 210, 30 60, 40 210, 40 30, 50 190, 50 20, 60 160, 60 50, 70 220,
+ 70 50, 80 20, 80 210, 90 50, 90 150, 100 30, 100 210, 110 20, 110 190, 120 50,
+ 120 180, 130 210, 120 20, 140 210, 130 50, 150 210, 130 20, 160 210, 140 30, 170 210,
+ 150 20, 180 210, 160 20, 190 210, 180 80, 170 50, 170 20, 180 70, 180 20, 190 190,
+ 190 30, 200 210, 200 30, 210 210, 210 20, 220 150, 220 20)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="001FF0102">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.2-1-1: two equal LineStrings with equal pointwise [dim(1){A.L.Int.SP-EP = B.L.Int.SP-EP}]</desc>
+ <a>
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-1-2: two equal LineStrings with points in reverse sequence [dim(1){A.L.Int.SP-EP = B.L.Int.EP-SP}]</desc>
+ <a>
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-1-3: two equal LineStrings with different number of points [dim(1){A.L.Int.SP-EP = B.L.Int.EP-SP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(80 240, 120 200, 200 120, 100 100, 80 80, 40 40)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-2-1: disjoint [dim(1){A.L.Int.SP-EP = B.L.Ext}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(260 210, 240 130, 280 120, 260 40)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-2-2: wrapping around but still disjoint [dim(1){A.L.Int.SP-EP = B.L.Ext}]</desc>
+ <a>
+ LINESTRING(100 20, 20 20, 20 160, 210 160, 210 20, 110 20, 50 120, 120 150, 200 150)
+ </a>
+ <b>
+ LINESTRING(140 130, 100 110, 120 60, 170 60)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-5-1: LineString A containing LineString B, same pointwise [dim(1){A.L.Int.SP-EP = B.L.Int.SP-EP}]</desc>
+ <a>
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-5-2: LineString A containing LineString B, LineString A with less points [dim(1){A.L.Int.SP-V = B.L.Int.SP-EP}]</desc>
+ <a>
+ LINESTRING(60 110, 110 160, 310 160, 360 210)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-5-3: LineString A containing LineString B [dim(1){A.L.Int.SP-V = B.L.Int.SP-EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(60 110, 110 160, 250 160)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-5-4: LineString A containing LineString B [dim(1){A.L.Int.NV-NV = B.L.Int.SP-EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(110 160, 310 160, 340 190)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-5-5: LineString A containing LineString B [dim(1){A.L.Int.V-NV = B.L.Int.SP-EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(140 160, 250 160, 310 160, 340 190)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-5-6: LineString A containing LineString B [dim(1){A.L.Int.V-V = B.L.Int.SP-EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(110 160, 250 160, 310 160)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-6-1: start portions of two LineStrings overlapping [dim(1){A.L.Int.SP-V = B.L.Int.SP-V}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(200 120, 100 100, 40 40, 140 80, 200 40)
+ </b>
+ <test>
+ </test>
+ <test><op name="overlaps" arg1="A" arg2="B">true</op></test>
+</case>
+<case>
+<desc>L/L.2-6-2: start portion of LineString A overlapping end portion of LineString B, intersecting at the middle of LineString A [dim(1){A.L.Int.SP-V = B.L.Int.V-EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(280 240, 240 140, 200 120, 100 100, 40 40)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1F1F00102">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.2-6-3: start portion of LineString A overlapping end portion of LineString B, intersecting at the middle of LineString A [dim(1){A.L.Int.SP-V = B.L.Int.NV-EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(80 190, 140 140, 40 40)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-6-4: end portions of two LineStrings overlapping [dim(1){A.L.Int.NV-EP = B.L.Int.V-EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(240 200, 200 260, 80 240, 140 180)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-6-5: end portion of LineString A overlapping start portion of LineString B [dim(1){A.L.Int.NV-EP = B.L.Int.SP-V}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(140 180, 80 240, 200 260, 240 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-6-6: end portion of LineString A overlapping end portion of LineString B, intersecting at the middle of LineString A [dim(1){A.L.Int.V-EP = B.L.Int.V-EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(280 240, 240 140, 200 120, 80 240)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-6-7: middle portions of two LineStrings overlapping [dim(1){A.L.Int.V-NV = B.L.Int.NV-V}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(20 80, 120 80, 200 80, 260 20)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1F1FF0102">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.2-6-8: middle portion of LineString A overlapping start portion of LineString B [dim(1){A.L.Int.V-V = B.L.Int.SP-V}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(100 100, 200 120, 240 140, 280 240)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="101FF0102">true</op>
+ </test>
+</case>
+<case>
+<desc>L/L.2-6-9: middle portion of LineString A overlapping end portion of LineString B [dim(1){A.L.Int.V-V = B.L.Int.V-EP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(280 240, 240 140, 200 120, 100 100)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-6-10: middle portions of two LineStrings overlapping [dim(1){A.L.Int.V-V = B.L.Int.V-V}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(80 20, 80 80, 240 80, 300 20)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/L.2-6-11: middle portions of two LineStrings overlapping, multiple intersects [dim(1){A.L.Int.V-V = B.L.Int.V-NV}, dim(1){A.L.Int.V-V = B.L.Int.V-NV}, dim(1){A.L.Int.V-V = B.L.Int.V-NV}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(20 80, 80 80, 120 80, 140 140, 160 80, 200 80, 220 20, 240 80, 270 110,
+ 300 80)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/LR-3-1: a LineString touching a LinearRing [dim(0){A.L.Bdy.SP = B.LR.Int.CP}]</desc>
+ <a>
+ LINESTRING(100 100, 20 180, 180 180)
+ </a>
+ <b>
+ LINESTRING(100 100, 180 20, 20 20, 100 100)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF10F01F2">true</op>
+ </test>
+</case>
+<case>
+<desc>L/LR-4-1: a LineString crossing a LinearRing [dim(0){A.L.Int.NV = B.LR.Int.CP}]</desc>
+ <a>
+ LINESTRING(20 100, 180 100, 100 180)
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0F1FF01F2">true</op>
+ </test>
+</case>
+<case>
+<desc>L/LR-4-2: a LineString crossing a LinearRing [dim(0){A.L.Int.NV = B.LR.Int.CP}]</desc>
+ <a>
+ LINESTRING(100 40, 100 160, 180 160)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/LR-4-3: a LineString crossing a LinearRing [dim(0){A.L.Int.V = B.LR.Int.CP}]</desc>
+ <a>
+ LINESTRING(20 100, 100 100, 180 100, 100 180)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/LR-5-1: a LineString within a LinearRing [dim(1){A.L.Int.SP-EP = B.LR.Int.SP-NV}]</desc>
+ <a>
+ LINESTRING(100 100, 160 40)
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1FF0FF1F2">true</op>
+ </test>
+</case>
+<case>
+<desc>L/LR-5-2: a LineString within a LinearRing [dim(1){A.L.Int.SP-EP = B.LR.Int.SP-NV}]</desc>
+ <a>
+ LINESTRING(100 100, 180 20)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/LR-5-3: a LineString within a LinearRing [dim(1){A.L.Int.SP-V-EP = B.LR.Int.NV-CP-NV}]</desc>
+ <a>
+ LINESTRING(60 60, 100 100, 140 60)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/LR-6-1: a LineString crossing a LinearRing [dim(1){A.L.Int.SP-NV = B.LR.Int.SP-V}]</desc>
+ <a>
+ LINESTRING(100 100, 190 10, 190 100)
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1F10F01F2">true</op>
+ </test>
+</case>
+<case>
+<desc>L/LR-6-2: a LineString crossing a LinearRing [dim(1){A.L.Int.SP-V = B.LR.Int.SP-NV}]</desc>
+ <a>
+ LINESTRING(100 100, 160 40, 160 100)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/LR-6-3: a LineString crossing a LinearRing [dim(1){A.L.Int.NV-V = B.LR.Int.SP-NV}]</desc>
+ <a>
+ LINESTRING(60 140, 160 40, 160 140)
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1F1FF01F2">true</op>
+ </test>
+</case>
+<case>
+<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's end point with both crossing and overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Bdy.EPb}]</desc>
+ <a>
+ LINESTRING(20 20, 140 140)
+ </a>
+ <b>
+ LINESTRING(80 80, 20 80, 140 80, 80 20, 80 140)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's end point with overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Bdy.EPo}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(80 80, 20 80, 140 80)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's end point with crossing line segments [dim(0){A.L.Int.NV = B.nsL.Bdy.EPx}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(80 80, 140 80, 80 20, 80 140)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's closing point with both crossing and overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.CPb}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(80 80, 20 80, 140 80, 80 20, 80 80)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's closing point with overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.CPo}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(80 80, 20 80, 140 80, 80 80)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's closing point with crossing line segments [dim(0){A.L.Int.NV = B.nsL.Int.CPx}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(80 80, 20 80, 20 140, 140 20, 80 20, 80 80)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a non-vertex [dim(0){A.L.Int.NV = B.nsL.Int.NV}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(20 140, 140 20, 100 20, 100 80)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a non-vertex with both crossing and overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.NVb}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(140 80, 20 80, 120 80, 80 20, 80 140)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a non-vertex with overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.NVo}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(140 80, 20 80, 140 80)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a non-vertex with crossing line segments [dim(0){A.L.Int.NV = B.nsL.Int.NVx}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(140 80, 20 80, 80 140, 80 20)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a vertex [dim(0){A.L.Int.NV = B.nsL.Int.V}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(140 80, 80 80, 20 80, 50 140, 50 60)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a vertex with both crossing and overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.Vb}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(140 80, 20 80, 120 80, 80 20, 80 80, 80 140)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a vertex with overlapping line segments [dim(0){A.L.Int.NV = B.nsL.Int.Vo}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(140 80, 20 80, 80 80, 140 80)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL: A line's interior at a non-vertex intersecting a non-simple linestring's interior at a vertex with crossing line segments [dim(0){A.L.Int.NV = B.nsL.Int.Vx}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(140 80, 20 80, 80 140, 80 80, 80 20)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL.1-3-1: start point of a LineString touching the self-intersecting point of a non-simple LineString [dim(0){A.L.Bdy.SP = B.nsL.Bdy.EPx}]</desc>
+ <a>
+ LINESTRING(130 150, 220 150, 220 240)
+ </a>
+ <b>
+ LINESTRING(130 240, 130 150, 220 20, 50 20, 130 150)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL.1-3-2: the interior of a LineString touching the self-intersecting point of a non-simple LineString [dim(0){A.L.Int.V = B.nsL.Bdy.EPx}]</desc>
+ <a>
+ LINESTRING(30 150, 130 150, 250 150)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL.1-3-3: the interior of a LineString touching the self-intersecting point of a non-simple LineString [dim(0){A.L.Int.NV = B.nsL.Bdy.EPx}]</desc>
+ <a>
+ LINESTRING(30 150, 250 150)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL.1-3-4: the interior of a LineString touching the self-intersecting point of a non-simple LineString [dim(0){A.L.Int.V = B.nsL.Bdy.EPx}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(130 240, 130 20, 30 20, 130 150)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL.1-4: a Line crossing a non-simple LineString at non-vertices [dim(0){A.L.Int.NV = B.nsL.Int.NV}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(120 240, 120 20, 20 20, 120 170)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>nsL.5/L-3-1: switching the geometries for case L/nsL.5-3-1 [dim(0){A.nsL.Bdy.EPx = B.L.Bdy.SP}]</desc>
+ <a>
+ LINESTRING(200 200, 20 20, 200 20, 110 110, 20 200, 110 200, 110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 200 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL.5-3-2: the start point of a line touching the self-intersecting and self-crossing point of a non-simple LineString [dim(0){A.L.Bdy.SP = B.nsL.Bdy.EPx}]</desc>
+ <a>
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL.5-3-3: the interior of a line touching the self-intersecting and self-crossing point of a non-simple LineString [dim(0){A.L.Int.NV = B.nsL.Bdy.EPx}]</desc>
+ <a>
+ LINESTRING(20 110, 200 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>nsL.5/L-3-4 touches dim(0){A.nsL.Bdy.EPx = B.L.Int.NV}</desc>
+ <a>
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF10F0102">true</op>
+ </test>
+</case>
+<case>
+<desc>L/nsL.10-6-1: the middle portion of a line overlapping from the self-intersecting to the self-crossing a non-simple LineString [dim(1){A.L.Int.V-V = B.nsL.Int.EPx-NVx}]</desc>
+ <a>
+ LINESTRING(90 200, 90 130, 110 110, 150 200)
+ </a>
+ <b>
+ LINESTRING(200 200, 20 20, 200 20, 20 200, 20 130, 90 130)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/nsL.10-6-2: the middle portion of a line overlapping from the self-intersecting to the self-crossing a non-simple LineString [dim(1){A.L.Int.V-V = B.nsL.Int.NVx-EPx}]</desc>
+ <a>
+ LINESTRING(200 110, 110 110, 90 130, 90 200)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>L/mL-3-1: a line's end point touching a non-vertex with crossing line segments of a MultiLineString [dim(0){A.L.Bdy.SP = B.mL.Int.NVx]</desc>
+ <a>
+ LINESTRING(80 80, 150 80, 210 80)
+ </a>
+ <b>
+ MULTILINESTRING(
+ (20 20, 140 140),
+ (20 140, 140 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>LR/LR-1-1: two equal LinearRings, pointwise [dim(1){A.LR.Int.SP-EP = B.LR.Int.SP-EP}, dim(0){A.LR.Int.CP = B.LR.Int.CP}]</desc>
+ <a>
+ LINESTRING(40 80, 160 200, 260 20, 40 80)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>LR/LR-1-2: two equal LinearRings with points in reverse sequence [dim(1){A.LR.Int.SP-EP = B.LR.Int.EP-SP}, dim(0){A.LR.Int.CP = B.LR.Int.CP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(40 80, 260 20, 160 200, 40 80)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>LR/LR-1-3: two equal LinearRings with points in different sequence [dim(1){A.LR.Int.SP-EP = B.LR.Int.SP-EP}, dim(0){A.LR.Int.CP = B.LR.Int.V}, dim(0){A.LR.Int.V = B.LR.Int.CP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(260 20, 40 80, 160 200, 260 20)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>LR/LR-1-4: two equal LinearRings with different number of points [dim(1){A.LR.Int.SP-EP = B.LR.Int.SP-EP}, dim(0){A.LR.Int.CP = B.LR.Int.V}, dim(0){A.LR.Int.NV = B.LR.Int.CP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(100 140, 160 200, 260 20, 40 80, 100 140)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>LR/LR-4-1: two LinearRings crossing at closing points [dim(0){A.LR.Int.CP = B.LR.Int.CP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(100 100, 180 180, 20 180, 100 100)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0F1FFF1F2">true</op>
+ </test>
+</case>
+<case>
+<desc>LR/LR-4-2: two LinearRings crossing at two points [dim(0){A.LR.Int.CP = B.LR.Int.CP}, dim(0){A.LR.Int.V = B.LR.Int.V},]</desc>
+ <a>
+ LINESTRING(40 150, 40 40, 150 40, 150 150, 40 150)
+ </a>
+ <b>
+ LINESTRING(40 150, 150 40, 170 20, 170 190, 40 150)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>LR/LR-4-3: two LinearRings crossing at the closing and a non-vertex [dim(0){A.LR.Int.CP = B.LR.Int.NV}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(180 100, 20 100, 100 180, 180 100)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>LR/LR-4-4: two LinearRings crossing at the closing and a vertex [dim(0){A.LR.Int.CP = B.LR.Int.V}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(180 180, 100 100, 20 180, 180 180)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>LR/LR-4-5: two LinearRings crossing at a vertex and a non-vertex [dim(0){A.LR.Int.V = B.LR.Int.NV}]</desc>
+ <a>
+ LINESTRING(20 180, 100 100, 20 20, 20 180)
+ </a>
+ <b>
+ LINESTRING(100 20, 100 180, 180 100, 100 20)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>LR/LR-4-6: two LinearRings crossing at two points [dim(0){A.LR.Int.V = B.LR.Int.NV}, dim(0){A.LR.Int.V = B.LR.Int.NV},]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(170 20, 20 170, 170 170, 170 20)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>LR/LR-6-1: two LinearRings overlapping [dim(1){A.LR.Int.CP-V = B.LR.Int.CP-V}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(40 150, 150 150, 90 210, 40 150)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="1F1FFF1F2">true</op>
+ </test>
+</case>
+<case>
+<desc>LR/LR-6-2: two LinearRings overlapping [dim(1){A.LR.Int.CP-V = B.LR.Int.NV-NV}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(20 150, 170 150, 90 230, 20 150)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>LR/LR-6-3: two LinearRings overlapping [dim(1){A.LR.Int.(V-V-V-EP) = B.LR.Int.(NV-V-V-SP)}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(40 150, 150 150, 150 40, 20 40, 20 150, 40 150)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>LR/nsL-3-1: a LinearRing touching a non-simple LineString [dim(0){A.nsL.Int.CP = B.nsL.Bdy.SPb}]</desc>
+ <a>
+ LINESTRING(110 110, 200 20, 20 20, 110 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F01FFF102">true</op>
+ </test>
+</case>
+<case>
+<desc>LR/nsL-3-1: a LinearRing touching a non-simple LineString [dim(0){A.nsL.Int.CP = B.nsL.Bdy.SPo}]</desc>
+ <a>
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>LR/nsL-3-1: a LinearRing touching a non-simple LineString [dim(0){A.nsL.Int.CP = B.nsL.Bdy.SPx}]</desc>
+ <a>
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>LR/nsL-6-1: a LinearRing and a non-simple LineString overlapping [dim(1){A.nsL.Int.SP-V = B.nsL.Int.NVx-SP}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(200 20, 20 200, 200 200, 110 110, 110 40)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="101FFF102">true</op>
+ </test>
+</case>
+<case>
+<desc>LR/nsL-6-2: a LinearRing and a non-simple LineString overlapping [dim(1){A.nsL.Int.SP-V = B.nsL.Int.NVx-SP}, dim(1){A.nsL.Int.V-EP = B.nsL.Int.EP-NVx}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(200 20, 20 200, 200 200, 20 20)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="101FFF1F2">true</op>
+ </test>
+</case>
+<case>
+<desc>nsL/nsL-4-1: non-simple LineStrings crossing at closing points [dim(0){A.nsL.Int.CP = B.nsL.Int.CP}]</desc>
+ <a>
+ LINESTRING(110 110, 20 110, 110 20, 20 20, 110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 200 200, 110 200, 200 110, 110 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>nsL/nsL-4-2: non-simple LineStrings crossing at two points without vertices [dim(0){A.nsL.Int.NV = B.nsL.Int.NV}]</desc>
+ <a>
+ LINESTRING(20 120, 120 120, 20 20, 120 20, 20 120)
+ </a>
+ <b>
+ LINESTRING(170 100, 70 100, 170 170, 70 170, 170 100)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>nsL/nsL-4-3: non-simple LineStrings crossing at a point [dim(0){A.nsL.Int.NV = B.nsL.Int.V}]</desc>
+ <a>
+ LINESTRING(20 110, 110 110, 20 20, 110 20, 20 110)
+ </a>
+ <b>
+ LINESTRING(110 160, 70 110, 60 160, 20 130, 110 160)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>nsL/nsL-4-4: non-simple LineStrings crossing at self-crossing points [dim(0){A.nsL.Int.NVx = B.nsL.Int.NVx}]</desc>
+ <a>
+ LINESTRING(20 200, 200 200, 20 20, 200 20, 20 200)
+ </a>
+ <b>
+ LINESTRING(20 110, 200 110, 200 160, 20 60, 20 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>nsL/nsL-4-5: non-simple LineStrings crossing at vertices [dim(0){A.nsL.Int.V = B.nsL.Int.V}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(200 200, 110 110, 200 110, 110 200, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>nsL/nsL-4-6: non-simple LineStrings crossing at two points with vertices [dim(0){A.nsL.Int.V = B.nsL.Int.V}]</desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING(220 120, 120 20, 220 20, 120 120, 220 120)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mL-1: MultiLineString [dim(1){A.mL.Int.SP-EP = B.mL.Int.SP-EP}]</desc>
+ <a>
+ MULTILINESTRING(
+ (70 20, 20 90, 70 170),
+ (70 170, 120 90, 70 20))
+ </a>
+ <b>
+ MULTILINESTRING(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mL-1-1: non-simple MultiLineString [dim(1){A.mL.Int.SP-EP = B.mL.Int.SP-EP}]</desc>
+ <a>
+ MULTILINESTRING(
+ (20 20, 90 20, 170 20),
+ (90 20, 90 80, 90 140))
+ </a>
+ <b>
+ MULTILINESTRING(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mL-1-2: equal non-simple MultiLineString with different sequence of lines and points [dim(1){A.mL.Int.SP-EP = B.mL.Int.EP-SP}]</desc>
+ <a>
+ MULTILINESTRING(
+ </a>
+ <b>
+ MULTILINESTRING(
+ (90 140, 90 60, 90 20),
+ (170 20, 130 20, 20 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mL-3-1: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Bdy.SPb}]</desc>
+ <a>
+ MULTILINESTRING(
+ </a>
+ <b>
+ MULTILINESTRING(
+ (90 20, 170 100, 170 140),
+ (170 60, 90 20, 20 60),
+ (130 100, 130 60, 90 20, 50 90))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mL-3-2: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Bdy.SPo}]</desc>
+ <a>
+ MULTILINESTRING(
+ </a>
+ <b>
+ MULTILINESTRING(
+ (130 140, 130 60, 90 20, 20 90, 90 20, 130 60, 170 60))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mL-3-3: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Bdy.SPx}]</desc>
+ <a>
+ MULTILINESTRING(
+ </a>
+ <b>
+ MULTILINESTRING(
+ (170 60, 90 20, 20 60))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mL-3-4: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Bdy.SPx}]</desc>
+ <a>
+ MULTILINESTRING(
+ </a>
+ <b>
+ MULTILINESTRING(
+ (130 100, 90 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mL-3-5: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Bdy.SPx}]</desc>
+ <a>
+ MULTILINESTRING(
+ </a>
+ <b>
+ MULTILINESTRING(
+ (120 100, 170 100, 90 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mL-3-6: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Int.SPb}]</desc>
+ <a>
+ MULTILINESTRING(
+ </a>
+ <b>
+ MULTILINESTRING(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mL-3-7: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Int.SPo}]</desc>
+ <a>
+ MULTILINESTRING(
+ </a>
+ <b>
+ MULTILINESTRING(
+ (130 140, 130 60, 90 20, 20 90, 90 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mL-3-8: non-simple MultiLineStrings touching at boundaries [dim(0){A.mL.Bdy.SPx = B.mL.Int.SPx}]</desc>
+ <a>
+ MULTILINESTRING(
+ </a>
+ <b>
+ MULTILINESTRING(
+ (170 60, 90 20, 20 60, 20 140, 90 20))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mL-4-1: non-simple MultiLineStrings crossing [dim(0){A.mL.Int.Vx = B.mL.Int.Vb}]</desc>
+ <a>
+ MULTILINESTRING(
+ (20 20, 90 90, 20 160),
+ (90 160, 90 20))
+ </a>
+ <b>
+ MULTILINESTRING(
+ (160 160, 90 90, 160 20),
+ (160 120, 120 120, 90 90, 160 60))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mL/mL-4-2: non-simple MultiLineStrings crossing [dim(0){A.mL.Int.Vx = B.mL.Int.Vo}]</desc>
+ <a>
+ MULTILINESTRING(
+ (90 160, 90 20))
+ </a>
+ <b>
+ MULTILINESTRING(
+ (160 120, 120 120, 90 90, 120 60, 160 60))
+ </b>
+ <test>
+ </test>
+ <test><op name="crosses" arg1="A" arg2="B">true</op></test>
+</case>
+<case>
+<desc>mL/mL-4-3: non-simple MultiLineStrings crossing [dim(0){A.mL.Int.Vx = B.mL.Int.Vx}]</desc>
+ <a>
+ MULTILINESTRING(
+ (90 160, 90 20))
+ </a>
+ <b>
+ MULTILINESTRING(
+ (160 120, 90 90, 160 60))
+ </b>
+ <test>
+ </test>
+</case>
+</run>
diff --git a/tests/xmltester/tests/validate/TestRelatePA.xml b/tests/xmltester/tests/validate/TestRelatePA.xml
index 0000000..643e766
--- /dev/null
+++ b/tests/xmltester/tests/validate/TestRelatePA.xml
@@ -0,0 +1,1018 @@
+<run>
+<case>
+<desc>P/A-2-1: a point outside a polygon [dim(0){A.P.Int = B.A.Ext}]</desc>
+ <a>
+ POINT(20 20)
+ </a>
+ <b>
+ POLYGON(
+ (60 120, 60 40, 160 40, 160 120, 60 120))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF0FFF212">true</op>
+ </test>
+</case>
+<case>
+<desc>P/A-2-2: a point outside a convex polygon [dim(0){A.P.Int = B.A.Ext}]</desc>
+ <a>
+ POINT(70 170)
+ </a>
+ <b>
+ POLYGON(
+ (110 230, 80 160, 20 160, 20 20, 200 20, 200 160, 140 160, 110 230))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/A-2-3: a point outside a concave polygon [dim(0){A.P.Int = B.A.Ext}]</desc>
+ <a>
+ POINT(110 130)
+ </a>
+ <b>
+ POLYGON(
+ (20 160, 80 160, 110 100, 140 160, 200 160, 200 20, 20 20, 20 160))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/A-2-4: dim(0){A.P.Int = B.A.Ext}</desc>
+ <a>
+ POINT(100 70)
+ </a>
+ <b>
+ POLYGON(
+ (20 150, 100 150, 40 50, 170 50, 110 150, 190 150, 190 20, 20 20, 20 150))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/A-2-5: a point outside a concave polygon [dim(0){A.P.Int = B.A.Ext}]</desc>
+ <a>
+ POINT(100 70)
+ </a>
+ <b>
+ POLYGON(
+ (20 150, 90 150, 40 50, 160 50, 110 150, 180 150, 180 20, 20 20, 20 150))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/A-3-1: a point on the closing point of a polygon [dim(0){A.P.Int = B.A.Bdy.CP}]</desc>
+ <a>
+ POINT(60 120)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F0FFFF212">true</op>
+ </test>
+</case>
+<case>
+<desc>P/A-3-2: a point on the boudary of a polygon at a non-vertex [dim(0){A.P.Int = B.A.Bdy.NV}]</desc>
+ <a>
+ POINT(110 120)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/A-3-3: a point on the boundary of a polygon at a vertex [dim(0){A.P.Int = B.A.Bdy.V]</desc>
+ <a>
+ POINT(160 120)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/A-5: a point on the interior of a polygon [dim(0){A.P.Int = B.A.Int}]</desc>
+ <a>
+ POINT(100 80)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0FFFFF212">true</op>
+ </test>
+</case>
+<case>
+<desc>P/Ah-2-1: a point outside of polygon with a hole [dim(0){A.P.Int = B.A.Ext}]</desc>
+ <a>
+ POINT(60 160)
+ </a>
+ <b>
+ POLYGON(
+ (280 50, 100 50, 190 140, 280 50))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/Ah-2-2: a point inside the hole of the polygon [dim(0){A.P.Int = B.A.Ext.h}]</desc>
+ <a>
+ POINT(190 90)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/Ah-3-1: a point on the closing point of the outer boundary of a polygon with a hole [dim(0){A.P.Int = B.A.oBdy.CP}]</desc>
+ <a>
+ POINT(190 190)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/Ah-3-2: a point on the outer boundary of a polygon at a vertex [dim(0){A.P.Int = B.A.oBdy.V}]</desc>
+ <a>
+ POINT(360 20)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/Ah-3-3: a point on the outer boundary of a polygon at a non-vertex [dim(0){A.P.Int = B.A.oBdy.NV}]</desc>
+ <a>
+ POINT(130 130)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/Ah-3-4: a point on the closing point of the inner boundary of a polygon [dim(0){A.P.Int = B.A.iBdy.CP}]</desc>
+ <a>
+ POINT(280 50)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/Ah-3-5: a point on the inner boundary of a polygon at a non-vertex [dim(0){A.P.Int = B.A.iBdy.NV}]</desc>
+ <a>
+ POINT(150 100)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/Ah-3-6: a point on the inner boundary of a polygon at a vertex [dim(0){A.P.Int = B.A.iBdy.V}]</desc>
+ <a>
+ POINT(100 50)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/Ah-5: a point inside the interior of a polygon with a hole [dim(0){A.P.Int = B.A.Int}]</desc>
+ <a>
+ POINT(140 120)
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/A2h-3-1: a point on the touching point of two holes in a polygon [dim(0){A.P.Int = B.A.iBdy.TP}]</desc>
+ <a>
+ POINT(190 50)
+ </a>
+ <b>
+ POLYGON(
+ (190 190, 360 20, 20 20, 190 190),
+ (90 50, 150 110, 190 50, 90 50),
+ (190 50, 230 110, 290 50, 190 50))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/A2h-3-2: a point on the touching point of two holes in a polygon [dim(0){A.P.Int = B.A.iBdy.TP}]</desc>
+ <a>
+ POINT(180 90)
+ </a>
+ <b>
+ POLYGON(
+ (180 140, 180 40, 80 40, 180 140),
+ (180 90, 210 140, 310 40, 230 40, 180 90))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/A-2: 3 points outside a polygon [dim(0){A.2P.Int = B.A.Ext}]</desc>
+ <a>
+ MULTIPOINT((20 80), (110 160), (20 160))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/A-3-1: one of 3 points on the closing point of the boundary of a polygon [dim(0){A.3P1.Int = B.A.Bdy.CP}]</desc>
+ <a>
+ MULTIPOINT((20 80), (60 120), (20 160))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F00FFF212">true</op>
+ </test>
+</case>
+<case>
+<desc>mP/A-3-2: one of 3 points on the boundary of a polygon at a non-vertex [dim(0){A.3P3 = B.A.Bdy.NV}]</desc>
+ <a>
+ MULTIPOINT((10 80), (110 170), (110 120))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/A-3-3: one of 3 points on the boundary of a polygon at a vertex [dim(0){A.3P1.Int = B.A.Bdy.V}]</desc>
+ <a>
+ MULTIPOINT((10 80), (110 170), (160 120))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/A-3-4: 3 of the 5 points on the boundary of a polygon [dim(0){A.5P2.Int = B.A.Bdy.CP}, dim(0){A.5P3.Int = B.A.Bdy.NV}, dim(0){A.5P4.Int = B.A.Bdy.V}]</desc>
+ <a>
+ MULTIPOINT((20 120), (60 120), (110 120), (160 120), (200 120))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/A-3-5: all 3 points on the boundary of a polygon [dim(0){A.3P1.Int = B.A.Bdy.CP}, dim(0){A.3P2.Int = B.A.Bdy.NV}, dim(0){A.3P3.Int = B.A.Bdy.V}]</desc>
+ <a>
+ MULTIPOINT((60 120), (110 120), (160 120))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/A-3-6: all 4 points on the boundary of a polygon [dim(0){A.4P = B.A.Bdy}]</desc>
+ <a>
+ MULTIPOINT((60 120), (160 120), (160 40), (60 40))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/A-4-1: 1 point outside a polygon, 1 point on the boundary and 1 point inside [dim(0){A.3P1.Int = B.A.Ext}, dim(0){A.3P2.Int = B.A.Bdy.CP}, dim(0){A.3P3.Int = B.A.Int}]</desc>
+ <a>
+ MULTIPOINT((20 150), (60 120), (110 80))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="000FFF212">true</op>
+ </test>
+</case>
+<case>
+<desc>mP/A-4-2: 1 point outside a polygon, 1 point on the boundary and 1 point inside [dim(0){A.3P1.Int = B.A.Ext}, dim(0){A.3P2.Int = B.A.Bdy.V}, dim(0){A.3P3.Int = B.A.Int}]</desc>
+ <a>
+ MULTIPOINT((110 80), (160 120), (200 160))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/A-4-3: 1 point outside a polygon, 1 point on the boundary and 1 point inside [dim(0){A.3P1.Int = B.A.Ext}, dim(0){A.3P2.Int = B.A.Bdy.NV}, dim(0){A.3P3.Int = B.A.Int}]</desc>
+ <a>
+ MULTIPOINT((110 80), (110 120), (110 160))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/A-4-4: 1 point outside a polygon, 1 point inside [dim(0){A.2P1.Int = B.A.Ext}, dim(0){A.2P2.Int = B.A.Int}]</desc>
+ <a>
+ MULTIPOINT((110 170), (110 80))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0F0FFF212">true</op>
+ </test>
+</case>
+<case>
+<desc>mP/A-4-5: 1 point outside a polygon, 2 points on the boundary and 1 point inside [dim(0){A.4P1.Int = B.A.Ext}, dim(0){A.4P2.Int = B.A.Bdy.CP}, dim(0){A.4P3.Int = B.A.Bdy.V}, dim(0){A.4P4.Int = B.A.Int}]</desc>
+ <a>
+ MULTIPOINT((60 120), (160 120), (110 80), (110 170))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/A-5-1: 2 points within a polygon [dim(0){A.2P.Int = B.A.Int]</desc>
+ <a>
+ MULTIPOINT((90 80), (130 80))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/A-5-2: 1 point on the boundary and 1 point inside a polygon [dim(0){A.2P1.Int = B.A.Bdy.CP}, dim(0){A.2P2.Int = B.A.Int}]</desc>
+ <a>
+ MULTIPOINT((60 120), (160 120), (110 80))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="00FFFF212">true</op>
+ </test>
+</case>
+<case>
+<desc>mP/Ah-2-1: 3 points outside a polygon [dim(0){A.3P.Int = B.Ah.Ext}]</desc>
+ <a>
+ MULTIPOINT((40 170), (40 90), (130 170))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/Ah-2-2: 2 points outside a polygon and 1 point inside the hole of the polygon [dim(0){A.3P1.Int = B.Ah.Ext}, dim(0){A.3P2.Int = B.Ah.Ext}, dim(0){A.3P3.Int = B.Ah.Ext.h}]</desc>
+ <a>
+ MULTIPOINT((90 170), (280 170), (190 90))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/Ah-2-3: all 3 points in polygon's hole [dim(0){A.3P.Int = B.Ah.Ext.h}]</desc>
+ <a>
+ MULTIPOINT((190 110), (150 70), (230 70))
+ </a>
+ <b>
+ POLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/mA-3-1: a point on the touching point of two polygons [dim(0){A.P.Int = B.2A.Bdy}]</desc>
+ <a>
+ POINT(100 100)
+ </a>
+ <b>
+ MULTIPOLYGON(
+ (20 100, 20 20, 100 20, 100 100, 20 100)),
+ (100 180, 100 100, 180 100, 180 180, 100 180)))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/mA-3-2: a point on the boundary of one of the 2 polygons [dim(0){A.P.Int = B.2A1.Bdy.CP}]</desc>
+ <a>
+ POINT(20 100)
+ </a>
+ <b>
+ MULTIPOLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/mA-3-3: a point on the boundary of one of the 2 polygons [dim(0){A.P.Int = B.2A1.Bdy.V}]</desc>
+ <a>
+ POINT(60 100)
+ </a>
+ <b>
+ MULTIPOLYGON(
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/mA-3-4: a point touching a polygon's boundary where the boundaries touch at a point [dim(0){A.P.Int = B.2A.Bdy.TP}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ MULTIPOLYGON(
+ (110 110, 20 200, 200 200, 110 110),
+ (110 110, 80 180, 140 180, 110 110)),
+ (110 110, 20 20, 200 20, 110 110),
+ (110 110, 80 40, 140 40, 110 110)))
+ </b>
+ <test>
+ </test>
+</case>
+</run>
diff --git a/tests/xmltester/tests/validate/TestRelatePL.xml b/tests/xmltester/tests/validate/TestRelatePL.xml
index 0000000..2e11fb7
--- /dev/null
+++ b/tests/xmltester/tests/validate/TestRelatePL.xml
@@ -0,0 +1,2286 @@
+<run>
+<case>
+<desc>P/L-2: a point and a line disjoint [dim(0){A.P.Int = B.L.Ext}]</desc>
+ <a>
+ POINT(110 200)
+ </a>
+ <b>
+ LINESTRING(90 80, 160 150, 300 150, 340 150, 340 240)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF0FFF102">true</op>
+ </test>
+</case>
+<case>
+<desc>P/L-2: a point and a zero-length line </desc>
+ <a>
+ POINT(110 200)
+ </a>
+ <b>
+ LINESTRING(110 200, 110 200)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0FFFFFFF2">true</op>
+ </test>
+</case>
+<case>
+<desc>P/L-3-1: a point touching the start point of a line [dim(0){A.P.Int = B.L.Bdy.SP}]</desc>
+ <a>
+ POINT(90 80)
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F0FFFF102">true</op>
+ </test>
+</case>
+<case>
+<desc>P/L-3-2: a point touching the end point of a line [dim(0){A.P.Int = B.L.Bdy.EP}]</desc>
+ <a>
+ POINT(340 240)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/L-5-1: a point on the line at a non-vertex [dim(0){A.P.Int = B.L.Int.NV}]</desc>
+ <a>
+ POINT(230 150)
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0FFFFF102">true</op>
+ </test>
+</case>
+<case>
+<desc>P/L-5-2: a point on the line at a vertex [dim(0){A.P.Int = B.L.Int.V}]</desc>
+ <a>
+ POINT(160 150)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/LR-2-1: a point outside a LinearRing [dim(0){A.P.Int = B.LR.Ext}]</desc>
+ <a>
+ POINT(90 150)
+ </a>
+ <b>
+ LINESTRING(150 150, 20 20, 280 20, 150 150)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF0FFF1F2">true</op>
+ </test>
+</case>
+<case>
+<desc>P/LR-2-2: a point inside a LinearRing [dim(0){A.P.Int = B.LR.Ext}]</desc>
+ <a>
+ POINT(150 80)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/LR-5-1: a point on the closing point of a LinearRing [dim(0){A.P.Int = B.LR.Int.CP}]</desc>
+ <a>
+ POINT(150 150)
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0FFFFF1F2">true</op>
+ </test>
+</case>
+<case>
+<desc>P/LR-5-2: a point on a LinearRing at a non-vertex [dim(0){A.P.Int = B.L.Int.NV}]</desc>
+ <a>
+ POINT(100 20)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/LR-5-3: a point on a LinearRing at a vertex [dim(0){A.P.Int = B.L.Int.V}]</desc>
+ <a>
+ POINT(20 20)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.1-3-1: a point on a non-simple LineString's end point [dim(0){A.P.Int = B.nsL.Bdy.EP}]</desc>
+ <a>
+ POINT(220 220)
+ </a>
+ <b>
+ LINESTRING(110 110, 220 20, 20 20, 110 110, 220 220)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.1-5-1: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.1-5-2: a point a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 220 20, 20 20, 220 220)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.1-5-3: a point on a non-simple LineString's interior at a non-vertex [dim(0){A.P.Int = B.nsL.Int.NV}]</desc>
+ <a>
+ POINT(110 20)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.1-5-4: a point on a non-simple LineString's interior at a vertex [dim(0){A.P.Int = B.nsL.Int.V}]</desc>
+ <a>
+ POINT(220 20)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.2-5-2: a point on a non-simple LineString's interior at a vertex [dim(0){A.P.Int = B.nsL.Int.NV}]</desc>
+ <a>
+ POINT(110 20)
+ </a>
+ <b>
+ LINESTRING(220 220, 20 20, 220 20, 110 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.2-5-3: a point on a non-simple LineString's interior at a vertex [dim(0){A.P.Int = B.nsL.Int.V}]</desc>
+ <a>
+ POINT(20 20)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.2-5-4: a point on a non-simple LineString's interior at a vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
+ <a>
+ POINT(20 110)
+ </a>
+ <b>
+ LINESTRING(20 200, 20 20, 110 20, 20 110, 110 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.3-3-1: a point on a non-simple LineString's start point [dim(0){A.P.Int = B.nsL.Bdy.SP}]</desc>
+ <a>
+ POINT(20 200)
+ </a>
+ <b>
+ LINESTRING(20 200, 200 20, 20 20, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.3-5-1: a point on a non-simple LineString's interior at a non-vertex with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.NVo}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(20 200, 200 20, 140 20, 140 80, 80 140, 20 140)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.3-5-2: a point on a non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.3-5-3: a point on a non-simple LineString's interior at a vertex with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vb}]</desc>
+ <a>
+ POINT(80 140)
+ </a>
+ <b>
+ LINESTRING(20 200, 110 110, 200 20, 140 20, 140 80, 110 110, 80 140, 20 140)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.3-5-4: a point on a non-simple LineString's interior at a two-vertex point with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vo}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.3-5-5: a point on a non-simple LineString's interior at a vertex with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vo}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(20 200, 200 20, 140 20, 140 80, 110 110, 80 140, 20 140)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.3-5-6: a point on a non-simple LineString's interior at a two-vertex point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(20 200, 110 110, 200 20, 20 20, 110 110, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.3-5-7: a point on a non-simple LineString's interior at a vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(20 200, 200 20, 20 20, 110 110, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.3-5-8: a point on a non-simple LineString's interior at a two-vertex point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(20 200, 110 110, 20 20, 200 20, 110 110, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.4-3-1: a point on a non-simple LineString's start point with crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Bdy.SPb}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 110 200, 20 200, 110 110, 200 20, 140 20, 140 80, 110 110, 80 140,
+ 20 140)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.4-3-2: a point on a non-simple LineString's start point with crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Bdy.SPb}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 110 200, 20 200, 200 20, 140 20, 140 80, 110 110, 80 140, 20 140)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.4-3-3:a point on a non-simple LineString's start point with crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Bdy.SPb}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 110 200, 20 200, 200 20, 140 20, 140 80, 80 140, 20 140)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.4-3-4: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 110 200, 20 200, 110 110, 200 20, 20 20, 110 110, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.4-3-5: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 110 200, 20 200, 200 20, 20 20, 110 110, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.4-3-6: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 110 200, 20 200, 200 20, 20 20, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.4-3-7: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 110 200, 20 200, 110 110, 20 20, 200 20, 110 110, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.4-3-8: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 110 200, 20 200, 200 20, 200 110, 110 110, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.5-3-1: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(200 200, 110 110, 20 20, 200 20, 110 110, 20 200, 110 200, 110 110)
+ </b>
+ <test>
+ </test>
+ <test><op name="coveredBy" arg1="A" arg2="B">true</op></test>
+ <test><op name="crosses" arg1="A" arg2="B">false</op></test>
+ <test><op name="disjoint" arg1="A" arg2="B">false</op></test>
+</case>
+<case>
+<desc>P/nsL.5-3-2: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+ <test><op name="intersects" arg1="A" arg2="B">true</op></test>
+ <test><op name="overlaps" arg1="A" arg2="B">false</op></test>
+</case>
+<case>
+<desc>P/nsL.5-3-3: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(200 200, 20 20, 200 20, 20 200, 110 200, 110 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.5-3-4: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(200 200, 110 110, 200 20, 20 20, 110 110, 20 200, 110 200, 110 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.5-3-5: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(200 200, 20 20, 20 110, 110 110, 20 200, 110 200, 110 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.6-3-1: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
+ <a>
+ POINT(110 160)
+ </a>
+ <b>
+ LINESTRING(110 160, 200 250, 110 250, 110 160, 110 110, 110 20, 20 20, 110 110)
+ </b>
+ <test>
+ </test>
+ <test><op name="contains" arg1="A" arg2="B">false</op></test>
+ <test><op name="covers" arg1="A" arg2="B">false</op></test>
+</case>
+<case>
+<desc>P/nsL.6-3-2: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
+ <a>
+ POINT(110 160)
+ </a>
+ <b>
+ LINESTRING(110 160, 200 250, 110 250, 110 110, 110 20, 20 20, 110 110)
+ </b>
+ <test>
+ </test>
+ <test><op name="equalsTopo" arg1="A" arg2="B">false</op></test>
+ <test><op name="within" arg1="A" arg2="B">false</op></test>
+</case>
+<case>
+<desc>P/nsL.6-3-3: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+ <test><op name="touches" arg1="A" arg2="B">true</op></test>
+</case>
+<case>
+<desc>P/nsL.6-3-4: a point on a non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 160, 200 250, 110 250, 110 160, 110 20, 20 20, 110 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.7-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 200 200, 110 200, 110 110, 110 20, 20 20, 110 110)
+ </b>
+ <test>
+ </test>
+ <test><op name="touches" arg1="A" arg2="B">false</op></test>
+ <test><op name="within" arg1="A" arg2="B">true</op></test>
+</case>
+<case>
+<desc>P/nsL.7-5-2: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 200 200, 110 200, 110 20, 20 20, 110 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.7-5-3: a point on a closed non-simple LineString's interior at a non-vertex [dim(0){A.P.Int = B.nsL.Int.NV}]</desc>
+ <a>
+ POINT(140 200)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.7-5-4: a point on a closed non-simple LineString's interior at a vertex [dim(0){A.P.Int = B.nsL.Int.V}]</desc>
+ <a>
+ POINT(110 200)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.8-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 200 200, 110 200, 110 110, 110 20, 200 20, 110 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.8-5-2: a point on the interior (at a non-vertex) of a closed non-simple LineString [dim(0){A.P.Int = B.nsL.Int.NV}]</desc>
+ <a>
+ POINT(140 200)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.8-5-3: a point on a closed non-simple LineString's interior at a vertex [dim(0){A.P.Int = B.nsL.Int.V}]</desc>
+ <a>
+ POINT(110 200)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.9-3-1: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
+ <a>
+ POINT(90 130)
+ </a>
+ <b>
+ LINESTRING(90 130, 20 130, 20 200, 90 130, 200 20, 20 20, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.9-5-1: a point on a non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.10-3-1: a point on a non-simple LineString's start point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
+ <a>
+ POINT(90 130)
+ </a>
+ <b>
+ LINESTRING(90 130, 20 130, 20 200, 200 20, 20 20, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.10-5-1: a point on a non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.11-3-1: a point on a closed non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.EPx}]</desc>
+ <a>
+ POINT(90 130)
+ </a>
+ <b>
+ LINESTRING(200 200, 20 20, 200 20, 90 130, 20 200, 20 130, 90 130)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.11-5-1: a point on a closed non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.12-3-1: a point on a closed non-simple LineString's end point with crossing line segments [dim(0){A.P.Int = B.nsL.Bdy.SPx}]</desc>
+ <a>
+ POINT(90 130)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.12-5-1: a point on a closed non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.13-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 20 130, 20 200, 110 110, 200 20, 20 20, 110 110, 200 200, 200 130,
+ 110 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.13-5-2: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 20 130, 20 200, 200 20, 20 20, 200 200, 200 130, 110 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.14-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 80 200, 20 200, 110 110, 200 20, 20 20, 110 110, 200 200, 140 200,
+ 110 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.14-5-2: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(110 110, 80 200, 20 200, 200 20, 20 20, 200 200, 140 200, 110 110)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.15-5-1: a point on a closed non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(200 200, 20 20, 200 20, 20 200, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.15-5-2: a point on a closed non-simple LineString's interior at a vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(200 200, 110 110, 20 20, 200 20, 110 110, 20 200, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.15-5-3: a point on a closed non-simple LineString's interior at a vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.Vx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ LINESTRING(200 200, 110 110, 200 20, 20 20, 110 110, 20 200, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.16-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
+ <a>
+ POINT(90 130)
+ </a>
+ <b>
+ LINESTRING(90 130, 20 130, 20 200, 90 130, 110 110, 200 20, 20 20, 110 110, 200 200,
+ 90 130)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.16-5-2: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
+ <a>
+ POINT(90 130)
+ </a>
+ <b>
+ LINESTRING(90 130, 20 130, 20 200, 110 110, 200 20, 20 20, 110 110, 200 200, 90 130)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.17-5-1: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
+ <a>
+ POINT(90 130)
+ </a>
+ <b>
+ LINESTRING(90 130, 90 200, 20 200, 90 130, 110 110, 200 20, 20 20, 110 110, 200 200,
+ 90 130)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.17-5-2: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
+ <a>
+ POINT(90 130)
+ </a>
+ <b>
+ LINESTRING(90 130, 90 200, 20 200, 200 20, 20 20, 200 200, 90 130)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.17-5-3: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
+ <a>
+ POINT(90 130)
+ </a>
+ <b>
+ LINESTRING(90 130, 90 200, 20 200, 110 110, 200 20, 20 20, 110 110, 200 200, 90 130)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.17-5-4: a point on a closed non-simple LineString's closing point with crossing line segments [dim(0){A.P.Int = B.nsL.Int.CPx}]</desc>
+ <a>
+ POINT(90 130)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.17-5-5: a point on a closed non-simple LineString's interior at a non-vertex with crossing line segments [dim(0){A.P.Int = B.nsL.Int.NVx}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.18-5-1: a point on a non-simple LineString's start point with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Bdy.SPb)}]</desc>
+ <a>
+ POINT(110 200)
+ </a>
+ <b>
+ LINESTRING(110 200, 110 110, 20 20, 200 20, 110 110, 110 200, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.18-5-2: a point on a non-simple LineString's interior at a non-vertex with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.NVo}]</desc>
+ <a>
+ POINT(110 150)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.18-5-3: a point on a non-simple LineString's interior at a vertex with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vb}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.19-5-1: a point on a non-simple LineString's closing point with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.CPo}]</desc>
+ <a>
+ POINT(110 200)
+ </a>
+ <b>
+ LINESTRING(110 200, 110 110, 20 20, 200 20, 110 110, 110 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.19-5-2: a point on a non-simple LineString's interior at a non-vertex overlapping line segments [dim(0){A.P.Int = B.nsL.Int.NVo}]</desc>
+ <a>
+ POINT(110 150)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.19-5-3: a point on a non-simple LineString interior at a vertex with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vb}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.20-5-1: a point on a non-simple LineString's interior at a non-vertex with overlapping line segments [dim(0){A.P.Int = B.nsL.Int.NVo}]</desc>
+ <a>
+ POINT(110 150)
+ </a>
+ <b>
+ LINESTRING(20 200, 110 200, 110 110, 20 20, 200 20, 110 110, 110 200, 200 200)
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsL.20-5-2: a point on a non-simple LineString's interior at a vertex with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vb}]</desc>
+ <a>
+ POINT(110 110)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/nsl.20-5-3: a point on a non-simple LineString's interior at a vertex with both crossing and overlapping line segments [dim(0){A.P.Int = B.nsL.Int.Vb}]</desc>
+ <a>
+ POINT(110 200)
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/L-2-1: MultiPoint and a line disjoint (points on one side of the line) [dim(0){A.3P.Int = B.L.Ext}]</desc>
+ <a>
+ MULTIPOINT((50 250), (90 220), (130 190))
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+ <test><op name="coveredBy" arg1="A" arg2="B">false</op></test>
+ <test><op name="disjoint" arg1="A" arg2="B">true</op></test>
+ <test><op name="intersects" arg1="A" arg2="B">false</op></test>
+</case>
+<case>
+<desc>mP/L-2-2: MultiPoint and a line disjoint (points over the line but no intersection) [dim(0){A.3P.Int = B.L.Ext}]</desc>
+ <a>
+ MULTIPOINT((180 180), (230 130), (280 80))
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/L-3-1: one of the points intersecting the start point of a line [dim(0){A.3P2.Int = B.L.Bdy.SP}]</desc>
+ <a>
+ MULTIPOINT((50 120), (90 80), (130 40))
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="F00FFF102">true</op>
+ </test>
+</case>
+<case>
+<desc>mP/L-3-2: one of the points intersecting the end point of a line [dim(0){A.3P2 = B.L.Bdy.EP}]</desc>
+ <a>
+ MULTIPOINT((300 280), (340 240), (380 200))
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/L-4-1: one of the points intersecting the interior of a line at a non-vertex (points on one side of the line) [dim(0){A.3P1.Int = B.L.Int.NV]</desc>
+ <a>
+ MULTIPOINT((230 150), (260 120), (290 90))
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0F0FFF102">true</op>
+ </test>
+</case>
+<case>
+<desc>mP/L-4-2: one of the points intersecting the interior of a line at a non-vertex (points over the line) [dim(0){A.3P2.Int = B.L.Int.NV]</desc>
+ <a>
+ MULTIPOINT((200 190), (240 150), (270 110))
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/L-4-3: one of the points intersecting the interior of a line at a vertex (points on one side of the line) [dim(0){A.3P1.Int = B.L.Int.V]</desc>
+ <a>
+ MULTIPOINT((160 150), (190 120), (220 90))
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/L-4-4: one of the points intersecting the interior of a line at a vertex (points over the line) [dim(0){A.3P2.Int = B.L.Int.V]</desc>
+ <a>
+ MULTIPOINT((120 190), (160 150), (200 110))
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/L-5-1: all the points on a line [dim(0){A.3P1.Int = B.L.Bdy.SP}, dim(0){A.3P2.Int = B.L.Int.V}, dim(0){A.3P3.Int = B.Bdy.EP}]</desc>
+ <a>
+ MULTIPOINT((90 80), (160 150), (340 240))
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="00FFFF1F2">true</op>
+ </test>
+</case>
+<case>
+<desc>mP/L-5-2: all the points on a line [dim(0){A.3P1.Int = B.L.Bdy.SP}, dim(0){A.3P2.Int = B.L.Int.V}, dim(0){A.3P3.Int = B.Int.V}]</desc>
+ <a>
+ MULTIPOINT((90 80), (160 150), (300 150))
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="00FFFF102">true</op>
+ </test>
+</case>
+<case>
+<desc>mP/L-5-3: all the points on a line [dim(0){A.3P1.Int = B.L.Bdy.SP}, dim(0){A.3P2.Int = B.L.Int.V}, dim(0){A.3P3.Int = B.Int.NV}]</desc>
+ <a>
+ MULTIPOINT((90 80), (160 150), (240 150))
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/L-5-4: all the points on a line [dim(0){A.3P1.Int = B.L.Bdy.SP}, dim(0){A.3P2.Int = B.L.Int.NV}, dim(0){A.3P3.Int = B.Int.NV}]</desc>
+ <a>
+ MULTIPOINT((90 80), (130 120), (210 150))
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/L-5-5: all the points on a line [dim(0){A.3P1.Int = B.L.Int.NV}, dim(0){A.3P2.Int = B.L.Int.NV}, dim(0){A.3P3.Int = B.Int.NV}]</desc>
+ <a>
+ MULTIPOINT((130 120), (210 150), (340 200))
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/L-5-6: all the points on a line [dim(0){A.3P1.Int = B.L.Int.V}, dim(0){A.3P2.Int = B.L.Int.V}, dim(0){A.3P3.Int = B.Int.NV}]</desc>
+ <a>
+ MULTIPOINT((160 150), (240 150), (340 210))
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/L-5-7: all the points on a line [dim(0){A.3P1.Int = B.L.Int.V}, dim(0){A.3P2.Int = B.L.Int.V}, dim(0){A.3P3.Int = B.Int.V}]</desc>
+ <a>
+ MULTIPOINT((160 150), (300 150), (340 150))
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/L-5-8: all the points on a line [dim(0){A.3P1.Int = B.L.Int.V}, dim(0){A.3P2.Int = B.L.Int.NV}, dim(0){A.3P3.Int = B.Bdy.EP}]</desc>
+ <a>
+ MULTIPOINT((160 150), (240 150), (340 240))
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+</run>
diff --git a/tests/xmltester/tests/validate/TestRelatePP.xml b/tests/xmltester/tests/validate/TestRelatePP.xml
new file mode 100644
index 0000000..847908e
--- /dev/null
+++ b/tests/xmltester/tests/validate/TestRelatePP.xml
@@ -0,0 +1,303 @@
+<run>
+<precisionModel type="FLOATING"/>
+<case>
+<desc>P/P: same point [dim(0){A.P.Int = B.P.Int}]</desc>
+ <a>
+ POINT(20 20)
+ </a>
+ <b>
+ POINT(20 20)
+ </b>
+ <test>
+ </test>
+ <test><op name="contains" arg1="A" arg2="B">true</op></test>
+ <test><op name="covers" arg1="A" arg2="B">true</op></test>
+ <test><op name="equalsTopo" arg1="A" arg2="B">true</op></test>
+</case>
+<case>
+<desc>P/P: different point [dim(0){A.P.Int = B.P.Ext}]</desc>
+ <a>
+ POINT(20 20)
+ </a>
+ <b>
+ POINT(40 60)
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="FF0FFF0F2">true</op>
+ </test>
+</case>
+<case>
+<desc>P/mP: different points [dim(0){A.P.Int = B.3P.Ext}]</desc>
+ <a>
+ POINT(40 40)
+ </a>
+ <b>
+ MULTIPOINT((20 20), (80 80), (20 120))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>P/mP: point A within one of B points [dim(0){A.P.Int = B.3P1.Int}]</desc>
+ <a>
+ POINT(20 20)
+ </a>
+ <b>
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0FFFFF0F2">true</op>
+ </test>
+</case>
+<case>
+<desc>mP/mP-1-1: same points [dim(0){A.3P1.Int = B.3P1.Int}, dim(0){A.3P2.Int = B.3P2.Int}, dim(0){A.3P3.Int = B.3P3.Int}]</desc>
+ <a>
+ MULTIPOINT((40 40), (80 60), (120 100))
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/mP-1-2: same but different sequence of points [dim(0){A.3P1.Int = B.3P1.Int}, dim(0){A.3P1.Int = B.3P3.Int}, dim(0){A.3P3.Int = B.3P2.Int}]</desc>
+ <a>
+ </a>
+ <b>
+ MULTIPOINT((40 40), (120 100), (80 60))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/mP-2: different points [dim(0){A.4P.Int = B.4P.Ext}]</desc>
+ <a>
+ MULTIPOINT((40 40), (60 100), (100 60), (120 120))
+ </a>
+ <b>
+ MULTIPOINT((20 120), (60 60), (100 100), (140 40))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/mP-5-1: same points [dim(0){A.4P.Int = B.4P.Int}]</desc>
+ <a>
+ MULTIPOINT((20 20), (80 70), (140 120), (200 170))
+ </a>
+ <b>
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/mP-5-2: same points but different sequence [dim(0){A.4P.Int = B.4P.Int}]</desc>
+ <a>
+ MULTIPOINT((20 20), (140 120), (80 70), (200 170))
+ </a>
+ <b>
+ MULTIPOINT((80 70), (20 20), (200 170), (140 120))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/mP-5-3: some points same [dim(0){A.4P2.Int = B.2P1.Int}, dim(0){A.4P3.Int = B.2P2.Int}]</desc>
+ <a>
+ </a>
+ <b>
+ MULTIPOINT((80 70), (140 120))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0F0FFFFF2">true</op>
+ </test>
+</case>
+<case>
+<desc>mP/mP-5-4: some points same, in a different sequence [dim(0){A.4P1.Int = B.2P2.Int}, dim(0){A.4P4.Int = B.2P1.Int}]</desc>
+ <a>
+ MULTIPOINT((80 70), (20 200), (200 170), (140 120))
+ </a>
+ <b>
+ MULTIPOINT((140 120), (80 70))
+ </b>
+ <test>
+ </test>
+</case>
+<case>
+<desc>mP/mP-6-1: some points same, some different [dim(0){A.4P4.Int = B.3P2.Int}]</desc>
+ <a>
+ </a>
+ <b>
+ MULTIPOINT((80 170), (140 120), (200 80))
+ </b>
+ <test>
+ <op name="relate" arg1="A" arg2="B" arg3="0F0FFF0F2">true</op>
+ </test>
+ <test><op name="overlaps" arg1="A" arg2="B">true</op></test>
+</case>
+<case>
+<desc>mP/mP-6-2: dim(0){A.4P1.Int = B.4P4.Int}, dim(0){A.4P4.Int = B.4P2.Int}</desc>
+ <a>
+ </a>
+ <b>
+ MULTIPOINT((80 170), (140 120), (200 80), (80 70))
+ </b>
+ <test>
+ </test>
+</case>
+</run>
Summary of changes:
tests/xmltester/CMakeLists.txt | 9 +
tests/xmltester/Makefile.am | 104 +-
tests/xmltester/XMLTester.cpp | 72 +
.../xmltester/tests/validate/TestRelateAA-big.xml | 34 +
tests/xmltester/tests/validate/TestRelateAA.xml | 2833 ++++++++++++++++
tests/xmltester/tests/validate/TestRelateAC.xml | 36 +
tests/xmltester/tests/validate/TestRelateLA.xml | 1932 +++++++++++
tests/xmltester/tests/validate/TestRelateLC.xml | 57 +
tests/xmltester/tests/validate/TestRelateLL.xml | 3388 ++++++++++++++++++++
tests/xmltester/tests/validate/TestRelatePA.xml | 1018 ++++++
tests/xmltester/tests/validate/TestRelatePL.xml | 2286 +++++++++++++
tests/xmltester/tests/validate/TestRelatePP.xml | 303 ++
12 files changed, 12025 insertions(+), 47 deletions(-)
create mode 100644 tests/xmltester/tests/validate/TestRelateAA-big.xml
create mode 100644 tests/xmltester/tests/validate/TestRelateAA.xml
create mode 100644 tests/xmltester/tests/validate/TestRelateAC.xml
create mode 100644 tests/xmltester/tests/validate/TestRelateLA.xml
create mode 100644 tests/xmltester/tests/validate/TestRelateLC.xml
create mode 100644 tests/xmltester/tests/validate/TestRelateLL.xml
create mode 100644 tests/xmltester/tests/validate/TestRelatePA.xml
create mode 100644 tests/xmltester/tests/validate/TestRelatePL.xml
create mode 100644 tests/xmltester/tests/validate/TestRelatePP.xml
hooks/post-receive
More information about the geos-commits
