[geos-commits] [SCM] GEOS branch master updated. b5eb5cd30df17480a55d81e8c087049d03c13ef3
Fri Nov 30 10:17:50 PST 2018
the project "GEOS".
       via  b5eb5cd30df17480a55d81e8c087049d03c13ef3 (commit)
      from  52aba2ca24177acc5ceecbcfb8e47d41d45c034b (commit)
revisions in full, below.
commit b5eb5cd30df17480a55d81e8c087049d03c13ef3
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Nov 30 10:17:26 2018 -0800
    Add TestEqualsExact.xml and update XMLTester
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index 2f3e299..f9004ab 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -69,6 +69,7 @@ if(GEOS_ENABLE_TESTS)
     ${XMLTESTS_DIR}/general/TestConvexHull-big.xml
     ${XMLTESTS_DIR}/general/TestConvexHull.xml
     ${XMLTESTS_DIR}/general/TestDistance.xml
+    ${XMLTESTS_DIR}/general/TestEqualsExact.xml
     ${XMLTESTS_DIR}/general/TestFunctionAA.xml
     ${XMLTESTS_DIR}/general/TestFunctionAAPrec.xml
     ${XMLTESTS_DIR}/general/TestFunctionLA.xml
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index e38f00b..5a01f1b 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -37,6 +37,7 @@ SAFE_XMLTESTS= \
 	$(srcdir)/tests/general/TestConvexHull-big.xml \
 	$(srcdir)/tests/general/TestConvexHull.xml \
 	$(srcdir)/tests/general/TestDistance.xml \
+	$(srcdir)/tests/general/TestEqualsExact.xml \
 	$(srcdir)/tests/general/TestFunctionAA.xml \
 	$(srcdir)/tests/general/TestFunctionAAPrec.xml \
 	$(srcdir)/tests/general/TestFunctionLA.xml \
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 3ad7e53..624de71 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -1051,6 +1051,34 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
             if (actual_result==opRes) success=1;
+        else if (opName=="equalsexact")
+            geom::Geometry *g1 = opArg1 == "B" ? gB : gA;
+            geom::Geometry *g2 = opArg2 == "B" ? gB : gA;
+            actual_result="false";
+            if (g1->equalsExact(g2)) actual_result="true";
+            if (actual_result==opRes) success=1;
+        // rather than implementing equalsnorm in the library,
+        // we just do it in this one test case for now
+        else if (opName=="equalsnorm")
+            g1->normalize();
+            g2->normalize();
         else if (opName=="coveredby")
diff --git a/tests/xmltester/tests/general/TestEqualsExact.xml b/tests/xmltester/tests/general/TestEqualsExact.xml
new file mode 100644
index 0000000..d5d0380
--- /dev/null
+++ b/tests/xmltester/tests/general/TestEqualsExact.xml
@@ -0,0 +1,157 @@
+<run>
+<description>
+Tests of exact equality and exact equality with normalization
+</description>
+<case>
+  <desc>P - point</desc>
+  <a>    POINT(10 10)  </a>
+  <b>    POINT(10 10)  </b>
+<test><op name="equalsExact" arg1="A" arg2="B">    true  </op></test>
+</case>
+<case>
+  <b>    POINT(10 11)  </b>
+<test><op name="equalsExact" arg1="A" arg2="B">    false  </op></test>
+</case>
+<case>
+  <desc>mP - MultiPoint</desc>
+  <a>    MULTIPOINT((10 10), (20 20))  </a>
+  <b>    MULTIPOINT((10 10), (20 20))  </b>
+</case>
+<case>
+  <desc>mP - MultiPoint, permuted</desc>
+  <b>    MULTIPOINT((20 20), (10 10))  </b>
+<test><op name="equalsNorm"  arg1="A" arg2="B">    true  </op></test>
+</case>
+<case>
+  <desc>mP - MultiPoint empty</desc>
+  <a>    MULTIPOINT EMPTY </a>
+  <b>    MULTIPOINT EMPTY </b>
+</case>
+<case>
+  <desc>L - Line</desc>
+  <a>    LINESTRING(10 10, 20 20, 30 30)  </a>
+  <b>    LINESTRING(10 10, 20 20, 30 30)  </b>
+</case>
+<case>
+  <desc>L - Line, permuted</desc>
+  <b>    LINESTRING(30 30, 20 20, 10 10)  </b>
+</case>
+<case>
+  <desc>L - closed</desc>
+  <a>    LINESTRING(10 10, 20 20, 20 10, 10 10)  </a>
+  <b>    LINESTRING(10 10, 20 20, 20 10, 10 10)  </b>
+</case>
+<case>
+  <desc>L - empty</desc>
+  <a>    LINESTRING EMPTY  </a>
+  <b>    LINESTRING EMPTY  </b>
+</case>
+<case>
+  <desc>mL - 2 lines with common endpoint</desc>
+  <a> MULTILINESTRING(
+      (10 10, 20 20),
+      (20 20, 30 30)) </a>
+  <b> MULTILINESTRING(
+      (10 10, 20 20),
+      (20 20, 30 30)) </b>
+</case>
+<case>
+  <desc>mL - 2 lines with common endpoint, permuted</desc>
+      (10 10, 20 20),
+      (30 30, 20 20),
+      (10 10, 20 20)) </b>
+</case>
+<case>
+  <desc>A - polygon with no holes</desc>
+  <a>  POLYGON((40 60, 420 60, 420 320, 40 320, 40 60))  </a>
+  <b>  POLYGON((40 60, 420 60, 420 320, 40 320, 40 60))  </b>
+</case>
+<case>
+  <desc>A - polygon with no holes, permuted</desc>
+  <b>  POLYGON((420 60, 420 320, 40 320, 40 60, 420 60))  </b>
+</case>
+<case>
+  <desc>A - polygon with 1 hole</desc>
+  <a>
+    POLYGON(
+      (40 60, 420 60, 420 320, 40 320, 40 60),
+      (200 140, 160 220, 260 200, 200 140))
+  </a>
+  <b>
+    POLYGON(
+  </b>
+</case>
+<case>
+  <desc>A - empty</desc>
+  <a>    POLYGON EMPTY  </a>
+  <b>    POLYGON EMPTY  </b>
+</case>
+<case>
+  <desc>mA</desc>
+  <a>    MULTIPOLYGON (((50 100, 100 100, 100 50, 50 50, 50 100)), ((150 100, 200 100, 200 50, 150 50, 150 100)))  </a>
+  <b>    MULTIPOLYGON (((50 100, 100 100, 100 50, 50 50, 50 100)), ((150 100, 200 100, 200 50, 150 50, 150 100)))  </b>
+</case>
+<case>
+  <desc>mA - permuted</desc>
+  <b>    MULTIPOLYGON (((150 100, 200 100, 200 50, 150 50, 150 100)), ((50 100, 100 100, 100 50, 50 50, 50 100)))  </b>
+</case>
+<case>
+  <desc>mA - empty</desc>
+  <a>    MULTIPOLYGON EMPTY  </a>
+  <b>    MULTIPOLYGON EMPTY  </b>
+</case>
+</run>
Summary of changes:
 tests/xmltester/CMakeLists.txt                    |   1 +
 tests/xmltester/Makefile.am                       |   1 +
 tests/xmltester/XMLTester.cpp                     |  28 ++++
 tests/xmltester/tests/general/TestEqualsExact.xml | 157 ++++++++++++++++++++++
 4 files changed, 187 insertions(+)
 create mode 100644 tests/xmltester/tests/general/TestEqualsExact.xml
hooks/post-receive
More information about the geos-commits mailing list
