[geos-commits] [SCM] GEOS branch 3.7 updated. 34cdf0252cd9ffd202f68faf94908860f5762461
Sun Sep 2 19:16:00 PDT 2018
the project "GEOS".
The branch, 3.7 has been updated
       via  34cdf0252cd9ffd202f68faf94908860f5762461 (commit)
      from  db3e7a7350e29b96255e34295f8771dd3fb80eee (commit)
revisions in full, below.
commit 34cdf0252cd9ffd202f68faf94908860f5762461
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Sep 2 22:15:59 2018 -0400
    Take out failing test on FreeBSD/macOS Clang. References #894
    Will revisit in 3.8
diff --git a/tests/unit/capi/GEOSGeomFromWKBTest.cpp b/tests/unit/capi/GEOSGeomFromWKBTest.cpp
index bc5298f..6575dee 100644
--- a/tests/unit/capi/GEOSGeomFromWKBTest.cpp
+++ b/tests/unit/capi/GEOSGeomFromWKBTest.cpp
@@ -81,19 +81,21 @@ namespace tut
     // Test Cases
-		/** TODO: Put this back after
-		 * We figure out why it fails on some Clang platforms
-		 * See https://trac.osgeo.org/geos/ticket/894 for details
-/*     template<>
+    template<>
     template<>
     void object::test<1>()
         // POINT(1.234 5.678)
         std::string wkt("POINT (1.234 5.678)");
-        std::string wkb("01010000005839B4C876BEF33F83C0CAA145B61640");
-        test_wkb(wkb, wkt);
+				std::string ewkb("01010000005839B4C876BEF33F83C0CAA145B61640");
+				test_wkb(ewkb, wkt);
+			/** TODO: Put this back after
+			 * We figure out why it fails on some Clang platforms
+			 * See https://trac.osgeo.org/geos/ticket/894 for details
+        //std::string wkb("01010000005839B4C876BEF33F83C0CAA145B61640");
+        //test_wkb(wkb, wkt);
     template<>
     template<>
Summary of changes:
 tests/unit/capi/GEOSGeomFromWKBTest.cpp | 18 ++++++++++--------
 1 file changed, 10 insertions(+), 8 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
