[geos-commits] [SCM] GEOS branch master updated. 04e07b0338860081c3b24073c6e76b832a917a02
Fri Apr 12 12:21:40 PDT 2019
the project "GEOS".
       via  04e07b0338860081c3b24073c6e76b832a917a02 (commit)
      from  a276208d4e887895ce841f76d5a71131d7f49cc1 (commit)
revisions in full, below.
commit 04e07b0338860081c3b24073c6e76b832a917a02
Author: Martin Davis <mtnclimb at gmail.co>
Date:   Fri Apr 12 12:21:26 2019 -0700
    Add XMLTester time output for -v
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 3b65168..e214278 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -367,24 +367,26 @@ XMLTester::printTest(bool success, const std::string& expected_result, const std
         std::cout << ": " << (success ? "ok." : "failed.");
         std::cout << " (" << std::setprecision(15) << java_math_round(prof.getTot() / 1000) << " ms)" << std::endl;
-        std::cout << "\tDescription: " << curr_case_desc << std::endl;
+        // print geometry etc for -v -v and above
+        if (verbose > 1) {
+            std::cout << "\tDescription: " << curr_case_desc << std::endl;
+            if(gA) {
+                std::cout << "\tGeometry A: ";
+                printGeom(std::cout, gA);
+                std::cout << std::endl;
-        if(gA) {
-            std::cout << "\tGeometry A: ";
-            printGeom(std::cout, gA);
-            std::cout << std::endl;
+            if(gB) {
+                std::cout << "\tGeometry B: ";
+                printGeom(std::cout, gB);
-        if(gB) {
-            std::cout << "\tGeometry B: ";
-            printGeom(std::cout, gB);
+            std::cout << "\tExpected result: " << expected_result << std::endl;
+            std::cout << "\tObtained result: " << actual_result << std::endl;
-        std::cout << "\tExpected result: " << expected_result << std::endl;
-        std::cout << "\tObtained result: " << actual_result << std::endl;
@@ -936,6 +938,8 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
         else if(opName == "union") {
             GeomPtr gRes(parseGeometry(opRes, "expected"));
+            profile.start();
             GeomPtr gRealRes;
             if(gB) {
 #ifndef USE_BINARYOP
@@ -948,6 +952,8 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
                 gRealRes = gA->Union();
+            profile.stop();
             success = checkOverlaySuccess(*gRes, *gRealRes);
             actual_result = printGeom(gRealRes.get());
@@ -1831,7 +1837,7 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
         ++failed;
-    if((!success && verbose) || verbose > 1) {
+    if((!success && verbose) || verbose > 0) {
         printTest(!!success, expected_result, actual_result, profile);
Summary of changes:
 tests/xmltester/XMLTester.cpp | 34 ++++++++++++++++++++--------------
 1 file changed, 20 insertions(+), 14 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
