[geos-commits] [SCM] GEOS branch master updated. 859dc941be742e2b0c58dcf2395285dfc5e2e71f
Fri Apr 12 15:36:04 PDT 2019
the project "GEOS".
       via  859dc941be742e2b0c58dcf2395285dfc5e2e71f (commit)
      from  1b24aed3c5ef4f972dd46ca46b6b389d02f38136 (commit)
revisions in full, below.
commit 859dc941be742e2b0c58dcf2395285dfc5e2e71f
Author: Martin Davis <mtnclimb at gmail.co>
Date:   Fri Apr 12 15:36:00 2019 -0700
    Reverting problematic fix for CascadedPolygonUnion
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index 70572d6..a456095 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -273,7 +273,7 @@ CascadedPolygonUnion::unionUsingEnvelopeIntersection(geom::Geometry* g0,
     check_valid(*g1Int, "unionUsingEnvelopeIntersection g1Int");
 #endif
-    std::unique_ptr<geom::Geometry> unionCommon(unionActual(g0Int.get(), g1Int.get()));
+    std::unique_ptr<geom::Geometry> u(unionActual(g0Int.get(), g1Int.get()));
 #if GEOS_DEBUG_CASCADED_UNION
     if(! check_valid(*u, "unionUsingEnvelopeIntersection unionActual return")) {
@@ -291,7 +291,7 @@ CascadedPolygonUnion::unionUsingEnvelopeIntersection(geom::Geometry* g0,
 #endif
     if(disjointPolys.empty()) {
-        return unionCommon.release();
+        return u.release();
@@ -302,39 +302,30 @@ CascadedPolygonUnion::unionUsingEnvelopeIntersection(geom::Geometry* g0,
 #endif
-    geom::Envelope const* unionCommonEnv = unionCommon->getEnvelopeInternal(); // TODO: check for EMPTY ?
+    // TODO: find, in disjointPolys, those which now have their
+    // environment intersect the environment of the union "u"
+    // and collect them in another vector to be unioned
     std::vector<geom::Geometry*> polysOn;
     std::vector<geom::Geometry*> polysOff;
-    extractByEnvelope(*unionCommonEnv, disjointPolys, polysOn, polysOff);
+    geom::Envelope const* uEnv = u->getEnvelopeInternal(); // TODO: check for EMPTY ?
+    extractByEnvelope(*uEnv, disjointPolys, polysOn, polysOff);
     std::cerr << "unionUsingEnvelopeIntersection: " << polysOn.size() << "/" << disjointPolys.size() <<
               " polys intersect union of final thing" << std::endl;
 #endif
-    // If the union of the interacting geometries
-    // is contained in the envelope of the inputs
-    // (and this is highly likely unless overlay robustness failure occurs)
-    // it is safe to combine with the disjoint polygons
-    geom::Envelope beforeUnionEnv( *(g0Int->getEnvelopeInternal()) );
-    beforeUnionEnv.expandToInclude( g1Int->getEnvelopeInternal() );
-    bool isUnionSafe = beforeUnionEnv.contains(unionCommonEnv);
-    //if (! isUnionSafe) std::cerr << "Found unsafe union" << std::endl;
     std::unique_ptr<geom::Geometry> ret;
-    if(polysOn.empty() || isUnionSafe) {
-        disjointPolys.push_back(unionCommon.get());
+    if(polysOn.empty()) {
+        disjointPolys.push_back(u.get());
         ret.reset(geom::util::GeometryCombiner::combine(disjointPolys));
     else {
-        // The union envelope changed (e.g. due to snapping heuristics)
-        // so to be safe must union everything (which is slow, but infrequent)
         // TODO: could be further tweaked to only union with polysOn
         //       and combine with polysOff, but then it'll need again to
         //       recurse in the check for disjoint/intersecting
-        std::unique_ptr<geom::Geometry> disjointCombined( geom::util::GeometryCombiner::combine(disjointPolys) );
-        ret.reset( unionActual( disjointCombined.get(), unionCommon.get() ) );
+        ret.reset(geom::util::GeometryCombiner::combine(disjointPolys));
+        ret.reset(unionActual(ret.get(), u.get()));
Summary of changes:
 src/operation/union/CascadedPolygonUnion.cpp | 31 ++++++++++------------------
 1 file changed, 11 insertions(+), 20 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
