[geos-commits] [SCM] GEOS branch master updated. f90b1db9336c440354344c4bca0ae7bab7662800
Tue Aug 27 07:42:23 PDT 2019
the project "GEOS".
       via  f90b1db9336c440354344c4bca0ae7bab7662800 (commit)
       via  81451a44c31eb5045b6026942051312130886bfe (commit)
      from  395ebff81baf36176fbd529b32cacd4c76927d53 (commit)
revisions in full, below.
commit f90b1db9336c440354344c4bca0ae7bab7662800
Merge: 395ebff 81451a4
Author: Daniel Baston <dbaston at gmail.com>
Date:   Tue Aug 27 10:40:40 2019 -0400
    Merge remote-tracking branch 'origin/trac-584'
commit 81451a44c31eb5045b6026942051312130886bfe
Date:   Sat Aug 24 21:31:47 2019 -0400
    Add envelope test to Distance::segmentToSegment
    JTS commit r652
    Fixes Trac #584
diff --git a/src/algorithm/Distance.cpp b/src/algorithm/Distance.cpp
index f55a3df..8a88a82 100644
--- a/src/algorithm/Distance.cpp
+++ b/src/algorithm/Distance.cpp
@@ -21,6 +21,7 @@
 #include <algorithm>
 #include <geos/algorithm/Distance.h>
+#include <geos/geom/Envelope.h>
 #include <geos/util/IllegalArgumentException.h>
 namespace geos {
@@ -142,21 +143,29 @@ Distance::segmentToSegment(const geom::Coordinate& A,
         If the numerator in eqn 1 is also zero, AB & CD are collinear.
-    double r_top = (A.y - C.y) * (D.x - C.x) - (A.x - C.x) * (D.y - C.y);
-    double r_bot = (B.x - A.x) * (D.y - C.y) - (B.y - A.y) * (D.x - C.x);
-    double s_top = (A.y - C.y) * (B.x - A.x) - (A.x - C.x) * (B.y - A.y);
-    double s_bot = (B.x - A.x) * (D.y - C.y) - (B.y - A.y) * (D.x - C.x);
+    bool noIntersection = false;
-    if((r_bot == 0) || (s_bot == 0)) {
-        return std::min(pointToSegment(A, C, D),
-                        std::min(pointToSegment(B, C, D),
-                                 std::min(pointToSegment(C, A, B), pointToSegment(D, A, B))));
+    if (!geom::Envelope::intersects(A, B, C, D)) {
+        noIntersection = true;
+    } else {
+        double denom = (B.x - A.x) * (D.y - C.y) - (B.y - A.y) * (D.x - C.x);
-    double s = s_top / s_bot;
-    double r = r_top / r_bot;
+        if (denom == 0) {
+        } else {
+            double r_num = (A.y - C.y) * (D.x - C.x) - (A.x - C.x) * (D.y - C.y);
+            double s_num = (A.y - C.y) * (B.x - A.x) - (A.x - C.x) * (B.y - A.y);
+            double s = s_num / denom;
+            double r = r_num / denom;
+            if ((r < 0) || (r > 1) || (s < 0) || (s > 1)) {
-    if((r < 0) || (r > 1) || (s < 0) || (s > 1)) {
+    if (noIntersection) {
         /* no intersection */
diff --git a/tests/unit/operation/distance/DistanceOpTest.cpp b/tests/unit/operation/distance/DistanceOpTest.cpp
index b7893ff..342a310 100644
--- a/tests/unit/operation/distance/DistanceOpTest.cpp
+++ b/tests/unit/operation/distance/DistanceOpTest.cpp
@@ -554,6 +554,17 @@ void object::test<20>()
     ensure(geos::geom::LineSegment(b0, b1).distance(seq->getAt(1)) < 1e-8);
+// JTS testDisjointCollinearSegments
+template<>
+template<>
+void object::test<21>()
+    auto g1 = wktreader.read("LINESTRING (0.0 0.0, 9.9 1.4)");
+    auto g2 = wktreader.read("LINESTRING (11.88 1.68, 21.78 3.08)");
+    ensure_equals(g1->distance(g2.get()), 1.9996999774966246);
 // TODO: finish the tests by adding:
 // 	LINESTRING - *all*
 // 	MULTILINESTRING - *all*
Summary of changes:
 src/algorithm/Distance.cpp                       | 33 +++++++++++++++---------
 tests/unit/operation/distance/DistanceOpTest.cpp | 11 ++++++++
 2 files changed, 32 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
