[geos-commits] [SCM] GEOS branch master updated. 21f1c673694f3a76390a323eae37d285599bc532
Tue Feb 5 14:49:01 PST 2019
the project "GEOS".
       via  21f1c673694f3a76390a323eae37d285599bc532 (commit)
      from  5e13295f74e375bc6c56b44f35f3593dd89b0e5e (commit)
revisions in full, below.
commit 21f1c673694f3a76390a323eae37d285599bc532
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Feb 5 14:48:46 2019 -0800
    Address build failure on GitLabCI
diff --git a/tools/astyle/astyle_main.cpp b/tools/astyle/astyle_main.cpp
index 96ae075..98dfadf 100755
--- a/tools/astyle/astyle_main.cpp
+++ b/tools/astyle/astyle_main.cpp
@@ -37,27 +37,27 @@
 #include <algorithm>
 #include <cerrno>
-#include <clocale>		// needed by some compilers
+#include <clocale>      // needed by some compilers
 #include <cstdlib>
 #include <fstream>
 #include <sstream>
 // includes for recursive getFileNames() function
 #ifdef _WIN32
-	#undef UNICODE		// use ASCII windows functions
-	#include <windows.h>
+    #undef UNICODE      // use ASCII windows functions
+    #include <windows.h>
 #else
-	#include <dirent.h>
-	#include <unistd.h>
-	#include <sys/stat.h>
-	#ifdef __VMS
-		#include <unixlib.h>
-		#include <rms.h>
-		#include <ssdef.h>
-		#include <stsdef.h>
-		#include <lib$routines.h>
-		#include <starlet.h>
-	#endif /* __VMS */
+    #include <dirent.h>
+    #include <unistd.h>
+    #include <sys/stat.h>
+    #ifdef __VMS
+        #include <unixlib.h>
+        #include <rms.h>
+        #include <ssdef.h>
+        #include <stsdef.h>
+        #include <lib$routines.h>
+        #include <starlet.h>
+    #endif /* __VMS */
 #endif
@@ -67,7 +67,7 @@
 // turn off MinGW automatic file globbing
 // this CANNOT be in the astyle namespace
 #ifndef ASTYLE_LIB
-	int _CRT_glob = 0;
+    int _CRT_glob = 0;
 #endif
@@ -78,20 +78,20 @@ namespace astyle {
 // console build variables
 #ifndef ASTYLE_LIB
-	#ifdef _WIN32
-		char g_fileSeparator = '\\';     // Windows file separator
-		bool g_isCaseSensitive = false;  // Windows IS NOT case sensitive
-	#else
-		char g_fileSeparator = '/';      // Linux file separator
-		bool g_isCaseSensitive = true;   // Linux IS case sensitive
-	#endif	// _WIN32
-#endif	// ASTYLE_LIB
+    #ifdef _WIN32
+        char g_fileSeparator = '\\';     // Windows file separator
+        bool g_isCaseSensitive = false;  // Windows IS NOT case sensitive
+    #else
+        char g_fileSeparator = '/';      // Linux file separator
+        bool g_isCaseSensitive = true;   // Linux IS case sensitive
+    #endif  // _WIN32
+#endif  // ASTYLE_LIB
 // java library build variables
 #ifdef ASTYLE_JNI
-	JNIEnv*   g_env;
-	jobject   g_obj;
-	jmethodID g_mid;
+    JNIEnv*   g_env;
+    jobject   g_obj;
+    jmethodID g_mid;
 #endif
 const char* g_version = "3.1";
@@ -105,18 +105,18 @@ const char* g_version = "3.1";
 template<typename T>
 ASStreamIterator<T>::ASStreamIterator(T* in)
-	inStream = in;
-	buffer.reserve(200);
-	eolWindows = 0;
-	eolLinux = 0;
-	eolMacOld = 0;
-	peekStart = 0;
-	prevLineDeleted = false;
-	checkForEmptyLine = false;
-	// get length of stream
-	inStream->seekg(0, inStream->end);
-	streamLength = inStream->tellg();
-	inStream->seekg(0, inStream->beg);
+    inStream = in;
+    buffer.reserve(200);
+    eolWindows = 0;
+    eolLinux = 0;
+    eolMacOld = 0;
+    peekStart = 0;
+    prevLineDeleted = false;
+    checkForEmptyLine = false;
+    // get length of stream
+    inStream->seekg(0, inStream->end);
+    streamLength = inStream->tellg();
+    inStream->seekg(0, inStream->beg);
@@ -133,7 +133,7 @@ ASStreamIterator<T>::~ASStreamIterator()
 int ASStreamIterator<T>::getStreamLength() const
-	return static_cast<int>(streamLength);
+    return static_cast<int>(streamLength);
@@ -145,92 +145,92 @@ int ASStreamIterator<T>::getStreamLength() const
 string ASStreamIterator<T>::nextLine(bool emptyLineWasDeleted)
-	// verify that the current position is correct
-	assert(peekStart == 0);
-	// a deleted line may be replaced if break-blocks is requested
-	// this sets up the compare to check for a replaced empty line
-	if (prevLineDeleted)
-		checkForEmptyLine = true;
-	if (!emptyLineWasDeleted)
-		prevBuffer = buffer;
-	else
-		prevLineDeleted = true;
-	// read the next record
-	buffer.clear();
-	char ch;
-	inStream->get(ch);
-	while (!inStream->eof() && ch != '\n' && ch != '\r')
-		buffer.append(1, ch);
-	if (inStream->eof())
-		return buffer;
-	int peekCh = inStream->peek();
-	// find input end-of-line characters
-	if (!inStream->eof())
-		if (ch == '\r')         // CR+LF is windows otherwise Mac OS 9
-			if (peekCh == '\n')
-				inStream->get();
-				eolWindows++;
-			else
-				eolMacOld++;
-		else                    // LF is Linux, allow for improbable LF/CR
-			if (peekCh == '\r')
-				inStream->get();
-				eolWindows++;
-			else
-				eolLinux++;
-	else
-		inStream->clear();
-	// has not detected an input end of line
-	if (!eolWindows && !eolLinux && !eolMacOld)
+    // verify that the current position is correct
+    assert(peekStart == 0);
+    // a deleted line may be replaced if break-blocks is requested
+    // this sets up the compare to check for a replaced empty line
+    if (prevLineDeleted)
+        checkForEmptyLine = true;
+    if (!emptyLineWasDeleted)
+        prevBuffer = buffer;
+    else
+        prevLineDeleted = true;
+    // read the next record
+    buffer.clear();
+    char ch;
+    inStream->get(ch);
+    while (!inStream->eof() && ch != '\n' && ch != '\r')
+        buffer.append(1, ch);
+    if (inStream->eof())
+        return buffer;
+    int peekCh = inStream->peek();
+    // find input end-of-line characters
+    if (!inStream->eof())
+        if (ch == '\r')         // CR+LF is windows otherwise Mac OS 9
+            if (peekCh == '\n')
+                inStream->get();
+                eolWindows++;
+            else
+                eolMacOld++;
+        else                    // LF is Linux, allow for improbable LF/CR
+            if (peekCh == '\r')
+                inStream->get();
+                eolWindows++;
+            else
+                eolLinux++;
+    else
+        inStream->clear();
+    // has not detected an input end of line
+    if (!eolWindows && !eolLinux && !eolMacOld)
 #ifdef _WIN32
-		eolWindows++;
+        eolWindows++;
 #else
-		eolLinux++;
+        eolLinux++;
 #endif
-	// set output end of line characters
-	if (eolWindows >= eolLinux)
-		if (eolWindows >= eolMacOld)
-			outputEOL = "\r\n";     // Windows (CR+LF)
-		else
-			outputEOL = "\r";       // MacOld (CR)
-	else if (eolLinux >= eolMacOld)
-		outputEOL = "\n";           // Linux (LF)
-	else
-	return buffer;
+    // set output end of line characters
+    if (eolWindows >= eolLinux)
+        if (eolWindows >= eolMacOld)
+            outputEOL = "\r\n";     // Windows (CR+LF)
+        else
+            outputEOL = "\r";       // MacOld (CR)
+    else if (eolLinux >= eolMacOld)
+        outputEOL = "\n";           // Linux (LF)
+    else
+    return buffer;
 // save the current position and get the next line
@@ -240,89 +240,89 @@ string ASStreamIterator<T>::nextLine(bool emptyLineWasDeleted)
 string ASStreamIterator<T>::peekNextLine()
-	assert(hasMoreLines());
-	string nextLine_;
-	char ch;
-	if (peekStart == 0)
-		peekStart = inStream->tellg();
-		nextLine_.append(1, ch);
-		return nextLine_;
-	// remove end-of-line characters
-		if ((peekCh == '\n' || peekCh == '\r') && peekCh != ch)
-			inStream->get();
-	return nextLine_;
+    assert(hasMoreLines());
+    string nextLine_;
+    char ch;
+    if (peekStart == 0)
+        peekStart = inStream->tellg();
+        nextLine_.append(1, ch);
+        return nextLine_;
+    // remove end-of-line characters
+        if ((peekCh == '\n' || peekCh == '\r') && peekCh != ch)
+            inStream->get();
+    return nextLine_;
 // reset current position and EOF for peekNextLine()
 void ASStreamIterator<T>::peekReset()
-	assert(peekStart != 0);
-	inStream->seekg(peekStart);
-	peekStart = 0;
+    assert(peekStart != 0);
+    inStream->seekg(peekStart);
+    peekStart = 0;
 // save the last input line after input has reached EOF
 void ASStreamIterator<T>::saveLastInputLine()
-	assert(inStream->eof());
+    assert(inStream->eof());
 // return position of the get pointer
 streamoff ASStreamIterator<T>::tellg()
-	return inStream->tellg();
+    return inStream->tellg();
 // check for a change in line ends
 bool ASStreamIterator<T>::getLineEndChange(int lineEndFormat) const
-	assert(lineEndFormat == LINEEND_DEFAULT
-	       || lineEndFormat == LINEEND_WINDOWS
-	       || lineEndFormat == LINEEND_LINUX
-	       || lineEndFormat == LINEEND_MACOLD);
-	bool lineEndChange = false;
-	if (lineEndFormat == LINEEND_WINDOWS)
-		lineEndChange = (eolLinux + eolMacOld != 0);
-	else if (lineEndFormat == LINEEND_LINUX)
-		lineEndChange = (eolWindows + eolMacOld != 0);
-	else if (lineEndFormat == LINEEND_MACOLD)
-		lineEndChange = (eolWindows + eolLinux != 0);
-	else
-		if (eolWindows > 0)
-		else if (eolLinux > 0)
-		else if (eolMacOld > 0)
-	return lineEndChange;
+    assert(lineEndFormat == LINEEND_DEFAULT
+           || lineEndFormat == LINEEND_WINDOWS
+           || lineEndFormat == LINEEND_LINUX
+           || lineEndFormat == LINEEND_MACOLD);
+    bool lineEndChange = false;
+    if (lineEndFormat == LINEEND_WINDOWS)
+        lineEndChange = (eolLinux + eolMacOld != 0);
+    else if (lineEndFormat == LINEEND_LINUX)
+        lineEndChange = (eolWindows + eolMacOld != 0);
+    else if (lineEndFormat == LINEEND_MACOLD)
+        lineEndChange = (eolWindows + eolLinux != 0);
+    else
+        if (eolWindows > 0)
+        else if (eolLinux > 0)
+        else if (eolMacOld > 0)
+    return lineEndChange;
@@ -334,28 +334,28 @@ bool ASStreamIterator<T>::getLineEndChange(int lineEndFormat) const
 ASConsole::ASConsole(ASFormatter& formatterArg) : formatter(formatterArg)
-	errorStream = &cerr;
-	// command line options
-	isRecursive = false;
-	isDryRun = false;
-	noBackup = false;
-	preserveDate = false;
-	isVerbose = false;
-	isQuiet = false;
-	isFormattedOnly = false;
-	ignoreExcludeErrors = false;
-	ignoreExcludeErrorsDisplay = false;
-	useAscii = false;
-	// other variables
-	bypassBrowserOpen = false;
-	hasWildcard = false;
-	filesAreIdentical = true;
-	lineEndsMixed = false;
-	origSuffix = ".orig";
-	mainDirectoryLength = 0;
-	filesFormatted = 0;
-	filesUnchanged = 0;
-	linesOut = 0;
+    errorStream = &cerr;
+    // command line options
+    isRecursive = false;
+    isDryRun = false;
+    noBackup = false;
+    preserveDate = false;
+    isVerbose = false;
+    isQuiet = false;
+    isFormattedOnly = false;
+    ignoreExcludeErrors = false;
+    ignoreExcludeErrorsDisplay = false;
+    useAscii = false;
+    // other variables
+    bypassBrowserOpen = false;
+    hasWildcard = false;
+    filesAreIdentical = true;
+    lineEndsMixed = false;
+    origSuffix = ".orig";
+    mainDirectoryLength = 0;
+    filesFormatted = 0;
+    filesUnchanged = 0;
+    linesOut = 0;
 ASConsole::~ASConsole()
@@ -364,97 +364,97 @@ ASConsole::~ASConsole()
 // rewrite a stringstream converting the line ends
 void ASConsole::convertLineEnds(ostringstream& out, int lineEnd)
-	assert(lineEnd == LINEEND_WINDOWS || lineEnd == LINEEND_LINUX || lineEnd == LINEEND_MACOLD);
-	const string& inStr = out.str();	// avoids strange looking syntax
-	string outStr;						// the converted output
-	int inLength = (int) inStr.length();
-	for (int pos = 0; pos < inLength; pos++)
-		if (inStr[pos] == '\r')
-			if (inStr[pos + 1] == '\n')
-				// CRLF
-				if (lineEnd == LINEEND_CR)
-					outStr += inStr[pos];		// Delete the LF
-					pos++;
-					continue;
-				else if (lineEnd == LINEEND_LF)
-					outStr += inStr[pos + 1];		// Delete the CR
-					pos++;
-					continue;
-				else
-					outStr += inStr[pos];		// Do not change
-					pos++;
-					continue;
-			else
-				// CR
-				if (lineEnd == LINEEND_CRLF)
-					outStr += inStr[pos];		// Insert the CR
-					outStr += '\n';				// Insert the LF
-					continue;
-					continue;
-				else
-					continue;
-		else if (inStr[pos] == '\n')
-			// LF
-				outStr += '\r';				// Insert the CR
-				outStr += inStr[pos];		// Insert the LF
-				continue;
-			else if (lineEnd == LINEEND_CR)
-				continue;
-			else
-				continue;
-		else
-			outStr += inStr[pos];		// Write the current char
-	// replace the stream
-	out.str(outStr);
+    assert(lineEnd == LINEEND_WINDOWS || lineEnd == LINEEND_LINUX || lineEnd == LINEEND_MACOLD);
+    const string& inStr = out.str();    // avoids strange looking syntax
+    string outStr;                      // the converted output
+    int inLength = (int) inStr.length();
+    for (int pos = 0; pos < inLength; pos++)
+        if (inStr[pos] == '\r')
+            if (inStr[pos + 1] == '\n')
+                // CRLF
+                if (lineEnd == LINEEND_CR)
+                    outStr += inStr[pos];       // Delete the LF
+                    pos++;
+                    continue;
+                else if (lineEnd == LINEEND_LF)
+                    outStr += inStr[pos + 1];       // Delete the CR
+                    pos++;
+                    continue;
+                else
+                    outStr += inStr[pos];       // Do not change
+                    pos++;
+                    continue;
+            else
+                // CR
+                if (lineEnd == LINEEND_CRLF)
+                    outStr += inStr[pos];       // Insert the CR
+                    outStr += '\n';             // Insert the LF
+                    continue;
+                    continue;
+                else
+                    continue;
+        else if (inStr[pos] == '\n')
+            // LF
+                outStr += '\r';             // Insert the CR
+                outStr += inStr[pos];       // Insert the LF
+                continue;
+            else if (lineEnd == LINEEND_CR)
+                continue;
+            else
+                continue;
+        else
+            outStr += inStr[pos];       // Write the current char
+    // replace the stream
+    out.str(outStr);
 void ASConsole::correctMixedLineEnds(ostringstream& out)
-	LineEndFormat lineEndFormat = LINEEND_DEFAULT;
-	if (outputEOL == "\r\n")
-		lineEndFormat = LINEEND_WINDOWS;
-	if (outputEOL == "\n")
-		lineEndFormat = LINEEND_LINUX;
-	if (outputEOL == "\r")
-		lineEndFormat = LINEEND_MACOLD;
-	convertLineEnds(out, lineEndFormat);
+    LineEndFormat lineEndFormat = LINEEND_DEFAULT;
+    if (outputEOL == "\r\n")
+        lineEndFormat = LINEEND_WINDOWS;
+    if (outputEOL == "\n")
+        lineEndFormat = LINEEND_LINUX;
+    if (outputEOL == "\r")
+        lineEndFormat = LINEEND_MACOLD;
+    convertLineEnds(out, lineEndFormat);
 // check files for 16 or 32 bit encoding
@@ -462,34 +462,34 @@ void ASConsole::correctMixedLineEnds(ostringstream& out)
 // NOTE: some string functions don't work with NULLs (e.g. length())
 FileEncoding ASConsole::detectEncoding(const char* data, size_t dataSize) const
-	FileEncoding encoding = ENCODING_8BIT;
-	if (dataSize >= 3 && memcmp(data, "\xEF\xBB\xBF", 3) == 0)
-		encoding = UTF_8BOM;
-	else if (dataSize >= 4 && memcmp(data, "\x00\x00\xFE\xFF", 4) == 0)
-		encoding = UTF_32BE;
-	else if (dataSize >= 4 && memcmp(data, "\xFF\xFE\x00\x00", 4) == 0)
-		encoding = UTF_32LE;
-	else if (dataSize >= 2 && memcmp(data, "\xFE\xFF", 2) == 0)
-		encoding = UTF_16BE;
-	else if (dataSize >= 2 && memcmp(data, "\xFF\xFE", 2) == 0)
-		encoding = UTF_16LE;
-	return encoding;
+    FileEncoding encoding = ENCODING_8BIT;
+    if (dataSize >= 3 && memcmp(data, "\xEF\xBB\xBF", 3) == 0)
+        encoding = UTF_8BOM;
+    else if (dataSize >= 4 && memcmp(data, "\x00\x00\xFE\xFF", 4) == 0)
+        encoding = UTF_32BE;
+    else if (dataSize >= 4 && memcmp(data, "\xFF\xFE\x00\x00", 4) == 0)
+        encoding = UTF_32LE;
+    else if (dataSize >= 2 && memcmp(data, "\xFE\xFF", 2) == 0)
+        encoding = UTF_16BE;
+    else if (dataSize >= 2 && memcmp(data, "\xFF\xFE", 2) == 0)
+        encoding = UTF_16LE;
+    return encoding;
 // error exit without a message
 void ASConsole::error() const
-	(*errorStream) << _("Artistic Style has terminated\n") << endl;
-	exit(EXIT_FAILURE);
+    (*errorStream) << _("Artistic Style has terminated\n") << endl;
+    exit(EXIT_FAILURE);
 // error exit with a message
 void ASConsole::error(const char* why, const char* what) const
-	(*errorStream) << why << ' ' << what << endl;
-	error();
+    (*errorStream) << why << ' ' << what << endl;
+    error();
@@ -500,64 +500,64 @@ void ASConsole::error(const char* why, const char* what) const
 void ASConsole::formatCinToCout()
-	// check for files from --stdin= and --stdout=
-	if (!stdPathIn.empty())
-		if (!freopen(stdPathIn.c_str(), "r", stdin))
-			error("Cannot open input file", stdPathIn.c_str());
-	if (!stdPathOut.empty())
-		if (!freopen(stdPathOut.c_str(), "w", stdout))
-			error("Cannot open output file", stdPathOut.c_str());
-	// Using cin.tellg() causes problems with both Windows and Linux.
-	// The Windows problem occurs when the input is not Windows line-ends.
-	// The tellg() will be out of sequence with the get() statements.
-	// The Linux cin.tellg() will return -1 (invalid).
-	// Copying the input sequentially to a stringstream before
-	// formatting solves the problem for both.
-	istream* inStream = &cin;
-	stringstream outStream;
-	char ch;
-	while (!inStream->eof() && !inStream->fail())
-		outStream.put(ch);
-	ASStreamIterator<stringstream> streamIterator(&outStream);
-	// Windows pipe or redirection always outputs Windows line-ends.
-	// Linux pipe or redirection will output any line end.
+    // check for files from --stdin= and --stdout=
+    if (!stdPathIn.empty())
+        if (!freopen(stdPathIn.c_str(), "r", stdin))
+            error("Cannot open input file", stdPathIn.c_str());
+    if (!stdPathOut.empty())
+        if (!freopen(stdPathOut.c_str(), "w", stdout))
+            error("Cannot open output file", stdPathOut.c_str());
+    // Using cin.tellg() causes problems with both Windows and Linux.
+    // The Windows problem occurs when the input is not Windows line-ends.
+    // The tellg() will be out of sequence with the get() statements.
+    // The Linux cin.tellg() will return -1 (invalid).
+    // Copying the input sequentially to a stringstream before
+    // formatting solves the problem for both.
+    istream* inStream = &cin;
+    stringstream outStream;
+    char ch;
+    while (!inStream->eof() && !inStream->fail())
+        outStream.put(ch);
+    ASStreamIterator<stringstream> streamIterator(&outStream);
+    // Windows pipe or redirection always outputs Windows line-ends.
+    // Linux pipe or redirection will output any line end.
 #ifdef _WIN32
 #else
-	LineEndFormat lineEndFormat = formatter.getLineEndFormat();
+    LineEndFormat lineEndFormat = formatter.getLineEndFormat();
 #endif // _WIN32
-	initializeOutputEOL(lineEndFormat);
-	formatter.init(&streamIterator);
-	while (formatter.hasMoreLines())
-		cout << formatter.nextLine();
-		if (formatter.hasMoreLines())
-			setOutputEOL(lineEndFormat, streamIterator.getOutputEOL());
-			cout << outputEOL;
-		else
-			// this can happen if the file if missing a closing brace and break-blocks is requested
-			if (formatter.getIsLineReady())
-	cout.flush();
+    initializeOutputEOL(lineEndFormat);
+    formatter.init(&streamIterator);
+    while (formatter.hasMoreLines())
+        cout << formatter.nextLine();
+        if (formatter.hasMoreLines())
+            setOutputEOL(lineEndFormat, streamIterator.getOutputEOL());
+            cout << outputEOL;
+        else
+            // this can happen if the file if missing a closing brace and break-blocks is requested
+            if (formatter.getIsLineReady())
+    cout.flush();
@@ -567,99 +567,99 @@ void ASConsole::formatCinToCout()
 void ASConsole::formatFile(const string& fileName_)
-	stringstream in;
-	ostringstream out;
-	FileEncoding encoding = readFile(fileName_, in);
-	// Unless a specific language mode has been set, set the language mode
-	// according to the file's suffix.
-	if (!formatter.getModeManuallySet())
-		if (stringEndsWith(fileName_, string(".java")))
-			formatter.setJavaStyle();
-		else if (stringEndsWith(fileName_, string(".cs")))
-			formatter.setSharpStyle();
-		else
-			formatter.setCStyle();
-	// set line end format
-	string nextLine;				// next output line
-	filesAreIdentical = true;		// input and output files are identical
-	// do this AFTER setting the file mode
-	ASStreamIterator<stringstream> streamIterator(&in);
-	// format the file
-		nextLine = formatter.nextLine();
-		out << nextLine;
-		linesOut++;
-			out << outputEOL;
-		else
-			streamIterator.saveLastInputLine();     // to compare the last input line
-				out << outputEOL;
-				out << nextLine;
-				linesOut++;
-		if (filesAreIdentical)
-			if (streamIterator.checkForEmptyLine)
-				if (nextLine.find_first_not_of(" \t") != string::npos)
-					filesAreIdentical = false;
-			else if (!streamIterator.compareToInputBuffer(nextLine))
-			streamIterator.checkForEmptyLine = false;
-	// correct for mixed line ends
-	if (lineEndsMixed)
-		correctMixedLineEnds(out);
-	// remove targetDirectory from filename if required by print
-	string displayName;
-	if (hasWildcard)
-		displayName = fileName_.substr(targetDirectory.length() + 1);
-	else
-		displayName = fileName_;
-	// if file has changed, write the new file
-	if (!filesAreIdentical || streamIterator.getLineEndChange(lineEndFormat))
-		if (!isDryRun)
-			writeFile(fileName_, encoding, out);
-		printMsg(_("Formatted  %s\n"), displayName);
-		filesFormatted++;
-	else
-		if (!isFormattedOnly)
-			printMsg(_("Unchanged  %s\n"), displayName);
-		filesUnchanged++;
-	assert(formatter.getChecksumDiff() == 0);
+    stringstream in;
+    ostringstream out;
+    FileEncoding encoding = readFile(fileName_, in);
+    // Unless a specific language mode has been set, set the language mode
+    // according to the file's suffix.
+    if (!formatter.getModeManuallySet())
+        if (stringEndsWith(fileName_, string(".java")))
+            formatter.setJavaStyle();
+        else if (stringEndsWith(fileName_, string(".cs")))
+            formatter.setSharpStyle();
+        else
+            formatter.setCStyle();
+    // set line end format
+    string nextLine;                // next output line
+    filesAreIdentical = true;       // input and output files are identical
+    // do this AFTER setting the file mode
+    ASStreamIterator<stringstream> streamIterator(&in);
+    // format the file
+        nextLine = formatter.nextLine();
+        out << nextLine;
+        linesOut++;
+            out << outputEOL;
+        else
+            streamIterator.saveLastInputLine();     // to compare the last input line
+                out << outputEOL;
+                out << nextLine;
+                linesOut++;
+        if (filesAreIdentical)
+            if (streamIterator.checkForEmptyLine)
+                if (nextLine.find_first_not_of(" \t") != string::npos)
+                    filesAreIdentical = false;
+            else if (!streamIterator.compareToInputBuffer(nextLine))
+            streamIterator.checkForEmptyLine = false;
+    // correct for mixed line ends
+    if (lineEndsMixed)
+        correctMixedLineEnds(out);
+    // remove targetDirectory from filename if required by print
+    string displayName;
+    if (hasWildcard)
+        displayName = fileName_.substr(targetDirectory.length() + 1);
+    else
+        displayName = fileName_;
+    // if file has changed, write the new file
+    if (!filesAreIdentical || streamIterator.getLineEndChange(lineEndFormat))
+        if (!isDryRun)
+            writeFile(fileName_, encoding, out);
+        printMsg(_("Formatted  %s\n"), displayName);
+        filesFormatted++;
+    else
+        if (!isFormattedOnly)
+            printMsg(_("Unchanged  %s\n"), displayName);
+        filesUnchanged++;
+    assert(formatter.getChecksumDiff() == 0);
@@ -675,34 +675,34 @@ void ASConsole::formatFile(const string& fileName_)
 string ASConsole::findProjectOptionFilePath(const string& fileName_) const
-	string parent;
-	if (!fileNameVector.empty())
-		parent = getFullPathName(fileNameVector.front());
-	else if (!stdPathIn.empty())
-		parent = getFullPathName(stdPathIn);
-	else
-		parent = getFullPathName(getCurrentDirectory(fileName_));
-	// remove filename from path
-	size_t endPath = parent.find_last_of(g_fileSeparator);
-	if (endPath != string::npos)
-		parent = parent.substr(0, endPath + 1);
-	while (!parent.empty())
-		string filepath = parent + fileName_;
-		if (fileExists(filepath.c_str()))
-			return filepath;
-		else if (fileName_ == ".astylerc")
-			filepath = parent + "_astylerc";
-				return filepath;
-		parent = getParentDirectory(parent);
-	return string();
+    string parent;
+    if (!fileNameVector.empty())
+        parent = getFullPathName(fileNameVector.front());
+    else if (!stdPathIn.empty())
+        parent = getFullPathName(stdPathIn);
+    else
+        parent = getFullPathName(getCurrentDirectory(fileName_));
+    // remove filename from path
+    size_t endPath = parent.find_last_of(g_fileSeparator);
+    if (endPath != string::npos)
+        parent = parent.substr(0, endPath + 1);
+    while (!parent.empty())
+        string filepath = parent + fileName_;
+        if (fileExists(filepath.c_str()))
+            return filepath;
+        else if (fileName_ == ".astylerc")
+            filepath = parent + "_astylerc";
+                return filepath;
+        parent = getParentDirectory(parent);
+    return string();
 // for unit testing
@@ -792,12 +792,12 @@ bool ASConsole::getPreserveDate() const
 // for unit testing
 string ASConsole::getProjectOptionFileName() const
-	assert(projectOptionFileName.length() > 0);
-	// remove the directory path
-	size_t start = projectOptionFileName.find_last_of(g_fileSeparator);
-	if (start == string::npos)
-		start = 0;
-	return projectOptionFileName.substr(start + 1);
+    assert(projectOptionFileName.length() > 0);
+    // remove the directory path
+    size_t start = projectOptionFileName.find_last_of(g_fileSeparator);
+    if (start == string::npos)
+        start = 0;
+    return projectOptionFileName.substr(start + 1);
 // for unit testing
@@ -819,128 +819,128 @@ void ASConsole::setBypassBrowserOpen(bool state)
 // for unit testing
 ostream* ASConsole::getErrorStream() const
-	return errorStream;
+    return errorStream;
 void ASConsole::setErrorStream(ostream* errStreamPtr)
-	errorStream = errStreamPtr;
+    errorStream = errStreamPtr;
 // build a vector of argv options
 // the program path argv[0] is excluded
 vector<string> ASConsole::getArgvOptions(int argc, char** argv) const
-	vector<string> argvOptions;
-	for (int i = 1; i < argc; i++)
-		argvOptions.emplace_back(string(argv[i]));
-	return argvOptions;
+    vector<string> argvOptions;
+    for (int i = 1; i < argc; i++)
+        argvOptions.emplace_back(string(argv[i]));
+    return argvOptions;
 string ASConsole::getParam(const string& arg, const char* op)
-	return arg.substr(strlen(op));
+    return arg.substr(strlen(op));
 void ASConsole::getTargetFilenames(string& targetFilename_,
                                    vector<string>& targetFilenameVector) const
-	size_t beg = 0;
-	size_t sep = 0;
-	while (beg < targetFilename_.length())
-		// find next target
-		sep = targetFilename_.find_first_of(",;", beg);
-		if (sep == string::npos)
-			sep = targetFilename_.length();
-		string fileExtension = targetFilename_.substr(beg, sep - beg);
-		beg = sep + 1;
-		// remove whitespace
-		while (fileExtension.length() > 0
-		        && (fileExtension[0] == ' ' || fileExtension[0] == '\t'))
-			fileExtension = fileExtension.erase(0, 1);
-		        && (fileExtension[fileExtension.length() - 1] == ' '
-		            || fileExtension[fileExtension.length() - 1] == '\t'))
-			fileExtension = fileExtension.erase(fileExtension.length() - 1, 1);
-		if (fileExtension.length() > 0)
-			targetFilenameVector.emplace_back(fileExtension);
-	if (targetFilenameVector.size() == 0)
-		fprintf(stderr, _("Missing filename in %s\n"), targetFilename_.c_str());
-		error();
+    size_t beg = 0;
+    size_t sep = 0;
+    while (beg < targetFilename_.length())
+        // find next target
+        sep = targetFilename_.find_first_of(",;", beg);
+        if (sep == string::npos)
+            sep = targetFilename_.length();
+        string fileExtension = targetFilename_.substr(beg, sep - beg);
+        beg = sep + 1;
+        // remove whitespace
+        while (fileExtension.length() > 0
+                && (fileExtension[0] == ' ' || fileExtension[0] == '\t'))
+            fileExtension = fileExtension.erase(0, 1);
+                && (fileExtension[fileExtension.length() - 1] == ' '
+                    || fileExtension[fileExtension.length() - 1] == '\t'))
+            fileExtension = fileExtension.erase(fileExtension.length() - 1, 1);
+        if (fileExtension.length() > 0)
+            targetFilenameVector.emplace_back(fileExtension);
+    if (targetFilenameVector.size() == 0)
+        fprintf(stderr, _("Missing filename in %s\n"), targetFilename_.c_str());
+        error();
 // initialize output end of line
 void ASConsole::initializeOutputEOL(LineEndFormat lineEndFormat)
-	outputEOL.clear();			// current line end
-	prevEOL.clear();			// previous line end
-	lineEndsMixed = false;		// output has mixed line ends, LINEEND_DEFAULT only
-		outputEOL = "\n";
-		outputEOL = "\r";
-	else
+    outputEOL.clear();          // current line end
+    prevEOL.clear();            // previous line end
+    lineEndsMixed = false;      // output has mixed line ends, LINEEND_DEFAULT only
+        outputEOL = "\n";
+        outputEOL = "\r";
+    else
 // read a file into the stringstream 'in'
 FileEncoding ASConsole::readFile(const string& fileName_, stringstream& in) const
-	const int blockSize = 65536;	// 64 KB
-	ifstream fin(fileName_.c_str(), ios::binary);
-	if (!fin)
-		error("Cannot open file", fileName_.c_str());
-	char* data = new (nothrow) char[blockSize];
-	if (data == nullptr)
-		error("Cannot allocate memory to open file", fileName_.c_str());
-	fin.read(data, blockSize);
-	if (fin.bad())
-		error("Cannot read file", fileName_.c_str());
-	size_t dataSize = static_cast<size_t>(fin.gcount());
-	FileEncoding encoding = detectEncoding(data, dataSize);
-	if (encoding == UTF_32BE || encoding == UTF_32LE)
-		error(_("Cannot process UTF-32 encoding"), fileName_.c_str());
-	bool firstBlock = true;
-	bool isBigEndian = (encoding == UTF_16BE);
-	while (dataSize != 0)
-		if (encoding == UTF_16LE || encoding == UTF_16BE)
-			// convert utf-16 to utf-8
-			size_t utf8Size = encode.utf8LengthFromUtf16(data, dataSize, isBigEndian);
-			char* utf8Out = new (nothrow) char[utf8Size];
-			if (utf8Out == nullptr)
-				error("Cannot allocate memory for utf-8 conversion", fileName_.c_str());
-			size_t utf8Len = encode.utf16ToUtf8(data, dataSize, isBigEndian, firstBlock, utf8Out);
-			assert(utf8Len <= utf8Size);
-			in << string(utf8Out, utf8Len);
-			delete[] utf8Out;
-		else
-			in << string(data, dataSize);
-		if (fin.bad())
-		dataSize = static_cast<size_t>(fin.gcount());
-		firstBlock = false;
-	fin.close();
-	delete[] data;
-	return encoding;
+    const int blockSize = 65536;    // 64 KB
+    ifstream fin(fileName_.c_str(), ios::binary);
+    if (!fin)
+        error("Cannot open file", fileName_.c_str());
+    char* data = new (nothrow) char[blockSize];
+    if (data == nullptr)
+        error("Cannot allocate memory to open file", fileName_.c_str());
+    fin.read(data, blockSize);
+    if (fin.bad())
+        error("Cannot read file", fileName_.c_str());
+    size_t dataSize = static_cast<size_t>(fin.gcount());
+    FileEncoding encoding = detectEncoding(data, dataSize);
+    if (encoding == UTF_32BE || encoding == UTF_32LE)
+        error(_("Cannot process UTF-32 encoding"), fileName_.c_str());
+    bool firstBlock = true;
+    bool isBigEndian = (encoding == UTF_16BE);
+    while (dataSize != 0)
+        if (encoding == UTF_16LE || encoding == UTF_16BE)
+            // convert utf-16 to utf-8
+            size_t utf8Size = encode.utf8LengthFromUtf16(data, dataSize, isBigEndian);
+            char* utf8Out = new (nothrow) char[utf8Size];
+            if (utf8Out == nullptr)
+                error("Cannot allocate memory for utf-8 conversion", fileName_.c_str());
+            size_t utf8Len = encode.utf16ToUtf8(data, dataSize, isBigEndian, firstBlock, utf8Out);
+            assert(utf8Len <= utf8Size);
+            in << string(utf8Out, utf8Len);
+            delete[] utf8Out;
+        else
+            in << string(data, dataSize);
+        if (fin.bad())
+        dataSize = static_cast<size_t>(fin.gcount());
+        firstBlock = false;
+    fin.close();
+    delete[] data;
+    return encoding;
 void ASConsole::setIgnoreExcludeErrors(bool state)
@@ -988,24 +988,24 @@ void ASConsole::setStdPathOut(const string& path)
 // set outputEOL variable
 void ASConsole::setOutputEOL(LineEndFormat lineEndFormat, const string& currentEOL)
-	if (lineEndFormat == LINEEND_DEFAULT)
-		outputEOL = currentEOL;
-		if (prevEOL.empty())
-			prevEOL = outputEOL;
-		if (prevEOL != outputEOL)
-			lineEndsMixed = true;
-	else
-		prevEOL = currentEOL;
+    if (lineEndFormat == LINEEND_DEFAULT)
+        outputEOL = currentEOL;
+        if (prevEOL.empty())
+            prevEOL = outputEOL;
+        if (prevEOL != outputEOL)
+            lineEndsMixed = true;
+    else
+        prevEOL = currentEOL;
 #ifdef _WIN32  // Windows specific
@@ -1015,20 +1015,20 @@ void ASConsole::setOutputEOL(LineEndFormat lineEndFormat, const string& currentE
 void ASConsole::displayLastError()
-	LPSTR msgBuf;
-	DWORD lastError = GetLastError();
-	FormatMessage(FORMAT_MESSAGE_ALLOCATE_BUFFER | FORMAT_MESSAGE_FROM_SYSTEM,
-	              nullptr,
-	              lastError,
-	              MAKELANGID(LANG_NEUTRAL, SUBLANG_DEFAULT),  // Default language
-	              (LPSTR) &msgBuf,
-	              0,
-	              nullptr
-	// Display the string.
-	(*errorStream) << "Error (" << lastError << ") " << msgBuf << endl;
-	// Free the buffer.
-	LocalFree(msgBuf);
+    LPSTR msgBuf;
+    DWORD lastError = GetLastError();
+    FormatMessage(FORMAT_MESSAGE_ALLOCATE_BUFFER | FORMAT_MESSAGE_FROM_SYSTEM,
+                  nullptr,
+                  lastError,
+                  MAKELANGID(LANG_NEUTRAL, SUBLANG_DEFAULT),  // Default language
+                  (LPSTR) &msgBuf,
+                  0,
+                  nullptr
+    // Display the string.
+    (*errorStream) << "Error (" << lastError << ") " << msgBuf << endl;
+    // Free the buffer.
+    LocalFree(msgBuf);
@@ -1040,11 +1040,11 @@ void ASConsole::displayLastError()
 string ASConsole::getCurrentDirectory(const string& fileName_) const
-	char currdir[MAX_PATH];
-	currdir[0] = '\0';
-	if (!GetCurrentDirectory(sizeof(currdir), currdir))
-		error("Cannot find file", fileName_.c_str());
-	return string(currdir);
+    char currdir[MAX_PATH];
+    currdir[0] = '\0';
+    if (!GetCurrentDirectory(sizeof(currdir), currdir))
+        error("Cannot find file", fileName_.c_str());
+    return string(currdir);
@@ -1056,134 +1056,134 @@ string ASConsole::getCurrentDirectory(const string& fileName_) const
 void ASConsole::getFileNames(const string& directory, const vector<string>& wildcards)
-	vector<string> subDirectory;    // sub directories of directory
-	WIN32_FIND_DATA findFileData;   // for FindFirstFile and FindNextFile
-	// Find the first file in the directory
-	// Find will get at least "." and "..".
-	string firstFile = directory + "\\*";
-	HANDLE hFind = FindFirstFile(firstFile.c_str(), &findFileData);
-	if (hFind == INVALID_HANDLE_VALUE)
-		// Error (3) The system cannot find the path specified.
-		// Error (123) The filename, directory name, or volume label syntax is incorrect.
-		// ::FindClose(hFind); before exiting
-		displayLastError();
-		error(_("Cannot open directory"), directory.c_str());
-	// save files and sub directories
-	do
-		// skip hidden or read only
-		if (findFileData.cFileName[0] == '.'
-		        || (findFileData.dwFileAttributes & FILE_ATTRIBUTE_HIDDEN)
-		        || (findFileData.dwFileAttributes & FILE_ATTRIBUTE_READONLY))
-			continue;
-		// is this a sub directory
-		if (findFileData.dwFileAttributes & FILE_ATTRIBUTE_DIRECTORY)
-			if (!isRecursive)
-				continue;
-			// if a sub directory and recursive, save sub directory
-			string subDirectoryPath = directory + g_fileSeparator + findFileData.cFileName;
-			if (isPathExclued(subDirectoryPath))
-				printMsg(_("Exclude  %s\n"), subDirectoryPath.substr(mainDirectoryLength));
-			else
-				subDirectory.emplace_back(subDirectoryPath);
-			continue;
-		string filePathName = directory + g_fileSeparator + findFileData.cFileName;
-		// check exclude before wildcmp to avoid "unmatched exclude" error
-		bool isExcluded = isPathExclued(filePathName);
-		// save file name if wildcard match
-		for (size_t i = 0; i < wildcards.size(); i++)
-			if (wildcmp(wildcards[i].c_str(), findFileData.cFileName))
-				if (isExcluded)
-					printMsg(_("Exclude  %s\n"), filePathName.substr(mainDirectoryLength));
-				else
-					fileName.emplace_back(filePathName);
-				break;
-	while (FindNextFile(hFind, &findFileData) != 0);
-	// check for processing error
-	::FindClose(hFind);
-	DWORD dwError = GetLastError();
-	if (dwError != ERROR_NO_MORE_FILES)
-		error("Error processing directory", directory.c_str());
-	// recurse into sub directories
-	// if not doing recursive subDirectory is empty
-	for (unsigned i = 0; i < subDirectory.size(); i++)
-		getFileNames(subDirectory[i], wildcards);
-	return;
+    vector<string> subDirectory;    // sub directories of directory
+    WIN32_FIND_DATA findFileData;   // for FindFirstFile and FindNextFile
+    // Find the first file in the directory
+    // Find will get at least "." and "..".
+    string firstFile = directory + "\\*";
+    HANDLE hFind = FindFirstFile(firstFile.c_str(), &findFileData);
+    if (hFind == INVALID_HANDLE_VALUE)
+        // Error (3) The system cannot find the path specified.
+        // Error (123) The filename, directory name, or volume label syntax is incorrect.
+        // ::FindClose(hFind); before exiting
+        displayLastError();
+        error(_("Cannot open directory"), directory.c_str());
+    // save files and sub directories
+    do
+        // skip hidden or read only
+        if (findFileData.cFileName[0] == '.'
+                || (findFileData.dwFileAttributes & FILE_ATTRIBUTE_HIDDEN)
+                || (findFileData.dwFileAttributes & FILE_ATTRIBUTE_READONLY))
+            continue;
+        // is this a sub directory
+        if (findFileData.dwFileAttributes & FILE_ATTRIBUTE_DIRECTORY)
+            if (!isRecursive)
+                continue;
+            // if a sub directory and recursive, save sub directory
+            string subDirectoryPath = directory + g_fileSeparator + findFileData.cFileName;
+            if (isPathExclued(subDirectoryPath))
+                printMsg(_("Exclude  %s\n"), subDirectoryPath.substr(mainDirectoryLength));
+            else
+                subDirectory.emplace_back(subDirectoryPath);
+            continue;
+        string filePathName = directory + g_fileSeparator + findFileData.cFileName;
+        // check exclude before wildcmp to avoid "unmatched exclude" error
+        bool isExcluded = isPathExclued(filePathName);
+        // save file name if wildcard match
+        for (size_t i = 0; i < wildcards.size(); i++)
+            if (wildcmp(wildcards[i].c_str(), findFileData.cFileName))
+                if (isExcluded)
+                    printMsg(_("Exclude  %s\n"), filePathName.substr(mainDirectoryLength));
+                else
+                    fileName.emplace_back(filePathName);
+                break;
+    while (FindNextFile(hFind, &findFileData) != 0);
+    // check for processing error
+    ::FindClose(hFind);
+    DWORD dwError = GetLastError();
+    if (dwError != ERROR_NO_MORE_FILES)
+        error("Error processing directory", directory.c_str());
+    // recurse into sub directories
+    // if not doing recursive subDirectory is empty
+    for (unsigned i = 0; i < subDirectory.size(); i++)
+        getFileNames(subDirectory[i], wildcards);
+    return;
 // WINDOWS function to get the full path name from the relative path name
 // Return the full path name or an empty string if failed.
 string ASConsole::getFullPathName(const string& relativePath) const
-	char fullPath[MAX_PATH];
-	GetFullPathName(relativePath.c_str(), MAX_PATH, fullPath, NULL);
-	return fullPath;
+    char fullPath[MAX_PATH];
+    GetFullPathName(relativePath.c_str(), MAX_PATH, fullPath, NULL);
+    return fullPath;
  * WINDOWS function to format a number according to the current locale.
  * This formats positive integers only, no float.
- * @param num		The number to be formatted.
- * @param lcid		The LCID of the locale to be used for testing.
- * @return			The formatted number.
+ * @param num       The number to be formatted.
+ * @param lcid      The LCID of the locale to be used for testing.
+ * @return          The formatted number.
 string ASConsole::getNumberFormat(int num, size_t lcid) const
 #if defined(_MSC_VER) || defined(__MINGW32__) || defined(__BORLANDC__) || defined(__GNUC__)
-	// Compilers that don't support C++ locales should still support this assert.
-	// The C locale should be set but not the C++.
-	// This function is not necessary if the C++ locale is set.
-	// The locale().name() return value is not portable to all compilers.
-	assert(locale().name() == "C");
+    // Compilers that don't support C++ locales should still support this assert.
+    // The C locale should be set but not the C++.
+    // This function is not necessary if the C++ locale is set.
+    // The locale().name() return value is not portable to all compilers.
+    assert(locale().name() == "C");
 #endif
-	// convert num to a string
-	stringstream alphaNum;
-	alphaNum << num;
-	string number = alphaNum.str();
-	if (useAscii)
-		return number;
-	// format the number using the Windows API
-	if (lcid == 0)
-		lcid = LOCALE_USER_DEFAULT;
-	int outSize = ::GetNumberFormat(lcid, 0, number.c_str(), nullptr, nullptr, 0);
-	char* outBuf = new (nothrow) char[outSize];
-	if (outBuf == nullptr)
-		return number;
-	::GetNumberFormat(lcid, 0, number.c_str(), nullptr, outBuf, outSize);
-	string formattedNum(outBuf);
-	delete[] outBuf;
-	// remove the decimal
-	int decSize = ::GetLocaleInfo(lcid, LOCALE_SDECIMAL, nullptr, 0);
-	char* decBuf = new (nothrow) char[decSize];
-	if (decBuf == nullptr)
-		return number;
-	::GetLocaleInfo(lcid, LOCALE_SDECIMAL, decBuf, decSize);
-	size_t i = formattedNum.rfind(decBuf);
-	delete[] decBuf;
-	if (i != string::npos)
-		formattedNum.erase(i);
-	if (!formattedNum.length())
-		formattedNum = "0";
-	return formattedNum;
+    // convert num to a string
+    stringstream alphaNum;
+    alphaNum << num;
+    string number = alphaNum.str();
+    if (useAscii)
+        return number;
+    // format the number using the Windows API
+    if (lcid == 0)
+        lcid = LOCALE_USER_DEFAULT;
+    int outSize = ::GetNumberFormat(lcid, 0, number.c_str(), nullptr, nullptr, 0);
+    char* outBuf = new (nothrow) char[outSize];
+    if (outBuf == nullptr)
+        return number;
+    ::GetNumberFormat(lcid, 0, number.c_str(), nullptr, outBuf, outSize);
+    string formattedNum(outBuf);
+    delete[] outBuf;
+    // remove the decimal
+    int decSize = ::GetLocaleInfo(lcid, LOCALE_SDECIMAL, nullptr, 0);
+    char* decBuf = new (nothrow) char[decSize];
+    if (decBuf == nullptr)
+        return number;
+    ::GetLocaleInfo(lcid, LOCALE_SDECIMAL, decBuf, decSize);
+    size_t i = formattedNum.rfind(decBuf);
+    delete[] decBuf;
+    if (i != string::npos)
+        formattedNum.erase(i);
+    if (!formattedNum.length())
+        formattedNum = "0";
+    return formattedNum;
@@ -1195,17 +1195,17 @@ string ASConsole::getNumberFormat(int num, size_t lcid) const
 bool ASConsole::isHomeOrInvalidAbsPath(const string& absPath) const
-	char* env = getenv("USERPROFILE");
-	if (env == nullptr)
-		return true;
+    char* env = getenv("USERPROFILE");
+    if (env == nullptr)
+        return true;
-	if (absPath.c_str() == env)
-		return true;
+    if (absPath.c_str() == env)
+        return true;
-	if (absPath.compare(0, strlen(env), env) != 0)
-		return true;
+    if (absPath.compare(0, strlen(env), env) != 0)
+        return true;
-	return false;
+    return false;
@@ -1213,57 +1213,57 @@ bool ASConsole::isHomeOrInvalidAbsPath(const string& absPath) const
 void ASConsole::launchDefaultBrowser(const char* filePathIn /*nullptr*/) const
-	struct stat statbuf;
-	const char* envPaths[] = { "PROGRAMFILES(X86)", "PROGRAMFILES" };
-	size_t pathsLen = sizeof(envPaths) / sizeof(envPaths[0]);
-	string htmlDefaultPath;
-	for (size_t i = 0; i < pathsLen; i++)
-		const char* envPath = getenv(envPaths[i]);
-		if (envPath == nullptr)
-			continue;
-		htmlDefaultPath = envPath;
-		if (htmlDefaultPath.length() > 0
-		        && htmlDefaultPath[htmlDefaultPath.length() - 1] == g_fileSeparator)
-			htmlDefaultPath.erase(htmlDefaultPath.length() - 1);
-		htmlDefaultPath.append("\\AStyle\\doc");
-		if (stat(htmlDefaultPath.c_str(), &statbuf) == 0 && statbuf.st_mode & S_IFDIR)
-			break;
-	htmlDefaultPath.append("\\");
-	// build file path
-	string htmlFilePath;
-	if (filePathIn == nullptr)
-		htmlFilePath = htmlDefaultPath + "astyle.html";
-	else
-		if (strpbrk(filePathIn, "\\/") == nullptr)
-			htmlFilePath = htmlDefaultPath + filePathIn;
-		else
-			htmlFilePath = filePathIn;
-	standardizePath(htmlFilePath);
-	if (stat(htmlFilePath.c_str(), &statbuf) != 0 || !(statbuf.st_mode & S_IFREG))
-		printf(_("Cannot open HTML file %s\n"), htmlFilePath.c_str());
-		return;
-	SHELLEXECUTEINFO sei = { sizeof(sei), 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
-	sei.fMask = SEE_MASK_FLAG_NO_UI;
-	sei.lpVerb = "open";
-	sei.lpFile = htmlFilePath.c_str();
-	sei.nShow = SW_SHOWNORMAL;
-	// browser open will be bypassed in test programs
-	printf(_("Opening HTML documentation %s\n"), htmlFilePath.c_str());
-	if (!bypassBrowserOpen)
-		int ret = ShellExecuteEx(&sei);
-		if (!ret)
-			error(_("Command execute failure"), htmlFilePath.c_str());
+    struct stat statbuf;
+    const char* envPaths[] = { "PROGRAMFILES(X86)", "PROGRAMFILES" };
+    size_t pathsLen = sizeof(envPaths) / sizeof(envPaths[0]);
+    string htmlDefaultPath;
+    for (size_t i = 0; i < pathsLen; i++)
+        const char* envPath = getenv(envPaths[i]);
+        if (envPath == nullptr)
+            continue;
+        htmlDefaultPath = envPath;
+        if (htmlDefaultPath.length() > 0
+                && htmlDefaultPath[htmlDefaultPath.length() - 1] == g_fileSeparator)
+            htmlDefaultPath.erase(htmlDefaultPath.length() - 1);
+        htmlDefaultPath.append("\\AStyle\\doc");
+        if (stat(htmlDefaultPath.c_str(), &statbuf) == 0 && statbuf.st_mode & S_IFDIR)
+            break;
+    htmlDefaultPath.append("\\");
+    // build file path
+    string htmlFilePath;
+    if (filePathIn == nullptr)
+        htmlFilePath = htmlDefaultPath + "astyle.html";
+    else
+        if (strpbrk(filePathIn, "\\/") == nullptr)
+            htmlFilePath = htmlDefaultPath + filePathIn;
+        else
+            htmlFilePath = filePathIn;
+    standardizePath(htmlFilePath);
+    if (stat(htmlFilePath.c_str(), &statbuf) != 0 || !(statbuf.st_mode & S_IFREG))
+        printf(_("Cannot open HTML file %s\n"), htmlFilePath.c_str());
+        return;
+    SHELLEXECUTEINFO sei = { sizeof(sei), 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
+    sei.fMask = SEE_MASK_FLAG_NO_UI;
+    sei.lpVerb = "open";
+    sei.lpFile = htmlFilePath.c_str();
+    sei.nShow = SW_SHOWNORMAL;
+    // browser open will be bypassed in test programs
+    printf(_("Opening HTML documentation %s\n"), htmlFilePath.c_str());
+    if (!bypassBrowserOpen)
+        int ret = ShellExecuteEx(&sei);
+        if (!ret)
+            error(_("Command execute failure"), htmlFilePath.c_str());
 #else  // Linux specific
@@ -1278,10 +1278,10 @@ void ASConsole::launchDefaultBrowser(const char* filePathIn /*nullptr*/) const
-	char* currdir = getenv("PWD");
-	if (currdir == nullptr)
+    char* currdir = getenv("PWD");
+    if (currdir == nullptr)
@@ -1293,98 +1293,101 @@ string ASConsole::getCurrentDirectory(const string& fileName_) const
-	struct dirent* entry;           // entry from readdir()
-	struct stat statbuf;            // entry from stat()
-	vector<string> subDirectory;    // sub directories of this directory
-	// errno is defined in <errno.h> and is set for errors in opendir, readdir, or stat
-	errno = 0;
-	DIR* dp = opendir(directory.c_str());
-	if (dp == nullptr)
-	// save the first fileName entry for this recursion
-	const unsigned firstEntry = fileName.size();
-	while ((entry = readdir(dp)) != nullptr)
-		// get file status
-		string entryFilepath = directory + g_fileSeparator + entry->d_name;
-		if (stat(entryFilepath.c_str(), &statbuf) != 0)
-			if (errno == EOVERFLOW)         // file over 2 GB is OK
-				errno = 0;
-				continue;
-			perror("errno message");
-			error("Error getting file status in directory", directory.c_str());
-		if (entry->d_name[0] == '.' || !(statbuf.st_mode & S_IWUSR))
-			continue;
-		if (S_ISDIR(statbuf.st_mode) && isRecursive)
-			if (isPathExclued(entryFilepath))
-				printMsg(_("Exclude  %s\n"), entryFilepath.substr(mainDirectoryLength));
-			else
-				subDirectory.emplace_back(entryFilepath);
-			continue;
-		// if a file, save file name
-		if (S_ISREG(statbuf.st_mode))
-			bool isExcluded = isPathExclued(entryFilepath);
-			for (string wildcard : wildcards)
-				if (wildcmp(wildcard.c_str(), entry->d_name) != 0)
-					if (isExcluded)
-					else
-						fileName.emplace_back(entryFilepath);
-					break;
-	if (closedir(dp) != 0)
-		error("Error reading directory", directory.c_str());
-	// sort the current entries for fileName
-	if (firstEntry < fileName.size())
-		sort(&fileName[firstEntry], &fileName[fileName.size()]);
-	// if not doing recursive, subDirectory is empty
-	if (subDirectory.size() > 1)
-		sort(subDirectory.begin(), subDirectory.end());
+    struct dirent* entry;           // entry from readdir()
+    struct stat statbuf;            // entry from stat()
+    vector<string> subDirectory;    // sub directories of this directory
+    // errno is defined in <errno.h> and is set for errors in opendir, readdir, or stat
+    errno = 0;
+    DIR* dp = opendir(directory.c_str());
+    if (dp == nullptr)
+    // save the first fileName entry for this recursion
+    const unsigned firstEntry = fileName.size();
+    while ((entry = readdir(dp)) != nullptr)
+        // get file status
+        string entryFilepath = directory + g_fileSeparator + entry->d_name;
+        if (stat(entryFilepath.c_str(), &statbuf) != 0)
+            if (errno == EOVERFLOW)         // file over 2 GB is OK
+                errno = 0;
+                continue;
+            perror("errno message");
+            error("Error getting file status in directory", directory.c_str());
+        if (entry->d_name[0] == '.' || !(statbuf.st_mode & S_IWUSR))
+            continue;
+        if (S_ISDIR(statbuf.st_mode) && isRecursive)
+            if (isPathExclued(entryFilepath))
+                printMsg(_("Exclude  %s\n"), entryFilepath.substr(mainDirectoryLength));
+            else
+                subDirectory.emplace_back(entryFilepath);
+            continue;
+        // if a file, save file name
+        if (S_ISREG(statbuf.st_mode))
+            bool isExcluded = isPathExclued(entryFilepath);
+            for (string wildcard : wildcards)
+                if (wildcmp(wildcard.c_str(), entry->d_name) != 0)
+                    if (isExcluded)
+                    else
+                        fileName.emplace_back(entryFilepath);
+                    break;
+    if (closedir(dp) != 0)
+        error("Error reading directory", directory.c_str());
+    // sort the current entries for fileName
+    if (firstEntry < fileName.size())
+        sort(&fileName[firstEntry], &fileName[fileName.size()]);
+    // if not doing recursive, subDirectory is empty
+    if (subDirectory.size() > 1)
+        sort(subDirectory.begin(), subDirectory.end());
 // LINUX function to get the full path name from the relative path name
-	// ignore realPath attribute warning
+    // ignore realPath attribute warning
 #pragma GCC diagnostic push
 #pragma GCC diagnostic ignored "-Wunused-result"
-	char fullPath[PATH_MAX];
-	realpath(relativePath.c_str(), fullPath);
-	return fullPath;
+#ifndef PATH_MAX
+#define PATH_MAX 4096
+#endif
+    char fullPath[PATH_MAX];
+    realpath(relativePath.c_str(), fullPath);
+    return fullPath;
 #pragma GCC diagnostic pop
@@ -1392,73 +1395,73 @@ string ASConsole::getFullPathName(const string& relativePath) const
  * LINUX function to get locale information and call getNumberFormat.
  *                  size_t is for compatibility with the Windows function.
 string ASConsole::getNumberFormat(int num, size_t /*lcid*/) const
 #endif
-	// get the locale info
-	struct lconv* lc;
-	lc = localeconv();
+    // get the locale info
+    struct lconv* lc;
+    lc = localeconv();
-	return getNumberFormat(num, lc->grouping, lc->thousands_sep);
+    return getNumberFormat(num, lc->grouping, lc->thousands_sep);
  * LINUX function to format a number according to the current locale.
  * @param groupingArg   The grouping string from the locale.
- * @param  separator	The thousands group separator from the locale.
+ * @param  separator    The thousands group separator from the locale.
 string ASConsole::getNumberFormat(int num, const char* groupingArg, const char* separator) const
-	alphaNum << num;
-	// format the number from right to left
-	string formattedNum;
-	size_t ig = 0;	// grouping index
-	int grouping = groupingArg[ig];
-	int i = number.length();
-	// check for no grouping
-	if (grouping == 0)
-		grouping = number.length();
-	while (i > 0)
-		// extract a group of numbers
-		string group;
-		if (i < grouping)
-			group = number;
-		else
-			group = number.substr(i - grouping);
-		// update formatted number
-		formattedNum.insert(0, group);
-		i -= grouping;
-		if (i < 0)
-			i = 0;
-		if (i > 0)
-			formattedNum.insert(0, separator);
-		number.erase(i);
-		// update grouping
-		if (groupingArg[ig] != '\0'
-		        && groupingArg[ig + 1] != '\0')
-			grouping = groupingArg[++ig];
+    alphaNum << num;
+    // format the number from right to left
+    string formattedNum;
+    size_t ig = 0;  // grouping index
+    int grouping = groupingArg[ig];
+    int i = number.length();
+    // check for no grouping
+    if (grouping == 0)
+        grouping = number.length();
+    while (i > 0)
+        // extract a group of numbers
+        string group;
+        if (i < grouping)
+            group = number;
+        else
+            group = number.substr(i - grouping);
+        // update formatted number
+        formattedNum.insert(0, group);
+        i -= grouping;
+        if (i < 0)
+            i = 0;
+        if (i > 0)
+            formattedNum.insert(0, separator);
+        number.erase(i);
+        // update grouping
+        if (groupingArg[ig] != '\0'
+                && groupingArg[ig + 1] != '\0')
+            grouping = groupingArg[++ig];
@@ -1470,17 +1473,17 @@ string ASConsole::getNumberFormat(int num, const char* groupingArg, const char*
-	char* env = getenv("HOME");
-		return true;
+    char* env = getenv("HOME");
+        return true;
-		return true;
+        return true;
-		return true;
+        return true;
-	return false;
+    return false;
@@ -1491,67 +1494,67 @@ bool ASConsole::isHomeOrInvalidAbsPath(const string& absPath) const
-	string htmlDefaultPath = "/usr/share/doc/astyle/html/";
-	string htmlDefaultFile = "astyle.html";
-		htmlFilePath = htmlDefaultPath + htmlDefaultFile;
-	else
-		else
-		return;
-	// get search paths
-	const char* envPaths = getenv("PATH");
-	if (envPaths == nullptr)
-		envPaths = "?";
-	size_t envlen = strlen(envPaths);
-	char* paths = new char[envlen + 1];
-	strcpy(paths, envPaths);
-	// find xdg-open (usually in /usr/bin)
-	// Mac uses open instead
+    string htmlDefaultPath = "/usr/share/doc/astyle/html/";
+    string htmlDefaultFile = "astyle.html";
+        htmlFilePath = htmlDefaultPath + htmlDefaultFile;
+    else
+        else
+        return;
+    // get search paths
+    const char* envPaths = getenv("PATH");
+    if (envPaths == nullptr)
+        envPaths = "?";
+    size_t envlen = strlen(envPaths);
+    char* paths = new char[envlen + 1];
+    strcpy(paths, envPaths);
+    // find xdg-open (usually in /usr/bin)
+    // Mac uses open instead
 #ifdef __APPLE__
-	const char* fileOpen = "open";
+    const char* fileOpen = "open";
 #else
-	const char* fileOpen = "xdg-open";
+    const char* fileOpen = "xdg-open";
 #endif
-	string searchPath;
-	char* searchDir = strtok(paths, ":");
-	while (searchDir != nullptr)
-		searchPath = searchDir;
-		if (searchPath.length() > 0
-		        && searchPath[searchPath.length() - 1] != g_fileSeparator)
-			searchPath.append(string(1, g_fileSeparator));
-		searchPath.append(fileOpen);
-		if (stat(searchPath.c_str(), &statbuf) == 0 && (statbuf.st_mode & S_IFREG))
-			break;
-		searchDir = strtok(nullptr, ":");
-	delete[] paths;
-	if (searchDir == nullptr)
-		error(_("Command is not installed"), fileOpen);
-		execlp(fileOpen, fileOpen, htmlFilePath.c_str(), nullptr);
-		// execlp will NOT return if successful
-		error(_("Command execute failure"), fileOpen);
+    string searchPath;
+    char* searchDir = strtok(paths, ":");
+    while (searchDir != nullptr)
+        searchPath = searchDir;
+        if (searchPath.length() > 0
+                && searchPath[searchPath.length() - 1] != g_fileSeparator)
+            searchPath.append(string(1, g_fileSeparator));
+        searchPath.append(fileOpen);
+        if (stat(searchPath.c_str(), &statbuf) == 0 && (statbuf.st_mode & S_IFREG))
+            break;
+        searchDir = strtok(nullptr, ":");
+    delete[] paths;
+    if (searchDir == nullptr)
+        error(_("Command is not installed"), fileOpen);
+        execlp(fileOpen, fileOpen, htmlFilePath.c_str(), nullptr);
+        // execlp will NOT return if successful
+        error(_("Command execute failure"), fileOpen);
 #endif  // _WIN32
@@ -1566,173 +1569,173 @@ void ASConsole::launchDefaultBrowser(const char* filePathIn /*nullptr*/) const
 string ASConsole::getParentDirectory(const string& absPath) const
-	if (isHomeOrInvalidAbsPath(absPath))
-		return string();
-	size_t offset = absPath.size() - 1;
-	if (absPath[absPath.size() - 1] == g_fileSeparator)
-		offset -= 1;
-	size_t idx = absPath.rfind(g_fileSeparator, offset);
-	if (idx == string::npos)
-		return string();
-	string str = absPath.substr(0, idx + 1);
-	return str;
+    if (isHomeOrInvalidAbsPath(absPath))
+        return string();
+    size_t offset = absPath.size() - 1;
+    if (absPath[absPath.size() - 1] == g_fileSeparator)
+        offset -= 1;
+    size_t idx = absPath.rfind(g_fileSeparator, offset);
+    if (idx == string::npos)
+        return string();
+    string str = absPath.substr(0, idx + 1);
+    return str;
 // get individual file names from the command-line file path
 void ASConsole::getFilePaths(const string& filePath)
-	fileName.clear();
-	targetDirectory = string();
-	targetFilename = string();
-	vector<string> targetFilenameVector;
-	// separate directory and file name
-	size_t separator = filePath.find_last_of(g_fileSeparator);
-	if (separator == string::npos)
-		// if no directory is present, use the currently active directory
-		targetDirectory = getCurrentDirectory(filePath);
-		targetFilename  = filePath;
-		mainDirectoryLength = targetDirectory.length() + 1;    // +1 includes trailing separator
-	else
-		targetDirectory = filePath.substr(0, separator);
-		targetFilename  = filePath.substr(separator + 1);
-	if (targetFilename.length() == 0)
-		fprintf(stderr, _("Missing filename in %s\n"), filePath.c_str());
-		error();
-	// check filename for wildcards
-	if (targetFilename.find_first_of("*?") != string::npos)
-		hasWildcard = true;
-	// If the filename is not quoted on Linux, bash will replace the
-	// wildcard instead of passing it to the program.
-	if (isRecursive && !hasWildcard)
-		fprintf(stderr, "%s\n", _("Recursive option with no wildcard"));
+    fileName.clear();
+    targetDirectory = string();
+    targetFilename = string();
+    vector<string> targetFilenameVector;
+    // separate directory and file name
+    size_t separator = filePath.find_last_of(g_fileSeparator);
+    if (separator == string::npos)
+        // if no directory is present, use the currently active directory
+        targetDirectory = getCurrentDirectory(filePath);
+        targetFilename  = filePath;
+        mainDirectoryLength = targetDirectory.length() + 1;    // +1 includes trailing separator
+    else
+        targetDirectory = filePath.substr(0, separator);
+        targetFilename  = filePath.substr(separator + 1);
+    if (targetFilename.length() == 0)
+        fprintf(stderr, _("Missing filename in %s\n"), filePath.c_str());
+        error();
+    // check filename for wildcards
+    if (targetFilename.find_first_of("*?") != string::npos)
+        hasWildcard = true;
+    // If the filename is not quoted on Linux, bash will replace the
+    // wildcard instead of passing it to the program.
+    if (isRecursive && !hasWildcard)
+        fprintf(stderr, "%s\n", _("Recursive option with no wildcard"));
 #ifndef _WIN32
-		fprintf(stderr, "%s\n", _("Did you intend quote the filename"));
+        fprintf(stderr, "%s\n", _("Did you intend quote the filename"));
 #endif
-		error();
-	bool hasMultipleTargets = false;
-	if (targetFilename.find_first_of(",;") != string::npos)
-		hasMultipleTargets = true;
-	// display directory name for wildcard processing
-	if (hasWildcard)
-		printSeparatingLine();
-		printMsg(_("Directory  %s\n"), targetDirectory + g_fileSeparator + targetFilename);
-	// clear exclude hits vector
-	size_t excludeHitsVectorSize = excludeHitsVector.size();
-	for (size_t ix = 0; ix < excludeHitsVectorSize; ix++)
-		excludeHitsVector[ix] = false;
-	// create a vector of paths and file names to process
-	if (hasWildcard || isRecursive || hasMultipleTargets)
-		getTargetFilenames(targetFilename, targetFilenameVector);
-		getFileNames(targetDirectory, targetFilenameVector);
-	else
-		// verify a single file is not a directory (needed on Linux)
-		string entryFilepath = targetDirectory + g_fileSeparator + targetFilename;
-		if (stat(entryFilepath.c_str(), &statbuf) == 0 && (statbuf.st_mode & S_IFREG))
-	// check for unprocessed excludes
-	bool excludeErr = false;
-	for (size_t ix = 0; ix < excludeHitsVector.size(); ix++)
-		if (!excludeHitsVector[ix])
-			excludeErr = true;
-			if (!ignoreExcludeErrorsDisplay)
-				if (ignoreExcludeErrors)
-					printMsg(_("Exclude (unmatched)  %s\n"), excludeVector[ix]);
-				else
-					fprintf(stderr, _("Exclude (unmatched)  %s\n"), excludeVector[ix].c_str());
-			else
-				if (!ignoreExcludeErrors)
-	if (excludeErr && !ignoreExcludeErrors)
-		if (hasWildcard && !isRecursive)
-			fprintf(stderr, "%s\n", _("Did you intend to use --recursive"));
-		error();
-	// check if files were found (probably an input error if not)
-	if (fileName.empty())
-		fprintf(stderr, _("No file to process %s\n"), filePath.c_str());
-		error();
-	if (hasWildcard)
+        error();
+    bool hasMultipleTargets = false;
+    if (targetFilename.find_first_of(",;") != string::npos)
+        hasMultipleTargets = true;
+    // display directory name for wildcard processing
+    if (hasWildcard)
+        printSeparatingLine();
+        printMsg(_("Directory  %s\n"), targetDirectory + g_fileSeparator + targetFilename);
+    // clear exclude hits vector
+    size_t excludeHitsVectorSize = excludeHitsVector.size();
+    for (size_t ix = 0; ix < excludeHitsVectorSize; ix++)
+        excludeHitsVector[ix] = false;
+    // create a vector of paths and file names to process
+    if (hasWildcard || isRecursive || hasMultipleTargets)
+        getTargetFilenames(targetFilename, targetFilenameVector);
+        getFileNames(targetDirectory, targetFilenameVector);
+    else
+        // verify a single file is not a directory (needed on Linux)
+        string entryFilepath = targetDirectory + g_fileSeparator + targetFilename;
+        if (stat(entryFilepath.c_str(), &statbuf) == 0 && (statbuf.st_mode & S_IFREG))
+    // check for unprocessed excludes
+    bool excludeErr = false;
+    for (size_t ix = 0; ix < excludeHitsVector.size(); ix++)
+        if (!excludeHitsVector[ix])
+            excludeErr = true;
+            if (!ignoreExcludeErrorsDisplay)
+                if (ignoreExcludeErrors)
+                    printMsg(_("Exclude (unmatched)  %s\n"), excludeVector[ix]);
+                else
+                    fprintf(stderr, _("Exclude (unmatched)  %s\n"), excludeVector[ix].c_str());
+            else
+                if (!ignoreExcludeErrors)
+    if (excludeErr && !ignoreExcludeErrors)
+        if (hasWildcard && !isRecursive)
+            fprintf(stderr, "%s\n", _("Did you intend to use --recursive"));
+        error();
+    // check if files were found (probably an input error if not)
+    if (fileName.empty())
+        fprintf(stderr, _("No file to process %s\n"), filePath.c_str());
+        error();
+    if (hasWildcard)
 // Check if a file exists
 bool ASConsole::fileExists(const char* file) const
-	struct stat buf;
-	return (stat(file, &buf) == 0);
+    struct stat buf;
+    return (stat(file, &buf) == 0);
 bool ASConsole::fileNameVectorIsEmpty() const
-	return fileNameVector.empty();
+    return fileNameVector.empty();
 bool ASConsole::isOption(const string& arg, const char* op)
-	return arg.compare(op) == 0;
+    return arg.compare(op) == 0;
 bool ASConsole::isOption(const string& arg, const char* a, const char* b)
-	return (isOption(arg, a) || isOption(arg, b));
+    return (isOption(arg, a) || isOption(arg, b));
 bool ASConsole::isParamOption(const string& arg, const char* option)
-	bool retVal = arg.compare(0, strlen(option), option) == 0;
-	// if comparing for short option, 2nd char of arg must be numeric
-	if (retVal && strlen(option) == 1 && arg.length() > 1)
-		if (!isdigit((unsigned char) arg[1]))
-			retVal = false;
-	return retVal;
+    bool retVal = arg.compare(0, strlen(option), option) == 0;
+    // if comparing for short option, 2nd char of arg must be numeric
+    if (retVal && strlen(option) == 1 && arg.length() > 1)
+        if (!isdigit((unsigned char) arg[1]))
+            retVal = false;
+    return retVal;
 // compare a path to the exclude vector
@@ -1741,537 +1744,537 @@ bool ASConsole::isParamOption(const string& arg, const char* option)
 // return true if a match
 bool ASConsole::isPathExclued(const string& subPath)
-	bool retVal = false;
-	// read the exclude vector checking for a match
-	for (size_t i = 0; i < excludeVector.size(); i++)
-		string exclude = excludeVector[i];
-		if (subPath.length() < exclude.length())
-			continue;
-		size_t compareStart = subPath.length() - exclude.length();
-		// subPath compare must start with a directory name
-		if (compareStart > 0)
-			char lastPathChar = subPath[compareStart - 1];
-			if (lastPathChar != g_fileSeparator)
-				continue;
-		string compare = subPath.substr(compareStart);
-		if (!g_isCaseSensitive)
-			// make it case insensitive for Windows
-			for (size_t j = 0; j < compare.length(); j++)
-				compare[j] = (char) tolower(compare[j]);
-			for (size_t j = 0; j < exclude.length(); j++)
-				exclude[j] = (char) tolower(exclude[j]);
-		// compare sub directory to exclude data - must check them all
-		if (compare == exclude)
-			excludeHitsVector[i] = true;
-			retVal = true;
-			break;
-	return retVal;
+    bool retVal = false;
+    // read the exclude vector checking for a match
+    for (size_t i = 0; i < excludeVector.size(); i++)
+        string exclude = excludeVector[i];
+        if (subPath.length() < exclude.length())
+            continue;
+        size_t compareStart = subPath.length() - exclude.length();
+        // subPath compare must start with a directory name
+        if (compareStart > 0)
+            char lastPathChar = subPath[compareStart - 1];
+            if (lastPathChar != g_fileSeparator)
+                continue;
+        string compare = subPath.substr(compareStart);
+        if (!g_isCaseSensitive)
+            // make it case insensitive for Windows
+            for (size_t j = 0; j < compare.length(); j++)
+                compare[j] = (char) tolower(compare[j]);
+            for (size_t j = 0; j < exclude.length(); j++)
+                exclude[j] = (char) tolower(exclude[j]);
+        // compare sub directory to exclude data - must check them all
+        if (compare == exclude)
+            excludeHitsVector[i] = true;
+            retVal = true;
+            break;
+    return retVal;
 void ASConsole::printHelp() const
-	cout << endl;
-	cout << "                     Artistic Style " << g_version << endl;
-	cout << "                     Maintained by: Jim Pattee\n";
-	cout << "                     Original Author: Tal Davidson\n";
-	cout << endl;
-	cout << "Usage:\n";
-	cout << "------\n";
-	cout << "            astyle [OPTIONS] File1 File2 File3 [...]\n";
-	cout << endl;
-	cout << "            astyle [OPTIONS] < Original > Beautified\n";
-	cout << endl;
-	cout << "    When indenting a specific file, the resulting indented file RETAINS\n";
-	cout << "    the original file-name. The original pre-indented file is renamed,\n";
-	cout << "    with a suffix of \'.orig\' added to the original filename.\n";
-	cout << endl;
-	cout << "    Wildcards (* and ?) may be used in the filename.\n";
-	cout << "    A \'recursive\' option can process directories recursively.\n";
-	cout << "    Multiple file extensions may be separated by a comma.\n";
-	cout << endl;
-	cout << "    By default, astyle is set up to indent with four spaces per indent,\n";
-	cout << "    a maximal indentation of 40 spaces inside continuous statements,\n";
-	cout << "    a minimum indentation of eight spaces inside conditional statements,\n";
-	cout << "    and NO formatting options.\n";
-	cout << endl;
-	cout << "Options:\n";
-	cout << "--------\n";
-	cout << "    This  program  follows  the  usual  GNU  command line syntax.\n";
-	cout << "    Long options (starting with '--') must be written one at a time.\n";
-	cout << "    Short options (starting with '-') may be appended together.\n";
-	cout << "    Thus, -bps4 is the same as -b -p -s4.\n";
-	cout << endl;
-	cout << "Option Files:\n";
-	cout << "-------------\n";
-	cout << "    Artistic Style looks for a default option file and/or a project\n";
-	cout << "    option file in the following order:\n";
-	cout << "    1. The command line options have precedence.\n";
-	cout << "    2. The project option file has precedence over the default file\n";
-	cout << "       o the file name indicated by the --project= command line option.\n";
-	cout << "       o the file named .astylerc or _ astylerc.\n";
-	cout << "       o the file name identified by ARTISTIC_STYLE_PROJECT_OPTIONS.\n";
-	cout << "       o the file is disabled by --project=none on the command line.\n";
-	cout << "    3. The default option file that can be used for all projects.\n";
-	cout << "       o the file path indicated by the --options= command line option.\n";
-	cout << "       o the file path indicated by ARTISTIC_STYLE_OPTIONS.\n";
-	cout << "       o the file named .astylerc in the HOME directory (for Linux).\n";
-	cout << "       o the file name astylerc in the APPDATA directory (for Windows).\n";
-	cout << "    Long options within the option files may be written without '--'.\n";
-	cout << "    Line-end comments begin with a '#'.\n";
-	cout << endl;
-	cout << "Disable Formatting:\n";
-	cout << "-------------------\n";
-	cout << "    Disable Block\n";
-	cout << "    Blocks of code can be disabled with the comment tags *INDENT-OFF*\n";
-	cout << "    and *INDENT-ON*. It must be contained in a one-line comment.\n";
-	cout << endl;
-	cout << "    Disable Line\n";
-	cout << "    Padding of operators can be disabled on a single line using the\n";
-	cout << "    comment tag *NOPAD*. It must be contained in a line-end comment.\n";
-	cout << endl;
-	cout << "Brace Style Options:\n";
-	cout << "--------------------\n";
-	cout << "    default brace style\n";
-	cout << "    If no brace style is requested, the opening braces will not be\n";
-	cout << "    changed and closing braces will be broken from the preceding line.\n";
-	cout << endl;
-	cout << "    --style=allman  OR  --style=bsd  OR  --style=break  OR  -A1\n";
-	cout << "    Allman style formatting/indenting.\n";
-	cout << "    Broken braces.\n";
-	cout << endl;
-	cout << "    --style=java  OR  --style=attach  OR  -A2\n";
-	cout << "    Java style formatting/indenting.\n";
-	cout << "    Attached braces.\n";
-	cout << endl;
-	cout << "    --style=kr  OR  --style=k&r  OR  --style=k/r  OR  -A3\n";
-	cout << "    Kernighan & Ritchie style formatting/indenting.\n";
-	cout << "    Linux braces.\n";
-	cout << endl;
-	cout << "    --style=stroustrup  OR  -A4\n";
-	cout << "    Stroustrup style formatting/indenting.\n";
-	cout << endl;
-	cout << "    --style=whitesmith  OR  -A5\n";
-	cout << "    Whitesmith style formatting/indenting.\n";
-	cout << "    Broken, indented braces.\n";
-	cout << "    Indented class blocks and switch blocks.\n";
-	cout << endl;
-	cout << "    --style=vtk  OR  -A15\n";
-	cout << "    VTK style formatting/indenting.\n";
-	cout << "    Broken, indented braces except for the opening braces.\n";
-	cout << endl;
-	cout << "    --style=ratliff  OR  --style=banner  OR  -A6\n";
-	cout << "    Ratliff style formatting/indenting.\n";
-	cout << "    Attached, indented braces.\n";
-	cout << endl;
-	cout << "    --style=gnu  OR  -A7\n";
-	cout << "    GNU style formatting/indenting.\n";
-	cout << "    Broken braces, indented blocks.\n";
-	cout << endl;
-	cout << "    --style=linux  OR  --style=knf  OR  -A8\n";
-	cout << "    Linux style formatting/indenting.\n";
-	cout << "    Linux braces, minimum conditional indent is one-half indent.\n";
-	cout << endl;
-	cout << "    --style=horstmann  OR  --style=run-in  OR  -A9\n";
-	cout << "    Horstmann style formatting/indenting.\n";
-	cout << "    Run-in braces, indented switches.\n";
-	cout << endl;
-	cout << "    --style=1tbs  OR  --style=otbs  OR  -A10\n";
-	cout << "    One True Brace Style formatting/indenting.\n";
-	cout << "    Linux braces, add braces to all conditionals.\n";
-	cout << endl;
-	cout << "    --style=google  OR  -A14\n";
-	cout << "    Google style formatting/indenting.\n";
-	cout << "    Attached braces, indented class modifiers.\n";
-	cout << endl;
-	cout << "    --style=mozilla  OR  -A16\n";
-	cout << "    Mozilla style formatting/indenting.\n";
-	cout << "    Linux braces, with broken braces for structs and enums,\n";
-	cout << "    and attached braces for namespaces.\n";
-	cout << endl;
-	cout << "    --style=pico  OR  -A11\n";
-	cout << "    Pico style formatting/indenting.\n";
-	cout << "    Run-in opening braces and attached closing braces.\n";
-	cout << "    Uses keep one line blocks and keep one line statements.\n";
-	cout << endl;
-	cout << "    --style=lisp  OR  -A12\n";
-	cout << "    Lisp style formatting/indenting.\n";
-	cout << "    Attached opening braces and attached closing braces.\n";
-	cout << "    Uses keep one line statements.\n";
-	cout << endl;
-	cout << "Tab Options:\n";
-	cout << "------------\n";
-	cout << "    default indent option\n";
-	cout << "    If no indentation option is set, the default\n";
-	cout << "    option of 4 spaces per indent will be used.\n";
-	cout << endl;
-	cout << "    --indent=spaces=#  OR  -s#\n";
-	cout << "    Indent using # spaces per indent. Not specifying #\n";
-	cout << "    will result in a default of 4 spaces per indent.\n";
-	cout << endl;
-	cout << "    --indent=tab  OR  --indent=tab=#  OR  -t  OR  -t#\n";
-	cout << "    Indent using tab characters, assuming that each\n";
-	cout << "    indent is # spaces long. Not specifying # will result\n";
-	cout << "    in a default assumption of 4 spaces per indent.\n";
-	cout << endl;
-	cout << "    --indent=force-tab=#  OR  -T#\n";
-	cout << "    indent is # spaces long. Force tabs to be used in areas\n";
-	cout << "    AStyle would prefer to use spaces.\n";
-	cout << endl;
-	cout << "    --indent=force-tab-x=#  OR  -xT#\n";
-	cout << "    Allows the tab length to be set to a length that is different\n";
-	cout << "    from the indent length. This may cause the indentation to be\n";
-	cout << "    a mix of both spaces and tabs. This option sets the tab length.\n";
-	cout << endl;
-	cout << "Brace Modify Options:\n";
-	cout << "---------------------\n";
-	cout << "    --attach-namespaces  OR  -xn\n";
-	cout << "    Attach braces to a namespace statement.\n";
-	cout << endl;
-	cout << "    --attach-classes  OR  -xc\n";
-	cout << "    Attach braces to a class statement.\n";
-	cout << endl;
-	cout << "    --attach-inlines  OR  -xl\n";
-	cout << "    Attach braces to class inline function definitions.\n";
-	cout << endl;
-	cout << "    --attach-extern-c  OR  -xk\n";
-	cout << "    Attach braces to an extern \"C\" statement.\n";
-	cout << endl;
-	cout << "    --attach-closing-while  OR  -xV\n";
-	cout << "    Attach closing while of do-while to the closing brace.\n";
-	cout << endl;
-	cout << "Indentation Options:\n";
-	cout << "    --indent-classes  OR  -C\n";
-	cout << "    Indent 'class' blocks so that the entire block is indented.\n";
-	cout << endl;
-	cout << "    --indent-modifiers  OR  -xG\n";
-	cout << "    Indent 'class' access modifiers, 'public:', 'protected:' or\n";
-	cout << "    'private:', one half indent. The rest of the class is not\n";
-	cout << "    indented. \n";
-	cout << endl;
-	cout << "    --indent-switches  OR  -S\n";
-	cout << "    Indent 'switch' blocks, so that the inner 'case XXX:'\n";
-	cout << "    headers are indented in relation to the switch block.\n";
-	cout << endl;
-	cout << "    --indent-cases  OR  -K\n";
-	cout << "    Indent case blocks from the 'case XXX:' headers.\n";
-	cout << "    Case statements not enclosed in blocks are NOT indented.\n";
-	cout << endl;
-	cout << "    --indent-namespaces  OR  -N\n";
-	cout << "    Indent the contents of namespace blocks.\n";
-	cout << endl;
-	cout << "    --indent-after-parens  OR  -xU\n";
-	cout << "    Indent, instead of align, continuation lines following lines\n";
-	cout << "    that contain an opening paren '(' or an assignment '='. \n";
-	cout << endl;
-	cout << "    --indent-continuation=#  OR  -xt#\n";
-	cout << "    Indent continuation lines an additional # indents.\n";
-	cout << "    The valid values are 0 thru 4 indents.\n";
-	cout << "    The default value is 1 indent.\n";
-	cout << endl;
-	cout << "    --indent-labels  OR  -L\n";
-	cout << "    Indent labels so that they appear one indent less than\n";
-	cout << "    the current indentation level, rather than being\n";
-	cout << "    flushed completely to the left (which is the default).\n";
-	cout << endl;
-	cout << "    --indent-preproc-block  OR  -xW\n";
-	cout << "    Indent preprocessor blocks at brace level 0.\n";
-	cout << "    Without this option the preprocessor block is not indented.\n";
-	cout << endl;
-	cout << "    --indent-preproc-cond  OR  -xw\n";
-	cout << "    Indent preprocessor conditional statements #if/#else/#endif\n";
-	cout << "    to the same level as the source code.\n";
-	cout << endl;
-	cout << "    --indent-preproc-define  OR  -w\n";
-	cout << "    Indent multi-line preprocessor #define statements.\n";
-	cout << endl;
-	cout << "    --indent-col1-comments  OR  -Y\n";
-	cout << "    Indent line comments that start in column one.\n";
-	cout << endl;
-	cout << "    --min-conditional-indent=#  OR  -m#\n";
-	cout << "    Indent a minimal # spaces in a continuous conditional\n";
-	cout << "    belonging to a conditional header.\n";
-	cout << "    The valid values are:\n";
-	cout << "    0 - no minimal indent.\n";
-	cout << "    1 - indent at least one additional indent.\n";
-	cout << "    2 - indent at least two additional indents.\n";
-	cout << "    3 - indent at least one-half an additional indent.\n";
-	cout << "    The default value is 2, two additional indents.\n";
-	cout << endl;
-	cout << "    --max-continuation-indent=#  OR  -M#\n";
-	cout << "    Indent a maximal # spaces in a continuation line,\n";
-	cout << "    relative to the previous line.\n";
-	cout << "    The valid values are 40 thru 120.\n";
-	cout << "    The default value is 40.\n";
-	cout << endl;
-	cout << "Padding Options:\n";
-	cout << "----------------\n";
-	cout << "    --break-blocks  OR  -f\n";
-	cout << "    Insert empty lines around unrelated blocks, labels, classes, ...\n";
-	cout << endl;
-	cout << "    --break-blocks=all  OR  -F\n";
-	cout << "    Like --break-blocks, except also insert empty lines \n";
-	cout << "    around closing headers (e.g. 'else', 'catch', ...).\n";
-	cout << endl;
-	cout << "    --pad-oper  OR  -p\n";
-	cout << "    Insert space padding around operators.\n";
-	cout << endl;
-	cout << "    --pad-comma  OR  -xg\n";
-	cout << "    Insert space padding after commas.\n";
-	cout << endl;
-	cout << "    --pad-paren  OR  -P\n";
-	cout << "    Insert space padding around parenthesis on both the outside\n";
-	cout << "    and the inside.\n";
-	cout << endl;
-	cout << "    --pad-paren-out  OR  -d\n";
-	cout << "    Insert space padding around parenthesis on the outside only.\n";
-	cout << endl;
-	cout << "    --pad-first-paren-out  OR  -xd\n";
-	cout << "    Insert space padding around first parenthesis in a series on\n";
-	cout << "    the outside only.\n";
-	cout << endl;
-	cout << "    --pad-paren-in  OR  -D\n";
-	cout << "    Insert space padding around parenthesis on the inside only.\n";
-	cout << endl;
-	cout << "    --pad-header  OR  -H\n";
-	cout << "    Insert space padding after paren headers (e.g. 'if', 'for'...).\n";
-	cout << endl;
-	cout << "    --unpad-paren  OR  -U\n";
-	cout << "    Remove unnecessary space padding around parenthesis. This\n";
-	cout << "    can be used in combination with the 'pad' options above.\n";
-	cout << endl;
-	cout << "    --delete-empty-lines  OR  -xd\n";
-	cout << "    Delete empty lines within a function or method.\n";
-	cout << "    It will NOT delete lines added by the break-blocks options.\n";
-	cout << endl;
-	cout << "    --fill-empty-lines  OR  -E\n";
-	cout << "    Fill empty lines with the white space of their\n";
-	cout << "    previous lines.\n";
-	cout << endl;
-	cout << "    --align-pointer=type    OR  -k1\n";
-	cout << "    --align-pointer=middle  OR  -k2\n";
-	cout << "    --align-pointer=name    OR  -k3\n";
-	cout << "    Attach a pointer or reference operator (*, &, or ^) to either\n";
-	cout << "    the operator type (left), middle, or operator name (right).\n";
-	cout << "    To align the reference separately use --align-reference.\n";
-	cout << endl;
-	cout << "    --align-reference=none    OR  -W0\n";
-	cout << "    --align-reference=type    OR  -W1\n";
-	cout << "    --align-reference=middle  OR  -W2\n";
-	cout << "    --align-reference=name    OR  -W3\n";
-	cout << "    Attach a reference operator (&) to either\n";
-	cout << "    If not set, follow pointer alignment.\n";
-	cout << endl;
-	cout << "Formatting Options:\n";
-	cout << "    --break-closing-braces  OR  -y\n";
-	cout << "    Break braces before closing headers (e.g. 'else', 'catch', ...).\n";
-	cout << "    Use with --style=java, --style=kr, --style=stroustrup,\n";
-	cout << "    --style=linux, or --style=1tbs.\n";
-	cout << endl;
-	cout << "    --break-elseifs  OR  -e\n";
-	cout << "    Break 'else if()' statements into two different lines.\n";
-	cout << endl;
-	cout << "    --break-one-line-headers  OR  -xb\n";
-	cout << "    Break one line headers (e.g. 'if', 'while', 'else', ...) from a\n";
-	cout << "    statement residing on the same line.\n";
-	cout << endl;
-	cout << "    --add-braces  OR  -j\n";
-	cout << "    Add braces to unbraced one line conditional statements.\n";
-	cout << endl;
-	cout << "    --add-one-line-braces  OR  -J\n";
-	cout << "    Add one line braces to unbraced one line conditional\n";
-	cout << "    statements.\n";
-	cout << endl;
-	cout << "    --remove-braces  OR  -xj\n";
-	cout << "    Remove braces from a braced one line conditional statements.\n";
-	cout << endl;
-	cout << "    --break-return-type       OR  -xB\n";
-	cout << "    --break-return-type-decl  OR  -xD\n";
-	cout << "    Break the return type from the function name. Options are\n";
-	cout << "    for the function definitions and the function declarations.\n";
-	cout << endl;
-	cout << "    --attach-return-type       OR  -xf\n";
-	cout << "    --attach-return-type-decl  OR  -xh\n";
-	cout << "    Attach the return type to the function name. Options are\n";
-	cout << endl;
-	cout << "    --keep-one-line-blocks  OR  -O\n";
-	cout << "    Don't break blocks residing completely on one line.\n";
-	cout << endl;
-	cout << "    --keep-one-line-statements  OR  -o\n";
-	cout << "    Don't break lines containing multiple statements into\n";
-	cout << "    multiple single-statement lines.\n";
-	cout << endl;
-	cout << "    --convert-tabs  OR  -c\n";
-	cout << "    Convert tabs to the appropriate number of spaces.\n";
-	cout << endl;
-	cout << "    --close-templates  OR  -xy\n";
-	cout << "    Close ending angle brackets on template definitions.\n";
-	cout << endl;
-	cout << "    --remove-comment-prefix  OR  -xp\n";
-	cout << "    Remove the leading '*' prefix on multi-line comments and\n";
-	cout << "    indent the comment text one indent.\n";
-	cout << endl;
-	cout << "    --max-code-length=#    OR  -xC#\n";
-	cout << "    --break-after-logical  OR  -xL\n";
-	cout << "    max-code-length=# will break the line if it exceeds more than\n";
-	cout << "    # characters. The valid values are 50 thru 200.\n";
-	cout << "    If the line contains logical conditionals they will be placed\n";
-	cout << "    first on the new line. The option break-after-logical will\n";
-	cout << "    cause the logical conditional to be placed last on the\n";
-	cout << "    previous line.\n";
-	cout << endl;
-	cout << "    --mode=c\n";
-	cout << "    Indent a C or C++ source file (this is the default).\n";
-	cout << endl;
-	cout << "    --mode=java\n";
-	cout << "    Indent a Java source file.\n";
-	cout << endl;
-	cout << "    --mode=cs\n";
-	cout << "    Indent a C# source file.\n";
-	cout << endl;
-	cout << "Objective-C Options:\n";
-	cout << "    --pad-method-prefix  OR  -xQ\n";
-	cout << "    Insert space padding after the '-' or '+' Objective-C\n";
-	cout << "    method prefix.\n";
-	cout << endl;
-	cout << "    --unpad-method-prefix  OR  -xR\n";
-	cout << "    Remove all space padding after the '-' or '+' Objective-C\n";
-	cout << endl;
-	cout << "    --pad-return-type  OR  -xq\n";
-	cout << "    Insert space padding after the Objective-C return type.\n";
-	cout << endl;
-	cout << "    --unpad-return-type  OR  -xr\n";
-	cout << "    Remove all space padding after the Objective-C return type.\n";
-	cout << endl;
-	cout << "    --pad-param-type  OR  -xS\n";
-	cout << endl;
-	cout << "    --unpad-param-type  OR  -xs\n";
-	cout << endl;
-	cout << "    --align-method-colon  OR  -xM\n";
-	cout << "    Align the colons in an Objective-C method definition.\n";
-	cout << endl;
-	cout << "    --pad-method-colon=none    OR  -xP\n";
-	cout << "    --pad-method-colon=all     OR  -xP1\n";
-	cout << "    --pad-method-colon=after   OR  -xP2\n";
-	cout << "    --pad-method-colon=before  OR  -xP3\n";
-	cout << "    Add or remove space padding before or after the colons in an\n";
-	cout << "    Objective-C method call.\n";
-	cout << endl;
-	cout << "Other Options:\n";
-	cout << "--------------\n";
-	cout << "    --suffix=####\n";
-	cout << "    Append the suffix #### instead of '.orig' to original filename.\n";
-	cout << endl;
-	cout << "    --suffix=none  OR  -n\n";
-	cout << "    Do not retain a backup of the original file.\n";
-	cout << endl;
-	cout << "    --recursive  OR  -r  OR  -R\n";
-	cout << "    Process subdirectories recursively.\n";
-	cout << endl;
-	cout << "    --dry-run\n";
-	cout << "    Perform a trial run with no changes made to check for formatting.\n";
-	cout << endl;
-	cout << "    --exclude=####\n";
-	cout << "    Specify a file or directory #### to be excluded from processing.\n";
-	cout << endl;
-	cout << "    --ignore-exclude-errors  OR  -i\n";
-	cout << "    Allow processing to continue if there are errors in the exclude=####\n";
-	cout << "    options. It will display the unmatched excludes.\n";
-	cout << endl;
-	cout << "    --ignore-exclude-errors-x  OR  -xi\n";
-	cout << "    options. It will NOT display the unmatched excludes.\n";
-	cout << endl;
-	cout << "    --errors-to-stdout  OR  -X\n";
-	cout << "    Print errors and help information to standard-output rather than\n";
-	cout << "    to standard-error.\n";
-	cout << endl;
-	cout << "    --preserve-date  OR  -Z\n";
-	cout << "    Preserve the original file's date and time modified. The time\n";
-	cout << "     modified will be changed a few micro seconds to force a compile.\n";
-	cout << endl;
-	cout << "    --verbose  OR  -v\n";
-	cout << "    Verbose mode. Extra informational messages will be displayed.\n";
-	cout << endl;
-	cout << "    --formatted  OR  -Q\n";
-	cout << "    Formatted display mode. Display only the files that have been\n";
-	cout << "    formatted.\n";
-	cout << endl;
-	cout << "    --quiet  OR  -q\n";
-	cout << "    Quiet mode. Suppress all output except error messages.\n";
-	cout << endl;
-	cout << "    --lineend=windows  OR  -z1\n";
-	cout << "    --lineend=linux    OR  -z2\n";
-	cout << "    --lineend=macold   OR  -z3\n";
-	cout << "    Force use of the specified line end style. Valid options\n";
-	cout << "    are windows (CRLF), linux (LF), and macold (CR).\n";
-	cout << endl;
-	cout << "Command Line Only:\n";
-	cout << "------------------\n";
-	cout << "    --options=####\n";
-	cout << "    --options=none\n";
-	cout << "    Specify a default option file #### to read and use.\n";
-	cout << "    It must contain a file path and a file name.\n";
-	cout << "    'none' disables the default option file.\n";
-	cout << endl;
-	cout << "    --project\n";
-	cout << "    --project=####\n";
-	cout << "    --project=none\n";
-	cout << "    Specify a project option file #### to read and use.\n";
-	cout << "    It must contain a file name only, without a directory path.\n";
-	cout << "    The file should be included in the project top-level directory.\n";
-	cout << "    The default file name is .astylerc or _astylerc.\n";
-	cout << "    'none' disables the project or environment variable file.\n";
-	cout << endl;
-	cout << "    --ascii  OR  -I\n";
-	cout << "    The displayed output will be ascii characters only.\n";
-	cout << endl;
-	cout << "    --version  OR  -V\n";
-	cout << "    Print version number.\n";
-	cout << endl;
-	cout << "    --help  OR  -h  OR  -?\n";
-	cout << "    Print this help message.\n";
-	cout << endl;
-	cout << "    --html  OR  -!\n";
-	cout << "    Open the HTML help file \"astyle.html\" in the default browser.\n";
-	cout << "    The documentation must be installed in the standard install path.\n";
-	cout << endl;
-	cout << "    --html=####\n";
-	cout << "    Open a HTML help file in the default browser using the file path\n";
-	cout << "    ####. The path may include a directory path and a file name, or a\n";
-	cout << "    file name only. Paths containing spaces must be enclosed in quotes.\n";
-	cout << endl;
-	cout << "    --stdin=####\n";
-	cout << "    Use the file path #### as input to single file formatting.\n";
-	cout << "    This is a replacement for redirection.\n";
-	cout << endl;
-	cout << "    --stdout=####\n";
-	cout << "    Use the file path #### as output from single file formatting.\n";
-	cout << endl;
-	cout << endl;
+    cout << endl;
+    cout << "                     Artistic Style " << g_version << endl;
+    cout << "                     Maintained by: Jim Pattee\n";
+    cout << "                     Original Author: Tal Davidson\n";
+    cout << endl;
+    cout << "Usage:\n";
+    cout << "------\n";
+    cout << "            astyle [OPTIONS] File1 File2 File3 [...]\n";
+    cout << endl;
+    cout << "            astyle [OPTIONS] < Original > Beautified\n";
+    cout << endl;
+    cout << "    When indenting a specific file, the resulting indented file RETAINS\n";
+    cout << "    the original file-name. The original pre-indented file is renamed,\n";
+    cout << "    with a suffix of \'.orig\' added to the original filename.\n";
+    cout << endl;
+    cout << "    Wildcards (* and ?) may be used in the filename.\n";
+    cout << "    A \'recursive\' option can process directories recursively.\n";
+    cout << "    Multiple file extensions may be separated by a comma.\n";
+    cout << endl;
+    cout << "    By default, astyle is set up to indent with four spaces per indent,\n";
+    cout << "    a maximal indentation of 40 spaces inside continuous statements,\n";
+    cout << "    a minimum indentation of eight spaces inside conditional statements,\n";
+    cout << "    and NO formatting options.\n";
+    cout << endl;
+    cout << "Options:\n";
+    cout << "--------\n";
+    cout << "    This  program  follows  the  usual  GNU  command line syntax.\n";
+    cout << "    Long options (starting with '--') must be written one at a time.\n";
+    cout << "    Short options (starting with '-') may be appended together.\n";
+    cout << "    Thus, -bps4 is the same as -b -p -s4.\n";
+    cout << endl;
+    cout << "Option Files:\n";
+    cout << "-------------\n";
+    cout << "    Artistic Style looks for a default option file and/or a project\n";
+    cout << "    option file in the following order:\n";
+    cout << "    1. The command line options have precedence.\n";
+    cout << "    2. The project option file has precedence over the default file\n";
+    cout << "       o the file name indicated by the --project= command line option.\n";
+    cout << "       o the file named .astylerc or _ astylerc.\n";
+    cout << "       o the file name identified by ARTISTIC_STYLE_PROJECT_OPTIONS.\n";
+    cout << "       o the file is disabled by --project=none on the command line.\n";
+    cout << "    3. The default option file that can be used for all projects.\n";
+    cout << "       o the file path indicated by the --options= command line option.\n";
+    cout << "       o the file path indicated by ARTISTIC_STYLE_OPTIONS.\n";
+    cout << "       o the file named .astylerc in the HOME directory (for Linux).\n";
+    cout << "       o the file name astylerc in the APPDATA directory (for Windows).\n";
+    cout << "    Long options within the option files may be written without '--'.\n";
+    cout << "    Line-end comments begin with a '#'.\n";
+    cout << endl;
+    cout << "Disable Formatting:\n";
+    cout << "-------------------\n";
+    cout << "    Disable Block\n";
+    cout << "    Blocks of code can be disabled with the comment tags *INDENT-OFF*\n";
+    cout << "    and *INDENT-ON*. It must be contained in a one-line comment.\n";
+    cout << endl;
+    cout << "    Disable Line\n";
+    cout << "    Padding of operators can be disabled on a single line using the\n";
+    cout << "    comment tag *NOPAD*. It must be contained in a line-end comment.\n";
+    cout << endl;
+    cout << "Brace Style Options:\n";
+    cout << "--------------------\n";
+    cout << "    default brace style\n";
+    cout << "    If no brace style is requested, the opening braces will not be\n";
+    cout << "    changed and closing braces will be broken from the preceding line.\n";
+    cout << endl;
+    cout << "    --style=allman  OR  --style=bsd  OR  --style=break  OR  -A1\n";
+    cout << "    Allman style formatting/indenting.\n";
+    cout << "    Broken braces.\n";
+    cout << endl;
+    cout << "    --style=java  OR  --style=attach  OR  -A2\n";
+    cout << "    Java style formatting/indenting.\n";
+    cout << "    Attached braces.\n";
+    cout << endl;
+    cout << "    --style=kr  OR  --style=k&r  OR  --style=k/r  OR  -A3\n";
+    cout << "    Kernighan & Ritchie style formatting/indenting.\n";
+    cout << "    Linux braces.\n";
+    cout << endl;
+    cout << "    --style=stroustrup  OR  -A4\n";
+    cout << "    Stroustrup style formatting/indenting.\n";
+    cout << endl;
+    cout << "    --style=whitesmith  OR  -A5\n";
+    cout << "    Whitesmith style formatting/indenting.\n";
+    cout << "    Broken, indented braces.\n";
+    cout << "    Indented class blocks and switch blocks.\n";
+    cout << endl;
+    cout << "    --style=vtk  OR  -A15\n";
+    cout << "    VTK style formatting/indenting.\n";
+    cout << "    Broken, indented braces except for the opening braces.\n";
+    cout << endl;
+    cout << "    --style=ratliff  OR  --style=banner  OR  -A6\n";
+    cout << "    Ratliff style formatting/indenting.\n";
+    cout << "    Attached, indented braces.\n";
+    cout << endl;
+    cout << "    --style=gnu  OR  -A7\n";
+    cout << "    GNU style formatting/indenting.\n";
+    cout << "    Broken braces, indented blocks.\n";
+    cout << endl;
+    cout << "    --style=linux  OR  --style=knf  OR  -A8\n";
+    cout << "    Linux style formatting/indenting.\n";
+    cout << "    Linux braces, minimum conditional indent is one-half indent.\n";
+    cout << endl;
+    cout << "    --style=horstmann  OR  --style=run-in  OR  -A9\n";
+    cout << "    Horstmann style formatting/indenting.\n";
+    cout << "    Run-in braces, indented switches.\n";
+    cout << endl;
+    cout << "    --style=1tbs  OR  --style=otbs  OR  -A10\n";
+    cout << "    One True Brace Style formatting/indenting.\n";
+    cout << "    Linux braces, add braces to all conditionals.\n";
+    cout << endl;
+    cout << "    --style=google  OR  -A14\n";
+    cout << "    Google style formatting/indenting.\n";
+    cout << "    Attached braces, indented class modifiers.\n";
+    cout << endl;
+    cout << "    --style=mozilla  OR  -A16\n";
+    cout << "    Mozilla style formatting/indenting.\n";
+    cout << "    Linux braces, with broken braces for structs and enums,\n";
+    cout << "    and attached braces for namespaces.\n";
+    cout << endl;
+    cout << "    --style=pico  OR  -A11\n";
+    cout << "    Pico style formatting/indenting.\n";
+    cout << "    Run-in opening braces and attached closing braces.\n";
+    cout << "    Uses keep one line blocks and keep one line statements.\n";
+    cout << endl;
+    cout << "    --style=lisp  OR  -A12\n";
+    cout << "    Lisp style formatting/indenting.\n";
+    cout << "    Attached opening braces and attached closing braces.\n";
+    cout << "    Uses keep one line statements.\n";
+    cout << endl;
+    cout << "Tab Options:\n";
+    cout << "------------\n";
+    cout << "    default indent option\n";
+    cout << "    If no indentation option is set, the default\n";
+    cout << "    option of 4 spaces per indent will be used.\n";
+    cout << endl;
+    cout << "    --indent=spaces=#  OR  -s#\n";
+    cout << "    Indent using # spaces per indent. Not specifying #\n";
+    cout << "    will result in a default of 4 spaces per indent.\n";
+    cout << endl;
+    cout << "    --indent=tab  OR  --indent=tab=#  OR  -t  OR  -t#\n";
+    cout << "    Indent using tab characters, assuming that each\n";
+    cout << "    indent is # spaces long. Not specifying # will result\n";
+    cout << "    in a default assumption of 4 spaces per indent.\n";
+    cout << endl;
+    cout << "    --indent=force-tab=#  OR  -T#\n";
+    cout << "    indent is # spaces long. Force tabs to be used in areas\n";
+    cout << "    AStyle would prefer to use spaces.\n";
+    cout << endl;
+    cout << "    --indent=force-tab-x=#  OR  -xT#\n";
+    cout << "    Allows the tab length to be set to a length that is different\n";
+    cout << "    from the indent length. This may cause the indentation to be\n";
+    cout << "    a mix of both spaces and tabs. This option sets the tab length.\n";
+    cout << endl;
+    cout << "Brace Modify Options:\n";
+    cout << "---------------------\n";
+    cout << "    --attach-namespaces  OR  -xn\n";
+    cout << "    Attach braces to a namespace statement.\n";
+    cout << endl;
+    cout << "    --attach-classes  OR  -xc\n";
+    cout << "    Attach braces to a class statement.\n";
+    cout << endl;
+    cout << "    --attach-inlines  OR  -xl\n";
+    cout << "    Attach braces to class inline function definitions.\n";
+    cout << endl;
+    cout << "    --attach-extern-c  OR  -xk\n";
+    cout << "    Attach braces to an extern \"C\" statement.\n";
+    cout << endl;
+    cout << "    --attach-closing-while  OR  -xV\n";
+    cout << "    Attach closing while of do-while to the closing brace.\n";
+    cout << endl;
+    cout << "Indentation Options:\n";
+    cout << "    --indent-classes  OR  -C\n";
+    cout << "    Indent 'class' blocks so that the entire block is indented.\n";
+    cout << endl;
+    cout << "    --indent-modifiers  OR  -xG\n";
+    cout << "    Indent 'class' access modifiers, 'public:', 'protected:' or\n";
+    cout << "    'private:', one half indent. The rest of the class is not\n";
+    cout << "    indented. \n";
+    cout << endl;
+    cout << "    --indent-switches  OR  -S\n";
+    cout << "    Indent 'switch' blocks, so that the inner 'case XXX:'\n";
+    cout << "    headers are indented in relation to the switch block.\n";
+    cout << endl;
+    cout << "    --indent-cases  OR  -K\n";
+    cout << "    Indent case blocks from the 'case XXX:' headers.\n";
+    cout << "    Case statements not enclosed in blocks are NOT indented.\n";
+    cout << endl;
+    cout << "    --indent-namespaces  OR  -N\n";
+    cout << "    Indent the contents of namespace blocks.\n";
+    cout << endl;
+    cout << "    --indent-after-parens  OR  -xU\n";
+    cout << "    Indent, instead of align, continuation lines following lines\n";
+    cout << "    that contain an opening paren '(' or an assignment '='. \n";
+    cout << endl;
+    cout << "    --indent-continuation=#  OR  -xt#\n";
+    cout << "    Indent continuation lines an additional # indents.\n";
+    cout << "    The valid values are 0 thru 4 indents.\n";
+    cout << "    The default value is 1 indent.\n";
+    cout << endl;
+    cout << "    --indent-labels  OR  -L\n";
+    cout << "    Indent labels so that they appear one indent less than\n";
+    cout << "    the current indentation level, rather than being\n";
+    cout << "    flushed completely to the left (which is the default).\n";
+    cout << endl;
+    cout << "    --indent-preproc-block  OR  -xW\n";
+    cout << "    Indent preprocessor blocks at brace level 0.\n";
+    cout << "    Without this option the preprocessor block is not indented.\n";
+    cout << endl;
+    cout << "    --indent-preproc-cond  OR  -xw\n";
+    cout << "    Indent preprocessor conditional statements #if/#else/#endif\n";
+    cout << "    to the same level as the source code.\n";
+    cout << endl;
+    cout << "    --indent-preproc-define  OR  -w\n";
+    cout << "    Indent multi-line preprocessor #define statements.\n";
+    cout << endl;
+    cout << "    --indent-col1-comments  OR  -Y\n";
+    cout << "    Indent line comments that start in column one.\n";
+    cout << endl;
+    cout << "    --min-conditional-indent=#  OR  -m#\n";
+    cout << "    Indent a minimal # spaces in a continuous conditional\n";
+    cout << "    belonging to a conditional header.\n";
+    cout << "    The valid values are:\n";
+    cout << "    0 - no minimal indent.\n";
+    cout << "    1 - indent at least one additional indent.\n";
+    cout << "    2 - indent at least two additional indents.\n";
+    cout << "    3 - indent at least one-half an additional indent.\n";
+    cout << "    The default value is 2, two additional indents.\n";
+    cout << endl;
+    cout << "    --max-continuation-indent=#  OR  -M#\n";
+    cout << "    Indent a maximal # spaces in a continuation line,\n";
+    cout << "    relative to the previous line.\n";
+    cout << "    The valid values are 40 thru 120.\n";
+    cout << "    The default value is 40.\n";
+    cout << endl;
+    cout << "Padding Options:\n";
+    cout << "----------------\n";
+    cout << "    --break-blocks  OR  -f\n";
+    cout << "    Insert empty lines around unrelated blocks, labels, classes, ...\n";
+    cout << endl;
+    cout << "    --break-blocks=all  OR  -F\n";
+    cout << "    Like --break-blocks, except also insert empty lines \n";
+    cout << "    around closing headers (e.g. 'else', 'catch', ...).\n";
+    cout << endl;
+    cout << "    --pad-oper  OR  -p\n";
+    cout << "    Insert space padding around operators.\n";
+    cout << endl;
+    cout << "    --pad-comma  OR  -xg\n";
+    cout << "    Insert space padding after commas.\n";
+    cout << endl;
+    cout << "    --pad-paren  OR  -P\n";
+    cout << "    Insert space padding around parenthesis on both the outside\n";
+    cout << "    and the inside.\n";
+    cout << endl;
+    cout << "    --pad-paren-out  OR  -d\n";
+    cout << "    Insert space padding around parenthesis on the outside only.\n";
+    cout << endl;
+    cout << "    --pad-first-paren-out  OR  -xd\n";
+    cout << "    Insert space padding around first parenthesis in a series on\n";
+    cout << "    the outside only.\n";
+    cout << endl;
+    cout << "    --pad-paren-in  OR  -D\n";
+    cout << "    Insert space padding around parenthesis on the inside only.\n";
+    cout << endl;
+    cout << "    --pad-header  OR  -H\n";
+    cout << "    Insert space padding after paren headers (e.g. 'if', 'for'...).\n";
+    cout << endl;
+    cout << "    --unpad-paren  OR  -U\n";
+    cout << "    Remove unnecessary space padding around parenthesis. This\n";
+    cout << "    can be used in combination with the 'pad' options above.\n";
+    cout << endl;
+    cout << "    --delete-empty-lines  OR  -xd\n";
+    cout << "    Delete empty lines within a function or method.\n";
+    cout << "    It will NOT delete lines added by the break-blocks options.\n";
+    cout << endl;
+    cout << "    --fill-empty-lines  OR  -E\n";
+    cout << "    Fill empty lines with the white space of their\n";
+    cout << "    previous lines.\n";
+    cout << endl;
+    cout << "    --align-pointer=type    OR  -k1\n";
+    cout << "    --align-pointer=middle  OR  -k2\n";
+    cout << "    --align-pointer=name    OR  -k3\n";
+    cout << "    Attach a pointer or reference operator (*, &, or ^) to either\n";
+    cout << "    the operator type (left), middle, or operator name (right).\n";
+    cout << "    To align the reference separately use --align-reference.\n";
+    cout << endl;
+    cout << "    --align-reference=none    OR  -W0\n";
+    cout << "    --align-reference=type    OR  -W1\n";
+    cout << "    --align-reference=middle  OR  -W2\n";
+    cout << "    --align-reference=name    OR  -W3\n";
+    cout << "    Attach a reference operator (&) to either\n";
+    cout << "    If not set, follow pointer alignment.\n";
+    cout << endl;
+    cout << "Formatting Options:\n";
+    cout << "    --break-closing-braces  OR  -y\n";
+    cout << "    Break braces before closing headers (e.g. 'else', 'catch', ...).\n";
+    cout << "    Use with --style=java, --style=kr, --style=stroustrup,\n";
+    cout << "    --style=linux, or --style=1tbs.\n";
+    cout << endl;
+    cout << "    --break-elseifs  OR  -e\n";
+    cout << "    Break 'else if()' statements into two different lines.\n";
+    cout << endl;
+    cout << "    --break-one-line-headers  OR  -xb\n";
+    cout << "    Break one line headers (e.g. 'if', 'while', 'else', ...) from a\n";
+    cout << "    statement residing on the same line.\n";
+    cout << endl;
+    cout << "    --add-braces  OR  -j\n";
+    cout << "    Add braces to unbraced one line conditional statements.\n";
+    cout << endl;
+    cout << "    --add-one-line-braces  OR  -J\n";
+    cout << "    Add one line braces to unbraced one line conditional\n";
+    cout << "    statements.\n";
+    cout << endl;
+    cout << "    --remove-braces  OR  -xj\n";
+    cout << "    Remove braces from a braced one line conditional statements.\n";
+    cout << endl;
+    cout << "    --break-return-type       OR  -xB\n";
+    cout << "    --break-return-type-decl  OR  -xD\n";
+    cout << "    Break the return type from the function name. Options are\n";
+    cout << "    for the function definitions and the function declarations.\n";
+    cout << endl;
+    cout << "    --attach-return-type       OR  -xf\n";
+    cout << "    --attach-return-type-decl  OR  -xh\n";
+    cout << "    Attach the return type to the function name. Options are\n";
+    cout << endl;
+    cout << "    --keep-one-line-blocks  OR  -O\n";
+    cout << "    Don't break blocks residing completely on one line.\n";
+    cout << endl;
+    cout << "    --keep-one-line-statements  OR  -o\n";
+    cout << "    Don't break lines containing multiple statements into\n";
+    cout << "    multiple single-statement lines.\n";
+    cout << endl;
+    cout << "    --convert-tabs  OR  -c\n";
+    cout << "    Convert tabs to the appropriate number of spaces.\n";
+    cout << endl;
+    cout << "    --close-templates  OR  -xy\n";
+    cout << "    Close ending angle brackets on template definitions.\n";
+    cout << endl;
+    cout << "    --remove-comment-prefix  OR  -xp\n";
+    cout << "    Remove the leading '*' prefix on multi-line comments and\n";
+    cout << "    indent the comment text one indent.\n";
+    cout << endl;
+    cout << "    --max-code-length=#    OR  -xC#\n";
+    cout << "    --break-after-logical  OR  -xL\n";
+    cout << "    max-code-length=# will break the line if it exceeds more than\n";
+    cout << "    # characters. The valid values are 50 thru 200.\n";
+    cout << "    If the line contains logical conditionals they will be placed\n";
+    cout << "    first on the new line. The option break-after-logical will\n";
+    cout << "    cause the logical conditional to be placed last on the\n";
+    cout << "    previous line.\n";
+    cout << endl;
+    cout << "    --mode=c\n";
+    cout << "    Indent a C or C++ source file (this is the default).\n";
+    cout << endl;
+    cout << "    --mode=java\n";
+    cout << "    Indent a Java source file.\n";
+    cout << endl;
+    cout << "    --mode=cs\n";
+    cout << "    Indent a C# source file.\n";
+    cout << endl;
+    cout << "Objective-C Options:\n";
+    cout << "    --pad-method-prefix  OR  -xQ\n";
+    cout << "    Insert space padding after the '-' or '+' Objective-C\n";
+    cout << "    method prefix.\n";
+    cout << endl;
+    cout << "    --unpad-method-prefix  OR  -xR\n";
+    cout << "    Remove all space padding after the '-' or '+' Objective-C\n";
+    cout << endl;
+    cout << "    --pad-return-type  OR  -xq\n";
+    cout << "    Insert space padding after the Objective-C return type.\n";
+    cout << endl;
+    cout << "    --unpad-return-type  OR  -xr\n";
+    cout << "    Remove all space padding after the Objective-C return type.\n";
+    cout << endl;
+    cout << "    --pad-param-type  OR  -xS\n";
+    cout << endl;
+    cout << "    --unpad-param-type  OR  -xs\n";
+    cout << endl;
+    cout << "    --align-method-colon  OR  -xM\n";
+    cout << "    Align the colons in an Objective-C method definition.\n";
+    cout << endl;
+    cout << "    --pad-method-colon=none    OR  -xP\n";
+    cout << "    --pad-method-colon=all     OR  -xP1\n";
+    cout << "    --pad-method-colon=after   OR  -xP2\n";
+    cout << "    --pad-method-colon=before  OR  -xP3\n";
+    cout << "    Add or remove space padding before or after the colons in an\n";
+    cout << "    Objective-C method call.\n";
+    cout << endl;
+    cout << "Other Options:\n";
+    cout << "--------------\n";
+    cout << "    --suffix=####\n";
+    cout << "    Append the suffix #### instead of '.orig' to original filename.\n";
+    cout << endl;
+    cout << "    --suffix=none  OR  -n\n";
+    cout << "    Do not retain a backup of the original file.\n";
+    cout << endl;
+    cout << "    --recursive  OR  -r  OR  -R\n";
+    cout << "    Process subdirectories recursively.\n";
+    cout << endl;
+    cout << "    --dry-run\n";
+    cout << "    Perform a trial run with no changes made to check for formatting.\n";
+    cout << endl;
+    cout << "    --exclude=####\n";
+    cout << "    Specify a file or directory #### to be excluded from processing.\n";
+    cout << endl;
+    cout << "    --ignore-exclude-errors  OR  -i\n";
+    cout << "    Allow processing to continue if there are errors in the exclude=####\n";
+    cout << "    options. It will display the unmatched excludes.\n";
+    cout << endl;
+    cout << "    --ignore-exclude-errors-x  OR  -xi\n";
+    cout << "    options. It will NOT display the unmatched excludes.\n";
+    cout << endl;
+    cout << "    --errors-to-stdout  OR  -X\n";
+    cout << "    Print errors and help information to standard-output rather than\n";
+    cout << "    to standard-error.\n";
+    cout << endl;
+    cout << "    --preserve-date  OR  -Z\n";
+    cout << "    Preserve the original file's date and time modified. The time\n";
+    cout << "     modified will be changed a few micro seconds to force a compile.\n";
+    cout << endl;
+    cout << "    --verbose  OR  -v\n";
+    cout << "    Verbose mode. Extra informational messages will be displayed.\n";
+    cout << endl;
+    cout << "    --formatted  OR  -Q\n";
+    cout << "    Formatted display mode. Display only the files that have been\n";
+    cout << "    formatted.\n";
+    cout << endl;
+    cout << "    --quiet  OR  -q\n";
+    cout << "    Quiet mode. Suppress all output except error messages.\n";
+    cout << endl;
+    cout << "    --lineend=windows  OR  -z1\n";
+    cout << "    --lineend=linux    OR  -z2\n";
+    cout << "    --lineend=macold   OR  -z3\n";
+    cout << "    Force use of the specified line end style. Valid options\n";
+    cout << "    are windows (CRLF), linux (LF), and macold (CR).\n";
+    cout << endl;
+    cout << "Command Line Only:\n";
+    cout << "------------------\n";
+    cout << "    --options=####\n";
+    cout << "    --options=none\n";
+    cout << "    Specify a default option file #### to read and use.\n";
+    cout << "    It must contain a file path and a file name.\n";
+    cout << "    'none' disables the default option file.\n";
+    cout << endl;
+    cout << "    --project\n";
+    cout << "    --project=####\n";
+    cout << "    --project=none\n";
+    cout << "    Specify a project option file #### to read and use.\n";
+    cout << "    It must contain a file name only, without a directory path.\n";
+    cout << "    The file should be included in the project top-level directory.\n";
+    cout << "    The default file name is .astylerc or _astylerc.\n";
+    cout << "    'none' disables the project or environment variable file.\n";
+    cout << endl;
+    cout << "    --ascii  OR  -I\n";
+    cout << "    The displayed output will be ascii characters only.\n";
+    cout << endl;
+    cout << "    --version  OR  -V\n";
+    cout << "    Print version number.\n";
+    cout << endl;
+    cout << "    --help  OR  -h  OR  -?\n";
+    cout << "    Print this help message.\n";
+    cout << endl;
+    cout << "    --html  OR  -!\n";
+    cout << "    Open the HTML help file \"astyle.html\" in the default browser.\n";
+    cout << "    The documentation must be installed in the standard install path.\n";
+    cout << endl;
+    cout << "    --html=####\n";
+    cout << "    Open a HTML help file in the default browser using the file path\n";
+    cout << "    ####. The path may include a directory path and a file name, or a\n";
+    cout << "    file name only. Paths containing spaces must be enclosed in quotes.\n";
+    cout << endl;
+    cout << "    --stdin=####\n";
+    cout << "    Use the file path #### as input to single file formatting.\n";
+    cout << "    This is a replacement for redirection.\n";
+    cout << endl;
+    cout << "    --stdout=####\n";
+    cout << "    Use the file path #### as output from single file formatting.\n";
+    cout << endl;
+    cout << endl;
@@ -2279,24 +2282,24 @@ void ASConsole::printHelp() const
 void ASConsole::processFiles()
-	if (isVerbose)
-		printVerboseHeader();
+    if (isVerbose)
+        printVerboseHeader();
-	clock_t startTime = clock();     // start time of file formatting
+    clock_t startTime = clock();     // start time of file formatting
-	// loop thru input fileNameVector and process the files
-	for (size_t i = 0; i < fileNameVector.size(); i++)
-		getFilePaths(fileNameVector[i]);
+    // loop thru input fileNameVector and process the files
+    for (size_t i = 0; i < fileNameVector.size(); i++)
+        getFilePaths(fileNameVector[i]);
-		// loop thru fileName vector formatting the files
-		for (size_t j = 0; j < fileName.size(); j++)
-			formatFile(fileName[j]);
+        // loop thru fileName vector formatting the files
+        for (size_t j = 0; j < fileName.size(); j++)
+            formatFile(fileName[j]);
-	// files are processed, display stats
-	if (isVerbose)
-		printVerboseStats(startTime);
+    // files are processed, display stats
+    if (isVerbose)
+        printVerboseStats(startTime);
 // process options from the command line and option files
@@ -2304,276 +2307,276 @@ void ASConsole::processFiles()
 // projectOptionsVector and fileOptionsVector
 void ASConsole::processOptions(const vector<string>& argvOptions)
-	string arg;
-	bool ok = true;
-	bool optionFileRequired = false;
-	bool shouldParseOptionFile = true;
-	bool projectOptionFileRequired = false;
-	bool shouldParseProjectOptionFile = true;
-	string projectOptionArg;		// save for display
-	// get command line options
-	for (size_t i = 0; i < argvOptions.size(); i++)
-		arg = argvOptions[i];
-		if (isOption(arg, "-I")
-		        || isOption(arg, "--ascii"))
-			useAscii = true;
-			setlocale(LC_ALL, "C");		// use English decimal indicator
-			localizer.setLanguageFromName("en");
-		else if (isOption(arg, "--options=none"))
-			optionFileRequired = false;
-			shouldParseOptionFile = false;
-			optionFileName = "";
-		else if (isParamOption(arg, "--options="))
-			optionFileName = getParam(arg, "--options=");
-			standardizePath(optionFileName);
-			optionFileName = getFullPathName(optionFileName);
-			optionFileRequired = true;
-		else if (isOption(arg, "--project=none"))
-			projectOptionFileRequired = false;
-			shouldParseProjectOptionFile = false;
-			setProjectOptionFileName("");
-		else if (isParamOption(arg, "--project="))
-			projectOptionFileName = getParam(arg, "--project=");
-			standardizePath(projectOptionFileName);
-			projectOptionFileRequired = true;
-			projectOptionArg = projectOptionFileName;
-		else if (isOption(arg, "--project"))
-			projectOptionFileName = ".astylerc";
-		else if (isOption(arg, "-h")
-		         || isOption(arg, "--help")
-		         || isOption(arg, "-?"))
-			printHelp();
-			exit(EXIT_SUCCESS);
-		else if (isOption(arg, "-!")
-		         || isOption(arg, "--html"))
-			launchDefaultBrowser();
-		else if (isParamOption(arg, "--html="))
-			string htmlFilePath = getParam(arg, "--html=");
-			launchDefaultBrowser(htmlFilePath.c_str());
-		else if (isOption(arg, "-V")
-		         || isOption(arg, "--version"))
-			printf("Artistic Style Version %s\n", g_version);
-		else if (isParamOption(arg, "--stdin="))
-			string path = getParam(arg, "--stdin=");
-			standardizePath(path);
-			setStdPathIn(path);
-		else if (isParamOption(arg, "--stdout="))
-			string path = getParam(arg, "--stdout=");
-			setStdPathOut(path);
-		else if (arg[0] == '-')
-			optionsVector.emplace_back(arg);
-		else // file-name
-			standardizePath(arg);
-			fileNameVector.emplace_back(arg);
-	// get option file path and name
-	if (shouldParseOptionFile)
-		if (optionFileName.empty())
-			char* env = getenv("ARTISTIC_STYLE_OPTIONS");
-			if (env != nullptr)
-				setOptionFileName(env);
-		// for Linux
-				string name = string(env) + "/.astylerc";
-				if (fileExists(name.c_str()))
-					setOptionFileName(name);
-		// for Windows
-			char* env = getenv("APPDATA");
-				string name = string(env) + "\\astylerc";
-		// for Windows
-		// NOTE: depreciated with release 3.1, remove when appropriate
-		// there is NO test data for this option
-			char* env = getenv("USERPROFILE");
-	// find project option file
-	if (projectOptionFileRequired)
-		string optfilepath = findProjectOptionFilePath(projectOptionFileName);
-		if (optfilepath.empty() || projectOptionArg.empty())
-			error(_("Cannot open project option file"), projectOptionArg.c_str());
-		standardizePath(optfilepath);
-		setProjectOptionFileName(optfilepath);
-	if (shouldParseProjectOptionFile)
-		char* env = getenv("ARTISTIC_STYLE_PROJECT_OPTIONS");
-			string optfilepath = findProjectOptionFilePath(env);
-	ASOptions options(formatter, *this);
-	if (!optionFileName.empty())
-		stringstream optionsIn;
-		if (!fileExists(optionFileName.c_str()))
-			error(_("Cannot open default option file"), optionFileName.c_str());
-		FileEncoding encoding = readFile(optionFileName, optionsIn);
-		// bypass a BOM, all BOMs have been converted to utf-8
-		if (encoding == UTF_8BOM || encoding == UTF_16LE || encoding == UTF_16BE)
-			char buf[4];
-			optionsIn.get(buf, 4);
-			assert(strcmp(buf, "\xEF\xBB\xBF") == 0);
-		options.importOptions(optionsIn, fileOptionsVector);
-		ok = options.parseOptions(fileOptionsVector,
-		                          string(_("Invalid default options:")));
-	else if (optionFileRequired)
-	if (!ok)
-		(*errorStream) << options.getOptionErrors();
-		(*errorStream) << _("For help on options type 'astyle -h'") << endl;
-		error();
-	if (!projectOptionFileName.empty())
-		stringstream projectOptionsIn;
-		if (!fileExists(projectOptionFileName.c_str()))
-			error(_("Cannot open project option file"), projectOptionFileName.c_str());
-		FileEncoding encoding = readFile(projectOptionFileName, projectOptionsIn);
-			char buf[4];
-			projectOptionsIn.get(buf, 4);
-		options.importOptions(projectOptionsIn, projectOptionsVector);
-		ok = options.parseOptions(projectOptionsVector,
-		                          string(_("Invalid project options:")));
-	if (!ok)
-		error();
-	// parse the command line options vector for errors
-	ok = options.parseOptions(optionsVector,
-	                          string(_("Invalid command line options:")));
-	if (!ok)
-		error();
+    string arg;
+    bool ok = true;
+    bool optionFileRequired = false;
+    bool shouldParseOptionFile = true;
+    bool projectOptionFileRequired = false;
+    bool shouldParseProjectOptionFile = true;
+    string projectOptionArg;        // save for display
+    // get command line options
+    for (size_t i = 0; i < argvOptions.size(); i++)
+        arg = argvOptions[i];
+        if (isOption(arg, "-I")
+                || isOption(arg, "--ascii"))
+            useAscii = true;
+            setlocale(LC_ALL, "C");     // use English decimal indicator
+            localizer.setLanguageFromName("en");
+        else if (isOption(arg, "--options=none"))
+            optionFileRequired = false;
+            shouldParseOptionFile = false;
+            optionFileName = "";
+        else if (isParamOption(arg, "--options="))
+            optionFileName = getParam(arg, "--options=");
+            standardizePath(optionFileName);
+            optionFileName = getFullPathName(optionFileName);
+            optionFileRequired = true;
+        else if (isOption(arg, "--project=none"))
+            projectOptionFileRequired = false;
+            shouldParseProjectOptionFile = false;
+            setProjectOptionFileName("");
+        else if (isParamOption(arg, "--project="))
+            projectOptionFileName = getParam(arg, "--project=");
+            standardizePath(projectOptionFileName);
+            projectOptionFileRequired = true;
+            projectOptionArg = projectOptionFileName;
+        else if (isOption(arg, "--project"))
+            projectOptionFileName = ".astylerc";
+        else if (isOption(arg, "-h")
+                 || isOption(arg, "--help")
+                 || isOption(arg, "-?"))
+            printHelp();
+            exit(EXIT_SUCCESS);
+        else if (isOption(arg, "-!")
+                 || isOption(arg, "--html"))
+            launchDefaultBrowser();
+        else if (isParamOption(arg, "--html="))
+            string htmlFilePath = getParam(arg, "--html=");
+            launchDefaultBrowser(htmlFilePath.c_str());
+        else if (isOption(arg, "-V")
+                 || isOption(arg, "--version"))
+            printf("Artistic Style Version %s\n", g_version);
+        else if (isParamOption(arg, "--stdin="))
+            string path = getParam(arg, "--stdin=");
+            standardizePath(path);
+            setStdPathIn(path);
+        else if (isParamOption(arg, "--stdout="))
+            string path = getParam(arg, "--stdout=");
+            setStdPathOut(path);
+        else if (arg[0] == '-')
+            optionsVector.emplace_back(arg);
+        else // file-name
+            standardizePath(arg);
+            fileNameVector.emplace_back(arg);
+    // get option file path and name
+    if (shouldParseOptionFile)
+        if (optionFileName.empty())
+            char* env = getenv("ARTISTIC_STYLE_OPTIONS");
+            if (env != nullptr)
+                setOptionFileName(env);
+        // for Linux
+            char* env = getenv("HOME");
+                string name = string(env) + "/.astylerc";
+                if (fileExists(name.c_str()))
+                    setOptionFileName(name);
+        // for Windows
+            char* env = getenv("APPDATA");
+                string name = string(env) + "\\astylerc";
+        // for Windows
+        // NOTE: depreciated with release 3.1, remove when appropriate
+        // there is NO test data for this option
+            char* env = getenv("USERPROFILE");
+    // find project option file
+    if (projectOptionFileRequired)
+        string optfilepath = findProjectOptionFilePath(projectOptionFileName);
+        if (optfilepath.empty() || projectOptionArg.empty())
+            error(_("Cannot open project option file"), projectOptionArg.c_str());
+        standardizePath(optfilepath);
+        setProjectOptionFileName(optfilepath);
+    if (shouldParseProjectOptionFile)
+        char* env = getenv("ARTISTIC_STYLE_PROJECT_OPTIONS");
+            string optfilepath = findProjectOptionFilePath(env);
+    ASOptions options(formatter, *this);
+    if (!optionFileName.empty())
+        stringstream optionsIn;
+        if (!fileExists(optionFileName.c_str()))
+            error(_("Cannot open default option file"), optionFileName.c_str());
+        FileEncoding encoding = readFile(optionFileName, optionsIn);
+        // bypass a BOM, all BOMs have been converted to utf-8
+        if (encoding == UTF_8BOM || encoding == UTF_16LE || encoding == UTF_16BE)
+            char buf[4];
+            optionsIn.get(buf, 4);
+            assert(strcmp(buf, "\xEF\xBB\xBF") == 0);
+        options.importOptions(optionsIn, fileOptionsVector);
+        ok = options.parseOptions(fileOptionsVector,
+                                  string(_("Invalid default options:")));
+    else if (optionFileRequired)
+    if (!ok)
+        (*errorStream) << options.getOptionErrors();
+        (*errorStream) << _("For help on options type 'astyle -h'") << endl;
+        error();
+    if (!projectOptionFileName.empty())
+        stringstream projectOptionsIn;
+        if (!fileExists(projectOptionFileName.c_str()))
+            error(_("Cannot open project option file"), projectOptionFileName.c_str());
+        FileEncoding encoding = readFile(projectOptionFileName, projectOptionsIn);
+            char buf[4];
+            projectOptionsIn.get(buf, 4);
+        options.importOptions(projectOptionsIn, projectOptionsVector);
+        ok = options.parseOptions(projectOptionsVector,
+                                  string(_("Invalid project options:")));
+    if (!ok)
+        error();
+    // parse the command line options vector for errors
+    ok = options.parseOptions(optionsVector,
+                              string(_("Invalid command line options:")));
+    if (!ok)
+        error();
 // remove a file and check for an error
 void ASConsole::removeFile(const char* fileName_, const char* errMsg) const
-	if (remove(fileName_) != 0)
-		if (errno == ENOENT)        // no file is OK
-			errno = 0;
-		if (errno)
-			perror("errno message");
-			error(errMsg, fileName_);
+    if (remove(fileName_) != 0)
+        if (errno == ENOENT)        // no file is OK
+            errno = 0;
+        if (errno)
+            perror("errno message");
+            error(errMsg, fileName_);
 // rename a file and check for an error
 void ASConsole::renameFile(const char* oldFileName, const char* newFileName, const char* errMsg) const
-	int result = rename(oldFileName, newFileName);
-	if (result != 0)
-		// if file still exists the remove needs more time - retry
-		if (errno == EEXIST)
-			errno = 0;
-			waitForRemove(newFileName);
-			result = rename(oldFileName, newFileName);
-		if (result != 0)
-			error(errMsg, oldFileName);
+    int result = rename(oldFileName, newFileName);
+    if (result != 0)
+        // if file still exists the remove needs more time - retry
+        if (errno == EEXIST)
+            errno = 0;
+            waitForRemove(newFileName);
+            result = rename(oldFileName, newFileName);
+        if (result != 0)
+            error(errMsg, oldFileName);
 // make sure file separators are correct type (Windows or Linux)
@@ -2582,197 +2585,197 @@ void ASConsole::renameFile(const char* oldFileName, const char* newFileName, con
 void ASConsole::standardizePath(string& path, bool removeBeginningSeparator /*false*/) const
 #ifdef __VMS
-	struct FAB fab;
-	struct NAML naml;
-	char less[NAML$C_MAXRSS];
-	char sess[NAM$C_MAXRSS];
-	int r0_status;
-	// If we are on a VMS system, translate VMS style filenames to unix
-	// style.
-	fab = cc$rms_fab;
-	fab.fab$l_fna = (char*) -1;
-	fab.fab$b_fns = 0;
-	fab.fab$l_naml = &naml;
-	naml = cc$rms_naml;
-	strcpy(sess, path.c_str());
-	naml.naml$l_long_filename = (char*) sess;
-	naml.naml$l_long_filename_size = path.length();
-	naml.naml$l_long_expand = less;
-	naml.naml$l_long_expand_alloc = sizeof(less);
-	naml.naml$l_esa = sess;
-	naml.naml$b_ess = sizeof(sess);
-	naml.naml$v_no_short_upcase = 1;
-	r0_status = sys$parse(&fab);
-	if (r0_status == RMS$_SYN)
-		error("File syntax error", path.c_str());
-	else
-		if (!$VMS_STATUS_SUCCESS(r0_status))
-			(void) lib$signal(r0_status);
-	less[naml.naml$l_long_expand_size - naml.naml$b_ver] = '\0';
-	sess[naml.naml$b_esl - naml.naml$b_ver] = '\0';
-	if (naml.naml$l_long_expand_size > naml.naml$b_esl)
-		path = decc$translate_vms(less);
-	else
-		path = decc$translate_vms(sess);
+    struct FAB fab;
+    struct NAML naml;
+    char less[NAML$C_MAXRSS];
+    char sess[NAM$C_MAXRSS];
+    int r0_status;
+    // If we are on a VMS system, translate VMS style filenames to unix
+    // style.
+    fab = cc$rms_fab;
+    fab.fab$l_fna = (char*) -1;
+    fab.fab$b_fns = 0;
+    fab.fab$l_naml = &naml;
+    naml = cc$rms_naml;
+    strcpy(sess, path.c_str());
+    naml.naml$l_long_filename = (char*) sess;
+    naml.naml$l_long_filename_size = path.length();
+    naml.naml$l_long_expand = less;
+    naml.naml$l_long_expand_alloc = sizeof(less);
+    naml.naml$l_esa = sess;
+    naml.naml$b_ess = sizeof(sess);
+    naml.naml$v_no_short_upcase = 1;
+    r0_status = sys$parse(&fab);
+    if (r0_status == RMS$_SYN)
+        error("File syntax error", path.c_str());
+    else
+        if (!$VMS_STATUS_SUCCESS(r0_status))
+            (void) lib$signal(r0_status);
+    less[naml.naml$l_long_expand_size - naml.naml$b_ver] = '\0';
+    sess[naml.naml$b_esl - naml.naml$b_ver] = '\0';
+    if (naml.naml$l_long_expand_size > naml.naml$b_esl)
+        path = decc$translate_vms(less);
+    else
+        path = decc$translate_vms(sess);
 #endif /* __VMS */
-	// make sure separators are correct type (Windows or Linux)
-	for (size_t i = 0; i < path.length(); i++)
-		i = path.find_first_of("/\\", i);
-		if (i == string::npos)
-			break;
-		path[i] = g_fileSeparator;
-	// remove beginning separator if requested
-	if (removeBeginningSeparator && (path[0] == g_fileSeparator))
-		path.erase(0, 1);
+    // make sure separators are correct type (Windows or Linux)
+    for (size_t i = 0; i < path.length(); i++)
+        i = path.find_first_of("/\\", i);
+        if (i == string::npos)
+            break;
+        path[i] = g_fileSeparator;
+    // remove beginning separator if requested
+    if (removeBeginningSeparator && (path[0] == g_fileSeparator))
+        path.erase(0, 1);
 void ASConsole::printMsg(const char* msg, const string& data) const
-	if (isQuiet)
-		return;
-	printf(msg, data.c_str());
+    if (isQuiet)
+        return;
+    printf(msg, data.c_str());
 void ASConsole::printSeparatingLine() const
-	string line;
-	for (size_t i = 0; i < 60; i++)
-		line.append("-");
-	printMsg("%s\n", line);
+    string line;
+    for (size_t i = 0; i < 60; i++)
+        line.append("-");
+    printMsg("%s\n", line);
 void ASConsole::printVerboseHeader() const
-	assert(isVerbose);
-	if (isQuiet)
-		return;
-	// get the date
-	time_t lt;
-	char str[20];
-	lt = time(nullptr);
-	struct tm* ptr = localtime(&lt);
-	strftime(str, 20, "%x", ptr);
-	// print the header
-	// 60 is the length of the separator in printSeparatingLine()
-	string header = "Artistic Style " + string(g_version);
-	size_t numSpaces = 60 - header.length() - strlen(str);
-	header.append(numSpaces, ' ');
-	header.append(str);
-	header.append("\n");
-	printf("%s", header.c_str());
-	// print option files
-		printf(_("Default option file  %s\n"), optionFileName.c_str());
-		if (env != nullptr && optionFileName == string(env) + "\\astylerc")
-			printf("The above option file has been DEPRECIATED\n");
-	// end depreciated
-		printf(_("Project option file  %s\n"), projectOptionFileName.c_str());
+    assert(isVerbose);
+    if (isQuiet)
+        return;
+    // get the date
+    time_t lt;
+    char str[20];
+    lt = time(nullptr);
+    struct tm* ptr = localtime(&lt);
+    strftime(str, 20, "%x", ptr);
+    // print the header
+    // 60 is the length of the separator in printSeparatingLine()
+    string header = "Artistic Style " + string(g_version);
+    size_t numSpaces = 60 - header.length() - strlen(str);
+    header.append(numSpaces, ' ');
+    header.append(str);
+    header.append("\n");
+    printf("%s", header.c_str());
+    // print option files
+        printf(_("Default option file  %s\n"), optionFileName.c_str());
+        if (env != nullptr && optionFileName == string(env) + "\\astylerc")
+            printf("The above option file has been DEPRECIATED\n");
+    // end depreciated
+        printf(_("Project option file  %s\n"), projectOptionFileName.c_str());
 void ASConsole::printVerboseStats(clock_t startTime) const
-	if (isQuiet)
-		return;
-	if (hasWildcard)
-		printSeparatingLine();
-	string formatted = getNumberFormat(filesFormatted);
-	string unchanged = getNumberFormat(filesUnchanged);
-	printf(_(" %s formatted   %s unchanged   "), formatted.c_str(), unchanged.c_str());
-	// show processing time
-	clock_t stopTime = clock();
-	double secs = (stopTime - startTime) / double(CLOCKS_PER_SEC);
-	if (secs < 60)
-		if (secs < 2.0)
-			printf("%.2f", secs);
-		else if (secs < 20.0)
-			printf("%.1f", secs);
-		else
-			printf("%.0f", secs);
-		printf("%s", _(" seconds   "));
-	else
-		// show minutes and seconds if time is greater than one minute
-		int min = (int) secs / 60;
-		secs -= min * 60;
-		int minsec = int(secs + .5);
-		printf(_("%d min %d sec   "), min, minsec);
-	string lines = getNumberFormat(linesOut);
-	printf(_("%s lines\n"), lines.c_str());
-	printf("\n");
+    if (isQuiet)
+        return;
+    if (hasWildcard)
+        printSeparatingLine();
+    string formatted = getNumberFormat(filesFormatted);
+    string unchanged = getNumberFormat(filesUnchanged);
+    printf(_(" %s formatted   %s unchanged   "), formatted.c_str(), unchanged.c_str());
+    // show processing time
+    clock_t stopTime = clock();
+    double secs = (stopTime - startTime) / double(CLOCKS_PER_SEC);
+    if (secs < 60)
+        if (secs < 2.0)
+            printf("%.2f", secs);
+        else if (secs < 20.0)
+            printf("%.1f", secs);
+        else
+            printf("%.0f", secs);
+        printf("%s", _(" seconds   "));
+    else
+        // show minutes and seconds if time is greater than one minute
+        int min = (int) secs / 60;
+        secs -= min * 60;
+        int minsec = int(secs + .5);
+        printf(_("%d min %d sec   "), min, minsec);
+    string lines = getNumberFormat(linesOut);
+    printf(_("%s lines\n"), lines.c_str());
+    printf("\n");
 void ASConsole::sleep(int seconds) const
-	clock_t endwait;
-	endwait = clock_t(clock() + seconds * CLOCKS_PER_SEC);
-	while (clock() < endwait) {}
+    clock_t endwait;
+    endwait = clock_t(clock() + seconds * CLOCKS_PER_SEC);
+    while (clock() < endwait) {}
 bool ASConsole::stringEndsWith(const string& str, const string& suffix) const
-	int strIndex = (int) str.length() - 1;
-	int suffixIndex = (int) suffix.length() - 1;
-	while (strIndex >= 0 && suffixIndex >= 0)
-		if (tolower(str[strIndex]) != tolower(suffix[suffixIndex]))
-			return false;
-		--strIndex;
-		--suffixIndex;
-	// suffix longer than string
-	if (strIndex < 0 && suffixIndex >= 0)
-		return false;
-	return true;
+    int strIndex = (int) str.length() - 1;
+    int suffixIndex = (int) suffix.length() - 1;
+    while (strIndex >= 0 && suffixIndex >= 0)
+        if (tolower(str[strIndex]) != tolower(suffix[suffixIndex]))
+            return false;
+        --strIndex;
+        --suffixIndex;
+    // suffix longer than string
+    if (strIndex < 0 && suffixIndex >= 0)
+        return false;
+    return true;
 void ASConsole::updateExcludeVector(const string& suffixParam)
-	excludeVector.emplace_back(suffixParam);
-	standardizePath(excludeVector.back(), true);
-	excludeHitsVector.push_back(false);
+    excludeVector.emplace_back(suffixParam);
+    standardizePath(excludeVector.back(), true);
+    excludeHitsVector.push_back(false);
 int ASConsole::waitForRemove(const char* newFileName) const
-	struct stat stBuf;
-	int seconds;
-	// sleep a max of 20 seconds for the remove
-	for (seconds = 1; seconds <= 20; seconds++)
-		sleep(1);
-		if (stat(newFileName, &stBuf) != 0)
-			break;
-	errno = 0;
-	return seconds;
+    struct stat stBuf;
+    int seconds;
+    // sleep a max of 20 seconds for the remove
+    for (seconds = 1; seconds <= 20; seconds++)
+        sleep(1);
+        if (stat(newFileName, &stBuf) != 0)
+            break;
+    errno = 0;
+    return seconds;
 // From The Code Project http://www.codeproject.com/string/wildcmp.asp
@@ -2780,178 +2783,178 @@ int ASConsole::waitForRemove(const char* newFileName) const
 // Modified to compare case insensitive for Windows
 int ASConsole::wildcmp(const char* wild, const char* data) const
-	const char* cp = nullptr, *mp = nullptr;
-	bool cmpval;
-	while ((*data) && (*wild != '*'))
-		if (!g_isCaseSensitive)
-			cmpval = (tolower(*wild) != tolower(*data)) && (*wild != '?');
-		else
-			cmpval = (*wild != *data) && (*wild != '?');
-		if (cmpval)
-			return 0;
-		wild++;
-		data++;
-	while (*data)
-		if (*wild == '*')
-			if (!*++wild)
-				return 1;
-			mp = wild;
-			cp = data + 1;
-		else
-				cmpval = (tolower(*wild) == tolower(*data) || (*wild == '?'));
-			else
-				cmpval = (*wild == *data) || (*wild == '?');
-			if (cmpval)
-				wild++;
-				data++;
-			else
-				wild = mp;
-				data = cp++;
-	while (*wild == '*')
-		wild++;
-	return !*wild;
+    const char* cp = nullptr, *mp = nullptr;
+    bool cmpval;
+    while ((*data) && (*wild != '*'))
+        if (!g_isCaseSensitive)
+            cmpval = (tolower(*wild) != tolower(*data)) && (*wild != '?');
+        else
+            cmpval = (*wild != *data) && (*wild != '?');
+        if (cmpval)
+            return 0;
+        wild++;
+        data++;
+    while (*data)
+        if (*wild == '*')
+            if (!*++wild)
+                return 1;
+            mp = wild;
+            cp = data + 1;
+        else
+                cmpval = (tolower(*wild) == tolower(*data) || (*wild == '?'));
+            else
+                cmpval = (*wild == *data) || (*wild == '?');
+            if (cmpval)
+                wild++;
+                data++;
+            else
+                wild = mp;
+                data = cp++;
+    while (*wild == '*')
+        wild++;
+    return !*wild;
 void ASConsole::writeFile(const string& fileName_, FileEncoding encoding, ostringstream& out) const
-	// save date accessed and date modified of original file
-	bool statErr = false;
-	if (stat(fileName_.c_str(), &stBuf) == -1)
-		statErr = true;
-	// create a backup
-	if (!noBackup)
-		string origFileName = fileName_ + origSuffix;
-		removeFile(origFileName.c_str(), "Cannot remove pre-existing backup file");
-		renameFile(fileName_.c_str(), origFileName.c_str(), "Cannot create backup file");
-	// write the output file
-	ofstream fout(fileName_.c_str(), ios::binary | ios::trunc);
-	if (!fout)
-		error("Cannot open output file", fileName_.c_str());
-	if (encoding == UTF_16LE || encoding == UTF_16BE)
-		// convert utf-8 to utf-16
-		bool isBigEndian = (encoding == UTF_16BE);
-		size_t utf16Size = encode.utf16LengthFromUtf8(out.str().c_str(), out.str().length());
-		char* utf16Out = new char[utf16Size];
-		size_t utf16Len = encode.utf8ToUtf16(const_cast<char*>(out.str().c_str()),
-		                                     out.str().length(), isBigEndian, utf16Out);
-		assert(utf16Len <= utf16Size);
-		fout << string(utf16Out, utf16Len);
-		delete[] utf16Out;
-	else
-		fout << out.str();
-	fout.close();
-	// change date modified to original file date
-	// Embarcadero must be linked with cw32mt not cw32
-	if (preserveDate)
-		if (!statErr)
-			struct utimbuf outBuf;
-			outBuf.actime = stBuf.st_atime;
-			// add ticks so 'make' will recognize a change
-			// Visual Studio 2008 needs more than 1
-			outBuf.modtime = stBuf.st_mtime + 10;
-			if (utime(fileName_.c_str(), &outBuf) == -1)
-				statErr = true;
-		if (statErr)
-			(*errorStream) << "*********  Cannot preserve file date" << endl;
+    // save date accessed and date modified of original file
+    bool statErr = false;
+    if (stat(fileName_.c_str(), &stBuf) == -1)
+        statErr = true;
+    // create a backup
+    if (!noBackup)
+        string origFileName = fileName_ + origSuffix;
+        removeFile(origFileName.c_str(), "Cannot remove pre-existing backup file");
+        renameFile(fileName_.c_str(), origFileName.c_str(), "Cannot create backup file");
+    // write the output file
+    ofstream fout(fileName_.c_str(), ios::binary | ios::trunc);
+    if (!fout)
+        error("Cannot open output file", fileName_.c_str());
+    if (encoding == UTF_16LE || encoding == UTF_16BE)
+        // convert utf-8 to utf-16
+        bool isBigEndian = (encoding == UTF_16BE);
+        size_t utf16Size = encode.utf16LengthFromUtf8(out.str().c_str(), out.str().length());
+        char* utf16Out = new char[utf16Size];
+        size_t utf16Len = encode.utf8ToUtf16(const_cast<char*>(out.str().c_str()),
+                                             out.str().length(), isBigEndian, utf16Out);
+        assert(utf16Len <= utf16Size);
+        fout << string(utf16Out, utf16Len);
+        delete[] utf16Out;
+    else
+        fout << out.str();
+    fout.close();
+    // change date modified to original file date
+    // Embarcadero must be linked with cw32mt not cw32
+    if (preserveDate)
+        if (!statErr)
+            struct utimbuf outBuf;
+            outBuf.actime = stBuf.st_atime;
+            // add ticks so 'make' will recognize a change
+            // Visual Studio 2008 needs more than 1
+            outBuf.modtime = stBuf.st_mtime + 10;
+            if (utime(fileName_.c_str(), &outBuf) == -1)
+                statErr = true;
+        if (statErr)
+            (*errorStream) << "*********  Cannot preserve file date" << endl;
-#else	// ASTYLE_LIB
+#else   // ASTYLE_LIB
 // ASLibrary class
 // used by shared object (DLL) calls
-char16_t* ASLibrary::formatUtf16(const char16_t* pSourceIn,		// the source to be formatted
-                                 const char16_t* pOptions,		// AStyle options
-                                 fpError fpErrorHandler,		// error handler function
-                                 fpAlloc fpMemoryAlloc) const	// memory allocation function)
+char16_t* ASLibrary::formatUtf16(const char16_t* pSourceIn,     // the source to be formatted
+                                 const char16_t* pOptions,      // AStyle options
+                                 fpError fpErrorHandler,        // error handler function
+                                 fpAlloc fpMemoryAlloc) const   // memory allocation function)
-	const char* utf8In = convertUtf16ToUtf8(pSourceIn);
-	if (utf8In == nullptr)
-		fpErrorHandler(121, "Cannot convert input utf-16 to utf-8.");
-		return nullptr;
-	const char* utf8Options = convertUtf16ToUtf8(pOptions);
-	if (utf8Options == nullptr)
-		delete[] utf8In;
-		fpErrorHandler(122, "Cannot convert options utf-16 to utf-8.");
-		return nullptr;
-	// call the Artistic Style formatting function
-	// cannot use the callers memory allocation here
-	char* utf8Out = AStyleMain(utf8In,
-	                           utf8Options,
-	                           fpErrorHandler,
-	                           ASLibrary::tempMemoryAllocation);
-	// finished with these
-	delete[] utf8In;
-	delete[] utf8Options;
-	utf8In = nullptr;
-	utf8Options = nullptr;
-	// AStyle error has already been sent
-	if (utf8Out == nullptr)
-		return nullptr;
-	// convert text to wide char and return it
-	char16_t* utf16Out = convertUtf8ToUtf16(utf8Out, fpMemoryAlloc);
-	delete[] utf8Out;
-	utf8Out = nullptr;
-	if (utf16Out == nullptr)
-		fpErrorHandler(123, "Cannot convert output utf-8 to utf-16.");
-		return nullptr;
-	return utf16Out;
+    const char* utf8In = convertUtf16ToUtf8(pSourceIn);
+    if (utf8In == nullptr)
+        fpErrorHandler(121, "Cannot convert input utf-16 to utf-8.");
+        return nullptr;
+    const char* utf8Options = convertUtf16ToUtf8(pOptions);
+    if (utf8Options == nullptr)
+        delete[] utf8In;
+        fpErrorHandler(122, "Cannot convert options utf-16 to utf-8.");
+        return nullptr;
+    // call the Artistic Style formatting function
+    // cannot use the callers memory allocation here
+    char* utf8Out = AStyleMain(utf8In,
+                               utf8Options,
+                               fpErrorHandler,
+                               ASLibrary::tempMemoryAllocation);
+    // finished with these
+    delete[] utf8In;
+    delete[] utf8Options;
+    utf8In = nullptr;
+    utf8Options = nullptr;
+    // AStyle error has already been sent
+    if (utf8Out == nullptr)
+        return nullptr;
+    // convert text to wide char and return it
+    char16_t* utf16Out = convertUtf8ToUtf16(utf8Out, fpMemoryAlloc);
+    delete[] utf8Out;
+    utf8Out = nullptr;
+    if (utf16Out == nullptr)
+        fpErrorHandler(123, "Cannot convert output utf-8 to utf-16.");
+        return nullptr;
+    return utf16Out;
 // STATIC method to allocate temporary memory for AStyle formatting.
 // The data will be converted before being returned to the calling program.
 char* STDCALL ASLibrary::tempMemoryAllocation(unsigned long memoryNeeded)
-	char* buffer = new (nothrow) char[memoryNeeded];
-	return buffer;
+    char* buffer = new (nothrow) char[memoryNeeded];
+    return buffer;
@@ -2961,24 +2964,24 @@ char* STDCALL ASLibrary::tempMemoryAllocation(unsigned long memoryNeeded)
 char16_t* ASLibrary::convertUtf8ToUtf16(const char* utf8In, fpAlloc fpMemoryAlloc) const
-		return nullptr;
-	char* data = const_cast<char*>(utf8In);
-	size_t dataSize = strlen(utf8In);
-	bool isBigEndian = encode.getBigEndian();
-	// return size is in number of CHARs, not char16_t
-	size_t utf16Size = (encode.utf16LengthFromUtf8(data, dataSize) + sizeof(char16_t));
-	char* utf16Out = fpMemoryAlloc((long) utf16Size);
-		return nullptr;
+        return nullptr;
+    char* data = const_cast<char*>(utf8In);
+    size_t dataSize = strlen(utf8In);
+    bool isBigEndian = encode.getBigEndian();
+    // return size is in number of CHARs, not char16_t
+    size_t utf16Size = (encode.utf16LengthFromUtf8(data, dataSize) + sizeof(char16_t));
+    char* utf16Out = fpMemoryAlloc((long) utf16Size);
+        return nullptr;
 #ifdef NDEBUG
-	encode.utf8ToUtf16(data, dataSize + 1, isBigEndian, utf16Out);
+    encode.utf8ToUtf16(data, dataSize + 1, isBigEndian, utf16Out);
 #else
-	size_t utf16Len = encode.utf8ToUtf16(data, dataSize + 1, isBigEndian, utf16Out);
-	assert(utf16Len == utf16Size);
+    size_t utf16Len = encode.utf8ToUtf16(data, dataSize + 1, isBigEndian, utf16Out);
+    assert(utf16Len == utf16Size);
 #endif
-	assert(utf16Size == (encode.utf16len(reinterpret_cast<char16_t*>(utf16Out)) + 1) * sizeof(char16_t));
-	return reinterpret_cast<char16_t*>(utf16Out);
+    assert(utf16Size == (encode.utf16len(reinterpret_cast<char16_t*>(utf16Out)) + 1) * sizeof(char16_t));
+    return reinterpret_cast<char16_t*>(utf16Out);
@@ -2988,27 +2991,27 @@ char16_t* ASLibrary::convertUtf8ToUtf16(const char* utf8In, fpAlloc fpMemoryAllo
 char* ASLibrary::convertUtf16ToUtf8(const char16_t* utf16In) const
-	if (utf16In == nullptr)
-		return nullptr;
-	char* data = reinterpret_cast<char*>(const_cast<char16_t*>(utf16In));
-	// size must be in chars
-	size_t dataSize = encode.utf16len(utf16In) * sizeof(char16_t);
-	size_t utf8Size = encode.utf8LengthFromUtf16(data, dataSize, isBigEndian) + 1;
-	char* utf8Out = new (nothrow) char[utf8Size];
-		return nullptr;
+    if (utf16In == nullptr)
+        return nullptr;
+    char* data = reinterpret_cast<char*>(const_cast<char16_t*>(utf16In));
+    // size must be in chars
+    size_t dataSize = encode.utf16len(utf16In) * sizeof(char16_t);
+    size_t utf8Size = encode.utf8LengthFromUtf16(data, dataSize, isBigEndian) + 1;
+    char* utf8Out = new (nothrow) char[utf8Size];
+        return nullptr;
 #ifdef NDEBUG
-	encode.utf16ToUtf8(data, dataSize + 1, isBigEndian, true, utf8Out);
+    encode.utf16ToUtf8(data, dataSize + 1, isBigEndian, true, utf8Out);
 #else
-	size_t utf8Len = encode.utf16ToUtf8(data, dataSize + 1, isBigEndian, true, utf8Out);
-	assert(utf8Len == utf8Size);
+    size_t utf8Len = encode.utf16ToUtf8(data, dataSize + 1, isBigEndian, true, utf8Out);
+    assert(utf8Len == utf8Size);
 #endif
-	assert(utf8Size == strlen(utf8Out) + 1);
-	return utf8Out;
+    assert(utf8Size == strlen(utf8Out) + 1);
+    return utf8Out;
-#endif	// ASTYLE_LIB
+#endif  // ASTYLE_LIB
 // ASOptions class
@@ -3017,11 +3020,11 @@ char* ASLibrary::convertUtf16ToUtf8(const char16_t* utf16In) const
 #ifdef ASTYLE_LIB
 ASOptions::ASOptions(ASFormatter& formatterArg)
-	: formatter(formatterArg)
+    : formatter(formatterArg)
 #else
 ASOptions::ASOptions(ASFormatter& formatterArg, ASConsole& consoleArg)
-	: formatter(formatterArg), console(consoleArg)
+    : formatter(formatterArg), console(consoleArg)
 #endif
@@ -3035,765 +3038,765 @@ ASOptions::ASOptions(ASFormatter& formatterArg, ASConsole& consoleArg)
 bool ASOptions::parseOptions(vector<string>& optionsVector, const string& errorInfo)
-	vector<string>::iterator option;
-	string arg, subArg;
-	optionErrors.clear();
-	for (option = optionsVector.begin(); option != optionsVector.end(); ++option)
-		arg = *option;
-		if (arg.compare(0, 2, "--") == 0)
-			parseOption(arg.substr(2), errorInfo);
-			size_t i;
-			for (i = 1; i < arg.length(); ++i)
-				if (i > 1
-				        && isalpha((unsigned char) arg[i])
-				        && arg[i - 1] != 'x')
-					// parse the previous option in subArg
-					parseOption(subArg, errorInfo);
-					subArg = "";
-				// append the current option to subArg
-				subArg.append(1, arg[i]);
-			// parse the last option
-			subArg = "";
-		else
-			parseOption(arg, errorInfo);
-			subArg = "";
-	if (optionErrors.str().length() > 0)
-		return false;
-	return true;
+    vector<string>::iterator option;
+    string arg, subArg;
+    optionErrors.clear();
+    for (option = optionsVector.begin(); option != optionsVector.end(); ++option)
+        arg = *option;
+        if (arg.compare(0, 2, "--") == 0)
+            parseOption(arg.substr(2), errorInfo);
+            size_t i;
+            for (i = 1; i < arg.length(); ++i)
+                if (i > 1
+                        && isalpha((unsigned char) arg[i])
+                        && arg[i - 1] != 'x')
+                    // parse the previous option in subArg
+                    parseOption(subArg, errorInfo);
+                    subArg = "";
+                // append the current option to subArg
+                subArg.append(1, arg[i]);
+            // parse the last option
+            subArg = "";
+        else
+            parseOption(arg, errorInfo);
+            subArg = "";
+    if (optionErrors.str().length() > 0)
+        return false;
+    return true;
 void ASOptions::parseOption(const string& arg, const string& errorInfo)
-	if (isOption(arg, "A1", "style=allman") || isOption(arg, "style=bsd") || isOption(arg, "style=break"))
-		formatter.setFormattingStyle(STYLE_ALLMAN);
-	else if (isOption(arg, "A2", "style=java") || isOption(arg, "style=attach"))
-		formatter.setFormattingStyle(STYLE_JAVA);
-	else if (isOption(arg, "A3", "style=k&r") || isOption(arg, "style=kr") || isOption(arg, "style=k/r"))
-		formatter.setFormattingStyle(STYLE_KR);
-	else if (isOption(arg, "A4", "style=stroustrup"))
-		formatter.setFormattingStyle(STYLE_STROUSTRUP);
-	else if (isOption(arg, "A5", "style=whitesmith"))
-		formatter.setFormattingStyle(STYLE_WHITESMITH);
-	else if (isOption(arg, "A15", "style=vtk"))
-		formatter.setFormattingStyle(STYLE_VTK);
-	else if (isOption(arg, "A6", "style=ratliff") || isOption(arg, "style=banner"))
-		formatter.setFormattingStyle(STYLE_RATLIFF);
-	else if (isOption(arg, "A7", "style=gnu"))
-		formatter.setFormattingStyle(STYLE_GNU);
-	else if (isOption(arg, "A8", "style=linux") || isOption(arg, "style=knf"))
-		formatter.setFormattingStyle(STYLE_LINUX);
-	else if (isOption(arg, "A9", "style=horstmann") || isOption(arg, "style=run-in"))
-		formatter.setFormattingStyle(STYLE_HORSTMANN);
-	else if (isOption(arg, "A10", "style=1tbs") || isOption(arg, "style=otbs"))
-		formatter.setFormattingStyle(STYLE_1TBS);
-	else if (isOption(arg, "A14", "style=google"))
-		formatter.setFormattingStyle(STYLE_GOOGLE);
-	else if (isOption(arg, "A16", "style=mozilla"))
-		formatter.setFormattingStyle(STYLE_MOZILLA);
-	else if (isOption(arg, "A11", "style=pico"))
-		formatter.setFormattingStyle(STYLE_PICO);
-	else if (isOption(arg, "A12", "style=lisp") || isOption(arg, "style=python"))
-		formatter.setFormattingStyle(STYLE_LISP);
-	// must check for mode=cs before mode=c !!!
-	else if (isOption(arg, "mode=cs"))
-		formatter.setSharpStyle();
-		formatter.setModeManuallySet(true);
-	else if (isOption(arg, "mode=c"))
-		formatter.setCStyle();
-	else if (isOption(arg, "mode=java"))
-		formatter.setJavaStyle();
-	else if (isParamOption(arg, "t", "indent=tab="))
-		int spaceNum = 4;
-		string spaceNumParam = getParam(arg, "t", "indent=tab=");
-		if (spaceNumParam.length() > 0)
-			spaceNum = atoi(spaceNumParam.c_str());
-		if (spaceNum < 2 || spaceNum > 20)
-			isOptionError(arg, errorInfo);
-		else
-			formatter.setTabIndentation(spaceNum, false);
-	else if (isOption(arg, "indent=tab"))
-		formatter.setTabIndentation(4);
-	else if (isParamOption(arg, "T", "indent=force-tab="))
-		int spaceNum = 4;
-		string spaceNumParam = getParam(arg, "T", "indent=force-tab=");
-		else
-			formatter.setTabIndentation(spaceNum, true);
-	else if (isOption(arg, "indent=force-tab"))
-		formatter.setTabIndentation(4, true);
-	else if (isParamOption(arg, "xT", "indent=force-tab-x="))
-		int tabNum = 8;
-		string tabNumParam = getParam(arg, "xT", "indent=force-tab-x=");
-		if (tabNumParam.length() > 0)
-			tabNum = atoi(tabNumParam.c_str());
-		if (tabNum < 2 || tabNum > 20)
-		else
-			formatter.setForceTabXIndentation(tabNum);
-	else if (isOption(arg, "indent=force-tab-x"))
-		formatter.setForceTabXIndentation(8);
-	else if (isParamOption(arg, "s", "indent=spaces="))
-		int spaceNum = 4;
-		string spaceNumParam = getParam(arg, "s", "indent=spaces=");
-		else
-			formatter.setSpaceIndentation(spaceNum);
-	else if (isOption(arg, "indent=spaces"))
-		formatter.setSpaceIndentation(4);
-	else if (isParamOption(arg, "xt", "indent-continuation="))
-		int contIndent = 1;
-		string contIndentParam = getParam(arg, "xt", "indent-continuation=");
-		if (contIndentParam.length() > 0)
-			contIndent = atoi(contIndentParam.c_str());
-		if (contIndent < 0)
-		else if (contIndent > 4)
-		else
-			formatter.setContinuationIndentation(contIndent);
-	else if (isParamOption(arg, "m", "min-conditional-indent="))
-		int minIndent = MINCOND_TWO;
-		string minIndentParam = getParam(arg, "m", "min-conditional-indent=");
-		if (minIndentParam.length() > 0)
-			minIndent = atoi(minIndentParam.c_str());
-		if (minIndent >= MINCOND_END)
-		else
-			formatter.setMinConditionalIndentOption(minIndent);
-	else if (isParamOption(arg, "M", "max-continuation-indent="))
-		int maxIndent = 40;
-		string maxIndentParam = getParam(arg, "M", "max-continuation-indent=");
-		if (maxIndentParam.length() > 0)
-			maxIndent = atoi(maxIndentParam.c_str());
-		if (maxIndent < 40)
-		else if (maxIndent > 120)
-		else
-			formatter.setMaxContinuationIndentLength(maxIndent);
-	else if (isOption(arg, "N", "indent-namespaces"))
-		formatter.setNamespaceIndent(true);
-	else if (isOption(arg, "C", "indent-classes"))
-		formatter.setClassIndent(true);
-	else if (isOption(arg, "xG", "indent-modifiers"))
-		formatter.setModifierIndent(true);
-	else if (isOption(arg, "S", "indent-switches"))
-		formatter.setSwitchIndent(true);
-	else if (isOption(arg, "K", "indent-cases"))
-		formatter.setCaseIndent(true);
-	else if (isOption(arg, "xU", "indent-after-parens"))
-		formatter.setAfterParenIndent(true);
-	else if (isOption(arg, "L", "indent-labels"))
-		formatter.setLabelIndent(true);
-	else if (isOption(arg, "xW", "indent-preproc-block"))
-		formatter.setPreprocBlockIndent(true);
-	else if (isOption(arg, "w", "indent-preproc-define"))
-		formatter.setPreprocDefineIndent(true);
-	else if (isOption(arg, "xw", "indent-preproc-cond"))
-		formatter.setPreprocConditionalIndent(true);
-	else if (isOption(arg, "y", "break-closing-braces"))
-		formatter.setBreakClosingHeaderBracesMode(true);
-	else if (isOption(arg, "O", "keep-one-line-blocks"))
-		formatter.setBreakOneLineBlocksMode(false);
-	else if (isOption(arg, "o", "keep-one-line-statements"))
-		formatter.setBreakOneLineStatementsMode(false);
-	else if (isOption(arg, "P", "pad-paren"))
-		formatter.setParensOutsidePaddingMode(true);
-		formatter.setParensInsidePaddingMode(true);
-	else if (isOption(arg, "d", "pad-paren-out"))
-	else if (isOption(arg, "xd", "pad-first-paren-out"))
-		formatter.setParensFirstPaddingMode(true);
-	else if (isOption(arg, "D", "pad-paren-in"))
-	else if (isOption(arg, "H", "pad-header"))
-		formatter.setParensHeaderPaddingMode(true);
-	else if (isOption(arg, "U", "unpad-paren"))
-		formatter.setParensUnPaddingMode(true);
-	else if (isOption(arg, "p", "pad-oper"))
-		formatter.setOperatorPaddingMode(true);
-	else if (isOption(arg, "xg", "pad-comma"))
-		formatter.setCommaPaddingMode(true);
-	else if (isOption(arg, "xe", "delete-empty-lines"))
-		formatter.setDeleteEmptyLinesMode(true);
-	else if (isOption(arg, "E", "fill-empty-lines"))
-		formatter.setEmptyLineFill(true);
-	else if (isOption(arg, "c", "convert-tabs"))
-		formatter.setTabSpaceConversionMode(true);
-	else if (isOption(arg, "xy", "close-templates"))
-		formatter.setCloseTemplatesMode(true);
-	else if (isOption(arg, "F", "break-blocks=all"))
-		formatter.setBreakBlocksMode(true);
-		formatter.setBreakClosingHeaderBlocksMode(true);
-	else if (isOption(arg, "f", "break-blocks"))
-	else if (isOption(arg, "e", "break-elseifs"))
-		formatter.setBreakElseIfsMode(true);
-	else if (isOption(arg, "xb", "break-one-line-headers"))
-		formatter.setBreakOneLineHeadersMode(true);
-	else if (isOption(arg, "j", "add-braces"))
-		formatter.setAddBracesMode(true);
-	else if (isOption(arg, "J", "add-one-line-braces"))
-		formatter.setAddOneLineBracesMode(true);
-	else if (isOption(arg, "xj", "remove-braces"))
-		formatter.setRemoveBracesMode(true);
-	else if (isOption(arg, "Y", "indent-col1-comments"))
-		formatter.setIndentCol1CommentsMode(true);
-	else if (isOption(arg, "align-pointer=type"))
-		formatter.setPointerAlignment(PTR_ALIGN_TYPE);
-	else if (isOption(arg, "align-pointer=middle"))
-		formatter.setPointerAlignment(PTR_ALIGN_MIDDLE);
-	else if (isOption(arg, "align-pointer=name"))
-		formatter.setPointerAlignment(PTR_ALIGN_NAME);
-	else if (isParamOption(arg, "k"))
-		int align = 0;
-		string styleParam = getParam(arg, "k");
-		if (styleParam.length() > 0)
-			align = atoi(styleParam.c_str());
-		if (align < 1 || align > 3)
-		else if (align == 1)
-		else if (align == 2)
-		else if (align == 3)
-	else if (isOption(arg, "align-reference=none"))
-		formatter.setReferenceAlignment(REF_ALIGN_NONE);
-	else if (isOption(arg, "align-reference=type"))
-		formatter.setReferenceAlignment(REF_ALIGN_TYPE);
-	else if (isOption(arg, "align-reference=middle"))
-		formatter.setReferenceAlignment(REF_ALIGN_MIDDLE);
-	else if (isOption(arg, "align-reference=name"))
-		formatter.setReferenceAlignment(REF_ALIGN_NAME);
-	else if (isParamOption(arg, "W"))
-		int align = 0;
-		string styleParam = getParam(arg, "W");
-		if (align < 0 || align > 3)
-		else if (align == 0)
-	else if (isParamOption(arg, "max-code-length="))
-		int maxLength = 50;
-		string maxLengthParam = getParam(arg, "max-code-length=");
-		if (maxLengthParam.length() > 0)
-			maxLength = atoi(maxLengthParam.c_str());
-		if (maxLength < 50)
-		else if (maxLength > 200)
-		else
-			formatter.setMaxCodeLength(maxLength);
-	else if (isParamOption(arg, "xC"))
-		string maxLengthParam = getParam(arg, "xC");
-		if (maxLength > 200)
-		else
-	else if (isOption(arg, "xL", "break-after-logical"))
-		formatter.setBreakAfterMode(true);
-	else if (isOption(arg, "xc", "attach-classes"))
-		formatter.setAttachClass(true);
-	else if (isOption(arg, "xV", "attach-closing-while"))
-		formatter.setAttachClosingWhile(true);
-	else if (isOption(arg, "xk", "attach-extern-c"))
-		formatter.setAttachExternC(true);
-	else if (isOption(arg, "xn", "attach-namespaces"))
-		formatter.setAttachNamespace(true);
-	else if (isOption(arg, "xl", "attach-inlines"))
-		formatter.setAttachInline(true);
-	else if (isOption(arg, "xp", "remove-comment-prefix"))
-		formatter.setStripCommentPrefix(true);
-	else if (isOption(arg, "xB", "break-return-type"))
-		formatter.setBreakReturnType(true);
-	else if (isOption(arg, "xD", "break-return-type-decl"))
-		formatter.setBreakReturnTypeDecl(true);
-	else if (isOption(arg, "xf", "attach-return-type"))
-		formatter.setAttachReturnType(true);
-	else if (isOption(arg, "xh", "attach-return-type-decl"))
-		formatter.setAttachReturnTypeDecl(true);
-	// Objective-C options
-	else if (isOption(arg, "xQ", "pad-method-prefix"))
-		formatter.setMethodPrefixPaddingMode(true);
-	else if (isOption(arg, "xR", "unpad-method-prefix"))
-		formatter.setMethodPrefixUnPaddingMode(true);
-	else if (isOption(arg, "xq", "pad-return-type"))
-		formatter.setReturnTypePaddingMode(true);
-	else if (isOption(arg, "xr", "unpad-return-type"))
-		formatter.setReturnTypeUnPaddingMode(true);
-	else if (isOption(arg, "xS", "pad-param-type"))
-		formatter.setParamTypePaddingMode(true);
-	else if (isOption(arg, "xs", "unpad-param-type"))
-		formatter.setParamTypeUnPaddingMode(true);
-	else if (isOption(arg, "xM", "align-method-colon"))
-		formatter.setAlignMethodColon(true);
-	else if (isOption(arg, "xP0", "pad-method-colon=none"))
-		formatter.setObjCColonPaddingMode(COLON_PAD_NONE);
-	else if (isOption(arg, "xP1", "pad-method-colon=all"))
-		formatter.setObjCColonPaddingMode(COLON_PAD_ALL);
-	else if (isOption(arg, "xP2", "pad-method-colon=after"))
-		formatter.setObjCColonPaddingMode(COLON_PAD_AFTER);
-	else if (isOption(arg, "xP3", "pad-method-colon=before"))
-		formatter.setObjCColonPaddingMode(COLON_PAD_BEFORE);
-	// NOTE: depreciated options - remove when appropriate
-	// depreciated options ////////////////////////////////////////////////////////////////////////
-	else if (isOption(arg, "indent-preprocessor"))		// depreciated release 2.04
-	else if (isOption(arg, "style=ansi"))					// depreciated release 2.05
-	// depreciated in release 3.0 /////////////////////////////////////////////////////////////////
-	else if (isOption(arg, "break-closing-brackets"))		// depreciated release 3.0
-		formatter.setBreakClosingHeaderBracketsMode(true);
-	else if (isOption(arg, "add-brackets"))				// depreciated release 3.0
-		formatter.setAddBracketsMode(true);
-	else if (isOption(arg, "add-one-line-brackets"))		// depreciated release 3.0
-		formatter.setAddOneLineBracketsMode(true);
-	else if (isOption(arg, "remove-brackets"))			// depreciated release 3.0
-		formatter.setRemoveBracketsMode(true);
-	else if (isParamOption(arg, "max-instatement-indent="))	// depreciated release 3.0
-		string maxIndentParam = getParam(arg, "max-instatement-indent=");
-		else
-			formatter.setMaxInStatementIndentLength(maxIndent);
-	// end depreciated options ////////////////////////////////////////////////////////////////////
+    if (isOption(arg, "A1", "style=allman") || isOption(arg, "style=bsd") || isOption(arg, "style=break"))
+        formatter.setFormattingStyle(STYLE_ALLMAN);
+    else if (isOption(arg, "A2", "style=java") || isOption(arg, "style=attach"))
+        formatter.setFormattingStyle(STYLE_JAVA);
+    else if (isOption(arg, "A3", "style=k&r") || isOption(arg, "style=kr") || isOption(arg, "style=k/r"))
+        formatter.setFormattingStyle(STYLE_KR);
+    else if (isOption(arg, "A4", "style=stroustrup"))
+        formatter.setFormattingStyle(STYLE_STROUSTRUP);
+    else if (isOption(arg, "A5", "style=whitesmith"))
+        formatter.setFormattingStyle(STYLE_WHITESMITH);
+    else if (isOption(arg, "A15", "style=vtk"))
+        formatter.setFormattingStyle(STYLE_VTK);
+    else if (isOption(arg, "A6", "style=ratliff") || isOption(arg, "style=banner"))
+        formatter.setFormattingStyle(STYLE_RATLIFF);
+    else if (isOption(arg, "A7", "style=gnu"))
+        formatter.setFormattingStyle(STYLE_GNU);
+    else if (isOption(arg, "A8", "style=linux") || isOption(arg, "style=knf"))
+        formatter.setFormattingStyle(STYLE_LINUX);
+    else if (isOption(arg, "A9", "style=horstmann") || isOption(arg, "style=run-in"))
+        formatter.setFormattingStyle(STYLE_HORSTMANN);
+    else if (isOption(arg, "A10", "style=1tbs") || isOption(arg, "style=otbs"))
+        formatter.setFormattingStyle(STYLE_1TBS);
+    else if (isOption(arg, "A14", "style=google"))
+        formatter.setFormattingStyle(STYLE_GOOGLE);
+    else if (isOption(arg, "A16", "style=mozilla"))
+        formatter.setFormattingStyle(STYLE_MOZILLA);
+    else if (isOption(arg, "A11", "style=pico"))
+        formatter.setFormattingStyle(STYLE_PICO);
+    else if (isOption(arg, "A12", "style=lisp") || isOption(arg, "style=python"))
+        formatter.setFormattingStyle(STYLE_LISP);
+    // must check for mode=cs before mode=c !!!
+    else if (isOption(arg, "mode=cs"))
+        formatter.setSharpStyle();
+        formatter.setModeManuallySet(true);
+    else if (isOption(arg, "mode=c"))
+        formatter.setCStyle();
+    else if (isOption(arg, "mode=java"))
+        formatter.setJavaStyle();
+    else if (isParamOption(arg, "t", "indent=tab="))
+        int spaceNum = 4;
+        string spaceNumParam = getParam(arg, "t", "indent=tab=");
+        if (spaceNumParam.length() > 0)
+            spaceNum = atoi(spaceNumParam.c_str());
+        if (spaceNum < 2 || spaceNum > 20)
+            isOptionError(arg, errorInfo);
+        else
+            formatter.setTabIndentation(spaceNum, false);
+    else if (isOption(arg, "indent=tab"))
+        formatter.setTabIndentation(4);
+    else if (isParamOption(arg, "T", "indent=force-tab="))
+        int spaceNum = 4;
+        string spaceNumParam = getParam(arg, "T", "indent=force-tab=");
+        else
+            formatter.setTabIndentation(spaceNum, true);
+    else if (isOption(arg, "indent=force-tab"))
+        formatter.setTabIndentation(4, true);
+    else if (isParamOption(arg, "xT", "indent=force-tab-x="))
+        int tabNum = 8;
+        string tabNumParam = getParam(arg, "xT", "indent=force-tab-x=");
+        if (tabNumParam.length() > 0)
+            tabNum = atoi(tabNumParam.c_str());
+        if (tabNum < 2 || tabNum > 20)
+        else
+            formatter.setForceTabXIndentation(tabNum);
+    else if (isOption(arg, "indent=force-tab-x"))
+        formatter.setForceTabXIndentation(8);
+    else if (isParamOption(arg, "s", "indent=spaces="))
+        int spaceNum = 4;
+        string spaceNumParam = getParam(arg, "s", "indent=spaces=");
+        else
+            formatter.setSpaceIndentation(spaceNum);
+    else if (isOption(arg, "indent=spaces"))
+        formatter.setSpaceIndentation(4);
+    else if (isParamOption(arg, "xt", "indent-continuation="))
+        int contIndent = 1;
+        string contIndentParam = getParam(arg, "xt", "indent-continuation=");
+        if (contIndentParam.length() > 0)
+            contIndent = atoi(contIndentParam.c_str());
+        if (contIndent < 0)
+        else if (contIndent > 4)
+        else
+            formatter.setContinuationIndentation(contIndent);
+    else if (isParamOption(arg, "m", "min-conditional-indent="))
+        int minIndent = MINCOND_TWO;
+        string minIndentParam = getParam(arg, "m", "min-conditional-indent=");
+        if (minIndentParam.length() > 0)
+            minIndent = atoi(minIndentParam.c_str());
+        if (minIndent >= MINCOND_END)
+        else
+            formatter.setMinConditionalIndentOption(minIndent);
+    else if (isParamOption(arg, "M", "max-continuation-indent="))
+        int maxIndent = 40;
+        string maxIndentParam = getParam(arg, "M", "max-continuation-indent=");
+        if (maxIndentParam.length() > 0)
+            maxIndent = atoi(maxIndentParam.c_str());
+        if (maxIndent < 40)
+        else if (maxIndent > 120)
+        else
+            formatter.setMaxContinuationIndentLength(maxIndent);
+    else if (isOption(arg, "N", "indent-namespaces"))
+        formatter.setNamespaceIndent(true);
+    else if (isOption(arg, "C", "indent-classes"))
+        formatter.setClassIndent(true);
+    else if (isOption(arg, "xG", "indent-modifiers"))
+        formatter.setModifierIndent(true);
+    else if (isOption(arg, "S", "indent-switches"))
+        formatter.setSwitchIndent(true);
+    else if (isOption(arg, "K", "indent-cases"))
+        formatter.setCaseIndent(true);
+    else if (isOption(arg, "xU", "indent-after-parens"))
+        formatter.setAfterParenIndent(true);
+    else if (isOption(arg, "L", "indent-labels"))
+        formatter.setLabelIndent(true);
+    else if (isOption(arg, "xW", "indent-preproc-block"))
+        formatter.setPreprocBlockIndent(true);
+    else if (isOption(arg, "w", "indent-preproc-define"))
+        formatter.setPreprocDefineIndent(true);
+    else if (isOption(arg, "xw", "indent-preproc-cond"))
+        formatter.setPreprocConditionalIndent(true);
+    else if (isOption(arg, "y", "break-closing-braces"))
+        formatter.setBreakClosingHeaderBracesMode(true);
+    else if (isOption(arg, "O", "keep-one-line-blocks"))
+        formatter.setBreakOneLineBlocksMode(false);
+    else if (isOption(arg, "o", "keep-one-line-statements"))
+        formatter.setBreakOneLineStatementsMode(false);
+    else if (isOption(arg, "P", "pad-paren"))
+        formatter.setParensOutsidePaddingMode(true);
+        formatter.setParensInsidePaddingMode(true);
+    else if (isOption(arg, "d", "pad-paren-out"))
+    else if (isOption(arg, "xd", "pad-first-paren-out"))
+        formatter.setParensFirstPaddingMode(true);
+    else if (isOption(arg, "D", "pad-paren-in"))
+    else if (isOption(arg, "H", "pad-header"))
+        formatter.setParensHeaderPaddingMode(true);
+    else if (isOption(arg, "U", "unpad-paren"))
+        formatter.setParensUnPaddingMode(true);
+    else if (isOption(arg, "p", "pad-oper"))
+        formatter.setOperatorPaddingMode(true);
+    else if (isOption(arg, "xg", "pad-comma"))
+        formatter.setCommaPaddingMode(true);
+    else if (isOption(arg, "xe", "delete-empty-lines"))
+        formatter.setDeleteEmptyLinesMode(true);
+    else if (isOption(arg, "E", "fill-empty-lines"))
+        formatter.setEmptyLineFill(true);
+    else if (isOption(arg, "c", "convert-tabs"))
+        formatter.setTabSpaceConversionMode(true);
+    else if (isOption(arg, "xy", "close-templates"))
+        formatter.setCloseTemplatesMode(true);
+    else if (isOption(arg, "F", "break-blocks=all"))
+        formatter.setBreakBlocksMode(true);
+        formatter.setBreakClosingHeaderBlocksMode(true);
+    else if (isOption(arg, "f", "break-blocks"))
+    else if (isOption(arg, "e", "break-elseifs"))
+        formatter.setBreakElseIfsMode(true);
+    else if (isOption(arg, "xb", "break-one-line-headers"))
+        formatter.setBreakOneLineHeadersMode(true);
+    else if (isOption(arg, "j", "add-braces"))
+        formatter.setAddBracesMode(true);
+    else if (isOption(arg, "J", "add-one-line-braces"))
+        formatter.setAddOneLineBracesMode(true);
+    else if (isOption(arg, "xj", "remove-braces"))
+        formatter.setRemoveBracesMode(true);
+    else if (isOption(arg, "Y", "indent-col1-comments"))
+        formatter.setIndentCol1CommentsMode(true);
+    else if (isOption(arg, "align-pointer=type"))
+        formatter.setPointerAlignment(PTR_ALIGN_TYPE);
+    else if (isOption(arg, "align-pointer=middle"))
+        formatter.setPointerAlignment(PTR_ALIGN_MIDDLE);
+    else if (isOption(arg, "align-pointer=name"))
+        formatter.setPointerAlignment(PTR_ALIGN_NAME);
+    else if (isParamOption(arg, "k"))
+        int align = 0;
+        string styleParam = getParam(arg, "k");
+        if (styleParam.length() > 0)
+            align = atoi(styleParam.c_str());
+        if (align < 1 || align > 3)
+        else if (align == 1)
+        else if (align == 2)
+        else if (align == 3)
+    else if (isOption(arg, "align-reference=none"))
+        formatter.setReferenceAlignment(REF_ALIGN_NONE);
+    else if (isOption(arg, "align-reference=type"))
+        formatter.setReferenceAlignment(REF_ALIGN_TYPE);
+    else if (isOption(arg, "align-reference=middle"))
+        formatter.setReferenceAlignment(REF_ALIGN_MIDDLE);
+    else if (isOption(arg, "align-reference=name"))
+        formatter.setReferenceAlignment(REF_ALIGN_NAME);
+    else if (isParamOption(arg, "W"))
+        int align = 0;
+        string styleParam = getParam(arg, "W");
+        if (align < 0 || align > 3)
+        else if (align == 0)
+    else if (isParamOption(arg, "max-code-length="))
+        int maxLength = 50;
+        string maxLengthParam = getParam(arg, "max-code-length=");
+        if (maxLengthParam.length() > 0)
+            maxLength = atoi(maxLengthParam.c_str());
+        if (maxLength < 50)
+        else if (maxLength > 200)
+        else
+            formatter.setMaxCodeLength(maxLength);
+    else if (isParamOption(arg, "xC"))
+        string maxLengthParam = getParam(arg, "xC");
+        if (maxLength > 200)
+        else
+    else if (isOption(arg, "xL", "break-after-logical"))
+        formatter.setBreakAfterMode(true);
+    else if (isOption(arg, "xc", "attach-classes"))
+        formatter.setAttachClass(true);
+    else if (isOption(arg, "xV", "attach-closing-while"))
+        formatter.setAttachClosingWhile(true);
+    else if (isOption(arg, "xk", "attach-extern-c"))
+        formatter.setAttachExternC(true);
+    else if (isOption(arg, "xn", "attach-namespaces"))
+        formatter.setAttachNamespace(true);
+    else if (isOption(arg, "xl", "attach-inlines"))
+        formatter.setAttachInline(true);
+    else if (isOption(arg, "xp", "remove-comment-prefix"))
+        formatter.setStripCommentPrefix(true);
+    else if (isOption(arg, "xB", "break-return-type"))
+        formatter.setBreakReturnType(true);
+    else if (isOption(arg, "xD", "break-return-type-decl"))
+        formatter.setBreakReturnTypeDecl(true);
+    else if (isOption(arg, "xf", "attach-return-type"))
+        formatter.setAttachReturnType(true);
+    else if (isOption(arg, "xh", "attach-return-type-decl"))
+        formatter.setAttachReturnTypeDecl(true);
+    // Objective-C options
+    else if (isOption(arg, "xQ", "pad-method-prefix"))
+        formatter.setMethodPrefixPaddingMode(true);
+    else if (isOption(arg, "xR", "unpad-method-prefix"))
+        formatter.setMethodPrefixUnPaddingMode(true);
+    else if (isOption(arg, "xq", "pad-return-type"))
+        formatter.setReturnTypePaddingMode(true);
+    else if (isOption(arg, "xr", "unpad-return-type"))
+        formatter.setReturnTypeUnPaddingMode(true);
+    else if (isOption(arg, "xS", "pad-param-type"))
+        formatter.setParamTypePaddingMode(true);
+    else if (isOption(arg, "xs", "unpad-param-type"))
+        formatter.setParamTypeUnPaddingMode(true);
+    else if (isOption(arg, "xM", "align-method-colon"))
+        formatter.setAlignMethodColon(true);
+    else if (isOption(arg, "xP0", "pad-method-colon=none"))
+        formatter.setObjCColonPaddingMode(COLON_PAD_NONE);
+    else if (isOption(arg, "xP1", "pad-method-colon=all"))
+        formatter.setObjCColonPaddingMode(COLON_PAD_ALL);
+    else if (isOption(arg, "xP2", "pad-method-colon=after"))
+        formatter.setObjCColonPaddingMode(COLON_PAD_AFTER);
+    else if (isOption(arg, "xP3", "pad-method-colon=before"))
+        formatter.setObjCColonPaddingMode(COLON_PAD_BEFORE);
+    // NOTE: depreciated options - remove when appropriate
+    // depreciated options ////////////////////////////////////////////////////////////////////////
+    else if (isOption(arg, "indent-preprocessor"))      // depreciated release 2.04
+    else if (isOption(arg, "style=ansi"))                   // depreciated release 2.05
+    // depreciated in release 3.0 /////////////////////////////////////////////////////////////////
+    else if (isOption(arg, "break-closing-brackets"))       // depreciated release 3.0
+        formatter.setBreakClosingHeaderBracketsMode(true);
+    else if (isOption(arg, "add-brackets"))             // depreciated release 3.0
+        formatter.setAddBracketsMode(true);
+    else if (isOption(arg, "add-one-line-brackets"))        // depreciated release 3.0
+        formatter.setAddOneLineBracketsMode(true);
+    else if (isOption(arg, "remove-brackets"))          // depreciated release 3.0
+        formatter.setRemoveBracketsMode(true);
+    else if (isParamOption(arg, "max-instatement-indent=")) // depreciated release 3.0
+        string maxIndentParam = getParam(arg, "max-instatement-indent=");
+        else
+            formatter.setMaxInStatementIndentLength(maxIndent);
+    // end depreciated options ////////////////////////////////////////////////////////////////////
 #ifdef ASTYLE_LIB
-	// End of options used by GUI /////////////////////////////////////////////////////////////////
-	else
+    // End of options used by GUI /////////////////////////////////////////////////////////////////
+    else
 #else
-	// Options used by only console ///////////////////////////////////////////////////////////////
-	else if (isOption(arg, "n", "suffix=none"))
-		console.setNoBackup(true);
-	else if (isParamOption(arg, "suffix="))
-		string suffixParam = getParam(arg, "suffix=");
-		if (suffixParam.length() > 0)
-			console.setOrigSuffix(suffixParam);
-	else if (isParamOption(arg, "exclude="))
-		string suffixParam = getParam(arg, "exclude=");
-			console.updateExcludeVector(suffixParam);
-	else if (isOption(arg, "r", "R") || isOption(arg, "recursive"))
-		console.setIsRecursive(true);
-	else if (isOption(arg, "dry-run"))
-		console.setIsDryRun(true);
-	else if (isOption(arg, "Z", "preserve-date"))
-		console.setPreserveDate(true);
-	else if (isOption(arg, "v", "verbose"))
-		console.setIsVerbose(true);
-	else if (isOption(arg, "Q", "formatted"))
-		console.setIsFormattedOnly(true);
-	else if (isOption(arg, "q", "quiet"))
-		console.setIsQuiet(true);
-	else if (isOption(arg, "i", "ignore-exclude-errors"))
-		console.setIgnoreExcludeErrors(true);
-	else if (isOption(arg, "xi", "ignore-exclude-errors-x"))
-		console.setIgnoreExcludeErrorsAndDisplay(true);
-	else if (isOption(arg, "X", "errors-to-stdout"))
-		console.setErrorStream(&cout);
-	else if (isOption(arg, "lineend=windows"))
-		formatter.setLineEndFormat(LINEEND_WINDOWS);
-	else if (isOption(arg, "lineend=linux"))
-		formatter.setLineEndFormat(LINEEND_LINUX);
-	else if (isOption(arg, "lineend=macold"))
-		formatter.setLineEndFormat(LINEEND_MACOLD);
-	else if (isParamOption(arg, "z"))
-		int lineendType = 0;
-		string lineendParam = getParam(arg, "z");
-		if (lineendParam.length() > 0)
-			lineendType = atoi(lineendParam.c_str());
-		if (lineendType < 1 || lineendType > 3)
-		else if (lineendType == 1)
-		else if (lineendType == 2)
-		else if (lineendType == 3)
-	else
+    // Options used by only console ///////////////////////////////////////////////////////////////
+    else if (isOption(arg, "n", "suffix=none"))
+        console.setNoBackup(true);
+    else if (isParamOption(arg, "suffix="))
+        string suffixParam = getParam(arg, "suffix=");
+        if (suffixParam.length() > 0)
+            console.setOrigSuffix(suffixParam);
+    else if (isParamOption(arg, "exclude="))
+        string suffixParam = getParam(arg, "exclude=");
+            console.updateExcludeVector(suffixParam);
+    else if (isOption(arg, "r", "R") || isOption(arg, "recursive"))
+        console.setIsRecursive(true);
+    else if (isOption(arg, "dry-run"))
+        console.setIsDryRun(true);
+    else if (isOption(arg, "Z", "preserve-date"))
+        console.setPreserveDate(true);
+    else if (isOption(arg, "v", "verbose"))
+        console.setIsVerbose(true);
+    else if (isOption(arg, "Q", "formatted"))
+        console.setIsFormattedOnly(true);
+    else if (isOption(arg, "q", "quiet"))
+        console.setIsQuiet(true);
+    else if (isOption(arg, "i", "ignore-exclude-errors"))
+        console.setIgnoreExcludeErrors(true);
+    else if (isOption(arg, "xi", "ignore-exclude-errors-x"))
+        console.setIgnoreExcludeErrorsAndDisplay(true);
+    else if (isOption(arg, "X", "errors-to-stdout"))
+        console.setErrorStream(&cout);
+    else if (isOption(arg, "lineend=windows"))
+        formatter.setLineEndFormat(LINEEND_WINDOWS);
+    else if (isOption(arg, "lineend=linux"))
+        formatter.setLineEndFormat(LINEEND_LINUX);
+    else if (isOption(arg, "lineend=macold"))
+        formatter.setLineEndFormat(LINEEND_MACOLD);
+    else if (isParamOption(arg, "z"))
+        int lineendType = 0;
+        string lineendParam = getParam(arg, "z");
+        if (lineendParam.length() > 0)
+            lineendType = atoi(lineendParam.c_str());
+        if (lineendType < 1 || lineendType > 3)
+        else if (lineendType == 1)
+        else if (lineendType == 2)
+        else if (lineendType == 3)
+    else
 #endif
-}	// End of parseOption function
+}   // End of parseOption function
 // Parse options from the option file.
 void ASOptions::importOptions(stringstream& in, vector<string>& optionsVector)
-	char ch;
-	bool isInQuote = false;
-	char quoteChar = ' ';
-	string currentToken;
-	while (in)
-		currentToken = "";
-		do
-			in.get(ch);
-			if (in.eof())
-				break;
-			// treat '#' as line comments
-			if (ch == '#')
-				while (in)
-					in.get(ch);
-					if (ch == '\n' || ch == '\r')
-						break;
-			// break options on new-lines, tabs, commas, or spaces
-			// remove quotes from output
-			if (in.eof() || ch == '\n' || ch == '\r' || ch == '\t' || ch == ',')
-				break;
-			if (ch == ' ' && !isInQuote)
-				break;
-			if (ch == quoteChar && isInQuote)
-				break;
-			if (ch == '"' || ch == '\'')
-				isInQuote = true;
-				quoteChar = ch;
-				continue;
-			currentToken.append(1, ch);
-		while (in);
-		if (currentToken.length() != 0)
-			optionsVector.emplace_back(currentToken);
-		isInQuote = false;
+    char ch;
+    bool isInQuote = false;
+    char quoteChar = ' ';
+    string currentToken;
+    while (in)
+        currentToken = "";
+        do
+            in.get(ch);
+            if (in.eof())
+                break;
+            // treat '#' as line comments
+            if (ch == '#')
+                while (in)
+                    in.get(ch);
+                    if (ch == '\n' || ch == '\r')
+                        break;
+            // break options on new-lines, tabs, commas, or spaces
+            // remove quotes from output
+            if (in.eof() || ch == '\n' || ch == '\r' || ch == '\t' || ch == ',')
+                break;
+            if (ch == ' ' && !isInQuote)
+                break;
+            if (ch == quoteChar && isInQuote)
+                break;
+            if (ch == '"' || ch == '\'')
+                isInQuote = true;
+                quoteChar = ch;
+                continue;
+            currentToken.append(1, ch);
+        while (in);
+        if (currentToken.length() != 0)
+            optionsVector.emplace_back(currentToken);
+        isInQuote = false;
 string ASOptions::getOptionErrors() const
-	return optionErrors.str();
+    return optionErrors.str();
 string ASOptions::getParam(const string& arg, const char* op)
-	return arg.substr(strlen(op));
+    return arg.substr(strlen(op));
 string ASOptions::getParam(const string& arg, const char* op1, const char* op2)
-	return isParamOption(arg, op1) ? getParam(arg, op1) : getParam(arg, op2);
+    return isParamOption(arg, op1) ? getParam(arg, op1) : getParam(arg, op2);
 bool ASOptions::isOption(const string& arg, const char* op)
-	return arg.compare(op) == 0;
+    return arg.compare(op) == 0;
 bool ASOptions::isOption(const string& arg, const char* op1, const char* op2)
-	return (isOption(arg, op1) || isOption(arg, op2));
+    return (isOption(arg, op1) || isOption(arg, op2));
 void ASOptions::isOptionError(const string& arg, const string& errorInfo)
-	if (optionErrors.str().length() == 0)
-		optionErrors << errorInfo << endl;   // need main error message
-	optionErrors << "\t" << arg << endl;
+    if (optionErrors.str().length() == 0)
+        optionErrors << errorInfo << endl;   // need main error message
+    optionErrors << "\t" << arg << endl;
 bool ASOptions::isParamOption(const string& arg, const char* option)
-	bool retVal = arg.compare(0, strlen(option), option) == 0;
-	// if comparing for short option, 2nd char of arg must be numeric
-	if (retVal && strlen(option) == 1 && arg.length() > 1)
-		if (!isdigit((unsigned char) arg[1]))
-			retVal = false;
-	return retVal;
+    bool retVal = arg.compare(0, strlen(option), option) == 0;
+    // if comparing for short option, 2nd char of arg must be numeric
+    if (retVal && strlen(option) == 1 && arg.length() > 1)
+        if (!isdigit((unsigned char) arg[1]))
+            retVal = false;
+    return retVal;
 bool ASOptions::isParamOption(const string& arg, const char* option1, const char* option2)
-	return isParamOption(arg, option1) || isParamOption(arg, option2);
+    return isParamOption(arg, option1) || isParamOption(arg, option2);
@@ -3803,25 +3806,25 @@ bool ASOptions::isParamOption(const string& arg, const char* option1, const char
 // Return true if an int is big endian.
 bool ASEncoding::getBigEndian() const
-	char16_t word = 0x0001;
-	char* byte = (char*) &word;
-	return (byte[0] ? false : true);
+    char16_t word = 0x0001;
+    char* byte = (char*) &word;
+    return (byte[0] ? false : true);
 // Swap the two low order bytes of a 16 bit integer value.
 int ASEncoding::swap16bit(int value) const
-	return (((value & 0xff) << 8) | ((value & 0xff00) >> 8));
+    return (((value & 0xff) << 8) | ((value & 0xff00) >> 8));
 // Return the length of a utf-16 C string.
 // The length is in number of char16_t.
 size_t ASEncoding::utf16len(const utf16* utf16In) const
-	size_t length = 0;
-	while (*utf16In++ != '\0')
-		length++;
-	return length;
+    size_t length = 0;
+    while (*utf16In++ != '\0')
+        length++;
+    return length;
 // Adapted from SciTE UniConversion.cxx.
@@ -3831,26 +3834,26 @@ size_t ASEncoding::utf16len(const utf16* utf16In) const
 // Input inLen is the size in BYTES (not wchar_t).
 size_t ASEncoding::utf8LengthFromUtf16(const char* utf16In, size_t inLen, bool isBigEndian) const
-	size_t len = 0;
-	size_t wcharLen = (inLen / 2) + (inLen % 2);
-	const char16_t* uptr = reinterpret_cast<const char16_t*>(utf16In);
-	for (size_t i = 0; i < wcharLen;)
-		size_t uch = isBigEndian ? swap16bit(uptr[i]) : uptr[i];
-		if (uch < 0x80)
-			len++;
-		else if (uch < 0x800)
-			len += 2;
-		else if ((uch >= SURROGATE_LEAD_FIRST) && (uch <= SURROGATE_LEAD_LAST))
-			len += 4;
-			i++;
-		else
-			len += 3;
-		i++;
-	return len;
+    size_t len = 0;
+    size_t wcharLen = (inLen / 2) + (inLen % 2);
+    const char16_t* uptr = reinterpret_cast<const char16_t*>(utf16In);
+    for (size_t i = 0; i < wcharLen;)
+        size_t uch = isBigEndian ? swap16bit(uptr[i]) : uptr[i];
+        if (uch < 0x80)
+            len++;
+        else if (uch < 0x800)
+            len += 2;
+        else if ((uch >= SURROGATE_LEAD_FIRST) && (uch <= SURROGATE_LEAD_LAST))
+            len += 4;
+            i++;
+        else
+            len += 3;
+        i++;
+    return len;
 // Adapted from SciTE Utf8_16.cxx.
@@ -3859,73 +3862,73 @@ size_t ASEncoding::utf8LengthFromUtf16(const char* utf16In, size_t inLen, bool i
 // Convert a utf-8 file to utf-16.
 size_t ASEncoding::utf8ToUtf16(char* utf8In, size_t inLen, bool isBigEndian, char* utf16Out) const
-	int nCur = 0;
-	ubyte* pRead = reinterpret_cast<ubyte*>(utf8In);
-	utf16* pCur = reinterpret_cast<utf16*>(utf16Out);
-	const ubyte* pEnd = pRead + inLen;
-	const utf16* pCurStart = pCur;
-	eState state = eStart;
-	// the BOM will automatically be converted to utf-16
-	while (pRead < pEnd)
-		switch (state)
-			case eStart:
-				if ((0xF0 & *pRead) == 0xF0)
-					nCur = (0x7 & *pRead) << 18;
-					state = eSecondOf4Bytes;
-				else if ((0xE0 & *pRead) == 0xE0)
-					nCur = (~0xE0 & *pRead) << 12;
-					state = ePenultimate;
-				else if ((0xC0 & *pRead) == 0xC0)
-					nCur = (~0xC0 & *pRead) << 6;
-					state = eFinal;
-				else
-					nCur = *pRead;
-					state = eStart;
-				break;
-			case eSecondOf4Bytes:
-				nCur |= (0x3F & *pRead) << 12;
-				break;
-			case ePenultimate:
-				nCur |= (0x3F & *pRead) << 6;
-				state = eFinal;
-				break;
-			case eFinal:
-				nCur |= (0x3F & *pRead);
-				state = eStart;
-				break;
-				// no default case is needed
-		++pRead;
-		if (state == eStart)
-			int codePoint = nCur;
-			if (codePoint >= SURROGATE_FIRST_VALUE)
-				codePoint -= SURROGATE_FIRST_VALUE;
-				int lead = (codePoint >> 10) + SURROGATE_LEAD_FIRST;
-				*pCur++ = static_cast<utf16>(isBigEndian ? swap16bit(lead) : lead);
-				int trail = (codePoint & 0x3ff) + SURROGATE_TRAIL_FIRST;
-				*pCur++ = static_cast<utf16>(isBigEndian ? swap16bit(trail) : trail);
-			else
-				*pCur++ = static_cast<utf16>(isBigEndian ? swap16bit(codePoint) : codePoint);
-	// return value is the output length in BYTES (not wchar_t)
-	return (pCur - pCurStart) * 2;
+    int nCur = 0;
+    ubyte* pRead = reinterpret_cast<ubyte*>(utf8In);
+    utf16* pCur = reinterpret_cast<utf16*>(utf16Out);
+    const ubyte* pEnd = pRead + inLen;
+    const utf16* pCurStart = pCur;
+    eState state = eStart;
+    // the BOM will automatically be converted to utf-16
+    while (pRead < pEnd)
+        switch (state)
+            case eStart:
+                if ((0xF0 & *pRead) == 0xF0)
+                    nCur = (0x7 & *pRead) << 18;
+                    state = eSecondOf4Bytes;
+                else if ((0xE0 & *pRead) == 0xE0)
+                    nCur = (~0xE0 & *pRead) << 12;
+                    state = ePenultimate;
+                else if ((0xC0 & *pRead) == 0xC0)
+                    nCur = (~0xC0 & *pRead) << 6;
+                    state = eFinal;
+                else
+                    nCur = *pRead;
+                    state = eStart;
+                break;
+            case eSecondOf4Bytes:
+                nCur |= (0x3F & *pRead) << 12;
+                break;
+            case ePenultimate:
+                nCur |= (0x3F & *pRead) << 6;
+                state = eFinal;
+                break;
+            case eFinal:
+                nCur |= (0x3F & *pRead);
+                state = eStart;
+                break;
+                // no default case is needed
+        ++pRead;
+        if (state == eStart)
+            int codePoint = nCur;
+            if (codePoint >= SURROGATE_FIRST_VALUE)
+                codePoint -= SURROGATE_FIRST_VALUE;
+                int lead = (codePoint >> 10) + SURROGATE_LEAD_FIRST;
+                *pCur++ = static_cast<utf16>(isBigEndian ? swap16bit(lead) : lead);
+                int trail = (codePoint & 0x3ff) + SURROGATE_TRAIL_FIRST;
+                *pCur++ = static_cast<utf16>(isBigEndian ? swap16bit(trail) : trail);
+            else
+                *pCur++ = static_cast<utf16>(isBigEndian ? swap16bit(codePoint) : codePoint);
+    // return value is the output length in BYTES (not wchar_t)
+    return (pCur - pCurStart) * 2;
@@ -3935,27 +3938,27 @@ size_t ASEncoding::utf8ToUtf16(char* utf8In, size_t inLen, bool isBigEndian, cha
 // Return value is the size in BYTES (not wchar_t).
 size_t ASEncoding::utf16LengthFromUtf8(const char* utf8In, size_t len) const
-	size_t ulen = 0;
-	size_t charLen;
-	for (size_t i = 0; i < len;)
-		unsigned char ch = static_cast<unsigned char>(utf8In[i]);
-		if (ch < 0x80)
-			charLen = 1;
-		else if (ch < 0x80 + 0x40 + 0x20)
-			charLen = 2;
-		else if (ch < 0x80 + 0x40 + 0x20 + 0x10)
-			charLen = 3;
-		else
-			charLen = 4;
-			ulen++;
-		i += charLen;
-		ulen++;
-	// return value is the length in bytes (not wchar_t)
-	return ulen * 2;
+    size_t ulen = 0;
+    size_t charLen;
+    for (size_t i = 0; i < len;)
+        unsigned char ch = static_cast<unsigned char>(utf8In[i]);
+        if (ch < 0x80)
+            charLen = 1;
+        else if (ch < 0x80 + 0x40 + 0x20)
+            charLen = 2;
+        else if (ch < 0x80 + 0x40 + 0x20 + 0x10)
+            charLen = 3;
+        else
+            charLen = 4;
+            ulen++;
+        i += charLen;
+        ulen++;
+    // return value is the length in bytes (not wchar_t)
+    return ulen * 2;
@@ -3965,93 +3968,93 @@ size_t ASEncoding::utf16LengthFromUtf8(const char* utf8In, size_t len) const
 size_t ASEncoding::utf16ToUtf8(char* utf16In, size_t inLen, bool isBigEndian,
                                bool firstBlock, char* utf8Out) const
-	int nCur16 = 0;
-	int nCur = 0;
-	ubyte* pRead = reinterpret_cast<ubyte*>(utf16In);
-	ubyte* pCur = reinterpret_cast<ubyte*>(utf8Out);
-	const ubyte* pCurStart = pCur;
-	static eState state = eStart;	// state is retained for subsequent blocks
-	if (firstBlock)
-		state = eStart;
-	// the BOM will automatically be converted to utf-8
-		switch (state)
-			case eStart:
-				if (pRead >= pEnd)
-					++pRead;
-					break;
-				if (isBigEndian)
-					nCur16 = static_cast<utf16>(*pRead++ << 8);
-					nCur16 |= static_cast<utf16>(*pRead);
-				else
-					nCur16 = *pRead++;
-					nCur16 |= static_cast<utf16>(*pRead << 8);
-				if (nCur16 >= SURROGATE_LEAD_FIRST && nCur16 <= SURROGATE_LEAD_LAST)
-					++pRead;
-					int trail;
-					if (isBigEndian)
-						trail = static_cast<utf16>(*pRead++ << 8);
-						trail |= static_cast<utf16>(*pRead);
-					else
-						trail = *pRead++;
-						trail |= static_cast<utf16>(*pRead << 8);
-					nCur16 = (((nCur16 & 0x3ff) << 10) | (trail & 0x3ff)) + SURROGATE_FIRST_VALUE;
-				++pRead;
-				if (nCur16 < 0x80)
-					nCur = static_cast<ubyte>(nCur16 & 0xFF);
-					state = eStart;
-				else if (nCur16 < 0x800)
-					nCur = static_cast<ubyte>(0xC0 | (nCur16 >> 6));
-					state = eFinal;
-				else if (nCur16 < SURROGATE_FIRST_VALUE)
-					nCur = static_cast<ubyte>(0xE0 | (nCur16 >> 12));
-				else
-					nCur = static_cast<ubyte>(0xF0 | (nCur16 >> 18));
-				break;
-				nCur = static_cast<ubyte>(0x80 | ((nCur16 >> 12) & 0x3F));
-				break;
-				nCur = static_cast<ubyte>(0x80 | ((nCur16 >> 6) & 0x3F));
-				state = eFinal;
-				break;
-			case eFinal:
-				nCur = static_cast<ubyte>(0x80 | (nCur16 & 0x3F));
-				state = eStart;
-				break;
-		*pCur++ = static_cast<ubyte>(nCur);
-	return pCur - pCurStart;
+    int nCur16 = 0;
+    int nCur = 0;
+    ubyte* pRead = reinterpret_cast<ubyte*>(utf16In);
+    ubyte* pCur = reinterpret_cast<ubyte*>(utf8Out);
+    const ubyte* pCurStart = pCur;
+    static eState state = eStart;   // state is retained for subsequent blocks
+    if (firstBlock)
+        state = eStart;
+    // the BOM will automatically be converted to utf-8
+        switch (state)
+            case eStart:
+                if (pRead >= pEnd)
+                    ++pRead;
+                    break;
+                if (isBigEndian)
+                    nCur16 = static_cast<utf16>(*pRead++ << 8);
+                    nCur16 |= static_cast<utf16>(*pRead);
+                else
+                    nCur16 = *pRead++;
+                    nCur16 |= static_cast<utf16>(*pRead << 8);
+                if (nCur16 >= SURROGATE_LEAD_FIRST && nCur16 <= SURROGATE_LEAD_LAST)
+                    ++pRead;
+                    int trail;
+                    if (isBigEndian)
+                        trail = static_cast<utf16>(*pRead++ << 8);
+                        trail |= static_cast<utf16>(*pRead);
+                    else
+                        trail = *pRead++;
+                        trail |= static_cast<utf16>(*pRead << 8);
+                    nCur16 = (((nCur16 & 0x3ff) << 10) | (trail & 0x3ff)) + SURROGATE_FIRST_VALUE;
+                ++pRead;
+                if (nCur16 < 0x80)
+                    nCur = static_cast<ubyte>(nCur16 & 0xFF);
+                    state = eStart;
+                else if (nCur16 < 0x800)
+                    nCur = static_cast<ubyte>(0xC0 | (nCur16 >> 6));
+                    state = eFinal;
+                else if (nCur16 < SURROGATE_FIRST_VALUE)
+                    nCur = static_cast<ubyte>(0xE0 | (nCur16 >> 12));
+                else
+                    nCur = static_cast<ubyte>(0xF0 | (nCur16 >> 18));
+                break;
+                nCur = static_cast<ubyte>(0x80 | ((nCur16 >> 12) & 0x3F));
+                break;
+                nCur = static_cast<ubyte>(0x80 | ((nCur16 >> 6) & 0x3F));
+                state = eFinal;
+                break;
+            case eFinal:
+                nCur = static_cast<ubyte>(0x80 | (nCur16 & 0x3F));
+                state = eStart;
+                break;
+        *pCur++ = static_cast<ubyte>(nCur);
+    return pCur - pCurStart;
@@ -4073,7 +4076,7 @@ using namespace astyle;
 extern "C"  EXPORT
 jstring STDCALL Java_AStyleInterface_AStyleGetVersion(JNIEnv* env, jclass)
-	return env->NewStringUTF(g_version);
+    return env->NewStringUTF(g_version);
 // called by a java program to format the source code
@@ -4084,55 +4087,55 @@ jstring STDCALL Java_AStyleInterface_AStyleMain(JNIEnv* env,
                                                 jstring textInJava,
                                                 jstring optionsJava)
-	g_env = env;                                // make object available globally
-	g_obj = obj;                                // make object available globally
-	jstring textErr = env->NewStringUTF("");    // zero length text returned if an error occurs
-	// get the method ID
-	jclass cls = env->GetObjectClass(obj);
-	g_mid = env->GetMethodID(cls, "ErrorHandler", "(ILjava/lang/String;)V");
-	if (g_mid == nullptr)
-		cout << "Cannot find java method ErrorHandler" << endl;
-		return textErr;
-	// convert jstring to char*
-	const char* textIn = env->GetStringUTFChars(textInJava, nullptr);
-	const char* options = env->GetStringUTFChars(optionsJava, nullptr);
-	// call the C++ formatting function
-	char* textOut = AStyleMain(textIn, options, javaErrorHandler, javaMemoryAlloc);
-	// if an error message occurred it was displayed by errorHandler
-	if (textOut == nullptr)
-		return textErr;
-	// release memory
-	jstring textOutJava = env->NewStringUTF(textOut);
-	delete[] textOut;
-	env->ReleaseStringUTFChars(textInJava, textIn);
-	env->ReleaseStringUTFChars(optionsJava, options);
-	return textOutJava;
+    g_env = env;                                // make object available globally
+    g_obj = obj;                                // make object available globally
+    jstring textErr = env->NewStringUTF("");    // zero length text returned if an error occurs
+    // get the method ID
+    jclass cls = env->GetObjectClass(obj);
+    g_mid = env->GetMethodID(cls, "ErrorHandler", "(ILjava/lang/String;)V");
+    if (g_mid == nullptr)
+        cout << "Cannot find java method ErrorHandler" << endl;
+        return textErr;
+    // convert jstring to char*
+    const char* textIn = env->GetStringUTFChars(textInJava, nullptr);
+    const char* options = env->GetStringUTFChars(optionsJava, nullptr);
+    // call the C++ formatting function
+    char* textOut = AStyleMain(textIn, options, javaErrorHandler, javaMemoryAlloc);
+    // if an error message occurred it was displayed by errorHandler
+    if (textOut == nullptr)
+        return textErr;
+    // release memory
+    jstring textOutJava = env->NewStringUTF(textOut);
+    delete[] textOut;
+    env->ReleaseStringUTFChars(textInJava, textIn);
+    env->ReleaseStringUTFChars(optionsJava, options);
+    return textOutJava;
 // Call the Java error handler
 void STDCALL javaErrorHandler(int errorNumber, const char* errorMessage)
-	jstring errorMessageJava = g_env->NewStringUTF(errorMessage);
-	g_env->CallVoidMethod(g_obj, g_mid, errorNumber, errorMessageJava);
+    jstring errorMessageJava = g_env->NewStringUTF(errorMessage);
+    g_env->CallVoidMethod(g_obj, g_mid, errorNumber, errorMessageJava);
 // Allocate memory for the formatted text
 char* STDCALL javaMemoryAlloc(unsigned long memoryNeeded)
-	// error condition is checked after return from AStyleMain
-	return buffer;
+    // error condition is checked after return from AStyleMain
+    return buffer;
-#endif	// ASTYLE_JNI
+#endif  // ASTYLE_JNI
 // ASTYLE_LIB functions for library builds
@@ -4150,42 +4153,42 @@ char* STDCALL javaMemoryAlloc(unsigned long memoryNeeded)
 *           /EXPORT:AStyleGetVersion=_AStyleGetVersion at 0
 * No /EXPORT is required for x64
-extern "C" EXPORT char16_t* STDCALL AStyleMainUtf16(const char16_t* pSourceIn,	// the source to be formatted
-                                                    fpAlloc fpMemoryAlloc)		// memory allocation function
+extern "C" EXPORT char16_t* STDCALL AStyleMainUtf16(const char16_t* pSourceIn,  // the source to be formatted
+                                                    fpAlloc fpMemoryAlloc)      // memory allocation function
-	if (fpErrorHandler == nullptr)         // cannot display a message if no error handler
-		return nullptr;
-	if (pSourceIn == nullptr)
-		fpErrorHandler(101, "No pointer to source input.");
-		return nullptr;
-	if (pOptions == nullptr)
-		fpErrorHandler(102, "No pointer to AStyle options.");
-		return nullptr;
-	if (fpMemoryAlloc == nullptr)
-		fpErrorHandler(103, "No pointer to memory allocation function.");
-		return nullptr;
+    if (fpErrorHandler == nullptr)         // cannot display a message if no error handler
+        return nullptr;
+    if (pSourceIn == nullptr)
+        fpErrorHandler(101, "No pointer to source input.");
+        return nullptr;
+    if (pOptions == nullptr)
+        fpErrorHandler(102, "No pointer to AStyle options.");
+        return nullptr;
+    if (fpMemoryAlloc == nullptr)
+        fpErrorHandler(103, "No pointer to memory allocation function.");
+        return nullptr;
 #ifndef _WIN32
-	// check size of char16_t on Linux
-	int sizeCheck = 2;
-	if (sizeof(char16_t) != sizeCheck)
-		fpErrorHandler(104, "char16_t is not the correct size.");
-		return nullptr;
+    // check size of char16_t on Linux
+    int sizeCheck = 2;
+    if (sizeof(char16_t) != sizeCheck)
+        fpErrorHandler(104, "char16_t is not the correct size.");
+        return nullptr;
 #endif
-	ASLibrary library;
-	char16_t* utf16Out = library.formatUtf16(pSourceIn, pOptions, fpErrorHandler, fpMemoryAlloc);
-	return utf16Out;
+    ASLibrary library;
+    char16_t* utf16Out = library.formatUtf16(pSourceIn, pOptions, fpErrorHandler, fpMemoryAlloc);
+    return utf16Out;
@@ -4198,87 +4201,87 @@ extern "C" EXPORT char16_t* STDCALL AStyleMainUtf16(const char16_t* pSourceIn,	/
-extern "C" EXPORT char* STDCALL AStyleMain(const char* pSourceIn,		// the source to be formatted
-                                           const char* pOptions,		// AStyle options
+extern "C" EXPORT char* STDCALL AStyleMain(const char* pSourceIn,       // the source to be formatted
+                                           const char* pOptions,        // AStyle options
-		return nullptr;
-		return nullptr;
-		return nullptr;
-		return nullptr;
-	ASFormatter formatter;
-	ASOptions options(formatter);
-	vector<string> optionsVector;
-	stringstream opt(pOptions);
-	options.importOptions(opt, optionsVector);
-	bool ok = options.parseOptions(optionsVector, "Invalid Artistic Style options:");
-	if (!ok)
-		fpErrorHandler(130, options.getOptionErrors().c_str());
-	stringstream in(pSourceIn);
-	ASStreamIterator<stringstream> streamIterator(&in);
-	ostringstream out;
-	formatter.init(&streamIterator);
-	while (formatter.hasMoreLines())
-		out << formatter.nextLine();
-		if (formatter.hasMoreLines())
-			out << streamIterator.getOutputEOL();
-		else
-			// this can happen if the file if missing a closing brace and break-blocks is requested
-			if (formatter.getIsLineReady())
-	size_t textSizeOut = out.str().length();
-	char* pTextOut = fpMemoryAlloc((long) textSizeOut + 1);     // call memory allocation function
-	if (pTextOut == nullptr)
-		fpErrorHandler(120, "Allocation failure on output.");
-		return nullptr;
-	strcpy(pTextOut, out.str().c_str());
+        return nullptr;
+        return nullptr;
+        return nullptr;
+        return nullptr;
+    ASFormatter formatter;
+    ASOptions options(formatter);
+    vector<string> optionsVector;
+    stringstream opt(pOptions);
+    options.importOptions(opt, optionsVector);
+    bool ok = options.parseOptions(optionsVector, "Invalid Artistic Style options:");
+    if (!ok)
+        fpErrorHandler(130, options.getOptionErrors().c_str());
+    stringstream in(pSourceIn);
+    ASStreamIterator<stringstream> streamIterator(&in);
+    ostringstream out;
+    formatter.init(&streamIterator);
+    while (formatter.hasMoreLines())
+        out << formatter.nextLine();
+        if (formatter.hasMoreLines())
+            out << streamIterator.getOutputEOL();
+        else
+            // this can happen if the file if missing a closing brace and break-blocks is requested
+            if (formatter.getIsLineReady())
+    size_t textSizeOut = out.str().length();
+    char* pTextOut = fpMemoryAlloc((long) textSizeOut + 1);     // call memory allocation function
+    if (pTextOut == nullptr)
+        fpErrorHandler(120, "Allocation failure on output.");
+        return nullptr;
+    strcpy(pTextOut, out.str().c_str());
 #ifndef NDEBUG
-	// The checksum is an assert in the console build and ASFormatter.
-	// This error returns the incorrectly formatted file to the editor.
-	// This is done to allow the file to be saved for debugging purposes.
-	if (formatter.getChecksumDiff() != 0)
-		fpErrorHandler(220,
-		               "Checksum error.\n"
-		               "The incorrectly formatted file will be returned for debugging.");
+    // The checksum is an assert in the console build and ASFormatter.
+    // This error returns the incorrectly formatted file to the editor.
+    // This is done to allow the file to be saved for debugging purposes.
+    if (formatter.getChecksumDiff() != 0)
+        fpErrorHandler(220,
+                       "Checksum error.\n"
+                       "The incorrectly formatted file will be returned for debugging.");
 #endif
-	return pTextOut;
+    return pTextOut;
 extern "C" EXPORT const char* STDCALL AStyleGetVersion(void)
-	return g_version;
+    return g_version;
 // ASTYLECON_LIB is defined to exclude "main" from the test programs
@@ -4290,23 +4293,23 @@ extern "C" EXPORT const char* STDCALL AStyleGetVersion(void)
 int main(int argc, char** argv)
-	// create objects
-	unique_ptr<ASConsole> console(new ASConsole(formatter));
-	// process command line and option files
-	// build the vectors fileNameVector, optionsVector, and fileOptionsVector
-	vector<string> argvOptions;
-	argvOptions = console->getArgvOptions(argc, argv);
-	console->processOptions(argvOptions);
-	// if no files have been given, use cin for input and cout for output
-	if (!console->fileNameVectorIsEmpty())
-		console->processFiles();
-	else
-		console->formatCinToCout();
-	return EXIT_SUCCESS;
+    // create objects
+    unique_ptr<ASConsole> console(new ASConsole(formatter));
+    // process command line and option files
+    // build the vectors fileNameVector, optionsVector, and fileOptionsVector
+    vector<string> argvOptions;
+    argvOptions = console->getArgvOptions(argc, argv);
+    console->processOptions(argvOptions);
+    // if no files have been given, use cin for input and cout for output
+    if (!console->fileNameVectorIsEmpty())
+        console->processFiles();
+    else
+        console->formatCinToCout();
+    return EXIT_SUCCESS;
Summary of changes:
 tools/astyle/astyle_main.cpp | 6717 +++++++++++++++++++++---------------------
 1 file changed, 3360 insertions(+), 3357 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
