[geos-commits] [SCM] GEOS branch master updated. edc36747409058cb10aeb8d9505d280dfbfcf697
Wed Feb 20 12:59:46 PST 2019
the project "GEOS".
       via  edc36747409058cb10aeb8d9505d280dfbfcf697 (commit)
      from  b2347421b7b7faa6d77ecc615ec26d3cdb5d901c (commit)
revisions in full, below.
commit edc36747409058cb10aeb8d9505d280dfbfcf697
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Feb 20 12:56:13 2019 -0800
    Port JTS InteriorPointArea improvements
diff --git a/include/geos/algorithm/InteriorPointArea.h b/include/geos/algorithm/InteriorPointArea.h
index 3a1bfd5..bc90f4c 100644
--- a/include/geos/algorithm/InteriorPointArea.h
+++ b/include/geos/algorithm/InteriorPointArea.h
@@ -3,9 +3,7 @@
  * GEOS - Geometry Engine Open Source
  * http://geos.osgeo.org
- * Copyright (C) 2013 Sandro Santilli <strk at kbt.io>
- * Copyright (C) 2005-2006 Refractions Research Inc.
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
+ * Copyright (C) 2019 Martin Davis <mtnclimb at gmail.com>
  * This is free software; you can redistribute and/or modify it under
  * the terms of the GNU Lesser General Public Licence as published
@@ -14,7 +12,8 @@
- * Last port: algorithm/InteriorPointArea.java r728 (JTS-1.13+)
+ * Last port: algorithm/InteriorPointArea.java (JTS-1.17+)
+ * https://github.com/locationtech/jts/commit/a140ca30cc51be4f65c950a30b0a8f51a6df75ba
@@ -28,60 +27,59 @@
 namespace geos {
 namespace geom {
 class Geometry;
-class LineString;
-class GeometryFactory;
-class GeometryCollection;
+class Polygon;
 namespace geos {
 namespace algorithm { // geos::algorithm
 /** \brief
  * Computes a point in the interior of an areal geometry.
+ * The point will lie in the geometry interior
+ * in all except certain pathological cases.
  * <h2>Algorithm</h2>
+ * For each input polygon:
  * <ul>
- *   <li>Find a Y value which is close to the centre of
- *       the geometry's vertical extent but is different
- *       to any of it's Y ordinates.
- *   <li>Create a horizontal bisector line using the Y value
- *       and the geometry's horizontal extent
- *   <li>Find the intersection between the geometry
- *       and the horizontal bisector line.
- *       The intersection is a collection of lines and points.
- *   <li>Pick the midpoint of the largest intersection geometry
+ * <li>Determine a horizontal scan line on which the interior
+ * point will be located.
+ * To increase the chance of the scan line
+ * having non-zero-width intersection with the polygon
+ * the scan line Y ordinate is chosen to be near the centre of the polygon's
+ * Y extent but distinct from all of vertex Y ordinates.
+ * <li>Compute the sections of the scan line
+ * which lie in the interior of the polygon.
+ * <li>Choose the widest interior section
+ * and take its midpoint as the interior point.
  * </ul>
+ * The final interior point is chosen as
+ * the one occurring in the widest interior section.
+ * <p>
+ * This algorithm is a tradeoff between performance
+ * and point quality (where points further from the geometry
+ * boundary are considered to be higher quality)
+ * Priority is given to performance.
+ * This means that the computed interior point
+ * may not be suitable for some uses
+ * (such as label positioning).
+ * <p>
+ * The algorithm handles some kinds of invalid/degenerate geometry,
+ * including zero-area and self-intersecting polygons.
+ * <p>
+ * Empty geometry is handled by returning a <code>null</code> point.
- * <b>
- * Note: If a fixed precision model is used,
- * in some cases this method may return a point
- * which does not lie in the interior.
- * </b>
+ * <h3>KNOWN BUGS</h3>
+ * <ul>
+ * <li>If a fixed precision model is used, in some cases this method may return
+ * a point which does not lie in the interior.
+ * <li>If the input polygon is <i>extremely</i> narrow the computed point
+ * may not lie in the interior of the polygon.
+ * </ul>
 class GEOS_DLL InteriorPointArea {
-private:
-    bool foundInterior;
-    const geom::GeometryFactory* factory;
-    geom::Coordinate interiorPoint;
-    double maxWidth;
-    void add(const geom::Geometry* geom);
-    const geom::Geometry* widestGeometry(const geom::Geometry* geometry);
-    const geom::Geometry* widestGeometry(const geom::GeometryCollection* gc);
-    geom::LineString* horizontalBisector(const geom::Geometry* geometry);
 public:
      * Creates a new interior point finder
      * for an areal geometry.
@@ -96,19 +94,17 @@ public:
      * Gets the computed interior point.
      * @return the coordinate of an interior point
+     *  or <code>null</code> if the input geometry is empty
     bool getInteriorPoint(geom::Coordinate& ret) const;
 private:
+    geom::Coordinate interiorPoint;
+    double maxWidth;
-    /** \brief
-     * Finds an interior point of a Polygon
-     * @param geometry the geometry to analyze
-     * @return the midpoint of the largest intersection between the geometry and
-     * a line halfway down its envelope
-    void addPolygon(const geom::Geometry* geometry);
+    void process(const geom::Geometry* geom);
+    void processPolygon(const geom::Polygon* polygon);
diff --git a/src/algorithm/InteriorPointArea.cpp b/src/algorithm/InteriorPointArea.cpp
index 5eaa674..ca335e4 100644
--- a/src/algorithm/InteriorPointArea.cpp
+++ b/src/algorithm/InteriorPointArea.cpp
@@ -3,9 +3,7 @@
@@ -14,7 +12,8 @@
@@ -23,10 +22,12 @@
 #include <geos/geom/Geometry.h>
 #include <geos/geom/GeometryCollection.h>
 #include <geos/geom/Polygon.h>
+#include <geos/geom/LinearRing.h>
 #include <geos/geom/LineString.h>
 #include <geos/geom/Envelope.h>
 #include <geos/geom/GeometryFactory.h>
 #include <geos/geom/CoordinateSequenceFactory.h>
+#include <geos/util/Interrupt.h>
 #include <vector>
 #include <typeinfo>
@@ -38,7 +39,7 @@ using namespace geos::geom;
 namespace geos {
 namespace algorithm { // geos.algorithm
-// file-statics
+// file statics
 namespace {
 double
@@ -48,24 +49,30 @@ avg(double a, double b)
- * Finds a safe bisector Y ordinate
- * by projecting to the Y axis
- * and finding the Y-ordinate interval
- * which contains the centre of the Y extent.
- * The centre of this interval is returned as the bisector Y-ordinate.
+ * Finds a safe scan line Y ordinate by projecting
+ * the polygon segments
+ * to the Y axis and finding the
+ * Y-axis interval which contains the centre of the Y extent.
+ * The centre of
+ * this interval is returned as the scan line Y-ordinate.
+ * <p>
+ * Note that in the case of (degenerate, invalid)
+ * zero-area polygons the computed Y value
+ * may be equal to a vertex Y-ordinate.
  * @author mdavis
-class SafeBisectorFinder {
+class ScanLineYOrdinateFinder {
 public:
     static double
-    getBisectorY(const Polygon& poly)
+    getScanLineY(const Polygon& poly)
-        SafeBisectorFinder finder(poly);
-        return finder.getBisectorY();
+        ScanLineYOrdinateFinder finder(poly);
+        return finder.getScanLineY();
-    SafeBisectorFinder(const Polygon& nPoly)
+    ScanLineYOrdinateFinder(const Polygon& nPoly)
         : poly(nPoly)
         // initialize using extremal values
@@ -75,7 +82,7 @@ public:
     double
-    getBisectorY()
+    getScanLineY()
         process(*poly.getExteriorRing());
         for(size_t i = 0; i < poly.getNumInteriorRing(); i++) {
@@ -85,7 +92,6 @@ public:
         return bisectY;
 private:
     const Polygon& poly;
@@ -117,145 +123,220 @@ private:
+class InteriorPointPolygon {
+public:
+    InteriorPointPolygon(const Polygon& poly)
+        : polygon(poly)
+        interiorPointY = ScanLineYOrdinateFinder::getScanLineY(polygon);
+    bool
+    getInteriorPoint(Coordinate& ret) const
+        ret = interiorPoint;
+        return true;
+    double getWidth()
+        return interiorSectionWidth;
+    void
+    process()
+         * This results in returning a null Coordinate
+        if (polygon.isEmpty()) return;
+         * set default interior point in case polygon has zero area
+        interiorPoint = *polygon.getCoordinate();
+        const LinearRing* shell = dynamic_cast<const LinearRing*>(polygon.getExteriorRing());
+        scanRing( *shell );
+        for (size_t i = 0; i < polygon.getNumInteriorRing(); i++) {
+            const LinearRing* hole = dynamic_cast<const LinearRing*>(polygon.getInteriorRingN(i));
+            scanRing( *hole );
+        findBestMidpoint(crossings);
+private:
+    const Polygon& polygon;
+    double interiorPointY;
+    double interiorSectionWidth = 0.0;
+    vector<double> crossings;
+    Coordinate interiorPoint;
+    void scanRing(const LinearRing& ring)
+        // skip rings which don't cross scan line
+        if ( ! intersectsHorizontalLine( ring.getEnvelopeInternal(), interiorPointY) )
+            return;
+        const CoordinateSequence* seq = ring.getCoordinatesRO();
+        for (size_t i = 1; i < seq->size(); i++) {
+            Coordinate ptPrev = seq->getAt(i - 1);
+            Coordinate pt = seq->getAt(i);
+            addEdgeCrossing(ptPrev, pt, interiorPointY, crossings);
+    void addEdgeCrossing(Coordinate& p0, Coordinate& p1, double scanY, vector<double>& crossings) {
+      // skip non-crossing segments
+      if ( !intersectsHorizontalLine(p0, p1, scanY) )
+        return;
+      if (! isEdgeCrossingCounted(p0, p1, scanY) )
+        return;
+      // edge intersects scan line, so add a crossing
+      double xInt = intersection(p0, p1, scanY);
+      crossings.push_back(xInt);
+      //checkIntersectionDD(p0, p1, scanY, xInt);
+    void findBestMidpoint(vector<double>& crossings)
+        // zero-area polygons will have no crossings
+        if (crossings.size() == 0) return;
+        //Assert.isTrue(0 == crossings.size() % 2, "Interior Point robustness failure: odd number of scanline crossings");
+        sort(crossings.begin(), crossings.end());
+         * Entries in crossings list are expected to occur in pairs representing a
+         * section of the scan line interior to the polygon (which may be zero-length)
+        for (size_t i = 0; i < crossings.size(); i += 2) {
+            double x1 = crossings[i];
+            // crossings count must be even so this should be safe
+            double x2 = crossings[i + 1];
+            double width = x2 - x1;
+            if ( width > interiorSectionWidth ) {
+                interiorSectionWidth = width;
+                double interiorPointX = avg(x1, x2);
+                interiorPoint = Coordinate(interiorPointX, interiorPointY);
-    SafeBisectorFinder(SafeBisectorFinder const&); /*= delete*/
-    SafeBisectorFinder& operator=(SafeBisectorFinder const&); /*= delete*/
+    static bool
+    isEdgeCrossingCounted(Coordinate& p0, Coordinate& p1, double scanY) {
+      // skip horizontal lines
+      if ( p0.y == p1.y )
+        return false;
+      // handle cases where vertices lie on scan-line
+      // downward segment does not include start point
+      if ( p0.y == scanY && p1.y < scanY )
+        return false;
+      // upward segment does not include endpoint
+      if ( p1.y == scanY && p0.y < scanY )
+        return false;
+      return true;
+    static double
+    intersection(const Coordinate& p0, const Coordinate& p1, double Y)
+        double x0 = p0.x;
+        double x1 = p1.x;
+        if ( x0 == x1 )
+        return x0;
+        // Assert: segDX is non-zero, due to previous equality test
+        double segDX = x1 - x0;
+        double segDY = p1.y - p0.y;
+        double m = segDY / segDX;
+        double x = x0 + ((Y - p0.y) / m);
+        return x;
+    static bool
+    intersectsHorizontalLine(const Envelope* env, double y)
+        if ( y < env->getMinY() )
+            return false;
+        if ( y > env->getMaxY() )
+            return false;
+        return true;
+    static bool
+    intersectsHorizontalLine(const Coordinate& p0, const Coordinate& p1, double y) {
+      // both ends above?
+      if ( p0.y > y && p1.y > y )
+        return false;
+      // both ends below?
+      if ( p0.y < y && p1.y < y )
+        return false;
+      // segment must intersect line
+      return true;
 } // anonymous namespace
-/*public*/
 InteriorPointArea::InteriorPointArea(const Geometry* g)
-    foundInterior = false;
-    maxWidth = 0.0;
-    factory = g->getFactory();
-    add(g);
+    maxWidth = -1;
+    process(g);
-/*public*/
 InteriorPointArea::~InteriorPointArea()
-/*public*/
 bool
 InteriorPointArea::getInteriorPoint(Coordinate& ret) const
-    if(! foundInterior) {
+    // GEOS-specific code
+    if (maxWidth < 0)
         return false;
     return true;
-/*public*/
+/*private*/
 void
-InteriorPointArea::add(const Geometry* geom)
+InteriorPointArea::process(const Geometry* geom)
+    if (geom->isEmpty())
+        return;
     const Polygon* poly = dynamic_cast<const Polygon*>(geom);
     if(poly) {
-        addPolygon(geom);
+        processPolygon(poly);
         return;
     const GeometryCollection* gc = dynamic_cast<const GeometryCollection*>(geom);
     if(gc) {
         for(std::size_t i = 0, n = gc->getNumGeometries(); i < n; i++) {
-            add(gc->getGeometryN(i));
+            process(gc->getGeometryN(i));
+            GEOS_CHECK_FOR_INTERRUPTS();
 /*private*/
 void
-InteriorPointArea::addPolygon(const Geometry* geometry)
+InteriorPointArea::processPolygon(const Polygon* polygon)
-    if(geometry->isEmpty()) {
-        return;
+    InteriorPointPolygon intPtPoly(*polygon);
+    intPtPoly.process();
+    double width = intPtPoly.getWidth();
+    if ( width > maxWidth ) {
+      maxWidth = width;
+      intPtPoly.getInteriorPoint(interiorPoint);
-    Coordinate intPt;
-    double width;
-    unique_ptr<LineString> bisector(horizontalBisector(geometry));
-    if(bisector->getLength() == 0.0) {
-        width = 0;
-        intPt = bisector->getCoordinateN(0);
-    else {
-        unique_ptr<Geometry> intersections(bisector->intersection(geometry));
-        const Geometry* widestIntersection = widestGeometry(intersections.get());
-        const Envelope* env = widestIntersection->getEnvelopeInternal();
-        width = env->getWidth();
-        env->centre(intPt);
-    if(!foundInterior || width > maxWidth) {
-        interiorPoint = intPt;
-        maxWidth = width;
-        foundInterior = true;
-//@return if geometry is a collection, the widest sub-geometry; otherwise,
-//the geometry itself
-const Geometry*
-InteriorPointArea::widestGeometry(const Geometry* geometry)
-    const GeometryCollection* gc = dynamic_cast<const GeometryCollection*>(geometry);
-    if(gc) {
-        return widestGeometry(gc);
-    else {
-        return geometry;
-const Geometry*
-InteriorPointArea::widestGeometry(const GeometryCollection* gc)
-    if(gc->isEmpty()) {
-        return gc;
-    const Geometry* p_widestGeometry = gc->getGeometryN(0);
-    // scan remaining geom components to see if any are wider
-    for(std::size_t i = 1, n = gc->getNumGeometries(); i < n; i++) { // start at 1
-        const Envelope* env1(gc->getGeometryN(i)->getEnvelopeInternal());
-        const Envelope* env2(p_widestGeometry->getEnvelopeInternal());
-        if(env1->getWidth() > env2->getWidth()) {
-            p_widestGeometry = gc->getGeometryN(i);
-    return p_widestGeometry;
-/* private */
-LineString*
-InteriorPointArea::horizontalBisector(const Geometry* geometry)
-    const Envelope* envelope = geometry->getEnvelopeInternal();
-     * Original algorithm.  Fails when geometry contains a horizontal
-     * segment at the Y midpoint.
-    // Assert: for areas, minx <> maxx
-    //double avgY=avg(envelope->getMinY(),envelope->getMaxY());
-    double bisectY = SafeBisectorFinder::getBisectorY(*dynamic_cast<const Polygon*>(geometry));
-    vector<Coordinate>* cv = new vector<Coordinate>(2);
-    (*cv)[0].x = envelope->getMinX();
-    (*cv)[0].y = bisectY;
-    (*cv)[1].x = envelope->getMaxX();
-    (*cv)[1].y = bisectY;
-    CoordinateSequence* cl = factory->getCoordinateSequenceFactory()->create(cv);
-    LineString* ret = factory->createLineString(cl);
-    return ret;
 } // namespace geos.algorithm
diff --git a/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp b/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp
index c118439..9ff3913 100644
--- a/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp
+++ b/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp
@@ -59,7 +59,8 @@ public:
          * algorithm, and provides a more realistic test.
         using geos::precision::SimpleGeometryPrecisionReducer;
-        PrecisionModel p_pm(SIZE);
+        double scale = nPts / SIZE;
+        PrecisionModel p_pm(scale);
         SimpleGeometryPrecisionReducer reducer(&p_pm);
         std::unique_ptr<Geometry> sinePolyCrinkly(reducer.reduce(sinePoly.get()));
         sinePoly.reset();
@@ -106,7 +107,6 @@ private:
         sw.stop();
         cout << poly.getNumPoints() << " points: " << sw.getTotFormatted() << endl;
     std::unique_ptr<Polygon>
@@ -131,6 +131,7 @@ main()
     InteriorPointAreaPerfTest tester;
+    tester.test(100);
     tester.test(1000);
     tester.test(10000);
     tester.test(100000);
diff --git a/tests/unit/algorithm/InteriorPointAreaTest.cpp b/tests/unit/algorithm/InteriorPointAreaTest.cpp
index fa9a82c..32cd3c8 100644
--- a/tests/unit/algorithm/InteriorPointAreaTest.cpp
+++ b/tests/unit/algorithm/InteriorPointAreaTest.cpp
@@ -3,6 +3,7 @@
  * Copyright (C) 2011      Sandro Santilli <strk at kbt.io>
@@ -55,29 +56,24 @@ group test_interiorpointarea_group("geos::algorithm::InteriorPointArea");
 // http://trac.osgeo.org/geos/ticket/475
-// This is a test for a memory leak more than anything else
+// This test no longer throws, since invalid inputs are now handled
 template<>
 template<>
 void object::test<1>
-    Coordinate centroid;
+    Coordinate result;
-    // this polygon is a typical hourglass-shape with a self intersection
+    // invalid polygon - classic hourglass-shape with a self intersection
     // without a node
     geom.reset(reader.read("POLYGON((6 54, 15 54, 6 47, 15 47, 6 54))"));
-    bool threw = false;
+    InteriorPointArea interiorPointArea(geom.get());
+    interiorPointArea.getInteriorPoint(result);
-    try {
-        InteriorPointArea interior_builder(geom.get());
-        interior_builder.getInteriorPoint(centroid);
-    catch(...) {
-        threw = true;
+    geos::geom::Coordinate expected(6, 54);
-    ensure(threw);
+    ensure_equals(result, expected);
 } // namespace tut
diff --git a/tests/unit/capi/GEOSPointOnSurfaceTest.cpp b/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
index e4899c0..2957558 100644
--- a/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
+++ b/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
@@ -150,7 +150,7 @@ void object::test<4>
     wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
-    ensure_equals(std::string(wkt_), std::string("POINT (56.528917 25.210417)"));
+    ensure_equals(std::string(wkt_), std::string("POINT (56.528667 25.210167)"));
Summary of changes:
 include/geos/algorithm/InteriorPointArea.h         |  94 +++----
 src/algorithm/InteriorPointArea.cpp                | 313 +++++++++++++--------
 tests/perf/algorithm/InteriorPointAreaPerfTest.cpp |   5 +-
 tests/unit/algorithm/InteriorPointAreaTest.cpp     |  20 +-
 tests/unit/capi/GEOSPointOnSurfaceTest.cpp         |   2 +-
 5 files changed, 254 insertions(+), 180 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
