[geos-commits] [SCM] GEOS branch master updated. 1ebed610582ad026cd08425423b3ecd95f0dd2e6
git at osgeo.org
git at osgeo.org
Wed Jan 23 08:24:29 PST 2019
the project "GEOS".
via 1ebed610582ad026cd08425423b3ecd95f0dd2e6 (commit)
via fa7e4f8219395f6f9d4c4c67f1a6b567b5a59f47 (commit)
from df24b6bb8ba421d45cd4a0c4732a847b0b6e0d56 (commit)
revisions in full, below.
commit 1ebed610582ad026cd08425423b3ecd95f0dd2e6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Jan 23 08:23:49 2019 -0800
Add test case and fix intersection finger
diff --git a/src/noding/NodingIntersectionFinder.cpp b/src/noding/NodingIntersectionFinder.cpp
index 98c10c4..a86b5c5 100644
--- a/src/noding/NodingIntersectionFinder.cpp
+++ b/src/noding/NodingIntersectionFinder.cpp
@@ -121,14 +121,13 @@ NodingIntersectionFinder::processIntersections(
if (isInteriorInt || isInteriorVertexInt)
// found an intersection!
- // TODO: record endpoint intersection(s)
- // Coordinate intSegments[4];
- // intSegments[0] = p00;
- // intSegments[1] = p01;
- // intSegments[2] = p10;
- // intSegments[3] = p11;
+ intSegments.push_back(p00);
+ intSegments.push_back(p01);
+ intSegments.push_back(p10);
+ intSegments.push_back(p11);
interiorIntersection = li.getIntersection(0);
+ // TODO: record endpoint intersection(s)
// if (keepIntersections) intersections.add(interiorIntersection);
intersectionCount++;
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index 0ea8f77..47e8b8b 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -131,6 +131,7 @@ if(GEOS_ENABLE_TESTS)
${XMLTESTS_DIR}/ticket/bug615.xml
${XMLTESTS_DIR}/ticket/bug716.xml
${XMLTESTS_DIR}/ticket/bug837.xml
+ ${XMLTESTS_DIR}/ticket/bug838.xml
${XMLTESTS_DIR}/validate/TestRelateAA-big.xml
${XMLTESTS_DIR}/validate/TestRelateAA.xml
${XMLTESTS_DIR}/validate/TestRelateAC.xml
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index 2f7cff5..87b2b4f 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -100,6 +100,7 @@ SAFE_XMLTESTS= \
$(srcdir)/tests/ticket/bug615.xml \
$(srcdir)/tests/ticket/bug716.xml \
$(srcdir)/tests/ticket/bug837.xml \
+ $(srcdir)/tests/ticket/bug838.xml \
$(srcdir)/tests/validate/TestRelateAA-big.xml \
$(srcdir)/tests/validate/TestRelateAA.xml \
$(srcdir)/tests/validate/TestRelateAC.xml \
diff --git a/tests/xmltester/tests/ticket/bug838.xml b/tests/xmltester/tests/ticket/bug838.xml
new file mode 100644
index 0000000..7e15c28
--- /dev/null
+++ b/tests/xmltester/tests/ticket/bug838.xml
@@ -0,0 +1,23 @@
+<run>
+<precisionModel type="FLOATING" />
+<case>
+<desc>
+Union of two valid polygons resulting in an invalid geometry in JTS 1.15.
+See https://trac.osgeo.org/geos/ticket/838.
+Failure is due to very close vertices leading to noding robustness failure.
+Fixed by improved noding validation detection, which allows
+snapping heuristic to be activated.
+</desc>
+<a>
+00000000060000000200000000030000000100000005412CD75B00000000413D8F0966666667412CD75933333333413D8F6D80000000412CD82166666667413D8F6E4CCCCCCD412CD82500000000413D8EA61999999A412CD75B00000000413D8F096666666700000000030000000100000005412CD82500000001413D8EA61999999A412CD82333333334413D8F0A33333333412CD8EB66666666413D8F0B19999999412CD8ED33333333413D8EA700000001412CD82500000001413D8EA61999999A
+</a>
+<b>
+00000000030000000100000007412CD9D4D50CE8F7413D8EA7FBC39C12412CD8ED33333333413D8EA700000000412CD8EB66666667413D8F0B1999999A412CD82333333333413D8F0A33333333412CD82166666667413D8F6E4CCCCCCD412CD9B1CCCCCCCD413D8F701999999A412CD9D4D50CE8F7413D8EA7FBC39C12
+</b>
+<test>
+<op name="union" arg1="A" arg2="B">
+0103000000010000000A000000000000005BD72C4167666666098F3D413333333359D72C41000000806D8F3D416766666621D82C41CDCCCC4C6E8F3D41CDCCCCCCB1D92C419A999919708F3D41F7E80CD5D4D92C41129CC3FBA78E3D4133333333EDD82C4100000000A78E3D410100000025D82C419A999919A68E3D413333333323D82C41333333330A8F3D410000000025D82C419A999919A68E3D41000000005BD72C4167666666098F3D41
+</op>
+</test>
+</case>
+</run>
commit fa7e4f8219395f6f9d4c4c67f1a6b567b5a59f47
Date: Tue Jan 22 15:32:32 2019 -0800
Improve overlay noding validation
JTS 06fa68bf9e6e445f0252ae5fc0dac33e86b4f890
diff --git a/include/geos/noding/FastNodingValidator.h b/include/geos/noding/FastNodingValidator.h
index 9675c58..c9b6622 100644
--- a/include/geos/noding/FastNodingValidator.h
+++ b/include/geos/noding/FastNodingValidator.h
@@ -19,7 +19,7 @@
#ifndef GEOS_NODING_FASTNODINGVALIDATOR_H
#define GEOS_NODING_FASTNODINGVALIDATOR_H
-#include <geos/noding/SingleInteriorIntersectionFinder.h> // for composition
+#include <geos/noding/NodingIntersectionFinder.h> // for composition
#include <geos/algorithm/LineIntersector.h> // for composition
#include <memory>
@@ -39,16 +39,23 @@ namespace noding { // geos.noding
/** \brief
* Validates that a collection of {@link SegmentString}s is correctly noded.
- * Uses indexes to improve performance.
- * Does NOT check a-b-a collapse situations.
- * Also does not check for endpt-interior vertex intersections.
- * This should not be a problem, since the noders should be
- * able to compute intersections between vertices correctly.
- * User may either test the valid condition, or request that a
- * {@link TopologyException}
- * be thrown.
+ * Indexing is used to improve performance.
+ * By default validation stops after a single
+ * non-noded intersection is detected.
+ * Alternatively, it can be requested to detect all intersections
+ * by using {@link #setFindAllIntersections(boolean)}.
+* The validator does not check for topology collapse situations
+ * (e.g. where two segment strings are fully co-incident).
+ * The validator checks for the following situations which indicated incorrect noding:
+ * - Proper intersections between segments (i.e. the intersection is interior to both segments)
+ * - Intersections at an interior vertex (i.e. with an endpoint or another interior vertex)
+ * The client may either test the {@link #isValid()} condition,
+ * or request that a suitable {@link TopologyException} be thrown.
- * @version 1.7
class FastNodingValidator
@@ -98,7 +105,7 @@ private:
std::vector<noding::SegmentString*>& segStrings;
- std::unique_ptr<SingleInteriorIntersectionFinder> segInt;
+ std::unique_ptr<NodingIntersectionFinder> segInt;
bool isValidVar;
diff --git a/include/geos/noding/Makefile.am b/include/geos/noding/Makefile.am
index f1814fe..30cf761 100644
--- a/include/geos/noding/Makefile.am
+++ b/include/geos/noding/Makefile.am
@@ -8,31 +8,31 @@ EXTRA_DIST =
geosdir = $(includedir)/geos/noding
geos_HEADERS = \
- BasicSegmentString.h \
- FastNodingValidator.h \
- FastSegmentSetIntersectionFinder.h \
- GeometryNoder.h \
- IntersectionAdder.h \
- IntersectionFinderAdder.h \
- IteratedNoder.h \
- MCIndexNoder.h \
- MCIndexNoder.inl \
- MCIndexSegmentSetMutualIntersector.h \
- NodableSegmentString.h \
- NodedSegmentString.h \
- Noder.h \
- NodingValidator.h \
- Octant.h \
- OrientedCoordinateArray.h \
- ScaledNoder.h \
- SegmentIntersectionDetector.h \
- SegmentIntersector.h \
- SegmentNode.h \
- SegmentNodeList.h \
- SegmentPointComparator.h \
- SegmentSetMutualIntersector.h \
- SegmentString.h \
- SegmentStringUtil.h \
- SimpleNoder.h \
- SingleInteriorIntersectionFinder.h \
- SinglePassNoder.h
+ BasicSegmentString.h \
+ FastNodingValidator.h \
+ FastSegmentSetIntersectionFinder.h \
+ GeometryNoder.h \
+ IntersectionAdder.h \
+ IntersectionFinderAdder.h \
+ IteratedNoder.h \
+ MCIndexNoder.h \
+ MCIndexNoder.inl \
+ MCIndexSegmentSetMutualIntersector.h \
+ NodableSegmentString.h \
+ NodedSegmentString.h \
+ Noder.h \
+ NodingValidator.h \
+ Octant.h \
+ OrientedCoordinateArray.h \
+ ScaledNoder.h \
+ SegmentIntersectionDetector.h \
+ SegmentIntersector.h \
+ SegmentNode.h \
+ SegmentNodeList.h \
+ SegmentPointComparator.h \
+ SegmentSetMutualIntersector.h \
+ SegmentString.h \
+ SegmentStringUtil.h \
+ SimpleNoder.h \
+ NodingIntersectionFinder.h \
+ SinglePassNoder.h
diff --git a/include/geos/noding/NodingIntersectionFinder.h b/include/geos/noding/NodingIntersectionFinder.h
index 0000000..c7d2f26
--- /dev/null
+++ b/include/geos/noding/NodingIntersectionFinder.h
@@ -0,0 +1,220 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2006 Refractions Research Inc.
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#ifndef GEOS_NODING_NODINGINTERSECTIONFINDER_H
+#define GEOS_NODING_NODINGINTERSECTIONFINDER_H
+#include <geos/noding/SegmentIntersector.h> // for inheritance
+#include <geos/geom/Coordinate.h> // for composition
+#include <vector>
+// Forward declarations
+namespace geos {
+ namespace algorithm {
+ class LineIntersector;
+ namespace noding {
+ class SegmentString;
+namespace geos {
+namespace noding { // geos.noding
+ * \brief Finds non-noded intersections in a set of {@link SegmentString}s, if any exist.
+ * Non-noded intersections include:
+ * - intersections which lie in the interior of a segment
+ * - intersections at a vertex in the interior of a {@link SegmentString}
+ * (e.g. with a segment string endpoint or other interior vertex)
+ * @version 1.7
+class NodingIntersectionFinder: public SegmentIntersector
+public:
+ /** \brief
+ * Creates an intersection finder which finds an interior intersection
+ * if one exists
+ * @param li the LineIntersector to use
+ NodingIntersectionFinder(algorithm::LineIntersector& newLi)
+ li(newLi),
+ interiorIntersection(geom::Coordinate::getNull()),
+ intersectionCount(0),
+ isCheckEndSegmentsOnly(false),
+ findAllIntersections(false),
+ keepIntersections(true)
+ /** \brief
+ * Tests whether an intersection was found.
+ * @return true if an intersection was found
+ bool hasIntersection() const
+ return !interiorIntersection.isNull();
+ /** \brief
+ * Gets the computed location of the intersection.
+ * Due to round-off, the location may not be exact.
+ * @return the coordinate for the intersection location
+ const geom::Coordinate& getInteriorIntersection() const
+ return interiorIntersection;
+ * Gets the count of intersections found.
+ * @return the intersection count
+ size_t count() const
+ return intersectionCount;
+ * Sets whether only end segments should be tested for interior intersection.
+ * This is a performance optimization that may be used if
+ * the segments have been previously noded by an appropriate algorithm.
+ * It may be known that any potential noding failures will occur only in
+ * end segments.
+ * @param isCheckEndSegmentsOnly whether to test only end segments
+ void setCheckEndSegmentsOnly(bool isCESO)
+ isCheckEndSegmentsOnly = isCESO;
+ * Sets whether all intersections should be computed.
+ * When this is <code>false</code> (the default value)
+ * the value of {@link #isDone()} is <code>true</code> after the first intersection is found.
+ * <p>
+ * Default is <code>false</code>.
+ * @param findAllIntersections whether all intersections should be computed
+ void setFindAllIntersections(bool fAI)
+ findAllIntersections = fAI;
+ /** \brief
+ * Gets the endpoints of the intersecting segments.
+ * @return an array of the segment endpoints (p00, p01, p10, p11)
+ const std::vector<geom::Coordinate>& getIntersectionSegments() const
+ return intSegments;
+ /** \brief
+ * This method is called by clients
+ * of the {@link SegmentIntersector} class to process
+ * intersections for two segments of the {@link SegmentStrings} being intersected.
+ * Note that some clients (such as {@link MonotoneChain}s) may optimize away
+ * this call for segment pairs which they have determined do not intersect
+ * (e.g. by an disjoint envelope test).
+ void processIntersections(
+ SegmentString* e0, size_t segIndex0,
+ SegmentString* e1, size_t segIndex1) override;
+ bool isDone() const override
+private:
+ algorithm::LineIntersector& li;
+ geom::Coordinate interiorIntersection;
+ size_t intersectionCount;
+ bool isCheckEndSegmentsOnly;
+ bool findAllIntersections;
+ bool keepIntersections;
+ std::vector<geom::Coordinate> intSegments;
+ // Declare type as noncopyable
+ NodingIntersectionFinder(const NodingIntersectionFinder& other) = delete;
+ NodingIntersectionFinder& operator=(const NodingIntersectionFinder& rhs) = delete;
+ * Tests if two vertices with at least one in a segmentString interior
+ * are equal.
+ * @param p0 a segment vertex
+ * @param p1 a segment vertex
+ * @param isEnd0 true if vertex is a segmentString endpoint
+ * @param isEnd1 true if vertex is a segmentString endpoint
+ * @return true if an intersection is found
+ bool isInteriorVertexIntersection(
+ const geom::Coordinate& p0, const geom::Coordinate& p1,
+ bool isEnd0, bool isEnd1);
+ * Tests if an intersection occurs between a segmentString interior vertex and another vertex.
+ * Note that intersections between two endpoint vertices are valid noding,
+ * and are not flagged.
+ * @param p00 a segment vertex
+ * @param p01 a segment vertex
+ * @param p10 a segment vertex
+ * @param p11 a segment vertex
+ * @param isEnd00 true if vertex is a segmentString endpoint
+ * @param isEnd01 true if vertex is a segmentString endpoint
+ * @param isEnd10 true if vertex is a segmentString endpoint
+ * @param isEnd11 true if vertex is a segmentString endpoint
+ const geom::Coordinate& p00, const geom::Coordinate& p01,
+ const geom::Coordinate& p10, const geom::Coordinate& p11,
+ bool isEnd00, bool isEnd01, bool isEnd10, bool isEnd11);
+ * Tests whether a segment in a {@link SegmentString} is an end segment.
+ * (either the first or last).
+ * @param segStr a segment string
+ * @param index the index of a segment in the segment string
+ * @return true if the segment is an end segment
+ bool isEndSegment(const SegmentString* segStr, size_t index);
+} // namespace geos.noding
+#endif // GEOS_NODING_NODINGINTERSECTIONFINDER_H
diff --git a/include/geos/noding/SingleInteriorIntersectionFinder.h b/include/geos/noding/SingleInteriorIntersectionFinder.h
deleted file mode 100644
index 8a3c6c4..0000000
--- a/include/geos/noding/SingleInteriorIntersectionFinder.h
+++ /dev/null
@@ -1,123 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2006 Refractions Research Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
-#ifndef GEOS_NODING_SINGLEINTERIORINTERSECTIONFINDER_H
-#define GEOS_NODING_SINGLEINTERIORINTERSECTIONFINDER_H
-#include <geos/noding/SegmentIntersector.h> // for inheritance
-#include <geos/geom/Coordinate.h> // for composition
-#include <vector>
-// Forward declarations
-namespace geos {
- namespace algorithm {
- class LineIntersector;
- namespace noding {
- class SegmentString;
-namespace geos {
-namespace noding { // geos.noding
- * \brief
- * Finds an interior intersection in a set of SegmentString,
- * if one exists. Only the first intersection found is reported.
- * @version 1.7
-class SingleInteriorIntersectionFinder: public SegmentIntersector
-public:
- /** \brief
- * Creates an intersection finder which finds an interior intersection
- * if one exists
- * @param li the LineIntersector to use
- SingleInteriorIntersectionFinder(algorithm::LineIntersector& newLi)
- li(newLi),
- interiorIntersection(geom::Coordinate::getNull())
- /** \brief
- * Tests whether an intersection was found.
- * @return true if an intersection was found
- bool hasIntersection() const
- return !interiorIntersection.isNull();
- /** \brief
- * Gets the computed location of the intersection.
- * Due to round-off, the location may not be exact.
- * @return the coordinate for the intersection location
- const geom::Coordinate& getInteriorIntersection() const
- return interiorIntersection;
- /** \brief
- * Gets the endpoints of the intersecting segments.
- * @return an array of the segment endpoints (p00, p01, p10, p11)
- const std::vector<geom::Coordinate>& getIntersectionSegments() const
- return intSegments;
- /** \brief
- * This method is called by clients
- * of the {@link SegmentIntersector} class to process
- * intersections for two segments of the {@link SegmentStrings} being intersected.
- * Note that some clients (such as {@link MonotoneChain}s) may optimize away
- * this call for segment pairs which they have determined do not intersect
- * (e.g. by an disjoint envelope test).
- void processIntersections(
- SegmentString* e0, size_t segIndex0,
- SegmentString* e1, size_t segIndex1) override;
- bool isDone() const override
-private:
- algorithm::LineIntersector& li;
- geom::Coordinate interiorIntersection;
- std::vector<geom::Coordinate> intSegments;
- // Declare type as noncopyable
- SingleInteriorIntersectionFinder(const SingleInteriorIntersectionFinder& other) = delete;
- SingleInteriorIntersectionFinder& operator=(const SingleInteriorIntersectionFinder& rhs) = delete;
-} // namespace geos.noding
-#endif // GEOS_NODING_SINGLEINTERIORINTERSECTIONFINDER_H
diff --git a/src/Makefile.vc b/src/Makefile.vc
index f67802d..28beef0 100644
--- a/src/Makefile.vc
+++ b/src/Makefile.vc
@@ -187,7 +187,7 @@ OBJ = \
noding\SegmentString.$(EXT) \
noding\SegmentStringUtil.$(EXT) \
noding\SimpleNoder.$(EXT) \
- noding\SingleInteriorIntersectionFinder.$(EXT) \
+ noding\NodingIntersectionFinder.$(EXT) \
noding\snapround\HotPixel.$(EXT) \
noding\snapround\MCIndexPointSnapper.$(EXT) \
noding\snapround\MCIndexSnapRounder.$(EXT) \
diff --git a/src/noding/FastNodingValidator.cpp b/src/noding/FastNodingValidator.cpp
index 69223bf..eb6e3f9 100644
--- a/src/noding/FastNodingValidator.cpp
+++ b/src/noding/FastNodingValidator.cpp
@@ -18,7 +18,7 @@
#include <geos/noding/FastNodingValidator.h>
#include <geos/noding/MCIndexNoder.h> // for checkInteriorIntersections()
#include <geos/util/TopologyException.h> // for checkValid()
#include <geos/io/WKTWriter.h> // for getErrorMessage()
@@ -33,45 +33,45 @@ namespace noding { // geos.noding
void
FastNodingValidator::checkInteriorIntersections()
- isValidVar = true;
- segInt.reset(new SingleInteriorIntersectionFinder(li));
- MCIndexNoder noder;
- noder.setSegmentIntersector(segInt.get());
- noder.computeNodes(&segStrings);
- if (segInt->hasIntersection()) {
- isValidVar = false;
- return;
+ isValidVar = true;
+ segInt.reset(new NodingIntersectionFinder(li));
+ MCIndexNoder noder;
+ noder.setSegmentIntersector(segInt.get());
+ noder.computeNodes(&segStrings);
+ if (segInt->hasIntersection()) {
+ isValidVar = false;
+ return;
/*public*/
std::string
FastNodingValidator::getErrorMessage() const
- using geos::io::WKTWriter;
- using geos::geom::Coordinate;
+ using geos::io::WKTWriter;
+ using geos::geom::Coordinate;
- if (isValidVar) return std::string("no intersections found");
+ if (isValidVar) return std::string("no intersections found");
- //return std::string("found non-noded intersection etc etc");
+ //return std::string("found non-noded intersection etc etc");
- const std::vector<Coordinate>& intSegs = segInt->getIntersectionSegments();
- assert(intSegs.size() == 4);
- return "found non-noded intersection between "
- + WKTWriter::toLineString(intSegs[0], intSegs[1])
- + " and "
- + WKTWriter::toLineString(intSegs[2], intSegs[3]);
+ const std::vector<Coordinate>& intSegs = segInt->getIntersectionSegments();
+ assert(intSegs.size() == 4);
+ return "found non-noded intersection between "
+ + WKTWriter::toLineString(intSegs[0], intSegs[1])
+ + " and "
+ + WKTWriter::toLineString(intSegs[2], intSegs[3]);
void
FastNodingValidator::checkValid()
- execute();
- if (! isValidVar)
- //std::cerr << "Not valid: " << getErrorMessage() << " interior intersection: " << segInt->getInteriorIntersection() << std::endl;
- throw util::TopologyException(getErrorMessage(), segInt->getInteriorIntersection());
+ execute();
+ if (! isValidVar)
+ //std::cerr << "Not valid: " << getErrorMessage() << " interior intersection: " << segInt->getInteriorIntersection() << std::endl;
+ throw util::TopologyException(getErrorMessage(), segInt->getInteriorIntersection());
diff --git a/src/noding/Makefile.am b/src/noding/Makefile.am
index 010adac..7bddb6b 100644
--- a/src/noding/Makefile.am
+++ b/src/noding/Makefile.am
@@ -28,6 +28,6 @@ libnoding_la_SOURCES = \
SegmentString.cpp \
SegmentStringUtil.cpp \
SimpleNoder.cpp \
- SingleInteriorIntersectionFinder.cpp
+ NodingIntersectionFinder.cpp
libnoding_la_LIBADD = snapround/libsnapround.la
index 0000000..98c10c4
--- /dev/null
@@ -0,0 +1,139 @@
+ * the terms of the GNU Lesser General Licence as published
+ * Last port: noding/NodingIntersectionFinder.java rev. ??? (JTS-1.8)
+#include <geos/noding/SegmentString.h>
+#include <geos/algorithm/LineIntersector.h>
+#include <cstdlib>
+using namespace geos::geom;
+namespace geos {
+/* private */
+bool
+NodingIntersectionFinder::isEndSegment(const SegmentString* segStr, size_t index)
+ if (index == 0) return true;
+ if (index >= segStr->size() - 2) return true;
+ return false;
+/* private */
+bool
+NodingIntersectionFinder::isInteriorVertexIntersection(
+ const Coordinate& p0, const Coordinate& p1,
+ // Intersections between endpoints are valid nodes, so not reported
+ if (isEnd0 && isEnd1) return false;
+ if (p0.equals2D(p1)) return true;
+ return false;
+/* private */
+bool
+ const Coordinate& p00, const Coordinate& p01, const Coordinate& p10, const Coordinate& p11,
+ if (isInteriorVertexIntersection(p00, p10, isEnd00, isEnd10)) return true;
+ if (isInteriorVertexIntersection(p00, p11, isEnd00, isEnd11)) return true;
+ if (isInteriorVertexIntersection(p01, p10, isEnd01, isEnd10)) return true;
+ if (isInteriorVertexIntersection(p01, p11, isEnd01, isEnd11)) return true;
+ return false;
+/* public (override) */
+void
+NodingIntersectionFinder::processIntersections(
+ // short-circuit if intersection already found
+ if (!findAllIntersections && hasIntersection())
+ return;
+ // don't bother intersecting a segment with itself
+ bool isSameSegString = e0 == e1;
+ bool isSameSegment = isSameSegString && segIndex0 == segIndex1;
+ if (isSameSegment) return;
+ * If enabled, only test end segments (on either segString).
+ if (isCheckEndSegmentsOnly)
+ bool isEndSegPresent =
+ isEndSegment(e0, segIndex0) ||
+ isEndSegment(e1, segIndex1);
+ if (! isEndSegPresent)
+ return;
+ const Coordinate& p00 = e0->getCoordinate(segIndex0);
+ const Coordinate& p01 = e0->getCoordinate(segIndex0 + 1);
+ const Coordinate& p10 = e1->getCoordinate(segIndex1);
+ const Coordinate& p11 = e1->getCoordinate(segIndex1 + 1);
+ bool isEnd00 = segIndex0 == 0;
+ bool isEnd01 = segIndex0 + 2 == e0->size();
+ bool isEnd10 = segIndex1 == 0;
+ bool isEnd11 = segIndex1 + 2 == e1->size();
+ li.computeIntersection(p00, p01, p10, p11);
+ * Check for an intersection in the interior of a segment
+ bool isInteriorInt = li.hasIntersection() && li.isInteriorIntersection();
+ * Check for an intersection between two vertices which are not both endpoints.
+ int segDiff = segIndex1 - segIndex0;
+ bool isAdjacentSegment = isSameSegString && std::abs(segDiff) <= 1;
+ bool isInteriorVertexInt = (!isAdjacentSegment) &&
+ isInteriorVertexIntersection(p00, p01, p10, p11, isEnd00, isEnd01, isEnd10, isEnd11);
+ if (isInteriorInt || isInteriorVertexInt)
+ // found an intersection!
+ // Coordinate intSegments[4];
+ // intSegments[0] = p00;
+ // intSegments[1] = p01;
+ // intSegments[2] = p10;
+ // intSegments[3] = p11;
+ interiorIntersection = li.getIntersection(0);
+ // if (keepIntersections) intersections.add(interiorIntersection);
+ intersectionCount++;
diff --git a/src/noding/SingleInteriorIntersectionFinder.cpp b/src/noding/SingleInteriorIntersectionFinder.cpp
index e735ea0..0000000
--- a/src/noding/SingleInteriorIntersectionFinder.cpp
+++ /dev/null
@@ -1,69 +0,0 @@
- * the terms of the GNU Lesser General Licence as published
- * Last port: noding/SingleInteriorIntersectionFinder.java rev. ??? (JTS-1.8)
-#include <geos/noding/SegmentString.h>
-#include <geos/algorithm/LineIntersector.h>
-using namespace geos::geom;
-namespace geos {
-/*public (override) */
-void
-SingleInteriorIntersectionFinder::processIntersections(
- // short-circuit if intersection already found
- if (hasIntersection())
- return;
- // don't bother intersecting a segment with itself
- if (e0 == e1 && segIndex0 == segIndex1) return;
- const Coordinate& p00 = e0->getCoordinate(segIndex0);
- const Coordinate& p01 = e0->getCoordinate(segIndex0 + 1);
- const Coordinate& p10 = e1->getCoordinate(segIndex1);
- const Coordinate& p11 = e1->getCoordinate(segIndex1 + 1);
- li.computeIntersection(p00, p01, p10, p11);
-//if (li.hasIntersection() && li.isProper()) Debug.println(li);
- if (li.hasIntersection())
- if (li.isInteriorIntersection())
- intSegments.resize(4);
- intSegments[0] = p00;
- intSegments[1] = p01;
- intSegments[2] = p10;
- intSegments[3] = p11;
- interiorIntersection = li.getIntersection(0);
Summary of changes:
include/geos/noding/FastNodingValidator.h | 29 +--
include/geos/noding/Makefile.am | 56 +++---
include/geos/noding/NodingIntersectionFinder.h | 220 +++++++++++++++++++++
.../geos/noding/SingleInteriorIntersectionFinder.h | 123 ------------
src/Makefile.vc | 2 +-
src/noding/FastNodingValidator.cpp | 52 ++---
src/noding/Makefile.am | 2 +-
src/noding/NodingIntersectionFinder.cpp | 138 +++++++++++++
src/noding/SingleInteriorIntersectionFinder.cpp | 69 -------
tests/xmltester/CMakeLists.txt | 1 +
tests/xmltester/Makefile.am | 1 +
tests/xmltester/tests/ticket/bug838.xml | 23 +++
12 files changed, 457 insertions(+), 259 deletions(-)
create mode 100644 include/geos/noding/NodingIntersectionFinder.h
delete mode 100644 include/geos/noding/SingleInteriorIntersectionFinder.h
create mode 100644 src/noding/NodingIntersectionFinder.cpp
delete mode 100644 src/noding/SingleInteriorIntersectionFinder.cpp
create mode 100644 tests/xmltester/tests/ticket/bug838.xml
hooks/post-receive
More information about the geos-commits
