[geos-commits] [SCM] GEOS branch master updated. 02ddad983f2a72bba5c25bac69d8c5f0ce01b276
Thu Jan 24 14:43:34 PST 2019
the project "GEOS".
       via  02ddad983f2a72bba5c25bac69d8c5f0ce01b276 (commit)
       via  5dee78d28de214fc46833615d069123b0ca8a393 (commit)
       via  6283586e79e81682d754bc27d8d7d39e48e427c3 (commit)
      from  397f07e0f819120b2c5b4de521c5ccd217224718 (commit)
revisions in full, below.
commit 02ddad983f2a72bba5c25bac69d8c5f0ce01b276
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jan 24 14:42:56 2019 -0800
    MinimumBoundingCircle passes tests
diff --git a/src/algorithm/MinimumBoundingCircle.cpp b/src/algorithm/MinimumBoundingCircle.cpp
index 233b019..f178ae0 100644
--- a/src/algorithm/MinimumBoundingCircle.cpp
+++ b/src/algorithm/MinimumBoundingCircle.cpp
@@ -173,7 +173,7 @@ MinimumBoundingCircle::computeCirclePoints()
         return;
     if (input->getNumPoints() == 1) {
-        extremalPts[0] = *(input->getCoordinate());
+        extremalPts.push_back(*(input->getCoordinate()));
         return;
@@ -305,140 +305,5 @@ MinimumBoundingCircle::pointWithMinAngleWithSegment(std::vector<Coordinate>& pts
-#if 0
-/*public*/
-InteriorPointArea::InteriorPointArea(const Geometry *g)
-	foundInterior=false;
-	maxWidth=0.0;
-	factory=g->getFactory();
-	add(g);
-/*public*/
-InteriorPointArea::~InteriorPointArea()
-/*public*/
-bool
-InteriorPointArea::getInteriorPoint(Coordinate& ret) const
-	if ( ! foundInterior ) return false;
-	ret=interiorPoint;
-	return true;
-/*public*/
-void
-InteriorPointArea::add(const Geometry *geom)
-	const Polygon *poly = dynamic_cast<const Polygon*>(geom);
-	if ( poly ) {
-		addPolygon(geom);
-		return;
-	const GeometryCollection *gc = dynamic_cast<const GeometryCollection*>(geom);
-	if ( gc )
-        for(std::size_t i=0, n=gc->getNumGeometries(); i<n; i++) {
-			add(gc->getGeometryN(i));
-/*private*/
-void
-InteriorPointArea::addPolygon(const Geometry *geometry)
-  if (geometry->isEmpty()) return;
-  Coordinate intPt;
-  double width;
-  unique_ptr<LineString> bisector ( horizontalBisector(geometry) );
-  if ( bisector->getLength() == 0.0 ) {
-    width = 0;
-    intPt = bisector->getCoordinateN(0);
-  else {
-    unique_ptr<Geometry> intersections ( bisector->intersection(geometry) );
-    const Geometry *widestIntersection = widestGeometry(intersections.get());
-    const Envelope *env = widestIntersection->getEnvelopeInternal();
-    width=env->getWidth();
-    env->centre(intPt);
-  if (!foundInterior || width>maxWidth) {
-    interiorPoint = intPt;
-    maxWidth = width;
-    foundInterior=true;
-//@return if geometry is a collection, the widest sub-geometry; otherwise,
-//the geometry itself
-const Geometry*
-InteriorPointArea::widestGeometry(const Geometry *geometry)
-	const GeometryCollection *gc = dynamic_cast<const GeometryCollection*>(geometry);
-	if ( gc ) {
-		return widestGeometry(gc);
-	} else {
-		return geometry;
-const Geometry*
-InteriorPointArea::widestGeometry(const GeometryCollection* gc) {
-	if (gc->isEmpty()) {
-		return gc;
-	const Geometry* p_widestGeometry=gc->getGeometryN(0);
-	// scan remaining geom components to see if any are wider
-	for(std::size_t i=1, n=gc->getNumGeometries(); i<n; i++) // start at 1
-		const Envelope *env1(gc->getGeometryN(i)->getEnvelopeInternal());
-		const Envelope *env2(p_widestGeometry->getEnvelopeInternal());
-		if (env1->getWidth()>env2->getWidth()) {
-				p_widestGeometry=gc->getGeometryN(i);
-	return p_widestGeometry;
-/* private */
-LineString*
-InteriorPointArea::horizontalBisector(const Geometry *geometry)
-	const Envelope *envelope=geometry->getEnvelopeInternal();
-	 * Original algorithm.  Fails when geometry contains a horizontal
-	 * segment at the Y midpoint.
-	// Assert: for areas, minx <> maxx
-	//double avgY=avg(envelope->getMinY(),envelope->getMaxY());
-	double bisectY = SafeBisectorFinder::getBisectorY(*dynamic_cast<const Polygon *>(geometry));
-	vector<Coordinate>*cv=new vector<Coordinate>(2);
-	(*cv)[0].x = envelope->getMinX();
-	(*cv)[0].y = bisectY;
-	(*cv)[1].x = envelope->getMaxX();
-	(*cv)[1].y = bisectY;
-	CoordinateSequence *cl = factory->getCoordinateSequenceFactory()->create(cv);
-	LineString *ret = factory->createLineString(cl);
-	return ret;
-#endif
 } // namespace geos.algorithm
 } // namespace geos
diff --git a/tests/unit/algorithm/MinimumBoundingCircleTest.cpp b/tests/unit/algorithm/MinimumBoundingCircleTest.cpp
index 34bbe96..bcc4185 100644
--- a/tests/unit/algorithm/MinimumBoundingCircleTest.cpp
+++ b/tests/unit/algorithm/MinimumBoundingCircleTest.cpp
@@ -61,16 +61,18 @@ namespace tut
             std::unique_ptr<Geometry> actual(geomFact->createMultiPoint(exPts));
             double actualRadius = mbc.getRadius();
             geos::geom::Coordinate actualCentre = mbc.getCentre();
-            //cout << "Centre = " << actualCentre << " Radius = " << actualRadius;
             geomOut.reset(reader.read(wktOut));
-            bool isEqual = geomOut->equals(geom.get());
+            bool isEqual = actual->equals(geomOut.get());
             // need this hack because apparently equals does not work for MULTIPOINT EMPTY
             if (geomOut->isEmpty() && geom->isEmpty())
                 isEqual = true;
-            // if (!isEqual) {
-            //   System.out.println("Actual = " + actual + ", Expected = " + expected);
+            if (!isEqual) {
+                std::cout << "Centre = " << actualCentre << " Radius = " << actualRadius << " isEqual = " << isEqual << std::endl;
+                std::cout << "Actual:"   << std::endl << actual->toString() << std::endl;
+                std::cout << "Expected:" << std::endl << geomOut->toString() << std::endl;
             ensure(isEqual);
             if (centreOut.isNull()) {
@@ -118,5 +120,79 @@ namespace tut
+    template<>
+    template<>
+    void object::test<2>()
+        Coordinate c(15, 15);
+        doMinimumBoundingCircleTest(
+            "MULTIPOINT ((10 10), (20 20))",
+            c,
+            7.0710678118654755);
+    template<>
+    template<>
+    void object::test<3>()
+        Coordinate c(20, 20);
+            "MULTIPOINT ((10 10), (20 20), (30 30))",
+            "MULTIPOINT ((10 10), (30 30))",
+            c,
+            14.142135623730951);
+    template<>
+    template<>
+    void object::test<4>()
+            "MULTIPOINT ((10 10), (20 20), (10 20))",
+            c,
+    template<>
+    template<>
+    void object::test<5>()
+        Coordinate c(150, 100);
+            "POLYGON ((100 100, 200 100, 150 90, 100 100))",
+            "MULTIPOINT ((100 100), (200 100))",
+            c,
+            50);
+    template<>
+    template<>
+    void object::test<6>()
+            "MULTIPOINT ((10 10), (20 20), (10 20), (15 19))",
+            c,
+    template<>
+    template<>
+    void object::test<7>()
+        Coordinate c(26284.84180271327, 65267.114509082545);
+            "POLYGON ((26426 65078, 26531 65242, 26096 65427, 26075 65136, 26426 65078))",
+            "MULTIPOINT ((26531 65242), (26075 65136), (26096 65427))",
+            c,
+            247.4360455914027);
 } // namespace tut
commit 5dee78d28de214fc46833615d069123b0ca8a393
Date:   Thu Jan 24 14:17:48 2019 -0800
    Draft tests for MinimumBoundingCircle
diff --git a/include/geos/algorithm/MinimumBoundingCircle.h b/include/geos/algorithm/MinimumBoundingCircle.h
index 104c16b..6ba76d2 100644
--- a/include/geos/algorithm/MinimumBoundingCircle.h
+++ b/include/geos/algorithm/MinimumBoundingCircle.h
@@ -68,7 +68,7 @@ public:
         centre.setNull();
-	~MinimumBoundingCircle();
+	~MinimumBoundingCircle() {};
     * Gets a geometry which represents the Minimum Bounding Circle.
index 9c6316b..233b019 100644
@@ -156,7 +156,7 @@ MinimumBoundingCircle::computeCentre()
 void
 MinimumBoundingCircle::compute()
-    if (extremalPts.size() > 0) return;
+    if (!extremalPts.empty()) return;
     computeCirclePoints();
     computeCentre();
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 46dada0..186dd34 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -51,6 +51,7 @@ geos_unit_SOURCES = \
 	algorithm/InteriorPointAreaTest.cpp \
 	algorithm/LengthTest.cpp \
 	algorithm/LocatePointInRingTest.cpp \
+	algorithm/MinimumBoundingCircleTest.cpp \
 	algorithm/MinimumDiameterTest.cpp \
 	algorithm/OrientationIndexFailureTest.cpp \
 	algorithm/PointLocatorTest.cpp \
new file mode 100644
index 0000000..34bbe96
--- /dev/null
@@ -0,0 +1,122 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2011      Sandro Santilli <strk at kbt.io>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+// Test Suite for geos::algorithm::MinimumBoundingCircle
+#include <tut/tut.hpp>
+// geos
+#include <geos/algorithm/MinimumBoundingCircle.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/io/WKTReader.h>
+// std
+#include <sstream>
+#include <string>
+#include <memory>
+namespace tut
+    // Test Group
+    // dummy data, not used
+    struct test_minimumboundingcircle_data {
+        typedef geos::geom::Geometry Geometry;
+        typedef geos::geom::Coordinate Coordinate;
+        typedef geos::geom::PrecisionModel PrecisionModel;
+        typedef geos::geom::GeometryFactory GeometryFactory;
+        typedef geos::algorithm::MinimumBoundingCircle MinimumBoundingCircle;
+        geos::io::WKTReader reader;
+        std::unique_ptr<Geometry> geom;
+        std::unique_ptr<Geometry> geomOut;
+        GeometryFactory::Ptr geomFact = GeometryFactory::create();
+        test_minimumboundingcircle_data()
+        void doMinimumBoundingCircleTest(std::string wktIn, std::string wktOut,
+            geos::geom::Coordinate &centreOut, double radiusOut)
+            geom.reset(reader.read(wktIn));
+            MinimumBoundingCircle mbc(geom.get());
+            std::vector<Coordinate> exPts = mbc.getExtremalPoints();
+            std::unique_ptr<Geometry> actual(geomFact->createMultiPoint(exPts));
+            double actualRadius = mbc.getRadius();
+            geos::geom::Coordinate actualCentre = mbc.getCentre();
+            //cout << "Centre = " << actualCentre << " Radius = " << actualRadius;
+            geomOut.reset(reader.read(wktOut));
+            bool isEqual = geomOut->equals(geom.get());
+            // need this hack because apparently equals does not work for MULTIPOINT EMPTY
+            if (geomOut->isEmpty() && geom->isEmpty())
+                isEqual = true;
+            // if (!isEqual) {
+            //   System.out.println("Actual = " + actual + ", Expected = " + expected);
+            ensure(isEqual);
+            if (centreOut.isNull()) {
+                ensure(centreOut.distance(actualCentre) < 0.0001);
+            if (radiusOut >= 0) {
+                ensure(fabs(radiusOut - actualRadius) < 0.0001);
+        void doMinimumBoundingCircleTest(std::string wktIn, std::string wktOut)
+            geos::geom::Coordinate c;
+            c.setNull();
+            doMinimumBoundingCircleTest(wktIn, wktOut, c, -1.0);
+    typedef test_group<test_minimumboundingcircle_data> group;
+    typedef group::object object;
+    group test_minimumboundingcircle_group("geos::algorithm::MinimumBoundingCircle");
+    // Test Cases
+    template<>
+    template<>
+    void object::test<1>()
+        Coordinate c(10, 10);
+            "POINT (10 10)",
+            "POINT (10 10)",
+            c,
+            0);
+} // namespace tut
commit 6283586e79e81682d754bc27d8d7d39e48e427c3
Date:   Thu Jan 24 11:56:34 2019 -0800
    First draft of MinimumBoundingCircle port
index 0000000..104c16b
--- /dev/null
@@ -0,0 +1,139 @@
+ * Copyright (C) 2019 Paul Ramsey <pramsey at cleverelephant.ca>
+ * Last port: algorithm/MinimumBoundingCircle.java 2019-01-23
+#ifndef GEOS_ALGORITHM_MINIMUMBOUNDINGCIRCLE_H
+#define GEOS_ALGORITHM_MINIMUMBOUNDINGCIRCLE_H
+#include <geos/export.h>
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/Point.h>
+#include <geos/geom/Triangle.h>
+#include <vector>
+// Forward declarations
+// namespace geos {
+// 	namespace geom {
+// 		class GeometryCollection;
+namespace geos {
+namespace algorithm { // geos::algorithm
+class GEOS_DLL MinimumBoundingCircle {
+private:
+    // member variables
+    const geom::Geometry *input;
+    std::vector<geom::Coordinate> extremalPts;
+    geom::Coordinate centre;
+    double radius;
+    void computeCentre();
+    void compute();
+    void computeCirclePoints();
+    geom::Coordinate lowestPoint(std::vector<geom::Coordinate>& pts);
+    geom::Coordinate pointWitMinAngleWithX(std::vector<geom::Coordinate>& pts, geom::Coordinate& P);
+    geom::Coordinate pointWithMinAngleWithSegment(std::vector<geom::Coordinate>& pts,
+        geom::Coordinate& P, geom::Coordinate& Q);
+public:
+    MinimumBoundingCircle(const geom::Geometry *geom):
+        input(nullptr),
+        radius(0.0)
+        input = geom;
+        centre.setNull();
+	~MinimumBoundingCircle();
+    * Gets a geometry which represents the Minimum Bounding Circle.
+    * If the input is degenerate (empty or a single unique point),
+    * this method will return an empty geometry or a single Point geometry.
+    * Otherwise, a Polygon will be returned which approximates the
+    * Minimum Bounding Circle.
+    * (Note that because the computed polygon is only an approximation,
+    * it may not precisely contain all the input points.)
+    * @return a Geometry representing the Minimum Bounding Circle.
+    geom::Geometry* getCircle();
+    * Gets a geometry representing a line between the two farthest points
+    * in the input.
+    * These points will be two of the extremal points of the Minimum Bounding Circle.
+    * They also lie on the convex hull of the input.
+    * @return a LineString between the two farthest points of the input
+    * @return a empty LineString if the input is empty
+    * @return a Point if the input is a point
+    geom::Geometry* getFarthestPoints();
+    * Gets a geometry representing the diameter of the computed Minimum Bounding
+    * Circle.
+    * @return the diameter LineString of the Minimum Bounding Circle
+    geom::Geometry* getDiameter();
+    * Gets the extremal points which define the computed Minimum Bounding Circle.
+    * There may be zero, one, two or three of these points,
+    * depending on the number of points in the input
+    * and the geometry of those points.
+    * @return the points defining the Minimum Bounding Circle
+    std::vector<geom::Coordinate> getExtremalPoints();
+    * Gets the centre point of the computed Minimum Bounding Circle.
+    * @return the centre point of the Minimum Bounding Circle
+    * @return null if the input is empty
+    geom::Coordinate getCentre();
+    * Gets the radius of the computed Minimum Bounding Circle.
+    * @return the radius of the Minimum Bounding Circle
+    double getRadius();
+} // namespace geos::algorithm
+#endif // GEOS_ALGORITHM_MINIMUMBOUNDINGCIRCLE_H
diff --git a/include/geos/geom/Triangle.h b/include/geos/geom/Triangle.h
index e80bb95..1a78ec8 100644
--- a/include/geos/geom/Triangle.h
+++ b/include/geos/geom/Triangle.h
@@ -66,6 +66,8 @@ public:
 	void circumcentre(Coordinate& resultPoint);
+    static const Coordinate circumcentre(const Coordinate& p0, const Coordinate& p1, const Coordinate& p2);
 private:
diff --git a/src/algorithm/Makefile.am b/src/algorithm/Makefile.am
index f48c0bf..2579281 100644
--- a/src/algorithm/Makefile.am
+++ b/src/algorithm/Makefile.am
@@ -23,6 +23,7 @@ libalgorithm_la_SOURCES = \
 	InteriorPointPoint.cpp \
 	LineIntersector.cpp \
 	Length.cpp \
+	MinimumBoundingCircle.cpp \
 	MinimumDiameter.cpp \
 	NotRepresentableException.cpp \
 	Orientation.cpp \
index 0000000..9c6316b
--- /dev/null
@@ -0,0 +1,444 @@
+ * Copyright (C) 2013 Sandro Santilli <strk at kbt.io>
+ * Copyright (C) 2005-2006 Refractions Research Inc.
+ * Copyright (C) 2001-2002 Vivid Solutions Inc.
+ * Last port: algorithm/MinimumBoundingCircle.java 2019-01-24
+#include <geos/algorithm/Angle.h>
+#include <geos/geom/CoordinateSequenceFactory.h>
+#include <geos/geom/Envelope.h>
+#include <geos/geom/GeometryCollection.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/Polygon.h>
+#include <geos/util/GEOSException.h>
+#include <math.h> // sqrt
+#include <memory> // for unique_ptr
+#include <typeinfo>
+#include <vector>
+using namespace geos::geom;
+namespace geos {
+namespace algorithm { // geos.algorithm
+/*public*/
+Geometry*
+MinimumBoundingCircle::getCircle()
+    //TODO: ensure the output circle contains the extermal points.
+    //TODO: or maybe even ensure that the returned geometry contains ALL the input points?
+    compute();
+    if (centre.isNull())
+        return input->getFactory()->createPolygon();
+    Point *centrePoint = input->getFactory()->createPoint(centre);
+    if (radius == 0.0)
+        return centrePoint;
+    return centrePoint->buffer(radius);
+/*public*/
+Geometry*
+MinimumBoundingCircle::getFarthestPoints()
+    compute();
+    switch (extremalPts.size()) {
+        case 0:
+            return input->getFactory()->createLineString();
+        case 1:
+            return input->getFactory()->createPoint(centre);
+    size_t dims = input->getDimension();
+    size_t len = 2;
+    CoordinateSequence *cs = input->getFactory()->getCoordinateSequenceFactory()->create(len, dims);
+    cs->add(extremalPts[0], true);
+    cs->add(extremalPts[extremalPts.size() - 1], true);
+    return input->getFactory()->createLineString(cs);
+/*public*/
+Geometry*
+MinimumBoundingCircle::getDiameter()
+    compute();
+        case 0:
+        case 1:
+    size_t len = 2;
+    // TODO: handle case of 3 extremal points, by computing a line from one of
+    // them through the centre point with len = 2*radius
+    cs->add(extremalPts[1], true);
+/*public*/
+std::vector<Coordinate>
+MinimumBoundingCircle::getExtremalPoints()
+    compute();
+    return extremalPts;
+/*public*/
+Coordinate
+MinimumBoundingCircle::getCentre()
+    compute();
+    return centre;
+/*public*/
+double
+MinimumBoundingCircle::getRadius()
+    compute();
+    return radius;
+/*private*/
+void
+MinimumBoundingCircle::computeCentre()
+        case 0: {
+            centre.setNull();
+            break;
+        case 1: {
+            centre = extremalPts[0];
+            break;
+        case 2: {
+            double xAvg = (extremalPts[0].x + extremalPts[1].x) / 2.0;
+            double yAvg = (extremalPts[0].y + extremalPts[1].y) / 2.0;
+            Coordinate c(xAvg, yAvg);
+            centre = c;
+            break;
+        case 3: {
+            centre = Triangle::circumcentre(extremalPts[0], extremalPts[1], extremalPts[2]);
+            break;
+        default: {
+            util::GEOSException("Logic failure in MinimumBoundingCircle algorithm!");\
+/*private*/
+void
+MinimumBoundingCircle::compute()
+    if (extremalPts.size() > 0) return;
+    computeCirclePoints();
+    computeCentre();
+    if (!centre.isNull())
+        radius = centre.distance(extremalPts[0]);
+/*private*/
+void
+MinimumBoundingCircle::computeCirclePoints()
+    // handle degenerate or trivial cases
+    if (input->isEmpty()) {
+        return;
+    if (input->getNumPoints() == 1) {
+        extremalPts[0] = *(input->getCoordinate());
+        return;
+    * The problem is simplified by reducing to the convex hull.
+    * Computing the convex hull also has the useful effect of eliminating duplicate points
+    Geometry *convexHull = input->convexHull();
+    CoordinateSequence *cs = convexHull->getCoordinates();
+    std::vector<Coordinate> pts;
+    cs->toVector(pts);
+    // strip duplicate final point, if any
+    if (pts.front().equals2D(pts.back())) {
+        pts.pop_back();
+    * Optimization for the trivial case where the CH has fewer than 3 points
+    if (pts.size() <= 2) {
+        extremalPts = pts;
+        return;
+    // find a point P with minimum Y ordinate
+    Coordinate P = lowestPoint(pts);
+    // find a point Q such that the angle that PQ makes with the x-axis is minimal
+    Coordinate Q = pointWitMinAngleWithX(pts, P);
+    * Iterate over the remaining points to find
+    * a pair or triplet of points which determine the minimal circle.
+    * By the design of the algorithm,
+    * at most <tt>pts.length</tt> iterations are required to terminate
+    * with a correct result.
+    for (auto p: pts) {
+        Coordinate R = pointWithMinAngleWithSegment(pts, P, Q);
+        // if PRQ is obtuse, then MBC is determined by P and Q
+        if (algorithm::Angle::isObtuse(P, R, Q)) {
+            extremalPts.push_back(P);
+            extremalPts.push_back(Q);
+            return;
+        // if RPQ is obtuse, update baseline and iterate
+        if (algorithm::Angle::isObtuse(R, P, Q)) {
+            P = R;
+            continue;
+        // if RQP is obtuse, update baseline and iterate
+        if (algorithm::Angle::isObtuse(R, Q, P)) {
+            Q = R;
+            continue;
+        // otherwise all angles are acute, and the MBC is determined by the triangle PQR
+        extremalPts.push_back(R);
+        return;
+    // never get here
+/*private*/
+Coordinate
+MinimumBoundingCircle::lowestPoint(std::vector<Coordinate>& pts)
+    Coordinate min = pts[0];
+    for (auto pt: pts) {
+        if (pt.y < min.y)
+            min = pt;
+    return min;
+/*private*/
+Coordinate
+MinimumBoundingCircle::pointWitMinAngleWithX(std::vector<Coordinate>& pts, Coordinate& P)
+    double minSin = std::numeric_limits<double>::max();
+    Coordinate minAngPt;
+    minAngPt.setNull();
+        if (p == P) continue;
+        * The sin of the angle is a simpler proxy for the angle itself
+        double dx = p.x - P.x;
+        double dy = p.y - P.y;
+        if (dy < 0) dy = -dy;
+        double len = sqrt(dx * dx + dy * dy);
+        double sin = dy / len;
+        if (sin < minSin) {
+            minSin = sin;
+            minAngPt = p;
+    return minAngPt;
+/*private*/
+Coordinate
+MinimumBoundingCircle::pointWithMinAngleWithSegment(std::vector<Coordinate>& pts, Coordinate& P, Coordinate& Q)
+    double minAng = std::numeric_limits<double>::max();
+        if (p == Q) continue;
+        double ang = Angle::angleBetween(P, p, Q);
+        if (ang < minAng) {
+            minAng = ang;
+            minAngPt = p;
+    return minAngPt;
+#if 0
+/*public*/
+InteriorPointArea::InteriorPointArea(const Geometry *g)
+	foundInterior=false;
+	maxWidth=0.0;
+	factory=g->getFactory();
+	add(g);
+/*public*/
+InteriorPointArea::~InteriorPointArea()
+/*public*/
+bool
+InteriorPointArea::getInteriorPoint(Coordinate& ret) const
+	if ( ! foundInterior ) return false;
+	ret=interiorPoint;
+	return true;
+/*public*/
+void
+InteriorPointArea::add(const Geometry *geom)
+	const Polygon *poly = dynamic_cast<const Polygon*>(geom);
+	if ( poly ) {
+		addPolygon(geom);
+		return;
+	const GeometryCollection *gc = dynamic_cast<const GeometryCollection*>(geom);
+	if ( gc )
+        for(std::size_t i=0, n=gc->getNumGeometries(); i<n; i++) {
+			add(gc->getGeometryN(i));
+/*private*/
+void
+InteriorPointArea::addPolygon(const Geometry *geometry)
+  if (geometry->isEmpty()) return;
+  Coordinate intPt;
+  double width;
+  unique_ptr<LineString> bisector ( horizontalBisector(geometry) );
+  if ( bisector->getLength() == 0.0 ) {
+    width = 0;
+    intPt = bisector->getCoordinateN(0);
+  else {
+    unique_ptr<Geometry> intersections ( bisector->intersection(geometry) );
+    const Geometry *widestIntersection = widestGeometry(intersections.get());
+    const Envelope *env = widestIntersection->getEnvelopeInternal();
+    width=env->getWidth();
+    env->centre(intPt);
+  if (!foundInterior || width>maxWidth) {
+    interiorPoint = intPt;
+    maxWidth = width;
+    foundInterior=true;
+//@return if geometry is a collection, the widest sub-geometry; otherwise,
+//the geometry itself
+const Geometry*
+InteriorPointArea::widestGeometry(const Geometry *geometry)
+	const GeometryCollection *gc = dynamic_cast<const GeometryCollection*>(geometry);
+	if ( gc ) {
+		return widestGeometry(gc);
+	} else {
+		return geometry;
+const Geometry*
+InteriorPointArea::widestGeometry(const GeometryCollection* gc) {
+	if (gc->isEmpty()) {
+		return gc;
+	const Geometry* p_widestGeometry=gc->getGeometryN(0);
+	// scan remaining geom components to see if any are wider
+	for(std::size_t i=1, n=gc->getNumGeometries(); i<n; i++) // start at 1
+		const Envelope *env1(gc->getGeometryN(i)->getEnvelopeInternal());
+		const Envelope *env2(p_widestGeometry->getEnvelopeInternal());
+		if (env1->getWidth()>env2->getWidth()) {
+				p_widestGeometry=gc->getGeometryN(i);
+	return p_widestGeometry;
+/* private */
+LineString*
+InteriorPointArea::horizontalBisector(const Geometry *geometry)
+	const Envelope *envelope=geometry->getEnvelopeInternal();
+	 * Original algorithm.  Fails when geometry contains a horizontal
+	 * segment at the Y midpoint.
+	// Assert: for areas, minx <> maxx
+	//double avgY=avg(envelope->getMinY(),envelope->getMaxY());
+	double bisectY = SafeBisectorFinder::getBisectorY(*dynamic_cast<const Polygon *>(geometry));
+	vector<Coordinate>*cv=new vector<Coordinate>(2);
+	(*cv)[0].x = envelope->getMinX();
+	(*cv)[0].y = bisectY;
+	(*cv)[1].x = envelope->getMaxX();
+	(*cv)[1].y = bisectY;
+	CoordinateSequence *cl = factory->getCoordinateSequenceFactory()->create(cv);
+	LineString *ret = factory->createLineString(cl);
+	return ret;
+#endif
+} // namespace geos.algorithm
diff --git a/src/geom/Triangle.cpp b/src/geom/Triangle.cpp
index fda964c..4a9685c 100644
--- a/src/geom/Triangle.cpp
+++ b/src/geom/Triangle.cpp
@@ -52,6 +52,17 @@ void Triangle::circumcentre(Coordinate& result)
 	result = Coordinate(ccx,ccy);
+/* public static */
+const Coordinate
+Triangle::circumcentre(const Coordinate& p0, const Coordinate& p1, const Coordinate& p2)
+    Triangle t(p0, p1, p2);
+    Coordinate c;
+    t.circumcentre(c);
+    return c;
 double Triangle::det(double m00 , double m01 , double m10 , double m11) const
 	return m00 * m11 - m01 * m10;
Summary of changes:
 include/geos/algorithm/MinimumBoundingCircle.h     | 139 +++++++++
 include/geos/geom/Triangle.h                       |   2 +
 src/algorithm/Makefile.am                          |   1 +
 src/algorithm/MinimumBoundingCircle.cpp            | 309 +++++++++++++++++++++
 src/geom/Triangle.cpp                              |  11 +
 tests/unit/Makefile.am                             |   1 +
 tests/unit/algorithm/MinimumBoundingCircleTest.cpp | 198 +++++++++++++
 7 files changed, 661 insertions(+)
 create mode 100644 include/geos/algorithm/MinimumBoundingCircle.h
 create mode 100644 src/algorithm/MinimumBoundingCircle.cpp
 create mode 100644 tests/unit/algorithm/MinimumBoundingCircleTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
