[geos-commits] [SCM] GEOS branch svn-3.6 updated.	33abb846d7e4a687a70c1ddc4d601060a71f0e8a
    git at osgeo.org
    git at osgeo.org
    Mon Jan 28 14:28:41 PST 2019
the project "GEOS".
The branch, svn-3.6 has been updated
       via  33abb846d7e4a687a70c1ddc4d601060a71f0e8a (commit)
      from  287b45da2cbaaa70fc27c333b496e02bd161b1d4 (commit)
revisions in full, below.
commit 33abb846d7e4a687a70c1ddc4d601060a71f0e8a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Jan 28 14:28:29 2019 -0800
    Static library does not contain C API
    Closes #878
diff --git a/NEWS b/NEWS
index cba7eb7..07b0462 100644
--- a/NEWS
+++ b/NEWS
@@ -9,6 +9,7 @@ Changes in 3.6.4
   - Envelope constructor use strtod (#875)
   - Polygon build failure in Overlay difference (#789 Paul Ramsey)
   - Invalid union result from valid polygon inputs (#838)
+  - Static library does not contain C API (#878)
 Changes in 3.6.3
diff --git a/capi/CMakeLists.txt b/capi/CMakeLists.txt
index 859722b..0607b16 100644
--- a/capi/CMakeLists.txt
+++ b/capi/CMakeLists.txt
@@ -6,7 +6,7 @@
 # This is free software; you can redistribute and/or modify it under
 # the terms of the GNU Lesser General Public Licence as published
-# by the Free Software Foundation.
+# by the Free Software Foundation.
 # See the COPYING file for more information.
@@ -21,9 +21,9 @@ set(geos_c_SOURCES
 file(GLOB geos_capi_HEADERS ${CMAKE_BINARY_DIR}/capi/*.h) # fix source_group issue
-if(NOT GEOS_ENABLE_MACOSX_FRAMEWORK)
-  # if building OS X framework, CAPI built into C++ library
-  add_library(geos_c SHARED ${geos_c_SOURCES})
+if(NOT GEOS_ENABLE_MACOSX_FRAMEWORK AND GEOS_BUILD_SHARED)
+  # if building OS X framework or only building static libs, CAPI built into C++ library)
+  add_library(geos_c SHARED ${geos_c_SOURCES})
   target_link_libraries(geos_c geos)
@@ -55,7 +55,7 @@ else()
     DESTINATION include)
 endif()
+if(NOT GEOS_ENABLE_MACOSX_FRAMEWORK)
   install(TARGETS geos_c
     RUNTIME DESTINATION bin
     LIBRARY DESTINATION lib
diff --git a/src/CMakeLists.txt b/src/CMakeLists.txt
index 4a1e688..3894a56 100644
--- a/src/CMakeLists.txt
+++ b/src/CMakeLists.txt
@@ -6,7 +6,7 @@
@@ -14,25 +14,26 @@
 file(GLOB_RECURSE geos_SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/*.cpp)
 file(GLOB_RECURSE geos_ALL_HEADERS ${CMAKE_SOURCE_DIR}/include/*.h) # fix source_group issue
+# Include CAPI in OS X framework binary and in static libs
+set(geos_c_SOURCES
+  ${CMAKE_CURRENT_SOURCE_DIR}/../capi/geos_c.cpp
+  ${CMAKE_CURRENT_SOURCE_DIR}/../capi/geos_ts_c.cpp)
 if(GEOS_ENABLE_MACOSX_FRAMEWORK)
   # OS X frameworks don't have static libs
   # also 1 binary, so include CAPI here
   # and, make name all caps
-  set(geos_c_SOURCES
-    ${CMAKE_CURRENT_SOURCE_DIR}/../capi/geos_c.cpp
-    ${CMAKE_CURRENT_SOURCE_DIR}/../capi/geos_ts_c.cpp)
   add_library(GEOS SHARED ${geos_SOURCES} ${geos_c_SOURCES})
-  math(EXPR CVERSION "${VERSION_MAJOR} + 1")
- 	# VERSION = current version, SOVERSION = compatibility version
+  math(EXPR CVERSION "${VERSION_MAJOR} + 1")
+ 	# VERSION = current version, SOVERSION = compatibility version
   set_target_properties(GEOS
     PROPERTIES
     CLEAN_DIRECT_OUTPUT 1
     FRAMEWORK 1
-    VERSION "${CVERSION}.${VERSION_MINOR}.${VERSION_PATCH}"
- 	  SOVERSION ${CVERSION}
+    VERSION "${CVERSION}.${VERSION_MINOR}.${VERSION_PATCH}"
+ 	  SOVERSION ${CVERSION}
     FRAMEWORK_VERSION ${VERSION_MAJOR}
     BUILD_WITH_INSTALL_RPATH TRUE
     INSTALL_NAME_DIR "${CMAKE_INSTALL_PREFIX}"
@@ -77,7 +78,8 @@ else()
   endif()
   if(GEOS_BUILD_STATIC)
-    add_library(geos-static STATIC ${geos_SOURCES} ${geos_ALL_HEADERS})
+    file(GLOB geos_capi_HEADERS ${CMAKE_CURRENT_SOURCE_DIR}/../capi/*.h) # fix source_group issue
+    add_library(geos-static STATIC ${geos_SOURCES} ${geos_c_SOURCES} ${geos_ALL_HEADERS} ${geos_capi_HEADERS})
     set_target_properties(geos-static
       PROPERTIES
Summary of changes:
 NEWS                |  1 +
 capi/CMakeLists.txt | 10 +++++-----
 src/CMakeLists.txt  | 22 ++++++++++++----------
 3 files changed, 18 insertions(+), 15 deletions(-)
hooks/post-receive
More information about the geos-commits
