[geos-commits] [SCM] GEOS branch master updated. e88a488c86273f95a825a3d23cb83651f73d0c9a
git at osgeo.org
git at osgeo.org
Thu Jun 20 11:07:44 PDT 2019
the project "GEOS".
via e88a488c86273f95a825a3d23cb83651f73d0c9a (commit)
via 52c722871a56d104d9d639584bf4508ae0736b04 (commit)
from d924cc7121cca892b1ee550b7cc6e91c6caf34bb (commit)
revisions in full, below.
commit e88a488c86273f95a825a3d23cb83651f73d0c9a
Merge: d924cc7 52c7228
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Jun 20 14:07:33 2019 -0400
Merge branch 'geometry-component-uniqueptr'
commit 52c722871a56d104d9d639584bf4508ae0736b04
Date: Mon Jun 17 22:08:35 2019 -0400
Remove manual memory management from GeometryCollection, Polygon
Have these classes manage their components using a std::vector of
std::unique_ptr. Avoid heap-allocating the std::vectors themselves.
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index 3bed163..d2754be 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -893,6 +893,8 @@ protected:
int compare(std::vector<Geometry*> a, std::vector<Geometry*> b) const;
+ int compare(const std::vector<std::unique_ptr<Geometry>> & a, const std::vector<std::unique_ptr<Geometry>> & b) const;
bool equal(const Coordinate& a, const Coordinate& b,
double tolerance) const;
int SRID;
diff --git a/include/geos/geom/GeometryCollection.h b/include/geos/geom/GeometryCollection.h
index 001d88d..b1af27c 100644
--- a/include/geos/geom/GeometryCollection.h
+++ b/include/geos/geom/GeometryCollection.h
@@ -57,9 +57,9 @@ class GEOS_DLL GeometryCollection : public virtual Geometry {
public:
friend class GeometryFactory;
- typedef std::vector<Geometry*>::const_iterator const_iterator;
+ typedef std::vector<std::unique_ptr<Geometry>>::const_iterator const_iterator;
- typedef std::vector<Geometry*>::iterator iterator;
+ typedef std::vector<std::unique_ptr<Geometry>>::iterator iterator;
const_iterator begin() const;
@@ -107,7 +107,7 @@ public:
Dimension::DimensionType getDimension() const override;
- virtual bool isDimensionStrict(Dimension::DimensionType d) const;
+ bool isDimensionStrict(Dimension::DimensionType d) const override;
/// Returns coordinate dimension.
int getCoordinateDimension() const override;
@@ -207,7 +207,7 @@ protected:
return SORTINDEX_GEOMETRYCOLLECTION;
- std::vector<Geometry*>* geometries;
+ std::vector<std::unique_ptr<Geometry>> geometries;
Envelope::Ptr computeEnvelopeInternal() const override;
diff --git a/include/geos/geom/GeometryCollection.inl b/include/geos/geom/GeometryCollection.inl
index b6df063..ecabd82 100644
--- a/include/geos/geom/GeometryCollection.inl
+++ b/include/geos/geom/GeometryCollection.inl
@@ -29,13 +29,13 @@ namespace geom { // geos::geom
INLINE GeometryCollection::const_iterator
GeometryCollection::begin() const
- return geometries->begin();
+ return geometries.begin();
GeometryCollection::end() const
- return geometries->end();
+ return geometries.end();
diff --git a/include/geos/geom/Polygon.h b/include/geos/geom/Polygon.h
index 45cbd4e..b4289cd 100644
--- a/include/geos/geom/Polygon.h
+++ b/include/geos/geom/Polygon.h
@@ -171,9 +171,9 @@ protected:
Polygon(LinearRing* newShell, std::vector<LinearRing*>* newHoles,
const GeometryFactory* newFactory);
- LinearRing* shell;
+ std::unique_ptr<LinearRing> shell;
- std::vector<LinearRing*>* holes;
+ std::vector<std::unique_ptr<LinearRing>> holes;
diff --git a/src/algorithm/PointLocator.cpp b/src/algorithm/PointLocator.cpp
index 5854f89..889e000 100644
--- a/src/algorithm/PointLocator.cpp
+++ b/src/algorithm/PointLocator.cpp
@@ -94,13 +94,9 @@ PointLocator::computeLocation(const Coordinate& p, const Geometry* geom)
else if(const GeometryCollection* col = dynamic_cast<const GeometryCollection*>(geom)) {
- for(GeometryCollection::const_iterator
- it = col->begin(), endIt = col->end();
- it != endIt;
- ++it) {
- const Geometry* g2 = *it;
- assert(g2 != geom); // is this check really needed ?
- computeLocation(p, g2);
+ for(const auto & g2 : *col) {
+ assert(g2.get() != geom); // is this check really needed ?
+ computeLocation(p, g2.get());
diff --git a/src/algorithm/locate/SimplePointInAreaLocator.cpp b/src/algorithm/locate/SimplePointInAreaLocator.cpp
index 8affb66..8457873 100644
--- a/src/algorithm/locate/SimplePointInAreaLocator.cpp
+++ b/src/algorithm/locate/SimplePointInAreaLocator.cpp
@@ -70,9 +70,9 @@ SimplePointInAreaLocator::locateInGeometry(const Coordinate& p, const Geometry*
return Location::EXTERIOR;
- for(auto g2 : *col) {
- Location loc = locateInGeometry(p, g2);
+ for(auto& g2 : *col) {
+ Location loc = locateInGeometry(p, g2.get());
if(loc != Location::EXTERIOR) {
return loc;
diff --git a/src/geom/Geometry.cpp b/src/geom/Geometry.cpp
index a050d0e..823a11f 100644
--- a/src/geom/Geometry.cpp
+++ b/src/geom/Geometry.cpp
@@ -778,6 +778,31 @@ Geometry::compare(vector<Geometry*> a, vector<Geometry*> b) const
return 0;
+int
+Geometry::compare(const std::vector<std::unique_ptr<Geometry>> & a,
+ const std::vector<std::unique_ptr<Geometry>> & b) const
+ size_t i = 0;
+ size_t j = 0;
+ while(i < a.size() && j < b.size()) {
+ Geometry* aGeom = a[i].get();
+ Geometry* bGeom = b[j].get();
+ int comparison = aGeom->compareTo(bGeom);
+ if(comparison != 0) {
+ return comparison;
+ i++;
+ j++;
+ if(i < a.size()) {
+ return 1;
+ if(j < b.size()) {
+ return -1;
+ return 0;
* Returns the minimum distance between this Geometry
* and the other Geometry
diff --git a/src/geom/GeometryCollection.cpp b/src/geom/GeometryCollection.cpp
index 40b0c98..a1fcf6b 100644
--- a/src/geom/GeometryCollection.cpp
+++ b/src/geom/GeometryCollection.cpp
@@ -27,6 +27,7 @@
#include <geos/geom/GeometryFilter.h>
#include <geos/geom/GeometryComponentFilter.h>
#include <geos/geom/Envelope.h>
+#include <geos/util.h>
#ifndef GEOS_INLINE
# include <geos/geom/GeometryCollection.inl>
@@ -36,51 +37,45 @@
#include <vector>
#include <memory>
-using namespace std;
namespace geos {
/*protected*/
GeometryCollection::GeometryCollection(const GeometryCollection& gc)
- Geometry(gc)
+ Geometry(gc),
+ geometries(gc.geometries.size())
- size_t ngeoms = gc.geometries->size();
- geometries = new vector<Geometry*>(ngeoms);
- for(size_t i = 0; i < ngeoms; ++i) {
- (*geometries)[i] = (*gc.geometries)[i]->clone().release();
+ for(size_t i = 0; i < geometries.size(); ++i) {
+ geometries[i] = gc.geometries[i]->clone();
/*protected*/
-GeometryCollection::GeometryCollection(vector<Geometry*>* newGeoms, const GeometryFactory* factory):
+GeometryCollection::GeometryCollection(std::vector<Geometry*>* newGeoms, const GeometryFactory* factory):
Geometry(factory)
if(newGeoms == nullptr) {
- geometries = new vector<Geometry*>();
return;
if(hasNullElements(newGeoms)) {
throw util::IllegalArgumentException("geometries must not contain null elements\n");
- return;
- geometries = newGeoms;
+ for (const auto& geom : *newGeoms) {
+ geometries.emplace_back(geom);
+ delete newGeoms;
// Set SRID for inner geoms
- size_t ngeoms = geometries->size();
- (*geometries)[i]->setSRID(getSRID());
+ setSRID(getSRID());
void
GeometryCollection::setSRID(int newSRID)
Geometry::setSRID(newSRID);
- for(size_t i = 0; i < geometries->size(); i++) {
- (*geometries)[i]->setSRID(newSRID);
+ for(auto& g : geometries) {
+ g->setSRID(newSRID);
@@ -93,25 +88,25 @@ GeometryCollection::setSRID(int newSRID)
std::unique_ptr<CoordinateSequence>
GeometryCollection::getCoordinates() const
- vector<Coordinate>* coordinates = new vector<Coordinate>(getNumPoints());
+ auto coordinates = detail::make_unique<std::vector<Coordinate>>(getNumPoints());
- int k = -1;
- for(size_t i = 0; i < geometries->size(); ++i) {
- auto childCoordinates = (*geometries)[i]->getCoordinates();
+ size_t k = 0;
+ for(const auto& g : geometries) {
+ auto childCoordinates = g->getCoordinates(); // TODO avoid this copy
size_t npts = childCoordinates->getSize();
for(size_t j = 0; j < npts; ++j) {
- k++;
(*coordinates)[k] = childCoordinates->getAt(j);
+ k++;
- return CoordinateArraySequenceFactory::instance()->create(coordinates);
+ return CoordinateArraySequenceFactory::instance()->create(coordinates.release());
bool
GeometryCollection::isEmpty() const
- if(!(*geometries)[i]->isEmpty()) {
+ if(!g->isEmpty()) {
return false;
@@ -122,16 +117,16 @@ Dimension::DimensionType
GeometryCollection::getDimension() const
Dimension::DimensionType dimension = Dimension::False;
- for(size_t i = 0, n = geometries->size(); i < n; ++i) {
- dimension = max(dimension, (*geometries)[i]->getDimension());
+ dimension = std::max(dimension, g->getDimension());
return dimension;
bool
GeometryCollection::isDimensionStrict(Dimension::DimensionType d) const {
- return std::all_of(geometries->begin(), geometries->end(),
- [&d](const Geometry* g) {
+ return std::all_of(geometries.begin(), geometries.end(),
+ [&d](const std::unique_ptr<Geometry> & g) {
return g->getDimension() == d;
@@ -140,8 +135,8 @@ int
GeometryCollection::getBoundaryDimension() const
int dimension = Dimension::False;
- dimension = max(dimension, (*geometries)[i]->getBoundaryDimension());
+ dimension = std::max(dimension, g->getBoundaryDimension());
return dimension;
@@ -151,8 +146,8 @@ GeometryCollection::getCoordinateDimension() const
int dimension = 2;
- dimension = max(dimension, (*geometries)[i]->getCoordinateDimension());
+ dimension = std::max(dimension, g->getCoordinateDimension());
return dimension;
@@ -160,26 +155,26 @@ GeometryCollection::getCoordinateDimension() const
size_t
GeometryCollection::getNumGeometries() const
- return geometries->size();
+ return geometries.size();
const Geometry*
GeometryCollection::getGeometryN(size_t n) const
- return (*geometries)[n];
+ return geometries[n].get();
size_t
GeometryCollection::getNumPoints() const
size_t numPoints = 0;
- numPoints += (*geometries)[i]->getNumPoints();
+ numPoints += g->getNumPoints();
return numPoints;
-string
+std::string
GeometryCollection::getGeometryType() const
return "GeometryCollection";
@@ -203,11 +198,11 @@ GeometryCollection::equalsExact(const Geometry* other, double tolerance) const
return false;
- if(geometries->size() != otherCollection->geometries->size()) {
+ if(geometries.size() != otherCollection->geometries.size()) {
return false;
- if(!((*geometries)[i]->equalsExact((*(otherCollection->geometries))[i], tolerance))) {
+ if(!(geometries[i]->equalsExact(otherCollection->geometries[i].get(), tolerance))) {
return false;
@@ -217,16 +212,16 @@ GeometryCollection::equalsExact(const Geometry* other, double tolerance) const
void
GeometryCollection::apply_rw(const CoordinateFilter* filter)
- (*geometries)[i]->apply_rw(filter);
+ g->apply_rw(filter);
void
GeometryCollection::apply_ro(CoordinateFilter* filter) const
- (*geometries)[i]->apply_ro(filter);
+ g->apply_ro(filter);
@@ -234,8 +229,8 @@ void
GeometryCollection::apply_ro(GeometryFilter* filter) const
filter->filter_ro(this);
@@ -243,26 +238,28 @@ void
GeometryCollection::apply_rw(GeometryFilter* filter)
filter->filter_rw(this);
void
GeometryCollection::normalize()
- (*geometries)[i]->normalize();
+ g->normalize();
- sort(geometries->begin(), geometries->end(), GeometryGreaterThen());
+ std::sort(geometries.begin(), geometries.end(), [](const std::unique_ptr<Geometry> & a, const std::unique_ptr<Geometry> & b) {
+ return a->compareTo(b.get()) > 0;
Envelope::Ptr
GeometryCollection::computeEnvelopeInternal() const
Envelope::Ptr p_envelope(new Envelope());
- const Envelope* env = (*geometries)[i]->getEnvelopeInternal();
+ const Envelope* env = g->getEnvelopeInternal();
p_envelope->expandToInclude(env);
return p_envelope;
@@ -272,15 +269,15 @@ int
GeometryCollection::compareToSameClass(const Geometry* g) const
const GeometryCollection* gc = dynamic_cast<const GeometryCollection*>(g);
- return compare(*geometries, *(gc->geometries));
+ return compare(geometries, gc->geometries);
const Coordinate*
GeometryCollection::getCoordinate() const
- return (*geometries)[i]->getCoordinate();
+ return g->getCoordinate();
return nullptr;
@@ -293,8 +290,8 @@ double
GeometryCollection::getArea() const
double area = 0.0;
- area += (*geometries)[i]->getArea();
+ area += g->getArea();
return area;
@@ -306,8 +303,8 @@ double
GeometryCollection::getLength() const
double sum = 0.0;
- sum += (*geometries)[i]->getLength();
+ sum += g->getLength();
return sum;
@@ -316,8 +313,11 @@ void
GeometryCollection::apply_rw(GeometryComponentFilter* filter)
- for(size_t i = 0; i < geometries->size() && !filter->isDone(); ++i) {
+ if (filter->isDone()) {
+ return;
@@ -325,20 +325,19 @@ void
GeometryCollection::apply_ro(GeometryComponentFilter* filter) const
+ return;
void
GeometryCollection::apply_rw(CoordinateSequenceFilter& filter)
- if(ngeoms == 0) {
- return;
if(filter.isDone()) {
break;
@@ -351,12 +350,8 @@ GeometryCollection::apply_rw(CoordinateSequenceFilter& filter)
void
GeometryCollection::apply_ro(CoordinateSequenceFilter& filter) const
- if(ngeoms == 0) {
- return;
break;
@@ -366,13 +361,7 @@ GeometryCollection::apply_ro(CoordinateSequenceFilter& filter) const
//if (filter.isGeometryChanged()) geometryChanged();
-GeometryCollection::~GeometryCollection()
- delete(*geometries)[i];
- delete geometries;
+GeometryCollection::~GeometryCollection() = default;
GeometryTypeId
GeometryCollection::getGeometryTypeId() const
@@ -387,12 +376,12 @@ GeometryCollection::reverse() const
return clone();
- auto* reversed = new std::vector<Geometry*> {geometries->size()};
+ auto* reversed = new std::vector<Geometry*> {geometries.size()};
- std::transform(geometries->begin(),
- geometries->end(),
+ std::transform(geometries.begin(),
+ geometries.end(),
reversed->begin(),
- [](const Geometry * g) {
+ [](const std::unique_ptr<Geometry> & g) {
return g->reverse().release();
diff --git a/src/geom/MultiLineString.cpp b/src/geom/MultiLineString.cpp
index f32ff30..bc909ed 100644
--- a/src/geom/MultiLineString.cpp
+++ b/src/geom/MultiLineString.cpp
@@ -77,8 +77,8 @@ MultiLineString::isClosed() const
if(isEmpty()) {
return false;
- LineString* ls = dynamic_cast<LineString*>((*geometries)[i]);
+ LineString* ls = dynamic_cast<LineString*>(g.get());
if(! ls->isClosed()) {
return false;
@@ -119,10 +119,10 @@ MultiLineString::reverse() const
return clone();
- size_t nLines = geometries->size();
+ size_t nLines = geometries.size();
Geometry::NonConstVect* revLines = new Geometry::NonConstVect(nLines);
for(size_t i = 0; i < nLines; ++i) {
- LineString* iLS = dynamic_cast<LineString*>((*geometries)[i]);
+ LineString* iLS = dynamic_cast<LineString*>(geometries[i].get());
assert(iLS);
(*revLines)[nLines - 1 - i] = iLS->reverse().release();
diff --git a/src/geom/MultiPoint.cpp b/src/geom/MultiPoint.cpp
index ebc28f3..ba6ddb2 100644
--- a/src/geom/MultiPoint.cpp
+++ b/src/geom/MultiPoint.cpp
@@ -78,7 +78,7 @@ MultiPoint::equalsExact(const Geometry* other, double tolerance) const
const Coordinate*
MultiPoint::getCoordinateN(size_t n) const
- return ((*geometries)[n])->getCoordinate();
+ return geometries[n]->getCoordinate();
GeometryTypeId
MultiPoint::getGeometryTypeId() const
diff --git a/src/geom/MultiPolygon.cpp b/src/geom/MultiPolygon.cpp
index 2d57353..cfaa121 100644
--- a/src/geom/MultiPolygon.cpp
+++ b/src/geom/MultiPolygon.cpp
@@ -72,8 +72,8 @@ MultiPolygon::getBoundary() const
return std::unique_ptr<Geometry>(getFactory()->createMultiLineString());
vector<Geometry*>* allRings = new vector<Geometry*>();
- Polygon* pg = dynamic_cast<Polygon*>((*geometries)[i]);
+ for(size_t i = 0; i < geometries.size(); i++) {
+ Polygon* pg = dynamic_cast<Polygon*>(geometries[i].get());
assert(pg);
auto g = pg->getBoundary();
if(LineString* ls = dynamic_cast<LineString*>(g.get())) {
@@ -115,12 +115,12 @@ MultiPolygon::reverse() const
return clone();
+ geometries.end(),
reversed->begin(),
diff --git a/src/geom/Polygon.cpp b/src/geom/Polygon.cpp
index 99b0685..612f039 100644
--- a/src/geom/Polygon.cpp
+++ b/src/geom/Polygon.cpp
@@ -44,7 +44,6 @@
#define GEOS_DEBUG 0
#endif
//using namespace geos::algorithm;
namespace geos {
@@ -53,44 +52,38 @@ namespace geom { // geos::geom
/*protected*/
Polygon::Polygon(const Polygon& p)
- Geometry(p)
+ Geometry(p),
+ shell(detail::make_unique<LinearRing>(*p.shell)),
+ holes(p.holes.size())
- shell = new LinearRing(*p.shell);
- size_t nholes = p.holes->size();
- holes = new vector<LinearRing*>(nholes);
- for(size_t i = 0; i < nholes; ++i) {
- LinearRing* h = new LinearRing(*(*p.holes)[i]);
- (*holes)[i] = h;
+ for(size_t i = 0; i < holes.size(); ++i) {
+ holes[i] = detail::make_unique<LinearRing>(*p.holes[i]);
/*protected*/
-Polygon::Polygon(LinearRing* newShell, vector<LinearRing*>* newHoles,
+Polygon::Polygon(LinearRing* newShell, std::vector<LinearRing*>* newHoles,
const GeometryFactory* newFactory):
Geometry(newFactory)
if(newShell == nullptr) {
- shell = getFactory()->createLinearRing(nullptr);
+ shell.reset(getFactory()->createLinearRing(nullptr));
else {
if(newHoles != nullptr && newShell->isEmpty() && hasNonEmptyElements(newHoles)) {
throw util::IllegalArgumentException("shell is empty but holes are not");
- shell = newShell;
+ shell.reset(newShell);
- if(newHoles == nullptr) {
- holes = new vector<LinearRing*>();
- else {
+ if(newHoles != nullptr) {
if(hasNullElements(newHoles)) {
throw util::IllegalArgumentException("holes must not contain null elements");
- for(size_t i = 0; i < newHoles->size(); i++)
- if((*newHoles)[i]->getGeometryTypeId() != GEOS_LINEARRING) {
- throw util::IllegalArgumentException("holes must be LinearRings");
- holes = newHoles;
+ for (const auto& hole : *newHoles) {
+ holes.emplace_back(hole);
+ delete newHoles;
@@ -101,7 +94,7 @@ Polygon::getCoordinates() const
return getFactory()->getCoordinateSequenceFactory()->create();
- vector<Coordinate>* cl = new vector<Coordinate>;
+ std::vector<Coordinate>* cl = new std::vector<Coordinate>;
// reserve space in the vector for all the polygon points
cl->reserve(getNumPoints());
@@ -111,10 +104,8 @@ Polygon::getCoordinates() const
shellCoords->toVector(*cl);
// Add holes points
- size_t nholes = holes->size();
- const LinearRing* lr = (*holes)[i];
- const CoordinateSequence* childCoords = lr->getCoordinatesRO();
+ for(const auto& hole : holes) {
+ const CoordinateSequence* childCoords = hole->getCoordinatesRO();
childCoords->toVector(*cl);
@@ -125,7 +116,7 @@ size_t
Polygon::getNumPoints() const
size_t numPoints = shell->getNumPoints();
- for(const LinearRing* lr : *holes) {
+ for(const auto& lr : holes) {
numPoints += lr->getNumPoints();
return numPoints;
@@ -143,12 +134,11 @@ Polygon::getCoordinateDimension() const
int dimension = 2;
if(shell != nullptr) {
- dimension = max(dimension, shell->getCoordinateDimension());
+ dimension = std::max(dimension, shell->getCoordinateDimension());
- dimension = max(dimension, (*holes)[i]->getCoordinateDimension());
+ dimension = std::max(dimension, hole->getCoordinateDimension());
return dimension;
@@ -169,22 +159,22 @@ Polygon::isEmpty() const
const LinearRing*
Polygon::getExteriorRing() const
- return shell;
+ return shell.get();
size_t
Polygon::getNumInteriorRing() const
- return holes->size();
+ return holes.size();
const LinearRing*
Polygon::getInteriorRingN(size_t n) const
- return (*holes)[n];
+ return holes[n].get();
-string
+std::string
Polygon::getGeometryType() const
return "Polygon";
@@ -207,15 +197,15 @@ Polygon::getBoundary() const
return std::unique_ptr<Geometry>(gf->createMultiLineString());
- if(! holes->size()) {
- return std::unique_ptr<Geometry>(gf->createLineString(*shell).release());
+ if(holes.empty()) {
+ return std::unique_ptr<Geometry>(gf->createLineString(*shell));
- vector<Geometry*>* rings = new vector<Geometry*>(holes->size() + 1);
+ std::vector<Geometry*>* rings = new std::vector<Geometry*>(holes.size() + 1);
(*rings)[0] = gf->createLineString(*shell).release();
- for(size_t i = 0, n = holes->size(); i < n; ++i) {
- const LinearRing* hole = (*holes)[i];
+ for(size_t i = 0, n = holes.size(); i < n; ++i) {
+ const LinearRing* hole = holes[i].get();
assert(hole);
LineString* ls = gf->createLineString(*hole).release();
(*rings)[i + 1] = ls;
@@ -238,19 +228,19 @@ Polygon::equalsExact(const Geometry* other, double tolerance) const
return false;
- if(!shell->equalsExact(otherPolygon->shell, tolerance)) {
+ if(!shell->equalsExact(otherPolygon->shell.get(), tolerance)) {
return false;
+ size_t nholes = holes.size();
- if(nholes != otherPolygon->holes->size()) {
+ if(nholes != otherPolygon->holes.size()) {
return false;
for(size_t i = 0; i < nholes; i++) {
- const Geometry* hole = (*holes)[i];
- const Geometry* otherhole = (*(otherPolygon->holes))[i];
+ const LinearRing* otherhole = otherPolygon->holes[i].get();
if(!hole->equalsExact(otherhole, tolerance)) {
return false;
@@ -263,7 +253,7 @@ void
Polygon::apply_ro(CoordinateFilter* filter) const
shell->apply_ro(filter);
lr->apply_ro(filter);
@@ -272,7 +262,7 @@ void
Polygon::apply_rw(const CoordinateFilter* filter)
shell->apply_rw(filter);
- for(LinearRing* lr : *holes) {
+ for(auto& lr : holes) {
lr->apply_rw(filter);
@@ -298,18 +288,20 @@ Polygon::convexHull() const
void
Polygon::normalize()
- normalize(shell, true);
- normalize(lr, false);
+ normalize(shell.get(), true);
+ normalize(lr.get(), false);
- sort(holes->begin(), holes->end(), GeometryGreaterThen());
+ std::sort(holes.begin(), holes.end(), [](const std::unique_ptr<LinearRing> & a, const std::unique_ptr<LinearRing> & b) {
int
Polygon::compareToSameClass(const Geometry* g) const
const Polygon* p = dynamic_cast<const Polygon*>(g);
- return shell->compareToSameClass(p->shell);
+ return shell->compareToSameClass(p->shell.get());
@@ -354,10 +346,10 @@ double
Polygon::getArea() const
double area = 0.0;
- area += fabs(algorithm::Area::ofRing(shell->getCoordinatesRO()));
+ area += algorithm::Area::ofRing(shell->getCoordinatesRO());
const CoordinateSequence* h = lr->getCoordinatesRO();
- area -= fabs(algorithm::Area::ofRing(h));
+ area -= algorithm::Area::ofRing(h);
return area;
@@ -372,8 +364,8 @@ Polygon::getLength() const
double len = 0.0;
len += shell->getLength();
- len += (*holes)[i]->getLength();
+ len += hole->getLength();
return len;
@@ -383,8 +375,8 @@ Polygon::apply_ro(GeometryComponentFilter* filter) const
- for(size_t i = 0, n = holes->size(); i < n && !filter->isDone(); ++i) {
- (*holes)[i]->apply_ro(filter);
+ for(size_t i = 0, n = holes.size(); i < n && !filter->isDone(); ++i) {
+ holes[i]->apply_ro(filter);
@@ -393,8 +385,8 @@ Polygon::apply_rw(GeometryComponentFilter* filter)
- (*holes)[i]->apply_rw(filter);
+ holes[i]->apply_rw(filter);
@@ -404,8 +396,8 @@ Polygon::apply_rw(CoordinateSequenceFilter& filter)
if(! filter.isDone()) {
break;
@@ -422,8 +414,8 @@ Polygon::apply_ro(CoordinateSequenceFilter& filter) const
break;
@@ -432,14 +424,7 @@ Polygon::apply_ro(CoordinateSequenceFilter& filter) const
-Polygon::~Polygon()
- delete shell;
- delete(*holes)[i];
- delete holes;
+Polygon::~Polygon() = default;
GeometryTypeId
Polygon::getGeometryTypeId() const
@@ -498,12 +483,12 @@ Polygon::reverse() const
auto* exteriorRingReversed = dynamic_cast<LinearRing*>(shell->reverse().release());
- auto* interiorRingsReversed = new std::vector<LinearRing*> {holes->size()};
+ auto* interiorRingsReversed = new std::vector<LinearRing*> {holes.size()};
- std::transform(holes->begin(),
- holes->end(),
+ std::transform(holes.begin(),
+ holes.end(),
interiorRingsReversed->begin(),
+ [](const std::unique_ptr<LinearRing> & g) {
return dynamic_cast<LinearRing*>(g->reverse().release());
diff --git a/src/operation/IsSimpleOp.cpp b/src/operation/IsSimpleOp.cpp
index 03c1fd5..c808f8c 100644
--- a/src/operation/IsSimpleOp.cpp
+++ b/src/operation/IsSimpleOp.cpp
@@ -263,10 +263,8 @@ IsSimpleOp::computeSimple(const geom::Geometry* g)
bool
IsSimpleOp::isSimpleGeometryCollection(const geom::GeometryCollection* col)
- GeometryCollection::const_iterator it;
- for(it = col->begin(); it < col->end(); ++it) {
- const geom::Geometry* g = *it;
- if(!computeSimple(g)) {
+ for(const auto& g : *col) {
+ if(!computeSimple(g.get())) {
return false;
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index 9198242..7016f03 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -118,10 +118,8 @@ CascadedPolygonUnion::Union(const geom::MultiPolygon* multipoly)
std::vector<geom::Polygon*> polys;
- typedef geom::MultiPolygon::const_iterator iterator;
- iterator end = multipoly->end();
- for(iterator i = multipoly->begin(); i != end; ++i) {
- polys.push_back(dynamic_cast<geom::Polygon*>(*i));
+ for(const auto& g : *multipoly) {
+ polys.push_back(dynamic_cast<geom::Polygon*>(g.get()));
CascadedPolygonUnion op(&polys);
diff --git a/src/operation/valid/MakeValid.cpp b/src/operation/valid/MakeValid.cpp
index b10ea95..90f9b62 100644
--- a/src/operation/valid/MakeValid.cpp
+++ b/src/operation/valid/MakeValid.cpp
@@ -96,8 +96,8 @@ static std::unique_ptr<geom::Geometry> MakeValidMultiLine(const geom::MultiLineS
std::vector<std::unique_ptr<geom::Geometry>> points;
std::vector<std::unique_ptr<geom::Geometry>> lines;
- for(const auto subgeom: *mls) {
- auto line = dynamic_cast<const geom::LineString*>(subgeom);
+ for(const auto& subgeom: *mls) {
+ auto line = dynamic_cast<const geom::LineString*>(subgeom.get());
assert(line);
auto validSubGeom = MakeValidLine(line);
if( !validSubGeom || validSubGeom->isEmpty() ) {
@@ -111,7 +111,7 @@ static std::unique_ptr<geom::Geometry> MakeValidMultiLine(const geom::MultiLineS
lines.emplace_back(std::move(validSubGeom));
} else if( validLineType == GEOS_MULTILINESTRING ) {
auto mlsValid = dynamic_cast<const geom::MultiLineString*>(validSubGeom.get());
- for(const auto subgeomMlsValid: *mlsValid) {
+ for(const auto& subgeomMlsValid: *mlsValid) {
lines.emplace_back(subgeomMlsValid->clone());
} else {
@@ -290,9 +290,9 @@ static std::unique_ptr<geom::Geometry> MakeValidCollection(const geom::GeometryC
auto validGeoms = new std::vector<geom::Geometry*>();
try {
- for( auto geom: *coll )
+ for(const auto& geom: *coll )
- validGeoms->push_back(MakeValid().build(geom).release());
+ validGeoms->push_back(MakeValid().build(geom.get()).release());
return std::unique_ptr<geom::Geometry>(
GeometryFactory::create()->createGeometryCollection(validGeoms));
Summary of changes:
include/geos/geom/Geometry.h | 2 +
include/geos/geom/GeometryCollection.h | 8 +-
include/geos/geom/GeometryCollection.inl | 4 +-
include/geos/geom/Polygon.h | 4 +-
src/algorithm/PointLocator.cpp | 10 +-
src/algorithm/locate/SimplePointInAreaLocator.cpp | 6 +-
src/geom/Geometry.cpp | 25 ++++
src/geom/GeometryCollection.cpp | 169 ++++++++++------------
src/geom/MultiLineString.cpp | 8 +-
src/geom/MultiPoint.cpp | 2 +-
src/geom/MultiPolygon.cpp | 12 +-
src/geom/Polygon.cpp | 137 ++++++++----------
src/operation/IsSimpleOp.cpp | 6 +-
src/operation/union/CascadedPolygonUnion.cpp | 6 +-
src/operation/valid/MakeValid.cpp | 10 +-
15 files changed, 201 insertions(+), 208 deletions(-)
hooks/post-receive
More information about the geos-commits
