[geos-commits] [SCM] GEOS branch master updated. e5d9a6893d92c89b850b13328bbbaea4ac6fb311
Fri May 24 14:13:19 PDT 2019
the project "GEOS".
       via  e5d9a6893d92c89b850b13328bbbaea4ac6fb311 (commit)
      from  7e4ffa5d1ebab6d61994846a95e66a1c811c868c (commit)
revisions in full, below.
commit e5d9a6893d92c89b850b13328bbbaea4ac6fb311
Author: Mateusz Łoskot <mateusz at loskot.net>
Date:   Fri May 24 09:47:50 2019 +0200
    Point CMAKE_*_OUTPUT_DIRECTORY to common location
    Place executables and shared libraries in the same location for
    convenience of direct execution from common spot and for
    convenience in environments without RPATH support.
    In future, if number of generated executables grows significantly,
    with possible name clashes, it may be more convenient to replace
    the common locations with setting PATH per test, on Windows only:
      set_tests_properties(<test name> PROPERTIES
        ENVIRONMENT
          "PATH=$<SHELL_PATH:$<TARGET_FILE_DIR:geos>>$<SEMICOLON>$<TARGET_FILE_DIR:geos_c>>$<SEMICOLON>$ENV{PATH}"
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 2937297..388ffbf 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -43,6 +43,18 @@ cmake_dependent_option(GEOS_BUILD_DEVELOPER
 mark_as_advanced(GEOS_BUILD_DEVELOPER)
+# Setup build directories
+# Place executables and shared libraries in the same location for
+# convenience of direct execution from common spot and for
+# convenience in environments without RPATH support.
+set(CMAKE_LIBRARY_OUTPUT_DIRECTORY ${CMAKE_BINARY_DIR}/lib)
+set(CMAKE_ARCHIVE_OUTPUT_DIRECTORY ${CMAKE_BINARY_DIR}/lib)
+set(CMAKE_RUNTIME_OUTPUT_DIRECTORY ${CMAKE_BINARY_DIR}/bin)
+message(STATUS "GEOS: Run-time output: ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}")
+message(STATUS "GEOS: Archives output: ${CMAKE_LIBRARY_OUTPUT_DIRECTORY}")
 # Version
 file(READ Version.txt _version_txt)
Summary of changes:
 CMakeLists.txt | 12 ++++++++++++
 1 file changed, 12 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
