[geos-commits] [SCM] GEOS branch 3.8 updated. 317ad362ca5d5b25dc615f97162121043802eb53
Fri Nov 8 08:20:25 PST 2019
the project "GEOS".
The branch, 3.8 has been updated
       via  317ad362ca5d5b25dc615f97162121043802eb53 (commit)
       via  4ac341b8098a4c38b71d0f654950d4e924c60393 (commit)
       via  1c5031b2cc9901221c48445499a1c08a9fe4a96a (commit)
      from  93be2e1d5a143d757e6cf5fc7c29c7ef48919ccf (commit)
revisions in full, below.
commit 317ad362ca5d5b25dc615f97162121043802eb53
Author: Daniel Baston <dbaston at gmail.com>
Date:   Fri Nov 8 11:20:18 2019 -0500
    Add NEWS entry for #1001 fix
diff --git a/NEWS b/NEWS
index 003c2f5..435124f 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,8 @@ Changes in 3.8.1
 - Bug fixes / improvements
   - Stack allocate line segments in OverlapUnion (Paul Ramsey)
+  - Avoid returning non-empty CoordinateSequence from empty Point
+    (#1001, Dan Baston)
   - Avoid assertion failure with MSVC 2017 / 2019 (#1002, Dan Baston)
commit 4ac341b8098a4c38b71d0f654950d4e924c60393
Date:   Fri Oct 25 15:13:44 2019 -0400
    Distinguish between 2D and 3D empty Points
diff --git a/include/geos/geom/FixedSizeCoordinateSequence.h b/include/geos/geom/FixedSizeCoordinateSequence.h
index 2bdcbb2..20e661d 100644
--- a/include/geos/geom/FixedSizeCoordinateSequence.h
+++ b/include/geos/geom/FixedSizeCoordinateSequence.h
@@ -35,9 +35,9 @@ namespace geom {
         explicit FixedSizeCoordinateSequence(size_t dimension_in = 0) : dimension(dimension_in) {}
         std::unique_ptr<CoordinateSequence> clone() const final override {
-            auto seq = detail::make_unique<FixedSizeCoordinateSequence<N>>();
+            auto seq = detail::make_unique<FixedSizeCoordinateSequence<N>>(dimension);
             seq->m_data = m_data;
-            return std::unique_ptr<CoordinateSequence>(seq.release());
+            return std::move(seq); // move needed for gcc 4.8
         const Coordinate& getAt(size_t i) const final override {
diff --git a/include/geos/geom/Point.h b/include/geos/geom/Point.h
index a631e70..bc84980 100644
--- a/include/geos/geom/Point.h
+++ b/include/geos/geom/Point.h
@@ -178,7 +178,9 @@ private:
      *  The <code>Coordinate</code> wrapped by this <code>Point</code>.
     FixedSizeCoordinateSequence<1> coordinates;
-    bool empty;
+    bool empty2d;
+    bool empty3d;
 } // namespace geos::geom
diff --git a/src/geom/Point.cpp b/src/geom/Point.cpp
index 3724503..864e883 100644
--- a/src/geom/Point.cpp
+++ b/src/geom/Point.cpp
@@ -41,18 +41,20 @@ using namespace std;
 namespace geos {
 namespace geom { // geos::geom
-const static FixedSizeCoordinateSequence<0> emptyCoords;
+const static FixedSizeCoordinateSequence<0> emptyCoords2d(2);
+const static FixedSizeCoordinateSequence<0> emptyCoords3d(3);
 /*protected*/
 Point::Point(CoordinateSequence* newCoords, const GeometryFactory* factory)
     Geometry(factory),
-    empty(false)
+    empty2d(false),
+    empty3d(false)
     std::unique_ptr<CoordinateSequence> coords(newCoords);
     if(coords == nullptr) {
-        empty = true;
+        empty3d = true;
         return;
@@ -60,14 +62,17 @@ Point::Point(CoordinateSequence* newCoords, const GeometryFactory* factory)
         coordinates.setAt(coords->getAt(0), 0);
     } else if (coords->getSize() > 1) {
         throw util::IllegalArgumentException("Point coordinate list must contain a single element");
+    } else if (coords->getDimension() == 3) {
+        empty3d = true;
     } else {
-        empty = true;
+        empty2d = true;
 Point::Point(const Coordinate & c, const GeometryFactory* factory) :
     Geometry(factory),
-    empty(false)
+    empty2d(false),
+    empty3d(false)
     coordinates.setAt(c, 0);
@@ -77,7 +82,8 @@ Point::Point(const Point& p)
     Geometry(p),
     coordinates(p.coordinates),
-    empty(p.empty)
+    empty2d(p.empty3d),
+    empty3d(p.empty3d)
@@ -90,13 +96,13 @@ Point::getCoordinates() const
 size_t
 Point::getNumPoints() const
-    return empty ? 0 : 1;
+    return isEmpty() ? 0 : 1;
 bool
 Point::isEmpty() const
-    return empty;
+    return empty2d || empty3d;
 bool
@@ -153,7 +159,7 @@ Point::getZ() const
 const Coordinate*
 Point::getCoordinate() const
-    return empty ? nullptr : &coordinates[0];
+    return isEmpty() ? nullptr : &coordinates[0];
 string
@@ -288,8 +294,10 @@ Point::getGeometryTypeId() const
 const CoordinateSequence*
 Point::getCoordinatesRO() const
-    if (isEmpty()) {
-        return &emptyCoords;
+    if (empty2d) {
+        return &emptyCoords2d;
+    } else if (empty3d) {
+        return &emptyCoords3d;
     return &coordinates;
diff --git a/tests/unit/geom/FixedSizeCoordinateSequenceTest.cpp b/tests/unit/geom/FixedSizeCoordinateSequenceTest.cpp
index 968c733..9987750 100644
--- a/tests/unit/geom/FixedSizeCoordinateSequenceTest.cpp
+++ b/tests/unit/geom/FixedSizeCoordinateSequenceTest.cpp
@@ -124,4 +124,20 @@ void object::test<5>() {
     ensure_equals(seq1_3d.getDimension(), 3ul);
+// test clone
+template<>
+template<>
+void object::test<6>
+    FixedSizeCoordinateSequence<1> a(2);
+    a.setAt({ 1, 2, 3 }, 0);
+    ensure_equals(a.getDimension(), 2);
+    auto b = a.clone();
+    ensure_equals(b->getDimension(), 2);
+    ensure(a.getAt(0).equals3D(b->getAt(0)));
diff --git a/tests/unit/geom/PointTest.cpp b/tests/unit/geom/PointTest.cpp
index 883ad7b..67f085c 100644
--- a/tests/unit/geom/PointTest.cpp
+++ b/tests/unit/geom/PointTest.cpp
@@ -559,5 +559,26 @@ void object::test<44>
     ensure_equals(empty_point_->getCoordinatesRO()->getSize(), 0u);
+// check dimensionality of empty points
+template<>
+template<>
+void object::test<45>
+    auto empty3d = factory_->createPoint();
+    ensure_equals(empty3d->getCoordinateDimension(), 3);
+    geos::geom::FixedSizeCoordinateSequence<0> seq2(2);
+    ensure_equals(seq2.getDimension(), 2u);
+    ensure_equals(factory_->createPoint(seq2)->getCoordinateDimension(), 2);
+    geos::geom::FixedSizeCoordinateSequence<0> seq3(3);
+    ensure_equals(seq3.getDimension(), 3u);
+    ensure_equals(factory_->createPoint(seq3)->getCoordinateDimension(), 3);
 } // namespace tut
commit 1c5031b2cc9901221c48445499a1c08a9fe4a96a
Date:   Wed Oct 23 21:25:39 2019 -0400
    Avoid returning size-1 CoordinateSequence from empty point
    Fixes #1001
index 0db6b30..3724503 100644
@@ -41,6 +41,7 @@ using namespace std;
 namespace geos {
+const static FixedSizeCoordinateSequence<0> emptyCoords;
 /*protected*/
@@ -83,7 +84,7 @@ Point::Point(const Point& p)
-    return coordinates.clone();
+    return getCoordinatesRO()->clone();
 size_t
@@ -113,7 +114,7 @@ Point::getDimension() const
 int
 Point::getCoordinateDimension() const
-    return (int) coordinates.getDimension();
+    return (int) getCoordinatesRO()->getDimension();
 int
@@ -191,6 +192,9 @@ Point::apply_ro(CoordinateFilter* filter) const
 void
 Point::apply_rw(const CoordinateFilter* filter)
+    if (isEmpty()) {
+        return;
     coordinates.apply_rw(filter);
@@ -284,6 +288,9 @@ Point::getGeometryTypeId() const
+    if (isEmpty()) {
+        return &emptyCoords;
index 4a91875..883ad7b 100644
@@ -549,5 +549,15 @@ void object::test<43>
     ensure(!point_->isDimensionStrict(geos::geom::Dimension::A));
+// empty point has size-0 coordinate sequence
+template<>
+template<>
+void object::test<44>
+    ensure_equals(empty_point_->getCoordinates()->getSize(), 0u);
+    ensure_equals(empty_point_->getCoordinatesRO()->getSize(), 0u);
 } // namespace tut
Summary of changes:
 NEWS                                               |  2 ++
 include/geos/geom/FixedSizeCoordinateSequence.h    |  4 +--
 include/geos/geom/Point.h                          |  4 ++-
 src/geom/Point.cpp                                 | 35 +++++++++++++++-------
 .../unit/geom/FixedSizeCoordinateSequenceTest.cpp  | 16 ++++++++++
 tests/unit/geom/PointTest.cpp                      | 31 +++++++++++++++++++
 6 files changed, 79 insertions(+), 13 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
