[geos-commits] [SCM] GEOS branch master updated. 7a7cbf84fc5d4369baaf4c6e0614f44d4207503f
Wed Nov 27 17:59:58 PST 2019
the project "GEOS".
       via  7a7cbf84fc5d4369baaf4c6e0614f44d4207503f (commit)
       via  ec5d8b2a7ea8eed70450145a6d4f0da182b87dd8 (commit)
       via  695b30dd48d6371ce0882bf2537fe2fd8d73c6a7 (commit)
      from  bc180e14fab95c77044647525e0854fbf98a8200 (commit)
revisions in full, below.
commit 7a7cbf84fc5d4369baaf4c6e0614f44d4207503f
Author: Daniel Baston <dbaston at gmail.com>
Date:   Sun Nov 24 21:49:53 2019 -0500
    Simplify GEOSLineMerge_r
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 5b4944a..34ec1e6 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1890,26 +1890,15 @@ extern "C" {
         return execute(extHandle, [&]() {
             GEOSContextHandleInternal_t* handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
             const GeometryFactory* gf = handle->geomFactory;
-            Geometry* out;
             LineMerger lmrgr;
             lmrgr.add(g);
             std::vector<LineString*>* lines = lmrgr.getMergedLineStrings();
-            assert(0 != lines);
-            // TODO avoid "new" here
-            std::vector<Geometry*>* geoms = new std::vector<Geometry*>(lines->size());
-            for(std::vector<Geometry*>::size_type i = 0; i < lines->size(); ++i) {
-                (*geoms)[i] = (*lines)[i];
-            delete lines;
-            lines = 0;
-            out = gf->buildGeometry(geoms);
+            auto out = gf->buildGeometry(lines->begin(), lines->end());
             out->setSRID(g->getSRID());
-            return out;
+            return out.release();
commit ec5d8b2a7ea8eed70450145a6d4f0da182b87dd8
Date:   Sun Nov 24 21:44:27 2019 -0500
    Remove heap alloc in GEOSGeom_createCollection_r
index 736b12d..5b4944a 100644
@@ -1285,7 +1285,6 @@ extern "C" {
             auto ret = g1->getInteriorPoint();
             if(ret == nullptr) {
-                // TODO check if it is really possible for getInteriorPoint to return null
                 const GeometryFactory* gf = g1->getFactory();
                 // return an empty point
                 ret = gf->createPoint();
@@ -1683,31 +1682,31 @@ extern "C" {
-            // TODO avoid new here
-            std::vector<Geometry*>* vgeoms = new std::vector<Geometry*>(geoms, geoms + ngeoms);
-            Geometry* g = 0;
+            std::vector<std::unique_ptr<Geometry>> vgeoms(ngeoms);
+            for (size_t i = 0; i < ngeoms; i++) {
+                vgeoms[i].reset(geoms[i]);
+            std::unique_ptr<Geometry> g;
             switch(type) {
             case GEOS_GEOMETRYCOLLECTION:
-                g = gf->createGeometryCollection(vgeoms);
+                g = gf->createGeometryCollection(std::move(vgeoms));
                 break;
             case GEOS_MULTIPOINT:
-                g = gf->createMultiPoint(vgeoms);
+                g = gf->createMultiPoint(std::move(vgeoms));
                 break;
             case GEOS_MULTILINESTRING:
-                g = gf->createMultiLineString(vgeoms);
+                g = gf->createMultiLineString(std::move(vgeoms));
                 break;
             case GEOS_MULTIPOLYGON:
-                g = gf->createMultiPolygon(vgeoms);
+                g = gf->createMultiPolygon(std::move(vgeoms));
                 break;
             default:
                 handle->ERROR_MESSAGE("Unsupported type request for PostGIS2GEOS_collection");
-                delete vgeoms;
-                g = 0;
-            return g;
+            return g.release();
commit 695b30dd48d6371ce0882bf2537fe2fd8d73c6a7
Date:   Sun Nov 24 21:12:55 2019 -0500
    Simplify CAPI polygonizer code
index 66d9373..736b12d 100644
@@ -1726,31 +1726,8 @@ extern "C" {
             auto polys = plgnzr.getPolygons();
-            assert(0 != polys);
-            // We need a vector of Geometry pointers, not Polygon pointers.
-            // STL vector doesn't allow transparent upcast of this
-            // nature, so we explicitly convert.
-            // (it's just a waste of processor and memory, btw)
-            // XXX mloskot: Why not to extent GeometryFactory to accept
-            // vector of polygons or extend Polygonizer to return list of Geometry*
-            // or add a wrapper which semantic is similar to:
-            // std::vector<as_polygon<Geometry*> >
-            std::vector<Geometry*>* polyvec = new std::vector<Geometry*>(polys->size());
-            for(std::size_t i = 0; i < polys->size(); ++i) {
-                (*polyvec)[i] = (*polys)[i].release();
-            polys = 0;
-            // The below takes ownership of the passed vector,
-            // so we must *not* delete it
-            return gf->createGeometryCollection(polyvec);
+            return gf->createGeometryCollection(std::move(polys)).release();
@@ -1772,18 +1749,12 @@ extern "C" {
-            if (polys->empty()) {
+            if (polys.empty()) {
                 out = handle->geomFactory->createGeometryCollection().release();
-            } else if (polys->size() == 1) {
-                return (*polys)[0].release();
+            } else if (polys.size() == 1) {
+                return polys[0].release();
             } else {
-                auto geoms = new std::vector<Geometry *>(polys->size());
-                for (size_t i = 0; i < polys->size(); i++) {
-                    (*geoms)[i] = (*polys)[i].release();
-                return handle->geomFactory->createMultiPolygon(geoms);
+                return handle->geomFactory->createMultiPolygon(std::move(polys)).release();
             out->setSRID(srid);
@@ -1876,54 +1847,37 @@ extern "C" {
             const GeometryFactory* gf = g->getFactory();
             if(cuts) {
                 const std::vector<const LineString*>& lines = plgnzr.getCutEdges();
-                std::vector<Geometry*>* linevec = new std::vector<Geometry*>(lines.size());
+                std::vector<std::unique_ptr<Geometry>> linevec(lines.size());
                 for(std::size_t i = 0, n = lines.size(); i < n; ++i) {
-                    (*linevec)[i] = lines[i]->clone().release();
+                    linevec[i] = lines[i]->clone();
-                *cuts = gf->createGeometryCollection(linevec);
+                *cuts = gf->createGeometryCollection(std::move(linevec)).release();
             if(dangles) {
                 const std::vector<const LineString*>& lines = plgnzr.getDangles();
-                *dangles = gf->createGeometryCollection(linevec);
+                *dangles = gf->createGeometryCollection(std::move(linevec)).release();
             if(invalid) {
                 const std::vector<std::unique_ptr<LineString>>& lines = plgnzr.getInvalidRingLines();
-                *invalid = gf->createGeometryCollection(linevec);
+                *invalid = gf->createGeometryCollection(std::move(linevec)).release();
-            Geometry* out = gf->createGeometryCollection(polyvec);
+            Geometry* out = gf->createGeometryCollection(std::move(polys)).release();
             return out;
diff --git a/doc/example.cpp b/doc/example.cpp
index 0a6b32c..bc1f324 100644
--- a/doc/example.cpp
+++ b/doc/example.cpp
@@ -1100,8 +1100,8 @@ do_all()
     plgnzr.add(geoms);
     newgeoms = new vector<const Geometry*>;
-    for(unsigned int i = 0; i < polys->size(); i++) {
-        newgeoms->push_back((*polys)[i].release());
+    for(unsigned int i = 0; i < polys.size(); i++) {
+        newgeoms->push_back(polys[i].release());
     cout << endl << "----- HERE IS POLYGONIZE OUTPUT ------" << endl;
diff --git a/include/geos/geom/GeometryFactory.h b/include/geos/geom/GeometryFactory.h
index a33d03f..c961745 100644
--- a/include/geos/geom/GeometryFactory.h
+++ b/include/geos/geom/GeometryFactory.h
@@ -185,8 +185,12 @@ public:
     GeometryCollection* createGeometryCollection(
         std::vector<Geometry*>* newGeoms) const;
+    template<typename T>
     std::unique_ptr<GeometryCollection> createGeometryCollection(
-            std::vector<std::unique_ptr<Geometry>> && newGeoms) const;
+            std::vector<std::unique_ptr<T>> && newGeoms) const {
+        // Can't use make_unique because constructor is protected
+        return std::unique_ptr<GeometryCollection>(new GeometryCollection(std::move(newGeoms), *this));
     /// Constructs a GeometryCollection with a deep-copy of args
diff --git a/include/geos/operation/polygonize/Polygonizer.h b/include/geos/operation/polygonize/Polygonizer.h
index ca4202b..04b2c72 100644
--- a/include/geos/operation/polygonize/Polygonizer.h
+++ b/include/geos/operation/polygonize/Polygonizer.h
@@ -118,9 +118,10 @@ private:
     static void findOuterShells(std::vector<EdgeRing*>& shellList);
-    static std::unique_ptr<std::vector<std::unique_ptr<geom::Polygon>>> extractPolygons(std::vector<EdgeRing*> & shellList, bool includeAll);
+    static std::vector<std::unique_ptr<geom::Polygon>> extractPolygons(std::vector<EdgeRing*> & shellList, bool includeAll);
     bool extractOnlyPolygonal;
+    bool computed;
 protected:
@@ -133,7 +134,7 @@ protected:
     std::vector<EdgeRing*> holeList;
     std::vector<EdgeRing*> shellList;
-    std::unique_ptr<std::vector<std::unique_ptr<geom::Polygon>>> polyList;
+    std::vector<std::unique_ptr<geom::Polygon>> polyList;
 public:
@@ -194,7 +195,7 @@ public:
      * calls will return NULL.
      * @return a collection of Polygons
-    std::unique_ptr<std::vector<std::unique_ptr<geom::Polygon>>> getPolygons();
+    std::vector<std::unique_ptr<geom::Polygon>> getPolygons();
     /** \brief
      * Get the list of dangling lines found during polygonization.
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index fc692f6..6cfa396 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -398,12 +398,6 @@ GeometryFactory::createGeometryCollection(vector<Geometry*>* newGeoms) const
     return new GeometryCollection(newGeoms, this);
-std::unique_ptr<GeometryCollection>
-GeometryFactory::createGeometryCollection(std::vector<std::unique_ptr<geos::geom::Geometry>> && newGeoms) const {
-    // Can't use make_unique because constructor is protected
-    return std::unique_ptr<GeometryCollection>(new GeometryCollection(std::move(newGeoms), *this));
 /*public*/
 GeometryCollection*
 GeometryFactory::createGeometryCollection(const std::vector<const Geometry*>& fromGeoms) const
diff --git a/src/operation/polygonize/BuildArea.cpp b/src/operation/polygonize/BuildArea.cpp
index 6b4b923..2302d20 100644
--- a/src/operation/polygonize/BuildArea.cpp
+++ b/src/operation/polygonize/BuildArea.cpp
@@ -144,7 +144,7 @@ unique_ptr<geom::Geometry> BuildArea::build(const geom::Geometry* geom) {
     auto polys = polygonizer.getPolygons();
     // No geometries in collection, early out
-    if( polys->empty() ) {
+    if( polys.empty() ) {
         // TODO don't create new GeometryFactory here
         auto emptyGeomCollection = unique_ptr<geom::Geometry>(
             GeometryFactory::create()->createGeometryCollection());
@@ -153,8 +153,8 @@ unique_ptr<geom::Geometry> BuildArea::build(const geom::Geometry* geom) {
     // Return first geometry if we only have one in collection
-    if( polys->size() == 1 ) {
-        auto ret = std::unique_ptr<geom::Geometry>((*polys)[0].release());
+    if( polys.size() == 1 ) {
+        std::unique_ptr<Geometry> ret = std::move(polys[0]);
         ret->setSRID(geom->getSRID());
         return ret;
@@ -189,7 +189,7 @@ unique_ptr<geom::Geometry> BuildArea::build(const geom::Geometry* geom) {
     /* Prepare face structures for later analysis */
     std::vector<std::unique_ptr<Face>> faces;
-    for(auto& poly: *polys) {
+    for(const auto& poly: polys) {
         faces.emplace_back(newFace(poly.get()));
diff --git a/src/operation/polygonize/Polygonizer.cpp b/src/operation/polygonize/Polygonizer.cpp
index 38bd0b1..e146bdc 100644
--- a/src/operation/polygonize/Polygonizer.cpp
+++ b/src/operation/polygonize/Polygonizer.cpp
@@ -63,13 +63,13 @@ Polygonizer::LineStringAdder::filter_ro(const Geometry* g)
 Polygonizer::Polygonizer(bool onlyPolygonal):
     lineStringAdder(this),
     extractOnlyPolygonal(onlyPolygonal),
+    computed(false),
     graph(nullptr),
     dangles(),
     cutEdges(),
     invalidRingLines(),
     holeList(),
-    shellList(),
-    polyList(nullptr)
+    shellList()
@@ -152,7 +152,7 @@ Polygonizer::add(const LineString* line)
  * Gets the list of polygons formed by the polygonization.
-unique_ptr<vector<unique_ptr<Polygon>>>
+std::vector<std::unique_ptr<Polygon>>
 Polygonizer::getPolygons()
     polygonize();
@@ -215,13 +215,13 @@ void
 Polygonizer::polygonize()
     // check if already computed
-    if(polyList != nullptr) {
+    if(computed) {
         return;
     // if no geometries were supplied it's possible graph could be null
     if(graph == nullptr) {
-        polyList.reset(new std::vector<std::unique_ptr<Polygon>>());
+        polyList.clear();
         return;
@@ -256,6 +256,8 @@ Polygonizer::polygonize()
         includeAll = false;
     polyList = extractPolygons(shellList, includeAll);
+    computed = true;
 /* private */
@@ -320,13 +322,13 @@ Polygonizer::findOuterShells(vector<EdgeRing*> & shells)
-std::unique_ptr<std::vector<std::unique_ptr<Polygon>>>
 Polygonizer::extractPolygons(vector<EdgeRing*> & shells, bool includeAll)
-    std::unique_ptr<std::vector<std::unique_ptr<Polygon>>> polys(new std::vector<std::unique_ptr<Polygon>>);
+    std::vector<std::unique_ptr<Polygon>> polys;
     for (EdgeRing* er : shells) {
         if (includeAll || er->isIncluded()) {
-            polys->emplace_back(er->getPolygon());
+            polys.emplace_back(er->getPolygon());
diff --git a/src/operation/union/CoverageUnion.cpp b/src/operation/union/CoverageUnion.cpp
index 4988d5a..5e10ca4 100644
--- a/src/operation/union/CoverageUnion.cpp
+++ b/src/operation/union/CoverageUnion.cpp
@@ -97,11 +97,11 @@ std::unique_ptr<Geometry> CoverageUnion::polygonize(const GeometryFactory* gf) {
     auto polygons = p.getPolygons();
     segment_geoms.reset();
-    if (polygons->size() == 1) {
-        return std::unique_ptr<Geometry>((*polygons)[0].release());
+    if (polygons.size() == 1) {
+        return std::move(polygons[0]);
-    return gf->createMultiPolygon(std::move(*polygons));
+    return gf->createMultiPolygon(std::move(polygons));
 std::unique_ptr<geom::Geometry> CoverageUnion::Union(const geom::Geometry* geom) {
diff --git a/tests/unit/operation/polygonize/PolygonizeTest.cpp b/tests/unit/operation/polygonize/PolygonizeTest.cpp
index 62a35a5..a668aba 100644
--- a/tests/unit/operation/polygonize/PolygonizeTest.cpp
+++ b/tests/unit/operation/polygonize/PolygonizeTest.cpp
@@ -119,18 +119,17 @@ struct test_polygonizetest_data {
             polygonizer.add(p.get());
-        std::unique_ptr<std::vector<std::unique_ptr<Poly>> > retGeoms;
-        retGeoms = polygonizer.getPolygons();
-        for (const auto& g : *retGeoms) {
+        auto retGeoms = polygonizer.getPolygons();
+        for (const auto& g : retGeoms) {
             g->normalize();
-        bool ok = compare(expectGeoms, *retGeoms);
+        bool ok = compare(expectGeoms, retGeoms);
         if(! ok) {
             cout << "EXPECTED(" << expectGeoms.size() << "): " << std::endl;
             printAll(cout, expectGeoms);
-            cout << "OBTAINED(" << retGeoms->size() << "): " << std::endl;
-            printAll(cout, *retGeoms);
+            cout << "OBTAINED(" << retGeoms.size() << "): " << std::endl;
+            printAll(cout, retGeoms);
             cout << endl;
             ensure("not all expected geometries in the obtained set", 0);
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 1c71baf..c133809 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -1512,8 +1512,8 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
             std::vector<geom::Geometry*>* newgeoms = new std::vector<geom::Geometry*>;
             GeomPtr gRealRes(factory->createGeometryCollection(newgeoms));
Summary of changes:
 capi/geos_ts_c.cpp                                 | 114 +++++----------------
 doc/example.cpp                                    |   4 +-
 include/geos/geom/GeometryFactory.h                |   6 +-
 include/geos/operation/polygonize/Polygonizer.h    |   7 +-
 src/geom/GeometryFactory.cpp                       |   6 --
 src/operation/polygonize/BuildArea.cpp             |   8 +-
 src/operation/polygonize/Polygonizer.cpp           |  18 ++--
 src/operation/union/CoverageUnion.cpp              |   6 +-
 tests/unit/operation/polygonize/PolygonizeTest.cpp |  11 +-
 tests/xmltester/XMLTester.cpp                      |   4 +-
 10 files changed, 63 insertions(+), 121 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
