[geos-commits] [SCM] GEOS branch 3.7 updated. f249089b763ceb859e6b9b83ee28742262753b54
Wed Sep 4 15:14:17 PDT 2019
the project "GEOS".
The branch, 3.7 has been updated
       via  f249089b763ceb859e6b9b83ee28742262753b54 (commit)
      from  6f305213fd544d21a09d5c802d8ac82cef576687 (commit)
revisions in full, below.
commit f249089b763ceb859e6b9b83ee28742262753b54
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Sep 4 15:13:51 2019 -0700
    Sync up tests run by cmake and autotools so failures/passes on CI are more consistent
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index 3021f4b..29634d0 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -47,7 +47,7 @@ if(GEOS_ENABLE_TESTS)
   endif()
   set(XMLTESTS_DIR ${CMAKE_CURRENT_SOURCE_DIR}/tests)
-  set(SAVE_XMLTESTS
+  set(SAFE_XMLTESTS
     ${XMLTESTS_DIR}/testLeaksBig.xml
     ${XMLTESTS_DIR}/split.xml
     ${XMLTESTS_DIR}/hexwkb.xml
@@ -56,12 +56,29 @@ if(GEOS_ENABLE_TESTS)
     ${XMLTESTS_DIR}/TestIsValid.xml
     ${XMLTESTS_DIR}/robustness.xml
     ${XMLTESTS_DIR}/buffer.xml
-    ${XMLTESTS_DIR}/test.xml
     ${XMLTESTS_DIR}/singlesidedbuffer.xml
     ${XMLTESTS_DIR}/ticket/bug176.xml
     ${XMLTESTS_DIR}/ticket/bug188.xml
     ${XMLTESTS_DIR}/ticket/bug244.xml
     ${XMLTESTS_DIR}/ticket/bug275.xml
+    ${XMLTESTS_DIR}/ticket/bug350.xml
+    ${XMLTESTS_DIR}/ticket/bug356.xml
+    ${XMLTESTS_DIR}/ticket/bug358.xml
+    ${XMLTESTS_DIR}/ticket/bug360.xml
+    ${XMLTESTS_DIR}/ticket/bug366.xml
+    ${XMLTESTS_DIR}/ticket/bug392.xml
+    ${XMLTESTS_DIR}/ticket/bug398.xml
+    ${XMLTESTS_DIR}/ticket/bug434.xml
+    ${XMLTESTS_DIR}/ticket/bug459.xml
+    ${XMLTESTS_DIR}/ticket/bug527.xml
+    ${XMLTESTS_DIR}/ticket/bug569.xml
+    ${XMLTESTS_DIR}/ticket/bug582.xml
+    ${XMLTESTS_DIR}/ticket/bug586.xml
+    ${XMLTESTS_DIR}/ticket/bug599.xml
+    ${XMLTESTS_DIR}/ticket/bug605.xml
+    ${XMLTESTS_DIR}/ticket/bug615.xml
+    ${XMLTESTS_DIR}/ticket/bug716.xml
+    ${XMLTESTS_DIR}/ticket/bug837.xml
     ${XMLTESTS_DIR}/ticket/bug838.xml
     ${XMLTESTS_DIR}/general/TestBoundary.xml
     ${XMLTESTS_DIR}/general/TestBuffer.xml
@@ -69,6 +86,7 @@ if(GEOS_ENABLE_TESTS)
     ${XMLTESTS_DIR}/general/TestCentroid.xml
     ${XMLTESTS_DIR}/general/TestConvexHull.xml
     ${XMLTESTS_DIR}/general/TestConvexHull-big.xml
+    ${XMLTESTS_DIR}/general/TestDistance.xml
     ${XMLTESTS_DIR}/general/TestFunctionAAPrec.xml
     ${XMLTESTS_DIR}/general/TestFunctionAA.xml
     ${XMLTESTS_DIR}/general/TestFunctionLAPrec.xml
@@ -80,6 +98,9 @@ if(GEOS_ENABLE_TESTS)
     ${XMLTESTS_DIR}/general/TestFunctionPL.xml
     ${XMLTESTS_DIR}/general/TestFunctionPP.xml
     ${XMLTESTS_DIR}/general/TestInteriorPoint.xml
+    ${XMLTESTS_DIR}/general/TestPreparedPointPredicate.xml
+    ${XMLTESTS_DIR}/general/TestPreparedPolygonPredicate.xml
+    ${XMLTESTS_DIR}/general/TestPreparedPredicatesWithGeometryCollection.xml
     ${XMLTESTS_DIR}/general/TestRectanglePredicate.xml
     ${XMLTESTS_DIR}/general/TestRelateAA.xml
     ${XMLTESTS_DIR}/general/TestRelateLA.xml
@@ -90,11 +111,14 @@ if(GEOS_ENABLE_TESTS)
     ${XMLTESTS_DIR}/general/TestRelatePA.xml
     ${XMLTESTS_DIR}/general/TestRelatePP.xml
     ${XMLTESTS_DIR}/general/TestSimple.xml
+    ${XMLTESTS_DIR}/general/TestUnaryUnion.xml
+    ${XMLTESTS_DIR}/general/TestUnaryUnionFloating.xml
     ${XMLTESTS_DIR}/general/TestValid.xml
     ${XMLTESTS_DIR}/general/TestValid2.xml
     ${XMLTESTS_DIR}/general/TestValid2-big.xml
     ${XMLTESTS_DIR}/general/TestWithinDistance.xml
     ${XMLTESTS_DIR}/stmlf/stmlf-cases-20061020.xml
+    ${XMLTESTS_DIR}/stmlf/stmlf-cases-20061020-invalid-output.xml
     ${XMLTESTS_DIR}/stmlf/stmlf-cases-20070119.xml
     ${XMLTESTS_DIR}/robust/TestRobustOverlayFixed.xml
     ${XMLTESTS_DIR}/robust/TestRobustRelate.xml
@@ -106,9 +130,10 @@ if(GEOS_ENABLE_TESTS)
     ${XMLTESTS_DIR}/hole_from_shell.xml
     ${XMLTESTS_DIR}/hole_red.xml
     ${XMLTESTS_DIR}/safe/16595.xml
-    ${XMLTESTS_DIR}/safe/16596.xml)
+    ${XMLTESTS_DIR}/safe/16596.xml
+    ${XMLTESTS_DIR}/safe/TestBufferJagged.xml)
-  add_test(test_xmltester ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/test_xmltester ${SAVE_XMLTESTS})
+  add_test(test_xmltester ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/test_xmltester --test-valid-output ${SAFE_XMLTESTS})
   set(STATUS_RESULT "ON")
 endif()
Summary of changes:
 tests/xmltester/CMakeLists.txt | 33 +++++++++++++++++++++++++++++----
 1 file changed, 29 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
