[geos-commits] [SCM] GEOS branch master updated. 6a8fecd2ff9177adceff8e245d8d3dc7be9599f2
Fri Sep 20 10:46:01 PDT 2019
the project "GEOS".
       via  6a8fecd2ff9177adceff8e245d8d3dc7be9599f2 (commit)
      from  6b6abc3a1b8aafeac2380e9bec9dc6ea45edce22 (commit)
revisions in full, below.
commit 6a8fecd2ff9177adceff8e245d8d3dc7be9599f2
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Sep 20 10:45:52 2019 -0700
    Log the move of issue 488 xml test
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index 81e727f..74c9477 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -94,6 +94,7 @@ SAFE_XMLTESTS= \
 	$(srcdir)/tests/issue/issue-geos-398.xml \
 	$(srcdir)/tests/issue/issue-geos-434.xml \
 	$(srcdir)/tests/issue/issue-geos-459.xml \
+	$(srcdir)/tests/issue/issue-geos-488.xml \
 	$(srcdir)/tests/issue/issue-geos-527.xml \
 	$(srcdir)/tests/issue/issue-geos-569.xml \
 	$(srcdir)/tests/issue/issue-geos-582.xml \
@@ -118,7 +119,6 @@ INVALID_OUTPUT_XMLTESTS =
 FAILING_XMLTESTS = \
 	$(srcdir)/tests/failure/TestOverlay.xml \
-	$(srcdir)/tests/failure/issue-geos-488.xml \
 	$(srcdir)/tests/failure/issue-geos-344.xml \
 	$(srcdir)/tests/failure/robust-TestRobustRelateFloat.xml \
 	$(srcdir)/tests/failure/misc-TestBigNastyBuffer.xml \
Summary of changes:
 tests/xmltester/Makefile.am | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
