[geos-commits] [SCM] GEOS branch master updated. d48dbefd0079da341cc5fb5f27a652858622d256
Fri Sep 27 15:36:30 PDT 2019
the project "GEOS".
       via  d48dbefd0079da341cc5fb5f27a652858622d256 (commit)
      from  c1dcd2906e8bf1a189cae0a38acb3c8a5bab591d (commit)
revisions in full, below.
commit d48dbefd0079da341cc5fb5f27a652858622d256
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Sep 27 15:36:03 2019 -0700
    Bump to beta version number, update docs with new versioning file (yay)
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index eaf4f7b..6c1a477 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -27,18 +27,19 @@
     - Deleting interfaces / compatibility issues - bump CURRENT, others to zero
       [ THIS MUST BE CAREFULLY AVOIDED ]
-11. Increment release version:
-    - In configure.ac
-    - In include/geos/version.h.vc
-    - In capi/geos_c.h.in
-      - VERSION_PATCH for bugfixes/improvements (even breaking C++ API)
-      - VERSION_MINOR for NEW interfaces in the C lib
-      - VERSION_MAJOR for SUBSTANTIAL additions or C lib ABI break
-        [ THIS MUST BE CAREFULLY AVOIDED ]
-    - In main CMakeLists.txt main one
-       - On section: "# Set GEOS project"
-         - CHANGE the line: project(GEOS VERSION <mayor>.<minor>.<micro> LANGUAGES C CXX)
-         - CHANGE the line: SET(GEOS_PATCH_WORD "dev")
+11. Increment release versions in Version.txt
+      - GEOS_VERSION_PATCH
+      - GEOS_VERSION_MINOR
+      - GEOS_VERSION_MAJOR
+      - CAPI_INTERFACE_CURRENT
+      - CAPI_INTERFACE_REVISION
+      - CAPI_INTERFACE_AGE
+      Always increase the revision value.
+      Increase the current value whenever an interface has been added, removed or changed.
+      Increase the age value only if the changes made to the ABI are backward compatible.
 12. Update wiki page https://trac.osgeo.org/geos/ at Download section
     - Add latest release
diff --git a/Version.txt b/Version.txt
index c2f95bb..b626f31 100644
--- a/Version.txt
+++ b/Version.txt
@@ -5,9 +5,15 @@ GEOS_VERSION_MINOR=8
 GEOS_VERSION_PATCH=0
 # OPTIONS: "", "dev", "rc1" etc.
-GEOS_PATCH_WORD=dev
+GEOS_PATCH_WORD=beta1
 # GEOS CAPI Versions
+# Always increase the revision value.
+# Increase the current value whenever an interface has been
+# added, removed or changed.
+# Increase the age value only if the changes made to the ABI
+# are backward compatible.
 CAPI_INTERFACE_CURRENT=13
 CAPI_INTERFACE_REVISION=0
 CAPI_INTERFACE_AGE=12
Summary of changes:
 HOWTO_RELEASE | 25 +++++++++++++------------
 Version.txt   |  8 +++++++-
 2 files changed, 20 insertions(+), 13 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
