[geos-commits] [SCM] GEOS branch master updated. a5e8b64efc516c2592016235443dac166034fe7f
Mon Apr 20 08:12:21 PDT 2020
the project "GEOS".
       via  a5e8b64efc516c2592016235443dac166034fe7f (commit)
       via  e6f315d314593a200c5cfd43d40328454b66d8f5 (commit)
      from  feb35a0fd17ed5f5cfe35ef7bd89693e057a0493 (commit)
revisions in full, below.
commit a5e8b64efc516c2592016235443dac166034fe7f
Merge: e6f315d feb35a0
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Apr 20 08:12:14 2020 -0700
    Merge branch 'master' of https://git.osgeo.org/gitea/geos/geos
commit e6f315d314593a200c5cfd43d40328454b66d8f5
Date:   Mon Apr 20 08:11:57 2020 -0700
    Remove undefined behaviour in CPI, closes #1021
diff --git a/NEWS b/NEWS
index e8ccc23..7c07c32 100644
--- a/NEWS
+++ b/NEWS
@@ -13,6 +13,7 @@ Changes in 3.9.0
   - Testing on Rasberry Pi 32-bit (berrie) (#1017, Bruce Rindahl, Regina Obe)
   - Replace ttmath with JTS DD double-double implementation (Paul Ramsey)
   - Fix bug in DistanceOp for geometries with empty components (#1026, Paul Ramsey)
+  - Remove undefined behaviour in CAPI (#1021, Greg Troxel)
 Changes in 3.8.0
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 9c3e810..d46a0af 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -234,7 +234,7 @@ typedef struct GEOSContextHandle_HS {
     void
-    NOTICE_MESSAGE(string fmt, ...)
+    NOTICE_MESSAGE(const char *fmt, ...)
         if(nullptr == noticeMessageOld && nullptr == noticeMessageNew) {
             return;
@@ -242,7 +242,7 @@ typedef struct GEOSContextHandle_HS {
         va_list args;
         va_start(args, fmt);
-        int result = vsnprintf(msgBuffer, sizeof(msgBuffer) - 1, fmt.c_str(), args);
+        int result = vsnprintf(msgBuffer, sizeof(msgBuffer) - 1, fmt, args);
         va_end(args);
         if(result > 0) {
@@ -256,7 +256,7 @@ typedef struct GEOSContextHandle_HS {
     void
-    ERROR_MESSAGE(string fmt, ...)
+    ERROR_MESSAGE(const char *fmt, ...)
         if(nullptr == errorMessageOld && nullptr == errorMessageNew) {
             return;
@@ -264,7 +264,7 @@ typedef struct GEOSContextHandle_HS {
         va_list args;
         va_end(args);
         if(result > 0) {
Summary of changes:
 NEWS               | 1 +
 capi/geos_ts_c.cpp | 8 ++++----
 2 files changed, 5 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
