[geos-commits] [SCM] GEOS branch master updated. 9b5cdbfab048e177bb565bf5caf278a773fb36ab
Thu Apr 30 08:56:05 PDT 2020
the project "GEOS".
       via  9b5cdbfab048e177bb565bf5caf278a773fb36ab (commit)
      from  ebae359519ddb33ff9e7ccfc40d36a412a83ac56 (commit)
revisions in full, below.
commit 9b5cdbfab048e177bb565bf5caf278a773fb36ab
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Apr 30 08:55:39 2020 -0700
    Match up parameters names to doc names
diff --git a/include/geos/algorithm/construct/LargestEmptyCircle.h b/include/geos/algorithm/construct/LargestEmptyCircle.h
index fb8c8de..6bd9d2c 100644
--- a/include/geos/algorithm/construct/LargestEmptyCircle.h
+++ b/include/geos/algorithm/construct/LargestEmptyCircle.h
@@ -64,31 +64,31 @@ public:
     * Creates a new instance of a Largest Empty Circle construction.
-    * @param obstacles a geometry representing the obstacles (points and lines)
-    * @param tolerance the distance tolerance for computing the circle center point
+    * @param p_obstacles a geometry representing the obstacles (points and lines)
+    * @param p_tolerance the distance tolerance for computing the circle center point
-    LargestEmptyCircle(const geom::Geometry* polygonal, double tolerance);
+    LargestEmptyCircle(const geom::Geometry* p_obstacles, double p_tolerance);
     ~LargestEmptyCircle() = default;
     * Computes the center point of the Largest Empty Circle
     * `within a set of obstacles, up to a given tolerance distance.
-    * @param tolerance the distance tolerance for computing the center point
+    * @param p_tolerance the distance tolerance for computing the center point
     * @return the center point of the Largest Empty Circle
-    static std::unique_ptr<geom::Point> getCenter(const geom::Geometry* polygonal, double tolerance);
+    static std::unique_ptr<geom::Point> getCenter(const geom::Geometry* p_obstacles, double p_tolerance);
     * Computes a radius line of the Largest Empty Circle
     * within a set of obstacles, up to a given distance tolerance.
     * @return a line from the center of the circle to a point on the edge
-    static std::unique_ptr<geom::LineString> getRadiusLine(const geom::Geometry* polygonal, double tolerance);
+    static std::unique_ptr<geom::LineString> getRadiusLine(const geom::Geometry* p_obstacles, double p_tolerance);
     std::unique_ptr<geom::Point> getCenter();
     std::unique_ptr<geom::Point> getRadiusPoint();
@@ -119,7 +119,7 @@ private:
     * Their containing cells will be last in the priority queue
     * (but will still end up being tested since they may be refined).
-    * @param p the point to compute the distance for
+    * @param c the point to compute the distance for
     * @return the signed distance to the constraints (negative indicates outside the boundary)
     double distanceToConstraints(const geom::Coordinate& c);
diff --git a/src/algorithm/construct/LargestEmptyCircle.cpp b/src/algorithm/construct/LargestEmptyCircle.cpp
index 6506442..82ebfbe 100644
--- a/src/algorithm/construct/LargestEmptyCircle.cpp
+++ b/src/algorithm/construct/LargestEmptyCircle.cpp
@@ -64,17 +64,17 @@ LargestEmptyCircle::LargestEmptyCircle(const Geometry* p_obstacles, double p_tol
 /* public static */
 std::unique_ptr<Point>
-LargestEmptyCircle::getCenter(const Geometry* polygonal, double tolerance)
+LargestEmptyCircle::getCenter(const Geometry* p_obstacles, double p_tolerance)
-    LargestEmptyCircle lec(polygonal, tolerance);
+    LargestEmptyCircle lec(p_obstacles, p_tolerance);
     return lec.getCenter();
 /* public static */
 std::unique_ptr<LineString>
-LargestEmptyCircle::getRadiusLine(const Geometry* polygonal, double tolerance)
+LargestEmptyCircle::getRadiusLine(const Geometry* p_obstacles, double p_tolerance)
     return lec.getRadiusLine();
Summary of changes:
 .../geos/algorithm/construct/LargestEmptyCircle.h    | 20 ++++++++++----------
 src/algorithm/construct/LargestEmptyCircle.cpp       |  8 ++++----
 2 files changed, 14 insertions(+), 14 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
