[geos-commits] [SCM] GEOS branch master updated. 4f9c3d9f42a1c7eb920c3bc7c4270c60a4807bc8
Thu Feb 13 10:34:39 PST 2020
the project "GEOS".
       via  4f9c3d9f42a1c7eb920c3bc7c4270c60a4807bc8 (commit)
       via  86e943e609f0833d319fc9222908cad0306ab570 (commit)
      from  7e0d548fed76e75beb1c39b725f0b558d4a302e2 (commit)
revisions in full, below.
commit 4f9c3d9f42a1c7eb920c3bc7c4270c60a4807bc8
Merge: 7e0d548 86e943e
Author: Dan Baston <dbaston at gmail.com>
Date:   Thu Feb 13 13:34:24 2020 -0500
    Merge remote-tracking branch 'rouault/down_cast'
commit 86e943e609f0833d319fc9222908cad0306ab570
Author: Even Rouault <even.rouault at spatialys.com>
Date:   Thu Feb 13 16:51:36 2020 +0100
    Add a geos::detail::down_cast<To>(From*) function
    (Ported from what has been used since a few years in GDAL, which was
    added per https://trac.osgeo.org/gdal/ticket/6720)
    This function can be used to replace most patterns where a static_cast
    or dynamic_cast is done, and we are sure that the result is of the target
    type (except programming bugs)
    In particular, the following common pattern
    assert(dynamic_cast<Target*>(foo));
    Target* t = static_cast<Target*>(foo);
    can now been replaced equivalently by
    Target* t = detail::down_cast<Target*>(foo);
    The assertion is only done in GEOS_DEBUG mode by down_cast.
    This is even safer as it avoids the risk of potentially side effect,
    in the assert() as was found in RelateComputer.cpp that had
                assert(dynamic_cast<RelateNode*>(nodes.addNode(ei.coord)));
                RelateNode* n = static_cast<RelateNode*>(nodes.addNode(ei.coord));
diff --git a/include/geos/util.h b/include/geos/util.h
index 2af350f..40d51dd 100644
--- a/include/geos/util.h
+++ b/include/geos/util.h
@@ -32,6 +32,7 @@
 //#include <geos/util/math.h>
 #include <memory>
+#include <type_traits>
 // Private macros definition
@@ -81,8 +82,29 @@ typename _Unique_if<T>::_Known_bound
 make_unique(Args &&...) = delete;
 #endif
+/** Use detail::down_cast<Derived*>(pointer_to_base) as equivalent of
+ * static_cast<Derived*>(pointer_to_base) with safe checking in debug
+ * mode.
+ * Only works if no virtual inheritance is involved.
+ * @param f pointer to a base class
+ * @return pointer to a derived class
+template<typename To, typename From> inline To down_cast(From* f)
+    static_assert(
+        (std::is_base_of<From,
+                        typename std::remove_pointer<To>::type>::value),
+        "target type not derived from source type");
+#if GEOS_DEBUG
+    assert(f == nullptr || dynamic_cast<To>(f) != nullptr);
+#endif
+    return static_cast<To>(f);
+} // namespace detail
+} // namespace geos
 #endif // GEOS_UTIL_H
diff --git a/src/geomgraph/DirectedEdgeStar.cpp b/src/geomgraph/DirectedEdgeStar.cpp
index c0ff38d..323028b 100644
--- a/src/geomgraph/DirectedEdgeStar.cpp
+++ b/src/geomgraph/DirectedEdgeStar.cpp
@@ -28,6 +28,7 @@
 #include <geos/geomgraph/Quadrant.h>
 #include <geos/geom/Location.h>
 #include <geos/util/TopologyException.h>
+#include <geos/util.h>
 #include <cassert>
 #include <string>
@@ -48,8 +49,7 @@ void
 DirectedEdgeStar::insert(EdgeEnd* ee)
     assert(ee);
-    assert(dynamic_cast<DirectedEdge*>(ee));
-    DirectedEdge* de = static_cast<DirectedEdge*>(ee);
+    DirectedEdge* de = detail::down_cast<DirectedEdge*>(ee);
     insertEdgeEnd(de);
@@ -61,8 +61,7 @@ DirectedEdgeStar::getOutgoingDegree()
     EdgeEndStar::iterator endIt = end();
     for(EdgeEndStar::iterator it = begin(); it != endIt; ++it) {
         assert(*it);
-        assert(dynamic_cast<DirectedEdge*>(*it));
-        DirectedEdge* de = static_cast<DirectedEdge*>(*it);
+        DirectedEdge* de = detail::down_cast<DirectedEdge*>(*it);
         if(de->isInResult()) {
             ++degree;
@@ -78,8 +77,7 @@ DirectedEdgeStar::getOutgoingDegree(EdgeRing* er)
         assert(*it);
         if(de->getEdgeRing() == er) {
             ++degree;
@@ -97,8 +95,7 @@ DirectedEdgeStar::getRightmostEdge()
     assert(*it);
-    DirectedEdge* de0 = static_cast<DirectedEdge*>(*it);
+    DirectedEdge* de0 = detail::down_cast<DirectedEdge*>(*it);
     ++it;
     if(it == end()) {
         return de0;
@@ -108,8 +105,7 @@ DirectedEdgeStar::getRightmostEdge()
     --it;
     assert(*it);
-    DirectedEdge* deLast = static_cast<DirectedEdge*>(*it);
+    DirectedEdge* deLast = detail::down_cast<DirectedEdge*>(*it);
     assert(de0);
     int quad0 = de0->getQuadrant();
@@ -170,8 +166,7 @@ DirectedEdgeStar::mergeSymLabels()
         assert(*it);
         Label& deLabel = de->getLabel();
         DirectedEdge* deSym = de->getSym();
@@ -189,8 +184,8 @@ DirectedEdgeStar::updateLabelling(const Label& nodeLabel)
-        DirectedEdge* de = dynamic_cast<DirectedEdge*>(*it);
-        assert(de);
+        assert(*it);
         deLabel.setAllLocationsIfNull(0, nodeLabel.getLocation(0));
         deLabel.setAllLocationsIfNull(1, nodeLabel.getLocation(1));
@@ -208,8 +203,7 @@ DirectedEdgeStar::getResultAreaEdges()
         assert(*it);
         if(de->isInResult() || de->getSym()->isInResult()) {
             resultAreaEdgeList.push_back(de);
@@ -340,8 +334,7 @@ DirectedEdgeStar::linkAllDirectedEdges()
     EdgeEndStar::reverse_iterator rendIt = rend();
     for(EdgeEndStar::reverse_iterator it = rbeginIt; it != rendIt; ++it) {
         assert(*it);
-        DirectedEdge* nextOut = static_cast<DirectedEdge*>(*it);
+        DirectedEdge* nextOut = detail::down_cast<DirectedEdge*>(*it);
         DirectedEdge* nextIn = nextOut->getSym();
         assert(nextIn);
@@ -378,8 +371,7 @@ DirectedEdgeStar::findCoveredLineEdges()
         assert(*it);
         assert(nextIn);
@@ -409,8 +401,7 @@ DirectedEdgeStar::findCoveredLineEdges()
     Location currLoc = startLoc;
         assert(*it);
         assert(nextIn);
@@ -461,8 +452,7 @@ DirectedEdgeStar::computeDepths(EdgeEndStar::iterator startIt,
     int currDepth = startDepth;
     for(EdgeEndStar::iterator it = startIt; it != endIt; ++it) {
         assert(*it);
-        DirectedEdge* nextDe = static_cast<DirectedEdge*>(*it);
+        DirectedEdge* nextDe = detail::down_cast<DirectedEdge*>(*it);
         nextDe->setEdgeDepths(Position::RIGHT, currDepth);
         currDepth = nextDe->getDepth(Position::LEFT);
@@ -479,8 +469,7 @@ DirectedEdgeStar::print() const
         assert(*it);
         assert(de);
         out += "out ";
         out += de->print();
diff --git a/src/geomgraph/EdgeRing.cpp b/src/geomgraph/EdgeRing.cpp
index f99b661..2e4077a 100644
--- a/src/geomgraph/EdgeRing.cpp
+++ b/src/geomgraph/EdgeRing.cpp
@@ -243,8 +243,7 @@ EdgeRing::computeMaxNodeDegree()
     do {
         Node* node = de->getNode();
         EdgeEndStar* ees = node->getEdges();
-        assert(dynamic_cast<DirectedEdgeStar*>(ees));
-        DirectedEdgeStar* des = static_cast<DirectedEdgeStar*>(ees);
+        DirectedEdgeStar* des = detail::down_cast<DirectedEdgeStar*>(ees);
         int degree = des->getOutgoingDegree(this);
         if(degree > maxNodeDegree) {
             maxNodeDegree = degree;
diff --git a/src/geomgraph/Node.cpp b/src/geomgraph/Node.cpp
index fcd8a21..f1f6478 100644
--- a/src/geomgraph/Node.cpp
+++ b/src/geomgraph/Node.cpp
@@ -26,6 +26,7 @@
 #include <geos/geomgraph/DirectedEdge.h>
 #include <geos/util/IllegalArgumentException.h>
 #include <cmath>
 #include <string>
@@ -123,8 +124,7 @@ Node::isIncidentEdgeInResult() const
     EdgeEndStar::iterator endIt = edges->end();
     for(; it != endIt; ++it) {
         assert(*it);
         if(de->getEdge()->isInResult()) {
             return true;
diff --git a/src/geomgraph/PlanarGraph.cpp b/src/geomgraph/PlanarGraph.cpp
index 3ad84c7..fed2a4c 100644
--- a/src/geomgraph/PlanarGraph.cpp
+++ b/src/geomgraph/PlanarGraph.cpp
@@ -240,8 +240,7 @@ PlanarGraph::linkResultDirectedEdges()
         assert(ees);
         // this might throw an exception
         des->linkResultDirectedEdges();
@@ -268,8 +267,7 @@ PlanarGraph::linkAllDirectedEdges()
         assert(ees);
         // Unespected non-DirectedEdgeStar in node
         des->linkAllDirectedEdges();
diff --git a/src/noding/IntersectionAdder.cpp b/src/noding/IntersectionAdder.cpp
index 8bf3988..91b560b 100644
--- a/src/noding/IntersectionAdder.cpp
+++ b/src/noding/IntersectionAdder.cpp
@@ -21,6 +21,7 @@
 #include <geos/noding/NodedSegmentString.h>
 #include <geos/algorithm/LineIntersector.h>
 #include <geos/geom/Coordinate.h>
 using namespace geos::geom;
@@ -99,9 +100,8 @@ IntersectionAdder::processIntersections(
     if(! isTrivialIntersection(e0, segIndex0, e1, segIndex1)) {
         hasIntersectionVar = true;
-        NodedSegmentString* ee0 = dynamic_cast<NodedSegmentString*>(e0);
-        NodedSegmentString* ee1 = dynamic_cast<NodedSegmentString*>(e1);
-        assert(ee0 && ee1);
+        NodedSegmentString* ee0 = detail::down_cast<NodedSegmentString*>(e0);
+        NodedSegmentString* ee1 = detail::down_cast<NodedSegmentString*>(e1);
         ee0->addIntersections(&li, segIndex0, 0);
         ee1->addIntersections(&li, segIndex1, 1);
diff --git a/src/noding/IntersectionFinderAdder.cpp b/src/noding/IntersectionFinderAdder.cpp
index 3235119..7efa694 100644
--- a/src/noding/IntersectionFinderAdder.cpp
+++ b/src/noding/IntersectionFinderAdder.cpp
@@ -23,6 +23,7 @@
@@ -53,9 +54,8 @@ IntersectionFinderAdder::processIntersections(
                 interiorIntersections.push_back(li.getIntersection(intIndex));
diff --git a/src/noding/snapround/SimpleSnapRounder.cpp b/src/noding/snapround/SimpleSnapRounder.cpp
index 723aa90..fa6caca 100644
--- a/src/noding/snapround/SimpleSnapRounder.cpp
+++ b/src/noding/snapround/SimpleSnapRounder.cpp
@@ -26,6 +26,7 @@
 #include <geos/geom/CoordinateSequence.h>
 #include <vector>
 #include <exception>
@@ -116,7 +117,7 @@ SimpleSnapRounder::computeSnaps(const SegmentString::NonConstVect& segStrings,
     for(SegmentString::NonConstVect::const_iterator
             i = segStrings.begin(), iEnd = segStrings.end();
             i != iEnd; ++i) {
-        NodedSegmentString* ss = dynamic_cast<NodedSegmentString*>(*i);
+        NodedSegmentString* ss = detail::down_cast<NodedSegmentString*>(*i);
         computeSnaps(ss, snapPts);
@@ -171,13 +172,11 @@ SimpleSnapRounder::computeVertexSnaps(const SegmentString::NonConstVect& edges)
             i0 = edges.begin(), i0End = edges.end();
             i0 != i0End; ++i0) {
-        NodedSegmentString* edge0 = dynamic_cast<NodedSegmentString*>(*i0);
-        assert(edge0);
+        NodedSegmentString* edge0 = detail::down_cast<NodedSegmentString*>(*i0);
                 i1 = edges.begin(), i1End = edges.end();
                 i1 != i1End; ++i1) {
-            NodedSegmentString* edge1 = dynamic_cast<NodedSegmentString*>(*i1);
-            assert(edge1);
+            NodedSegmentString* edge1 = detail::down_cast<NodedSegmentString*>(*i1);
             computeVertexSnaps(edge0, edge1);
diff --git a/src/operation/buffer/BufferSubgraph.cpp b/src/operation/buffer/BufferSubgraph.cpp
index b2ca203..2602a39 100644
--- a/src/operation/buffer/BufferSubgraph.cpp
+++ b/src/operation/buffer/BufferSubgraph.cpp
@@ -27,6 +27,7 @@
 #include <geos/geomgraph/DirectedEdgeStar.h>
 #include <geos/geomgraph/EdgeEndStar.h>
 #include <geos/geomgraph/Position.h>
 #include <cassert>
 #include <vector>
@@ -103,8 +104,7 @@ BufferSubgraph::add(Node* node, vector<Node*>* nodeStack)
     EdgeEndStar::iterator it = ees->begin();
     EdgeEndStar::iterator endIt = ees->end();
         dirEdgeList.push_back(de);
         DirectedEdge* sym = de->getSym();
         Node* symNode = sym->getNode();
@@ -157,15 +157,13 @@ BufferSubgraph::computeNodeDepth(Node* n)
     // find a visited dirEdge to start at
     DirectedEdge* startEdge = nullptr;
-    assert(dynamic_cast<DirectedEdgeStar*>(n->getEdges()));
-    DirectedEdgeStar* ees = static_cast<DirectedEdgeStar*>(n->getEdges());
+    DirectedEdgeStar* ees = detail::down_cast<DirectedEdgeStar*>(n->getEdges());
         if(de->isVisited() || de->getSym()->isVisited()) {
             startEdge = de;
             break;
@@ -185,8 +183,7 @@ BufferSubgraph::computeNodeDepth(Node* n)
     // copy depths to sym edges
     for(it = ees->begin(); it != endIt; ++it) {
         de->setVisited(true);
         copySymDepths(de);
@@ -284,8 +281,7 @@ BufferSubgraph::computeDepths(DirectedEdge* startEdge)
             if(sym->isVisited()) {
                 continue;
diff --git a/src/operation/buffer/OffsetCurveSetBuilder.cpp b/src/operation/buffer/OffsetCurveSetBuilder.cpp
index d23c899..e2c3804 100644
--- a/src/operation/buffer/OffsetCurveSetBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveSetBuilder.cpp
@@ -39,6 +39,7 @@
 #include <geos/geomgraph/Label.h>
 #include <algorithm> // for min
 #include <cmath>
@@ -254,8 +255,7 @@ OffsetCurveSetBuilder::addPolygon(const Polygon* p)
     for(size_t i = 0, n = p->getNumInteriorRing(); i < n; ++i) {
         const LineString* hls = p->getInteriorRingN(i);
-        assert(dynamic_cast<const LinearRing*>(hls));
-        const LinearRing* hole = static_cast<const LinearRing*>(hls);
+        const LinearRing* hole = detail::down_cast<const LinearRing*>(hls);
         // optimization - don't bother computing buffer for this hole
         // if the hole would be completely covered
diff --git a/src/operation/buffer/RightmostEdgeFinder.cpp b/src/operation/buffer/RightmostEdgeFinder.cpp
index 02b4741..57765c3 100644
--- a/src/operation/buffer/RightmostEdgeFinder.cpp
+++ b/src/operation/buffer/RightmostEdgeFinder.cpp
@@ -25,6 +25,7 @@
 #include <geos/geomgraph/Node.h>
 #include <geos/geomgraph/Edge.h>
 #include <vector>
 #include <cassert>
@@ -120,8 +121,7 @@ RightmostEdgeFinder::findRightmostEdgeAtNode()
     Node* node = minDe->getNode();
     assert(node);
-    assert(dynamic_cast<DirectedEdgeStar*>(node->getEdges()));
-    DirectedEdgeStar* star = static_cast<DirectedEdgeStar*>(node->getEdges());
+    DirectedEdgeStar* star = detail::down_cast<DirectedEdgeStar*>(node->getEdges());
     // Warning! NULL could be returned if the star is empty!
     minDe = star->getRightmostEdge();
diff --git a/src/operation/linemerge/EdgeString.cpp b/src/operation/linemerge/EdgeString.cpp
index 8c7ad8b..4b152f4 100644
--- a/src/operation/linemerge/EdgeString.cpp
+++ b/src/operation/linemerge/EdgeString.cpp
@@ -26,6 +26,7 @@
 #include <geos/geom/CoordinateArraySequence.h>
 #include <geos/geom/LineString.h>
 #include <vector>
 #include <cassert>
@@ -73,8 +74,7 @@ EdgeString::getCoordinates()
                 reverseDirectedEdges++;
-            assert(dynamic_cast<LineMergeEdge*>(directedEdge->getEdge()));
-            LineMergeEdge* lme = static_cast<LineMergeEdge*>(directedEdge->getEdge());
+            LineMergeEdge* lme = detail::down_cast<LineMergeEdge*>(directedEdge->getEdge());
             coordinates->add(lme->getLine()->getCoordinatesRO(),
                              false,
diff --git a/src/operation/linemerge/LineMerger.cpp b/src/operation/linemerge/LineMerger.cpp
index ec680f3..af7c4ca 100644
--- a/src/operation/linemerge/LineMerger.cpp
+++ b/src/operation/linemerge/LineMerger.cpp
@@ -200,9 +200,8 @@ LineMerger::buildEdgeStringsStartingAt(Node* node)
     vector<planargraph::DirectedEdge*>& edges = node->getOutEdges()->getEdges();
     size_t size = edges.size();
     for(size_t i = 0; i < size; i++) {
-        assert(dynamic_cast<LineMergeDirectedEdge*>(edges[i]));
-        LineMergeDirectedEdge* directedEdge = \
-                                              static_cast<LineMergeDirectedEdge*>(edges[i]);
+        LineMergeDirectedEdge* directedEdge =
+                            detail::down_cast<LineMergeDirectedEdge*>(edges[i]);
         if(directedEdge->getEdge()->isMarked()) {
             continue;
diff --git a/src/operation/linemerge/LineSequencer.cpp b/src/operation/linemerge/LineSequencer.cpp
index f4e6edb..3739d7a 100644
--- a/src/operation/linemerge/LineSequencer.cpp
+++ b/src/operation/linemerge/LineSequencer.cpp
@@ -30,6 +30,7 @@
 #include <geos/planargraph/Subgraph.h>
 #include <geos/planargraph/algorithm/ConnectedSubgraphFinder.h>
 #include <geos/util/Assert.h>
 #include <cassert>
 #include <limits>
@@ -206,8 +207,7 @@ LineSequencer::buildSequencedGeometry(const Sequences& sequences)
         for(planargraph::DirectedEdge::NonConstList::iterator i2 = seq.begin(),
                 i2End = seq.end(); i2 != i2End; ++i2) {
             const planargraph::DirectedEdge* de = *i2;
-            assert(dynamic_cast<LineMergeEdge* >(de->getEdge()));
-            LineMergeEdge* e = static_cast<LineMergeEdge* >(de->getEdge());
+            LineMergeEdge* e = detail::down_cast<LineMergeEdge* >(de->getEdge());
             const LineString* line = e->getLine();
             // lineToAdd will be a *copy* of input things
@@ -218,8 +218,7 @@ LineSequencer::buildSequencedGeometry(const Sequences& sequences)
             else {
                 Geometry* lineClone = line->clone().release();
-                lineToAdd = dynamic_cast<LineString*>(lineClone);
-                assert(lineToAdd);
+                lineToAdd = detail::down_cast<LineString*>(lineClone);
             lines->push_back(lineToAdd);
diff --git a/src/operation/overlay/LineBuilder.cpp b/src/operation/overlay/LineBuilder.cpp
index 487577b..c3d64ef 100644
--- a/src/operation/overlay/LineBuilder.cpp
+++ b/src/operation/overlay/LineBuilder.cpp
@@ -25,6 +25,7 @@
 #include <map>
 #include <vector>
@@ -85,8 +86,7 @@ LineBuilder::findCoveredLineEdges()
     for(auto& entry : nodeMap) {
         Node* node = entry.second;
         //node.print(System.out);
-        DirectedEdgeStar* des = static_cast<DirectedEdgeStar*>(node->getEdges());
+        DirectedEdgeStar* des = detail::down_cast<DirectedEdgeStar*>(node->getEdges());
         des->findCoveredLineEdges();
         //((DirectedEdgeStar*)node->getEdges())->findCoveredLineEdges();
@@ -97,8 +97,7 @@ LineBuilder::findCoveredLineEdges()
     vector<EdgeEnd*>* ee = op->getGraph().getEdgeEnds();
     for(size_t i = 0, s = ee->size(); i < s; ++i) {
-        assert(dynamic_cast<DirectedEdge*>((*ee)[i]));
-        DirectedEdge* de = static_cast<DirectedEdge*>((*ee)[i]);
+        DirectedEdge* de = detail::down_cast<DirectedEdge*>((*ee)[i]);
         Edge* e = de->getEdge();
         if(de->isLineEdge() && !e->isCoveredSet()) {
             bool isCovered = op->isCoveredByA(de->getCoordinate());
@@ -112,8 +111,7 @@ LineBuilder::collectLines(OverlayOp::OpCode opCode)
         collectLineEdge(de, opCode, &lineEdgesList);
         collectBoundaryTouchEdge(de, opCode, &lineEdgesList);
diff --git a/src/operation/overlay/MaximalEdgeRing.cpp b/src/operation/overlay/MaximalEdgeRing.cpp
index f8f73f8..5f5e4c8 100644
--- a/src/operation/overlay/MaximalEdgeRing.cpp
+++ b/src/operation/overlay/MaximalEdgeRing.cpp
@@ -24,6 +24,7 @@
 #include <cassert>
 #include <vector>
@@ -81,8 +82,7 @@ MaximalEdgeRing::linkDirectedEdgesForMinimalEdgeRings()
         des->linkMinimalDirectedEdges(this);
diff --git a/src/operation/overlay/OverlayOp.cpp b/src/operation/overlay/OverlayOp.cpp
index df1e654..7959c7c 100644
--- a/src/operation/overlay/OverlayOp.cpp
+++ b/src/operation/overlay/OverlayOp.cpp
@@ -44,6 +44,7 @@
 #include <geos/util/Interrupt.h>
 #include <geos/geomgraph/EdgeNodingValidator.h>
 #include <cassert>
 #include <cmath>
@@ -319,8 +320,7 @@ OverlayOp::mergeSymLabels()
             it != itEnd; ++it) {
         Node* node = it->second;
-        static_cast<DirectedEdgeStar*>(ees)->mergeSymLabels();
+        detail::down_cast<DirectedEdgeStar*>(ees)->mergeSymLabels();
         //((DirectedEdgeStar*)node->getEdges())->mergeSymLabels();
 #if GEOS_DEBUG
         cerr << "     " << node->print() << endl;
@@ -349,8 +349,7 @@ OverlayOp::updateNodeLabelling()
         Label& lbl = des->getLabel();
         node->getLabel().merge(lbl);
 #if GEOS_DEBUG
@@ -383,8 +382,7 @@ OverlayOp::labelIncompleteNodes()
         // now update the labelling for the DirectedEdges incident on this node
         EdgeEndStar* ees = n->getEdges();
         des->updateLabelling(label);
         //((DirectedEdgeStar*)n->getEdges())->updateLabelling(label);
diff --git a/src/operation/overlay/PolygonBuilder.cpp b/src/operation/overlay/PolygonBuilder.cpp
index 90d12ca..0069edc 100644
--- a/src/operation/overlay/PolygonBuilder.cpp
+++ b/src/operation/overlay/PolygonBuilder.cpp
@@ -81,8 +81,7 @@ PolygonBuilder::add(PlanarGraph* graph)
     vector<DirectedEdge*> dirEdges(eeSize);
     for(size_t i = 0; i < eeSize; ++i) {
-        assert(dynamic_cast<DirectedEdge*>(ee[i]));
-        DirectedEdge* de = static_cast<DirectedEdge*>(ee[i]);
+        DirectedEdge* de = detail::down_cast<DirectedEdge*>(ee[i]);
         dirEdges[i] = de;
diff --git a/src/operation/polygonize/PolygonizeGraph.cpp b/src/operation/polygonize/PolygonizeGraph.cpp
index 3bafb0f..84354ba 100644
--- a/src/operation/polygonize/PolygonizeGraph.cpp
+++ b/src/operation/polygonize/PolygonizeGraph.cpp
@@ -27,6 +27,7 @@
 #include <geos/planargraph/DirectedEdge.h>
 #include <cassert>
 #include <vector>
@@ -62,7 +63,7 @@ PolygonizeGraph::getDegree(Node* node, long label)
     auto edges = node->getOutEdges()->getEdges();
     int degree = 0;
     for(const auto& de : edges) {
-        auto pde = dynamic_cast<PolygonizeDirectedEdge*>(de);
+        auto pde = detail::down_cast<PolygonizeDirectedEdge*>(de);
         if(pde->getLabel() == label) {
             ++degree;
@@ -235,7 +236,7 @@ PolygonizeGraph::getEdgeRings(std::vector<EdgeRing*>& edgeRingList)
     // find all edgerings
     for(DirectedEdge* de : dirEdges) {
         if(pde->isMarked()) {
             continue;
@@ -255,7 +256,7 @@ PolygonizeGraph::findLabeledEdgeRings(std::vector<DirectedEdge*>& dirEdges,
     // label the edge rings formed
     long currLabel = 1;
             continue;
@@ -291,20 +292,20 @@ PolygonizeGraph::deleteCutEdges(std::vector<const LineString*>& cutLines)
      * Delete them, and record them
         if(de->isMarked()) {
             continue;
-        auto sym = dynamic_cast<PolygonizeDirectedEdge*>(de->getSym());
+        auto sym = detail::down_cast<PolygonizeDirectedEdge*>(de->getSym());
         if(pde->getLabel() == sym->getLabel()) {
             de->setMarked(true);
             sym->setMarked(true);
             // save the line as a cut edge
-            auto e = dynamic_cast<PolygonizeEdge*>(de->getEdge());
+            auto e = detail::down_cast<PolygonizeEdge*>(de->getEdge());
             cutLines.push_back(e->getLine());
@@ -323,7 +324,7 @@ void
 PolygonizeGraph::label(std::vector<DirectedEdge*>& dirEdges, long label)
     for(auto& de : dirEdges) {
         pde->setLabel(label);
@@ -338,7 +339,7 @@ PolygonizeGraph::computeNextCWEdges(Node* node)
     // the edges are stored in CCW order around the star
     std::vector<DirectedEdge*>& pde = deStar->getEdges();
     for(DirectedEdge* de : pde) {
-        auto outDE = dynamic_cast<PolygonizeDirectedEdge*>(de);
+        auto outDE = detail::down_cast<PolygonizeDirectedEdge*>(de);
         if(outDE->isMarked()) {
             continue;
@@ -346,13 +347,13 @@ PolygonizeGraph::computeNextCWEdges(Node* node)
             startDE = outDE;
         if(prevDE != nullptr) {
-            auto sym = dynamic_cast<PolygonizeDirectedEdge*>(prevDE->getSym());
+            auto sym = detail::down_cast<PolygonizeDirectedEdge*>(prevDE->getSym());
             sym->setNext(outDE);
         prevDE = outDE;
         sym->setNext(startDE);
@@ -374,8 +375,8 @@ PolygonizeGraph::computeNextCCWEdges(Node* node, long label)
     std::vector<DirectedEdge*>& edges = deStar->getEdges();
     for(auto i = edges.size(); i > 0; --i) {
-        PolygonizeDirectedEdge* de = dynamic_cast<PolygonizeDirectedEdge*>(edges[i - 1]);
-        PolygonizeDirectedEdge* sym = dynamic_cast<PolygonizeDirectedEdge*>(de->getSym());
+        PolygonizeDirectedEdge* de = detail::down_cast<PolygonizeDirectedEdge*>(edges[i - 1]);
+        PolygonizeDirectedEdge* sym = detail::down_cast<PolygonizeDirectedEdge*>(de->getSym());
         PolygonizeDirectedEdge* outDE = nullptr;
         if(de->getLabel() == label) {
             outDE = de;
@@ -446,7 +447,7 @@ PolygonizeGraph::deleteDangles(std::vector<const LineString*>& dangleLines)
             // save the line as a dangle
             const LineString* ls = e->getLine();
             if(uniqueDangles.insert(ls).second) {
                 dangleLines.push_back(ls);
diff --git a/src/operation/relate/RelateComputer.cpp b/src/operation/relate/RelateComputer.cpp
index 9d1f136..2c8d149 100644
--- a/src/operation/relate/RelateComputer.cpp
+++ b/src/operation/relate/RelateComputer.cpp
@@ -37,6 +37,7 @@
 #include <geos/geomgraph/EdgeIntersection.h>
 #include <vector>
 #include <cassert>
@@ -339,8 +340,7 @@ RelateComputer::computeIntersectionNodes(int argIndex)
         Location eLoc = e->getLabel().getLocation(argIndex);
         EdgeIntersectionList& eiL = e->getEdgeIntersectionList();
         for(const EdgeIntersection & ei : eiL) {
-            assert(dynamic_cast<RelateNode*>(nodes.addNode(ei.coord)));
-            RelateNode* n = static_cast<RelateNode*>(nodes.addNode(ei.coord));
+            RelateNode* n = detail::down_cast<RelateNode*>(nodes.addNode(ei.coord));
             if(eLoc == Location::BOUNDARY) {
                 n->setLabelBoundary(argIndex);
@@ -405,8 +405,7 @@ RelateComputer::labelNodeEdges()
     auto& nMap = nodes.nodeMap;
     for(auto& entry : nMap) {
-        assert(dynamic_cast<RelateNode*>(entry.second));
-        RelateNode* node = static_cast<RelateNode*>(entry.second);
+        RelateNode* node = detail::down_cast<RelateNode*>(entry.second);
 #if GEOS_DEBUG
         std::cerr << "RelateComputer::labelNodeEdges: "
                   << "node edges: " << *(node->getEdges())
diff --git a/src/operation/relate/RelateNode.cpp b/src/operation/relate/RelateNode.cpp
index 5ea1b85..161dbde 100644
--- a/src/operation/relate/RelateNode.cpp
+++ b/src/operation/relate/RelateNode.cpp
@@ -22,6 +22,7 @@
 #include <geos/geom/IntersectionMatrix.h>
 #include <cassert>
@@ -49,8 +50,7 @@ RelateNode::computeIM(IntersectionMatrix& im)
 void
 RelateNode::updateIMFromEdges(IntersectionMatrix& im)
-    assert(dynamic_cast<EdgeEndBundleStar*>(edges));
-    EdgeEndBundleStar* eebs = static_cast<EdgeEndBundleStar*>(edges);
+    EdgeEndBundleStar* eebs = detail::down_cast<EdgeEndBundleStar*>(edges);
     eebs->updateIM(im);
diff --git a/src/operation/valid/ConnectedInteriorTester.cpp b/src/operation/valid/ConnectedInteriorTester.cpp
index a2770f3..6cda789 100644
--- a/src/operation/valid/ConnectedInteriorTester.cpp
+++ b/src/operation/valid/ConnectedInteriorTester.cpp
@@ -43,6 +43,7 @@
 #include <vector>
 #include <cassert>
@@ -52,8 +53,6 @@
 #define GEOS_DEBUG 0
 #endif
-//#define GEOS_CAST_PARANOIA 1
 #if GEOS_DEBUG
 #include <iostream>
 #endif
@@ -174,8 +173,7 @@ ConnectedInteriorTester::setInteriorEdgesInResult(PlanarGraph& graph)
     std::vector<EdgeEnd*>* ee = graph.getEdgeEnds();
     for(size_t i = 0, n = ee->size(); i < n; ++i) {
         // Unexpected non DirectedEdge in graphEdgeEnds
         if(de->getLabel().getLocation(0, Position::RIGHT) == Location::INTERIOR) {
             de->setInResult(true);
@@ -195,10 +193,7 @@ ConnectedInteriorTester::buildEdgeRings(std::vector<EdgeEnd*>* dirEdges,
     //std::vector<MinimalEdgeRing*> minEdgeRings;
     for(EdgeEnds::size_type i = 0, n = dirEdges->size(); i < n; ++i) {
-#ifdef GEOS_CAST_PARANOIA
-        assert(dynamic_cast<DirectedEdge*>((*dirEdges)[i]));
-#endif
-        DirectedEdge* de = static_cast<DirectedEdge*>((*dirEdges)[i]);
+        DirectedEdge* de = detail::down_cast<DirectedEdge*>((*dirEdges)[i]);
 #if GEOS_DEBUG
         cerr << "DirectedEdge " << i << ": " << de->print() << endl;
diff --git a/src/operation/valid/ConsistentAreaTester.cpp b/src/operation/valid/ConsistentAreaTester.cpp
index 325aae3..9ebefb2 100644
--- a/src/operation/valid/ConsistentAreaTester.cpp
+++ b/src/operation/valid/ConsistentAreaTester.cpp
@@ -28,6 +28,7 @@
 #include <geos/operation/relate/RelateNodeGraph.h>
 #include <geos/operation/relate/RelateNode.h>
 #include <geos/operation/relate/EdgeEndBundle.h>
 #include <memory> // unique_ptr
 #include <cassert>
@@ -100,13 +101,11 @@ ConsistentAreaTester::hasDuplicateRings()
     auto& nMap = nodeGraph.getNodeMap();
-        assert(dynamic_cast<relate::RelateNode*>(entry.second));
-        relate::RelateNode* node = static_cast<relate::RelateNode*>(entry.second);
+        relate::RelateNode* node = detail::down_cast<relate::RelateNode*>(entry.second);
         for(EdgeEndStar::iterator it = ees->begin(); it != endIt; ++it) {
-            assert(dynamic_cast<relate::EdgeEndBundle*>(*it));
-            relate::EdgeEndBundle* eeb = static_cast<relate::EdgeEndBundle*>(*it);
+            relate::EdgeEndBundle* eeb = detail::down_cast<relate::EdgeEndBundle*>(*it);
             if(eeb->getEdgeEnds().size() > 1) {
                 invalidPoint = eeb->getEdge()->getCoordinate(0);
                 return true;
Summary of changes:
 include/geos/util.h                             | 24 ++++++++++++++-
 src/geomgraph/DirectedEdgeStar.cpp              | 41 +++++++++----------------
 src/geomgraph/EdgeRing.cpp                      |  3 +-
 src/geomgraph/Node.cpp                          |  4 +--
 src/geomgraph/PlanarGraph.cpp                   |  6 ++--
 src/noding/IntersectionAdder.cpp                |  6 ++--
 src/noding/IntersectionFinderAdder.cpp          |  6 ++--
 src/noding/snapround/SimpleSnapRounder.cpp      |  9 +++---
 src/operation/buffer/BufferSubgraph.cpp         | 16 ++++------
 src/operation/buffer/OffsetCurveSetBuilder.cpp  |  4 +--
 src/operation/buffer/RightmostEdgeFinder.cpp    |  4 +--
 src/operation/linemerge/EdgeString.cpp          |  4 +--
 src/operation/linemerge/LineMerger.cpp          |  5 ++-
 src/operation/linemerge/LineSequencer.cpp       |  7 ++---
 src/operation/overlay/LineBuilder.cpp           | 10 +++---
 src/operation/overlay/MaximalEdgeRing.cpp       |  4 +--
 src/operation/overlay/OverlayOp.cpp             | 10 +++---
 src/operation/overlay/PolygonBuilder.cpp        |  3 +-
 src/operation/polygonize/PolygonizeGraph.cpp    | 27 ++++++++--------
 src/operation/relate/RelateComputer.cpp         |  7 ++---
 src/operation/relate/RelateNode.cpp             |  4 +--
 src/operation/valid/ConnectedInteriorTester.cpp | 11 ++-----
 src/operation/valid/ConsistentAreaTester.cpp    |  7 ++---
 23 files changed, 106 insertions(+), 116 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
