[geos-commits] [SCM] GEOS branch master updated. f5131cf06e2204de0176fae7fe2245548cad04ad
Thu Feb 20 07:46:56 PST 2020
the project "GEOS".
       via  f5131cf06e2204de0176fae7fe2245548cad04ad (commit)
       via  ec16c426eb355d01ef175e338213de6e5df291c3 (commit)
      from  40e21143e2309fc5ba524d535f02c9078b232ed9 (commit)
revisions in full, below.
commit f5131cf06e2204de0176fae7fe2245548cad04ad
Author: Raúl Marín <git at rmr.ninja>
Date:   Mon Dec 2 19:27:51 2019 +0100
    Autotools: Remove deprecated macros
diff --git a/configure.ac b/configure.ac
index 78dad89..7c54d75 100644
--- a/configure.ac
+++ b/configure.ac
@@ -191,51 +191,6 @@ AC_SUBST(AM_CXXFLAGS)
 AC_SUBST(AM_CFLAGS)
 dnl --------------------------------------------------------------------
-dnl - Look for finite and/or isfinite macros/functions
-dnl --------------------------------------------------------------------
-dnl These two tests need the math library or they won't link
-dnl on OpenBSD, even if the functions exist.
-save_LIBS=$LIBS
-LIBS="$LIBS -lm"
-AC_CACHE_CHECK([for finite], ac_cv_finite,
- [AC_TRY_LINK([#include <math.h>],
- [double x; int y; y = finite(x);],
- ac_cv_finite=yes,
- ac_cv_finite=no
-if test x"$ac_cv_finite" = x"yes"; then
-  AC_DEFINE(HAVE_FINITE, [1], [Has finite])
-fi
-AC_CACHE_CHECK([for isfinite], ac_cv_isfinite,
- [double x; int y; y = isfinite(x);],
- ac_cv_isfinite=yes,
- ac_cv_isfinite=no
-if test x"$ac_cv_isfinite" = x"yes"; then
-  AC_DEFINE(HAVE_ISFINITE, [1], [Has isfinite])
-fi
-dnl Test for presence of isnan function when using C++ and <cmath>
-dnl This is for a particular bug in OS/X where <cmath> drops the definition
-dnl of isnan().
-AC_LANG_PUSH([C++])
-AC_CACHE_CHECK([for isnan], ac_cv_isnan,
- [AC_TRY_LINK([#include <cmath>],
- [double x; int y; y = std::isnan(x);],
- ac_cv_isnan=yes,
- ac_cv_isnan=no
-if test x"$ac_cv_isnan" = x"yes"; then
-  AC_DEFINE(HAVE_ISNAN, [1], [Has isnan])
-fi
-AC_LANG_POP([C++])
 LIBS=$save_LIBS
commit ec16c426eb355d01ef175e338213de6e5df291c3
Date:   Mon Dec 2 19:25:28 2019 +0100
    Autotools: Add std=c++11 automatically to the builds
index 8677887..78dad89 100644
--- a/configure.ac
+++ b/configure.ac
@@ -152,8 +152,8 @@ fi
 dnl - Append default C++ and C flags
-AX_CXX_COMPILE_STDCXX_11([noext],[mandatory])
+AC_PROG_CXX
+AX_CXX_COMPILE_STDCXX(11, noext, mandatory)
 WARNFLAGS=""
 AC_LANG_PUSH([C++])
diff --git a/macros/ax_cxx_compile_stdcxx.m4 b/macros/ax_cxx_compile_stdcxx.m4
index 2c18e49..9e9eaed 100755
--- a/macros/ax_cxx_compile_stdcxx.m4
+++ b/macros/ax_cxx_compile_stdcxx.m4
@@ -1,5 +1,5 @@
-#   http://www.gnu.org/software/autoconf-archive/ax_cxx_compile_stdcxx.html
+#  https://www.gnu.org/software/autoconf-archive/ax_cxx_compile_stdcxx.html
 # SYNOPSIS
@@ -33,21 +33,22 @@
 #   Copyright (c) 2014, 2015 Google Inc.; contributed by Alexey Sokolov <sokolov at google.com>
 #   Copyright (c) 2015 Paul Norman <penorman at mac.com>
 #   Copyright (c) 2015 Moritz Klammler <moritz at klammler.eu>
+#   Copyright (c) 2016, 2018 Krzesimir Nowak <qdlacz at gmail.com>
 #   Copying and distribution of this file, with or without modification, are
 #   permitted in any medium without royalty provided the copyright notice
 #   and this notice are preserved.  This file is offered as-is, without any
 #   warranty.
-#serial 4
+#serial 10
 dnl  This macro is based on the code from the AX_CXX_COMPILE_STDCXX_11 macro
 dnl  (serial version number 13).
 AC_DEFUN([AX_CXX_COMPILE_STDCXX], [dnl
-  m4_if([$1], [11], [],
-        [$1], [14], [],
-        [$1], [17], [m4_fatal([support for C++17 not yet implemented in AX_CXX_COMPILE_STDCXX])],
+  m4_if([$1], [11], [ax_cxx_compile_alternatives="11 0x"],
+        [$1], [14], [ax_cxx_compile_alternatives="14 1y"],
+        [$1], [17], [ax_cxx_compile_alternatives="17 1z"],
         [m4_fatal([invalid first argument `$1' to AX_CXX_COMPILE_STDCXX])])dnl
   m4_if([$2], [], [],
         [$2], [ext], [],
@@ -59,18 +60,11 @@ AC_DEFUN([AX_CXX_COMPILE_STDCXX], [dnl
         [m4_fatal([invalid third argument `$3' to AX_CXX_COMPILE_STDCXX])])
   AC_LANG_PUSH([C++])dnl
   ac_success=no
-  AC_CACHE_CHECK(whether $CXX supports C++$1 features by default,
-  ax_cv_cxx_compile_cxx$1,
-  [AC_COMPILE_IFELSE([AC_LANG_SOURCE([_AX_CXX_COMPILE_STDCXX_testbody_$1])],
-    [ax_cv_cxx_compile_cxx$1=yes],
-    [ax_cv_cxx_compile_cxx$1=no])])
-  if test x$ax_cv_cxx_compile_cxx$1 = xyes; then
-    ac_success=yes
-  fi
   m4_if([$2], [noext], [], [dnl
   if test x$ac_success = xno; then
-    for switch in -std=gnu++$1 -std=gnu++0x; do
+    for alternative in ${ax_cxx_compile_alternatives}; do
+      switch="-std=gnu++${alternative}"
       cachevar=AS_TR_SH([ax_cv_cxx_compile_cxx$1_$switch])
       AC_CACHE_CHECK(whether $CXX supports C++$1 features with $switch,
                      $cachevar,
@@ -96,22 +90,27 @@ AC_DEFUN([AX_CXX_COMPILE_STDCXX], [dnl
     dnl HP's aCC needs +std=c++11 according to:
     dnl http://h21007.www2.hp.com/portal/download/files/unprot/aCxx/PDF_Release_Notes/769149-001.pdf
     dnl Cray's crayCC needs "-h std=c++11"
-    for switch in -std=c++$1 -std=c++0x +std=c++$1 "-h std=c++$1"; do
-      cachevar=AS_TR_SH([ax_cv_cxx_compile_cxx$1_$switch])
-      AC_CACHE_CHECK(whether $CXX supports C++$1 features with $switch,
-                     $cachevar,
-        [ac_save_CXX="$CXX"
-         CXX="$CXX $switch"
-         AC_COMPILE_IFELSE([AC_LANG_SOURCE([_AX_CXX_COMPILE_STDCXX_testbody_$1])],
-          [eval $cachevar=yes],
-          [eval $cachevar=no])
-         CXX="$ac_save_CXX"])
-      if eval test x\$$cachevar = xyes; then
-        if test -n "$CXXCPP" ; then
-          CXXCPP="$CXXCPP $switch"
+      for switch in -std=c++${alternative} +std=c++${alternative} "-h std=c++${alternative}"; do
+        cachevar=AS_TR_SH([ax_cv_cxx_compile_cxx$1_$switch])
+        AC_CACHE_CHECK(whether $CXX supports C++$1 features with $switch,
+                       $cachevar,
+          [ac_save_CXX="$CXX"
+           CXX="$CXX $switch"
+           AC_COMPILE_IFELSE([AC_LANG_SOURCE([_AX_CXX_COMPILE_STDCXX_testbody_$1])],
+            [eval $cachevar=yes],
+            [eval $cachevar=no])
+           CXX="$ac_save_CXX"])
+        if eval test x\$$cachevar = xyes; then
+          if test -n "$CXXCPP" ; then
+            CXXCPP="$CXXCPP $switch"
+          fi
+          ac_success=yes
+          break
         fi
-        ac_success=yes
+      done
+      if test x$ac_success = xyes; then
         break
       fi
     done
@@ -148,6 +147,11 @@ m4_define([_AX_CXX_COMPILE_STDCXX_testbody_14],
   _AX_CXX_COMPILE_STDCXX_testbody_new_in_14
+m4_define([_AX_CXX_COMPILE_STDCXX_testbody_17],
+  _AX_CXX_COMPILE_STDCXX_testbody_new_in_11
+  _AX_CXX_COMPILE_STDCXX_testbody_new_in_14
+  _AX_CXX_COMPILE_STDCXX_testbody_new_in_17
 dnl  Tests for new features in C++11
@@ -518,7 +522,7 @@ namespace cxx14
-  namespace test_digit_seperators
+  namespace test_digit_separators
     constexpr auto ten_million = 100'000'000;
@@ -560,3 +564,385 @@ namespace cxx14
 #endif  // __cplusplus >= 201402L
+dnl  Tests for new features in C++17
+m4_define([_AX_CXX_COMPILE_STDCXX_testbody_new_in_17], [[
+// If the compiler admits that it is not ready for C++17, why torture it?
+// Hopefully, this will speed up the test.
+#ifndef __cplusplus
+#error "This is not a C++ compiler"
+#elif __cplusplus < 201703L
+#error "This is not a C++17 compiler"
+#else
+#include <initializer_list>
+#include <utility>
+#include <type_traits>
+namespace cxx17
+  namespace test_constexpr_lambdas
+    constexpr int foo = [](){return 42;}();
+  namespace test::nested_namespace::definitions
+  namespace test_fold_expression
+    template<typename... Args>
+    int multiply(Args... args)
+      return (args * ... * 1);
+    bool all(Args... args)
+      return (args && ...);
+  namespace test_extended_static_assert
+    static_assert (true);
+  namespace test_auto_brace_init_list
+    auto foo = {5};
+    auto bar {5};
+    static_assert(std::is_same<std::initializer_list<int>, decltype(foo)>::value);
+    static_assert(std::is_same<int, decltype(bar)>::value);
+  namespace test_typename_in_template_template_parameter
+    template<template<typename> typename X> struct D;
+  namespace test_fallthrough_nodiscard_maybe_unused_attributes
+    int f1()
+      return 42;
+    [[nodiscard]] int f2()
+      [[maybe_unused]] auto unused = f1();
+      switch (f1())
+      case 17:
+        f1();
+        [[fallthrough]];
+      case 42:
+        f1();
+      return f1();
+  namespace test_extended_aggregate_initialization
+    struct base1
+      int b1, b2 = 42;
+    struct base2
+      base2() {
+        b3 = 42;
+      int b3;
+    struct derived : base1, base2
+        int d;
+    derived d1 {{1, 2}, {}, 4};  // full initialization
+    derived d2 {{}, {}, 4};      // value-initialized bases
+  namespace test_general_range_based_for_loop
+    struct iter
+      int i;
+      int& operator* ()
+        return i;
+      const int& operator* () const
+        return i;
+      iter& operator++()
+        ++i;
+        return *this;
+    struct sentinel
+      int i;
+    bool operator== (const iter& i, const sentinel& s)
+      return i.i == s.i;
+    bool operator!= (const iter& i, const sentinel& s)
+      return !(i == s);
+    struct range
+      iter begin() const
+        return {0};
+      sentinel end() const
+        return {5};
+    void f()
+      range r {};
+      for (auto i : r)
+        [[maybe_unused]] auto v = i;
+  namespace test_lambda_capture_asterisk_this_by_value
+    struct t
+      int i;
+      int foo()
+        return [*this]()
+          return i;
+  namespace test_enum_class_construction
+    enum class byte : unsigned char
+    byte foo {42};
+  namespace test_constexpr_if
+    template <bool cond>
+    int f ()
+      if constexpr(cond)
+        return 13;
+      else
+        return 42;
+  namespace test_selection_statement_with_initializer
+    int f()
+      return 13;
+    int f2()
+      if (auto i = f(); i > 0)
+        return 3;
+      switch (auto i = f(); i + 4)
+      case 17:
+        return 2;
+      default:
+        return 1;
+  namespace test_template_argument_deduction_for_class_templates
+    template <typename T1, typename T2>
+    struct pair
+      pair (T1 p1, T2 p2)
+        : m1 {p1},
+          m2 {p2}
+      T1 m1;
+      T2 m2;
+    void f()
+      [[maybe_unused]] auto p = pair{13, 42u};
+  namespace test_non_type_auto_template_parameters
+    template <auto n>
+    struct B
+    B<5> b1;
+    B<'a'> b2;
+  namespace test_structured_bindings
+    int arr[2] = { 1, 2 };
+    std::pair<int, int> pr = { 1, 2 };
+    auto f1() -> int(&)[2]
+      return arr;
+    auto f2() -> std::pair<int, int>&
+      return pr;
+    struct S
+      int x1 : 2;
+      volatile double y1;
+    S f3()
+      return {};
+    auto [ x1, y1 ] = f1();
+    auto& [ xr1, yr1 ] = f1();
+    auto [ x2, y2 ] = f2();
+    auto& [ xr2, yr2 ] = f2();
+    const auto [ x3, y3 ] = f3();
+  namespace test_exception_spec_type_system
+    struct Good {};
+    struct Bad {};
+    void g1() noexcept;
+    void g2();
+    template<typename T>
+    Bad
+    f(T*, T*);
+    template<typename T1, typename T2>
+    Good
+    f(T1*, T2*);
+    static_assert (std::is_same_v<Good, decltype(f(g1, g2))>);
+  namespace test_inline_variables
+    template<class T> void f(T)
+    template<class T> inline T g(T)
+      return T{};
+    template<> inline void f<>(int)
+    template<> int g<>(int)
+      return 5;
+}  // namespace cxx17
+#endif  // __cplusplus < 201703L
diff --git a/tools/ci/script_autotools_scanbuild.sh b/tools/ci/script_autotools_scanbuild.sh
index 3cbb8bb..1216cb7 100755
--- a/tools/ci/script_autotools_scanbuild.sh
+++ b/tools/ci/script_autotools_scanbuild.sh
@@ -21,5 +21,5 @@ fi
 cd ${TRAVIS_BUILD_DIR}
 ./autogen.sh
 cd -
-${TRAVIS_BUILD_DIR}/configure CC=clang CXX=clang++ CXXFLAGS="-std=c++11"
+${TRAVIS_BUILD_DIR}/configure CC=clang CXX=clang++
 scan-build --status-bugs make -j2
Summary of changes:
 configure.ac                           |  49 +---
 macros/ax_cxx_compile_stdcxx.m4        | 446 ++++++++++++++++++++++++++++++---
 tools/ci/script_autotools_scanbuild.sh |   2 +-
 3 files changed, 419 insertions(+), 78 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
