[geos-commits] [SCM] GEOS branch master updated. 099e74b3127348e1f8544ab279b609e2fdc6cc74
Thu May 7 12:08:13 PDT 2020
the project "GEOS".
       via  099e74b3127348e1f8544ab279b609e2fdc6cc74 (commit)
      from  a57d337ca05c1089f7935d3548e18e8ed85e19d6 (commit)
revisions in full, below.
commit 099e74b3127348e1f8544ab279b609e2fdc6cc74
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu May 7 08:58:26 2020 -0700
    Add boundary argument to CAPI for LargestEmptyCircle
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 8e4547d..363d8bf 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -464,9 +464,9 @@ extern "C" {
     Geometry*
-    GEOSLargestEmptyCircle(const Geometry* g, double tolerance)
+    GEOSLargestEmptyCircle(const Geometry* g, const Geometry* boundary, double tolerance)
-        return GEOSLargestEmptyCircle_r(handle, g, tolerance);
+        return GEOSLargestEmptyCircle_r(handle, g, boundary, tolerance);
     Geometry*
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index e411f79..ccccbc1 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -562,7 +562,7 @@ extern GEOSGeometry GEOS_DLL *GEOSMinimumRotatedRectangle_r(GEOSContextHandle_t
                                                const GEOSGeometry* g);
 extern GEOSGeometry GEOS_DLL *GEOSMaximumInscribedCircle_r(GEOSContextHandle_t handle, const GEOSGeometry* g, double tolerance);
-extern GEOSGeometry GEOS_DLL *GEOSLargestEmptyCircle_r(GEOSContextHandle_t handle, const GEOSGeometry* g, double tolerance);
+extern GEOSGeometry GEOS_DLL *GEOSLargestEmptyCircle_r(GEOSContextHandle_t handle, const GEOSGeometry* g, const GEOSGeometry* boundary, double tolerance);
 /* Returns a LINESTRING geometry which represents the minimum diameter of the geometry.
  * The minimum diameter is defined to be the width of the smallest band that
@@ -1632,7 +1632,7 @@ extern GEOSGeometry GEOS_DLL *GEOSMaximumInscribedCircle(const GEOSGeometry* g,
  * Returns a two-point linestring, with one point at the center of the inscribed circle and the other
  * on the boundary of the inscribed circle.
-extern GEOSGeometry GEOS_DLL *GEOSLargestEmptyCircle(const GEOSGeometry* g, double tolerance);
+extern GEOSGeometry GEOS_DLL *GEOSLargestEmptyCircle(const GEOSGeometry* g, const GEOSGeometry* boundary, double tolerance);
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index a4b2692..519da23 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1172,10 +1172,10 @@ extern "C" {
     Geometry*
-    GEOSLargestEmptyCircle_r(GEOSContextHandle_t extHandle, const Geometry* g, double tolerance)
+    GEOSLargestEmptyCircle_r(GEOSContextHandle_t extHandle, const Geometry* g, const GEOSGeometry* boundary, double tolerance)
         return execute(extHandle, [&]() {
-            geos::algorithm::construct::LargestEmptyCircle lec(g, tolerance);
+            geos::algorithm::construct::LargestEmptyCircle lec(g, boundary, tolerance);
             auto g3 = lec.getRadiusLine();
             g3->setSRID(g->getSRID());
             return g3.release();
diff --git a/include/geos/algorithm/construct/LargestEmptyCircle.h b/include/geos/algorithm/construct/LargestEmptyCircle.h
index 6bd9d2c..84eed26 100644
--- a/include/geos/algorithm/construct/LargestEmptyCircle.h
+++ b/include/geos/algorithm/construct/LargestEmptyCircle.h
@@ -68,6 +68,7 @@ public:
     * @param p_tolerance the distance tolerance for computing the circle center point
     LargestEmptyCircle(const geom::Geometry* p_obstacles, double p_tolerance);
+    LargestEmptyCircle(const geom::Geometry* p_obstacles, const geom::Geometry* p_boundary, double p_tolerance);
     ~LargestEmptyCircle() = default;
diff --git a/src/algorithm/construct/LargestEmptyCircle.cpp b/src/algorithm/construct/LargestEmptyCircle.cpp
index 82ebfbe..2cdd47f 100644
--- a/src/algorithm/construct/LargestEmptyCircle.cpp
+++ b/src/algorithm/construct/LargestEmptyCircle.cpp
@@ -43,16 +43,35 @@ namespace construct { // geos.algorithm.construct
 LargestEmptyCircle::LargestEmptyCircle(const Geometry* p_obstacles, double p_tolerance)
+    : LargestEmptyCircle(p_obstacles, nullptr, p_tolerance)
+LargestEmptyCircle::LargestEmptyCircle(const Geometry* p_obstacles, const Geometry* p_boundary, double p_tolerance)
     : tolerance(p_tolerance)
     , obstacles(p_obstacles)
     , factory(p_obstacles->getFactory())
-    , boundary(p_obstacles->convexHull())
     , obstacleDistance(p_obstacles)
     , done(false)
-    if (p_obstacles->isEmpty()) {
+    if (!p_boundary)
+        boundary = p_obstacles->convexHull();
+    else
+        boundary = p_boundary->clone();
+    if (obstacles->isEmpty()) {
+        throw util::IllegalArgumentException("Empty obstacles geometry is not supported");
+    if (boundary->isEmpty()) {
+    if (!boundary->covers(obstacles)) {
+        throw util::IllegalArgumentException("Boundary geometry does not cover obstacles");
     // if boundary does not enclose an area cannot create a ptLocator
     if (boundary->getDimension() >= 2) {
@@ -61,7 +80,6 @@ LargestEmptyCircle::LargestEmptyCircle(const Geometry* p_obstacles, double p_tol
 /* public static */
 std::unique_ptr<Point>
 LargestEmptyCircle::getCenter(const Geometry* p_obstacles, double p_tolerance)
diff --git a/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp b/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp
index 210f9e8..341c1f1 100644
--- a/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp
+++ b/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp
@@ -93,7 +93,7 @@ void object::test<2>
     geom1_ = GEOSGeomFromWKT("MULTIPOINT ((100 100), (100 200), (200 200), (200 100))");
     ensure(nullptr != geom1_);
-    geom2_ = GEOSLargestEmptyCircle(geom1_, 0.001);
+    geom2_ = GEOSLargestEmptyCircle(geom1_, nullptr, 0.001);
     ensure(nullptr != geom2_);
     wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
Summary of changes:
 capi/geos_c.cpp                                    |  4 ++--
 capi/geos_c.h.in                                   |  4 ++--
 capi/geos_ts_c.cpp                                 |  4 ++--
 .../geos/algorithm/construct/LargestEmptyCircle.h  |  1 +
 src/algorithm/construct/LargestEmptyCircle.cpp     | 24 +++++++++++++++++++---
 tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp |  2 +-
 6 files changed, 29 insertions(+), 10 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
