[geos-commits] [SCM] GEOS branch master updated. 76d7586ea53b2f9796bd4257d1d997fe05f11703
Thu Nov 5 01:38:07 PST 2020
the project "GEOS".
       via  76d7586ea53b2f9796bd4257d1d997fe05f11703 (commit)
      from  6841d68152f296ce3007af5b4789f2d9b25f0f25 (commit)
revisions in full, below.
commit 76d7586ea53b2f9796bd4257d1d997fe05f11703
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Nov 4 14:28:47 2020 -0800
    Remove no-op code from QESubdiv::remove
diff --git a/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h b/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
index e3b5c88..f5852f9 100644
--- a/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
+++ b/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
@@ -93,6 +93,10 @@ public:
                                  const QuadEdge* triEdge[3]);
 private:
+     * Use a deque to ensure QuadEdge pointers are stable.
+     * Note that it is NOT safe to erase entries from the deque.
     std::deque<QuadEdgeQuartet> quadEdges;
     std::array<QuadEdge*, 3> startingEdges;
     double tolerance;
diff --git a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
index 14c07fa..bc0a019 100644
--- a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
+++ b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
@@ -128,17 +128,10 @@ QuadEdgeSubdivision::remove(QuadEdge& e)
     QuadEdge::splice(e, e.oPrev());
     QuadEdge::splice(e.sym(), e.sym().oPrev());
-    // this is inefficient but this should be called infrequently
-    // check base edge against both edge and sym, since either may be removed
-    // rot edges do not need to be tested because they are not removed
-    quadEdges.erase(
-            std::remove_if(quadEdges.begin(), quadEdges.end(),
-                           [e](QuadEdgeQuartet& es) {
-                               return &es.base() == &e || &es.base() == &e.sym(); }),
-            quadEdges.end());
-    //mark these edges as removed
-    e.remove();
+    // because QuadEdge pointers must be stable, do not remove edge from quadedges container
+    // This is fine since they are detached from the subdivision
+    e.remove();
 QuadEdge*
Summary of changes:
 include/geos/triangulate/quadedge/QuadEdgeSubdivision.h |  4 ++++
 src/triangulate/quadedge/QuadEdgeSubdivision.cpp        | 13 +++----------
 2 files changed, 7 insertions(+), 10 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
