[geos-commits] [SCM] GEOS branch master updated. d6d4e12ff8142e008d88302ebcc84b6372807cdd
git at osgeo.org
git at osgeo.org
Sun Nov 22 20:06:44 PST 2020
the project "GEOS".
via d6d4e12ff8142e008d88302ebcc84b6372807cdd (commit)
from cb2a1dae659825759037e7e81ad16d726e61a3dc (commit)
revisions in full, below.
commit d6d4e12ff8142e008d88302ebcc84b6372807cdd
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Sun Nov 22 20:04:53 2020 -0800
Add nearestNeighbor() to the SimpleSTRtree implementation as well as
isWithinDistance(). Refactor classes a little to put all the
distance related calculations and classes in SimpleSTRdistance instead of in the
tree class, for a cleaner tree. Add some tests to the unit test,
but only enough to check that it turns over and returns minimally
sensible results.
diff --git a/include/geos/index/strtree/Makefile.am b/include/geos/index/strtree/Makefile.am
index 2f9191e..204059d 100644
--- a/include/geos/index/strtree/Makefile.am
+++ b/include/geos/index/strtree/Makefile.am
@@ -20,4 +20,5 @@ geos_HEADERS = \
SIRtree.h \
STRtree.h \
SimpleSTRtree.h \
- SimpleSTRnode.h
+ SimpleSTRnode.h \
+ SimpleSTRdistance.h
diff --git a/include/geos/index/strtree/SimpleSTRdistance.h b/include/geos/index/strtree/SimpleSTRdistance.h
new file mode 100644
index 0000000..3024f57
--- /dev/null
+++ b/include/geos/index/strtree/SimpleSTRdistance.h
@@ -0,0 +1,166 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2020 Paul Ramsey
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#pragma once
+#include <cassert>
+#include <cstddef>
+#include <geos/export.h>
+#include <geos/geom/Envelope.h>
+#include <geos/index/strtree/SimpleSTRtree.h>
+#include <geos/index/strtree/SimpleSTRnode.h>
+#include <vector>
+#include <queue>
+#ifdef _MSC_VER
+#pragma warning(push)
+#pragma warning(disable: 4251) // warning C4251: needs to have dll-interface to be used by clients of class
+#endif
+namespace geos {
+namespace index { // geos::index
+namespace strtree { // geos::index::strtree
+class GEOS_DLL SimpleSTRpair {
+private:
+ SimpleSTRnode* node1;
+ SimpleSTRnode* node2;
+ ItemDistance* itemDistance;
+ double m_distance;
+ /** \brief
+ * Computes the distance between the {@link SimpleSTRnode}s in this pair.
+ * The nodes are either composites or leaves.
+ * If either is composite, the distance is computed as the minimum distance
+ * between the bounds.
+ * If both are leaves, the distance is computed by
+ * ItemDistance::distance(const void* item1, const void* item2).
+ * @return the distance between the items
+ double distance();
+public:
+ SimpleSTRpair(SimpleSTRnode* p_node1, SimpleSTRnode* p_node2, ItemDistance* p_itemDistance)
+ : node1(p_node1)
+ , node2(p_node2)
+ , itemDistance(p_itemDistance)
+ m_distance = distance();
+ SimpleSTRnode* getNode(int i) const;
+ /** \brief
+ * Gets the minimum possible distance between the SimpleSTRnode in this pair.
+ * If the members are both items, this will be the
+ * exact distance between them.
+ * Otherwise, this distance will be a lower bound on
+ * the distances between the items in the members.
+ * @return the exact or lower bound distance for this pair
+ double getDistance() const;
+ * Tests if both elements of the pair are leaf nodes
+ * @return true if both pair elements are leaf nodes
+ bool isLeaves() const;
+ /** \brief
+ * Computes the maximum distance between any
+ * two items in the pair of nodes.
+ * @return the maximum distance between items in the pair
+ double maximumDistance();
+ friend std::ostream& operator<<(std::ostream& os, SimpleSTRpair& pair);
+class GEOS_DLL SimpleSTRdistance {
+public:
+ struct STRpairQueueCompare {
+ bool
+ operator()(const SimpleSTRpair* a, const SimpleSTRpair* b)
+ return a->getDistance() > b->getDistance();
+ typedef std::priority_queue<SimpleSTRpair*,
+ std::vector<SimpleSTRpair*>,
+ STRpairQueueCompare> STRpairQueue;
+ /* Initialize class */
+ SimpleSTRdistance(SimpleSTRnode* root1, SimpleSTRnode* root2, ItemDistance* p_itemDistance);
+ /* Turn over the calculation */
+ std::pair<const void*, const void*> nearestNeighbour();
+ bool isWithinDistance(double maxDistance);
+private:
+ std::deque<SimpleSTRpair> pairStore;
+ SimpleSTRpair* initPair;
+ /* Utility method to store allocated pairs */
+ SimpleSTRpair* createPair(SimpleSTRnode* p_node1, SimpleSTRnode* p_node2, ItemDistance* p_itemDistance);
+ std::pair<const void*, const void*> nearestNeighbour(SimpleSTRpair* p_initPair);
+ std::pair<const void*, const void*> nearestNeighbour(SimpleSTRpair* p_initPair, double maxDistance);
+ bool isWithinDistance(SimpleSTRpair* p_initPair, double maxDistance);
+ void expandToQueue(SimpleSTRpair* pair, STRpairQueue&, double minDistance);
+ void expand(SimpleSTRnode* nodeComposite, SimpleSTRnode* nodeOther,
+ bool isFlipped, STRpairQueue& priQ, double minDistance);
+} // namespace geos::index::strtree
+#ifdef _MSC_VER
+#pragma warning(pop)
+#endif
diff --git a/include/geos/index/strtree/SimpleSTRnode.h b/include/geos/index/strtree/SimpleSTRnode.h
index 1826382..b5ea81e 100644
--- a/include/geos/index/strtree/SimpleSTRnode.h
+++ b/include/geos/index/strtree/SimpleSTRnode.h
@@ -15,9 +15,9 @@
#pragma once
#include <cassert>
-#include <cstddef>
+#include <geos/index/strtree/ItemBoundable.h>
#include <vector>
@@ -34,12 +34,12 @@ namespace strtree { // geos::index::strtree
* A node of the STR tree.
-class GEOS_DLL SimpleSTRnode {
+class GEOS_DLL SimpleSTRnode : public ItemBoundable {
private:
- void *item;
std::vector<SimpleSTRnode*> childNodes;
+ void *item;
geom::Envelope bounds;
std::size_t level;
@@ -50,13 +50,15 @@ public:
* Constructs an AbstractNode at the given level in the tree
- SimpleSTRnode(std::size_t newLevel, const geom::Envelope *itemEnv, void* item, size_t capacity = 10)
- : item(item)
+ SimpleSTRnode(std::size_t newLevel, const geom::Envelope *p_env, void* p_item, size_t capacity = 10)
+ : ItemBoundable(p_env, p_item)
+ , item(p_item)
+ , bounds()
, level(newLevel)
childNodes.reserve(capacity);
- if (itemEnv) {
- bounds = *itemEnv;
+ if (p_env) {
+ bounds = *p_env;
@@ -65,7 +67,7 @@ public:
: SimpleSTRnode(newLevel, nullptr, nullptr)
- void toString(std::ostream& os, int level) const;
+ void toString(std::ostream& os, int indentLevel) const;
const std::vector<SimpleSTRnode*>&
getChildNodes() const
@@ -80,13 +82,17 @@ public:
* Returns a representation of space that encloses this Node
- const geom::Envelope& getBounds() {
+ const geom::Envelope& getEnvelope() {
if(bounds.isNull()) {
computeBounds();
return bounds;
+ const void* getBounds() const {
+ return &bounds;
* Returns 0 if this node is a leaf, 1 if a parent of a leaf, and so on; the
* root node will have the highest level
@@ -114,6 +120,16 @@ public:
return item != nullptr;
+ bool isComposite() const
+ return ! isLeaf();
+ double area()
+ return getEnvelope().getArea();
diff --git a/include/geos/index/strtree/SimpleSTRtree.h b/include/geos/index/strtree/SimpleSTRtree.h
index 3477ab0..baf79a4 100644
--- a/include/geos/index/strtree/SimpleSTRtree.h
+++ b/include/geos/index/strtree/SimpleSTRtree.h
@@ -20,6 +20,8 @@
#include <vector>
+#include <utility>
#ifdef _MSC_VER
@@ -33,8 +35,12 @@ namespace geom {
class Geometry;
class Envelope;
+namespace index {
+class ItemDistance;
namespace geos {
@@ -62,14 +68,14 @@ class GEOS_DLL SimpleSTRtree: public SpatialIndex {
private:
/* Members */
- std::deque<SimpleSTRnode> storedNodes;
+ std::deque<SimpleSTRnode> nodesQue;
std::vector<SimpleSTRnode*> nodes;
std::size_t nodeCapacity;
SimpleSTRnode* root;
bool built;
- * Allocate node in storedNodes std::deque for memory locality,
+ * Allocate node in nodesQue std::deque for memory locality,
* return reference to node.
SimpleSTRnode* createNode(int newLevel, const geom::Envelope* itemEnv, void* item);
@@ -125,7 +131,8 @@ public:
return built;
- SimpleSTRnode* getRoot() const {
+ SimpleSTRnode* getRoot() {
+ build();
return root;
@@ -142,6 +149,22 @@ public:
friend std::ostream& operator<<(std::ostream& os, const SimpleSTRtree& tree);
+ /* Nearest neighbor searches, public API */
+ /* Internal nearest node to node */
+ std::pair<const void*, const void*> nearestNeighbour(ItemDistance* itemDist);
+ /* Nearest to another geometry/item */
+ const void* nearestNeighbour(const geom::Envelope* env, const void* item, ItemDistance* itemDist);
+ /* Nearest to another tree */
+ std::pair<const void*, const void*> nearestNeighbour(SimpleSTRtree& tree, ItemDistance* itemDist);
+ /* Radius test */
+ bool isWithinDistance(SimpleSTRtree& tree, ItemDistance* itemDist, double maxDistance);
diff --git a/src/index/strtree/Makefile.am b/src/index/strtree/Makefile.am
index 4f3d773..335b673 100644
--- a/src/index/strtree/Makefile.am
+++ b/src/index/strtree/Makefile.am
@@ -14,6 +14,7 @@ libindexstrtree_la_SOURCES = \
SIRtree.cpp \
STRtree.cpp \
SimpleSTRtree.cpp \
- SimpleSTRnode.cpp
+ SimpleSTRnode.cpp \
+ SimpleSTRdistance.cpp
libindexstrtree_la_LIBADD =
diff --git a/src/index/strtree/SimpleSTRdistance.cpp b/src/index/strtree/SimpleSTRdistance.cpp
index 0000000..d1e3316
--- /dev/null
+++ b/src/index/strtree/SimpleSTRdistance.cpp
@@ -0,0 +1,328 @@
+#include <geos/index/strtree/SimpleSTRdistance.h>
+#include <geos/index/strtree/ItemDistance.h>
+#include <geos/index/strtree/EnvelopeUtil.h>
+#include <geos/util/GEOSException.h>
+#include <geos/util/IllegalArgumentException.h>
+#include <iostream>
+using namespace geos::geom;
+namespace geos {
+namespace index { // geos.index
+namespace strtree { // geos.index.strtree
+SimpleSTRdistance::SimpleSTRdistance(SimpleSTRnode* root1,
+ SimpleSTRnode* root2, ItemDistance* p_itemDistance)
+ : initPair(createPair(root1, root2, p_itemDistance))
+SimpleSTRpair*
+SimpleSTRdistance::createPair(SimpleSTRnode* p_node1, SimpleSTRnode* p_node2,
+ ItemDistance* p_itemDistance)
+ pairStore.emplace_back(p_node1, p_node2, p_itemDistance);
+ SimpleSTRpair& pair = pairStore.back();
+ return &pair;
+/*public*/
+std::pair<const void*, const void*>
+SimpleSTRdistance::nearestNeighbour()
+ return nearestNeighbour(initPair);
+/*private*/
+SimpleSTRdistance::nearestNeighbour(SimpleSTRpair* p_initPair)
+ return nearestNeighbour(p_initPair, std::numeric_limits<double>::infinity());
+/*private*/
+SimpleSTRdistance::nearestNeighbour(SimpleSTRpair* p_initPair, double maxDistance)
+ double distanceLowerBound = maxDistance;
+ SimpleSTRpair* minPair = nullptr;
+ STRpairQueue priQ;
+ priQ.push(p_initPair);
+ while(!priQ.empty() && distanceLowerBound > 0.0) {
+ SimpleSTRpair* pair = priQ.top();
+ double currentDistance = pair->getDistance();
+ // std::cout << *pair << std::endl;
+ * If the distance for the first node in the queue
+ * is >= the current minimum distance, all other nodes
+ * in the queue must also have a greater distance.
+ * So the current minDistance must be the true minimum,
+ * and we are done.
+ if(minPair && currentDistance >= distanceLowerBound) {
+ break;
+ priQ.pop();
+ * If the pair members are leaves
+ * then their distance is the exact lower bound.
+ * Update the distanceLowerBound to reflect this
+ * (which must be smaller, due to the test
+ * immediately prior to this).
+ if(pair->isLeaves()) {
+ distanceLowerBound = currentDistance;
+ minPair = pair;
+ else {
+ * Otherwise, expand one side of the pair,
+ * (the choice of which side to expand is heuristically determined)
+ * and insert the new expanded pairs into the queue
+ expandToQueue(pair, priQ, distanceLowerBound);
+ /* Free any remaining node pairs in the queue */
+ while(!priQ.empty()) {
+ priQ.pop();
+ if(!minPair) {
+ throw util::GEOSException("Error computing nearest neighbor");
+ const void* item0 = minPair->getNode(0)->getItem();
+ const void* item1 = minPair->getNode(1)->getItem();
+ return std::pair<const void*, const void*>(item0, item1);
+void
+SimpleSTRdistance::expandToQueue(SimpleSTRpair* pair, STRpairQueue& priQ, double minDistance)
+ SimpleSTRnode* node1 = pair->getNode(0);
+ SimpleSTRnode* node2 = pair->getNode(1);
+ bool isComp1 = node1->isComposite();
+ bool isComp2 = node2->isComposite();
+ * HEURISTIC: If both boundable are composite,
+ * choose the one with largest area to expand.
+ * Otherwise, simply expand whichever is composite.
+ if (isComp1 && isComp2) {
+ if (node1->area() > node2->area()) {
+ expand(node1, node2, false, priQ, minDistance);
+ return;
+ else {
+ expand(node2, node1, true, priQ, minDistance);
+ return;
+ else if (isComp1) {
+ return;
+ else if (isComp2) {
+ return;
+ throw util::IllegalArgumentException("neither boundable is composite");
+void
+SimpleSTRdistance::expand(SimpleSTRnode* nodeComposite, SimpleSTRnode* nodeOther,
+ auto children = nodeComposite->getChildNodes();
+ for (auto* child: children) {
+ SimpleSTRpair* sp = nullptr;
+ if (isFlipped) {
+ sp = createPair(nodeOther, child, itemDistance);
+ else {
+ sp = createPair(child, nodeOther, itemDistance);
+ // only add to queue if this pair might contain the closest points
+ // MD - it's actually faster to construct the object rather than called distance(child, nodeOther)!
+ if (sp->getDistance() < minDistance) {
+ priQ.push(sp);
+/* public */
+bool
+SimpleSTRdistance::isWithinDistance(double maxDistance)
+ return isWithinDistance(initPair, maxDistance);
+/* private */
+bool
+SimpleSTRdistance::isWithinDistance(SimpleSTRpair* p_initPair, double maxDistance)
+ double distanceUpperBound = std::numeric_limits<double>::infinity();
+ // initialize search queue
+ while (! priQ.empty()) {
+ // pop head of queue and expand one side of pair
+ double pairDistance = pair->getDistance();
+ * If the distance for the first pair in the queue
+ * is > maxDistance, all other pairs
+ * in the queue must have a greater distance as well.
+ * So can conclude no items are within the distance
+ * and terminate with result = false
+ if (pairDistance > maxDistance)
+ return false;
+ priQ.pop();
+ * If the maximum distance between the nodes
+ * is less than the maxDistance,
+ * than all items in the nodes must be
+ * closer than the max distance.
+ * Then can terminate with result = true.
+ * NOTE: using Envelope MinMaxDistance
+ * would provide a tighter bound,
+ * but not much performance improvement has been observed
+ if (pair->maximumDistance() <= maxDistance)
+ return true;
+ * If the pair items are leaves
+ * then their actual distance is an upper bound.
+ * Update the distanceUpperBound to reflect this
+ if (pair->isLeaves()) {
+ // assert: currentDistance < minimumDistanceFound
+ distanceUpperBound = pairDistance;
+ * If the items are closer than maxDistance
+ * can terminate with result = true.
+ if (distanceUpperBound <= maxDistance)
+ return true;
+ else {
+ * and insert the expanded pairs into the queue.
+ * The choice of which side to expand is determined heuristically.
+ expandToQueue(pair, priQ, distanceUpperBound);
+ return false;
+SimpleSTRnode*
+SimpleSTRpair::getNode(int i) const
+ if (i == 0) {
+ return node1;
+ return node2;
+/* private */
+double
+SimpleSTRpair::distance()
+ // if items, compute exact distance
+ if (isLeaves()) {
+ return itemDistance->distance(node1, node2);
+ // otherwise compute distance between bounds of nodes
+ const geom::Envelope& e1 = node1->getEnvelope();
+ const geom::Envelope& e2 = node2->getEnvelope();
+ return e1.distance(e2);
+double
+SimpleSTRpair::getDistance() const
+ return m_distance;
+bool
+SimpleSTRpair::isLeaves() const
+ return node1->isLeaf() && node2->isLeaf();
+double
+SimpleSTRpair::maximumDistance()
+ return EnvelopeUtil::maximumDistance(&(node1->getEnvelope()), &(node2->getEnvelope()));
+/*public static*/
+std::ostream&
+operator<<(std::ostream& os, SimpleSTRpair& pair)
+ const geom::Envelope& e1 = pair.getNode(0)->getEnvelope();
+ const geom::Envelope& e2 = pair.getNode(1)->getEnvelope();
+ double distance = pair.getDistance();
+ os << e1 << " " << e2 << " " << distance;
+ return os;
+} // namespace geos.index.strtree
diff --git a/src/index/strtree/SimpleSTRnode.cpp b/src/index/strtree/SimpleSTRnode.cpp
index 6f3671c..047dafc 100644
--- a/src/index/strtree/SimpleSTRnode.cpp
+++ b/src/index/strtree/SimpleSTRnode.cpp
@@ -3,18 +3,13 @@
- * Copyright (C) 2006 Refractions Research Inc.
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
- * Last port: index/strtree/STRtree.java rev. 1.11
@@ -32,21 +27,20 @@ void
SimpleSTRnode::computeBounds()
for (auto* node: childNodes) {
- bounds.expandToInclude(node->getBounds());
+ bounds.expandToInclude(node->getEnvelope());
/*public*/
void
-SimpleSTRnode::toString(std::ostream& os, int level) const
+SimpleSTRnode::toString(std::ostream& os, int indentLevel) const
- for (int i = 0; i < level; i++) {
+ for (int i = 0; i < indentLevel; i++) {
os << " ";
os << bounds << std::endl;
- node->toString(os, level+1);
+ node->toString(os, indentLevel+1);
diff --git a/src/index/strtree/SimpleSTRtree.cpp b/src/index/strtree/SimpleSTRtree.cpp
index 8f800a8..8103a15 100644
--- a/src/index/strtree/SimpleSTRtree.cpp
+++ b/src/index/strtree/SimpleSTRtree.cpp
@@ -3,21 +3,17 @@
#include <geos/index/ItemVisitor.h>
#include <geos/geom/Geometry.h>
@@ -40,9 +36,9 @@ namespace strtree { // geos.index.strtree
SimpleSTRnode*
SimpleSTRtree::createNode(int newLevel, const geom::Envelope* itemEnv, void* item)
- storedNodes.emplace_back(newLevel, itemEnv, item, nodeCapacity);
- SimpleSTRnode* node = &(storedNodes.back());
- return node;
+ nodesQue.emplace_back(newLevel, itemEnv, item, nodeCapacity);
+ SimpleSTRnode& node = nodesQue.back();
+ return &node;
/* private */
@@ -74,8 +70,8 @@ SimpleSTRtree::sortNodesY(std::vector<SimpleSTRnode*>& nodeList)
struct {
bool operator()(SimpleSTRnode* a, SimpleSTRnode* b) const
- const geom::Envelope& ea = a->getBounds();
- const geom::Envelope& eb = b->getBounds();
+ const geom::Envelope& ea = a->getEnvelope();
+ const geom::Envelope& eb = b->getEnvelope();
double ya = (ea.getMinY() + ea.getMaxY()) / 2.0;
double yb = (eb.getMinY() + eb.getMaxY()) / 2.0;
return ya < yb;
@@ -92,8 +88,8 @@ SimpleSTRtree::sortNodesX(std::vector<SimpleSTRnode*>& nodeList)
struct {
double xa = (ea.getMinX() + ea.getMaxX()) / 2.0;
double xb = (eb.getMinX() + eb.getMaxX()) / 2.0;
return xa < xb;
@@ -202,7 +198,7 @@ SimpleSTRtree::query(const geom::Envelope* searchEnv, ItemVisitor& visitor)
return;
- if(root->getBounds().intersects(searchEnv)) {
+ if(root->getEnvelope().intersects(searchEnv)) {
query(searchEnv, root, visitor);
@@ -214,7 +210,7 @@ SimpleSTRtree::query(const geom::Envelope* searchEnv,
for(auto* childNode: node->getChildNodes()) {
- if(!childNode->getBounds().intersects(searchEnv)) {
+ if(!childNode->getEnvelope().intersects(searchEnv)) {
continue;
@@ -239,7 +235,7 @@ SimpleSTRtree::query(const geom::Envelope* searchEnv, std::vector<void*>& matche
return;
query(searchEnv, root, matches);
@@ -253,7 +249,7 @@ SimpleSTRtree::query(const geom::Envelope* searchEnv,
continue;
@@ -276,7 +272,7 @@ SimpleSTRtree::remove(const geom::Envelope* itemEnv, void* item)
/*public static*/
std::ostream&
-operator<<(std::ostream& os, const SimpleSTRtree& tree)
+operator<<(std::ostream& os, SimpleSTRtree& tree)
os << "nodeCapacity: " << tree.getNodeCapacity() << std::endl;
@@ -289,6 +285,45 @@ operator<<(std::ostream& os, const SimpleSTRtree& tree)
return os;
+/*public*/
+SimpleSTRtree::nearestNeighbour(ItemDistance* itemDist)
+ SimpleSTRdistance strDist(this->getRoot(), this->getRoot(), itemDist);
+ return strDist.nearestNeighbour();
+/*public*/
+const void*
+SimpleSTRtree::nearestNeighbour(const geom::Envelope* p_env, const void* p_item, ItemDistance* itemDist)
+ std::unique_ptr<SimpleSTRnode> ssn(new SimpleSTRnode(0, p_env, (void*)p_item));
+ SimpleSTRdistance strDist(getRoot(), ssn.get(), itemDist);
+ std::pair<const void*, const void*> result = strDist.nearestNeighbour();
+ return result.first;
+/*public*/
+SimpleSTRtree::nearestNeighbour(SimpleSTRtree& tree, ItemDistance* itemDist)
+ SimpleSTRdistance strDist(this->getRoot(), tree.getRoot(), itemDist);
+/*public*/
+bool
+SimpleSTRtree::isWithinDistance(SimpleSTRtree& tree, ItemDistance* itemDist, double maxDistance)
+ return strDist.isWithinDistance(maxDistance);
diff --git a/tests/unit/index/strtree/SimpleSTRtreeTest.cpp b/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
index 698f5ab..7fa2869 100644
--- a/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
+++ b/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
@@ -1,9 +1,12 @@
#include <tut/tut.hpp>
// geos
-#include <geos/index/strtree/SimpleSTRtree.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/Point.h>
+#include <geos/index/strtree/GeometryItemDistance.h>
+#include <geos/index/ItemVisitor.h>
using namespace geos;
@@ -32,19 +35,81 @@ void object::test<1>
for (int i = 0; i < gridSize; ++i) {
for (int j = 0; j < gridSize; ++j) {
geom::Coordinate c((double)i, (double)j);
- geom::Point *pt = gf->createPoint(c);
+ geom::Point* pt = gf->createPoint(c);
geoms.emplace_back(pt);
t.insert(pt);
+ // std::cout << t << std::endl;
geom::Envelope qe(-0.5, 1.5, -0.5, 1.5);
std::vector<void*> matches;
t.query(&qe, matches);
- std::cout << matches.size() << std::endl;
+ // std::cout << matches.size() << std::endl;
ensure(matches.size() == 4);
- // std::cout << t << std::endl;
+ class SimpleTestVisitor: public index::ItemVisitor {
+ public:
+ std::size_t count;
+ SimpleTestVisitor()
+ : count(0)
+ void
+ visitItem(void* item) override
+ count++;
+ // geom::Point* pt = static_cast<geom::Point*>(item);
+ // std::cout << pt << std::endl;
+ SimpleTestVisitor vis;
+ t.query(&qe, vis);
+ ensure(vis.count == 4);
+template<>
+template<>
+void object::test<2>
+ const int gridSize = 10;
+ index::strtree::SimpleSTRtree t1(10);
+ index::strtree::SimpleSTRtree t2(10);
+ std::vector<std::unique_ptr<geom::Geometry>> geoms;
+ auto gf = geom::GeometryFactory::create();
+ for (int i = 0; i < gridSize; ++i) {
+ for (int j = 0; j < gridSize; ++j) {
+ geom::Coordinate c1((double)i, (double)j);
+ geom::Coordinate c2((double)(i+gridSize+1), (double)(j+gridSize+1));
+ geom::Point *pt1 = gf->createPoint(c1);
+ geom::Point *pt2 = gf->createPoint(c2);
+ geoms.emplace_back(pt1);
+ geoms.emplace_back(pt2);
+ t1.insert(pt1);
+ t2.insert(pt2);
+ std::pair<const void*, const void*> rslt;
+ index::strtree::GeometryItemDistance gi;
+ rslt = t1.nearestNeighbour(t2, &gi);
+ const geom::Point* g1 = static_cast<const geom::Point*>(rslt.first);
+ const geom::Point* g2 = static_cast<const geom::Point*>(rslt.second);
+ // std::cout << *g1 << std::endl;
+ // std::cout << *g2 << std::endl;
+ ensure_equals(g1->getX(), 9.0);
+ ensure_equals(g1->getY(), 9.0);
+ ensure_equals(g2->getX(), 11.0);
+ ensure_equals(g2->getY(), 11.0);
Summary of changes:
include/geos/index/strtree/Makefile.am | 3 +-
include/geos/index/strtree/SimpleSTRdistance.h | 166 +++++++++++++
include/geos/index/strtree/SimpleSTRnode.h | 34 ++-
include/geos/index/strtree/SimpleSTRtree.h | 31 ++-
src/index/strtree/Makefile.am | 3 +-
src/index/strtree/SimpleSTRdistance.cpp | 328 +++++++++++++++++++++++++
src/index/strtree/SimpleSTRnode.cpp | 16 +-
src/index/strtree/SimpleSTRtree.cpp | 71 ++++--
tests/unit/index/strtree/SimpleSTRtreeTest.cpp | 73 +++++-
9 files changed, 677 insertions(+), 48 deletions(-)
create mode 100644 include/geos/index/strtree/SimpleSTRdistance.h
create mode 100644 src/index/strtree/SimpleSTRdistance.cpp
hooks/post-receive
More information about the geos-commits
