[geos-commits] [SCM] GEOS branch master updated. e26560f7000baf5715ac3905f9395a5a5f2fa2c4
    git at osgeo.org
    git at osgeo.org
    Sat Nov 28 16:32:00 PST 2020
the project "GEOS".
       via  e26560f7000baf5715ac3905f9395a5a5f2fa2c4 (commit)
      from  ad0122541f85886cf9eb9dd65d8246e0144f7ffa (commit)
revisions in full, below.
commit e26560f7000baf5715ac3905f9395a5a5f2fa2c4
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Sat Nov 28 16:31:50 2020 -0800
    Clean-ups that hopefully will make python downstream happier
diff --git a/include/geos/index/strtree/SimpleSTRnode.h b/include/geos/index/strtree/SimpleSTRnode.h
index 1782189..9d24e25 100644
--- a/include/geos/index/strtree/SimpleSTRnode.h
+++ b/include/geos/index/strtree/SimpleSTRnode.h
@@ -114,7 +114,7 @@ public:
     bool isLeaf() const override
-        return childNodes.size() == 0;
+        return level == 0;
     bool isComposite() const
diff --git a/include/geos/index/strtree/SimpleSTRtree.h b/include/geos/index/strtree/SimpleSTRtree.h
index c01bd5e..5cd41b1 100644
--- a/include/geos/index/strtree/SimpleSTRtree.h
+++ b/include/geos/index/strtree/SimpleSTRtree.h
@@ -71,7 +71,6 @@ private:
     std::deque<SimpleSTRnode> nodesQue;
     std::vector<SimpleSTRnode*> nodes;
     std::size_t nodeCapacity;
-    SimpleSTRnode* root;
     bool built;
@@ -111,6 +110,9 @@ private:
 public:
+    /* Member */
+    SimpleSTRnode* root;
      * Constructs an STRtree with the given maximum number of child nodes that
      * a node may have
@@ -126,7 +128,10 @@ public:
     std::size_t getNumLeafNodes() const {
-        return root->getNumLeafNodes();
+        if (!root)
+            return 0;
+        else
+            return root->getNumLeafNodes();
diff --git a/src/index/strtree/SimpleSTRnode.cpp b/src/index/strtree/SimpleSTRnode.cpp
index 36299f7..ae09494 100644
--- a/src/index/strtree/SimpleSTRnode.cpp
+++ b/src/index/strtree/SimpleSTRnode.cpp
@@ -31,7 +31,7 @@ SimpleSTRnode::toString(std::ostream& os, int indentLevel) const
     for (int i = 0; i < indentLevel; i++) {
         os << "  ";
-    os << bounds << std::endl;
+    os << bounds << " [" << level << "]" << std::endl;
     for (auto* node: childNodes) {
         node->toString(os, indentLevel+1);
diff --git a/src/index/strtree/SimpleSTRtree.cpp b/src/index/strtree/SimpleSTRtree.cpp
index 9d60adc..ca63b2d 100644
--- a/src/index/strtree/SimpleSTRtree.cpp
+++ b/src/index/strtree/SimpleSTRtree.cpp
@@ -181,7 +181,7 @@ SimpleSTRtree::build()
         root = nullptr;
     else {
-        std::vector<SimpleSTRnode*> nodeTree = createHigherLevels(nodes, -1);
+        std::vector<SimpleSTRnode*> nodeTree = createHigherLevels(nodes, 0);
         assert(nodeTree.size()==1);
         root = nodeTree[0];
@@ -309,20 +309,18 @@ SimpleSTRtree::remove(const geom::Envelope* searchBounds,
     return found;
 /*public static*/
 std::ostream&
-operator<<(std::ostream& os, SimpleSTRtree& tree)
+operator<<(std::ostream& os, const SimpleSTRtree& tree)
     os << "nodeCapacity: " << tree.getNodeCapacity() << std::endl;
     os << "nodes.size(): " << tree.getNumLeafNodes() << std::endl;
     os << "built: " << tree.getBuilt() << std::endl;
-    if (tree.getRoot()) {
+    if (tree.root) {
         os << "tree: " << std::endl;
-        tree.getRoot()->toString(os, 1);
+        tree.root->toString(os, 1);
     else {
         os << "tree: empty" << std::endl;
diff --git a/tests/unit/index/strtree/SimpleSTRtreeTest.cpp b/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
index 5c7d239..67735d6 100644
--- a/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
+++ b/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
@@ -8,6 +8,7 @@
 #include <geos/index/ItemVisitor.h>
 #include <geos/io/WKTReader.h>
+#include <iostream>
 using namespace geos;
@@ -42,14 +43,14 @@ void object::test<1>
-    // std::cout << t << std::endl;
     geom::Envelope qe(-0.5, 1.5, -0.5, 1.5);
     std::vector<void*> matches;
     t.query(&qe, matches);
     // std::cout << matches.size() << std::endl;
     ensure(matches.size() == 4);
+    // std::cout << t << std::endl;
     class SimpleTestVisitor: public index::ItemVisitor {
         public:
             std::size_t count;
@@ -140,6 +141,8 @@ void object::test<3>
     ensure(leaf_before = 4u);
     ensure(all_before  = 5u);
     t.remove(geoms[3]->getEnvelopeInternal(), geoms[3].get());
     std::size_t leaf_after = t.getRoot()->getNumLeafNodes();
Summary of changes:
 include/geos/index/strtree/SimpleSTRnode.h     |  2 +-
 include/geos/index/strtree/SimpleSTRtree.h     |  9 +++++++--
 src/index/strtree/SimpleSTRnode.cpp            |  2 +-
 src/index/strtree/SimpleSTRtree.cpp            | 10 ++++------
 tests/unit/index/strtree/SimpleSTRtreeTest.cpp |  7 +++++--
 5 files changed, 18 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits
