[geos-commits] [SCM] GEOS branch master updated. 708d32b2cd2dd3bedc38ff1d839368656b1f9626
Fri Oct 30 08:12:12 PDT 2020
the project "GEOS".
       via  708d32b2cd2dd3bedc38ff1d839368656b1f9626 (commit)
      from  07532c3afd174a5f0767569e07aba6c7782f7087 (commit)
revisions in full, below.
commit 708d32b2cd2dd3bedc38ff1d839368656b1f9626
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Oct 30 08:12:06 2020 -0700
    Create new EMPTY geometry with 2D coordinates by default. Parse Z EMPTY geometry in WKT reader, for simple (non-multi) geometries. Closes #1048
diff --git a/include/geos/geom/GeometryFactory.h b/include/geos/geom/GeometryFactory.h
index 341e978..9dcfa45 100644
--- a/include/geos/geom/GeometryFactory.h
+++ b/include/geos/geom/GeometryFactory.h
@@ -164,7 +164,7 @@ public:
     const PrecisionModel* getPrecisionModel() const;
     /// Creates an EMPTY Point
-    std::unique_ptr<Point> createPoint() const;
+    std::unique_ptr<Point> createPoint(std::size_t coordinateDimension = 2) const;
     /// Creates a Point using the given Coordinate
     Point* createPoint(const Coordinate& coordinate) const;
@@ -269,7 +269,7 @@ public:
         const std::vector<Coordinate>& fromCoords) const;
     /// Construct an EMPTY Polygon
-    std::unique_ptr<Polygon> createPolygon() const;
+    std::unique_ptr<Polygon> createPolygon(std::size_t coordinateDimension = 2) const;
     /// Construct a Polygon taking ownership of given arguments
     Polygon* createPolygon(LinearRing* shell,
@@ -285,7 +285,7 @@ public:
                            const std::vector<LinearRing*>& holes) const;
     /// Construct an EMPTY LineString
-    std::unique_ptr<LineString> createLineString() const;
+    std::unique_ptr<LineString> createLineString(std::size_t coordinateDimension = 2) const;
     /// Copy a LineString
     std::unique_ptr<LineString> createLineString(const LineString& ls) const;
diff --git a/include/geos/io/WKTReader.h b/include/geos/io/WKTReader.h
index d43e1ee..bbaf46c 100644
--- a/include/geos/io/WKTReader.h
+++ b/include/geos/io/WKTReader.h
@@ -88,7 +88,7 @@ public:
 protected:
     std::unique_ptr<geom::CoordinateSequence> getCoordinates(io::StringTokenizer* tokenizer);
     double getNextNumber(io::StringTokenizer* tokenizer);
-    std::string getNextEmptyOrOpener(io::StringTokenizer* tokenizer);
+    std::string getNextEmptyOrOpener(io::StringTokenizer* tokenizer, std::size_t& dim);
     std::string getNextCloserOrComma(io::StringTokenizer* tokenizer);
     std::string getNextCloser(io::StringTokenizer* tokenizer);
     std::string getNextWord(io::StringTokenizer* tokenizer);
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index 1d2afeb..3618ee7 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -298,8 +298,12 @@ GeometryFactory::getPrecisionModel() const
 /*public*/
-GeometryFactory::createPoint() const
+GeometryFactory::createPoint(std::size_t coordinateDimension) const
+    if (coordinateDimension == 3) {
+        geos::geom::FixedSizeCoordinateSequence<0> seq(coordinateDimension);
+        return std::unique_ptr<Point>(createPoint(seq));
     return std::unique_ptr<Point>(new Point(nullptr, this));
@@ -553,9 +557,11 @@ GeometryFactory::createMultiPoint(const std::vector<Coordinate>& fromCoords) con
 /*public*/
-GeometryFactory::createPolygon() const
+GeometryFactory::createPolygon(std::size_t coordinateDimension) const
-    return std::unique_ptr<Polygon>(new Polygon(nullptr, nullptr, this));
+    auto cs = coordinateListFactory->create(std::size_t(0), coordinateDimension);
+    auto lr = createLinearRing(cs.release());
+    return std::unique_ptr<Polygon>(createPolygon(lr, nullptr));
 /*public*/
@@ -600,8 +606,11 @@ const
 /*public*/
-GeometryFactory::createLineString() const
+GeometryFactory::createLineString(std::size_t coordinateDimension) const
+        return createLineString(coordinateListFactory->create(std::size_t(0), coordinateDimension));
     return std::unique_ptr<LineString>(new LineString(nullptr, this));
diff --git a/src/geom/Point.cpp b/src/geom/Point.cpp
index 864e883..5c3d083 100644
--- a/src/geom/Point.cpp
+++ b/src/geom/Point.cpp
@@ -54,7 +54,7 @@ Point::Point(CoordinateSequence* newCoords, const GeometryFactory* factory)
     std::unique_ptr<CoordinateSequence> coords(newCoords);
     if(coords == nullptr) {
-        empty3d = true;
+        empty2d = true;
         return;
@@ -82,7 +82,7 @@ Point::Point(const Point& p)
     Geometry(p),
     coordinates(p.coordinates),
-    empty2d(p.empty3d),
+    empty2d(p.empty2d),
     empty3d(p.empty3d)
diff --git a/src/io/WKTReader.cpp b/src/io/WKTReader.cpp
index 11a3bea..384c8bd 100644
--- a/src/io/WKTReader.cpp
+++ b/src/io/WKTReader.cpp
@@ -70,10 +70,10 @@ WKTReader::read(const string& wellKnownText)
 WKTReader::getCoordinates(StringTokenizer* tokenizer)
-    size_t dim;
-    string nextToken = getNextEmptyOrOpener(tokenizer);
+    size_t dim = 2;
+    string nextToken = getNextEmptyOrOpener(tokenizer, dim);
     if(nextToken == "EMPTY") {
-        return geometryFactory->getCoordinateSequenceFactory()->create();
+        return geometryFactory->getCoordinateSequenceFactory()->create(std::size_t(0), dim);
     Coordinate coord;
@@ -148,11 +148,16 @@ WKTReader::getNextNumber(StringTokenizer* tokenizer)
 string
-WKTReader::getNextEmptyOrOpener(StringTokenizer* tokenizer)
+WKTReader::getNextEmptyOrOpener(StringTokenizer* tokenizer, std::size_t& dim)
     string nextWord = getNextWord(tokenizer);
     // Skip the Z, M or ZM of an SF1.2 3/4 dim coordinate.
+    if(nextWord == "Z" || nextWord == "ZM") {
+        dim = 3;
+    // Skip the Z, M or ZM of an SF1.2 3/4 dim coordinate.
     if(nextWord == "Z" || nextWord == "M" || nextWord == "ZM") {
@@ -249,10 +254,10 @@ WKTReader::readGeometryTaggedText(StringTokenizer* tokenizer)
 WKTReader::readPointText(StringTokenizer* tokenizer)
-    size_t dim;
+    size_t dim = 2;
-        return geometryFactory->createPoint();
+        return geometryFactory->createPoint(dim);
     Coordinate coord;
@@ -279,7 +284,8 @@ WKTReader::readLinearRingText(StringTokenizer* tokenizer)
 std::unique_ptr<MultiPoint>
 WKTReader::readMultiPointText(StringTokenizer* tokenizer)
+    size_t dim = 2;
         return geometryFactory->createMultiPoint();
@@ -287,7 +293,6 @@ WKTReader::readMultiPointText(StringTokenizer* tokenizer)
     int tok = tokenizer->peekNextToken();
     if(tok == StringTokenizer::TT_NUMBER) {
-        size_t dim;
         // Try to parse deprecated form "MULTIPOINT(0 0, 1 1)"
         auto coords = detail::make_unique<CoordinateArraySequence>();
@@ -350,9 +355,10 @@ WKTReader::readMultiPointText(StringTokenizer* tokenizer)
 WKTReader::readPolygonText(StringTokenizer* tokenizer)
+    size_t dim = 2;
-        return geometryFactory->createPolygon();
+        return geometryFactory->createPolygon(dim);
     std::vector<std::unique_ptr<LinearRing>> holes;
@@ -369,7 +375,8 @@ WKTReader::readPolygonText(StringTokenizer* tokenizer)
 std::unique_ptr<MultiLineString>
 WKTReader::readMultiLineStringText(StringTokenizer* tokenizer)
+    size_t dim = 2;
         return geometryFactory->createMultiLineString();
@@ -386,7 +393,8 @@ WKTReader::readMultiLineStringText(StringTokenizer* tokenizer)
 std::unique_ptr<MultiPolygon>
 WKTReader::readMultiPolygonText(StringTokenizer* tokenizer)
+    size_t dim = 2;
         return geometryFactory->createMultiPolygon();
@@ -403,7 +411,8 @@ WKTReader::readMultiPolygonText(StringTokenizer* tokenizer)
 std::unique_ptr<GeometryCollection>
 WKTReader::readGeometryCollectionText(StringTokenizer* tokenizer)
+    size_t dim = 2;
         return geometryFactory->createGeometryCollection();
diff --git a/src/operation/buffer/BufferInputLineSimplifier.cpp b/src/operation/buffer/BufferInputLineSimplifier.cpp
index 2fd6e92..1ada936 100644
--- a/src/operation/buffer/BufferInputLineSimplifier.cpp
+++ b/src/operation/buffer/BufferInputLineSimplifier.cpp
@@ -128,7 +128,7 @@ BufferInputLineSimplifier::findNextNonDeletedIndex(size_t index) const
 BufferInputLineSimplifier::collapseLine() const
-    auto coordList = detail::make_unique<CoordinateArraySequence>();
+    auto coordList = new CoordinateArraySequence();
     for(size_t i = 0, n = inputLine.size(); i < n; ++i) {
         if(isDeleted[i] != DELETE) {
@@ -136,7 +136,7 @@ BufferInputLineSimplifier::collapseLine() const
-    return coordList;
+    return std::unique_ptr<CoordinateSequence>(coordList);
 /* private */
diff --git a/tests/unit/geom/PointTest.cpp b/tests/unit/geom/PointTest.cpp
index 5aeb1e4..3880eb8 100644
--- a/tests/unit/geom/PointTest.cpp
+++ b/tests/unit/geom/PointTest.cpp
@@ -566,7 +566,7 @@ void object::test<45>
     auto empty3d = factory_->createPoint();
-    ensure_equals(empty3d->getCoordinateDimension(), 3);
+    ensure_equals(empty3d->getCoordinateDimension(), 2);
     geos::geom::FixedSizeCoordinateSequence<0> seq2(2);
     ensure_equals(seq2.getDimension(), 2u);
diff --git a/tests/unit/io/WKBWriterTest.cpp b/tests/unit/io/WKBWriterTest.cpp
index 381449c..fae8fbc 100644
--- a/tests/unit/io/WKBWriterTest.cpp
+++ b/tests/unit/io/WKBWriterTest.cpp
@@ -197,6 +197,74 @@ void object::test<6>
     assert(geom->equals(geom2.get()));
+// https://trac.osgeo.org/geos/ticket/1048
+// Higher dimension empty. Need correct support in WKT reader and in
+// WKB writer.
+template<>
+template<>
+void object::test<7>
+    auto geom = wktreader.read("POINT Z EMPTY");
+    geom->setSRID(4326);
+    std::stringstream result_stream;
+    wkbwriter.setOutputDimension(3);
+    wkbwriter.setByteOrder(1);
+    wkbwriter.setIncludeSRID(1);
+    wkbwriter.writeHEX(*geom, result_stream);
+    std::string actual = result_stream.str();
+    ensure_equals(actual, "01010000A0E6100000000000000000F87F000000000000F87F000000000000F87F");
+    auto geom2 = wkbreader.readHEX(result_stream);
+    assert(geom->equals(geom2.get()));
+template<>
+template<>
+void object::test<8>
+    auto geom = wktreader.read("LINESTRING Z EMPTY");
+    ensure_equals(actual, "01020000A0E610000000000000");
+template<>
+template<>
+void object::test<9>
+    auto geom = wktreader.read("GEOMETRYCOLLECTION (POINT EMPTY)");
+    wkbwriter.setIncludeSRID(0);
+    ensure_equals(actual, "0107000000010000000101000000000000000000F87F000000000000F87F");
 } // namespace tut
diff --git a/tests/unit/io/WKTReaderTest.cpp b/tests/unit/io/WKTReaderTest.cpp
index a50fe6f..f7808fb 100644
--- a/tests/unit/io/WKTReaderTest.cpp
+++ b/tests/unit/io/WKTReaderTest.cpp
@@ -193,4 +193,30 @@ void object::test<8>
+// Correctly read higher dimensional empty
+template<>
+template<>
+    auto geom1(wktreader.read("POINT EMPTY"));
+    ensure("dimension(POINT EMPTY) == 2", geom1->getCoordinateDimension() == 2);
+    auto geom2(wktreader.read("POINT Z EMPTY"));
+    ensure("dimension(POINT Z EMPTY) == 3", geom2->getCoordinateDimension() == 3);
+    auto geom3(wktreader.read("LINESTRING EMPTY"));
+    ensure("dimension(LINESTRING EMPTY) == 2", geom3->getCoordinateDimension() == 2);
+    auto geom4(wktreader.read("LINESTRING Z EMPTY"));
+    ensure("dimension(LINESTRING Z EMPTY) == 3", geom4->getCoordinateDimension() == 3);
+    auto geom5(wktreader.read("POLYGON EMPTY"));
+    ensure("dimension(POLYGON EMPTY) == 2", geom5->getCoordinateDimension() == 2);
+    auto geom6(wktreader.read("POLYGON Z EMPTY"));
+    ensure("dimension(POLYGON Z EMPTY) == 3", geom6->getCoordinateDimension() == 3);
 } // namespace tut
Summary of changes:
 include/geos/geom/GeometryFactory.h                |  6 +-
 include/geos/io/WKTReader.h                        |  2 +-
 src/geom/GeometryFactory.cpp                       | 17 ++++--
 src/geom/Point.cpp                                 |  4 +-
 src/io/WKTReader.cpp                               | 37 +++++++-----
 src/operation/buffer/BufferInputLineSimplifier.cpp |  4 +-
 tests/unit/geom/PointTest.cpp                      |  2 +-
 tests/unit/io/WKBWriterTest.cpp                    | 68 ++++++++++++++++++++++
 tests/unit/io/WKTReaderTest.cpp                    | 26 +++++++++
 9 files changed, 139 insertions(+), 27 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
