[geos-commits] [SCM] GEOS branch master updated. dfb6d579ad64e769770653987ff9e50d52f2087a
Mon Sep 14 09:36:28 PDT 2020
the project "GEOS".
       via  dfb6d579ad64e769770653987ff9e50d52f2087a (commit)
       via  a32d1b5caff914cc7c0d38a31cbf1f16517ec324 (commit)
       via  4633d4960a2ad15043f932cc8951209ba49d21a2 (commit)
      from  208a6f5090deac573597f54471b0651f91ae415f (commit)
revisions in full, below.
commit dfb6d579ad64e769770653987ff9e50d52f2087a
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Aug 24 14:06:17 2020 +0200
    Add OverlayNG in HeuristicOverlay, kept disabled
diff --git a/src/geom/HeuristicOverlay.cpp b/src/geom/HeuristicOverlay.cpp
index ed7eace..c1fd19b 100644
--- a/src/geom/HeuristicOverlay.cpp
+++ b/src/geom/HeuristicOverlay.cpp
@@ -45,11 +45,9 @@
-#define GEOS_DEBUG_HEURISTICOVERLAY 1
-#define GEOS_DEBUG_HEURISTICOVERLAY_PRINT_INVALID 1
 #include <geos/geom/HeuristicOverlay.h>
 #include <geos/operation/overlay/OverlayOp.h>
+#include <geos/operation/overlayng/OverlayNG.h>
 #include <geos/operation/overlayng/OverlayNGSnapIfNeeded.h>
 #include <geos/simplify/TopologyPreservingSimplifier.h>
@@ -72,6 +70,9 @@
 #include <geos/operation/overlay/snap/GeometrySnapper.h>
+#define GEOS_DEBUG_HEURISTICOVERLAY 1
+#define GEOS_DEBUG_HEURISTICOVERLAY_PRINT_INVALID 0
 #ifdef GEOS_DEBUG_HEURISTICOVERLAY
 # include <iostream>
@@ -92,6 +93,20 @@
 #define GEOS_CHECK_ORIGINAL_RESULT_VALIDITY 0
+ * Define this to use OverlayNG policy with fixed precision
+#ifndef USE_FIXED_PRECISION_OVERLAYNG
+# define USE_FIXED_PRECISION_OVERLAYNG 0
+#endif
+ * Define this to use OverlayNG policy with whatever precision
+#ifndef USE_OVERLAYNG_SNAPIFNEEDED
+# define USE_OVERLAYNG_SNAPIFNEEDED 0
+#endif
  * Define this to use PrecisionReduction policy
@@ -163,6 +178,7 @@
 #define GEOS_CHECK_SNAPPINGOP_VALIDITY 0
 using geos::operation::overlay::OverlayOp;
+using geos::operation::overlayng::OverlayNG;
 namespace geos {
 namespace geom { // geos::geom
@@ -470,6 +486,7 @@ HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode)
 #endif // USE_SNAPPING_POLICY }
 #if USE_PRECISION_REDUCTION_POLICY
@@ -489,7 +506,8 @@ HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode)
                   << std::endl;
 #endif
-        double maxScale = 1e16;
+        double maxScale = 1e16; // TODO: compute from input
+        double minScale = 1; // TODO: compute from input
         // Don't use a scale bigger than the input one
         if(g0scale && static_cast<double>(g0scale) < maxScale) {
@@ -500,7 +518,7 @@ HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode)
-        for(double scale = maxScale; scale >= 1; scale /= 10) {
+        for(double scale = maxScale; scale >= minScale; scale /= 10) {
             PrecisionModel pm(scale);
             GeometryFactory::Ptr gf = GeometryFactory::create(&pm);
 #if GEOS_DEBUG_HEURISTICOVERLAY
@@ -558,6 +576,74 @@ HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode)
 #endif
 // USE_PRECISION_REDUCTION_POLICY }
+#if USE_FIXED_PRECISION_OVERLAYNG
+    // Try OverlayNG with fixed precision
+    try {
+        long unsigned int g0scale =
+            static_cast<long unsigned int>(g0->getFactory()->getPrecisionModel()->getScale());
+        long unsigned int g1scale =
+            static_cast<long unsigned int>(g1->getFactory()->getPrecisionModel()->getScale());
+#if GEOS_DEBUG_HEURISTICOVERLAY
+        std::cerr << "Original input scales are: "
+                  << g0scale
+                  << " and "
+                  << g1scale
+                  << std::endl;
+#endif
+        double minScale = 1e10; // TODO: compute from input
+        // Don't use a scale bigger than the input one
+        if(g0scale && static_cast<double>(g0scale) < maxScale) {
+            maxScale = static_cast<double>(g0scale);
+        if(g1scale && static_cast<double>(g1scale) < maxScale) {
+            maxScale = static_cast<double>(g1scale);
+            PrecisionModel pm(scale);
+            std::cerr << "Trying with precision scale " << scale << std::endl;
+#endif
+            try {
+                ret = OverlayNG::overlay(g0, g1, opCode, &pm);
+                std::cerr << "Attempt with fixedNG scale " << scale << " succeeded" << std::endl;
+#endif
+                return ret;
+            catch(const geos::util::TopologyException& ex) {
+                std::cerr << "fixedNG with scale (" << scale << "): "
+                          << ex.what() << std::endl;
+#endif
+                if(scale == 1) {
+                    throw ex;
+        std::cerr << "Reduced: " << ex.what() << std::endl;
+#endif
+        ::geos::ignore_unused_variable_warning(ex);
+#endif
+// USE_FIXED_PRECISION_OVERLAYNG }
 #if USE_TP_SIMPLIFY_POLICY
@@ -606,6 +692,9 @@ HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode)
 // USE_TP_SIMPLIFY_POLICY }
+#if USE_OVERLAYNG_SNAPIFNEEDED
     std::cerr << "Trying with OverlayNGSnapIfNeeded" << std::endl;
 #endif
@@ -625,6 +714,7 @@ HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode)
         std::cerr << "OverlayNGSnapIfNeeded: " << ex.what() << std::endl;
 #endif
+#endif // USE_OVERLAYNG_SNAPIFNEEDED }
commit a32d1b5caff914cc7c0d38a31cbf1f16517ec324
Date:   Fri Aug 21 14:33:54 2020 +0200
    Rename BinaryOp to HeuristicOverlay
    This is in preparation of using OverlayNG as a possible fallback
    heuristic.
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index d5d79a4..17a2fb2 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -21,10 +21,6 @@
 #include <geos/io/WKBReader.h>
 #include <geos/io/WKTWriter.h>
 #include <geos/io/WKBWriter.h>
-#include <geos/operation/overlay/OverlayOp.h>
-#include <geos/operation/union/CascadedPolygonUnion.h>
-#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
-#include <geos/algorithm/distance/DiscreteFrechetDistance.h>
 #include <geos/util/Interrupt.h>
 #include <stdexcept>
@@ -76,9 +72,6 @@ using geos::io::WKBWriter;
 using geos::index::strtree::STRtree;
-using geos::operation::overlay::OverlayOp;
-using geos::operation::overlay::overlayOp;
-using geos::operation::geounion::CascadedPolygonUnion;
 typedef std::unique_ptr<Geometry> GeomPtr;
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 7557459..a6d6fde 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -63,11 +63,10 @@
 #include <geos/operation/distance/IndexedFacetDistance.h>
 #include <geos/operation/linemerge/LineMerger.h>
-#include <geos/operation/overlayng/OverlayNG.h>
-#include <geos/operation/overlayng/OverlayNGSnapIfNeeded.h>
 #include <geos/operation/overlayng/PrecisionReducer.h>
+#include <geos/operation/overlayng/OverlayNGSnapIfNeeded.h>
 #include <geos/operation/intersection/Rectangle.h>
 #include <geos/operation/intersection/RectangleIntersection.h>
 #include <geos/operation/polygonize/Polygonizer.h>
@@ -141,6 +140,7 @@ using geos::geom::LinearRing;
 using geos::geom::MultiLineString;
 using geos::geom::MultiPolygon;
 using geos::geom::Polygon;
+using geos::geom::PrecisionModel;
 using geos::geom::CoordinateSequence;
 using geos::geom::GeometryCollection;
 using geos::geom::GeometryFactory;
@@ -150,19 +150,19 @@ using geos::io::WKTWriter;
 using geos::io::WKBReader;
-using geos::geom::PrecisionModel;
+using geos::algorithm::distance::DiscreteFrechetDistance;
+using geos::algorithm::distance::DiscreteHausdorffDistance;
+using geos::operation::buffer::BufferBuilder;
+using geos::operation::buffer::BufferParameters;
+using geos::operation::distance::IndexedFacetDistance;
+using geos::operation::geounion::CascadedPolygonUnion;
 using geos::operation::overlayng::OverlayNGSnapIfNeeded;
-using geos::operation::distance::IndexedFacetDistance;
-using geos::operation::buffer::BufferParameters;
-using geos::operation::buffer::BufferBuilder;
 using geos::precision::GeometryPrecisionReducer;
 using geos::util::IllegalArgumentException;
-using geos::algorithm::distance::DiscreteHausdorffDistance;
-using geos::algorithm::distance::DiscreteFrechetDistance;
diff --git a/include/geos/geom/HeuristicOverlay.h b/include/geos/geom/HeuristicOverlay.h
new file mode 100644
index 0000000..ae3e057
--- /dev/null
+++ b/include/geos/geom/HeuristicOverlay.h
@@ -0,0 +1,36 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2013-2020 Sandro Santilli <strk at kbt.io>
+ * Copyright (C) 2006 Refractions Research Inc.
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: ORIGINAL WORK
+#ifndef GEOS_GEOM_HEURISTICOVERLAY_H
+#define GEOS_GEOM_HEURISTICOVERLAY_H
+#include <memory> // for unique_ptr
+namespace geos {
+namespace geom { // geos::geom
+class Geometry;
+std::unique_ptr<Geometry>
+HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode);
+} // namespace geos::geom
+#endif // GEOS_GEOM_HEURISTICOVERLAY_H
diff --git a/include/geos/geom/Makefile.am b/include/geos/geom/Makefile.am
index 3397ae6..d7afb62 100644
--- a/include/geos/geom/Makefile.am
+++ b/include/geos/geom/Makefile.am
@@ -10,7 +10,7 @@ SUBDIRS = \
 geosdir = $(includedir)/geos/geom
 geos_HEADERS = \
-    BinaryOp.h \
+    HeuristicOverlay.h \
     CoordinateArraySequenceFactory.h \
     CoordinateArraySequenceFactory.inl \
     CoordinateArraySequence.h \
diff --git a/include/geos/operation/overlay/OverlayOp.h b/include/geos/operation/overlay/OverlayOp.h
index a2f5f6a..3f34525 100644
--- a/include/geos/operation/overlay/OverlayOp.h
+++ b/include/geos/operation/overlay/OverlayOp.h
@@ -400,27 +400,6 @@ private:
-/** \brief
- * OverlayOp::overlayOp Adapter for use with geom::BinaryOp
-struct overlayOp {
-    OverlayOp::OpCode opCode;
-    overlayOp(OverlayOp::OpCode code)
-        opCode(code)
-    geom::Geometry*
-    operator()(const geom::Geometry* g0,
-               const geom::Geometry* g1)
-        return OverlayOp::overlayOp(g0, g1, opCode);
 } // namespace geos::operation::overlay
 } // namespace geos
diff --git a/include/geos/operation/union/UnaryUnionOp.h b/include/geos/operation/union/UnaryUnionOp.h
index e6d9900..049cf80 100644
--- a/include/geos/operation/union/UnaryUnionOp.h
+++ b/include/geos/operation/union/UnaryUnionOp.h
@@ -24,7 +24,7 @@
 #include <geos/export.h>
 #include <geos/geom/GeometryFactory.h>
-#include <geos/geom/BinaryOp.h>
+#include <geos/geom/HeuristicOverlay.h>
 #include <geos/geom/Point.h>
 #include <geos/geom/LineString.h>
 #include <geos/geom/Polygon.h>
diff --git a/src/geom/Geometry.cpp b/src/geom/Geometry.cpp
index 6701897..6a1075a 100644
--- a/src/geom/Geometry.cpp
+++ b/src/geom/Geometry.cpp
@@ -18,7 +18,7 @@
 #include <geos/geom/Geometry.h>
 #include <geos/geom/PrecisionModel.h>
@@ -554,7 +554,7 @@ Geometry::intersection(const Geometry* other) const
 #ifdef USE_OVERLAYNG
     return operation::overlayng::OverlayNGSnapIfNeeded::Intersection(this, other);
 #else
-    return BinaryOp(this, other, overlayOp(OverlayOp::opINTERSECTION));
+    return HeuristicOverlay(this, other, OverlayOp::opINTERSECTION);
 #endif
@@ -612,7 +612,7 @@ Geometry::Union(const Geometry* other) const
     return operation::overlayng::OverlayNGSnapIfNeeded::Union(this, other);
 #else
-    return BinaryOp(this, other, overlayOp(OverlayOp::opUNION));
+    return HeuristicOverlay(this, other, OverlayOp::opUNION);
 #endif
@@ -643,7 +643,7 @@ Geometry::difference(const Geometry* other) const
     return operation::overlayng::OverlayNGSnapIfNeeded::Difference(this, other);
 #else
-    return BinaryOp(this, other, overlayOp(OverlayOp::opDIFFERENCE));
+    return HeuristicOverlay(this, other, OverlayOp::opDIFFERENCE);
 #endif
@@ -697,7 +697,7 @@ Geometry::symDifference(const Geometry* other) const
     return operation::overlayng::OverlayNGSnapIfNeeded::SymDifference(this, other);
 #else
-    return BinaryOp(this, other, overlayOp(OverlayOp::opSYMDIFFERENCE));
+    return HeuristicOverlay(this, other, OverlayOp::opSYMDIFFERENCE);
 #endif
diff --git a/include/geos/geom/BinaryOp.h b/src/geom/HeuristicOverlay.cpp
similarity index 85%
rename from include/geos/geom/BinaryOp.h
rename to src/geom/HeuristicOverlay.cpp
index 3a385e3..ed7eace 100644
--- a/include/geos/geom/BinaryOp.h
@@ -3,7 +3,7 @@
- * Copyright (C) 2013 Sandro Santilli <strk at kbt.io>
@@ -43,11 +43,22 @@
  * See USE_TP_SIMPLIFY_POLICY, USE_PRECISION_REDUCTION_POLICY and
  * USE_SNAPPING_POLICY macros below.
-#ifndef GEOS_GEOM_BINARYOP_H
-#define GEOS_GEOM_BINARYOP_H
+#define GEOS_DEBUG_HEURISTICOVERLAY_PRINT_INVALID 1
+#include <geos/operation/overlay/OverlayOp.h>
+#include <geos/simplify/TopologyPreservingSimplifier.h>
+#include <geos/operation/IsSimpleOp.h>
+#include <geos/operation/valid/IsValidOp.h>
+#include <geos/operation/valid/TopologyValidationError.h>
+#include <geos/util/TopologyException.h>
+#include <geos/util.h>
 #include <geos/algorithm/BoundaryNodeRule.h>
@@ -61,19 +72,8 @@
-#include <geos/simplify/TopologyPreservingSimplifier.h>
-#include <geos/operation/IsSimpleOp.h>
-#include <geos/operation/valid/IsValidOp.h>
-#include <geos/operation/valid/TopologyValidationError.h>
-#include <geos/util/TopologyException.h>
-#include <geos/util.h>
-#include <memory> // for unique_ptr
-//#define GEOS_DEBUG_BINARYOP 1
-#define GEOS_DEBUG_BINARYOP_PRINT_INVALID 1
-#ifdef GEOS_DEBUG_BINARYOP
+#ifdef GEOS_DEBUG_HEURISTICOVERLAY
 # include <iomanip>
 # include <sstream>
@@ -162,6 +162,7 @@
+using geos::operation::overlay::OverlayOp;
 namespace geos {
@@ -186,13 +187,13 @@ check_valid(const Geometry& g, const std::string& label, bool doThrow = false, b
         if(! ivo.isValid()) {
             using operation::valid::TopologyValidationError;
             TopologyValidationError* err = ivo.getValidationError();
             std::cerr << label << " is INVALID: "
                       << err->toString()
                       << " (" << std::setprecision(20)
                       << err->getCoordinate() << ")"
                       << std::endl
-#ifdef GEOS_DEBUG_BINARYOP_PRINT_INVALID
+#ifdef GEOS_DEBUG_HEURISTICOVERLAY_PRINT_INVALID
                       << "<A>" << std::endl
                       << g.toString()
                       << std::endl
@@ -221,7 +222,7 @@ inline std::unique_ptr<Geometry>
 fix_self_intersections(std::unique_ptr<Geometry> g, const std::string& label)
     ::geos::ignore_unused_variable_warning(label);
     std::cerr << label << " fix_self_intersection (UnaryUnion)" << std::endl;
 #endif
@@ -246,18 +247,18 @@ fix_self_intersections(std::unique_ptr<Geometry> g, const std::string& label)
     switch(err->getErrorType()) {
     case TopologyValidationError::eRingSelfIntersection:
     case TopologyValidationError::eTooFewPoints: // collapsed lines
         std::cerr << label << " ATTEMPT_TO_FIX: " << err->getErrorType() << ": " << *g << std::endl;
 #endif
         g = g->Union();
         std::cerr << label << " ATTEMPT_TO_FIX succeeded.. " << std::endl;
 #endif
         return g;
     case TopologyValidationError::eSelfIntersection:
     // this one is within a single component, won't be fixed
     default:
         std::cerr << label << " invalidity is: " << err->getErrorType() << std::endl;
 #endif
         return g;
@@ -266,13 +267,12 @@ fix_self_intersections(std::unique_ptr<Geometry> g, const std::string& label)
 /// \brief
-/// Apply a binary operation to the given geometries
+/// Apply an overlay operation to the given geometries
 /// after snapping them to each other after common-bits
 /// removal.
-template <class BinOp>
-SnapOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
+SnapOp(const Geometry* g0, const Geometry* g1, int opCode)
@@ -282,7 +282,7 @@ SnapOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
     // Snap tolerance must be computed on the original
     // (not commonbits-removed) geoms
     double snapTolerance = GeometrySnapper::computeOverlaySnapTolerance(*g0, *g1);
-#if GEOS_DEBUG_BINARYOP
     std::cerr << std::setprecision(20) << "Computed snap tolerance: " << snapTolerance << std::endl;
 #endif
@@ -292,7 +292,7 @@ SnapOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
     geos::precision::CommonBitsRemover cbr;
     cbr.add(g0);
     cbr.add(g1);
     std::cerr << "Computed common bits: " << cbr.getCommonCoordinate() << std::endl;
 #endif
@@ -302,7 +302,7 @@ SnapOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
     GeomPtr rG1 = g1->clone();
     cbr.removeCommonBits(rG1.get());
     check_valid(*rG0, "CBR: removed-bits geom 0");
     check_valid(*rG1, "CBR: removed-bits geom 1");
 #endif
@@ -324,10 +324,10 @@ SnapOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
     GeomPtr snapG1(snapper1.snapTo(*snapG0, snapTolerance));
     //snapG1 = fix_self_intersections(snapG1, "SNAP: snapped geom 1");
-    // Run the binary op
-    GeomPtr result(_Op(snapG0.get(), snapG1.get()));
+    // Run the overlay op
+    GeomPtr result(OverlayOp::overlayOp(snapG0.get(), snapG1.get(), OverlayOp::OpCode(opCode)));
     check_valid(*result, "SNAP: result (before common-bits addition");
 #endif
@@ -343,9 +343,9 @@ SnapOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
     return result;
-BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
@@ -355,23 +355,23 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
 #ifdef USE_ORIGINAL_INPUT
     // Try with original input
     try {
         std::cerr << "Trying with original input." << std::endl;
 #endif
-        ret.reset(_Op(g0, g1));
+        ret.reset(OverlayOp::overlayOp(g0, g1, OverlayOp::OpCode(opCode)));
 #if GEOS_CHECK_ORIGINAL_RESULT_VALIDITY
         check_valid(*ret, "Overlay result between original inputs", true, true);
 #endif
         std::cerr << "Attempt with original input succeeded" << std::endl;
 #endif
         return ret;
         origException = ex;
         std::cerr << "Original exception: " << ex.what() << std::endl;
 #endif
@@ -393,7 +393,7 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
         GeomPtr rG1;
         std::cerr << "Trying with Common Bits Remover (CBR)" << std::endl;
 #endif
@@ -406,14 +406,14 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
         rG1 = g1->clone();
         check_valid(*rG0, "CBR: geom 0 (after common-bits removal)");
         check_valid(*rG1, "CBR: geom 1 (after common-bits removal)");
 #endif
-        ret.reset(_Op(rG0.get(), rG1.get()));
+        ret.reset(OverlayOp::overlayOp(rG0.get(), rG1.get(), OverlayOp::OpCode(opCode)));
         check_valid(*ret, "CBR: result (before common-bits addition)");
 #endif
@@ -423,7 +423,7 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
         check_valid(*ret, "CBR: result (after common-bits addition)", true);
 #endif
         std::cerr << "Attempt with CBR succeeded" << std::endl;
 #endif
@@ -431,7 +431,7 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
         std::cerr << "CBR: " << ex.what() << std::endl;
 #endif
@@ -446,16 +446,16 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
 #if USE_SNAPPING_POLICY
     std::cerr << "Trying with snapping " << std::endl;
 #endif
     try {
-        ret = SnapOp(g0, g1, _Op);
+        ret = SnapOp(g0, g1, opCode);
 #if GEOS_CHECK_SNAPPINGOP_VALIDITY
         check_valid(*ret, "SNAP: result", true, true);
 #endif
         std::cerr << "SnapOp succeeded" << std::endl;
 #endif
         return ret;
@@ -463,7 +463,7 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
         std::cerr << "SNAP: " << ex.what() << std::endl;
 #endif
@@ -481,7 +481,7 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
                   << g0scale
                   << " and "
@@ -503,7 +503,7 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
             std::cerr << "Trying with scale " << scale << std::endl;
 #endif
@@ -511,13 +511,13 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
             GeomPtr rG0(reducer.reduce(*g0));
             GeomPtr rG1(reducer.reduce(*g1));
             check_valid(*rG0, "PR: geom 0 (after precision reduction)");
             check_valid(*rG1, "PR: geom 1 (after precision reduction)");
 #endif
             try {
                 // restore original precision (least precision between inputs)
                 if(g0->getFactory()->getPrecisionModel()->compareTo(g1->getFactory()->getPrecisionModel()) < 0) {
                     ret.reset(g0->getFactory()->createGeometry(ret.get()));
@@ -530,13 +530,13 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
                 check_valid(*ret, "PR: result (after restore of original precision)", true);
 #endif
                 std::cerr << "Attempt with scale " << scale << " succeeded" << std::endl;
 #endif
                 return ret;
                 std::cerr << "Reduced with scale (" << scale << "): "
 #endif
@@ -549,7 +549,7 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
 #endif
@@ -559,9 +559,6 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
@@ -573,7 +570,7 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
         double tolStep = 0.01;
         for(double tol = minTolerance; tol <= maxTolerance; tol += tolStep) {
             std::cerr << "Trying simplifying with tolerance " << tol << std::endl;
 #endif
@@ -581,14 +578,14 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
             GeomPtr rG1(simplify::TopologyPreservingSimplifier::simplify(g1, tol));
             try {
+                ret.reset(OverlayOp::overlayOp(rG0.get(), rG1.get(), geos::operation::overlay::OverlayOp::OpCode(opCode)));
                 return ret;
                 if(tol >= maxTolerance) {
                     throw ex;
                 std::cerr << "Simplified with tolerance (" << tol << "): "
 #endif
@@ -600,7 +597,7 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
         std::cerr << "Simplified: " << ex.what() << std::endl;
 #endif
@@ -608,7 +605,29 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
 #endif
+    std::cerr << "Trying with OverlayNGSnapIfNeeded" << std::endl;
+#endif
+    try {
+        ret = operation::overlayng::OverlayNGSnapIfNeeded::Overlay(g0, g1, opCode);
+        std::cerr << "Attempt with OverlayNGSnapIfNeeded succeeded" << std::endl;
+#endif
+        return ret;
+        std::cerr << "OverlayNGSnapIfNeeded: " << ex.what() << std::endl;
+#endif
     std::cerr << "No attempts worked to union " << std::endl;
     std::cerr << "Input geometries:" << std::endl
@@ -625,5 +644,3 @@ BinaryOp(const Geometry* g0, const Geometry* g1, BinOp _Op)
 } // namespace geos
-#endif // GEOS_GEOM_BINARYOP_H
diff --git a/src/geom/Makefile.am b/src/geom/Makefile.am
index fc49614..245fd4e 100644
--- a/src/geom/Makefile.am
+++ b/src/geom/Makefile.am
@@ -22,6 +22,7 @@ libgeom_la_SOURCES = \
     GeometryCollection.cpp \
     GeometryComponentFilter.cpp \
     GeometryFactory.cpp \
+    HeuristicOverlay.cpp \
     IntersectionMatrix.cpp \
     LinearRing.cpp \
     LineSegment.cpp \
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index d28c212..6d1d9bf 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -21,7 +21,7 @@
 #include <geos/operation/union/OverlapUnion.h>
 #include <geos/geom/Dimension.h>
@@ -305,7 +305,7 @@ ClassicUnionStrategy::Union(const geom::Geometry* g0, const geom::Geometry* g1)
     try {
         // return SnapIfNeededOverlayOp.union(g0, g1);
-        return geom::BinaryOp(g0, g1, overlay::overlayOp(OverlayOp::opUNION));
+        return geom::HeuristicOverlay(g0, g1, overlay::OverlayOp::opUNION);
     catch (const util::TopologyException &ex) {
         // union-by-buffer only works for polygons
diff --git a/src/operation/valid/MakeValid.cpp b/src/operation/valid/MakeValid.cpp
index 8807432..afe29db 100644
--- a/src/operation/valid/MakeValid.cpp
+++ b/src/operation/valid/MakeValid.cpp
@@ -25,7 +25,7 @@
 #include <geos/operation/polygonize/BuildArea.h>
 #include <geos/operation/union/UnaryUnionOp.h>
 #include <geos/geom/GeometryCollection.h>
@@ -60,19 +60,19 @@ namespace valid { // geos.operation.valid
 static std::unique_ptr<geom::Geometry>
 makeValidSymDifference(const geom::Geometry* g0, const geom::Geometry* g1)
-    return BinaryOp(g0, g1, overlayOp(OverlayOp::opSYMDIFFERENCE));
+    return HeuristicOverlay(g0, g1, OverlayOp::opSYMDIFFERENCE);
 makeValidDifference(const geom::Geometry* g0, const geom::Geometry* g1)
-    return BinaryOp(g0, g1, overlayOp(OverlayOp::opDIFFERENCE));
+    return HeuristicOverlay(g0, g1, OverlayOp::opDIFFERENCE);
 makeValidUnion(const geom::Geometry* g0, const geom::Geometry* g1)
-    return BinaryOp(g0, g1, overlayOp(OverlayOp::opUNION));
+    return HeuristicOverlay(g0, g1, OverlayOp::opUNION);
diff --git a/tests/xmltester/BufferResultMatcher.cpp b/tests/xmltester/BufferResultMatcher.cpp
index 8e17a56..96ff030 100644
--- a/tests/xmltester/BufferResultMatcher.cpp
+++ b/tests/xmltester/BufferResultMatcher.cpp
@@ -19,7 +19,7 @@
 #include "BufferResultMatcher.h"
@@ -68,11 +68,11 @@ BufferResultMatcher::isSymDiffAreaInTolerance(
     typedef std::unique_ptr<geom::Geometry> GeomPtr;
     using namespace operation::overlay;
-    using geos::geom::BinaryOp;
+    using geos::geom::HeuristicOverlay;
     double area = expectedBuffer.getArea();
-    GeomPtr diff = BinaryOp(&actualBuffer, &expectedBuffer,
-                            overlayOp(OverlayOp::opSYMDIFFERENCE));
+    GeomPtr diff = HeuristicOverlay(&actualBuffer, &expectedBuffer,
+                            OverlayOp::opSYMDIFFERENCE);
     double areaDiff = diff->getArea();
diff --git a/tests/xmltester/SingleSidedBufferResultMatcher.cpp b/tests/xmltester/SingleSidedBufferResultMatcher.cpp
index c3a1f92..9e51218 100644
--- a/tests/xmltester/SingleSidedBufferResultMatcher.cpp
+++ b/tests/xmltester/SingleSidedBufferResultMatcher.cpp
@@ -19,7 +19,7 @@
 #include "SingleSidedBufferResultMatcher.h"
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 552524e..d9567dc 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -2393,7 +2393,7 @@ main(int argC, char* argV[])
  *         error on load of requested tests.
  * Revision 1.32  2006/04/14 14:57:15  strk
- * XMLTester binary ops invoked using the new BinaryOp template function.
+ * XMLTester binary ops invoked using the new HeuristicOverlay template function.
  * Revision 1.31  2006/04/07 13:26:38  strk
  * Use of unique_ptr<> to prevent confusing leaks in tester
commit 4633d4960a2ad15043f932cc8951209ba49d21a2
Date:   Mon Aug 24 14:05:15 2020 +0200
    OID are not needed by modern QGIS anymore
index 8fcf23d..552524e 100644
@@ -410,7 +410,7 @@ XMLTester::run(const std::string& source)
                   //       The 'WITH OIDS' parameter is supported back to
                   //       PostgreSQL 7.2, so if you run an older version
                   //       rebuild with the next line commented out.
-                  << " WITH OIDS"
+                  //<< " WITH OIDS"
                   << ";" << std::endl;
Summary of changes:
 capi/geos_c.cpp                                    |   7 -
 capi/geos_ts_c.cpp                                 |  22 +-
 .../{GeometryCollection.inl => HeuristicOverlay.h} |  27 +--
 include/geos/geom/Makefile.am                      |   2 +-
 include/geos/operation/overlay/OverlayOp.h         |  21 --
 include/geos/operation/union/UnaryUnionOp.h        |   2 +-
 src/geom/Geometry.cpp                              |  10 +-
 .../BinaryOp.h => src/geom/HeuristicOverlay.cpp    | 231 +++++++++++++++------
 src/geom/Makefile.am                               |   1 +
 src/operation/union/CascadedPolygonUnion.cpp       |   4 +-
 src/operation/valid/MakeValid.cpp                  |   8 +-
 tests/xmltester/BufferResultMatcher.cpp            |   8 +-
 tests/xmltester/SingleSidedBufferResultMatcher.cpp |   2 +-
 tests/xmltester/XMLTester.cpp                      |   4 +-
 14 files changed, 210 insertions(+), 139 deletions(-)
 copy include/geos/geom/{GeometryCollection.inl => HeuristicOverlay.h} (60%)
 rename include/geos/geom/BinaryOp.h => src/geom/HeuristicOverlay.cpp (75%)
hooks/post-receive
More information about the geos-commits mailing list
