[geos-commits] [SCM] GEOS branch master updated. 49ac5aa40404b634be3769375c70ee7c4466958d
Thu Sep 17 10:00:42 PDT 2020
the project "GEOS".
       via  49ac5aa40404b634be3769375c70ee7c4466958d (commit)
      from  1bb072153d7bb195d5065416123de06c34b972a9 (commit)
revisions in full, below.
commit 49ac5aa40404b634be3769375c70ee7c4466958d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Sep 17 09:35:14 2020 -0700
    Unit test and fix for dateline clipping case reported by @roualt
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index 9fbda99..ea00845 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -361,6 +361,14 @@ public:
         return isDimensionStrict(Dimension::A);
+    bool isCollection() const {
+        int t = getGeometryTypeId();
+        return t == GEOS_GEOMETRYCOLLECTION ||
+               t == GEOS_MULTIPOINT ||
+               t == GEOS_MULTILINESTRING ||
+               t == GEOS_MULTIPOLYGON;
     /// Returns the coordinate dimension of this Geometry (2=XY, 3=XYZ, 4=XYZM in future).
     virtual int getCoordinateDimension() const = 0; //Abstract
diff --git a/src/operation/overlayng/OverlayNG.cpp b/src/operation/overlayng/OverlayNG.cpp
index eb80103..3c1a05b 100644
--- a/src/operation/overlayng/OverlayNG.cpp
+++ b/src/operation/overlayng/OverlayNG.cpp
@@ -188,10 +188,12 @@ OverlayNG::computeEdgeOverlay()
     * Edge* list allocated in the EdgeNodingBuilder survives
     * long enough to be copied into the OverlayGraph
-    // XXX sort the edges first
+    // Sort the edges first, for comparison with JTS results
     // std::sort(edges.begin(), edges.end(), EdgeComparator);
     OverlayGraph graph;
     for (Edge* e : edges) {
+        // Write out edge graph as hex for examination
+        // std::cout << *e << std::endl;
         graph.addEdge(e);
diff --git a/src/operation/overlayng/RobustClipEnvelopeComputer.cpp b/src/operation/overlayng/RobustClipEnvelopeComputer.cpp
index f1bd0ed..2786701 100644
--- a/src/operation/overlayng/RobustClipEnvelopeComputer.cpp
+++ b/src/operation/overlayng/RobustClipEnvelopeComputer.cpp
@@ -58,7 +58,7 @@ RobustClipEnvelopeComputer::add(const Geometry* g)
     if (g->getGeometryTypeId() == GEOS_POLYGON)
         addPolygon(static_cast<const Polygon*>(g));
-    else if (g->getGeometryTypeId() == GEOS_GEOMETRYCOLLECTION)
+    else if (g->isCollection())
         addCollection(static_cast<const GeometryCollection*>(g));
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index c2f26f8..d7290cd 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -196,6 +196,7 @@ geos_unit_SOURCES = \
 	operation/overlayng/OverlayNGFloatingNoderTest.cpp \
 	operation/overlayng/OverlayNGPointsTest.cpp \
 	operation/overlayng/OverlayNGMixedPointsTest.cpp \
+	operation/overlayng/OverlayNGRobustTest.cpp \
 	operation/overlayng/OverlayNGSnappingNoderTest.cpp \
 	operation/overlayng/OverlayNGSnappingOneTest.cpp \
 	operation/overlayng/OverlayNGTest.cpp \
diff --git a/tests/unit/operation/overlayng/OverlayNGRobustTest.cpp b/tests/unit/operation/overlayng/OverlayNGRobustTest.cpp
new file mode 100644
index 0000000..b8bd71b
--- /dev/null
+++ b/tests/unit/operation/overlayng/OverlayNGRobustTest.cpp
@@ -0,0 +1,65 @@
+// Test Suite for geos::operation::overlayng::OverlayNG class.
+#include <tut/tut.hpp>
+#include <utility.h>
+// geos
+#include <geos/operation/overlayng/OverlayNGRobust.h>
+// std
+#include <memory>
+using namespace geos::geom;
+using namespace geos::operation::overlayng;
+using geos::io::WKTReader;
+using geos::io::WKTWriter;
+namespace tut {
+// Test Group
+// Common data used by all tests
+struct test_overlayngrobust_data {
+    WKTReader r;
+    WKTWriter w;
+    void
+    testOverlay(const std::string& a, const std::string& b, const std::string& expected, int opCode)
+        std::unique_ptr<Geometry> geom_a = r.read(a);
+        std::unique_ptr<Geometry> geom_b = r.read(b);
+        std::unique_ptr<Geometry> geom_expected = r.read(expected);
+        std::unique_ptr<Geometry> geom_result = OverlayNGRobust::Overlay(geom_a.get(), geom_b.get(), opCode);
+        // std::string wkt_result = w.write(geom_result.get());
+        // std::cout << std::endl << wkt_result << std::endl;
+        ensure_equals_geometry(geom_expected.get(), geom_result.get());
+typedef test_group<test_overlayngrobust_data> group;
+typedef group::object object;
+group test_overlayngrobust_data("geos::operation::overlayng::OverlayNGRobust");
+// Test Cases
+//  Square overlapping square
+template<>
+template<>
+void object::test<1> ()
+    std::string a = "LINESTRING(832864.275023695 0,835092.849076364 0)";
+    std::string b = "MULTIPOLYGON (((832864.275023695 0.0,833978.556808034 -0.000110682755987,833978.556808034 0.0,833978.556808034 0.000110682755987,832864.275023695 0.0,832864.275023695 0.0)),((835092.849076364 0.0,833978.557030887 -0.000110682755987,833978.557030887 0.0,833978.557030887 0.000110682755987,835092.849076364 0.0,835092.849076364 0.0)))";
+    std::string exp = "MULTILINESTRING ((832864.275023695 0.0,833978.556808034 0.0),(833978.557030887 0.0,835092.849076364 0.0))";
+    testOverlay(a, b, exp, OverlayNG::INTERSECTION);
+} // namespace tut
Summary of changes:
 include/geos/geom/Geometry.h                       |  8 +++
 src/operation/overlayng/OverlayNG.cpp              |  4 +-
 .../overlayng/RobustClipEnvelopeComputer.cpp       |  2 +-
 tests/unit/Makefile.am                             |  1 +
 .../operation/overlayng/OverlayNGRobustTest.cpp    | 65 ++++++++++++++++++++++
 5 files changed, 78 insertions(+), 2 deletions(-)
 create mode 100644 tests/unit/operation/overlayng/OverlayNGRobustTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
