[geos-commits] [SCM] GEOS branch master updated. 3c5ed392f4570a9a434c059b68e26d777570ed47
Thu Sep 17 13:11:14 PDT 2020
the project "GEOS".
       via  3c5ed392f4570a9a434c059b68e26d777570ed47 (commit)
      from  f54cd8347c070a3b76b02b9b772c31a1feca6173 (commit)
revisions in full, below.
commit 3c5ed392f4570a9a434c059b68e26d777570ed47
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Sep 17 13:11:07 2020 -0700
    Add OverlayNG strict mode, from https://github.com/dr-jts/jts/commit/0da1f61ad6e71c04c7de22853cb06fb1b394bec6 and https://github.com/dr-jts/jts/commit/b0d6f035777de7035cbe915ec18e65c2b9f0838e
diff --git a/include/geos/operation/overlayng/IntersectionPointBuilder.h b/include/geos/operation/overlayng/IntersectionPointBuilder.h
index 08b5e09..63637e6 100644
--- a/include/geos/operation/overlayng/IntersectionPointBuilder.h
+++ b/include/geos/operation/overlayng/IntersectionPointBuilder.h
@@ -15,6 +15,7 @@
 #pragma once
 #include <geos/geom/Point.h>
+#include <geos/operation/overlayng/OverlayNG.h>
 #include <geos/export.h>
 #include <vector>
@@ -64,6 +65,12 @@ private:
     OverlayGraph* graph;
     const geom::GeometryFactory* geometryFactory;
     std::vector<std::unique_ptr<geom::Point>> points;
+    * Controls whether lines created by area topology collapses
+    * to participate in the result computation.
+    * True provides the original JTS semantics.
+    bool isAllowCollapseLines;
     // Methods
     void addResultPoints();
@@ -77,18 +84,26 @@ private:
     bool isEdgeOf(const OverlayLabel* label, int i) const;
 public:
     IntersectionPointBuilder(OverlayGraph* p_graph, const geom::GeometryFactory* geomFact)
         : graph(p_graph)
-        , geometryFactory(geomFact) {}
+        , geometryFactory(geomFact)
+        , isAllowCollapseLines(!OverlayNG::STRICT_MODE_DEFAULT)
     std::vector<std::unique_ptr<geom::Point>> getPoints();
     IntersectionPointBuilder(const IntersectionPointBuilder&) = delete;
     IntersectionPointBuilder& operator=(const IntersectionPointBuilder&) = delete;
+    void setStrictMode(bool p_isStrictMode)
+        isAllowCollapseLines = ! p_isStrictMode;
diff --git a/include/geos/operation/overlayng/LineBuilder.h b/include/geos/operation/overlayng/LineBuilder.h
index 63039b8..f0a4a12 100644
--- a/include/geos/operation/overlayng/LineBuilder.h
+++ b/include/geos/operation/overlayng/LineBuilder.h
@@ -17,6 +17,7 @@
 #include <geos/operation/overlayng/InputGeometry.h>
 #include <geos/geom/Location.h>
 #include <geos/geom/LineString.h>
@@ -78,6 +79,21 @@ private:
     int inputAreaIndex;
     std::vector<std::unique_ptr<geom::LineString>> lines;
+    * Indicates whether intersections are allowed to produce
+    * heterogeneous results including proper boundary touches.
+    * This does not control inclusion of touches along collapses.
+    bool isAllowMixedResult = ! OverlayNG::STRICT_MODE_DEFAULT;
+    * Allow lines created by area topology collapses
+    * to appear in the result.
+    bool isAllowCollapseLines = ! OverlayNG::STRICT_MODE_DEFAULT;
     void markResultLines();
@@ -149,13 +165,22 @@ public:
         , opCode(p_opCode)
         , hasResultArea(p_hasResultArea)
-        , inputAreaIndex(inputGeom->getAreaIndex()) {}
+        , inputAreaIndex(inputGeom->getAreaIndex())
+        , isAllowMixedResult(! OverlayNG::STRICT_MODE_DEFAULT)
+        , isAllowCollapseLines(! OverlayNG::STRICT_MODE_DEFAULT)
     LineBuilder(const LineBuilder&) = delete;
     LineBuilder& operator=(const LineBuilder&) = delete;
     std::vector<std::unique_ptr<geom::LineString>> getLines();
+    void setStrictMode(bool p_isStrictResultMode)
+        isAllowCollapseLines = ! p_isStrictResultMode;
+        isAllowMixedResult = ! p_isStrictResultMode;
diff --git a/include/geos/operation/overlayng/OverlayNG.h b/include/geos/operation/overlayng/OverlayNG.h
index 74efe8d..0c40858 100644
--- a/include/geos/operation/overlayng/OverlayNG.h
+++ b/include/geos/operation/overlayng/OverlayNG.h
@@ -77,8 +77,21 @@ namespace overlayng { // geos.operation.overlayng
  * since the intersection clipping optimization can
  * interact with the snapping to alter the result.
- * @author mdavis
+ * TOptionally the overlay computation can process using strict mode
+ * (via setStrictMode(boolean). In strict mode result semantics are:
+ *  - Result geometries are homogeneous (all components are of same dimension),
+ *    except for some cases of symmetricDifference.
+ *  - Lines and Points resulting from topology collapses are not included in the result
+ * Strict mode has the following benefits:
+ *  - Results are simpler
+ *  - Overlay operations are easily chainable
+ * The original JTS overlay semantics correspond to non-strict mode.
+ * @author mdavis
  * @see OverlayNGRobust
@@ -86,19 +99,13 @@ class GEOS_DLL OverlayNG {
 private:
-    * Indicates whether the old overlay result semantics are used:
-    * - Intersection result can be mixed-dimension
-    * - Results can include lines caused by Area topology collapse
-    static constexpr bool USE_OLD_RESULT_SEMANTICS = true;
     // Members
     const geom::PrecisionModel* pm;
     InputGeometry inputGeom;
     const geom::GeometryFactory* geomFact;
     int opCode;
     noding::Noder* noder;
+    bool isStrictMode;
     bool isOptimized;
     bool isAreaResultOnly;
     bool isOutputEdges;
@@ -129,28 +136,22 @@ private:
 public:
+    * The default setting for Strict Mode.
+    * The original JTS overlay semantics used non-strict result
+    * semantics, including;
+    * - An Intersection result can be mixed-dimension,
+    *   due to inclusion of intersection components of all dimensions
+    * - Results can include lines caused by Area topology collapse
+    static constexpr bool STRICT_MODE_DEFAULT = false;
     static constexpr int INTERSECTION   = overlay::OverlayOp::opINTERSECTION;
     static constexpr int UNION          = overlay::OverlayOp::opUNION;
     static constexpr int DIFFERENCE     = overlay::OverlayOp::opDIFFERENCE;
     static constexpr int SYMDIFFERENCE  = overlay::OverlayOp::opSYMDIFFERENCE;
-    * Indicates whether intersections are allowed to produce
-    * heterogeneous results including proper boundary touches.
-    * This does not control inclusion of touches along collapses.
-    * True provides the original JTS semantics.
-    static constexpr bool ALLOW_INT_MIXED_RESULT = USE_OLD_RESULT_SEMANTICS;
-    * Allow lines created by area topology collapses
-    * to appear in the result.
-    static constexpr bool ALLOW_COLLAPSE_LINES = USE_OLD_RESULT_SEMANTICS;
     * Creates an overlay operation on the given geometries,
     * with a defined precision model.
@@ -162,6 +163,7 @@ public:
         , geomFact(p_geomFact)
         , opCode(p_opCode)
         , noder(nullptr)
+        , isStrictMode(STRICT_MODE_DEFAULT)
         , isOptimized(true)
         , isAreaResultOnly(false)
         , isOutputEdges(false)
@@ -180,6 +182,7 @@ public:
         , geomFact(geom0->getFactory())
         , opCode(p_opCode)
         , noder(nullptr)
         , isOptimized(true)
@@ -217,6 +220,7 @@ public:
     * @param p_isOptimized whether to optimize processing
     void setOptimized(bool p_isOptimized) { isOptimized = p_isOptimized; }
+    void setStrictMode(bool p_isStrictMode) { isStrictMode = p_isStrictMode; }
     void setAreaResultOnly(bool p_areaResultOnly) { isAreaResultOnly = p_areaResultOnly; }
     void setOutputEdges(bool p_isOutputEdges) { isOutputEdges = p_isOutputEdges; }
     void setOutputResultEdges(bool p_isOutputResultEdges) { isOutputResultEdges = p_isOutputResultEdges; }
diff --git a/src/operation/overlayng/IntersectionPointBuilder.cpp b/src/operation/overlayng/IntersectionPointBuilder.cpp
index d1c8484..fed278a 100644
--- a/src/operation/overlayng/IntersectionPointBuilder.cpp
+++ b/src/operation/overlayng/IntersectionPointBuilder.cpp
@@ -75,6 +75,9 @@ IntersectionPointBuilder::isResultPoint(OverlayEdge* nodeEdge) const
 bool
 IntersectionPointBuilder::isEdgeOf(const OverlayLabel* label, int i) const
+    if (!isAllowCollapseLines && label->isBoundaryCollapse()) {
+        return false;
     return label->isBoundary(i) || label->isLine(i);
diff --git a/src/operation/overlayng/LineBuilder.cpp b/src/operation/overlayng/LineBuilder.cpp
index 52fa91e..06e0dcc 100644
--- a/src/operation/overlayng/LineBuilder.cpp
+++ b/src/operation/overlayng/LineBuilder.cpp
@@ -82,7 +82,7 @@ LineBuilder::isResultLine(const OverlayLabel* lbl) const
     * OR two coincident area boundaries.
     * This logic is only used if not including collapse lines in result.
-    if (! OverlayNG::ALLOW_COLLAPSE_LINES && lbl->isBoundaryCollapse())
+    if (!isAllowCollapseLines && lbl->isBoundaryCollapse())
         return false;
@@ -120,7 +120,7 @@ LineBuilder::isResultLine(const OverlayLabel* lbl) const
     * Include line edge formed by touching area boundaries,
     * if enabled.
-    if (OverlayNG::ALLOW_INT_MIXED_RESULT &&
+    if (isAllowMixedResult &&
         opCode == OverlayNG::INTERSECTION &&
         lbl->isBoundaryTouch()) {
         return true;
diff --git a/src/operation/overlayng/OverlayNG.cpp b/src/operation/overlayng/OverlayNG.cpp
index 3c1a05b..baba411 100644
--- a/src/operation/overlayng/OverlayNG.cpp
+++ b/src/operation/overlayng/OverlayNG.cpp
@@ -232,6 +232,8 @@ OverlayNG::extractResult(int p_opCode, OverlayGraph* graph)
     std::cerr << "OverlayNG::extractResult: graph: " << *graph << std::endl;
 #endif
+    bool isAllowMixedIntResult = ! isStrictMode;
     //--- Build polygons
     std::vector<OverlayEdge*> resultAreaEdges = graph->getResultAreaEdges();
     PolygonBuilder polyBuilder(resultAreaEdges, geomFact);
@@ -243,9 +245,14 @@ OverlayNG::extractResult(int p_opCode, OverlayGraph* graph)
     if (!isAreaResultOnly) {
         //--- Build lines
-        bool allowResultLines = ! hasResultAreaComponents || ALLOW_INT_MIXED_RESULT;
+        bool allowResultLines = !hasResultAreaComponents ||
+                                isAllowMixedIntResult ||
+                                opCode == SYMDIFFERENCE ||
+                                opCode == UNION;
         if (allowResultLines) {
             LineBuilder lineBuilder(&inputGeom, graph, hasResultAreaComponents, p_opCode, geomFact);
+            lineBuilder.setStrictMode(isStrictMode);
             resultLineList = lineBuilder.getLines();
@@ -254,9 +261,10 @@ OverlayNG::extractResult(int p_opCode, OverlayGraph* graph)
          * from non-point inputs.
         bool hasResultComponents = hasResultAreaComponents || resultLineList.size() > 0;
-        bool allowResultPoints = ! hasResultComponents || ALLOW_INT_MIXED_RESULT;
+        bool allowResultPoints = ! hasResultComponents || isAllowMixedIntResult;
         if (opCode == INTERSECTION && allowResultPoints) {
             IntersectionPointBuilder pointBuilder(graph, geomFact);
+            pointBuilder.setStrictMode(isStrictMode);
             resultPointList = pointBuilder.getPoints();
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index d7290cd..f8d4c8c 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -194,11 +194,12 @@ geos_unit_SOURCES = \
 	operation/overlayng/LineLimiterTest.cpp \
 	operation/overlayng/OverlayGraphTest.cpp \
 	operation/overlayng/OverlayNGFloatingNoderTest.cpp \
-	operation/overlayng/OverlayNGPointsTest.cpp \
 	operation/overlayng/OverlayNGMixedPointsTest.cpp \
+	operation/overlayng/OverlayNGPointsTest.cpp \
 	operation/overlayng/OverlayNGRobustTest.cpp \
 	operation/overlayng/OverlayNGSnappingNoderTest.cpp \
 	operation/overlayng/OverlayNGSnappingOneTest.cpp \
+	operation/overlayng/OverlayNGStrictModeTest.cpp \
 	operation/overlayng/OverlayNGTest.cpp \
 	operation/overlayng/PrecisionReducerTest.cpp \
 	operation/overlayng/PrecisionUtilTest.cpp \
diff --git a/tests/unit/operation/overlayng/OverlayNGStrictModeTest.cpp b/tests/unit/operation/overlayng/OverlayNGStrictModeTest.cpp
new file mode 100644
index 0000000..ed2c588
--- /dev/null
+++ b/tests/unit/operation/overlayng/OverlayNGStrictModeTest.cpp
@@ -0,0 +1,194 @@
+// Test Suite for geos::operation::overlayng::OverlayNGRobust class.
+// Useful place for test cases raised by 3rd party software, that will be using
+// Geometry->Intersection(), Geometry->Union(), etc, that call into the
+// OverlayNGRobust utility class that bundles up different precision models
+// and noders to provide a "best case" overlay for all inputs.
+#include <tut/tut.hpp>
+#include <utility.h>
+// geos
+// std
+#include <memory>
+using namespace geos::geom;
+using namespace geos::operation::overlayng;
+using geos::io::WKTReader;
+using geos::io::WKTWriter;
+namespace tut {
+// Test Group
+// Common data used by all tests
+struct test_overlayngstring_data {
+    WKTReader r;
+    WKTWriter w;
+    void
+    testOverlay(const std::string& a, const std::string& b, const std::string& expected, int opCode)
+        std::unique_ptr<Geometry> geom_a = r.read(a);
+        std::unique_ptr<Geometry> geom_b = r.read(b);
+        std::unique_ptr<Geometry> geom_expected = r.read(expected);
+        OverlayNG ov(geom_a.get(), geom_b.get(), opCode);
+        ov.setStrictMode(true);
+        std::unique_ptr<Geometry> geom_result = ov.getResult();
+        // std::string wkt_result = w.write(geom_result.get());
+        // std::cout << std::endl << wkt_result << std::endl;
+        ensure_equals_geometry(geom_expected.get(), geom_result.get());
+    void
+    testOverlay(const std::string& a, const std::string& b, const std::string& expected, int opCode, double scaleFactor)
+        PrecisionModel pm(scaleFactor);
+        OverlayNG ov(geom_a.get(), geom_b.get(), &pm, opCode);
+typedef test_group<test_overlayngstring_data> group;
+typedef group::object object;
+group test_overlayngstring_data("geos::operation::overlayng::OverlayNGStrictMode");
+// Test Cases
+// testPolygonTouchALPIntersection
+template<>
+template<>
+void object::test<1> ()
+    std::string a = "POLYGON ((10 10, 10 30, 30 30, 30 10, 10 10))";
+    std::string b = "POLYGON ((40 10, 30 10, 35 15, 30 15, 30 20, 35 20, 25 30, 40 30, 40 10))";
+    std::string expected = "POLYGON ((30 25, 25 30, 30 30, 30 25))";
+    testOverlay(a, b, expected, OverlayNG::INTERSECTION);
+// testPolygonTouchALIntersection
+template<>
+template<>
+void object::test<3> ()
+    std::string a = "POLYGON ((10 30, 60 30, 60 10, 10 10, 10 30))";
+    std::string b = "POLYGON ((10 50, 60 50, 60 30, 30 30, 10 10, 10 50))";
+    std::string expected = "POLYGON ((30 30, 10 10, 10 30, 30 30))";
+// testPolygonTouchLPIntersection
+template<>
+template<>
+void object::test<4> ()
+    std::string b = "POLYGON ((40 25, 30 25, 30 20, 35 20, 30 15, 40 15, 40 25))";
+    std::string expected = "LINESTRING (30 25, 30 20)";
+// testLineTouchLPIntersection
+template<>
+template<>
+void object::test<5> ()
+    std::string a = "LINESTRING (10 10, 20 10, 20 20, 30 10)";
+    std::string b = "LINESTRING (10 10, 30 10)";
+    std::string expected = "LINESTRING (10 10, 20 10)";
+// testPolygonResultMixedIntersection
+template<>
+template<>
+void object::test<6> ()
+// testPolygonResultLineIntersection
+template<>
+template<>
+void object::test<7> ()
+    std::string a = "POLYGON ((10 20, 20 20, 20 10, 10 10, 10 20))";
+    std::string b = "POLYGON ((30 20, 30 10, 20 10, 20 20, 30 20))";
+    std::string expected = "LINESTRING (20 20, 20 10)";
+* Symmetric Difference is the one exception
+* to the Strict Mode homogeneous output rule.
+// testPolygonLineSymDifference
+template<>
+template<>
+void object::test<8> ()
+    std::string b = "LINESTRING (15 15, 25 15)";
+    std::string expected = "GEOMETRYCOLLECTION (POLYGON ((20 20, 20 15, 20 10, 10 10, 10 20, 20 20)), LINESTRING (20 15, 25 15))";
+    testOverlay(a, b, expected, OverlayNG::SYMDIFFERENCE);
+* Check that result does not include collapsed line intersection
+// testPolygonIntersectionCollapse
+template<>
+template<>
+void object::test<9> ()
+    std::string a = "POLYGON ((1 1, 1 5, 3 5, 3 2, 9 1, 1 1))";
+    std::string b = "POLYGON ((7 5, 9 5, 9 1, 7 1, 7 5))";
+    std::string expected = "POLYGON EMPTY";
+    testOverlay(a, b, expected, OverlayNG::INTERSECTION, 1.0);
+// testPolygonUnionCollapse
+template<>
+template<>
+void object::test<10> ()
+    std::string a = "POLYGON ((1 1, 1 5, 3 5, 3 1.4, 7 1, 1 1))";
+    std::string expected = "MULTIPOLYGON (((1 1, 1 5, 3 5, 3 1, 1 1)), ((7 1, 7 5, 9 5, 9 1, 7 1)))";
+    testOverlay(a, b, expected, OverlayNG::UNION, 1.0);
+// testPolygonLineUnion
+template<>
+template<>
+void object::test<11> ()
+    testOverlay(a, b, expected, OverlayNG::UNION);
+} // namespace tut
Summary of changes:
 .../operation/overlayng/IntersectionPointBuilder.h |  19 +-
 include/geos/operation/overlayng/LineBuilder.h     |  27 ++-
 include/geos/operation/overlayng/OverlayNG.h       |  52 +++---
 .../overlayng/IntersectionPointBuilder.cpp         |   3 +
 src/operation/overlayng/LineBuilder.cpp            |   4 +-
 src/operation/overlayng/OverlayNG.cpp              |  12 +-
 tests/unit/Makefile.am                             |   3 +-
 .../overlayng/OverlayNGStrictModeTest.cpp          | 194 +++++++++++++++++++++
 8 files changed, 282 insertions(+), 32 deletions(-)
 create mode 100644 tests/unit/operation/overlayng/OverlayNGStrictModeTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
