[geos-commits] [SCM] GEOS branch master updated. 23ce93fe1ed062fca0ad035fca54e0002570b7f0
Mon Sep 28 03:43:52 PDT 2020
the project "GEOS".
       via  23ce93fe1ed062fca0ad035fca54e0002570b7f0 (commit)
      from  14a18becb0c6ec1564241bdc9b41317b9b1c06dd (commit)
revisions in full, below.
commit 23ce93fe1ed062fca0ad035fca54e0002570b7f0
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Sep 28 12:40:35 2020 +0200
    Add test for ticket #960
    No exception is thrown, so this commit
    closes #960
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index cef4333..b2dc84f 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -394,5 +394,32 @@ void object::test<12>
     ensure(gBuffer->getNumPoints() >= std::size_t(expected_segments));
+// Test for ticket #960
+template<>
+template<>
+void object::test<13>
+    using geos::operation::buffer::BufferOp;
+    using geos::operation::buffer::BufferParameters;
+    std::string wkt0("MULTILINESTRING ((10 10, 20 20, 10 40), (40 40, 30 30, 40 20, 30 10))");
+    GeomPtr g0(wktreader.read(wkt0));
+    BufferParameters param;
+    param.setEndCapStyle(geos::operation::buffer::BufferParameters::CAP_FLAT);
+    param.setQuadrantSegments(6);
+    BufferOp op(g0.get(), param);
+    double const distance = 40.0;
+    GeomPtr gBuffer(op.getResultGeometry(distance));
+    ensure_not(gBuffer->isEmpty());
+    ensure(gBuffer->isValid());
+    ensure_equals(gBuffer->getGeometryTypeId(), geos::geom::GEOS_POLYGON);
 } // namespace tut
Summary of changes:
 tests/unit/operation/buffer/BufferOpTest.cpp | 27 +++++++++++++++++++++++++++
 1 file changed, 27 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
