[geos-commits] [SCM] GEOS branch master updated. 995b5574dc7117a1367393c4e1cf2eeb1387b2fc
git at osgeo.org
git at osgeo.org
Tue Jan 12 20:02:36 PST 2021
the project "GEOS".
via 995b5574dc7117a1367393c4e1cf2eeb1387b2fc (commit)
from f107c5b20bf5f1359e01a6a8a0265f3f99c64c9d (commit)
revisions in full, below.
commit 995b5574dc7117a1367393c4e1cf2eeb1387b2fc
Author: Martin Davis <mtnclimb at gmail.com>
Date: Tue Jan 12 20:03:33 2021 -0800
Add geosop normalize operation
diff --git a/util/geosop/GeomFunction.cpp b/util/geosop/GeomFunction.cpp
index 9e8d407..c818711 100644
--- a/util/geosop/GeomFunction.cpp
+++ b/util/geosop/GeomFunction.cpp
@@ -145,6 +145,12 @@ GeomFunction::init()
auto res = factory->createLineString( std::move(cs) );
return new Result( std::move(res) );
+ add("normalize", "normalizes geometry A", 1, 0,
+ [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d)->Result* {
+ auto res = geom->clone();
+ res->normalize();
+ return new Result( std::move(res) );
add("delaunay", "computes the Delaunay Triangulation of geometry A vertices", 1, 0,
@@ -189,10 +195,28 @@ GeomFunction::init()
return new Result( std::move(geoms) ) ;
+ add("reducePrecision", "reduces precision of geometry to a precision scale factor", 1, 1,
+ PrecisionModel pm(d);
+ return new Result( geos::precision::GeometryPrecisionReducer::reduce( *geom, pm ) );
+ add("relate", "computes DE-9IM matrix for geometry A and B", 2, 0,
+ std::unique_ptr<geom::IntersectionMatrix> im(geom->relate( geomB.get() ));
+ return new Result( im->toString() );
add("reverse", "reverses geometry A", 1, 0,
return new Result( geom->reverse() );
+ add("simplifyDP", "simplifies geometry A using Douglas-Peucker with a distance tolerance", 1, 1,
+ return new Result( geos::simplify::DouglasPeuckerSimplifier::simplify(geom.get(), d) );
+ add("simplifyTP", "simplifies geometry A using Douglas-Peucker with a distance tolerance, preserving topology", 1, 1,
+ return new Result( geos::simplify::TopologyPreservingSimplifier::simplify(geom.get(), d) );
add("containsPrep", "tests if geometry A contains geometry B, using PreparedGeometry", 2, 0,
@@ -261,25 +285,6 @@ GeomFunction::init()
- add("reducePrecision", "reduces precision of geometry to a precision scale factor", 1, 1,
- [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d)->Result* {
- PrecisionModel pm(d);
- return new Result( geos::precision::GeometryPrecisionReducer::reduce( *geom, pm ) );
- add("relate", "computes DE-9IM matrix for geometry A and B", 2, 0,
- std::unique_ptr<geom::IntersectionMatrix> im(geom->relate( geomB.get() ));
- return new Result( im->toString() );
- add("simplifyDP", "simplifies geometry A using Douglas-Peucker with a distance tolerance", 1, 1,
- return new Result( geos::simplify::DouglasPeuckerSimplifier::simplify(geom.get(), d) );
- add("simplifyTP", "simplifies geometry A using Douglas-Peucker with a distance tolerance, preserving topology", 1, 1,
- return new Result( geos::simplify::TopologyPreservingSimplifier::simplify(geom.get(), d) );
add("difference", "computes difference of geometry A from B", 2, 0,
Summary of changes:
util/geosop/GeomFunction.cpp | 43 ++++++++++++++++++++++++-------------------
1 file changed, 24 insertions(+), 19 deletions(-)
hooks/post-receive
More information about the geos-commits
