[geos-commits] [SCM] GEOS branch master updated. 841135eed82c7bfc1653a7ba77af5b8c82d9eaa7
Fri Jan 22 15:24:13 PST 2021
the project "GEOS".
       via  841135eed82c7bfc1653a7ba77af5b8c82d9eaa7 (commit)
      from  2c0c59b2cb89ace31b78f34ce09118701e2ebaad (commit)
revisions in full, below.
commit 841135eed82c7bfc1653a7ba77af5b8c82d9eaa7
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Jan 22 15:23:28 2021 -0800
    Add filled-in simple examples with comments, and a few changes
    to the CAPI doco
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index e5e478b..d0c0e90 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -124,26 +124,48 @@ typedef void (*GEOSMessageHandler_r)(const char *message, void *userdata);
 * those clients don't have access to the original C++ headers, by design.
 #ifndef GEOSGeometry
-Geometry generic type. Geometry can be a point, linestring, polygon,
-multipoint, multilinestring, multipolygon, or geometrycollection.
-Geometry type can be read with \ref GEOSGeomTypeId. Most functions
-in GEOS either have GEOSGeometry* as a parameter or a return type.
-\see GEOSGeom_createPoint
-\see GEOSGeom_createLineString
-\see GEOSGeom_createPolygon
-\see GEOSGeom_createCollection
-\see GEOSGeom_destroy
+* Geometry generic type. Geometry can be a point, linestring, polygon,
+* multipoint, multilinestring, multipolygon, or geometrycollection.
+* Geometry type can be read with \ref GEOSGeomTypeId. Most functions
+* in GEOS either have GEOSGeometry* as a parameter or a return type.
+* \see GEOSGeom_createPoint
+* \see GEOSGeom_createLineString
+* \see GEOSGeom_createPolygon
+* \see GEOSGeom_createCollection
+* \see GEOSGeom_destroy
 typedef struct GEOSGeom_t GEOSGeometry;
-/** Prepared geometry type. \see GEOSPrepare */
+* Prepared geometry type.
+* \see GEOSPrepare()
+* \see GEOSPreparedGeom_destroy()
 typedef struct GEOSPrepGeom_t GEOSPreparedGeometry;
-/** Coordinate sequence. \see GEOSCoordSeq_create */
+* Coordinate sequence.
+* \see GEOSCoordSeq_create()
+* \see GEOSCoordSeq_destroy()
 typedef struct GEOSCoordSeq_t GEOSCoordSequence;
-/** STRTree index. \see GEOSSTRtree_create */
+* STRTree index.
+* \see GEOSSTRtree_create()
+* \see GEOSSTRtree_destroy()
 typedef struct GEOSSTRtree_t GEOSSTRtree;
-/** Paramter object for buffering. \see GEOSBufferParams_create */
+* Paramter object for buffering.
+* \see GEOSBufferParams_create()
+* \see GEOSBufferParams_destroy()
 typedef struct GEOSBufParams_t GEOSBufferParams;
 #endif
 /** \cond */
@@ -1440,14 +1462,35 @@ extern int GEOS_DLL GEOSOrientationIndex_r(
 /* ========== Reader and Writer APIs ========== */
 #ifndef GEOSWKTReader
-/** Reader object to read Well-Known Text (WKT) format and construct Geometry. */
+* Reader object to read Well-Known Text (WKT) format and construct Geometry.
+* \see GEOSWKTReader_create
+* \see GEOSWKTReader_create_r
 typedef struct GEOSWKTReader_t GEOSWKTReader;
-/** Writer object to turn Geometry into Well-Known Text (WKT). */
+* Writer object to turn Geometry into Well-Known Text (WKT).
+* \see GEOSWKTWriter_create
+* \see GEOSWKTWriter_create_r
 typedef struct GEOSWKTWriter_t GEOSWKTWriter;
-/** Reader object to read Well-Known Binary (WKB) format and construct Geometry. */
+* Reader object to read Well-Known Binary (WKB) format and construct Geometry.
+* \see GEOSWKBReader_create
+* \see GEOSWKBReader_create_r
 typedef struct GEOSWKBReader_t GEOSWKBReader;
-/** Writer object to turn Geometry into Well-Known Binary (WKB). */
+* Writer object to turn Geometry into Well-Known Binary (WKB).
+* \see GEOSWKBWriter_create
+* \see GEOSWKBWriter_create_r
 typedef struct GEOSWKBWriter_t GEOSWKBWriter;
 #endif
 /* ========== WKT Reader ========== */
diff --git a/examples/client/CMakeLists.txt b/examples/CMakeLists.txt
similarity index 56%
rename from examples/client/CMakeLists.txt
rename to examples/CMakeLists.txt
index b6106c6..c72e8c5 100644
--- a/examples/client/CMakeLists.txt
+++ b/examples/CMakeLists.txt
@@ -11,10 +11,16 @@
 cmake_minimum_required(VERSION 3.12)
 project(GEOS VERSION 1.0.0 LANGUAGES C CXX)
-find_package(GEOS 3.8 REQUIRED)
+find_package(GEOS 3.9 REQUIRED)
-add_executable(geos_client geos_client.cpp)
-target_link_libraries(geos_client PRIVATE GEOS::geos)
+add_executable(cpp_read cpp_read.cpp)
+target_link_libraries(cpp_read PRIVATE GEOS::geos)
-add_executable(geos_c_client geos_c_client.cpp)
-target_link_libraries(geos_c_client PRIVATE GEOS::geos_c)
+add_executable(capi_read capi_read.cpp)
+target_link_libraries(capi_read PRIVATE GEOS::geos_c)
+add_executable(capi_prepared capi_prepared.cpp)
+target_link_libraries(capi_prepared PRIVATE GEOS::geos_c)
+add_executable(capi_read_ts capi_read_ts.cpp)
+target_link_libraries(capi_read_ts PRIVATE GEOS::geos_c)
diff --git a/examples/README.md b/examples/README.md
new file mode 100644
index 0000000..ddfbe48
--- /dev/null
+++ b/examples/README.md
@@ -0,0 +1,15 @@
+# GEOS Example Programs
+* `capi_read` uses the standard C API to read two WKT geometries, calculate the intersection and print the result
+* `capi_read_ts` uses the "re-entrant" C API (threadsafe) to read two WKT geometries, calculate the intersection and print the result
+* `cpp_read` uses the C++ API to read two WKT geometries, calculate the intersection and print the result
+* `capi_prepared` uses the standard C API to read one WKT geometry, and fill it with a point grid, applying a high performance "prepared" geometry to speed up intersection testing
+## Build
+mkdir _build
+cd _build
+cmake ..
+make
diff --git a/examples/capi_prepared.cpp b/examples/capi_prepared.cpp
index 0000000..a1ffd12
--- /dev/null
+++ b/examples/capi_prepared.cpp
@@ -0,0 +1,137 @@
+* # GEOS C API example 2
+* Reads one geometry and does a high-performance
+* prepared geometry operations to place random
+* points inside it.
+/* To print to stdout */
+#include <stdio.h>
+#include <stdarg.h>
+#include <stdlib.h>
+/* Only the CAPI header is required */
+#include <geos_c.h>
+* GEOS requires two message handlers to return
+* error and notice message to the calling program.
+*   typedef void(* GEOSMessageHandler) (const char *fmt,...)
+* Here we stub out an example that just prints the
+* messages to stdout.
+static void
+geos_message_handler(const char* fmt, ...)
+    va_list ap;
+    va_start(ap, fmt);
+    vprintf (fmt, ap);
+    va_end(ap);
+int main()
+    /* Send notice and error messages to our stdout handler */
+    initGEOS(geos_message_handler, geos_message_handler);
+    /* One concave polygon */
+    const char* wkt = "POLYGON ((189 115, 200 170, 130 170, 35 242, 156 215, 210 290, 274 256, 360 190, 267 215, 300 50, 200 60, 189 115))";
+    /* Read the WKT into geometry objects */
+    GEOSWKTReader* reader = GEOSWKTReader_create();
+    GEOSGeometry* geom = GEOSWKTReader_read(reader, wkt);
+    GEOSWKTReader_destroy(reader);
+    /* Check for parse success */
+    if (!geom) {
+        finishGEOS();
+        return 1;
+    /* Prepare the geometry */
+    const GEOSPreparedGeometry* prep_geom = GEOSPrepare(geom);
+    /* Read bounds of geometry */
+    double xmin, xmax, ymin, ymax;
+    GEOSGeom_getXMin(geom, &xmin);
+    GEOSGeom_getXMax(geom, &xmax);
+    GEOSGeom_getYMin(geom, &ymin);
+    GEOSGeom_getYMax(geom, &ymax);
+    * Set up the point generator
+    * Generate all the points in the bounding box
+    * of the input polygon.
+    const int steps = 10;
+    double xstep = (xmax - xmin) / steps;
+    double ystep = (ymax - ymin) / steps;
+    /* Place to hold points to output */
+    GEOSGeometry** geoms = (GEOSGeometry**)malloc(steps*steps*sizeof(GEOSGeometry*));
+    size_t ngeoms = 0;
+    * Test all the points in the polygon bounding box
+    * and only keep those that intersect the actual polygon
+    int i, j;
+    for (i = 0; i < steps; i++) {
+        for (j = 0; j < steps; j++) {
+            /* Make a point in the point grid */
+            GEOSGeometry* pt = GEOSGeom_createPointFromXY(
+                                    xmin + xstep*i,
+                                    ymin + ystep*j);
+            /* Check if the point and polygon intersect */
+            if (GEOSPreparedIntersects(prep_geom, pt)) {
+                /* Save the ones that do */
+                geoms[ngeoms++] = pt;
+            else {
+                /* Clean up the ones that don't */
+                GEOSGeom_destroy(pt);
+    /* Put the successful geoms inside a geometry for WKT output */
+    GEOSGeometry* result = GEOSGeom_createCollection(GEOS_MULTIPOINT, geoms, ngeoms);
+    * The GEOSGeom_createCollection() only takes ownership of the
+    * geometries, not the array container, so we can free the container
+    * now
+    free(geoms);
+    /* Convert result to WKT */
+    GEOSWKTWriter* writer = GEOSWKTWriter_create();
+    /* Trim trailing zeros off output */
+    GEOSWKTWriter_setTrim(writer, 1);
+    GEOSWKTWriter_setRoundingPrecision(writer, 3);
+    char* wkt_result = GEOSWKTWriter_write(writer, result);
+    GEOSWKTWriter_destroy(writer);
+    /* Print answer */
+    printf("Input Polygon:\n");
+    printf("%s\n\n", wkt);
+    printf("Output Points:\n");
+    printf("%s\n\n", wkt_result);
+    /* Clean up everything we allocated */
+    GEOSPreparedGeom_destroy(prep_geom);
+    GEOSGeom_destroy(geom);
+    GEOSGeom_destroy(result);
+    GEOSFree(wkt_result);
+    /* Clean up the global context */
+    finishGEOS();
+    /* Done */
+    return 0;
diff --git a/examples/capi_read.cpp b/examples/capi_read.cpp
index 0000000..691dd9b
--- /dev/null
+++ b/examples/capi_read.cpp
@@ -0,0 +1,75 @@
+* # GEOS C API example 1
+* Reads two WKT representations and calculates the
+* intersection, prints it out, and cleans up.
+#include <stdio.h>
+static void
+    va_list ap;
+    va_end(ap);
+int main()
+    /* Two squares that overlap */
+    const char* wkt_a = "POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))";
+    const char* wkt_b = "POLYGON((5 5, 15 5, 15 15, 5 15, 5 5))";
+    GEOSGeometry* geom_a = GEOSWKTReader_read(reader, wkt_a);
+    GEOSGeometry* geom_b = GEOSWKTReader_read(reader, wkt_b);
+    /* Calculate the intersection */
+    GEOSGeometry* inter = GEOSIntersection(geom_a, geom_b);
+    char* wkt_inter = GEOSWKTWriter_write(writer, inter);
+    printf("Geometry A:         %s\n", wkt_a);
+    printf("Geometry B:         %s\n", wkt_b);
+    printf("Intersection(A, B): %s\n", wkt_inter);
+    GEOSGeom_destroy(geom_a);
+    GEOSGeom_destroy(geom_b);
+    GEOSGeom_destroy(inter);
+    GEOSFree(wkt_inter);
+    finishGEOS();
+    /* Done */
+    return 0;
diff --git a/examples/capi_read_ts.cpp b/examples/capi_read_ts.cpp
index 0000000..b351159
--- /dev/null
+++ b/examples/capi_read_ts.cpp
@@ -0,0 +1,86 @@
+* Thread-safe version of example 1. Uses the
+* re-entrant API.
+#include <stdio.h>
+static void
+    va_list ap;
+    va_end(ap);
+int main()
+    * Each thread using the re-entrant API must get its
+    * own context handle
+    GEOSContextHandle_t context = GEOS_init_r();
+    * The notice/error handlers route message back to the calling
+    * application. Here they just print to stdout.
+    GEOSContext_setNoticeHandler_r(context, geos_message_handler);
+    GEOSContext_setErrorHandler_r(context, geos_message_handler);
+    GEOSWKTReader* reader = GEOSWKTReader_create_r(context);
+    GEOSGeometry* geom_a = GEOSWKTReader_read_r(context, reader, wkt_a);
+    GEOSGeometry* geom_b = GEOSWKTReader_read_r(context, reader, wkt_b);
+    GEOSGeometry* inter = GEOSIntersection_r(context, geom_a, geom_b);
+    GEOSWKTWriter* writer = GEOSWKTWriter_create_r(context);
+    char* wkt_inter = GEOSWKTWriter_write_r(context, writer, inter);
+    GEOSWKTReader_destroy_r(context, reader);
+    GEOSWKTWriter_destroy_r(context, writer);
+    GEOSGeom_destroy_r(context, geom_a);
+    GEOSGeom_destroy_r(context, geom_b);
+    GEOSGeom_destroy_r(context, inter);
+    GEOSFree_r(context, wkt_inter);
+    GEOS_finish_r(context);
+    /* Done */
+    return 0;
diff --git a/examples/client/geos_c_client.cpp b/examples/client/geos_c_client.cpp
deleted file mode 100644
index 7b1be59..0000000
--- a/examples/client/geos_c_client.cpp
+++ /dev/null
@@ -1,6 +0,0 @@
-#include <geos_c.h>
-int main()
-    finishGEOS();
\ No newline at end of file
diff --git a/examples/client/geos_client.cpp b/examples/client/geos_client.cpp
index d880ee0..0000000
--- a/examples/client/geos_client.cpp
+++ /dev/null
@@ -1,8 +0,0 @@
-#include <geos/geom/GeometryFactory.h>
-using namespace geos::geom;
-int main()
-    GeometryFactory::Ptr factory = GeometryFactory::create();
-    (void)factory;
diff --git a/examples/cpp_read.cpp b/examples/cpp_read.cpp
index 0000000..ec31a4c
--- /dev/null
+++ b/examples/cpp_read.cpp
@@ -0,0 +1,60 @@
+* # GEOS C++ example 1
+* In general, to avoid API changes, stick to operations
+* on Geometry. The more esoteric APIs are more likely
+* to change between versions.
+#include <iostream>
+/* For geometry operations */
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h>
+/* For WKT read/write */
+#include <geos/io/WKTReader.h>
+#include <geos/io/WKTWriter.h>
+/* Geometry/GeometryFactory */
+using namespace geos::geom;
+/* WKTReader/WKTWriter */
+using namespace geos::io;
+int main()
+    /* New factory with default (float) precision model */
+    GeometryFactory::Ptr factory = GeometryFactory::create();
+    * Reader requires a factory to bind the geometry to
+    * for shared resources like the PrecisionModel
+    WKTReader reader(*factory);
+    /* Input WKT strings */
+    std::string wkt_a("POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))");
+    std::string wkt_b("POLYGON((5 5, 15 5, 15 15, 5 15, 5 5))");
+    /* Convert WKT to Geometry */
+    std::unique_ptr<Geometry> geom_a(reader.read(wkt_a));
+    std::unique_ptr<Geometry> geom_b(reader.read(wkt_b));
+    /* Calculate intersection */
+    std::unique_ptr<Geometry> inter = geom_a->intersection(geom_b.get());
+    /* Convert Geometry to WKT */
+    WKTWriter writer;
+    writer.setTrim(true);
+    std::string inter_wkt = writer.write(inter.get());
+    /* Print out results */
+    std::cout << "Geometry A:         " << wkt_a << std::endl;
+    std::cout << "Geometry B:         " << wkt_b << std::endl;
+    std::cout << "Intersection(A, B): " << inter_wkt << std::endl;
Summary of changes:
 capi/geos_c.h.in                     |  77 +++++++++++++++-----
 examples/{client => }/CMakeLists.txt |  16 ++--
 examples/README.md                   |  15 ++++
 examples/capi_prepared.cpp           | 137 +++++++++++++++++++++++++++++++++++
 examples/capi_read.cpp               |  75 +++++++++++++++++++
 examples/capi_read_ts.cpp            |  86 ++++++++++++++++++++++
 examples/client/geos_c_client.cpp    |   6 --
 examples/client/geos_client.cpp      |   8 --
 examples/cpp_read.cpp                |  60 +++++++++++++++
 9 files changed, 444 insertions(+), 36 deletions(-)
 rename examples/{client => }/CMakeLists.txt (56%)
 create mode 100644 examples/README.md
 create mode 100644 examples/capi_prepared.cpp
 create mode 100644 examples/capi_read.cpp
 create mode 100644 examples/capi_read_ts.cpp
 delete mode 100644 examples/client/geos_c_client.cpp
 delete mode 100644 examples/client/geos_client.cpp
 create mode 100644 examples/cpp_read.cpp
hooks/post-receive
More information about the geos-commits mailing list
