[geos-commits] [SCM] GEOS branch master updated. 7f673661bc4a5a56aa8cd24bd66d2428c432157b
git at osgeo.org
git at osgeo.org
Fri Jan 22 16:21:24 PST 2021
the project "GEOS".
via 7f673661bc4a5a56aa8cd24bd66d2428c432157b (commit)
from dcf4f0b9fa4bd9ff02755889a482be9ee5a444b7 (commit)
revisions in full, below.
commit 7f673661bc4a5a56aa8cd24bd66d2428c432157b
Author: Daniel Baston <dbaston at gmail.com>
Date: Fri Jan 22 19:20:42 2021 -0500
Remove old example program
Superseded by programs in example dir using modern conventions.
diff --git a/doc/CMakeLists.txt b/doc/CMakeLists.txt
index b7e6d33..f88fba3 100644
--- a/doc/CMakeLists.txt
+++ b/doc/CMakeLists.txt
@@ -10,9 +10,6 @@
# See the COPYING file for more information.
-add_executable(example example.cpp)
-target_link_libraries(example PRIVATE geos)
if(BUILD_TESTING)
target_include_directories(test_geos_unit
PRIVATE
diff --git a/doc/example.cpp b/doc/example.cpp
deleted file mode 100644
index a011cfb..0000000
--- a/doc/example.cpp
+++ /dev/null
@@ -1,1154 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
- * Copyright (C) 2005 Refractions Research Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * This file should document by example usage of the GEOS library.
- * It could actually be a live discuss-by-example board for
- * architectural design choices.
- * --strk;
- * DEBUGGING TIPS:
- * use -D__USE_MALLOC at compile time for gcc 2.91, 2.95, 3.0 and 3.1
- * and GLIBCXX_FORCE_NEW or GLIBCPP_FORCE_NEW at run time with gcc 3.2.2+
- * to force libstdc++ avoid caching memory. This should remove some
- * obscure reports from memory checkers like valgrind.
-#include <geos/geom/PrecisionModel.h>
-#include <geos/geom/GeometryFactory.h>
-#include <geos/geom/Geometry.h>
-#include <geos/geom/Point.h>
-#include <geos/geom/LinearRing.h>
-#include <geos/geom/LineString.h>
-#include <geos/geom/Polygon.h>
-#include <geos/geom/GeometryCollection.h>
-#include <geos/geom/Coordinate.h>
-#include <geos/geom/CoordinateSequence.h>
-#include <geos/geom/CoordinateArraySequence.h>
-#include <geos/geom/IntersectionMatrix.h>
-#include <geos/io/WKBReader.h>
-#include <geos/io/WKBWriter.h>
-#include <geos/io/WKTWriter.h>
-#include <geos/util/GeometricShapeFactory.h>
-#include <geos/geom/util/SineStarFactory.h>
-#include <geos/util/GEOSException.h>
-#include <geos/util/IllegalArgumentException.h>
-#include <geos/operation/linemerge/LineMerger.h>
-#include <geos/operation/polygonize/Polygonizer.h>
-#include <geos/constants.h>
-#include <vector>
-#include <sstream>
-#include <iomanip>
-#include <cstdlib> // exit()
-// Set to 0 to skip section
-#define GEOMETRIC_SHAPES 1
-#define RELATIONAL_OPERATORS 1
-#define COMBINATIONS 1
-#define UNARY_OPERATIONS 1
-#define LINEMERGE 1
-#define POLYGONIZE 1
-using namespace geos;
-using namespace geos::geom;
-using namespace geos::operation::polygonize;
-using namespace geos::operation::linemerge;
-using geos::util::GEOSException;
-using geos::util::IllegalArgumentException;
-// Prototypes
-void wkt_print_geoms(std::vector<const Geometry*>* geoms);
-// This object will be used to construct our geometries.
-// It might be bypassed by directly call geometry constructors,
-// but that would be boring because you'd need to specify
-// a PrecisionModel and a SRID everytime: those infos are
-// cached inside a GeometryFactory object.
-GeometryFactory::Ptr global_factory;
-//#define DEBUG_STREAM_STATE 1
-// This function tests writing and reading WKB
-// TODO:
-// - compare input and output geometries for equality
-// - remove debugging lines (on stream state)
-void
-WKBtest(std::vector<const Geometry*>* geoms)
- std::stringstream s(std::ios_base::binary | std::ios_base::in | std::ios_base::out);
- io::WKBReader wkbReader(*global_factory);
- io::WKBWriter wkbWriter;
- Geometry* gout;
-#if DEBUG_STREAM_STATE
- std::cout << "WKBtest: machine byte order: " << BYTE_ORDER << std::endl;
-#endif
- std::size_t ngeoms = geoms->size();
- for(unsigned int i = 0; i < ngeoms; ++i) {
- const Geometry* gin = (*geoms)[i];
- std::cout << "State of stream before WRITE: ";
- std::cout << "p:" << s.tellp() << " g:" << s.tellg() <<
- " good:" << s.good() <<
- " eof:" << s.eof() <<
- " bad:" << s.bad() <<
- " fail:" << s.fail() << std::endl;
-#endif
- std::cout << "State of stream after SEEKP: ";
-#endif
- wkbWriter.write(*gin, s);
- std::cout << "wkbWriter wrote and reached ";
- std::cout << "p:" << s.tellp() << " g:" << s.tellg() << std::endl;
- std::cout << "State of stream before DUMP: ";
-#endif
- std::cout << "State of stream after DUMP: ";
-#endif
- s.seekg(0, std::ios::beg); // rewind reader pointer
- std::cout << "State of stream before READ: ";
-#endif
- gout = wkbReader.read(s).release();
- std::cout << "State of stream after READ: ";
-#endif
- const_cast<Geometry*>(gin)->normalize();
- gout->normalize();
- int failed = gin->compareTo(gout);
- if(failed) {
- std::cout << "{" << i << "} (WKB) ";
- else {
- std::cout << "[" << i << "] (WKB) ";
- io::WKBReader::printHEX(s, std::cout);
- std::cout << std::endl;
- if(failed) {
- io::WKTWriter wkt;
- std::cout << " IN: " << wkt.write(gin) << std::endl;
- std::cout << " OUT: " << wkt.write(gout) << std::endl;
- s.seekp(0, std::ios::beg); // rewind writer pointer
- delete gout;
-// This function will print given geometries in WKT
-// format to stdout. As a side-effect, will test WKB
-// output and input, using the WKBtest function.
-void
-wkt_print_geoms(std::vector<const Geometry*>* geoms)
- WKBtest(geoms); // test WKB parser
- // WKT-print given geometries
- io::WKTWriter* wkt = new io::WKTWriter();
- for(unsigned int i = 0; i < geoms->size(); i++) {
- const Geometry* g = (*geoms)[i];
- std::string tmp = wkt->write(g);
- std::cout << "[" << i << "] (WKT) " << tmp << std::endl;
- delete wkt;
-// This is the simpler geometry you can get: a point.
-Point*
-create_point(double x, double y)
- Coordinate c(x, y);
- Point* p = global_factory->createPoint(c);
- return p;
-// This function will create a LinearString
-// geometry with the shape of the letter U
-// having top-left corner at given coordinates
-// and 'side' height and width
-LineString*
-create_ushaped_linestring(double xoffset, double yoffset, double side)
- // We will use a coordinate list to build the linestring
- CoordinateArraySequence* cl = new CoordinateArraySequence();
- cl->add(Coordinate(xoffset, yoffset));
- cl->add(Coordinate(xoffset, yoffset + side));
- cl->add(Coordinate(xoffset + side, yoffset + side));
- cl->add(Coordinate(xoffset + side, yoffset));
- // Now that we have a CoordinateSequence we can create
- // the linestring.
- // The newly created LineString will take ownership
- // of the CoordinateSequence.
- LineString* ls = global_factory->createLineString(cl);
- // This is what you do if you want the new LineString
- // to make a copy of your CoordinateSequence:
- // LineString *ls = global_factory->createLineString(*cl);
- return ls; // our LineString
-// This function will create a LinearRing
-// geometry representing a square with the given origin
-// and side
-LinearRing*
-create_square_linearring(double xoffset, double yoffset, double side)
- // We will use a coordinate list to build the linearring
- // the linearring.
- // The newly created LinearRing will take ownership
- LinearRing* lr = global_factory->createLinearRing(cl);
- // This is what you do if you want the new LinearRing
- // LinearRing *lr = global_factory->createLinearRing(*cl);
- return lr; // our LinearRing
-// This function will create a Polygon
-// and side and with a central hole 1/3 sided.
-Polygon*
-create_square_polygon(double xoffset, double yoffset, double side)
- // We need a LinearRing for the polygon shell
- LinearRing* outer = create_square_linearring(xoffset, yoffset, side);
- // And another for the hole
- LinearRing* inner = create_square_linearring(xoffset + (side / 3),
- yoffset + (side / 3), (side / 3));
- // If we need to specify any hole, we do it using
- // a vector of LinearRing pointers
- std::vector<LinearRing*>* holes = new std::vector<LinearRing*>;
- // We add the newly created geometry to the vector
- // of holes.
- holes->push_back(inner);
- // And finally we call the polygon constructor.
- // Both the outer LinearRing and the vector of holes
- // will be referenced by the resulting Polygon object,
- // thus we CANNOT delete them, neither the holes, nor
- // the vector containing their pointers, nor the outer
- // LinearRing. Everything will be deleted at Polygon
- // deletion time (this is inconsistent with LinearRing
- // behaviour... what should we do?).
- Polygon* poly = global_factory->createPolygon(outer, holes);
- return poly;
-// This function will create a GeometryCollection
-// containing copies of all Geometries in given vector.
-GeometryCollection*
-create_simple_collection(std::vector<const Geometry*>* geoms)
- return global_factory->createGeometryCollection(*geoms);
- // if you wanted to transfer ownership of vector end
- // its elements you should have call:
- // return global_factory->createGeometryCollection(geoms);
-// This function uses GeometricShapeFactory to render
-// a circle having given center and radius
-Polygon*
-create_circle(double centerX, double centerY, double radius)
- geos::util::GeometricShapeFactory shapefactory(global_factory.get());
- shapefactory.setCentre(Coordinate(centerX, centerY));
- shapefactory.setSize(radius);
- // same as:
- // shapefactory.setHeight(radius);
- // shapefactory.setWidth(radius);
- return shapefactory.createCircle().release();
-// an ellipse having given center and axis size
-Polygon*
-create_ellipse(double centerX, double centerY, double width, double height)
- shapefactory.setHeight(height);
- shapefactory.setWidth(width);
-// a rectangle having lower-left corner at given coordinates
-// and given sizes.
-Polygon*
-create_rectangle(double llX, double llY, double width, double height)
- shapefactory.setBase(Coordinate(llX, llY));
- shapefactory.setNumPoints(4); // we don't need more then 4 points for a rectangle...
- // can use setSize for a square
- return shapefactory.createRectangle().release();
-// an arc having lower-left corner at given coordinates,
-// given sizes and given angles.
-LineString*
-create_arc(double llX, double llY, double width, double height, double startang, double endang)
- // shapefactory.setNumPoints(100); // the default (100 pts)
- return shapefactory.createArc(startang, endang).release();
-std::unique_ptr<Polygon>
-create_sinestar(double cx, double cy, double size, int nArms, double armLenRat)
- geos::geom::util::SineStarFactory fact(global_factory.get());
- fact.setCentre(Coordinate(cx, cy));
- fact.setSize(size);
- fact.setNumPoints(nArms * 5);
- fact.setArmLengthRatio(armLenRat);
- fact.setNumArms(nArms);
- return fact.createSineStar();
-// Start reading here
-void
-do_all()
- std::vector<const Geometry*>* geoms = new std::vector<const Geometry*>;
- std::vector<const Geometry*>* newgeoms;
- // Define a precision model using 0,0 as the reference origin
- // and 2.0 as coordinates scale.
- PrecisionModel* pm = new PrecisionModel(2.0, 0, 0);
- // Initialize global factory with defined PrecisionModel
- // and a SRID of -1 (undefined).
- global_factory = GeometryFactory::create(pm, -1);
- // We do not need PrecisionMode object anymore, it has
- // been copied to global_factory private storage
- delete pm;
-// GEOMETRY CREATION
- // Read function bodies to see the magic behind them
- geoms->push_back(create_point(150, 350));
- geoms->push_back(create_square_linearring(0, 0, 100));
- geoms->push_back(create_ushaped_linestring(60, 60, 100));
- geoms->push_back(create_square_polygon(0, 200, 300));
- geoms->push_back(create_square_polygon(0, 250, 300));
- geoms->push_back(create_simple_collection(geoms));
-#if GEOMETRIC_SHAPES
- // These ones use a GeometricShapeFactory
- geoms->push_back(create_circle(0, 0, 10));
- geoms->push_back(create_ellipse(0, 0, 8, 12));
- geoms->push_back(create_rectangle(-5, -5, 10, 10)); // a square
- geoms->push_back(create_rectangle(-5, -5, 10, 20)); // a rectangle
- // The upper-right quarter of a vertical ellipse
- geoms->push_back(create_arc(0, 0, 10, 20, 0, MATH_PI / 2));
- geoms->push_back(create_sinestar(10, 10, 100, 5, 2).release()); // a sine star
-#endif
- // Print all geoms.
- std::cout << "--------HERE ARE THE BASE GEOMS ----------" << std::endl;
- wkt_print_geoms(geoms);
-#if UNARY_OPERATIONS
-// UNARY OPERATIONS
- // CENTROID
- // Find centroid of each base geometry
- newgeoms = new std::vector<const Geometry*>;
- newgeoms->push_back(g->getCentroid().release());
- // Print all convex hulls
- std::cout << std::endl << "------- AND HERE ARE THEIR CENTROIDS -----" << std::endl;
- wkt_print_geoms(newgeoms);
- // Delete the centroids
- for(unsigned int i = 0; i < newgeoms->size(); i++) {
- delete(*newgeoms)[i];
- delete newgeoms;
- // BUFFER
- try {
- Geometry* g2 = g->buffer(10).release();
- newgeoms->push_back(g2);
- catch(const GEOSException& exc) {
- std::cerr << "GEOS Exception: geometry " << i << "->buffer(10): " << exc.what() << "\n";
- std::cout << std::endl << "--------HERE COMES THE BUFFERED GEOMS ----------" << std::endl;
- delete newgeoms;
- // CONVEX HULL
- // Make convex hulls of geometries
- newgeoms->push_back(g->convexHull().release());
- std::cout << std::endl << "--------HERE COMES THE HULLS----------" << std::endl;
- // Delete the hulls
- delete newgeoms;
-#endif // UNARY_OPERATIONS
-#if RELATIONAL_OPERATORS
-// RELATIONAL OPERATORS
- std::cout << "-------------------------------------------------------------------------------" << std::endl;
- std::cout << "RELATIONAL OPERATORS" << std::endl;
- // DISJOINT
- std::cout << " DISJOINT ";
- std::cout << "\t[" << i << "]";
- const Geometry* g1 = (*geoms)[i];
- std::cout << " [" << i << "]\t";
- for(unsigned int j = 0; j < geoms->size(); j++) {
- const Geometry* g2 = (*geoms)[j];
- try {
- if(g1->disjoint(g2)) {
- std::cout << " 1\t";
- else {
- std::cout << " 0\t";
- // Geometry Collection is not a valid argument
- catch(const IllegalArgumentException&) {
- std::cout << " X\t";
- catch(const std::exception& exc) {
- std::cerr << exc.what() << std::endl;
- // TOUCHES
- std::cout << " TOUCHES ";
- try {
- if(g1->touches(g2)) {
- else {
- // INTERSECTS
- std::cout << " INTERSECTS ";
- try {
- if(g1->intersects(g2)) {
- else {
- // CROSSES
- std::cout << " CROSSES ";
- try {
- if(g1->crosses(g2)) {
- else {
- // WITHIN
- std::cout << " WITHIN ";
- try {
- if(g1->within(g2)) {
- else {
- // CONTAINS
- std::cout << " CONTAINS ";
- try {
- if(g1->contains(g2)) {
- else {
- // OVERLAPS
- std::cout << " OVERLAPS ";
- try {
- if(g1->overlaps(g2)) {
- else {
- // RELATE
- std::cout << " RELATE ";
- try {
- // second argument is intersectionPattern
- std::string pattern = "212101212";
- if(g1->relate(g2, pattern)) {
- else {
- // get the intersectionMatrix itself
- auto im = g1->relate(g2);
- // EQUALS
- std::cout << " EQUALS ";
- try {
- if(g1->equals(g2)) {
- else {
- // EQUALS_EXACT
- std::cout << "EQUALS_EXACT ";
- try {
- // second argument is a tolerance
- if(g1->equalsExact(g2, 0.5)) {
- else {
- // IS_WITHIN_DISTANCE
- std::cout << "IS_WITHIN_DIST";
- try {
- // second argument is the distance
- if(g1->isWithinDistance(g2, 2)) {
- else {
-#endif // RELATIONAL_OPERATORS
-#if COMBINATIONS
-// COMBINATIONS
- std::cout << "COMBINATIONS" << std::endl;
- // UNION
- // Make unions of all geoms
- for(unsigned int i = 0; i < geoms->size() - 1; i++) {
- for(unsigned int j = i + 1; j < geoms->size(); j++) {
- try {
- Geometry* g3 = g1->Union(g2).release();
- newgeoms->push_back(g3);
- // It's illegal to union a collection ...
- //std::cerr <<ill.toString()<<"\n";
- // Print all unions
- std::cout << std::endl << "----- AND HERE ARE SOME UNION COMBINATIONS ------" << std::endl;
- // Delete the resulting geoms
- delete newgeoms;
- // INTERSECTION
- // Compute intersection of adjacent geometries
- try {
- Geometry* g3 = g1->intersection(g2).release();
- // Collection are illegal as intersection argument
- std::cout << std::endl << "----- HERE ARE SOME INTERSECTIONS COMBINATIONS ------" << std::endl;
- delete newgeoms;
- // DIFFERENCE
- // Compute difference of adjacent geometries
- try {
- Geometry* g3 = g1->difference(g2).release();
- // Collection are illegal as difference argument
- std::cout << std::endl << "----- HERE ARE SOME DIFFERENCE COMBINATIONS ------" << std::endl;
- delete newgeoms;
- // SYMMETRIC DIFFERENCE
- // Compute symmetric difference of adjacent geometries
- try {
- Geometry* g3 = g1->symDifference(g2).release();
- // Collection are illegal as symdifference argument
- std::cout << std::endl << "----- HERE ARE SYMMETRIC DIFFERENCES ------" << std::endl;
- delete newgeoms;
-#endif // COMBINATIONS
-#if LINEMERGE
- // LINEMERGE
- LineMerger lm;
- lm.add(geoms);
- auto mls = lm.getMergedLineStrings();
- for(unsigned int i = 0; i < mls.size(); i++) {
- newgeoms->push_back(mls[i].release());
- std::cout << std::endl << "----- HERE IS THE LINEMERGE OUTPUT ------" << std::endl;
- delete newgeoms;
-#endif // LINEMERGE
-#if POLYGONIZE
- // POLYGONIZE
- Polygonizer plgnzr;
- plgnzr.add(geoms);
- auto polys = plgnzr.getPolygons();
- for(unsigned int i = 0; i < polys.size(); i++) {
- newgeoms->push_back(polys[i].release());
- std::cout << std::endl << "----- HERE IS POLYGONIZE OUTPUT ------" << std::endl;
- delete newgeoms;
-#endif // POLYGONIZE
- // CLEANUP
- // Delete base geometries
- delete(*geoms)[i];
- delete geoms;
-int
-main()
- std::cout << "GEOS " << geosversion() << " ported from JTS " << jtsport() << std::endl;
- try {
- do_all();
- // All exception thrown by GEOS are subclasses of this
- // one, so this is a catch-all
- std::cerr << "GEOS Exception: " << exc.what() << "\n";
- exit(1);
- catch(const std::exception& e) {
- std::cerr << "Standard exception thrown: " << e.what() << std::endl;
- exit(1);
- // and this is a catch-all non standard ;)
- catch(...) {
- std::cerr << "unknown exception trown!\n";
- exit(1);
- // Unload is no more necessary
- //io::Unload::Release();
- exit(0);
diff --git a/doc/example.tosql b/doc/example.tosql
deleted file mode 100755
index 5dbf2b2..0000000
--- a/doc/example.tosql
+++ /dev/null
@@ -1,9 +0,0 @@
-#!/bin/sh
-if [ -n "$1" ]; then
- table=$1
-else
- table='test'
-fi
-grep '^\[' | sed "s/^\[[^]]*\]/INSERT INTO $table (geom) VALUES ('/" | sed "s/$/');/" | sed 's/LINEARRING/LINESTRING/g'
Summary of changes:
doc/CMakeLists.txt | 3 -
doc/example.cpp | 1154 ----------------------------------------------------
doc/example.tosql | 9 -
3 files changed, 1166 deletions(-)
delete mode 100644 doc/example.cpp
delete mode 100755 doc/example.tosql
hooks/post-receive
More information about the geos-commits
