[geos-commits] [SCM] GEOS branch 3.9 updated. 7c2f400cb870e33f01a84da5308546dd965749bb
Wed Jan 27 13:52:20 PST 2021
the project "GEOS".
The branch, 3.9 has been updated
       via  7c2f400cb870e33f01a84da5308546dd965749bb (commit)
      from  a5890d8f9ee7737d697e23b19100a86333fcb665 (commit)
revisions in full, below.
commit 7c2f400cb870e33f01a84da5308546dd965749bb
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon Jan 25 13:19:56 2021 -0800
    Fix OverlayNG line ordering
diff --git a/include/geos/operation/overlayng/EdgeMerger.h b/include/geos/operation/overlayng/EdgeMerger.h
index b67233a..c02eda7 100644
--- a/include/geos/operation/overlayng/EdgeMerger.h
+++ b/include/geos/operation/overlayng/EdgeMerger.h
@@ -59,32 +59,23 @@ namespace overlayng { // geos.operation.overlayng
  * This ensures that the overlay output line direction will be as consistent
  * as possible with input lines.
+ * The merger also preserves the order of the edges in the input.
+ * This means that for polygon-line overlay
+ * the result lines will be in the same order as in the input
+ * (possibly with multiple result lines for a single input line).
  * @author mdavis
 class GEOS_DLL EdgeMerger {
-private:
-    // Members
-    std::vector<Edge*>& edges;
-    std::map<EdgeKey, Edge*> edgeMap;
 public:
-    // Methods
-    EdgeMerger(std::vector<Edge*>& p_edges);
     static std::vector<Edge*> merge(std::vector<Edge*>& edges);
-    std::vector<Edge*> merge();
 } // namespace geos.operation.overlayng
 } // namespace geos
diff --git a/src/operation/overlayng/EdgeMerger.cpp b/src/operation/overlayng/EdgeMerger.cpp
index 605180c..205dcdb 100644
--- a/src/operation/overlayng/EdgeMerger.cpp
+++ b/src/operation/overlayng/EdgeMerger.cpp
@@ -23,23 +23,12 @@ namespace geos {      // geos
 namespace operation { // geos.operation
-EdgeMerger::EdgeMerger(std::vector<Edge*>& p_edges)
-    : edges(p_edges) {}
 /*public static */
 std::vector<Edge*>
 EdgeMerger::merge(std::vector<Edge*>& edges)
-    EdgeMerger merger(edges);
-    return merger.merge();
-/*public static */
-std::vector<Edge*>
-EdgeMerger::merge()
     std::vector<Edge*> mergedEdges;
+    std::map<EdgeKey, Edge*> edgeMap;
     for (Edge* edge : edges) {
         EdgeKey edgeKey(edge);
@@ -47,6 +36,7 @@ EdgeMerger::merge()
         if (it == edgeMap.end()) {
             // this is the first (and maybe only) edge for this line
             edgeMap[edgeKey] = edge;
+            mergedEdges.push_back(edge);
             //Debug.println("edge added: " + edge);
             //Debug.println(edge.toLineString());
@@ -69,11 +59,6 @@ EdgeMerger::merge()
-    // copy map values into return vector
-    for (auto it: edgeMap) {
-        mergedEdges.push_back(it.second);
     return mergedEdges;
diff --git a/tests/unit/index/chain/MonotoneChainBuilderTest.cpp b/tests/unit/index/chain/MonotoneChainBuilderTest.cpp
index 08e5015..75995d7 100644
--- a/tests/unit/index/chain/MonotoneChainBuilderTest.cpp
+++ b/tests/unit/index/chain/MonotoneChainBuilderTest.cpp
@@ -2,6 +2,7 @@
 // Test Suite for geos::index::chain::MonotoneChainBuilder class.
 #include <tut/tut.hpp>
+#include <utility.h>
 // geos
 #include <geos/io/WKTReader.h>
 #include <geos/io/WKTWriter.h>
@@ -46,28 +47,14 @@ void object::test<1>
     std::string wkt2("POLYGON((0.1 0.1, 4.0 0.1, 4.0 1.9, 0.1 1.9, 0.1 0.1))");
     std::unique_ptr<geos::geom::Geometry> g2(wktreader.read(wkt2));
-    // POLYGON ((2.0 1.9, 4.0 1.9, 4.0 0.1, 2.0 0.1, 2.0 1.9))
-    double x[5] = {2.0, 4.0, 4.0, 2.0, 2.0};
-    double y[5] = {1.9, 1.9, 0.1, 0.1, 1.9};
+    auto result = g2->difference(g1.get());
+    result->normalize();
-    auto g3 = g2->difference(g1.get());
-    auto cs = g3->getCoordinates();
-    // std::string wkt3 = wktwriter.write(g3.get());
-    // std::cout << wkt3 << std::endl;
-    for (int i = 0; i < 5; ++i)
-        auto csx = cs->getOrdinate(i, 0);
-        auto csy = cs->getOrdinate(i, 1);
-        // std::cout << csx << ", " << csy << std::endl;
-        // std::cout << x[i] << ", " << y[i] << std::endl;
-        ensure_equals("x", csx, x[i], 0.01);
-        ensure_equals("y", csy, y[i], 0.01);
+    std::string wktExpected("POLYGON ((2 0.1, 2 1.9, 4 1.9, 4 0.1, 2 0.1))");
+    std::unique_ptr<geos::geom::Geometry> expected(wktreader.read(wktExpected));
+    ensure_equals_geometry(expected.get(), result.get());
 } // namespace tut
diff --git a/tests/unit/operation/overlayng/OverlayNGTest.cpp b/tests/unit/operation/overlayng/OverlayNGTest.cpp
index 479597c..b753159 100644
--- a/tests/unit/operation/overlayng/OverlayNGTest.cpp
+++ b/tests/unit/operation/overlayng/OverlayNGTest.cpp
@@ -45,6 +45,24 @@ struct test_overlayng_data {
     void
+    testOverlayExact(const std::string& a, const std::string& b, const std::string& expected, int opCode, double scaleFactor)
+        std::unique_ptr<PrecisionModel> pm;
+        if (scaleFactor > 0)
+            pm.reset(new PrecisionModel(scaleFactor));
+        else
+            pm.reset(new PrecisionModel());
+        std::unique_ptr<Geometry> geom_a = r.read(a);
+        std::unique_ptr<Geometry> geom_b = r.read(b);
+        std::unique_ptr<Geometry> geom_expected = r.read(expected);
+        std::unique_ptr<Geometry> geom_result = OverlayNG::overlay(geom_a.get(), geom_b.get(), opCode, pm.get());
+        // std::string wkt_result = w.write(geom_result.get());
+        // std::cout << std::endl << wkt_result << std::endl;
+        ensure_equals_exact_geometry(geom_expected.get(), geom_result.get(), 0);
+    void
     testOverlayNoOpt(const std::string& a, const std::string& b, const std::string& expected, int opCode, double scaleFactor)
         PrecisionModel pm(scaleFactor);
@@ -531,4 +549,14 @@ void object::test<42> ()
     testOverlay(a, b, exp, OverlayNG::INTERSECTION, 0);
+template<>
+template<>
+void object::test<43> ()
+    std::string a = "POLYGON ((1 1, 1 9, 9 9, 9 7, 3 7, 3 3, 9 3, 9 1, 1 1))";
+    std::string b = "MULTILINESTRING ((2 10, 2 0), (4 10, 4 0))";
+    std::string exp = "MULTILINESTRING ((2 9, 2 1), (4 9, 4 7), (4 3, 4 1))";
+    testOverlay(a, b, exp, OverlayNG::INTERSECTION, 0);
 } // namespace tut
diff --git a/tests/unit/utility.h b/tests/unit/utility.h
index 08f14e1..65781e8 100644
--- a/tests/unit/utility.h
+++ b/tests/unit/utility.h
@@ -327,6 +327,49 @@ ensure_equals_geometry_xyz(const T *lhs_in,
     ensure_equals_exact_geometry_xyz(g1.get(), g2.get(), tolerance);
+ * Checks for geometries exactly equal in XY only
+template <typename T> inline void ensure_equals_exact_geometry(const T *lhs_in, const T *rhs_in, double tolerance = 0.0);
+template <>
+inline void
+ensure_equals_exact_geometry(const geos::geom::Geometry *lhs_in,
+                                 const geos::geom::Geometry *rhs_in,
+                                 double tolerance)
+    assert(nullptr != lhs_in);
+    assert(nullptr != rhs_in);
+    using geos::geom::Point;
+    using geos::geom::LineString;
+    using geos::geom::Polygon;
+    using geos::geom::CoordinateSequence;
+    using geos::geom::GeometryCollection;
+    ensure_equals("type id do not match",
+                  lhs_in->getGeometryTypeId(), rhs_in->getGeometryTypeId());
+    if (const Point* gpt1 = dynamic_cast<const Point *>(lhs_in)) {
+      const Point *gpt2 = static_cast<const Point *>(rhs_in);
+      return ensure_equals_dims( gpt1->getCoordinatesRO(), gpt2->getCoordinatesRO(), 2, tolerance);
+    else if (const LineString* gln1 = dynamic_cast<const LineString *>(lhs_in)) {
+      const LineString *gln2 = static_cast<const LineString *>(rhs_in);
+      return ensure_equals_dims( gln1->getCoordinatesRO(), gln2->getCoordinatesRO(), 2, tolerance);
+    else if (dynamic_cast<const Polygon *>(lhs_in)) {
+      assert("Not implemented yet" == 0);
+    else if (const GeometryCollection* gc1 = dynamic_cast<const GeometryCollection *>(lhs_in)) {
+      const GeometryCollection *gc2 = static_cast<const GeometryCollection *>(rhs_in);
+      for (unsigned int i = 0; i < gc1->getNumGeometries(); i++) {
+        ensure_equals_exact_geometry(gc1->getGeometryN(i), gc2->getGeometryN(i), tolerance);
 // Utility functions
@@ -353,4 +396,3 @@ struct wkb_hex_decoder {
 } // namespace tut
 #endif // #ifndef GEOS_TUT_UTILITY_H_INCLUDED
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 5a747fc..f4d1ac3 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -1312,6 +1312,7 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
         else if(opName == "union") {
             GeomPtr gRes(parseGeometry(opRes, "expected"));
+            gRes->normalize();
             profile.start();
@@ -1324,6 +1325,7 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
             profile.stop();
+            gRealRes->normalize();
             success = checkOverlaySuccess(*gRes, *gRealRes);
@@ -2414,4 +2416,3 @@ main(int argC, char* argV[])
  * Revision 1.29  2006/03/17 14:56:39  strk
  * Fixed filename normalizer for sql output
Summary of changes:
 include/geos/operation/overlayng/EdgeMerger.h      | 19 +++-------
 src/operation/overlayng/EdgeMerger.cpp             | 19 +---------
 .../unit/index/chain/MonotoneChainBuilderTest.cpp  | 25 +++---------
 tests/unit/operation/overlayng/OverlayNGTest.cpp   | 28 ++++++++++++++
 tests/unit/utility.h                               | 44 +++++++++++++++++++++-
 tests/xmltester/XMLTester.cpp                      |  3 +-
 6 files changed, 86 insertions(+), 52 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
