[geos-commits] [SCM] GEOS branch master updated. c03c6856210a8e1cc7c8bb399e8972a6debfedd1
git at osgeo.org
git at osgeo.org
Thu Jan 28 17:46:32 PST 2021
the project "GEOS".
via c03c6856210a8e1cc7c8bb399e8972a6debfedd1 (commit)
via 825b7662392f75bcd85239d0f4b6f8c4c0311f5b (commit)
from 08c3fc5aaa097a602a7747c76cd3ce95670f14fb (commit)
revisions in full, below.
commit c03c6856210a8e1cc7c8bb399e8972a6debfedd1
Merge: 08c3fc5 825b766
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Jan 28 20:46:22 2021 -0500
Merge branch 'rm-travis'
commit 825b7662392f75bcd85239d0f4b6f8c4c0311f5b
Date: Wed Jan 27 19:35:50 2021 -0500
Remove Travis configuration [ci skip]
diff --git a/.travis.yml b/.travis.yml
deleted file mode 100644
index 707fc74..0000000
--- a/.travis.yml
+++ /dev/null
@@ -1,140 +0,0 @@
-# .travis.yml - Travis CI service configuration for GEOS
-# This is free software; you can redistribute and/or modify it under
-# the terms of the GNU Lesser General Public Licence as published
-# by the Free Software Foundation.
-# See the COPYING file for more information.
-dist: xenial
-sudo: false
-language: cpp
-ref:
- sources: &sources
- - ubuntu-toolchain-r-test
- - george-edison55-precise-backports
-matrix:
- fast_finish: true
- include:
- - os: linux
- cache:
- apt: true
- directories:
- - $HOME/.ccache
- addons:
- apt:
- sources: *sources
- packages: ['g++-7','cmake','ccache','doxygen']
- env:
- - E="TOOL=cmake && BUILD_TYPE=Release && CXX=g++-7 && ARCH=-m64 && CC=gcc-7"
- - os: linux
- cache:
- apt: true
- directories:
- - $HOME/.ccache
- addons:
- apt:
- sources: *sources
- env:
- - E="TOOL=cmake && BUILD_TYPE=Coverage && CXX=g++-7 && ARCH=-m64 && CC=gcc-7"
- - os: linux
- cache:
- apt: true
- directories:
- - $HOME/.ccache
- addons:
- apt:
- sources: *sources
- packages: ['g++-4.8','cmake','ccache','doxygen']
- env:
- - E="TOOL=cmake && BUILD_TYPE=Release && CXX=g++-4.8 && ARCH=-m64 && CC=gcc-4.8"
- - os: linux
- cache:
- apt: true
- directories:
- - $HOME/.ccache
- addons:
- apt:
- sources: *sources
- packages: ['clang-3.9','cmake','ccache','doxygen']
- env:
- - E="TOOL=cmake && BUILD_TYPE=Release && CXX=clang++-3.9 && ARCH=-m64 && CC=clang-3.9"
- - os: linux
- cache:
- apt: true
- directories:
- - $HOME/.ccache
- addons:
- apt:
- sources: *sources
- packages: ['clang','cmake','ccache','doxygen']
- env:
- - E="TOOL=cmake && BUILD_TYPE=Release && CXX=clang++ && ARCH=-m64 && CC=clang"
- - os: linux
- dist: bionic
- arch: arm64
- cache:
- apt: true
- directories:
- - $HOME/.ccache
- addons:
- apt:
- sources:
- packages: ['doxygen']
- env:
- - E="TOOL=cmake && BUILD_TYPE=Release && CXX=clang++ && CC=clang"
- # - os: linux
- # dist: bionic
- # arch: s390x
- # cache:
- # apt: true
- # directories:
- # - $HOME/.ccache
- # addons:
- # apt:
- # sources:
- # - ubuntu-toolchain-r-test
- # packages: ['doxygen']
- # env:
- # - E="TOOL=cmake && BUILD_TYPE=Release && CXX=clang++ && CC=clang"
-before_install:
- - eval "${E}"
- - export CXXFLAGS=${ARCH}
- - export CFLAGS=${ARCH}
- - export GEOS_BUILD_TOOL=${TOOL}
- - export BUILD_TYPE=${BUILD_TYPE}
- - export CXX="ccache ${CXX}"
- - ${CXX} --version
-script: ./tools/ci/script.sh
-notifications:
- irc:
- channels:
- - "chat.freenode.net#postgis-activity"
- on_success: always # [always|never|change] # default: change
- on_failure: always # [always|never|change] # default: always
- use_notice: false
- email:
- recipients:
- - geos-devel at lists.osgeo.org
- on_success: change
- webhooks:
- urls:
- - https://webhooks.gitter.im/e/a38e35772d115f246fb9
- on_success: always # options: [always|never|change] default: always
- on_failure: always # options: [always|never|change] default: always
- on_start: always # options: [always|never|change] default: always
diff --git a/README.md b/README.md
index 00d4c17..28dda0d 100644
--- a/README.md
+++ b/README.md
@@ -12,11 +12,11 @@ More information is available the [project homepage](https://trac.osgeo.org/geos
## Build status
-| branch / CI | Debbie | Winnie | Dronie | Travis CI | GitLab CI | AppVeyor | GitHub | Bessie | Bessie32 |
-| master | [![debbie](https://debbie.postgis.net/buildStatus/icon?job=GEOS_Master)](https://debbie.postgis.net/view/GEOS/job/GEOS_Master/) | [![winnie](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Master/badge/icon)](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Master/) | [![dronie](https://dronie.osgeo.org/api/badges/geos/geos/status.svg?branch=master)](https://dronie.osgeo.org/geos/geos?branch=master) | [![travis](https://travis-ci.com/libgeos/geos.svg?branch=master)](https://travis-ci.com/libgeos/geos?branch=master) | [![gitlab-ci](https://gitlab.com/geos/libgeos/badges/master/pipeline.svg)](https://gitlab.com/geos/libgeos/commits/master) | [![appveyor](https://ci.appveyor.com/api/projects/status/62aplwst722b89au/branch/master?svg=true)](https://ci.appveyor.com/project/dbaston/geos/branch/master) | [![github](https://github.com/libgeos/geos/workflows/CI/badge.svg?branch=master)](https://github.com/libgeos/geos/actions?query=workflow%3ACI) | [![bessie](https://debbi
e.postgis.net/buildStatus/icon?job=GEOS_Worker_Run/label=bessie&BRANCH=master)](https://debbie.postgis.net/view/GEOS/job/GEOS_Worker_Run/label=bessie) | [![bessie32](https://debbie.postgis.net/buildStatus/icon?job=GEOS_Worker_Run/label=bessie32&BRANCH=master)](https://debbie.postgis.net/view/GEOS/job/GEOS_Worker_Run/label=bessie32)
-| 3.8 | [![debbie](https://debbie.postgis.net/buildStatus/icon?job=GEOS_Branch_3.8)](https://debbie.postgis.net/view/GEOS/job/GEOS_Branch_3.8/) | [![winnie](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.8/badge/icon)](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.8/) | [![dronie](https://dronie.osgeo.org/api/badges/geos/geos/status.svg?branch=3.8)](https://dronie.osgeo.org/geos/geos?branch=3.8) | [![travis](https://travis-ci.com/libgeos/geos.svg?branch=3.8)](https://travis-ci.com/libgeos/geos?branch=3.8) | [![gitlab-ci](https://gitlab.com/geos/libgeos/badges/3.8/pipeline.svg)](https://gitlab.com/geos/libgeos/commits/3.8) | [![appveyor](https://ci.appveyor.com/api/projects/status/62aplwst722b89au/branch/3.8?svg=true)](https://ci.appveyor.com/project/dbaston/geos/branch/3.8) | [![github](https://github.com/libgeos/geos/workflows/CI/badge.svg?branch=3.8)](https://github.com/libgeos/geos/actions?query=workflow%3ACI) |
-| 3.7 | [![debbie](https://debbie.postgis.net/buildStatus/icon?job=GEOS_Branch_3.7)](https://debbie.postgis.net/view/GEOS/job/GEOS_Branch_3.7/) | [![winnie](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.7/badge/icon)](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.7/) | [![dronie](https://dronie.osgeo.org/api/badges/geos/geos/status.svg?branch=3.7)](https://dronie.osgeo.org/geos/geos?branch=3.7) | [![travis](https://travis-ci.com/libgeos/geos.svg?branch=3.7)](https://travis-ci.com/libgeos/geos?branch=3.7) | [![gitlab-ci](https://gitlab.com/geos/libgeos/badges/3.7/pipeline.svg)](https://gitlab.com/geos/libgeos/commits/3.7) | [![appveyor](https://ci.appveyor.com/api/projects/status/62aplwst722b89au/branch/3.7?svg=true)](https://ci.appveyor.com/project/dbaston/geos/branch/3.7) | [![github](https://github.com/libgeos/geos/workflows/CI/badge.svg?branch=3.7)](https://github.com/libgeos/geos/actions?query=workflow%3ACI) |
+| branch / CI | Debbie | Winnie | Dronie | GitLab CI | AppVeyor | GitHub | Bessie | Bessie32 |
+| master | [![debbie](https://debbie.postgis.net/buildStatus/icon?job=GEOS_Master)](https://debbie.postgis.net/view/GEOS/job/GEOS_Master/) | [![winnie](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Master/badge/icon)](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Master/) | [![dronie](https://dronie.osgeo.org/api/badges/geos/geos/status.svg?branch=master)](https://dronie.osgeo.org/geos/geos?branch=master) | [![gitlab-ci](https://gitlab.com/geos/libgeos/badges/master/pipeline.svg)](https://gitlab.com/geos/libgeos/commits/master) | [![appveyor](https://ci.appveyor.com/api/projects/status/62aplwst722b89au/branch/master?svg=true)](https://ci.appveyor.com/project/dbaston/geos/branch/master) | [![github](https://github.com/libgeos/geos/workflows/CI/badge.svg?branch=master)](https://github.com/libgeos/geos/actions?query=workflow%3ACI) | [![bessie](https://debbie.postgis.net/buildStatus/icon?job=GEOS_Worker_Run/label=bessie&BRANCH=master)](https://debbie.postgis.net/view/GEOS/j
+| 3.8 | [![debbie](https://debbie.postgis.net/buildStatus/icon?job=GEOS_Branch_3.8)](https://debbie.postgis.net/view/GEOS/job/GEOS_Branch_3.8/) | [![winnie](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.8/badge/icon)](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.8/) | [![dronie](https://dronie.osgeo.org/api/badges/geos/geos/status.svg?branch=3.8)](https://dronie.osgeo.org/geos/geos?branch=3.8) | [![gitlab-ci](https://gitlab.com/geos/libgeos/badges/3.8/pipeline.svg)](https://gitlab.com/geos/libgeos/commits/3.8) | [![appveyor](https://ci.appveyor.com/api/projects/status/62aplwst722b89au/branch/3.8?svg=true)](https://ci.appveyor.com/project/dbaston/geos/branch/3.8) | [![github](https://github.com/libgeos/geos/workflows/CI/badge.svg?branch=3.8)](https://github.com/libgeos/geos/actions?query=workflow%3ACI) |
+| 3.7 | [![debbie](https://debbie.postgis.net/buildStatus/icon?job=GEOS_Branch_3.7)](https://debbie.postgis.net/view/GEOS/job/GEOS_Branch_3.7/) | [![winnie](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.7/badge/icon)](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.7/) | [![dronie](https://dronie.osgeo.org/api/badges/geos/geos/status.svg?branch=3.7)](https://dronie.osgeo.org/geos/geos?branch=3.7) | [![gitlab-ci](https://gitlab.com/geos/libgeos/badges/3.7/pipeline.svg)](https://gitlab.com/geos/libgeos/commits/3.7) | [![appveyor](https://ci.appveyor.com/api/projects/status/62aplwst722b89au/branch/3.7?svg=true)](https://ci.appveyor.com/project/dbaston/geos/branch/3.7) | [![github](https://github.com/libgeos/geos/workflows/CI/badge.svg?branch=3.7)](https://github.com/libgeos/geos/actions?query=workflow%3ACI) |
## Build/install
Summary of changes:
.travis.yml | 140 ------------------------------------------------------------
README.md | 10 ++---
2 files changed, 5 insertions(+), 145 deletions(-)
delete mode 100644 .travis.yml
hooks/post-receive
More information about the geos-commits
