[geos-commits] [SCM] GEOS branch 3.7 updated. 81bff22258238d4fd5885bcbdcfefc7507f94280
Tue Jul 6 12:01:17 PDT 2021
the project "GEOS".
The branch, 3.7 has been updated
       via  81bff22258238d4fd5885bcbdcfefc7507f94280 (commit)
      from  51dd077734cab54127b5831d4c83794ce7efbcbf (commit)
revisions in full, below.
commit 81bff22258238d4fd5885bcbdcfefc7507f94280
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jul 6 12:01:12 2021 -0700
    Remove dead cmake code
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 19988b0..9fde6dc 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -50,24 +50,12 @@ jobs:
     - name: 'Build'
       run: |
         set -e
-        if [ ${{ matrix.ci.build }} == 'cmake' ];
-        then
-          mkdir build.cmake
-          cd build.cmake
-          cmake --version
-          cmake -DCMAKE_CXX_COMPILER=${{ matrix.ci.compiler }} -DCMAKE_CXX_STANDARD=${{ matrix.ci.cxxstd }} -DBUILD_DOCUMENTATION=YES -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
-          make
-          cmake --build . --target docs
-          ctest --output-on-failure .
-        else
-          set -e
-          ./autogen.sh
-          mkdir build.autotools
-          cd build.autotools
-          CFLAGS="-std=c++${{ matrix.ci.cxxstd }} -m${{ matrix.ci.arch }}"
-          ../configure CC=${{ matrix.ci.compiler }} CXX=${{ matrix.ci.compiler }} CXXFLAGS="$CFLAGS" CFLAGS="$CFLAGS"
-          make && make check && make distcheck
-        fi
+        ./autogen.sh
+        mkdir build.autotools
+        cd build.autotools
+        export CFLAGS="-std=c++${{ matrix.ci.cxxstd }} -m${{ matrix.ci.arch }}"
+        ../configure CC=${{ matrix.ci.compiler }} CXX=${{ matrix.ci.compiler }} CXXFLAGS="$CFLAGS" CFLAGS="$CFLAGS"
+        make && make check && make distcheck
Summary of changes:
 .github/workflows/ci.yml | 24 ++++++------------------
 1 file changed, 6 insertions(+), 18 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
