[geos-commits] [SCM] GEOS branch main updated. 67a1b10487bbbe3df8d746fd44ec42d3f91eb949
Wed Jul 14 14:38:10 PDT 2021
the project "GEOS".
The branch, main has been updated
       via  67a1b10487bbbe3df8d746fd44ec42d3f91eb949 (commit)
      from  1bfc5b27493c552fd9a28823358a4c1f4c3b65f7 (commit)
revisions in full, below.
commit 67a1b10487bbbe3df8d746fd44ec42d3f91eb949
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jul 14 14:38:06 2021 -0700
    Remove un-used SnapIfNeededOverlayOp
diff --git a/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h b/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h
deleted file mode 100644
index 4d4843a..0000000
--- a/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h
+++ /dev/null
@@ -1,111 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2009 2011  Sandro Santilli <strk at kbt.io>
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Last port: operation/overlay/snap/SnapIfNeededOverlayOp.java r320 (JTS-1.12)
-#ifndef GEOS_OP_OVERLAY_SNAP_SNAPIFNEEDEDOVERLAYOP_H
-#define GEOS_OP_OVERLAY_SNAP_SNAPIFNEEDEDOVERLAYOP_H
-#include <geos/operation/overlay/OverlayOp.h> // for enums
-#include <memory> // for unique_ptr
-// Forward declarations
-namespace geos {
-namespace geom {
-class Geometry;
-namespace geos {
-namespace operation { // geos::operation
-namespace overlay { // geos::operation::overlay
-namespace snap { // geos::operation::overlay::snap
-/** \brief
- * Performs an overlay operation using snapping and enhanced precision
- * to improve the robustness of the result.
- * This class only uses snapping if an error is detected when running
- * the standard JTS overlay code. Errors detected include thrown exceptions
- * (in particular, [TopologyException](@ref util::TopologyException))
- * and invalid overlay computations.
-class SnapIfNeededOverlayOp {
-public:
-    static std::unique_ptr<geom::Geometry>
-    overlayOp(const geom::Geometry& g0, const geom::Geometry& g1,
-              OverlayOp::OpCode opCode)
-        SnapIfNeededOverlayOp op(g0, g1);
-        return op.getResultGeometry(opCode);
-    intersection(const geom::Geometry& g0, const geom::Geometry& g1)
-        return overlayOp(g0, g1, OverlayOp::opINTERSECTION);
-    Union(const geom::Geometry& g0, const geom::Geometry& g1)
-        return overlayOp(g0, g1, OverlayOp::opUNION);
-    difference(const geom::Geometry& g0, const geom::Geometry& g1)
-        return overlayOp(g0, g1, OverlayOp::opDIFFERENCE);
-    symDifference(const geom::Geometry& g0, const geom::Geometry& g1)
-        return overlayOp(g0, g1, OverlayOp::opSYMDIFFERENCE);
-    SnapIfNeededOverlayOp(const geom::Geometry& g1, const geom::Geometry& g2)
-        geom0(g1),
-        geom1(g2)
-    typedef std::unique_ptr<geom::Geometry> GeomPtr;
-    GeomPtr getResultGeometry(OverlayOp::OpCode opCode);
-private:
-    const geom::Geometry& geom0;
-    const geom::Geometry& geom1;
-    // Declare type as noncopyable
-    SnapIfNeededOverlayOp(const SnapIfNeededOverlayOp& other) = delete;
-    SnapIfNeededOverlayOp& operator=(const SnapIfNeededOverlayOp& rhs) = delete;
-} // namespace geos::operation::overlay::snap
-#endif // ndef GEOS_OP_OVERLAY_SNAP_SNAPIFNEEDEDOVERLAYOP_H
diff --git a/include/geos/operation/union/UnaryUnionOp.h b/include/geos/operation/union/UnaryUnionOp.h
index 0ba3de9..eb1bfe8 100644
--- a/include/geos/operation/union/UnaryUnionOp.h
+++ b/include/geos/operation/union/UnaryUnionOp.h
@@ -30,7 +30,6 @@
 #include <geos/geom/util/GeometryExtracter.h>
 #include <geos/operation/union/CascadedPolygonUnion.h>
-//#include <geos/operation/overlay/snap/SnapIfNeededOverlayOp.h>
 #ifdef _MSC_VER
 #pragma warning(push)
@@ -199,12 +198,10 @@ private:
     unionNoOpt(const geom::Geometry& g0)
         using geos::operation::overlay::OverlayOp;
-        //using geos::operation::overlay::snap::SnapIfNeededOverlayOp;
         if(! empty.get()) {
             empty = geomFact->createEmptyGeometry();
-        //return SnapIfNeededOverlayOp::overlayOp(g0, *empty, OverlayOp::opUNION);
         return unionFunction->Union(&g0, empty.get());
diff --git a/src/geom/Geometry.cpp b/src/geom/Geometry.cpp
index 49c05f3..ff5822b 100644
--- a/src/geom/Geometry.cpp
+++ b/src/geom/Geometry.cpp
@@ -47,7 +47,6 @@
 #include <geos/operation/valid/IsValidOp.h>
 #include <geos/operation/union/UnaryUnionOp.h>
-#include <geos/operation/overlay/snap/SnapIfNeededOverlayOp.h>
 #include <geos/operation/buffer/BufferOp.h>
 #include <geos/operation/distance/DistanceOp.h>
 #include <geos/operation/valid/IsSimpleOp.h>
@@ -77,7 +76,6 @@ using namespace geos::operation::valid;
 using namespace geos::operation::relate;
 using namespace geos::operation::buffer;
 using namespace geos::operation::overlay;
-using namespace geos::operation::overlay::snap;
 using namespace geos::operation::distance;
 using namespace geos::operation;
diff --git a/src/operation/overlay/snap/SnapIfNeededOverlayOp.cpp b/src/operation/overlay/snap/SnapIfNeededOverlayOp.cpp
index 7fd2df4..0000000
--- a/src/operation/overlay/snap/SnapIfNeededOverlayOp.cpp
+++ /dev/null
@@ -1,82 +0,0 @@
-#include <geos/operation/overlay/snap/SnapOverlayOp.h>
-#include <geos/geom/Geometry.h> // for use in unique_ptr
-#include <geos/util.h>
-#include <cassert>
-#include <limits> // for numeric_limits
-#ifndef GEOS_DEBUG
-#define GEOS_DEBUG 0
-#endif
-using namespace geos::geom;
-namespace geos {
-namespace operation { // geos.operation
-namespace overlay { // geos.operation.overlay
-namespace snap { // geos.operation.overlay.snap
-/* public */
-std::unique_ptr<Geometry>
-SnapIfNeededOverlayOp::getResultGeometry(OverlayOp::OpCode opCode)
-    using geos::util::TopologyException;
-    std::unique_ptr<Geometry> result;
-    TopologyException origEx;
-    // Try with original input
-    try {
-        result.reset(OverlayOp::overlayOp(&geom0, &geom1, opCode));
-        return result;
-    catch(const TopologyException& ex) {
-        origEx = ex; // save original exception
-#if GEOS_DEBUG
-        std::cerr << "Overlay op threw " << ex.what() << ". Will try snapping now" << std::endl;
-#endif
-    // Try snapping
-    try {
-        result = SnapOverlayOp::overlayOp(geom0, geom1, opCode);
-        return result;
-        ::geos::ignore_unused_variable_warning(ex);
-#if GEOS_DEBUG
-        std::cerr << "Overlay op on snapped geoms threw " << ex.what() << ". Will try snapping now" << std::endl;
-#endif
-        throw origEx;
-} // namespace geos.operation.snap
-} // namespace geos.operation.overlay
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index 92d7bba..3741dd9 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -274,7 +274,6 @@ ClassicUnionStrategy::Union(const geom::Geometry* g0, const geom::Geometry* g1)
     // TODO make an rvalue overload for this that can consume its inputs.
     // At a minimum, a copy in the buffer fallback can be eliminated.
     try {
-        // return SnapIfNeededOverlayOp.union(g0, g1);
         return geom::HeuristicOverlay(g0, g1, overlay::OverlayOp::opUNION);
     catch (const util::TopologyException &ex) {
Summary of changes:
 .../operation/overlay/snap/SnapIfNeededOverlayOp.h | 111 ---------------------
 include/geos/operation/union/UnaryUnionOp.h        |   3 -
 src/geom/Geometry.cpp                              |   2 -
 .../overlay/snap/SnapIfNeededOverlayOp.cpp         |  82 ---------------
 src/operation/union/CascadedPolygonUnion.cpp       |   1 -
 5 files changed, 199 deletions(-)
 delete mode 100644 include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h
 delete mode 100644 src/operation/overlay/snap/SnapIfNeededOverlayOp.cpp
hooks/post-receive
More information about the geos-commits mailing list
